[PULL] u-boot-sh/master_rzn1/rzn1
The following changes since commit e94fbdd2729fdcd570035d43f67adda8e0dfc115:
Merge https://source.denx.de/u-boot/custodians/u-boot-x86 (2023-05-11 08:40:33 -0400)
https://source.denx.de/u-boot/custodians/u-boot-sh.git master_rzn1/rzn1
for you to fetch changes up to a5b9f959439bbf5492f9a0c42c6c81a4d008ac46:
doc: renesas: add Renesas board docs (2023-05-13 04:24:05 +0200)
---------------------------------------------------------------- Ralph Siemsen (10): ARM: armv7: add non-SPL enable for Cortex SMPEN clk: renesas: prepare for non R-Car clock drivers clk: renesas: add R906G032 driver pinctrl: renesas: add R906G032 driver ram: cadence: add driver for Cadence EDAC ARM: dts: add devicetree for Renesas RZ/N1 SoC ARM: rmobile: Add support for Renesas RZ/N1 SoC board: schneider: add RZN1 board support tools: spkgimage: add Renesas SPKG format doc: renesas: add Renesas board docs
arch/arm/cpu/armv7/Kconfig | 5 + arch/arm/dts/r9a06g032-ddr.dtsi | 512 ++++++++++ arch/arm/dts/r9a06g032-rzn1-snarc-u-boot.dtsi | 23 + arch/arm/dts/r9a06g032-rzn1-snarc.dts | 92 ++ arch/arm/dts/r9a06g032.dtsi | 477 +++++++++ arch/arm/mach-rmobile/Kconfig | 19 + arch/arm/mach-rmobile/Kconfig.rzn1 | 20 + arch/arm/mach-rmobile/cpu_info.c | 10 +- board/schneider/rzn1-snarc/Kconfig | 18 + board/schneider/rzn1-snarc/Makefile | 3 + board/schneider/rzn1-snarc/rzn1.c | 31 + board/schneider/rzn1-snarc/spkgimage.cfg | 26 + boot/image.c | 1 + configs/rzn1_snarc_defconfig | 24 + doc/board/index.rst | 1 + doc/board/renesas/index.rst | 10 + doc/board/renesas/renesas.rst | 45 + doc/board/renesas/rzn1.rst | 76 ++ doc/mkimage.1 | 45 + drivers/clk/renesas/Kconfig | 15 +- drivers/clk/renesas/Makefile | 3 +- drivers/clk/renesas/r9a06g032-clocks.c | 1103 +++++++++++++++++++++ drivers/pinctrl/Makefile | 1 + drivers/pinctrl/renesas/Kconfig | 7 + drivers/pinctrl/renesas/Makefile | 1 + drivers/pinctrl/renesas/pinctrl-rzn1.c | 379 +++++++ drivers/ram/Kconfig | 1 + drivers/ram/Makefile | 3 + drivers/ram/cadence/Kconfig | 12 + drivers/ram/cadence/Makefile | 1 + drivers/ram/cadence/ddr_ctrl.c | 414 ++++++++ drivers/ram/renesas/Makefile | 3 + drivers/ram/renesas/rzn1/Makefile | 3 + drivers/ram/renesas/rzn1/ddr_async.c | 376 +++++++ include/configs/rzn1-snarc.h | 13 + include/dt-bindings/clock/r9a06g032-sysctrl.h | 149 +++ include/dt-bindings/pinctrl/rzn1-pinctrl.h | 141 +++ include/image.h | 1 + include/renesas/ddr_ctrl.h | 175 ++++ include/renesas/is43tr16256a_125k_CTL.h | 419 ++++++++ include/renesas/jedec_ddr3_2g_x16_1333h_500_cl8.h | 399 ++++++++ tools/Makefile | 1 + tools/renesas_spkgimage.c | 336 +++++++ tools/renesas_spkgimage.h | 87 ++ 44 files changed, 5477 insertions(+), 4 deletions(-) create mode 100644 arch/arm/dts/r9a06g032-ddr.dtsi create mode 100644 arch/arm/dts/r9a06g032-rzn1-snarc-u-boot.dtsi create mode 100644 arch/arm/dts/r9a06g032-rzn1-snarc.dts create mode 100644 arch/arm/dts/r9a06g032.dtsi create mode 100644 arch/arm/mach-rmobile/Kconfig.rzn1 create mode 100644 board/schneider/rzn1-snarc/Kconfig create mode 100644 board/schneider/rzn1-snarc/Makefile create mode 100644 board/schneider/rzn1-snarc/rzn1.c create mode 100644 board/schneider/rzn1-snarc/spkgimage.cfg create mode 100644 configs/rzn1_snarc_defconfig create mode 100644 doc/board/renesas/index.rst create mode 100644 doc/board/renesas/renesas.rst create mode 100644 doc/board/renesas/rzn1.rst create mode 100644 drivers/clk/renesas/r9a06g032-clocks.c create mode 100644 drivers/pinctrl/renesas/pinctrl-rzn1.c create mode 100644 drivers/ram/cadence/Kconfig create mode 100644 drivers/ram/cadence/Makefile create mode 100644 drivers/ram/cadence/ddr_ctrl.c create mode 100644 drivers/ram/renesas/Makefile create mode 100644 drivers/ram/renesas/rzn1/Makefile create mode 100644 drivers/ram/renesas/rzn1/ddr_async.c create mode 100644 include/configs/rzn1-snarc.h create mode 100644 include/dt-bindings/clock/r9a06g032-sysctrl.h create mode 100644 include/dt-bindings/pinctrl/rzn1-pinctrl.h create mode 100644 include/renesas/ddr_ctrl.h create mode 100644 include/renesas/is43tr16256a_125k_CTL.h create mode 100644 include/renesas/jedec_ddr3_2g_x16_1333h_500_cl8.h create mode 100644 tools/renesas_spkgimage.c create mode 100644 tools/renesas_spkgimage.h
