[U-Boot] [PATCH V2 1/2] mmc: add bcm2835 driver
This adds a simple driver for the BCM2835's SD controller.
Workarounds are implemented for: * Register writes can't be too close to each-other in time, or they will be lost. * Register accesses must all be 32-bit, so implement custom accessors.
This code was extracted from: git://github.com/gonzoua/u-boot-pi.git master which was created by Oleksandr Tymoshenko.
Portions of the code there were obviously based on the Linux kernel at: git://github.com/raspberrypi/linux.git rpi-3.6.y commit f5b930b "Main bcm2708 linux port" signed-off-by Dom Cobley.
swarren changed the following for upstream: * Removed hack udelay()s in bcm2835_sdhci_raw_writel(); setting SDHCI_QUIRK_WAIT_SEND_CMD appears to solve the issues. * Remove register logging from read*/write* functions. * Sort out confusion with min/max_freq values passed to add_sdhci(). * Use more descriptive variable names and calculations in IO accessors. * Simplified and commented twoticks_delay calculation. * checkpatch fixes.
Signed-off-by: Oleksandr Tymoshenko gonzo@bluezbox.com Signed-off-by: Stephen Warren swarren@wwwdotorg.org --- This series is based on the previous bcm2835 patches I sent, to add the mbox and video drivers. Patch 1 should be independant, but patch 2 depends on those other patches.
v2: * Use more descriptive variable names and calculations in IO accessors. * Add Oleksandr's S-o-b. * Rewrite commit description to note that the Linux code this was derived from was S-o-b Dom Cobley. --- arch/arm/include/asm/arch-bcm2835/sdhci.h | 24 ++++ drivers/mmc/Makefile | 1 + drivers/mmc/bcm2835_sdhci.c | 177 +++++++++++++++++++++++++++++ 3 files changed, 202 insertions(+) create mode 100644 arch/arm/include/asm/arch-bcm2835/sdhci.h create mode 100644 drivers/mmc/bcm2835_sdhci.c
diff --git a/arch/arm/include/asm/arch-bcm2835/sdhci.h b/arch/arm/include/asm/arch-bcm2835/sdhci.h new file mode 100644 index 0000000..a4f867b --- /dev/null +++ b/arch/arm/include/asm/arch-bcm2835/sdhci.h @@ -0,0 +1,24 @@ +/* + * (C) Copyright 2012 Stephen Warren + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License + * version 2 as published by the Free Software Foundation. + * + * This program is distributed in the hope that it will be useful, but + * WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + */ + +#ifndef _BCM2835_SDHCI_H_ +#define _BCM2835_SDHCI_H_ + +#define BCM2835_SDHCI_BASE 0x20300000 + +int bcm2835_sdhci_init(u32 regbase, u32 emmc_freq); + +#endif diff --git a/drivers/mmc/Makefile b/drivers/mmc/Makefile index a1dd730..6be36f2 100644 --- a/drivers/mmc/Makefile +++ b/drivers/mmc/Makefile @@ -43,6 +43,7 @@ COBJS-$(CONFIG_MXS_MMC) += mxsmmc.o COBJS-$(CONFIG_OMAP_HSMMC) += omap_hsmmc.o COBJS-$(CONFIG_PXA_MMC_GENERIC) += pxa_mmc_gen.o COBJS-$(CONFIG_SDHCI) += sdhci.o +COBJS-$(CONFIG_BCM2835_SDHCI) += bcm2835_sdhci.o COBJS-$(CONFIG_S5P_SDHCI) += s5p_sdhci.o COBJS-$(CONFIG_SH_MMCIF) += sh_mmcif.o COBJS-$(CONFIG_TEGRA_MMC) += tegra_mmc.o diff --git a/drivers/mmc/bcm2835_sdhci.c b/drivers/mmc/bcm2835_sdhci.c new file mode 100644 index 0000000..8f2137e --- /dev/null +++ b/drivers/mmc/bcm2835_sdhci.c @@ -0,0 +1,177 @@ +/* + * This code was extracted from: + * git://github.com/gonzoua/u-boot-pi.git master + * and hence presumably (C) 2012 Oleksandr Tymoshenko + * + * Tweaks for U-Boot upstreaming + * (C) 2012 Stephen Warren + * + * Portions (e.g. read/write macros, concepts for back-to-back register write + * timing workarounds) obviously extracted from the Linux kernel at: + * https://github.com/raspberrypi/linux.git rpi-3.6.y + * + * The Linux kernel code has the following (c) and license, which is hence + * propagated to Oleksandr's tree and here: + * + * Support for SDHCI device on 2835 + * Based on sdhci-bcm2708.c (c) 2010 Broadcom + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License version 2 as + * published by the Free Software Foundation. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 675 Mass Ave, Cambridge, MA 02139, USA. + */ + +/* Supports: + * SDHCI platform device - Arasan SD controller in BCM2708 + * + * Inspired by sdhci-pci.c, by Pierre Ossman + */ + +#include <common.h> +#include <malloc.h> +#include <sdhci.h> + +/* 400KHz is max freq for card ID etc. Use that as min */ +#define MIN_FREQ 400000 + +static uint twoticks_delay; + +static inline void bcm2835_sdhci_raw_writel(struct sdhci_host *host, u32 val, + int reg) +{ + static ulong last_write; + + /* + * The Arasan has a bugette whereby it may lose the content of + * successive writes to registers that are within two SD-card clock + * cycles of each other (a clock domain crossing problem). + * It seems, however, that the data register does not have this problem. + * (Which is just as well - otherwise we'd have to nobble the DMA engine + * too) + */ + while (get_timer(last_write) < twoticks_delay) + ; + + writel(val, host->ioaddr + reg); + last_write = get_timer(0); +} + +static inline u32 bcm2835_sdhci_raw_readl(struct sdhci_host *host, int reg) +{ + return readl(host->ioaddr + reg); +} + +static void bcm2835_sdhci_writel(struct sdhci_host *host, u32 val, int reg) +{ + bcm2835_sdhci_raw_writel(host, val, reg); +} + +static void bcm2835_sdhci_writew(struct sdhci_host *host, u16 val, int reg) +{ + static u32 shadow; + u32 oldval = (reg == SDHCI_COMMAND) ? shadow : + bcm2835_sdhci_raw_readl(host, reg & ~3); + u32 word_num = (reg >> 1) & 1; + u32 word_shift = word_num * 16; + u32 mask = 0xffff << word_shift; + u32 newval = (oldval & ~mask) | (val << word_shift); + + if (reg == SDHCI_TRANSFER_MODE) + shadow = newval; + else + bcm2835_sdhci_raw_writel(host, newval, reg & ~3); +} + +static void bcm2835_sdhci_writeb(struct sdhci_host *host, u8 val, int reg) +{ + u32 oldval = bcm2835_sdhci_raw_readl(host, reg & ~3); + u32 byte_num = reg & 3; + u32 byte_shift = byte_num * 8; + u32 mask = 0xff << byte_shift; + u32 newval = (oldval & ~mask) | (val << byte_shift); + + bcm2835_sdhci_raw_writel(host, newval, reg & ~3); +} + +static u32 bcm2835_sdhci_readl(struct sdhci_host *host, int reg) +{ + u32 val = bcm2835_sdhci_raw_readl(host, reg); + + return val; +} + +static u16 bcm2835_sdhci_readw(struct sdhci_host *host, int reg) +{ + u32 val = bcm2835_sdhci_raw_readl(host, (reg & ~3)); + u32 word_num = (reg >> 1) & 1; + u32 word_shift = word_num * 16; + u32 word = (val >> word_shift) & 0xffff; + + return word; +} + +static u8 bcm2835_sdhci_readb(struct sdhci_host *host, int reg) +{ + u32 val = bcm2835_sdhci_raw_readl(host, (reg & ~3)); + u32 byte_num = reg & 3; + u32 byte_shift = byte_num * 8; + u32 byte = (val >> byte_shift) & 0xff; + + return byte; +} + +static const struct sdhci_ops bcm2835_ops = { + .write_l = bcm2835_sdhci_writel, + .write_w = bcm2835_sdhci_writew, + .write_b = bcm2835_sdhci_writeb, + .read_l = bcm2835_sdhci_readl, + .read_w = bcm2835_sdhci_readw, + .read_b = bcm2835_sdhci_readb, +}; + +int bcm2835_sdhci_init(u32 regbase, u32 emmc_freq) +{ + struct sdhci_host *host = NULL; + + /* + * See the comments in bcm2835_sdhci_raw_writel(). + * + * This should probably be dynamically calculated based on the actual + * frequency. However, this is the longest we'll have to wait, and + * doesn't seem to slow access down too much, so the added complexity + * doesn't seem worth it for now. + * + * 1/MIN_FREQ is (max) time per tick of eMMC clock. + * 2/MIN_FREQ is time for two ticks. + * Multiply by 1000000 to get uS per two ticks. + * +1 for hack rounding. + */ + twoticks_delay = ((2 * 1000000) / MIN_FREQ) + 1; + + host = malloc(sizeof(struct sdhci_host)); + if (!host) { + printf("sdhci_host malloc fail!\n"); + return 1; + } + + host->name = "bcm2835_sdhci"; + host->ioaddr = (void *)regbase; + host->quirks = SDHCI_QUIRK_BROKEN_VOLTAGE | SDHCI_QUIRK_BROKEN_R1B | + SDHCI_QUIRK_WAIT_SEND_CMD; + host->voltages = MMC_VDD_32_33 | MMC_VDD_33_34 | MMC_VDD_165_195; + host->ops = &bcm2835_ops; + + host->version = sdhci_readw(host, SDHCI_HOST_VERSION); + add_sdhci(host, emmc_freq, MIN_FREQ); + + return 0; +}
Enable the SD controller driver for the Raspberry Pi. Enable a number of useful MMC, partition, and filesystem-related commands. Set up the environment to provide standard locations for loading a kernel, DTB, etc. Provide a boot command that loads and executes boot.scr.uimg from the SD card; this is written considering future extensibilty to USB storage.
Signed-off-by: Stephen Warren swarren@wwwdotorg.org --- arch/arm/include/asm/arch-bcm2835/mbox.h | 26 ++++++++++++ board/raspberrypi/rpi_b/rpi_b.c | 26 ++++++++++++ include/configs/rpi_b.h | 68 ++++++++++++++++++++++++++++-- 3 files changed, 117 insertions(+), 3 deletions(-)
diff --git a/arch/arm/include/asm/arch-bcm2835/mbox.h b/arch/arm/include/asm/arch-bcm2835/mbox.h index 4752091..b07c4a0 100644 --- a/arch/arm/include/asm/arch-bcm2835/mbox.h +++ b/arch/arm/include/asm/arch-bcm2835/mbox.h @@ -144,6 +144,32 @@ struct bcm2835_mbox_tag_get_arm_mem { } body; };
+#define BCM2835_MBOX_TAG_GET_CLOCK_RATE 0x00030002 + +#define BCM2835_MBOX_CLOCK_ID_EMMC 1 +#define BCM2835_MBOX_CLOCK_ID_UART 2 +#define BCM2835_MBOX_CLOCK_ID_ARM 3 +#define BCM2835_MBOX_CLOCK_ID_CORE 4 +#define BCM2835_MBOX_CLOCK_ID_V3D 5 +#define BCM2835_MBOX_CLOCK_ID_H264 6 +#define BCM2835_MBOX_CLOCK_ID_ISP 7 +#define BCM2835_MBOX_CLOCK_ID_SDRAM 8 +#define BCM2835_MBOX_CLOCK_ID_PIXEL 9 +#define BCM2835_MBOX_CLOCK_ID_PWM 10 + +struct bcm2835_mbox_tag_get_clock_rate { + struct bcm2835_mbox_tag_hdr tag_hdr; + union { + struct { + u32 clock_id; + } req; + struct { + u32 clock_id; + u32 rate_hz; + } resp; + } body; +}; + #define BCM2835_MBOX_TAG_ALLOCATE_BUFFER 0x00040001
struct bcm2835_mbox_tag_allocate_buffer { diff --git a/board/raspberrypi/rpi_b/rpi_b.c b/board/raspberrypi/rpi_b/rpi_b.c index 3c654a1..6b3e095 100644 --- a/board/raspberrypi/rpi_b/rpi_b.c +++ b/board/raspberrypi/rpi_b/rpi_b.c @@ -16,6 +16,7 @@
#include <common.h> #include <asm/arch/mbox.h> +#include <asm/arch/sdhci.h> #include <asm/global_data.h>
DECLARE_GLOBAL_DATA_PTR; @@ -26,6 +27,12 @@ struct msg_get_arm_mem { u32 end_tag; };
+struct msg_get_clock_rate { + struct bcm2835_mbox_hdr hdr; + struct bcm2835_mbox_tag_get_clock_rate get_clock_rate; + u32 end_tag; +}; + int dram_init(void) { ALLOC_ALIGN_BUFFER(struct msg_get_arm_mem, msg, 1, 16); @@ -51,3 +58,22 @@ int board_init(void)
return 0; } + +int board_mmc_init(void) +{ + ALLOC_ALIGN_BUFFER(struct msg_get_clock_rate, msg_clk, 1, 16); + int ret; + + BCM2835_MBOX_INIT_HDR(msg_clk); + BCM2835_MBOX_INIT_TAG(&msg_clk->get_clock_rate, GET_CLOCK_RATE); + msg_clk->get_clock_rate.body.req.clock_id = BCM2835_MBOX_CLOCK_ID_EMMC; + + ret = bcm2835_mbox_call_prop(BCM2835_MBOX_PROP_CHAN, &msg_clk->hdr); + if (ret) { + printf("bcm2835: Could not query eMMC clock rate\n"); + return -1; + } + + return bcm2835_sdhci_init(BCM2835_SDHCI_BASE, + msg_clk->get_clock_rate.body.resp.rate_hz); +} diff --git a/include/configs/rpi_b.h b/include/configs/rpi_b.h index a709feb..4d834e1 100644 --- a/include/configs/rpi_b.h +++ b/include/configs/rpi_b.h @@ -50,6 +50,7 @@ #define CONFIG_SYS_MALLOC_LEN SZ_4M #define CONFIG_SYS_MEMTEST_START 0x00100000 #define CONFIG_SYS_MEMTEST_END 0x00200000 +#define CONFIG_LOADADDR 0x00200000
/* Flash */ #define CONFIG_SYS_NO_FLASH @@ -69,6 +70,13 @@ #define CONFIG_VIDEO_BCM2835 #define CONFIG_SYS_WHITE_ON_BLACK
+/* SD/MMC configuration */ +#define CONFIG_GENERIC_MMC +#define CONFIG_MMC +#define CONFIG_SDHCI +#define CONFIG_MMC_SDHCI_IO_ACCESSORS +#define CONFIG_BCM2835_SDHCI + /* Console UART */ #define CONFIG_PL011_SERIAL #define CONFIG_PL011_CLOCK 3000000 @@ -84,12 +92,59 @@ /* Environment */ #define CONFIG_ENV_SIZE SZ_16K #define CONFIG_ENV_IS_NOWHERE +#define CONFIG_ENV_VARS_UBOOT_CONFIG #define CONFIG_SYS_LOAD_ADDR 0x1000000 #define CONFIG_CONSOLE_MUX #define CONFIG_SYS_CONSOLE_IS_IN_ENV -#define CONFIG_EXTRA_ENV_SETTINGS "stdin=serial\0" \ - "stderr=serial,lcd\0" \ - "stdout=serial,lcd\0" +/* + * Memory layout for where various images get loaded by boot scripts: + * + * scriptaddr can be pretty much anywhere that doesn't conflict with something + * else. Put it low in memory to avoid conflicts. + * + * kernel_addr_r must be within the first 128M of RAM in order for the + * kernel's CONFIG_AUTO_ZRELADDR option to work. Since the kernel will + * decompress itself to 0x8000 after the start of RAM, kernel_addr_r + * should not overlap that area, or the kernel will have to copy itself + * somewhere else before decompression. Similarly, the address of any other + * data passed to the kernel shouldn't overlap the start of RAM. Pushing + * this up to 16M allows for a sizable kernel to be decompressed below the + * compressed load address. + * + * fdt_addr_r simply shouldn't overlap anything else. Choosing 32M allows for + * the compressed kernel to be up to 16M too. + * + * ramdisk_addr_r simply shouldn't overlap anything else. Choosing 33M allows + * for the FDT/DTB to be up to 1M, which is hopefully plenty. + */ +#define CONFIG_EXTRA_ENV_SETTINGS \ + "stdin=serial\0" \ + "stderr=serial,lcd\0" \ + "stdout=serial,lcd\0" \ + "scriptaddr=0x00000000\0" \ + "kernel_addr_r=0x01000000\0" \ + "fdt_addr_r=0x02000000\0" \ + "ramdisk_addr_r=0x02100000\0" \ + "boot_targets=mmc0\0" \ + \ + "script_boot=" \ + "if fatload ${devtype} ${devnum}:1 " \ + "${scriptaddr} boot.scr.uimg; then " \ + "source ${scriptaddr}; " \ + "fi;\0" \ + \ + "mmc_boot=" \ + "setenv devtype mmc; " \ + "if mmc dev ${devnum}; then " \ + "run script_boot; " \ + "fi\0" \ + \ + "bootcmd_mmc0=setenv devnum 0; run mmc_boot\0" \ + +#define CONFIG_BOOTCOMMAND \ + "for target in ${boot_targets}; do run bootcmd_${target}; done" + +#define CONFIG_BOOTDELAY 2
/* Shell */ #define CONFIG_SYS_HUSH_PARSER @@ -104,6 +159,13 @@ #include <config_cmd_default.h> #define CONFIG_CMD_BOOTZ #define CONFIG_CMD_GPIO +#define CONFIG_CMD_MMC +#define CONFIG_DOS_PARTITION +#define CONFIG_PARTITION_UUIDS +#define CONFIG_CMD_PART +#define CONFIG_CMD_FS_GENERIC +#define CONFIG_CMD_FAT +#define CONFIG_CMD_EXT /* Some things don't make sense on this HW or yet */ #undef CONFIG_CMD_FPGA #undef CONFIG_CMD_NET
Hi Stephen,
Actually the patch is essentially an MMC driver one, with the ARM file touched only to add a base address. I have reassigned the patch to Andy.
Amicalement,
On 11/10/2012 02:17 AM, Albert ARIBAUD wrote:
Hi Stephen,
OK. Note that patch 2/2 is all ARM and relies on patch 1/2 to compile though.
Hi Stephen,
On Sun, 11 Nov 2012 14:54:46 -0700, Stephen Warren swarren@wwwdotorg.org wrote:
Hi Stephen,
If you prefer, Andy can give his Acked-By: and reassign to me, and I will apply the series.
Amicalement,
Albert ARIBAUD
Stephen Warren
