[U-Boot] [PATCH v4 0/8] x86: Add basic Slim Bootloader payload support
This patch is to enable U-Boot as a payload which runs on top of Slim Bootloader(https://github.com/slimbootloader/slimbootloader) boot firmware for x86 platforms.
The Slim Bootloader is designed with multi-stage architecture for the execution from reset vector to OS hand-off, and supports qemu, Apollolake, Whiskeylake and Coffeelake platforms consuming Intel FSP(https://github.com/IntelFsp/FSP) for silicon initialization including CAR and memory initialization. As multi-stage architecture, the Slim Bootloader adopts payload concept which is responsible for OS load from media devices and boot OS and it supports 32-bit PE32, EFI FV, ELF and RAW format payloads. The Slim Bootloader generate HOB(Hand Off Block) list pointer, which has debug serial port info, memory map info, performance data info and etc., and passes it to a payload. U-Boot configures serial port, dram, pci, tsc and others with the information from the HOB.
The compiled U-Boot supports usb, sata and sd/mmc boot which have been verified on qemu and other supported platforms.
Changes in v4: * Use arch/x86/cpu/start.S with CONFIG_SYS_SLIMBOOTLOADER condition * Update U-boot or u-boot to U-Boot in commit message * Add static keyword in static function
Changes in v3: * Add a brief description about Slim Bootloader in 1st patch * Add a common HOB library to be used by both FSP and Slim Bootloader * Move board/slimbootloader/slimbootloader to board/intel/slimbootloader * Add more description board/intel/slimbootloader/README * Fix comments from the code review
Changes in v2: * Split a single patch to 8 patches * Add more comment for each structure and functions
Aiden Park (8): x86: Add new slimbootloader CPU type x86: Add a common hob library x86: slimbootloader: Add memory configuration x86: slimbootloader: Add serial driver x86: slimbootloader: Set TSC information for timer driver x86: slimbootloader: Add a slimbootloader device tree board: intel: Add new slimbootloader board x86: Skip setting up MTRRs in slimbootloader
arch/x86/Kconfig | 1 + arch/x86/cpu/Makefile | 1 + arch/x86/cpu/slimbootloader/Kconfig | 26 ++ arch/x86/cpu/slimbootloader/Makefile | 5 + arch/x86/cpu/slimbootloader/car.S | 14 + arch/x86/cpu/slimbootloader/dram.c | 151 +++++++++++ arch/x86/cpu/slimbootloader/serial.c | 69 +++++ arch/x86/cpu/slimbootloader/slimbootloader.c | 55 ++++ arch/x86/cpu/start.S | 6 +- arch/x86/dts/Makefile | 1 + arch/x86/dts/slimbootloader.dts | 27 ++ .../asm/arch-slimbootloader/slimbootloader.h | 121 +++++++++ arch/x86/include/asm/fsp/fsp_hob.h | 183 +------------ arch/x86/include/asm/fsp/fsp_support.h | 37 +-- arch/x86/include/asm/fsp/fsp_types.h | 8 - arch/x86/include/asm/global_data.h | 2 +- arch/x86/include/asm/hob.h | 250 ++++++++++++++++++ arch/x86/lib/Makefile | 3 +- arch/x86/lib/asm-offsets.c | 2 +- arch/x86/lib/fsp/fsp_support.c | 78 +----- arch/x86/lib/hob.c | 104 ++++++++ arch/x86/lib/init_helpers.c | 3 +- board/intel/Kconfig | 14 + board/intel/slimbootloader/Kconfig | 51 ++++ board/intel/slimbootloader/Makefile | 5 + board/intel/slimbootloader/README | 133 ++++++++++ board/intel/slimbootloader/slimbootloader.c | 17 ++ board/intel/slimbootloader/start.S | 9 + configs/slimbootloader_defconfig | 22 ++ include/configs/slimbootloader.h | 59 +++++ 30 files changed, 1150 insertions(+), 307 deletions(-) create mode 100644 arch/x86/cpu/slimbootloader/Kconfig create mode 100644 arch/x86/cpu/slimbootloader/Makefile create mode 100644 arch/x86/cpu/slimbootloader/car.S create mode 100644 arch/x86/cpu/slimbootloader/dram.c create mode 100644 arch/x86/cpu/slimbootloader/serial.c create mode 100644 arch/x86/cpu/slimbootloader/slimbootloader.c create mode 100644 arch/x86/dts/slimbootloader.dts create mode 100644 arch/x86/include/asm/arch-slimbootloader/slimbootloader.h create mode 100644 arch/x86/include/asm/hob.h create mode 100644 arch/x86/lib/hob.c create mode 100644 board/intel/slimbootloader/Kconfig create mode 100644 board/intel/slimbootloader/Makefile create mode 100644 board/intel/slimbootloader/README create mode 100644 board/intel/slimbootloader/slimbootloader.c create mode 100644 board/intel/slimbootloader/start.S create mode 100644 configs/slimbootloader_defconfig create mode 100644 include/configs/slimbootloader.h
-- 2.20.1
Thanks for the series. I have some questions.
Is it chained bootloader in the sense of how it's done? Can it use rather SPL part of U-Boot? Can it simple run Linux kernel as an EFI payload?
Very briefly looking I didn't notice (may be simple missed it) the use of X86_32BIT_INIT. Why do you not use it (it it's the case)?
Bin, may you give me couple of days to briefly review this in order to see if there is any similarities with what Intel Edison firmware is doing?
P.S. Aiden, please, Cc me for the next series.
Changes in v4:
- Use arch/x86/cpu/start.S with CONFIG_SYS_SLIMBOOTLOADER condition
- Update U-boot or u-boot to U-Boot in commit message
- Add static keyword in static function
Changes in v3:
- Add a brief description about Slim Bootloader in 1st patch
- Add a common HOB library to be used by both FSP and Slim Bootloader
- Move board/slimbootloader/slimbootloader to board/intel/slimbootloader
- Add more description board/intel/slimbootloader/README
- Fix comments from the code review
Changes in v2:
- Split a single patch to 8 patches
- Add more comment for each structure and functions
-- 2.20.1
On Mon, Jul 15, 2019 at 12:31 PM Andy Shevchenko andy.shevchenko@gmail.com wrote:
s/X86_32BIT_INIT/LOAD_FROM_32_BIT/
Changes in v4:
Changes in v3:
Changes in v2:
-- 2.20.1
-- With Best Regards, Andy Shevchenko
Hi Andy,
-----Original Message----- From: Andy Shevchenko [mailto:andy.shevchenko@gmail.com] Sent: Monday, July 15, 2019 2:33 AM To: Park, Aiden aiden.park@intel.com Cc: U-Boot Mailing List u-boot@lists.denx.de; Simon Glass sjg@chromium.org; Bin Meng bmeng.cn@gmail.com Subject: Re: [U-Boot] [PATCH v4 0/8] x86: Add basic Slim Bootloader payload support
Thanks for your comment. X86_LOAD_FROM_32_BIT is already defined in configs/slimbootloader_defconfig. In fact, this is not necessary because Slim Bootloader has already done GDT setup before loading U-Boot, and gdt re-config is done in arch_setup_gd(). X86_LOAD_FROM_32_BIT is required only if protected mode switch is done but gdt still covers real mode address space only. Slim Bootloader already initialized memory and configured GDT for 32bit address space, so X86_LOAD_FROM_32_BIT is not necessary for Slim Bootloader. If you don't mind, let me remove X86_LOAD_FROM_32_BIT from def_config.
Slim Bootloader is chained boot firmware(Stage1A/B -> Stage2 -> Payload) with Intel FSP 2.x binary, and it is executed from reset vector. * Stage1A: Reset vector, CAR init with FSP-T * Stage1B: Memory init with FSP-M, CAR teardown, Continue execution in memory * Stage2 : Rest of Silicon init with FSP-S, Create HOB, Hand-off to Payload * Payload: Payload init with HOB, Load OS from media, Booting OS Stage1A/B/2 focus on silicon configuration and rich payloads access media, load and boot OS. Slim Bootloader supports UEFI and OsLoader payloads currently. * UEFI : Support same environment as UEFI BIOS. Boot Windows/Linux. * OsLoader: Default payload. Light-weight. Support Linux boot.
Changes in v4:
condition
Changes in v3:
Changes in v2:
-- 2.20.1
Best Regards, Aiden
Hi Andy,
On Mon, Jul 15, 2019 at 5:31 PM Andy Shevchenko andy.shevchenko@gmail.com wrote:
Yes, for sure.
Regards, Bin
Andy Shevchenko
Bin Meng
Park, Aiden
