[PATCH] board/freescale/common: fix a bug that failed to read/write eeprom on ls1021atsn
Fix a bug that failed to read/write eeprom on ls1021atsn
Signed-off-by: Biwen Li biwen.li@nxp.com --- board/freescale/common/sys_eeprom.c | 6 ++++-- 1 file changed, 4 insertions(+), 2 deletions(-)
diff --git a/board/freescale/common/sys_eeprom.c b/board/freescale/common/sys_eeprom.c index c487e3a515..f14602af20 100644 --- a/board/freescale/common/sys_eeprom.c +++ b/board/freescale/common/sys_eeprom.c @@ -173,9 +173,11 @@ static int read_eeprom(void) struct udevice *dev; #ifdef CONFIG_SYS_EEPROM_BUS_NUM ret = i2c_get_chip_for_busnum(CONFIG_SYS_EEPROM_BUS_NUM, - CONFIG_SYS_I2C_EEPROM_ADDR, 1, &dev); + CONFIG_SYS_I2C_EEPROM_ADDR, + CONFIG_SYS_I2C_EEPROM_ADDR_LEN, &dev); #else - ret = i2c_get_chip_for_busnum(0, CONFIG_SYS_I2C_EEPROM_ADDR, 1, &dev); + ret = i2c_get_chip_for_busnum(0, CONFIG_SYS_I2C_EEPROM_ADDR, + CONFIG_SYS_I2C_EEPROM_ADDR_LEN, &dev); #endif if (!ret) ret = dm_i2c_read(dev, 0, (void *)&e, sizeof(e));
Tested-by: Vladimir Oltean vladimir.oltean@nxp.com
#else
#endif if (!ret) ret = dm_i2c_read(dev, 0, (void *)&e, sizeof(e)); -- 2.17.1
-----Original Message----- From: Biwen Li biwen.li@oss.nxp.com Sent: Monday, October 26, 2020 12:44 PM To: Priyanka Jain priyanka.jain@nxp.com Cc: Jiafei Pan jiafei.pan@nxp.com; u-boot@lists.denx.de; Biwen Li biwen.li@nxp.com Subject: [PATCH] board/freescale/common: fix a bug that failed to read/write eeprom on ls1021atsn
<snip> Applied to fsl-qoriq. Awaiting upstream
Thanks Priyanka
Biwen Li
Priyanka Jain
Vladimir Oltean
