[U-Boot] [PATCH 0/4] tegra: Move tegra20 towards the 'new' display bindings
The original tegra20 display driver was written before Linux had device tree bindings for display. Since then Linux has developed a robust set of bindings covering various aspects of enabling a display.
This series moves closer to those bindings by using the panel and backlight as separate drivers. The device tree files for seaboard, ventana and harmony thereby become almost the same as Linux.
Unfortunately this breaks the other boards, which will need a similar sync. So I'm not sure how easy it will be to accept this series. Still, it seems worth sending it out in the hope that board maintainers can help. I have kept this series separate so that it can progress separately.
Simon Glass (4): tegra: dts: Sync seaboard device tree file with Linux video: tegra: Move to using simple-panel and pwm-backlight tegra: video: Always use write-through cache on LCD fdt: Drop some unused compatible strings
arch/arm/dts/tegra20-harmony.dts | 751 ++++++++++++++++++++++++++++-- arch/arm/dts/tegra20-seaboard.dts | 934 ++++++++++++++++++++++++++++++++++---- arch/arm/dts/tegra20-ventana.dts | 685 ++++++++++++++++++++++++++-- configs/colibri_t20_defconfig | 5 +- configs/harmony_defconfig | 5 +- configs/medcom-wide_defconfig | 5 +- configs/paz00_defconfig | 5 +- configs/seaboard_defconfig | 5 +- configs/tec_defconfig | 5 +- configs/ventana_defconfig | 5 +- drivers/video/tegra.c | 333 +++----------- include/fdtdec.h | 4 - lib/fdtdec.c | 4 - 13 files changed, 2307 insertions(+), 439 deletions(-)
Sync everything except the display panel, which will come in a future patch. One USB port is left disabled since we don't want to support it in U-Boot.
arch/arm/dts/tegra20-seaboard.dts | 889 +++++++++++++++++++++++++++++++++++--- 1 file changed, 822 insertions(+), 67 deletions(-)
diff --git a/arch/arm/dts/tegra20-seaboard.dts b/arch/arm/dts/tegra20-seaboard.dts index eada590..19292f8 100644 --- a/arch/arm/dts/tegra20-seaboard.dts +++ b/arch/arm/dts/tegra20-seaboard.dts @@ -1,19 +1,12 @@ /dts-v1/;
+#include <dt-bindings/input/input.h> #include "tegra20.dtsi"
/ { model = "NVIDIA Seaboard"; compatible = "nvidia,seaboard", "nvidia,tegra20";
- chosen { - bootargs = "vmalloc=192M video=tegrafb console=ttyS0,115200n8 root=/dev/mmcblk1p3 rw rootwait"; - }; - - chosen { - stdout-path = &uartd; - }; - aliases { /* This defines the order of our ports */ usb0 = "/usb@c5008000"; @@ -22,13 +15,23 @@ i2c1 = "/i2c@7000c000"; i2c2 = "/i2c@7000c400"; i2c3 = "/i2c@7000c500"; + rtc0 = "/i2c@7000d000/tps6586x@34"; + rtc1 = "/rtc@7000e000"; + serial0 = &uartd; sdhci0 = "/sdhci@c8000600"; sdhci1 = "/sdhci@c8000400"; };
+ chosen { + bootargs = "vmalloc=192M video=tegrafb console=ttyS0,115200n8 root=/dev/mmcblk1p3 rw rootwait"; + }; + + chosen { + stdout-path = &uartd; + }; + memory { - device_type = "memory"; - reg = < 0x00000000 0x40000000 >; + reg = <0x00000000 0x40000000>; };
host1x@50000000 { @@ -37,35 +40,309 @@ status = "okay"; rgb { status = "okay"; - nvidia,panel = <&lcd_panel>; + + nvidia,panel = <&panel>; }; };
dc@54240000 { status = "disabled"; }; + + hdmi@54280000 { + status = "okay"; + + vdd-supply = <&hdmi_vdd_reg>; + pll-supply = <&hdmi_pll_reg>; + hdmi-supply = <&vdd_hdmi>; + + nvidia,ddc-i2c-bus = <&hdmi_ddc>; + nvidia,hpd-gpio = <&gpio TEGRA_GPIO(N, 7) + GPIO_ACTIVE_HIGH>; + }; };
- /* This is not used in U-Boot, but is expected to be in kernel .dts */ - i2c@7000d000 { - status = "okay"; - clock-frequency = <100000>; - pmic@34 { - compatible = "ti,tps6586x"; - reg = <0x34>; + pinmux@70000014 { + pinctrl-names = "default"; + pinctrl-0 = <&state_default>; + + state_default: pinmux { + ata { + nvidia,pins = "ata"; + nvidia,function = "ide"; + }; + atb { + nvidia,pins = "atb", "gma", "gme"; + nvidia,function = "sdio4"; + }; + atc { + nvidia,pins = "atc"; + nvidia,function = "nand"; + }; + atd { + nvidia,pins = "atd", "ate", "gmb", "spia", + "spib", "spic"; + nvidia,function = "gmi"; + }; + cdev1 { + nvidia,pins = "cdev1"; + nvidia,function = "plla_out"; + }; + cdev2 { + nvidia,pins = "cdev2"; + nvidia,function = "pllp_out4"; + }; + crtp { + nvidia,pins = "crtp", "lm1"; + nvidia,function = "crt"; + }; + csus { + nvidia,pins = "csus"; + nvidia,function = "vi_sensor_clk"; + }; + dap1 { + nvidia,pins = "dap1"; + nvidia,function = "dap1"; + }; + dap2 { + nvidia,pins = "dap2"; + nvidia,function = "dap2"; + }; + dap3 { + nvidia,pins = "dap3"; + nvidia,function = "dap3"; + }; + dap4 { + nvidia,pins = "dap4"; + nvidia,function = "dap4"; + }; + dta { + nvidia,pins = "dta", "dtb", "dtc", "dtd", "dte"; + nvidia,function = "vi"; + }; + dtf { + nvidia,pins = "dtf"; + nvidia,function = "i2c3"; + }; + gmc { + nvidia,pins = "gmc"; + nvidia,function = "uartd"; + }; + gmd { + nvidia,pins = "gmd"; + nvidia,function = "sflash"; + }; + gpu { + nvidia,pins = "gpu"; + nvidia,function = "pwm"; + }; + gpu7 { + nvidia,pins = "gpu7"; + nvidia,function = "rtck"; + }; + gpv { + nvidia,pins = "gpv", "slxa", "slxk"; + nvidia,function = "pcie"; + }; + hdint { + nvidia,pins = "hdint", "lpw0", "lpw2", "lsc1", + "lsck", "lsda"; + nvidia,function = "hdmi"; + }; + i2cp { + nvidia,pins = "i2cp"; + nvidia,function = "i2cp"; + }; + irrx { + nvidia,pins = "irrx", "irtx"; + nvidia,function = "uartb"; + }; + kbca { + nvidia,pins = "kbca", "kbcb", "kbcc", "kbcd", + "kbce", "kbcf"; + nvidia,function = "kbc"; + }; + lcsn { + nvidia,pins = "lcsn", "ldc", "lm0", "lpw1", + "lsdi", "lvp0"; + nvidia,function = "rsvd4"; + }; + ld0 { + nvidia,pins = "ld0", "ld1", "ld2", "ld3", "ld4", + "ld5", "ld6", "ld7", "ld8", "ld9", + "ld10", "ld11", "ld12", "ld13", "ld14", + "ld15", "ld16", "ld17", "ldi", "lhp0", + "lhp1", "lhp2", "lhs", "lpp", "lsc0", + "lspi", "lvp1", "lvs"; + nvidia,function = "displaya"; + }; + owc { + nvidia,pins = "owc", "spdi", "spdo", "uac"; + nvidia,function = "rsvd2"; + }; + pmc { + nvidia,pins = "pmc"; + nvidia,function = "pwr_on"; + }; + rm { + nvidia,pins = "rm"; + nvidia,function = "i2c1"; + }; + sdb { + nvidia,pins = "sdb", "sdc", "sdd"; + nvidia,function = "sdio3"; + }; + sdio1 { + nvidia,pins = "sdio1"; + nvidia,function = "sdio1"; + }; + slxc { + nvidia,pins = "slxc", "slxd"; + nvidia,function = "spdif"; + }; + spid { + nvidia,pins = "spid", "spie", "spif"; + nvidia,function = "spi1"; + }; + spig { + nvidia,pins = "spig", "spih"; + nvidia,function = "spi2_alt"; + }; + uaa { + nvidia,pins = "uaa", "uab", "uda"; + nvidia,function = "ulpi"; + }; + uad { + nvidia,pins = "uad"; + nvidia,function = "irda"; + }; + uca { + nvidia,pins = "uca", "ucb"; + nvidia,function = "uartc"; + }; + conf_ata { + nvidia,pins = "ata", "atb", "atc", "atd", + "cdev1", "cdev2", "dap1", "dap2", + "dap4", "ddc", "dtf", "gma", "gmc", "gmd", + "gme", "gpu", "gpu7", "i2cp", "irrx", + "irtx", "pta", "rm", "sdc", "sdd", + "slxd", "slxk", "spdi", "spdo", "uac", + "uad", "uca", "ucb", "uda"; + nvidia,pull = <TEGRA_PIN_PULL_NONE>; + nvidia,tristate = <TEGRA_PIN_DISABLE>; + }; + conf_ate { + nvidia,pins = "ate", "csus", "dap3", + "gpv", "owc", "slxc", "spib", "spid", + "spie"; + nvidia,pull = <TEGRA_PIN_PULL_NONE>; + nvidia,tristate = <TEGRA_PIN_ENABLE>; + }; + conf_ck32 { + nvidia,pins = "ck32", "ddrc", "pmca", "pmcb", + "pmcc", "pmcd", "pmce", "xm2c", "xm2d"; + nvidia,pull = <TEGRA_PIN_PULL_NONE>; + }; + conf_crtp { + nvidia,pins = "crtp", "gmb", "slxa", "spia", + "spig", "spih"; + nvidia,pull = <TEGRA_PIN_PULL_UP>; + nvidia,tristate = <TEGRA_PIN_ENABLE>; + }; + conf_dta { + nvidia,pins = "dta", "dtb", "dtc", "dtd"; + nvidia,pull = <TEGRA_PIN_PULL_DOWN>; + nvidia,tristate = <TEGRA_PIN_DISABLE>; + }; + conf_dte { + nvidia,pins = "dte", "spif"; + nvidia,pull = <TEGRA_PIN_PULL_DOWN>; + nvidia,tristate = <TEGRA_PIN_ENABLE>; + }; + conf_hdint { + nvidia,pins = "hdint", "lcsn", "ldc", "lm1", + "lpw1", "lsc1", "lsck", "lsda", "lsdi", + "lvp0"; + nvidia,tristate = <TEGRA_PIN_ENABLE>; + }; + conf_kbca { + nvidia,pins = "kbca", "kbcb", "kbcc", "kbcd", + "kbce", "kbcf", "sdio1", "spic", "uaa", + "uab"; + nvidia,pull = <TEGRA_PIN_PULL_UP>; + nvidia,tristate = <TEGRA_PIN_DISABLE>; + }; + conf_lc { + nvidia,pins = "lc", "ls"; + nvidia,pull = <TEGRA_PIN_PULL_UP>; + }; + conf_ld0 { + nvidia,pins = "ld0", "ld1", "ld2", "ld3", "ld4", + "ld5", "ld6", "ld7", "ld8", "ld9", + "ld10", "ld11", "ld12", "ld13", "ld14", + "ld15", "ld16", "ld17", "ldi", "lhp0", + "lhp1", "lhp2", "lhs", "lm0", "lpp", + "lpw0", "lpw2", "lsc0", "lspi", "lvp1", + "lvs", "pmc", "sdb"; + nvidia,tristate = <TEGRA_PIN_DISABLE>; + }; + conf_ld17_0 { + nvidia,pins = "ld17_0", "ld19_18", "ld21_20", + "ld23_22"; + nvidia,pull = <TEGRA_PIN_PULL_DOWN>; + }; + drive_sdio1 { + nvidia,pins = "drive_sdio1"; + nvidia,high-speed-mode = <TEGRA_PIN_DISABLE>; + nvidia,schmitt = <TEGRA_PIN_DISABLE>; + nvidia,low-power-mode = <TEGRA_PIN_LP_DRIVE_DIV_1>; + nvidia,pull-down-strength = <31>; + nvidia,pull-up-strength = <31>; + nvidia,slew-rate-rising = <TEGRA_PIN_SLEW_RATE_SLOWEST>; + nvidia,slew-rate-falling = <TEGRA_PIN_SLEW_RATE_SLOWEST>; + }; + }; + + state_i2cmux_ddc: pinmux_i2cmux_ddc { + ddc { + nvidia,pins = "ddc"; + nvidia,function = "i2c2"; + }; + pta { + nvidia,pins = "pta"; + nvidia,function = "rsvd4"; + }; + };
- clk_32k: clock { - compatible = "fixed-clock"; - /* - * leave out for now due to CPP: - * #clock-cells = <0>; - */ - clock-frequency = <32768>; + state_i2cmux_pta: pinmux_i2cmux_pta { + ddc { + nvidia,pins = "ddc"; + nvidia,function = "rsvd4"; + }; + pta { + nvidia,pins = "pta"; + nvidia,function = "i2c2"; + }; + }; + + state_i2cmux_idle: pinmux_i2cmux_idle { + ddc { + nvidia,pins = "ddc"; + nvidia,function = "rsvd4"; + }; + pta { + nvidia,pins = "pta"; + nvidia,function = "rsvd4"; }; }; };
+ i2s@70002800 { + status = "okay"; + }; + serial@70006300 { + status = "okay"; clock-frequency = < 216000000 >; };
@@ -79,56 +356,376 @@ }; };
+ pwm: pwm@7000a000 { + status = "okay"; + }; + i2c@7000c000 { status = "okay"; - clock-frequency = <100000>; + clock-frequency = <400000>; + + wm8903: wm8903@1a { + compatible = "wlf,wm8903"; + reg = <0x1a>; + interrupt-parent = <&gpio>; + interrupts = <TEGRA_GPIO(X, 3) IRQ_TYPE_LEVEL_HIGH>; + + gpio-controller; + #gpio-cells = <2>; + + micdet-cfg = <0>; + micdet-delay = <100>; + gpio-cfg = <0xffffffff 0xffffffff 0 0xffffffff 0xffffffff>; + }; + + /* ALS and proximity sensor */ + isl29018@44 { + compatible = "isil,isl29018"; + reg = <0x44>; + interrupt-parent = <&gpio>; + interrupts = <TEGRA_GPIO(Z, 2) IRQ_TYPE_LEVEL_HIGH>; + }; + + gyrometer@68 { + compatible = "invn,mpu3050"; + reg = <0x68>; + interrupt-parent = <&gpio>; + interrupts = <TEGRA_GPIO(Z, 4) IRQ_TYPE_LEVEL_HIGH>; + }; };
i2c@7000c400 { status = "okay"; + clock-frequency = <100000>; + }; + + i2cmux { + compatible = "i2c-mux-pinctrl"; + #address-cells = <1>; + #size-cells = <0>; + + i2c-parent = <&{/i2c@7000c400}>; + + pinctrl-names = "ddc", "pta", "idle"; + pinctrl-0 = <&state_i2cmux_ddc>; + pinctrl-1 = <&state_i2cmux_pta>; + pinctrl-2 = <&state_i2cmux_idle>; + + hdmi_ddc: i2c@0 { + reg = <0>; + #address-cells = <1>; + #size-cells = <0>; + }; + + lvds_ddc: i2c@1 { + reg = <1>; + #address-cells = <1>; + #size-cells = <0>; + + smart-battery@b { + compatible = "ti,bq20z75", "smart-battery-1.1"; + reg = <0xb>; + ti,i2c-retry-count = <2>; + ti,poll-retry-count = <10>; + }; + }; };
i2c@7000c500 { status = "okay"; - clock-frequency = <100000>; + clock-frequency = <400000>; + }; + + i2c@7000d000 { + status = "okay"; + clock-frequency = <400000>; + + magnetometer@c { + compatible = "asahi-kasei,ak8975"; + reg = <0xc>; + interrupt-parent = <&gpio>; + interrupts = <TEGRA_GPIO(N, 5) IRQ_TYPE_LEVEL_HIGH>; + }; + + pmic: tps6586x@34 { + compatible = "ti,tps6586x"; + reg = <0x34>; + interrupts = <GIC_SPI 86 IRQ_TYPE_LEVEL_HIGH>; + + ti,system-power-controller; + + #gpio-cells = <2>; + gpio-controller; + + sys-supply = <&vdd_5v0_reg>; + vin-sm0-supply = <&sys_reg>; + vin-sm1-supply = <&sys_reg>; + vin-sm2-supply = <&sys_reg>; + vinldo01-supply = <&sm2_reg>; + vinldo23-supply = <&sm2_reg>; + vinldo4-supply = <&sm2_reg>; + vinldo678-supply = <&sm2_reg>; + vinldo9-supply = <&sm2_reg>; + + regulators { + sys_reg: sys { + regulator-name = "vdd_sys"; + regulator-always-on; + }; + + sm0 { + regulator-name = "vdd_sm0,vdd_core"; + regulator-min-microvolt = <1300000>; + regulator-max-microvolt = <1300000>; + regulator-always-on; + }; + + sm1 { + regulator-name = "vdd_sm1,vdd_cpu"; + regulator-min-microvolt = <1125000>; + regulator-max-microvolt = <1125000>; + regulator-always-on; + }; + + sm2_reg: sm2 { + regulator-name = "vdd_sm2,vin_ldo*"; + regulator-min-microvolt = <3700000>; + regulator-max-microvolt = <3700000>; + regulator-always-on; + }; + + /* LDO0 is not connected to anything */ + + ldo1 { + regulator-name = "vdd_ldo1,avdd_pll*"; + regulator-min-microvolt = <1100000>; + regulator-max-microvolt = <1100000>; + regulator-always-on; + }; + + ldo2 { + regulator-name = "vdd_ldo2,vdd_rtc"; + regulator-min-microvolt = <1200000>; + regulator-max-microvolt = <1200000>; + }; + + ldo3 { + regulator-name = "vdd_ldo3,avdd_usb*"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + regulator-always-on; + }; + + ldo4 { + regulator-name = "vdd_ldo4,avdd_osc,vddio_sys"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-always-on; + }; + + ldo5 { + regulator-name = "vdd_ldo5,vcore_mmc"; + regulator-min-microvolt = <2850000>; + regulator-max-microvolt = <2850000>; + regulator-always-on; + }; + + ldo6 { + regulator-name = "vdd_ldo6,avdd_vdac,vddio_vi,vddio_cam"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + }; + + hdmi_vdd_reg: ldo7 { + regulator-name = "vdd_ldo7,avdd_hdmi,vdd_fuse"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + }; + + hdmi_pll_reg: ldo8 { + regulator-name = "vdd_ldo8,avdd_hdmi_pll"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + }; + + ldo9 { + regulator-name = "vdd_ldo9,avdd_2v85,vdd_ddr_rx"; + regulator-min-microvolt = <2850000>; + regulator-max-microvolt = <2850000>; + regulator-always-on; + }; + + ldo_rtc { + regulator-name = "vdd_rtc_out,vdd_cell"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + regulator-always-on; + }; + }; + }; + + temperature-sensor@4c { + compatible = "onnn,nct1008"; + reg = <0x4c>; + }; };
kbc@7000e200 { status = "okay"; - linux,keymap = <0x00020011 0x0003001f 0x0004001e 0x0005002c - 0x000701d0 0x0107007d 0x02060064 0x02070038 0x03000006 - 0x03010005 0x03020013 0x03030012 0x03040021 0x03050020 - 0x0306002d 0x04000008 0x04010007 0x04020014 0x04030023 - 0x04040022 0x0405002f 0x0406002e 0x04070039 0x0500000a - 0x05010009 0x05020016 0x05030015 0x05040024 0x05050031 - 0x05060030 0x0507002b 0x0600000c 0x0601000b 0x06020018 - 0x06030017 0x06040026 0x06050025 0x06060033 0x06070032 - 0x0701000d 0x0702001b 0x0703001c 0x0707008b 0x08040036 - 0x0805002a 0x09050061 0x0907001d 0x0b00001a 0x0b010019 - 0x0b020028 0x0b030027 0x0b040035 0x0b050034 0x0c000044 - 0x0c010043 0x0c02000e 0x0c030004 0x0c040003 0x0c050067 - 0x0c0600d2 0x0c070077 0x0d00006e 0x0d01006f 0x0d030068 - 0x0d04006d 0x0d05006a 0x0d06006c 0x0d070069 0x0e000057 - 0x0e010058 0x0e020042 0x0e030010 0x0e04003e 0x0e05003d - 0x0e060002 0x0e070041 0x0f000001 0x0f010029 0x0f02003f - 0x0f03000f 0x0f04003b 0x0f05003c 0x0f06003a 0x0f070040 - 0x14000047 0x15000049 0x15010048 0x1502004b 0x1504004f - 0x16010062 0x1602004d 0x1603004c 0x16040051 0x16050050 - 0x16070052 0x1b010037 0x1b03004a 0x1b04004e 0x1b050053 - 0x1c050073 0x1d030066 0x1d04006b 0x1d0500e0 0x1d060072 - 0x1d0700e1 0x1e000045 0x1e010046 0x1e020071 - 0x1f04008a>; - linux,fn-keymap = <0x05040002>; - }; - - emc@7000f400 { - #address-cells = <1>; - #size-cells = <0>; + nvidia,debounce-delay-ms = <32>; + nvidia,repeat-delay-ms = <160>; + nvidia,ghost-filter; + nvidia,kbc-row-pins = <0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15>; + nvidia,kbc-col-pins = <16 17 18 19 20 21 22 23>; + linux,keymap = <MATRIX_KEY(0x00, 0x02, KEY_W) + MATRIX_KEY(0x00, 0x03, KEY_S) + MATRIX_KEY(0x00, 0x04, KEY_A) + MATRIX_KEY(0x00, 0x05, KEY_Z) + MATRIX_KEY(0x00, 0x07, KEY_FN) + + MATRIX_KEY(0x01, 0x07, KEY_LEFTMETA) + MATRIX_KEY(0x02, 0x06, KEY_RIGHTALT) + MATRIX_KEY(0x02, 0x07, KEY_LEFTALT) + + MATRIX_KEY(0x03, 0x00, KEY_5) + MATRIX_KEY(0x03, 0x01, KEY_4) + MATRIX_KEY(0x03, 0x02, KEY_R) + MATRIX_KEY(0x03, 0x03, KEY_E) + MATRIX_KEY(0x03, 0x04, KEY_F) + MATRIX_KEY(0x03, 0x05, KEY_D) + MATRIX_KEY(0x03, 0x06, KEY_X) + + MATRIX_KEY(0x04, 0x00, KEY_7) + MATRIX_KEY(0x04, 0x01, KEY_6) + MATRIX_KEY(0x04, 0x02, KEY_T) + MATRIX_KEY(0x04, 0x03, KEY_H) + MATRIX_KEY(0x04, 0x04, KEY_G) + MATRIX_KEY(0x04, 0x05, KEY_V) + MATRIX_KEY(0x04, 0x06, KEY_C) + MATRIX_KEY(0x04, 0x07, KEY_SPACE) + + MATRIX_KEY(0x05, 0x00, KEY_9) + MATRIX_KEY(0x05, 0x01, KEY_8) + MATRIX_KEY(0x05, 0x02, KEY_U) + MATRIX_KEY(0x05, 0x03, KEY_Y) + MATRIX_KEY(0x05, 0x04, KEY_J) + MATRIX_KEY(0x05, 0x05, KEY_N) + MATRIX_KEY(0x05, 0x06, KEY_B) + MATRIX_KEY(0x05, 0x07, KEY_BACKSLASH) + + MATRIX_KEY(0x06, 0x00, KEY_MINUS) + MATRIX_KEY(0x06, 0x01, KEY_0) + MATRIX_KEY(0x06, 0x02, KEY_O) + MATRIX_KEY(0x06, 0x03, KEY_I) + MATRIX_KEY(0x06, 0x04, KEY_L) + MATRIX_KEY(0x06, 0x05, KEY_K) + MATRIX_KEY(0x06, 0x06, KEY_COMMA) + MATRIX_KEY(0x06, 0x07, KEY_M) + + MATRIX_KEY(0x07, 0x01, KEY_EQUAL) + MATRIX_KEY(0x07, 0x02, KEY_RIGHTBRACE) + MATRIX_KEY(0x07, 0x03, KEY_ENTER) + MATRIX_KEY(0x07, 0x07, KEY_MENU) + + MATRIX_KEY(0x08, 0x04, KEY_RIGHTSHIFT) + MATRIX_KEY(0x08, 0x05, KEY_LEFTSHIFT) + + MATRIX_KEY(0x09, 0x05, KEY_RIGHTCTRL) + MATRIX_KEY(0x09, 0x07, KEY_LEFTCTRL) + + MATRIX_KEY(0x0B, 0x00, KEY_LEFTBRACE) + MATRIX_KEY(0x0B, 0x01, KEY_P) + MATRIX_KEY(0x0B, 0x02, KEY_APOSTROPHE) + MATRIX_KEY(0x0B, 0x03, KEY_SEMICOLON) + MATRIX_KEY(0x0B, 0x04, KEY_SLASH) + MATRIX_KEY(0x0B, 0x05, KEY_DOT) + + MATRIX_KEY(0x0C, 0x00, KEY_F10) + MATRIX_KEY(0x0C, 0x01, KEY_F9) + MATRIX_KEY(0x0C, 0x02, KEY_BACKSPACE) + MATRIX_KEY(0x0C, 0x03, KEY_3) + MATRIX_KEY(0x0C, 0x04, KEY_2) + MATRIX_KEY(0x0C, 0x05, KEY_UP) + MATRIX_KEY(0x0C, 0x06, KEY_PRINT) + MATRIX_KEY(0x0C, 0x07, KEY_PAUSE) + + MATRIX_KEY(0x0D, 0x00, KEY_INSERT) + MATRIX_KEY(0x0D, 0x01, KEY_DELETE) + MATRIX_KEY(0x0D, 0x03, KEY_PAGEUP ) + MATRIX_KEY(0x0D, 0x04, KEY_PAGEDOWN) + MATRIX_KEY(0x0D, 0x05, KEY_RIGHT) + MATRIX_KEY(0x0D, 0x06, KEY_DOWN) + MATRIX_KEY(0x0D, 0x07, KEY_LEFT) + + MATRIX_KEY(0x0E, 0x00, KEY_F11) + MATRIX_KEY(0x0E, 0x01, KEY_F12) + MATRIX_KEY(0x0E, 0x02, KEY_F8) + MATRIX_KEY(0x0E, 0x03, KEY_Q) + MATRIX_KEY(0x0E, 0x04, KEY_F4) + MATRIX_KEY(0x0E, 0x05, KEY_F3) + MATRIX_KEY(0x0E, 0x06, KEY_1) + MATRIX_KEY(0x0E, 0x07, KEY_F7) + + MATRIX_KEY(0x0F, 0x00, KEY_ESC) + MATRIX_KEY(0x0F, 0x01, KEY_GRAVE) + MATRIX_KEY(0x0F, 0x02, KEY_F5) + MATRIX_KEY(0x0F, 0x03, KEY_TAB) + MATRIX_KEY(0x0F, 0x04, KEY_F1) + MATRIX_KEY(0x0F, 0x05, KEY_F2) + MATRIX_KEY(0x0F, 0x06, KEY_CAPSLOCK) + MATRIX_KEY(0x0F, 0x07, KEY_F6) + + /* Software Handled Function Keys */ + MATRIX_KEY(0x14, 0x00, KEY_KP7) + + MATRIX_KEY(0x15, 0x00, KEY_KP9) + MATRIX_KEY(0x15, 0x01, KEY_KP8) + MATRIX_KEY(0x15, 0x02, KEY_KP4) + MATRIX_KEY(0x15, 0x04, KEY_KP1) + + MATRIX_KEY(0x16, 0x01, KEY_KPSLASH) + MATRIX_KEY(0x16, 0x02, KEY_KP6) + MATRIX_KEY(0x16, 0x03, KEY_KP5) + MATRIX_KEY(0x16, 0x04, KEY_KP3) + MATRIX_KEY(0x16, 0x05, KEY_KP2) + MATRIX_KEY(0x16, 0x07, KEY_KP0) + + MATRIX_KEY(0x1B, 0x01, KEY_KPASTERISK) + MATRIX_KEY(0x1B, 0x03, KEY_KPMINUS) + MATRIX_KEY(0x1B, 0x04, KEY_KPPLUS) + MATRIX_KEY(0x1B, 0x05, KEY_KPDOT) + + MATRIX_KEY(0x1C, 0x05, KEY_VOLUMEUP) + + MATRIX_KEY(0x1D, 0x03, KEY_HOME) + MATRIX_KEY(0x1D, 0x04, KEY_END) + MATRIX_KEY(0x1D, 0x05, KEY_BRIGHTNESSDOWN) + MATRIX_KEY(0x1D, 0x06, KEY_VOLUMEDOWN) + MATRIX_KEY(0x1D, 0x07, KEY_BRIGHTNESSUP) + + MATRIX_KEY(0x1E, 0x00, KEY_NUMLOCK) + MATRIX_KEY(0x1E, 0x01, KEY_SCROLLLOCK) + MATRIX_KEY(0x1E, 0x02, KEY_MUTE) + + MATRIX_KEY(0x1F, 0x04, KEY_HELP)>; + }; + + pmc@7000e400 { + nvidia,invert-interrupt; + nvidia,suspend-mode = <1>; + nvidia,cpu-pwr-good-time = <5000>; + nvidia,cpu-pwr-off-time = <5000>; + nvidia,core-pwr-good-time = <3845 3845>; + nvidia,core-pwr-off-time = <3875>; + nvidia,sys-clock-req-active-high; + }; + + memory-controller@7000f400 { emc-table@190000 { - reg = < 190000 >; + reg = <190000>; compatible = "nvidia,tegra20-emc-table"; - clock-frequency = < 190000 >; - nvidia,emc-registers = < 0x0000000c 0x00000026 + clock-frequency = <190000>; + nvidia,emc-registers = <0x0000000c 0x00000026 0x00000009 0x00000003 0x00000004 0x00000004 0x00000002 0x0000000c 0x00000003 0x00000003 0x00000002 0x00000001 0x00000004 0x00000005 @@ -139,13 +736,14 @@ 0x00000002 0x00000000 0x00000000 0x00000002 0x00000000 0x00000000 0x00000083 0xa06204ae 0x007dc010 0x00000000 0x00000000 0x00000000 - 0x00000000 0x00000000 0x00000000 0x00000000 >; + 0x00000000 0x00000000 0x00000000 0x00000000>; }; + emc-table@380000 { - reg = < 380000 >; + reg = <380000>; compatible = "nvidia,tegra20-emc-table"; - clock-frequency = < 380000 >; - nvidia,emc-registers = < 0x00000017 0x0000004b + clock-frequency = <380000>; + nvidia,emc-registers = <0x00000017 0x0000004b 0x00000012 0x00000006 0x00000004 0x00000005 0x00000003 0x0000000c 0x00000006 0x00000006 0x00000003 0x00000001 0x00000004 0x00000005 @@ -156,7 +754,7 @@ 0x00000002 0x00000000 0x00000000 0x00000002 0x00000000 0x00000000 0x00000083 0xe044048b 0x007d8010 0x00000000 0x00000000 0x00000000 - 0x00000000 0x00000000 0x00000000 0x00000000 >; + 0x00000000 0x00000000 0x00000000 0x00000000>; }; };
@@ -166,14 +764,39 @@ dr_mode = "otg"; };
+ usb-phy@c5000000 { + status = "okay"; + vbus-supply = <&vbus_reg>; + dr_mode = "otg"; + }; + usb@c5004000 { status = "disabled"; + nvidia,phy-reset-gpio = <&gpio TEGRA_GPIO(V, 1) + GPIO_ACTIVE_LOW>; + }; + + usb-phy@c5004000 { + status = "okay"; + nvidia,phy-reset-gpio = <&gpio TEGRA_GPIO(V, 1) + GPIO_ACTIVE_LOW>; };
usb@c5008000 { status = "okay"; };
+ usb-phy@c5008000 { + status = "okay"; + }; + + sdhci@c8000000 { + status = "okay"; + power-gpios = <&gpio TEGRA_GPIO(K, 6) GPIO_ACTIVE_HIGH>; + bus-width = <4>; + keep-power-in-suspend; + }; + sdhci@c8000400 { status = "okay"; cd-gpios = <&gpio TEGRA_GPIO(I, 5) GPIO_ACTIVE_LOW>; @@ -185,6 +808,18 @@ sdhci@c8000600 { status = "okay"; bus-width = <8>; + non-removable; + }; + + backlight: backlight { + compatible = "pwm-backlight"; + + enable-gpios = <&gpio TEGRA_GPIO(D, 4) GPIO_ACTIVE_HIGH>; + power-supply = <&vdd_bl_reg>; + pwms = <&pwm 2 5000000>; + + brightness-levels = <0 4 8 16 32 64 128 255>; + default-brightness-level = <6>; };
clocks { @@ -200,11 +835,27 @@ }; };
- pwm: pwm@7000a000 { - status = "okay"; + gpio-keys { + compatible = "gpio-keys"; + + power { + label = "Power"; + gpios = <&gpio TEGRA_GPIO(V, 2) GPIO_ACTIVE_LOW>; + linux,code = <KEY_POWER>; + gpio-key,wakeup; + }; + + lid { + label = "Lid"; + gpios = <&gpio TEGRA_GPIO(C, 7) GPIO_ACTIVE_HIGH>; + linux,input-type = <5>; /* EV_SW */ + linux,code = <0>; /* SW_LID */ + debounce-interval = <1>; + gpio-key,wakeup; + }; };
- lcd_panel: panel { + panel: panel { /* Seaboard has 1366x768 */ clock = <70600000>; xres = <1366>; @@ -228,4 +879,108 @@ GPIO_ACTIVE_HIGH>; nvidia,panel-timings = <400 4 203 17 15>; }; + + regulators { + compatible = "simple-bus"; + #address-cells = <1>; + #size-cells = <0>; + + vdd_5v0_reg: regulator@0 { + compatible = "regulator-fixed"; + reg = <0>; + regulator-name = "vdd_5v0"; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + regulator-always-on; + }; + + regulator@1 { + compatible = "regulator-fixed"; + reg = <1>; + regulator-name = "vdd_1v5"; + regulator-min-microvolt = <1500000>; + regulator-max-microvolt = <1500000>; + gpio = <&pmic 0 GPIO_ACTIVE_HIGH>; + }; + + regulator@2 { + compatible = "regulator-fixed"; + reg = <2>; + regulator-name = "vdd_1v2"; + regulator-min-microvolt = <1200000>; + regulator-max-microvolt = <1200000>; + gpio = <&pmic 1 GPIO_ACTIVE_HIGH>; + enable-active-high; + }; + + vbus_reg: regulator@3 { + compatible = "regulator-fixed"; + reg = <3>; + regulator-name = "vdd_vbus_wup1"; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + enable-active-high; + gpio = <&gpio TEGRA_GPIO(D, 0) 0>; + regulator-always-on; + regulator-boot-on; + }; + + vdd_pnl_reg: regulator@4 { + compatible = "regulator-fixed"; + reg = <4>; + regulator-name = "vdd_pnl"; + regulator-min-microvolt = <2800000>; + regulator-max-microvolt = <2800000>; + gpio = <&gpio TEGRA_GPIO(C, 6) GPIO_ACTIVE_HIGH>; + enable-active-high; + }; + + vdd_bl_reg: regulator@5 { + compatible = "regulator-fixed"; + reg = <5>; + regulator-name = "vdd_bl"; + regulator-min-microvolt = <2800000>; + regulator-max-microvolt = <2800000>; + gpio = <&gpio TEGRA_GPIO(W, 0) GPIO_ACTIVE_HIGH>; + enable-active-high; + }; + + vdd_hdmi: regulator@6 { + compatible = "regulator-fixed"; + reg = <6>; + regulator-name = "VDDIO_HDMI"; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + gpio = <&gpio TEGRA_GPIO(V, 5) GPIO_ACTIVE_HIGH>; + enable-active-high; + vin-supply = <&vdd_5v0_reg>; + }; + }; + + sound { + compatible = "nvidia,tegra-audio-wm8903-seaboard", + "nvidia,tegra-audio-wm8903"; + nvidia,model = "NVIDIA Tegra Seaboard"; + + nvidia,audio-routing = + "Headphone Jack", "HPOUTR", + "Headphone Jack", "HPOUTL", + "Int Spk", "ROP", + "Int Spk", "RON", + "Int Spk", "LOP", + "Int Spk", "LON", + "Mic Jack", "MICBIAS", + "IN1R", "Mic Jack"; + + nvidia,i2s-controller = <&tegra_i2s1>; + nvidia,audio-codec = <&wm8903>; + + nvidia,spkr-en-gpios = <&wm8903 2 GPIO_ACTIVE_HIGH>; + nvidia,hp-det-gpios = <&gpio TEGRA_GPIO(X, 1) GPIO_ACTIVE_HIGH>; + + clocks = <&tegra_car TEGRA20_CLK_PLL_A>, + <&tegra_car TEGRA20_CLK_PLL_A_OUT0>, + <&tegra_car TEGRA20_CLK_CDEV1>; + clock-names = "pll_a", "pll_a_out0", "mclk"; + }; };
It would be useful to mention which version of Linux this DT content came from.
BTW, this series (at least this patch) seems to have a significant number of "git am" conflicts when I try to apply it to either v2016.01 or u-boot/master as of today. Consequently I can't apply it to test it. Which commit/branch is it based on?
- pinmux@70000014 {
I agree that the DT content that's common between U-Boot's and Linux's copies of the DT files should be identical. However, I wonder if it makes sense to include nodes (and perhaps even properties) in U-Boot's DT that U-Boot doesn't use.
I can see the argument that keeping the files identical is easier to track and remove any differences.
However, I'd also argue that keeping the U-Boot DT files lean (i.e. only containing the nodes U-Boot uses) will allow easier determination of exactly what parts of the DT U-Boot uses, and hence perhaps highlight any parts that might still need conversion.
Hi Stephen,
See u-boot-dm/rkf-working, which has all the patches.
pinmux@70000014 {
Indeed. I'm leaning towards including everything since it is simple. On tegra we don't use pinctrl so that is a waste, but it's not that huge.
We have standard drivers for panels and backlights which can do most of the work for us. Move the tegra20 LCD driver over to use those instead of custom code.
This patch includes device tree changes for the nvidia boards. I have only been able to test seaboard. If this patch is applied, these boards will also need to be synced with the kernel, and updated to use display-timings:
- colibri - medcom-wide - paz00 - tec
arch/arm/dts/tegra20-harmony.dts | 751 ++++++++++++++++++++++++++++++++++++-- arch/arm/dts/tegra20-seaboard.dts | 45 +-- arch/arm/dts/tegra20-ventana.dts | 685 ++++++++++++++++++++++++++++++++-- configs/colibri_t20_defconfig | 5 +- configs/harmony_defconfig | 5 +- configs/medcom-wide_defconfig | 5 +- configs/paz00_defconfig | 5 +- configs/seaboard_defconfig | 5 +- configs/tec_defconfig | 5 +- configs/ventana_defconfig | 5 +- drivers/video/tegra.c | 312 +++------------- 11 files changed, 1482 insertions(+), 346 deletions(-)
diff --git a/arch/arm/dts/tegra20-harmony.dts b/arch/arm/dts/tegra20-harmony.dts index 623eb90..8e9fe5a 100644 --- a/arch/arm/dts/tegra20-harmony.dts +++ b/arch/arm/dts/tegra20-harmony.dts @@ -1,5 +1,6 @@ /dts-v1/;
/ { @@ -11,6 +12,9 @@ };
aliases { + rtc0 = "/i2c@7000d000/tps6586x@34"; + rtc1 = "/rtc@7000e000"; + serial0 = &uartd; usb0 = "/usb@c5008000"; usb1 = "/usb@c5004000"; sdhci0 = "/sdhci@c8000600"; @@ -27,15 +31,295 @@ status = "okay"; rgb { status = "okay"; - nvidia,panel = <&lcd_panel>; + + nvidia,panel = <&panel>; + + display-timings { + timing@0 { + /* Seaboard has 1366x768 */ + clock-frequency = <42430000>; + hactive = <1024>; + vactive = <600>; + hback-porch = <138>; + hfront-porch = <34>; + hsync-len = <136>; + vback-porch = <21>; + vfront-porch = <4>; + vsync-len = <4>; + }; + }; + }; + }; + + hdmi@54280000 { + status = "okay"; + + hdmi-supply = <&vdd_5v0_hdmi>; + vdd-supply = <&hdmi_vdd_reg>; + pll-supply = <&hdmi_pll_reg>; + + nvidia,ddc-i2c-bus = <&hdmi_ddc>; + nvidia,hpd-gpio = <&gpio TEGRA_GPIO(N, 7) + GPIO_ACTIVE_HIGH>; + }; + }; + + pinmux@70000014 { + pinctrl-names = "default"; + pinctrl-0 = <&state_default>; + + state_default: pinmux { + ata { + nvidia,pins = "ata"; + nvidia,function = "ide"; + }; + atb { + nvidia,pins = "atb", "gma", "gme"; + nvidia,function = "sdio4"; + }; + atc { + nvidia,pins = "atc"; + nvidia,function = "nand"; + }; + atd { + nvidia,pins = "atd", "ate", "gmb", "gmd", "gpu", + "spia", "spib", "spic"; + nvidia,function = "gmi"; + }; + cdev1 { + nvidia,pins = "cdev1"; + nvidia,function = "plla_out"; + }; + cdev2 { + nvidia,pins = "cdev2"; + nvidia,function = "pllp_out4"; + }; + crtp { + nvidia,pins = "crtp"; + nvidia,function = "crt"; + }; + csus { + nvidia,pins = "csus"; + nvidia,function = "vi_sensor_clk"; + }; + dap1 { + nvidia,pins = "dap1"; + nvidia,function = "dap1"; + }; + dap2 { + nvidia,pins = "dap2"; + nvidia,function = "dap2"; + }; + dap3 { + nvidia,pins = "dap3"; + nvidia,function = "dap3"; + }; + dap4 { + nvidia,pins = "dap4"; + nvidia,function = "dap4"; + }; + ddc { + nvidia,pins = "ddc"; + nvidia,function = "i2c2"; + }; + dta { + nvidia,pins = "dta", "dtd"; + nvidia,function = "sdio2"; + }; + dtb { + nvidia,pins = "dtb", "dtc", "dte"; + nvidia,function = "rsvd1"; + }; + dtf { + nvidia,pins = "dtf"; + nvidia,function = "i2c3"; + }; + gmc { + nvidia,pins = "gmc"; + nvidia,function = "uartd"; + }; + gpu7 { + nvidia,pins = "gpu7"; + nvidia,function = "rtck"; + }; + gpv { + nvidia,pins = "gpv", "slxa", "slxk"; + nvidia,function = "pcie"; + }; + hdint { + nvidia,pins = "hdint", "pta"; + nvidia,function = "hdmi"; + }; + i2cp { + nvidia,pins = "i2cp"; + nvidia,function = "i2cp"; + }; + irrx { + nvidia,pins = "irrx", "irtx"; + nvidia,function = "uarta"; + }; + kbca { + nvidia,pins = "kbca", "kbcb", "kbcc", "kbcd", + "kbce", "kbcf"; + nvidia,function = "kbc"; + }; + lcsn { + nvidia,pins = "lcsn", "ld0", "ld1", "ld2", + "ld3", "ld4", "ld5", "ld6", "ld7", + "ld8", "ld9", "ld10", "ld11", "ld12", + "ld13", "ld14", "ld15", "ld16", "ld17", + "ldc", "ldi", "lhp0", "lhp1", "lhp2", + "lhs", "lm0", "lm1", "lpp", "lpw0", + "lpw1", "lpw2", "lsc0", "lsc1", "lsck", + "lsda", "lsdi", "lspi", "lvp0", "lvp1", + "lvs"; + nvidia,function = "displaya"; + }; + owc { + nvidia,pins = "owc", "spdi", "spdo", "uac"; + nvidia,function = "rsvd2"; + }; + pmc { + nvidia,pins = "pmc"; + nvidia,function = "pwr_on"; + }; + rm { + nvidia,pins = "rm"; + nvidia,function = "i2c1"; + }; + sdb { + nvidia,pins = "sdb", "sdc", "sdd"; + nvidia,function = "pwm"; + }; + sdio1 { + nvidia,pins = "sdio1"; + nvidia,function = "sdio1"; + }; + slxc { + nvidia,pins = "slxc", "slxd"; + nvidia,function = "spdif"; + }; + spid { + nvidia,pins = "spid", "spie", "spif"; + nvidia,function = "spi1"; + }; + spig { + nvidia,pins = "spig", "spih"; + nvidia,function = "spi2_alt"; + }; + uaa { + nvidia,pins = "uaa", "uab", "uda"; + nvidia,function = "ulpi"; + }; + uad { + nvidia,pins = "uad"; + nvidia,function = "irda"; + }; + uca { + nvidia,pins = "uca", "ucb"; + nvidia,function = "uartc"; + }; + conf_ata { + nvidia,pins = "ata", "atb", "atc", "atd", "ate", + "cdev1", "cdev2", "dap1", "dtb", "gma", + "gmb", "gmc", "gmd", "gme", "gpu7", + "gpv", "i2cp", "pta", "rm", "slxa", + "slxk", "spia", "spib", "uac"; + nvidia,pull = <TEGRA_PIN_PULL_NONE>; + nvidia,tristate = <TEGRA_PIN_DISABLE>; + }; + conf_ck32 { + nvidia,pins = "ck32", "ddrc", "pmca", "pmcb", + "pmcc", "pmcd", "pmce", "xm2c", "xm2d"; + nvidia,pull = <TEGRA_PIN_PULL_NONE>; + }; + conf_csus { + nvidia,pins = "csus", "spid", "spif"; + nvidia,pull = <TEGRA_PIN_PULL_DOWN>; + nvidia,tristate = <TEGRA_PIN_ENABLE>; + }; + conf_crtp { + nvidia,pins = "crtp", "dap2", "dap3", "dap4", + "dtc", "dte", "dtf", "gpu", "sdio1", + "slxc", "slxd", "spdi", "spdo", "spig", + "uda"; + nvidia,pull = <TEGRA_PIN_PULL_NONE>; + nvidia,tristate = <TEGRA_PIN_ENABLE>; + }; + conf_ddc { + nvidia,pins = "ddc", "dta", "dtd", "kbca", + "kbcb", "kbcc", "kbcd", "kbce", "kbcf", + "sdc"; + nvidia,pull = <TEGRA_PIN_PULL_UP>; + nvidia,tristate = <TEGRA_PIN_DISABLE>; + }; + conf_hdint { + nvidia,pins = "hdint", "lcsn", "ldc", "lm1", + "lpw1", "lsc1", "lsck", "lsda", "lsdi", + "lvp0", "owc", "sdb"; + nvidia,tristate = <TEGRA_PIN_ENABLE>; + }; + conf_irrx { + nvidia,pins = "irrx", "irtx", "sdd", "spic", + "spie", "spih", "uaa", "uab", "uad", + "uca", "ucb"; + nvidia,pull = <TEGRA_PIN_PULL_UP>; + nvidia,tristate = <TEGRA_PIN_ENABLE>; + }; + conf_lc { + nvidia,pins = "lc", "ls"; + nvidia,pull = <TEGRA_PIN_PULL_UP>; + }; + conf_ld0 { + nvidia,pins = "ld0", "ld1", "ld2", "ld3", "ld4", + "ld5", "ld6", "ld7", "ld8", "ld9", + "ld10", "ld11", "ld12", "ld13", "ld14", + "ld15", "ld16", "ld17", "ldi", "lhp0", + "lhp1", "lhp2", "lhs", "lm0", "lpp", + "lpw0", "lpw2", "lsc0", "lspi", "lvp1", + "lvs", "pmc"; + nvidia,tristate = <TEGRA_PIN_DISABLE>; + }; + conf_ld17_0 { + nvidia,pins = "ld17_0", "ld19_18", "ld21_20", + "ld23_22"; + nvidia,pull = <TEGRA_PIN_PULL_DOWN>; }; }; };
+ pwm: pwm@7000a000 { + status = "okay"; + }; + + i2c@7000c000 { + status = "okay"; + clock-frequency = <400000>; + + wm8903: wm8903@1a { + compatible = "wlf,wm8903"; + reg = <0x1a>; + interrupt-parent = <&gpio>; + interrupts = <TEGRA_GPIO(X, 3) IRQ_TYPE_LEVEL_HIGH>; + + gpio-controller; + #gpio-cells = <2>; + + micdet-cfg = <0>; + micdet-delay = <100>; + gpio-cfg = <0xffffffff 0xffffffff 0 0xffffffff 0xffffffff>; + }; + }; + nand-controller@70008000 { nvidia,wp-gpios = <&gpio TEGRA_GPIO(C, 7) GPIO_ACTIVE_HIGH>; nvidia,width = <8>; @@ -46,15 +330,319 @@ }; };
+ hdmi_ddc: i2c@7000c400 { + status = "okay"; + clock-frequency = <100000>; + }; + + i2c@7000c500 { + status = "okay"; + clock-frequency = <400000>; + }; + + i2c@7000d000 { + status = "okay"; + clock-frequency = <400000>; + + pmic: tps6586x@34 { + compatible = "ti,tps6586x"; + reg = <0x34>; + interrupts = <GIC_SPI 86 IRQ_TYPE_LEVEL_HIGH>; + + ti,system-power-controller; + + #gpio-cells = <2>; + gpio-controller; + + sys-supply = <&vdd_5v0_reg>; + vin-sm0-supply = <&sys_reg>; + vin-sm1-supply = <&sys_reg>; + vin-sm2-supply = <&sys_reg>; + vinldo01-supply = <&sm2_reg>; + vinldo23-supply = <&sm2_reg>; + vinldo4-supply = <&sm2_reg>; + vinldo678-supply = <&sm2_reg>; + vinldo9-supply = <&sm2_reg>; + + regulators { + sys_reg: sys { + regulator-name = "vdd_sys"; + regulator-always-on; + }; + + sm0 { + regulator-name = "vdd_sm0,vdd_core"; + regulator-min-microvolt = <1200000>; + regulator-max-microvolt = <1200000>; + regulator-always-on; + }; + + sm1 { + regulator-name = "vdd_sm1,vdd_cpu"; + regulator-min-microvolt = <1000000>; + regulator-max-microvolt = <1000000>; + regulator-always-on; + }; + + sm2_reg: sm2 { + regulator-name = "vdd_sm2,vin_ldo*"; + regulator-min-microvolt = <3700000>; + regulator-max-microvolt = <3700000>; + regulator-always-on; + }; + + pci_clk_reg: ldo0 { + regulator-name = "vdd_ldo0,vddio_pex_clk"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + }; + + ldo1 { + regulator-name = "vdd_ldo1,avdd_pll*"; + regulator-min-microvolt = <1100000>; + regulator-max-microvolt = <1100000>; + regulator-always-on; + }; + + ldo2 { + regulator-name = "vdd_ldo2,vdd_rtc"; + regulator-min-microvolt = <1200000>; + regulator-max-microvolt = <1200000>; + }; + + ldo3 { + regulator-name = "vdd_ldo3,avdd_usb*"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + regulator-always-on; + }; + + ldo4 { + regulator-name = "vdd_ldo4,avdd_osc,vddio_sys"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-always-on; + }; + + ldo5 { + regulator-name = "vdd_ldo5,vcore_mmc"; + regulator-min-microvolt = <2850000>; + regulator-max-microvolt = <2850000>; + regulator-always-on; + }; + + ldo6 { + regulator-name = "vdd_ldo6,avdd_vdac"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + }; + + hdmi_vdd_reg: ldo7 { + regulator-name = "vdd_ldo7,avdd_hdmi"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + }; + + hdmi_pll_reg: ldo8 { + regulator-name = "vdd_ldo8,avdd_hdmi_pll"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + }; + + ldo9 { + regulator-name = "vdd_ldo9,avdd_2v85,vdd_ddr_rx"; + regulator-min-microvolt = <2850000>; + regulator-max-microvolt = <2850000>; + regulator-always-on; + }; + + ldo_rtc { + regulator-name = "vdd_rtc_out,vdd_cell"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + regulator-always-on; + }; + }; + }; + + temperature-sensor@4c { + compatible = "adi,adt7461"; + reg = <0x4c>; + }; + }; + + kbc@7000e200 { + status = "okay"; + nvidia,debounce-delay-ms = <2>; + nvidia,repeat-delay-ms = <160>; + nvidia,kbc-row-pins = <0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15>; + nvidia,kbc-col-pins = <16 17 18 19 20 21 22 23>; + linux,keymap = <MATRIX_KEY(0x00, 0x02, KEY_W) + MATRIX_KEY(0x00, 0x03, KEY_S) + MATRIX_KEY(0x00, 0x04, KEY_A) + MATRIX_KEY(0x00, 0x05, KEY_Z) + MATRIX_KEY(0x00, 0x07, KEY_FN) + MATRIX_KEY(0x01, 0x07, KEY_MENU) + MATRIX_KEY(0x02, 0x06, KEY_LEFTALT) + MATRIX_KEY(0x02, 0x07, KEY_RIGHTALT) + MATRIX_KEY(0x03, 0x00, KEY_5) + MATRIX_KEY(0x03, 0x01, KEY_4) + MATRIX_KEY(0x03, 0x02, KEY_R) + MATRIX_KEY(0x03, 0x03, KEY_E) + MATRIX_KEY(0x03, 0x04, KEY_F) + MATRIX_KEY(0x03, 0x05, KEY_D) + MATRIX_KEY(0x03, 0x06, KEY_X) + MATRIX_KEY(0x04, 0x00, KEY_7) + MATRIX_KEY(0x04, 0x01, KEY_6) + MATRIX_KEY(0x04, 0x02, KEY_T) + MATRIX_KEY(0x04, 0x03, KEY_H) + MATRIX_KEY(0x04, 0x04, KEY_G) + MATRIX_KEY(0x04, 0x05, KEY_V) + MATRIX_KEY(0x04, 0x06, KEY_C) + MATRIX_KEY(0x04, 0x07, KEY_SPACE) + MATRIX_KEY(0x05, 0x00, KEY_9) + MATRIX_KEY(0x05, 0x01, KEY_8) + MATRIX_KEY(0x05, 0x02, KEY_U) + MATRIX_KEY(0x05, 0x03, KEY_Y) + MATRIX_KEY(0x05, 0x04, KEY_J) + MATRIX_KEY(0x05, 0x05, KEY_N) + MATRIX_KEY(0x05, 0x06, KEY_B) + MATRIX_KEY(0x05, 0x07, KEY_BACKSLASH) + MATRIX_KEY(0x06, 0x00, KEY_MINUS) + MATRIX_KEY(0x06, 0x01, KEY_0) + MATRIX_KEY(0x06, 0x02, KEY_O) + MATRIX_KEY(0x06, 0x03, KEY_I) + MATRIX_KEY(0x06, 0x04, KEY_L) + MATRIX_KEY(0x06, 0x05, KEY_K) + MATRIX_KEY(0x06, 0x06, KEY_COMMA) + MATRIX_KEY(0x06, 0x07, KEY_M) + MATRIX_KEY(0x07, 0x01, KEY_EQUAL) + MATRIX_KEY(0x07, 0x02, KEY_RIGHTBRACE) + MATRIX_KEY(0x07, 0x03, KEY_ENTER) + MATRIX_KEY(0x07, 0x07, KEY_MENU) + MATRIX_KEY(0x08, 0x04, KEY_LEFTSHIFT) + MATRIX_KEY(0x08, 0x05, KEY_RIGHTSHIFT) + MATRIX_KEY(0x09, 0x05, KEY_LEFTCTRL) + MATRIX_KEY(0x09, 0x07, KEY_RIGHTCTRL) + MATRIX_KEY(0x0B, 0x00, KEY_LEFTBRACE) + MATRIX_KEY(0x0B, 0x01, KEY_P) + MATRIX_KEY(0x0B, 0x02, KEY_APOSTROPHE) + MATRIX_KEY(0x0B, 0x03, KEY_SEMICOLON) + MATRIX_KEY(0x0B, 0x04, KEY_SLASH) + MATRIX_KEY(0x0B, 0x05, KEY_DOT) + MATRIX_KEY(0x0C, 0x00, KEY_F10) + MATRIX_KEY(0x0C, 0x01, KEY_F9) + MATRIX_KEY(0x0C, 0x02, KEY_BACKSPACE) + MATRIX_KEY(0x0C, 0x03, KEY_3) + MATRIX_KEY(0x0C, 0x04, KEY_2) + MATRIX_KEY(0x0C, 0x05, KEY_UP) + MATRIX_KEY(0x0C, 0x06, KEY_PRINT) + MATRIX_KEY(0x0C, 0x07, KEY_PAUSE) + MATRIX_KEY(0x0D, 0x00, KEY_INSERT) + MATRIX_KEY(0x0D, 0x01, KEY_DELETE) + MATRIX_KEY(0x0D, 0x03, KEY_PAGEUP ) + MATRIX_KEY(0x0D, 0x04, KEY_PAGEDOWN) + MATRIX_KEY(0x0D, 0x05, KEY_RIGHT) + MATRIX_KEY(0x0D, 0x06, KEY_DOWN) + MATRIX_KEY(0x0D, 0x07, KEY_LEFT) + MATRIX_KEY(0x0E, 0x00, KEY_F11) + MATRIX_KEY(0x0E, 0x01, KEY_F12) + MATRIX_KEY(0x0E, 0x02, KEY_F8) + MATRIX_KEY(0x0E, 0x03, KEY_Q) + MATRIX_KEY(0x0E, 0x04, KEY_F4) + MATRIX_KEY(0x0E, 0x05, KEY_F3) + MATRIX_KEY(0x0E, 0x06, KEY_1) + MATRIX_KEY(0x0E, 0x07, KEY_F7) + MATRIX_KEY(0x0F, 0x00, KEY_ESC) + MATRIX_KEY(0x0F, 0x01, KEY_GRAVE) + MATRIX_KEY(0x0F, 0x02, KEY_F5) + MATRIX_KEY(0x0F, 0x03, KEY_TAB) + MATRIX_KEY(0x0F, 0x04, KEY_F1) + MATRIX_KEY(0x0F, 0x05, KEY_F2) + MATRIX_KEY(0x0F, 0x06, KEY_CAPSLOCK) + MATRIX_KEY(0x0F, 0x07, KEY_F6) + MATRIX_KEY(0x14, 0x00, KEY_KP7) + MATRIX_KEY(0x15, 0x00, KEY_KP9) + MATRIX_KEY(0x15, 0x01, KEY_KP8) + MATRIX_KEY(0x15, 0x02, KEY_KP4) + MATRIX_KEY(0x15, 0x04, KEY_KP1) + MATRIX_KEY(0x16, 0x01, KEY_KPSLASH) + MATRIX_KEY(0x16, 0x02, KEY_KP6) + MATRIX_KEY(0x16, 0x03, KEY_KP5) + MATRIX_KEY(0x16, 0x04, KEY_KP3) + MATRIX_KEY(0x16, 0x05, KEY_KP2) + MATRIX_KEY(0x16, 0x07, KEY_KP0) + MATRIX_KEY(0x1B, 0x01, KEY_KPASTERISK) + MATRIX_KEY(0x1B, 0x03, KEY_KPMINUS) + MATRIX_KEY(0x1B, 0x04, KEY_KPPLUS) + MATRIX_KEY(0x1B, 0x05, KEY_KPDOT) + MATRIX_KEY(0x1C, 0x05, KEY_VOLUMEUP) + MATRIX_KEY(0x1D, 0x03, KEY_HOME) + MATRIX_KEY(0x1D, 0x04, KEY_END) + MATRIX_KEY(0x1D, 0x05, KEY_BRIGHTNESSUP) + MATRIX_KEY(0x1D, 0x06, KEY_VOLUMEDOWN) + MATRIX_KEY(0x1D, 0x07, KEY_BRIGHTNESSDOWN) + MATRIX_KEY(0x1E, 0x00, KEY_NUMLOCK) + MATRIX_KEY(0x1E, 0x01, KEY_SCROLLLOCK) + MATRIX_KEY(0x1E, 0x02, KEY_MUTE) + MATRIX_KEY(0x1F, 0x04, KEY_QUESTION)>; + }; + + pmc@7000e400 { + nvidia,invert-interrupt; + nvidia,suspend-mode = <1>; + nvidia,cpu-pwr-good-time = <5000>; + nvidia,cpu-pwr-off-time = <5000>; + nvidia,core-pwr-good-time = <3845 3845>; + nvidia,core-pwr-off-time = <3875>; + nvidia,sys-clock-req-active-high; + }; + + pcie-controller@80003000 { + status = "okay"; + + avdd-pex-supply = <&pci_vdd_reg>; + vdd-pex-supply = <&pci_vdd_reg>; + avdd-pex-pll-supply = <&pci_vdd_reg>; + avdd-plle-supply = <&pci_vdd_reg>; + vddio-pex-clk-supply = <&pci_clk_reg>; + + pci@1,0 { + status = "okay"; + }; + + pci@2,0 { + status = "okay"; + }; + }; + + usb@c5000000 { + status = "okay"; + }; + + usb-phy@c5000000 { + status = "okay"; + }; + usb@c5004000 { - statuc = "okay"; + status = "okay"; nvidia,phy-reset-gpio = <&gpio TEGRA_GPIO(V, 1) 0>; };
+ usb-phy@c5004000 { + status = "okay"; + nvidia,phy-reset-gpio = <&gpio TEGRA_GPIO(V, 1) + GPIO_ACTIVE_LOW>; + }; + usb@c5008000 { status = "okay"; };
+ usb-phy@c5008000 { + status = "okay"; + }; + sdhci@c8000200 { status = "okay"; cd-gpios = <&gpio TEGRA_GPIO(I, 5) GPIO_ACTIVE_LOW>; @@ -71,6 +659,17 @@ bus-width = <8>; };
+ backlight: backlight { + compatible = "pwm-backlight"; + + enable-gpios = <&gpio TEGRA_GPIO(B, 5) GPIO_ACTIVE_HIGH>; + power-supply = <&vdd_bl_reg>; + pwms = <&pwm 0 5000000>; + + brightness-levels = <0 4 8 16 32 64 128 255>; + default-brightness-level = <6>; + }; + clocks { compatible = "simple-bus"; #address-cells = <1>; @@ -84,32 +683,130 @@ }; };
- pwm: pwm@7000a000 { - status = "okay"; + gpio-keys { + compatible = "gpio-keys"; + + power { + label = "Power"; + gpios = <&gpio TEGRA_GPIO(V, 2) GPIO_ACTIVE_LOW>; + linux,code = <KEY_POWER>; + gpio-key,wakeup; + }; + }; + + panel: panel { + compatible = "auo,b101aw03", "simple-panel"; + + power-supply = <&vdd_pnl_reg>; + enable-gpios = <&gpio TEGRA_GPIO(B, 2) GPIO_ACTIVE_HIGH>; + + backlight = <&backlight>; };
- lcd_panel: panel { - clock = <42430000>; - xres = <1024>; - yres = <600>; - left-margin = <138>; - right-margin = <34>; - hsync-len = <136>; - lower-margin = <4>; - upper-margin = <21>; - vsync-len = <4>; - hsync-active-high; - vsyncx-active-high; - nvidia,bits-per-pixel = <16>; - nvidia,pwm = <&pwm 0 0>; - nvidia,backlight-enable-gpios = <&gpio TEGRA_GPIO(B, 5) - GPIO_ACTIVE_HIGH>; - nvidia,lvds-shutdown-gpios = <&gpio TEGRA_GPIO(B, 2) - GPIO_ACTIVE_HIGH>; - nvidia,backlight-vdd-gpios = <&gpio TEGRA_GPIO(W, 0) - GPIO_ACTIVE_HIGH>; - nvidia,panel-vdd-gpios = <&gpio TEGRA_GPIO(C, 6) - GPIO_ACTIVE_HIGH>; - nvidia,panel-timings = <0 0 200 0 0>; + regulators { + compatible = "simple-bus"; + #address-cells = <1>; + #size-cells = <0>; + + vdd_5v0_reg: regulator@0 { + compatible = "regulator-fixed"; + reg = <0>; + regulator-name = "vdd_5v0"; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + regulator-always-on; + }; + + regulator@1 { + compatible = "regulator-fixed"; + reg = <1>; + regulator-name = "vdd_1v5"; + regulator-min-microvolt = <1500000>; + regulator-max-microvolt = <1500000>; + gpio = <&pmic 0 GPIO_ACTIVE_HIGH>; + }; + + regulator@2 { + compatible = "regulator-fixed"; + reg = <2>; + regulator-name = "vdd_1v2"; + regulator-min-microvolt = <1200000>; + regulator-max-microvolt = <1200000>; + gpio = <&pmic 1 GPIO_ACTIVE_HIGH>; + enable-active-high; + }; + + pci_vdd_reg: regulator@3 { + compatible = "regulator-fixed"; + reg = <3>; + regulator-name = "vdd_1v05"; + regulator-min-microvolt = <1050000>; + regulator-max-microvolt = <1050000>; + gpio = <&pmic 2 GPIO_ACTIVE_HIGH>; + enable-active-high; + }; + + vdd_pnl_reg: regulator@4 { + compatible = "regulator-fixed"; + reg = <4>; + regulator-name = "vdd_pnl"; + regulator-min-microvolt = <2800000>; + regulator-max-microvolt = <2800000>; + gpio = <&gpio TEGRA_GPIO(C, 6) GPIO_ACTIVE_HIGH>; + enable-active-high; + }; + + vdd_bl_reg: regulator@5 { + compatible = "regulator-fixed"; + reg = <5>; + regulator-name = "vdd_bl"; + regulator-min-microvolt = <2800000>; + regulator-max-microvolt = <2800000>; + gpio = <&gpio TEGRA_GPIO(W, 0) GPIO_ACTIVE_HIGH>; + enable-active-high; + }; + + vdd_5v0_hdmi: regulator@6 { + compatible = "regulator-fixed"; + reg = <6>; + regulator-name = "VDDIO_HDMI"; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + gpio = <&gpio TEGRA_GPIO(T, 2) GPIO_ACTIVE_HIGH>; + enable-active-high; + vin-supply = <&vdd_5v0_reg>; + }; + }; + + sound { + compatible = "nvidia,tegra-audio-wm8903-harmony", + "nvidia,tegra-audio-wm8903"; + nvidia,model = "NVIDIA Tegra Harmony"; + + nvidia,audio-routing = + "Headphone Jack", "HPOUTR", + "Headphone Jack", "HPOUTL", + "Int Spk", "ROP", + "Int Spk", "RON", + "Int Spk", "LOP", + "Int Spk", "LON", + "Mic Jack", "MICBIAS", + "IN1L", "Mic Jack"; + + nvidia,i2s-controller = <&tegra_i2s1>; + nvidia,audio-codec = <&wm8903>; + + nvidia,spkr-en-gpios = <&wm8903 2 GPIO_ACTIVE_HIGH>; + nvidia,hp-det-gpios = <&gpio TEGRA_GPIO(W, 2) + GPIO_ACTIVE_HIGH>; + nvidia,int-mic-en-gpios = <&gpio TEGRA_GPIO(X, 0) + GPIO_ACTIVE_HIGH>; + nvidia,ext-mic-en-gpios = <&gpio TEGRA_GPIO(X, 1) + GPIO_ACTIVE_HIGH>; + + clocks = <&tegra_car TEGRA20_CLK_PLL_A>, + <&tegra_car TEGRA20_CLK_PLL_A_OUT0>, + <&tegra_car TEGRA20_CLK_CDEV1>; + clock-names = "pll_a", "pll_a_out0", "mclk"; }; }; diff --git a/arch/arm/dts/tegra20-seaboard.dts b/arch/arm/dts/tegra20-seaboard.dts index 19292f8..eca551f 100644 --- a/arch/arm/dts/tegra20-seaboard.dts +++ b/arch/arm/dts/tegra20-seaboard.dts @@ -42,6 +42,22 @@ status = "okay";
nvidia,panel = <&panel>; + + display-timings { + timing@0 { + /* Seaboard has 1366x768 */ + clock-frequency = <70600000>; + hactive = <1366>; + vactive = <768>; + hback-porch = <58>; + hfront-porch = <58>; + hsync-len = <58>; + vback-porch = <4>; + vfront-porch = <4>; + vsync-len = <4>; + hsync-active = <1>; + }; + }; }; };
@@ -856,28 +872,13 @@ };
panel: panel { - /* Seaboard has 1366x768 */ - clock = <70600000>; - xres = <1366>; - yres = <768>; - left-margin = <58>; - right-margin = <58>; - hsync-len = <58>; - lower-margin = <4>; - upper-margin = <4>; - vsync-len = <4>; - hsync-active-high; - nvidia,bits-per-pixel = <16>; - nvidia,pwm = <&pwm 2 0>; - nvidia,backlight-enable-gpios = <&gpio TEGRA_GPIO(D, 4) - GPIO_ACTIVE_HIGH>; - nvidia,lvds-shutdown-gpios = <&gpio TEGRA_GPIO(B, 2) - GPIO_ACTIVE_HIGH>; - nvidia,backlight-vdd-gpios = <&gpio TEGRA_GPIO(W, 0) - GPIO_ACTIVE_HIGH>; - nvidia,panel-vdd-gpios = <&gpio TEGRA_GPIO(C, 6) - GPIO_ACTIVE_HIGH>; - nvidia,panel-timings = <400 4 203 17 15>; + compatible = "chunghwa,claa101wa01a", "simple-panel"; + + power-supply = <&vdd_pnl_reg>; + enable-gpios = <&gpio TEGRA_GPIO(B, 2) GPIO_ACTIVE_HIGH>; + + backlight = <&backlight>; + ddc-i2c-bus = <&lvds_ddc>; };
regulators { diff --git a/arch/arm/dts/tegra20-ventana.dts b/arch/arm/dts/tegra20-ventana.dts index 851e0ed..143e964 100644 --- a/arch/arm/dts/tegra20-ventana.dts +++ b/arch/arm/dts/tegra20-ventana.dts @@ -1,5 +1,6 @@ /dts-v1/;
aliases { + rtc0 = "/i2c@7000d000/tps6586x@34"; + rtc1 = "/rtc@7000e000"; + serial0 = &uartd; usb0 = "/usb@c5008000"; sdhci0 = "/sdhci@c8000600"; sdhci1 = "/sdhci@c8000400"; @@ -26,19 +30,557 @@ status = "okay"; rgb { status = "okay"; - nvidia,panel = <&lcd_panel>; + + nvidia,panel = <&panel>; + + display-timings { + timing@0 { + /* Seaboard has 1366x768 */ + clock-frequency = <70600000>; + hactive = <1366>; + vactive = <768>; + hback-porch = <58>; + hfront-porch = <58>; + hsync-len = <58>; + vback-porch = <4>; + vfront-porch = <4>; + vsync-len = <4>; + hsync-active = <1>; + }; + }; }; }; + + hdmi@54280000 { + status = "okay"; + + vdd-supply = <&hdmi_vdd_reg>; + pll-supply = <&hdmi_pll_reg>; + + nvidia,ddc-i2c-bus = <&hdmi_ddc>; + nvidia,hpd-gpio = <&gpio TEGRA_GPIO(N, 7) + GPIO_ACTIVE_HIGH>; + }; + }; + + pinmux@70000014 { + pinctrl-names = "default"; + pinctrl-0 = <&state_default>; + + state_default: pinmux { + ata { + nvidia,pins = "ata"; + nvidia,function = "ide"; + }; + atb { + nvidia,pins = "atb", "gma", "gme"; + nvidia,function = "sdio4"; + }; + atc { + nvidia,pins = "atc"; + nvidia,function = "nand"; + }; + atd { + nvidia,pins = "atd", "ate", "gmb", "spia", + "spib", "spic"; + nvidia,function = "gmi"; + }; + cdev1 { + nvidia,pins = "cdev1"; + nvidia,function = "plla_out"; + }; + cdev2 { + nvidia,pins = "cdev2"; + nvidia,function = "pllp_out4"; + }; + crtp { + nvidia,pins = "crtp", "lm1"; + nvidia,function = "crt"; + }; + csus { + nvidia,pins = "csus"; + nvidia,function = "vi_sensor_clk"; + }; + dap1 { + nvidia,pins = "dap1"; + nvidia,function = "dap1"; + }; + dap2 { + nvidia,pins = "dap2"; + nvidia,function = "dap2"; + }; + dap3 { + nvidia,pins = "dap3"; + nvidia,function = "dap3"; + }; + dap4 { + nvidia,pins = "dap4"; + nvidia,function = "dap4"; + }; + dta { + nvidia,pins = "dta", "dtb", "dtc", "dtd", "dte"; + nvidia,function = "vi"; + }; + dtf { + nvidia,pins = "dtf"; + nvidia,function = "i2c3"; + }; + gmc { + nvidia,pins = "gmc"; + nvidia,function = "uartd"; + }; + gmd { + nvidia,pins = "gmd"; + nvidia,function = "sflash"; + }; + gpu { + nvidia,pins = "gpu"; + nvidia,function = "pwm"; + }; + gpu7 { + nvidia,pins = "gpu7"; + nvidia,function = "rtck"; + }; + gpv { + nvidia,pins = "gpv", "slxa", "slxk"; + nvidia,function = "pcie"; + }; + hdint { + nvidia,pins = "hdint"; + nvidia,function = "hdmi"; + }; + i2cp { + nvidia,pins = "i2cp"; + nvidia,function = "i2cp"; + }; + irrx { + nvidia,pins = "irrx", "irtx"; + nvidia,function = "uartb"; + }; + kbca { + nvidia,pins = "kbca", "kbcb", "kbcc", "kbcd", + "kbce", "kbcf"; + nvidia,function = "kbc"; + }; + lcsn { + nvidia,pins = "lcsn", "ldc", "lm0", "lpw1", + "lsdi", "lvp0"; + nvidia,function = "rsvd4"; + }; + ld0 { + nvidia,pins = "ld0", "ld1", "ld2", "ld3", "ld4", + "ld5", "ld6", "ld7", "ld8", "ld9", + "ld10", "ld11", "ld12", "ld13", "ld14", + "ld15", "ld16", "ld17", "ldi", "lhp0", + "lhp1", "lhp2", "lhs", "lpp", "lpw0", + "lpw2", "lsc0", "lsc1", "lsck", "lsda", + "lspi", "lvp1", "lvs"; + nvidia,function = "displaya"; + }; + owc { + nvidia,pins = "owc", "spdi", "spdo", "uac"; + nvidia,function = "rsvd2"; + }; + pmc { + nvidia,pins = "pmc"; + nvidia,function = "pwr_on"; + }; + rm { + nvidia,pins = "rm"; + nvidia,function = "i2c1"; + }; + sdb { + nvidia,pins = "sdb", "sdc", "sdd", "slxc"; + nvidia,function = "sdio3"; + }; + sdio1 { + nvidia,pins = "sdio1"; + nvidia,function = "sdio1"; + }; + slxd { + nvidia,pins = "slxd"; + nvidia,function = "spdif"; + }; + spid { + nvidia,pins = "spid", "spie", "spif"; + nvidia,function = "spi1"; + }; + spig { + nvidia,pins = "spig", "spih"; + nvidia,function = "spi2_alt"; + }; + uaa { + nvidia,pins = "uaa", "uab", "uda"; + nvidia,function = "ulpi"; + }; + uad { + nvidia,pins = "uad"; + nvidia,function = "irda"; + }; + uca { + nvidia,pins = "uca", "ucb"; + nvidia,function = "uartc"; + }; + conf_ata { + nvidia,pins = "ata", "atb", "atc", "atd", + "cdev1", "cdev2", "dap1", "dap2", + "dap4", "ddc", "dtf", "gma", "gmc", + "gme", "gpu", "gpu7", "i2cp", "irrx", + "irtx", "pta", "rm", "sdc", "sdd", + "slxc", "slxd", "slxk", "spdi", "spdo", + "uac", "uad", "uca", "ucb", "uda"; + nvidia,pull = <TEGRA_PIN_PULL_NONE>; + nvidia,tristate = <TEGRA_PIN_DISABLE>; + }; + conf_ate { + nvidia,pins = "ate", "csus", "dap3", "gmd", + "gpv", "owc", "spia", "spib", "spic", + "spid", "spie", "spig"; + nvidia,pull = <TEGRA_PIN_PULL_NONE>; + nvidia,tristate = <TEGRA_PIN_ENABLE>; + }; + conf_ck32 { + nvidia,pins = "ck32", "ddrc", "pmca", "pmcb", + "pmcc", "pmcd", "pmce", "xm2c", "xm2d"; + nvidia,pull = <TEGRA_PIN_PULL_NONE>; + }; + conf_crtp { + nvidia,pins = "crtp", "gmb", "slxa", "spih"; + nvidia,pull = <TEGRA_PIN_PULL_UP>; + nvidia,tristate = <TEGRA_PIN_ENABLE>; + }; + conf_dta { + nvidia,pins = "dta", "dtb", "dtc", "dtd"; + nvidia,pull = <TEGRA_PIN_PULL_DOWN>; + nvidia,tristate = <TEGRA_PIN_DISABLE>; + }; + conf_dte { + nvidia,pins = "dte", "spif"; + nvidia,pull = <TEGRA_PIN_PULL_DOWN>; + nvidia,tristate = <TEGRA_PIN_ENABLE>; + }; + conf_hdint { + nvidia,pins = "hdint", "lcsn", "ldc", "lm1", + "lpw1", "lsck", "lsda", "lsdi", "lvp0"; + nvidia,tristate = <TEGRA_PIN_ENABLE>; + }; + conf_kbca { + nvidia,pins = "kbca", "kbcb", "kbcc", "kbcd", + "kbce", "kbcf", "sdio1", "uaa", "uab"; + nvidia,pull = <TEGRA_PIN_PULL_UP>; + nvidia,tristate = <TEGRA_PIN_DISABLE>; + }; + conf_lc { + nvidia,pins = "lc", "ls"; + nvidia,pull = <TEGRA_PIN_PULL_UP>; + }; + conf_ld0 { + nvidia,pins = "ld0", "ld1", "ld2", "ld3", "ld4", + "ld5", "ld6", "ld7", "ld8", "ld9", + "ld10", "ld11", "ld12", "ld13", "ld14", + "ld15", "ld16", "ld17", "ldi", "lhp0", + "lhp1", "lhp2", "lhs", "lm0", "lpp", + "lpw0", "lpw2", "lsc0", "lsc1", "lspi", + "lvp1", "lvs", "pmc", "sdb"; + nvidia,tristate = <TEGRA_PIN_DISABLE>; + }; + conf_ld17_0 { + nvidia,pins = "ld17_0", "ld19_18", "ld21_20", + "ld23_22"; + nvidia,pull = <TEGRA_PIN_PULL_DOWN>; + }; + drive_sdio1 { + nvidia,pins = "drive_sdio1"; + nvidia,high-speed-mode = <TEGRA_PIN_DISABLE>; + nvidia,schmitt = <TEGRA_PIN_ENABLE>; + nvidia,low-power-mode = <TEGRA_PIN_LP_DRIVE_DIV_1>; + nvidia,pull-down-strength = <31>; + nvidia,pull-up-strength = <31>; + nvidia,slew-rate-rising = <TEGRA_PIN_SLEW_RATE_SLOWEST>; + nvidia,slew-rate-falling = <TEGRA_PIN_SLEW_RATE_SLOWEST>; + }; + }; + + state_i2cmux_ddc: pinmux_i2cmux_ddc { + ddc { + nvidia,pins = "ddc"; + nvidia,function = "i2c2"; + }; + pta { + nvidia,pins = "pta"; + nvidia,function = "rsvd4"; + }; + }; + + state_i2cmux_pta: pinmux_i2cmux_pta { + ddc { + nvidia,pins = "ddc"; + nvidia,function = "rsvd4"; + }; + pta { + nvidia,pins = "pta"; + nvidia,function = "i2c2"; + }; + }; + + state_i2cmux_idle: pinmux_i2cmux_idle { + ddc { + nvidia,pins = "ddc"; + nvidia,function = "rsvd4"; + }; + pta { + nvidia,pins = "pta"; + nvidia,function = "rsvd4"; + }; + }; + }; + + i2s@70002800 { + status = "okay"; };
serial@70006300 { - clock-frequency = < 216000000 >; + status = "okay"; + clock-frequency = < 216000000 >; }; + + pwm: pwm@7000a000 { + status = "okay"; + }; + + i2c@7000c000 { + status = "okay"; + clock-frequency = <400000>; + + wm8903: wm8903@1a { + compatible = "wlf,wm8903"; + reg = <0x1a>; + interrupt-parent = <&gpio>; + interrupts = <TEGRA_GPIO(X, 3) IRQ_TYPE_LEVEL_HIGH>; + + gpio-controller; + #gpio-cells = <2>; + + micdet-cfg = <0>; + micdet-delay = <100>; + gpio-cfg = <0xffffffff 0xffffffff 0 0xffffffff 0xffffffff>; + }; + + /* ALS and proximity sensor */ + isl29018@44 { + compatible = "isil,isl29018"; + reg = <0x44>; + interrupt-parent = <&gpio>; + interrupts = <TEGRA_GPIO(Z, 2) IRQ_TYPE_LEVEL_HIGH>; + }; + }; + + i2c@7000c400 { + status = "okay"; + clock-frequency = <100000>; + }; + + i2cmux { + compatible = "i2c-mux-pinctrl"; + #address-cells = <1>; + #size-cells = <0>; + + i2c-parent = <&{/i2c@7000c400}>; + + pinctrl-names = "ddc", "pta", "idle"; + pinctrl-0 = <&state_i2cmux_ddc>; + pinctrl-1 = <&state_i2cmux_pta>; + pinctrl-2 = <&state_i2cmux_idle>; + + hdmi_ddc: i2c@0 { + reg = <0>; + #address-cells = <1>; + #size-cells = <0>; + }; + + lvds_ddc: i2c@1 { + reg = <1>; + #address-cells = <1>; + #size-cells = <0>; + }; + }; + + i2c@7000c500 { + status = "okay"; + clock-frequency = <400000>; + }; + + i2c@7000d000 { + status = "okay"; + clock-frequency = <400000>; + + pmic: tps6586x@34 { + compatible = "ti,tps6586x"; + reg = <0x34>; + interrupts = <GIC_SPI 86 IRQ_TYPE_LEVEL_HIGH>; + + ti,system-power-controller; + + #gpio-cells = <2>; + gpio-controller; + + sys-supply = <&vdd_5v0_reg>; + vin-sm0-supply = <&sys_reg>; + vin-sm1-supply = <&sys_reg>; + vin-sm2-supply = <&sys_reg>; + vinldo01-supply = <&sm2_reg>; + vinldo23-supply = <&sm2_reg>; + vinldo4-supply = <&sm2_reg>; + vinldo678-supply = <&sm2_reg>; + vinldo9-supply = <&sm2_reg>; + + regulators { + sys_reg: sys { + regulator-name = "vdd_sys"; + regulator-always-on; + }; + + sm0 { + regulator-name = "vdd_sm0,vdd_core"; + regulator-min-microvolt = <1200000>; + regulator-max-microvolt = <1200000>; + regulator-always-on; + }; + + sm1 { + regulator-name = "vdd_sm1,vdd_cpu"; + regulator-min-microvolt = <1000000>; + regulator-max-microvolt = <1000000>; + regulator-always-on; + }; + + sm2_reg: sm2 { + regulator-name = "vdd_sm2,vin_ldo*"; + regulator-min-microvolt = <3700000>; + regulator-max-microvolt = <3700000>; + regulator-always-on; + }; + + /* LDO0 is not connected to anything */ + + ldo1 { + regulator-name = "vdd_ldo1,avdd_pll*"; + regulator-min-microvolt = <1100000>; + regulator-max-microvolt = <1100000>; + regulator-always-on; + }; + + ldo2 { + regulator-name = "vdd_ldo2,vdd_rtc"; + regulator-min-microvolt = <1200000>; + regulator-max-microvolt = <1200000>; + }; + + ldo3 { + regulator-name = "vdd_ldo3,avdd_usb*"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + regulator-always-on; + }; + + ldo4 { + regulator-name = "vdd_ldo4,avdd_osc,vddio_sys"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-always-on; + }; + + ldo5 { + regulator-name = "vdd_ldo5,vcore_mmc"; + regulator-min-microvolt = <2850000>; + regulator-max-microvolt = <2850000>; + regulator-always-on; + }; + + ldo6 { + regulator-name = "vdd_ldo6,avdd_vdac"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + }; + + hdmi_vdd_reg: ldo7 { + regulator-name = "vdd_ldo7,avdd_hdmi,vdd_fuse"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + }; + + hdmi_pll_reg: ldo8 { + regulator-name = "vdd_ldo8,avdd_hdmi_pll"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + }; + + ldo9 { + regulator-name = "vdd_ldo9,avdd_2v85,vdd_ddr_rx"; + regulator-min-microvolt = <2850000>; + regulator-max-microvolt = <2850000>; + regulator-always-on; + }; + + ldo_rtc { + regulator-name = "vdd_rtc_out,vdd_cell"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + regulator-always-on; + }; + }; + }; + + temperature-sensor@4c { + compatible = "onnn,nct1008"; + reg = <0x4c>; + }; + }; + + pmc@7000e400 { + nvidia,invert-interrupt; + nvidia,suspend-mode = <1>; + nvidia,cpu-pwr-good-time = <2000>; + nvidia,cpu-pwr-off-time = <100>; + nvidia,core-pwr-good-time = <3845 3845>; + nvidia,core-pwr-off-time = <458>; + nvidia,sys-clock-req-active-high; + }; + + usb@c5000000 { + status = "okay"; + }; + + usb-phy@c5000000 { + status = "okay"; + }; + + usb@c5004000 { + status = "okay"; + nvidia,phy-reset-gpio = <&gpio TEGRA_GPIO(V, 1) + GPIO_ACTIVE_LOW>; + }; + + usb-phy@c5004000 { + status = "okay"; + nvidia,phy-reset-gpio = <&gpio TEGRA_GPIO(V, 1) + GPIO_ACTIVE_LOW>; };
+ usb-phy@c5008000 { + status = "okay"; + }; + + sdhci@c8000000 { + status = "okay"; + power-gpios = <&gpio TEGRA_GPIO(K, 6) GPIO_ACTIVE_HIGH>; + bus-width = <4>; + keep-power-in-suspend; + }; + sdhci@c8000400 { status = "okay"; cd-gpios = <&gpio TEGRA_GPIO(I, 5) GPIO_ACTIVE_LOW>; @@ -50,6 +592,18 @@ sdhci@c8000600 { status = "okay"; bus-width = <8>; + non-removable; + }; + + backlight: backlight { + compatible = "pwm-backlight"; + + enable-gpios = <&gpio TEGRA_GPIO(D, 4) GPIO_ACTIVE_HIGH>; + power-supply = <&vdd_bl_reg>; + pwms = <&pwm 2 5000000>; + + brightness-levels = <0 4 8 16 32 64 128 255>; + default-brightness-level = <6>; };
clocks { @@ -65,32 +619,109 @@ }; };
- pwm: pwm@7000a000 { - status = "okay"; + gpio-keys { + compatible = "gpio-keys"; + + power { + label = "Power"; + gpios = <&gpio TEGRA_GPIO(V, 2) GPIO_ACTIVE_LOW>; + linux,code = <KEY_POWER>; + gpio-key,wakeup; + }; };
- lcd_panel: panel { - clock = <72072000>; - xres = <1366>; - yres = <768>; - left-margin = <58>; - right-margin = <58>; - hsync-len = <58>; - lower-margin = <4>; - upper-margin = <4>; - vsync-len = <4>; - hsync-active-high; - vsync-active-high; - nvidia,bits-per-pixel = <16>; - nvidia,pwm = <&pwm 2 0>; - nvidia,backlight-enable-gpios = <&gpio TEGRA_GPIO(D, 4) - GPIO_ACTIVE_HIGH>; - nvidia,lvds-shutdown-gpios = <&gpio TEGRA_GPIO(B, 2) - GPIO_ACTIVE_HIGH>; - nvidia,backlight-vdd-gpios = <&gpio TEGRA_GPIO(W, 0) - GPIO_ACTIVE_HIGH>; - nvidia,panel-vdd-gpios = <&gpio TEGRA_GPIO(C, 6) - GPIO_ACTIVE_HIGH>; - nvidia,panel-timings = <0 0 200 0 0>; + panel: panel { + compatible = "chunghwa,claa101wa01a", "simple-panel"; + + power-supply = <&vdd_pnl_reg>; + enable-gpios = <&gpio TEGRA_GPIO(B, 2) GPIO_ACTIVE_HIGH>; + + backlight = <&backlight>; + ddc-i2c-bus = <&lvds_ddc>; + }; + + regulators { + compatible = "simple-bus"; + #address-cells = <1>; + #size-cells = <0>; + + vdd_5v0_reg: regulator@0 { + compatible = "regulator-fixed"; + reg = <0>; + regulator-name = "vdd_5v0"; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + regulator-always-on; + }; + + regulator@1 { + compatible = "regulator-fixed"; + reg = <1>; + regulator-name = "vdd_1v5"; + regulator-min-microvolt = <1500000>; + regulator-max-microvolt = <1500000>; + gpio = <&pmic 0 GPIO_ACTIVE_HIGH>; + }; + + regulator@2 { + compatible = "regulator-fixed"; + reg = <2>; + regulator-name = "vdd_1v2"; + regulator-min-microvolt = <1200000>; + regulator-max-microvolt = <1200000>; + gpio = <&pmic 1 GPIO_ACTIVE_HIGH>; + enable-active-high; + }; + + vdd_pnl_reg: regulator@3 { + compatible = "regulator-fixed"; + reg = <3>; + regulator-name = "vdd_pnl"; + regulator-min-microvolt = <2800000>; + regulator-max-microvolt = <2800000>; + gpio = <&gpio TEGRA_GPIO(C, 6) GPIO_ACTIVE_HIGH>; + enable-active-high; + }; + + vdd_bl_reg: regulator@4 { + compatible = "regulator-fixed"; + reg = <4>; + regulator-name = "vdd_bl"; + regulator-min-microvolt = <2800000>; + regulator-max-microvolt = <2800000>; + gpio = <&gpio TEGRA_GPIO(W, 0) GPIO_ACTIVE_HIGH>; + enable-active-high; + }; + }; + + sound { + compatible = "nvidia,tegra-audio-wm8903-ventana", + "nvidia,tegra-audio-wm8903"; + nvidia,model = "NVIDIA Tegra Ventana"; + + nvidia,audio-routing = + "Headphone Jack", "HPOUTR", + "Headphone Jack", "HPOUTL", + "Int Spk", "ROP", + "Int Spk", "RON", + "Int Spk", "LOP", + "Int Spk", "LON", + "Mic Jack", "MICBIAS", + "IN1L", "Mic Jack"; + + nvidia,i2s-controller = <&tegra_i2s1>; + nvidia,audio-codec = <&wm8903>; + + nvidia,spkr-en-gpios = <&wm8903 2 GPIO_ACTIVE_HIGH>; + nvidia,hp-det-gpios = <&gpio TEGRA_GPIO(W, 2) GPIO_ACTIVE_HIGH>; + nvidia,int-mic-en-gpios = <&gpio TEGRA_GPIO(X, 0) + GPIO_ACTIVE_HIGH>; + nvidia,ext-mic-en-gpios = <&gpio TEGRA_GPIO(X, 1) + GPIO_ACTIVE_HIGH>; + + clocks = <&tegra_car TEGRA20_CLK_PLL_A>, + <&tegra_car TEGRA20_CLK_PLL_A_OUT0>, + <&tegra_car TEGRA20_CLK_CDEV1>; + clock-names = "pll_a", "pll_a_out0", "mclk"; }; }; diff --git a/configs/colibri_t20_defconfig b/configs/colibri_t20_defconfig index 49687cf..3573c15 100644 --- a/configs/colibri_t20_defconfig +++ b/configs/colibri_t20_defconfig @@ -12,9 +12,11 @@ CONFIG_SYS_PROMPT="Tegra20 (Medcom-Wide) # " CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set # CONFIG_CMD_NFS is not set +CONFIG_CMD_PMIC=y +CONFIG_CMD_REGULATOR=y CONFIG_DM_PMIC=y CONFIG_DM_REGULATOR=y -CONFIG_DM_PWM=y +CONFIG_DM_REGULATOR_FIXED=y CONFIG_PWM_TEGRA=y CONFIG_SYS_NS16550=y CONFIG_USB=y @@ -22,3 +24,4 @@ CONFIG_DM_USB=y CONFIG_DM_VIDEO=y CONFIG_VIDEO_TEGRA20=y CONFIG_USE_PRIVATE_LIBGCC=y +CONFIG_ERRNO_STR=y diff --git a/configs/harmony_defconfig b/configs/harmony_defconfig index 14125b4..0de56a9 100644 --- a/configs/harmony_defconfig +++ b/configs/harmony_defconfig @@ -12,9 +12,11 @@ CONFIG_SYS_PROMPT="Tegra20 (Harmony) # " CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set # CONFIG_CMD_NFS is not set +CONFIG_CMD_PMIC=y +CONFIG_CMD_REGULATOR=y CONFIG_DM_PMIC=y CONFIG_DM_REGULATOR=y -CONFIG_DM_PWM=y +CONFIG_DM_REGULATOR_FIXED=y CONFIG_PWM_TEGRA=y CONFIG_SYS_NS16550=y CONFIG_USB=y @@ -22,3 +24,4 @@ CONFIG_DM_USB=y CONFIG_DM_VIDEO=y CONFIG_VIDEO_TEGRA20=y CONFIG_USE_PRIVATE_LIBGCC=y +CONFIG_ERRNO_STR=y diff --git a/configs/medcom-wide_defconfig b/configs/medcom-wide_defconfig index 49687cf..3573c15 100644 --- a/configs/medcom-wide_defconfig +++ b/configs/medcom-wide_defconfig @@ -12,9 +12,11 @@ CONFIG_SYS_PROMPT="Tegra20 (Medcom-Wide) # " CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set # CONFIG_CMD_NFS is not set +CONFIG_CMD_PMIC=y +CONFIG_CMD_REGULATOR=y CONFIG_DM_PMIC=y CONFIG_DM_REGULATOR=y -CONFIG_DM_PWM=y +CONFIG_DM_REGULATOR_FIXED=y CONFIG_PWM_TEGRA=y CONFIG_SYS_NS16550=y CONFIG_USB=y @@ -22,3 +24,4 @@ CONFIG_DM_USB=y CONFIG_DM_VIDEO=y CONFIG_VIDEO_TEGRA20=y CONFIG_USE_PRIVATE_LIBGCC=y +CONFIG_ERRNO_STR=y diff --git a/configs/paz00_defconfig b/configs/paz00_defconfig index 5469331..7ed63f2 100644 --- a/configs/paz00_defconfig +++ b/configs/paz00_defconfig @@ -12,9 +12,11 @@ CONFIG_SYS_PROMPT="Tegra20 (Paz00) MOD # " CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set # CONFIG_CMD_NFS is not set +CONFIG_CMD_PMIC=y +CONFIG_CMD_REGULATOR=y CONFIG_DM_PMIC=y CONFIG_DM_REGULATOR=y -CONFIG_DM_PWM=y +CONFIG_DM_REGULATOR_FIXED=y CONFIG_PWM_TEGRA=y CONFIG_SYS_NS16550=y CONFIG_USB=y @@ -22,3 +24,4 @@ CONFIG_DM_USB=y CONFIG_DM_VIDEO=y CONFIG_VIDEO_TEGRA20=y CONFIG_USE_PRIVATE_LIBGCC=y +CONFIG_ERRNO_STR=y diff --git a/configs/seaboard_defconfig b/configs/seaboard_defconfig index 7956670..0ec3ad9 100644 --- a/configs/seaboard_defconfig +++ b/configs/seaboard_defconfig @@ -12,9 +12,11 @@ CONFIG_SYS_PROMPT="Tegra20 (SeaBoard) # " CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set # CONFIG_CMD_NFS is not set +CONFIG_CMD_PMIC=y +CONFIG_CMD_REGULATOR=y CONFIG_DM_PMIC=y CONFIG_DM_REGULATOR=y -CONFIG_DM_PWM=y +CONFIG_DM_REGULATOR_FIXED=y CONFIG_PWM_TEGRA=y CONFIG_SYS_NS16550=y CONFIG_USB=y @@ -22,3 +24,4 @@ CONFIG_DM_USB=y CONFIG_DM_VIDEO=y CONFIG_VIDEO_TEGRA20=y CONFIG_USE_PRIVATE_LIBGCC=y +CONFIG_ERRNO_STR=y diff --git a/configs/tec_defconfig b/configs/tec_defconfig index 274fc9d..d38941b 100644 --- a/configs/tec_defconfig +++ b/configs/tec_defconfig @@ -12,9 +12,11 @@ CONFIG_SYS_PROMPT="Tegra20 (TEC) # " CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set # CONFIG_CMD_NFS is not set +CONFIG_CMD_PMIC=y +CONFIG_CMD_REGULATOR=y CONFIG_DM_PMIC=y CONFIG_DM_REGULATOR=y -CONFIG_DM_PWM=y +CONFIG_DM_REGULATOR_FIXED=y CONFIG_PWM_TEGRA=y CONFIG_SYS_NS16550=y CONFIG_USB=y @@ -22,3 +24,4 @@ CONFIG_DM_USB=y CONFIG_DM_VIDEO=y CONFIG_VIDEO_TEGRA20=y CONFIG_USE_PRIVATE_LIBGCC=y +CONFIG_ERRNO_STR=y diff --git a/configs/ventana_defconfig b/configs/ventana_defconfig index 66c9e26..38fb202 100644 --- a/configs/ventana_defconfig +++ b/configs/ventana_defconfig @@ -12,9 +12,11 @@ CONFIG_SYS_PROMPT="Tegra20 (Ventana) # " CONFIG_CMD_GPIO=y # CONFIG_CMD_SETEXPR is not set # CONFIG_CMD_NFS is not set +CONFIG_CMD_PMIC=y +CONFIG_CMD_REGULATOR=y CONFIG_DM_PMIC=y CONFIG_DM_REGULATOR=y -CONFIG_DM_PWM=y +CONFIG_DM_REGULATOR_FIXED=y CONFIG_PWM_TEGRA=y CONFIG_SYS_NS16550=y CONFIG_USB=y @@ -22,3 +24,4 @@ CONFIG_DM_USB=y CONFIG_DM_VIDEO=y CONFIG_VIDEO_TEGRA20=y CONFIG_USE_PRIVATE_LIBGCC=y +CONFIG_ERRNO_STR=y diff --git a/drivers/video/tegra.c b/drivers/video/tegra.c index 1626772..d34189d 100644 --- a/drivers/video/tegra.c +++ b/drivers/video/tegra.c @@ -6,6 +6,7 @@ #include <common.h> #include <dm.h> #include <fdtdec.h> +#include <panel.h> #include <pwm.h> #include <video.h> #include <asm/system.h> @@ -21,28 +22,6 @@
DECLARE_GLOBAL_DATA_PTR;
-/* These are the stages we go throuh in enabling the LCD */ -enum stage_t { - STAGE_START, - STAGE_PANEL_VDD, - STAGE_LVDS, - STAGE_BACKLIGHT_VDD, - STAGE_PWM, - STAGE_BACKLIGHT_EN, - STAGE_DONE, -}; - -#define FDT_LCD_TIMINGS 4 - -enum { - FDT_LCD_TIMING_REF_TO_SYNC, - FDT_LCD_TIMING_SYNC_WIDTH, - FDT_LCD_TIMING_BACK_PORCH, - FDT_LCD_TIMING_FRONT_PORCH, - - FDT_LCD_TIMING_COUNT, -}; - enum lcd_cache_t { FDT_LCD_CACHE_OFF = 0, FDT_LCD_CACHE_WRITE_THROUGH = 1 << 0, @@ -54,37 +33,15 @@ enum lcd_cache_t {
/* Information about the display controller */ struct tegra_lcd_priv { - enum stage_t stage; /* Current stage we are at */ - unsigned long timer_next; /* Time we can move onto next stage */ int width; /* width in pixels */ int height; /* height in pixels */ - - /* - * log2 of number of bpp, in general, unless it bpp is 24 in which - * case this field holds 24 also! This is a U-Boot thing. - */ - int log2_bpp; + enum video_log2_bpp log2_bpp; /* colour depth */ + struct display_timing timing; + struct udevice *panel; struct disp_ctlr *disp; /* Display controller to use */ fdt_addr_t frame_buffer; /* Address of frame buffer */ unsigned pixel_clock; /* Pixel clock in Hz */ - uint horiz_timing[FDT_LCD_TIMING_COUNT]; /* Horizontal timing */ - uint vert_timing[FDT_LCD_TIMING_COUNT]; /* Vertical timing */ - struct udevice *pwm; - int pwm_channel; /* PWM channel to use for backlight */ enum lcd_cache_t cache_type; - - struct gpio_desc backlight_en; /* GPIO for backlight enable */ - struct gpio_desc lvds_shutdown; /* GPIO for lvds shutdown */ - struct gpio_desc backlight_vdd; /* GPIO for backlight vdd */ - struct gpio_desc panel_vdd; /* GPIO for panel vdd */ - /* - * Panel required timings - * Timing 1: delay between panel_vdd-rise and data-rise - * Timing 2: delay between data-rise and backlight_vdd-rise - * Timing 3: delay between backlight_vdd and pwm-rise - * Timing 4: delay between pwm-rise and backlight_en-rise - */ - uint panel_timings[FDT_LCD_TIMINGS]; };
enum { @@ -150,26 +107,23 @@ static void update_window(struct dc_ctlr *dc, struct disp_ctl_win *win) writel(val, &dc->cmd.state_ctrl); }
-static void write_pair(struct tegra_lcd_priv *priv, int item, u32 *reg) -{ - writel(priv->horiz_timing[item] | - (priv->vert_timing[item] << 16), reg); -} - static int update_display_mode(struct dc_disp_reg *disp, struct tegra_lcd_priv *priv) { + struct display_timing *dt = &priv->timing; unsigned long val; unsigned long rate; unsigned long div;
writel(0x0, &disp->disp_timing_opt); - write_pair(priv, FDT_LCD_TIMING_REF_TO_SYNC, &disp->ref_to_sync); - write_pair(priv, FDT_LCD_TIMING_SYNC_WIDTH, &disp->sync_width); - write_pair(priv, FDT_LCD_TIMING_BACK_PORCH, &disp->back_porch); - write_pair(priv, FDT_LCD_TIMING_FRONT_PORCH, &disp->front_porch);
- writel(priv->width | (priv->height << 16), &disp->disp_active); + writel(1 | 1 << 16, &disp->ref_to_sync); + writel(dt->hsync_len.typ | dt->vsync_len.typ << 16, &disp->sync_width); + writel(dt->hback_porch.typ | dt->vback_porch.typ << 16, + &disp->back_porch); + writel((dt->hfront_porch.typ - 1) | (dt->vfront_porch.typ - 1) << 16, + &disp->front_porch); + writel(dt->hactive.typ | (dt->vactive.typ << 16), &disp->disp_active);
val = DE_SELECT_ACTIVE << DE_SELECT_SHIFT; val |= DE_CONTROL_NORMAL << DE_CONTROL_SHIFT; @@ -287,12 +241,11 @@ static int setup_window(struct disp_ctl_win *win, win->stride = priv->width * (1 << priv->log2_bpp) / 8; debug("%s: depth = %d\n", __func__, priv->log2_bpp); switch (priv->log2_bpp) { - case 5: - case 24: + case VIDEO_BPP32: win->fmt = COLOR_DEPTH_R8G8B8A8; win->bpp = 32; break; - case 4: + case VIDEO_BPP16: win->fmt = COLOR_DEPTH_B5G6R5; win->bpp = 16; break; @@ -305,18 +258,6 @@ static int setup_window(struct disp_ctl_win *win, return 0; }
-static void debug_timing(const char *name, unsigned int timing[]) -{ -#ifdef DEBUG - int i; - - debug("%s timing: ", name); - for (i = 0; i < FDT_LCD_TIMING_COUNT; i++) - debug("%d ", timing[i]); - debug("\n"); -#endif -} - /** * Register a new display based on device tree configuration. * @@ -363,112 +304,6 @@ static int tegra_display_probe(const void *blob, struct tegra_lcd_priv *priv, return 0; }
-/** - * Handle the next stage of device init - */ -static int handle_stage(const void *blob, struct tegra_lcd_priv *priv) -{ - debug("%s: stage %d\n", __func__, priv->stage); - - /* do the things for this stage */ - switch (priv->stage) { - case STAGE_START: - /* - * It is possible that the FDT has requested that the LCD be - * disabled. We currently don't support this. It would require - * changes to U-Boot LCD subsystem to have LCD support - * compiled in but not used. An easier option might be to - * still have a frame buffer, but leave the backlight off and - * remove all mention of lcd in the stdout environment - * variable. - */ - - funcmux_select(PERIPH_ID_DISP1, FUNCMUX_DEFAULT); - break; - case STAGE_PANEL_VDD: - if (dm_gpio_is_valid(&priv->panel_vdd)) - dm_gpio_set_value(&priv->panel_vdd, 1); - break; - case STAGE_LVDS: - if (dm_gpio_is_valid(&priv->lvds_shutdown)) - dm_gpio_set_value(&priv->lvds_shutdown, 1); - break; - case STAGE_BACKLIGHT_VDD: - if (dm_gpio_is_valid(&priv->backlight_vdd)) - dm_gpio_set_value(&priv->backlight_vdd, 1); - break; - case STAGE_PWM: - /* Enable PWM at 15/16 high, 32768 Hz with divider 1 */ - pinmux_set_func(PMUX_PINGRP_GPU, PMUX_FUNC_PWM); - pinmux_tristate_disable(PMUX_PINGRP_GPU); - - pwm_set_config(priv->pwm, priv->pwm_channel, 0xdf, 0xff); - pwm_set_enable(priv->pwm, priv->pwm_channel, true); - break; - case STAGE_BACKLIGHT_EN: - if (dm_gpio_is_valid(&priv->backlight_en)) - dm_gpio_set_value(&priv->backlight_en, 1); - break; - case STAGE_DONE: - break; - } - - /* set up timer for next stage */ - priv->timer_next = timer_get_us(); - if (priv->stage < FDT_LCD_TIMINGS) - priv->timer_next += priv->panel_timings[priv->stage] * 1000; - - /* move to next stage */ - priv->stage++; - return 0; -} - -/** - * Perform the next stage of the LCD init if it is time to do so. - * - * LCD init can be time-consuming because of the number of delays we need - * while waiting for the backlight power supply, etc. This function can - * be called at various times during U-Boot operation to advance the - * initialization of the LCD to the next stage if sufficient time has - * passed since the last stage. It keeps track of what stage it is up to - * and the time that it is permitted to move to the next stage. - * - * The final call should have wait=1 to complete the init. - * - * @param blob fdt blob containing LCD information - * @param wait 1 to wait until all init is complete, and then return - * 0 to return immediately, potentially doing nothing if it is - * not yet time for the next init. - */ -static int tegra_lcd_check_next_stage(const void *blob, - struct tegra_lcd_priv *priv, int wait) -{ - if (priv->stage == STAGE_DONE) - return 0; - - do { - /* wait if we need to */ - debug("%s: stage %d\n", __func__, priv->stage); - if (priv->stage != STAGE_START) { - int delay = priv->timer_next - timer_get_us(); - - if (delay > 0) { - if (wait) - udelay(delay); - else - return 0; - } - } - - if (handle_stage(blob, priv)) - return -1; - } while (wait && priv->stage != STAGE_DONE); - if (priv->stage == STAGE_DONE) - debug("%s: LCD init complete\n", __func__); - - return 0; -} - static int tegra_lcd_probe(struct udevice *dev) { struct video_uc_platdata *plat = dev_get_uclass_platdata(dev); @@ -476,15 +311,24 @@ static int tegra_lcd_probe(struct udevice *dev) struct tegra_lcd_priv *priv = dev_get_priv(dev); const void *blob = gd->fdt_blob; int type = DCACHE_OFF; + int ret;
/* Initialize the Tegra display controller */ + funcmux_select(PERIPH_ID_DISP1, FUNCMUX_DEFAULT); if (tegra_display_probe(blob, priv, (void *)plat->base)) { printf("%s: Failed to probe display driver\n", __func__); return -1; }
- tegra_lcd_check_next_stage(blob, priv, 1); + pinmux_set_func(PMUX_PINGRP_GPU, PMUX_FUNC_PWM); + pinmux_tristate_disable(PMUX_PINGRP_GPU); + + ret = panel_enable_backlight(priv->panel); + if (ret) { + debug("%s: Cannot enable backlight, ret=%d\n", __func__, ret); + return ret; + }
/* Set up the LCD caching as requested */ if (priv->cache_type & FDT_LCD_CACHE_WRITE_THROUGH) @@ -508,13 +352,11 @@ static int tegra_lcd_probe(struct udevice *dev) static int tegra_lcd_ofdata_to_platdata(struct udevice *dev) { struct tegra_lcd_priv *priv = dev_get_priv(dev); - struct fdtdec_phandle_args args; const void *blob = gd->fdt_blob; + struct display_timing *timing; int node = dev->of_offset; - int front, back, ref; int panel_node; int rgb; - int bpp, bit; int ret;
priv->disp = (struct disp_ctlr *)dev_get_addr(dev); @@ -524,96 +366,40 @@ static int tegra_lcd_ofdata_to_platdata(struct udevice *dev) }
rgb = fdt_subnode_offset(blob, node, "rgb"); - - panel_node = fdtdec_lookup_phandle(blob, rgb, "nvidia,panel"); - if (panel_node < 0) { - debug("%s: Cannot find panel information\n", __func__); + if (rgb < 0) { + debug("%s: Cannot find rgb subnode for '%s' (ret=%d)\n", + __func__, dev->name, rgb); return -EINVAL; }
- priv->width = fdtdec_get_int(blob, panel_node, "xres", -1); - priv->height = fdtdec_get_int(blob, panel_node, "yres", -1); - priv->pixel_clock = fdtdec_get_int(blob, panel_node, "clock", 0); - if (!priv->pixel_clock || priv->width == -1 || priv->height == -1) { - debug("%s: Pixel parameters missing\n", __func__); - return -EINVAL; - } - - back = fdtdec_get_int(blob, panel_node, "left-margin", -1); - front = fdtdec_get_int(blob, panel_node, "right-margin", -1); - ref = fdtdec_get_int(blob, panel_node, "hsync-len", -1); - if ((back | front | ref) == -1) { - debug("%s: Horizontal parameters missing\n", __func__); - return -EINVAL; - } - - /* Use a ref-to-sync of 1 always, and take this from the front porch */ - priv->horiz_timing[FDT_LCD_TIMING_REF_TO_SYNC] = 1; - priv->horiz_timing[FDT_LCD_TIMING_SYNC_WIDTH] = ref; - priv->horiz_timing[FDT_LCD_TIMING_BACK_PORCH] = back; - priv->horiz_timing[FDT_LCD_TIMING_FRONT_PORCH] = front - - priv->horiz_timing[FDT_LCD_TIMING_REF_TO_SYNC]; - debug_timing("horiz", priv->horiz_timing); - - back = fdtdec_get_int(blob, panel_node, "upper-margin", -1); - front = fdtdec_get_int(blob, panel_node, "lower-margin", -1); - ref = fdtdec_get_int(blob, panel_node, "vsync-len", -1); - if ((back | front | ref) == -1) { - debug("%s: Vertical parameters missing\n", __func__); - return -EINVAL; - } - - priv->vert_timing[FDT_LCD_TIMING_REF_TO_SYNC] = 1; - priv->vert_timing[FDT_LCD_TIMING_SYNC_WIDTH] = ref; - priv->vert_timing[FDT_LCD_TIMING_BACK_PORCH] = back; - priv->vert_timing[FDT_LCD_TIMING_FRONT_PORCH] = front - - priv->vert_timing[FDT_LCD_TIMING_REF_TO_SYNC]; - debug_timing("vert", priv->vert_timing); - - bpp = fdtdec_get_int(blob, panel_node, "nvidia,bits-per-pixel", -1); - bit = ffs(bpp) - 1; - if (bpp == (1 << bit)) - priv->log2_bpp = bit; - else - priv->log2_bpp = bpp; - if (bpp == -1) { - debug("%s: Pixel bpp parameters missing\n", __func__); + ret = fdtdec_decode_display_timing(blob, rgb, 0, &priv->timing); + if (ret) { + debug("%s: Cannot read display timing for '%s' (ret=%d)\n", + __func__, dev->name, ret); return -EINVAL; } + timing = &priv->timing; + priv->width = timing->hactive.typ; + priv->height = timing->vactive.typ; + priv->pixel_clock = timing->pixelclock.typ; + priv->log2_bpp = VIDEO_BPP16;
- if (fdtdec_parse_phandle_with_args(blob, panel_node, "nvidia,pwm", - "#pwm-cells", 0, 0, &args)) { - debug("%s: Unable to decode PWM\n", __func__); + /* + * Sadly the panel phandle is in an rgb subnode so we cannot use + * uclass_get_device_by_phandle(). + */ + panel_node = fdtdec_lookup_phandle(blob, rgb, "nvidia,panel"); + if (panel_node < 0) { + debug("%s: Cannot find panel information\n", __func__); return -EINVAL; } - - ret = uclass_get_device_by_of_offset(UCLASS_PWM, args.node, &priv->pwm); + ret = uclass_get_device_by_of_offset(UCLASS_PANEL, panel_node, + &priv->panel); if (ret) { - debug("%s: Unable to find PWM\n", __func__); - return -EINVAL; + debug("%s: Cannot find panel for '%s' (ret=%d)\n", __func__, + dev->name, ret); + return ret; } - priv->pwm_channel = args.args[0]; - - priv->cache_type = fdtdec_get_int(blob, panel_node, "nvidia,cache-type", - FDT_LCD_CACHE_WRITE_BACK_FLUSH); - - /* These GPIOs are all optional */ - gpio_request_by_name_nodev(blob, panel_node, - "nvidia,backlight-enable-gpios", 0, - &priv->backlight_en, GPIOD_IS_OUT); - gpio_request_by_name_nodev(blob, panel_node, - "nvidia,lvds-shutdown-gpios", 0, - &priv->lvds_shutdown, GPIOD_IS_OUT); - gpio_request_by_name_nodev(blob, panel_node, - "nvidia,backlight-vdd-gpios", 0, - &priv->backlight_vdd, GPIOD_IS_OUT); - gpio_request_by_name_nodev(blob, panel_node, - "nvidia,panel-vdd-gpios", 0, - &priv->panel_vdd, GPIOD_IS_OUT); - - if (fdtdec_get_int_array(blob, panel_node, "nvidia,panel-timings", - priv->panel_timings, FDT_LCD_TIMINGS)) - return -EINVAL;
return 0; }
This file has huge changes unrelated to panel, video, and backlight. Perhaps patch 1/4 was meant to sync the DTs for Harmony and Ventana too rather than just Seaboard, leaving this commit to make roughly identical DT changes for all 3 boards?
display-timings {
timing@0 {
hactive = <1366>;
vactive = <768>;
hback-porch = <58>;
hsync-len = <58>;
vback-porch = <4>;
vfront-porch = <4>;
vsync-len = <4>;
hsync-active = <1>;
It seems very strange to go to the effort of creating patch 1 to sync the U-Boot and Linux DT files (such that I assume they're 100% identical?) yet immediately have patch 2 diverge the two DTs again.
This lends more weight to my argument that the U-Boot DTs should contain only nodes that U-Boot actively uses. I can see the argument for copying over the entire DT from Linux into U-Boot in order to keep them 100% identical, and in turn that means importing a bunch of DT content that U-Boot doesn't use. However, that argument completely breaks down if the DTs are just going to diverge still.
At least the display-timings node is a standard binding, even if it isn't one that the Linux Tegra DTs make use of.
I assume those are all needed by the modified Tegra video/LCD driver. If so, wouldn't it make sense for that driver to select those Kconfig options rather than requiring every board defconfig to be modified to enable the features?
Hi Stephen,
Yes I think that would be better. I started on seaboard since that's the only one I have. But then I thought I could do the other two since you or Tom should be able to test it.
display-timings {
timing@0 {
clock-frequency =
<70600000>;
hactive = <1366>;
vactive = <768>;
hback-porch = <58>;
hsync-len = <58>;
vback-porch = <4>;
vfront-porch = <4>;
vsync-len = <4>;
hsync-active = <1>;
How about adding this to the Linux Tegra DT? It's a hardware description so shouldn't ruffle too many feathres.
Do you mean 'depends on' in the Kconfig? This is a discussion that goes back and forth...I don't really mind. It would mean that you would have to play detective in menuconfig to turn the display on for a board: find all the options it depends on, turn them on one by one and then the display option appears.
On 01/18/2016 07:08 PM, Simon Glass wrote:
Hi Stephen,
display-timings {
timing@0 {
clock-frequency =
<70600000>;
hactive = <1366>;
vactive = <768>;
hback-porch = <58>;
hsync-len = <58>;
vback-porch = <4>;
vfront-porch = <4>;
vsync-len = <4>;
hsync-active = <1>;
I was thinking of "select" in Kconfig, so that if someone enables Tegra LCD/display support then regulators etc. get automatically enabled too.
But "depends" would work too.
Hi Stephen,
Hi Stephen,
display-timings {
timing@0 {
clock-frequency =
<70600000>;
hactive = <1366>;
vactive = <768>;
hback-porch = <58>;
hsync-len = <58>;
vback-porch = <4>;
vfront-porch = <4>;
vsync-len = <4>;
hsync-active = <1>;
'select' sounds better. I'll take a look.
This seems to give the best performance, so let's use it always.
drivers/video/tegra.c | 21 +++------------------ 1 file changed, 3 insertions(+), 18 deletions(-)
diff --git a/drivers/video/tegra.c b/drivers/video/tegra.c index d34189d..cb2a157 100644 --- a/drivers/video/tegra.c +++ b/drivers/video/tegra.c @@ -22,15 +22,6 @@
-enum lcd_cache_t { - FDT_LCD_CACHE_OFF = 0, - FDT_LCD_CACHE_WRITE_THROUGH = 1 << 0, - FDT_LCD_CACHE_WRITE_BACK = 1 << 1, - FDT_LCD_CACHE_FLUSH = 1 << 2, - FDT_LCD_CACHE_WRITE_BACK_FLUSH = FDT_LCD_CACHE_WRITE_BACK | - FDT_LCD_CACHE_FLUSH, -}; - /* Information about the display controller */ struct tegra_lcd_priv { int width; /* width in pixels */ @@ -41,7 +32,6 @@ struct tegra_lcd_priv { struct disp_ctlr *disp; /* Display controller to use */ fdt_addr_t frame_buffer; /* Address of frame buffer */ unsigned pixel_clock; /* Pixel clock in Hz */ - enum lcd_cache_t cache_type; };
enum { @@ -310,7 +300,6 @@ static int tegra_lcd_probe(struct udevice *dev) struct video_priv *uc_priv = dev_get_uclass_priv(dev); struct tegra_lcd_priv *priv = dev_get_priv(dev); const void *blob = gd->fdt_blob; - int type = DCACHE_OFF; int ret;
/* Initialize the Tegra display controller */ @@ -330,15 +319,11 @@ static int tegra_lcd_probe(struct udevice *dev) return ret; }
- /* Set up the LCD caching as requested */ - if (priv->cache_type & FDT_LCD_CACHE_WRITE_THROUGH) - type = DCACHE_WRITETHROUGH; - else if (priv->cache_type & FDT_LCD_CACHE_WRITE_BACK) - type = DCACHE_WRITEBACK; - mmu_set_region_dcache_behaviour(priv->frame_buffer, plat->size, type); + mmu_set_region_dcache_behaviour(priv->frame_buffer, plat->size, + DCACHE_WRITETHROUGH);
/* Enable flushing after LCD writes if requested */ - video_set_flush_dcache(dev, priv->cache_type & FDT_LCD_CACHE_FLUSH); + video_set_flush_dcache(dev, true);
uc_priv->xsize = priv->width; uc_priv->ysize = priv->height;
I thought we chose the current cache mode due to display corruption issues with other modes, but I tested a change that I believe does the same as this change on Seaboard without any apparent issue so,
Acked-by: Stephen Warren swarren@nvidia.com
I think for framebuffers the best option is still write-combine, which would be something like:
DCACHE_WRITECOMBINE = DCACHE_OFF | TTB_SECT_B_MASK
on ARM v7. Did you ever benchmark that against DCACHE_WRITETHROUGH? It should be faster provided that you never read from the region.
Thierry
Hi Thierry,
This is noticeably slower in my experience. Reading from the region is pretty common - e.g. scrolling.
We have driver-model drivers for some of these now, so drop them. Signed-off-by: Simon Glass sjg@chromium.org ---
include/fdtdec.h | 4 ---- lib/fdtdec.c | 4 ---- 2 files changed, 8 deletions(-)
diff --git a/include/fdtdec.h b/include/fdtdec.h index 6154b81..ba8c1ad 100644 --- a/include/fdtdec.h +++ b/include/fdtdec.h @@ -119,10 +119,7 @@ enum fdt_compat_id { COMPAT_NVIDIA_TEGRA20_EMC, /* Tegra20 memory controller */ COMPAT_NVIDIA_TEGRA20_EMC_TABLE, /* Tegra20 memory timing table */ COMPAT_NVIDIA_TEGRA20_NAND, /* Tegra2 NAND controller */ - COMPAT_NVIDIA_TEGRA20_PWM, /* Tegra 2 PWM controller */ - COMPAT_NVIDIA_TEGRA124_SOR, /* Tegra 124 Serial Output Resource */ COMPAT_NVIDIA_TEGRA124_PMC, /* Tegra 124 power mgmt controller */ - COMPAT_NVIDIA_TEGRA20_DC, /* Tegra 2 Display controller */ COMPAT_NVIDIA_TEGRA210_SDMMC, /* Tegra210 SDMMC controller */ COMPAT_NVIDIA_TEGRA124_SDMMC, /* Tegra124 SDMMC controller */ COMPAT_NVIDIA_TEGRA30_SDMMC, /* Tegra30 SDMMC controller */ @@ -145,7 +142,6 @@ enum fdt_compat_id { COMPAT_SAMSUNG_EXYNOS5_DP, /* Exynos Display port controller */ COMPAT_SAMSUNG_EXYNOS_DWMMC, /* Exynos DWMMC controller */ COMPAT_SAMSUNG_EXYNOS_MMC, /* Exynos MMC controller */ - COMPAT_SAMSUNG_EXYNOS_SERIAL, /* Exynos UART */ COMPAT_MAXIM_MAX77686_PMIC, /* MAX77686 PMIC */ COMPAT_GENERIC_SPI_FLASH, /* Generic SPI Flash chip */ COMPAT_MAXIM_98095_CODEC, /* MAX98095 Codec */ diff --git a/lib/fdtdec.c b/lib/fdtdec.c index 751bee1..8278f43 100644 --- a/lib/fdtdec.c +++ b/lib/fdtdec.c @@ -26,10 +26,7 @@ static const char * const compat_names[COMPAT_COUNT] = { COMPAT(NVIDIA_TEGRA20_EMC, "nvidia,tegra20-emc"), COMPAT(NVIDIA_TEGRA20_EMC_TABLE, "nvidia,tegra20-emc-table"), COMPAT(NVIDIA_TEGRA20_NAND, "nvidia,tegra20-nand"), - COMPAT(NVIDIA_TEGRA20_PWM, "nvidia,tegra20-pwm"), - COMPAT(NVIDIA_TEGRA124_SOR, "nvidia,tegra124-sor"), COMPAT(NVIDIA_TEGRA124_PMC, "nvidia,tegra124-pmc"), - COMPAT(NVIDIA_TEGRA20_DC, "nvidia,tegra20-dc"), COMPAT(NVIDIA_TEGRA210_SDMMC, "nvidia,tegra210-sdhci"), COMPAT(NVIDIA_TEGRA124_SDMMC, "nvidia,tegra124-sdhci"), COMPAT(NVIDIA_TEGRA30_SDMMC, "nvidia,tegra30-sdhci"), @@ -50,7 +47,6 @@ static const char * const compat_names[COMPAT_COUNT] = { COMPAT(SAMSUNG_EXYNOS5_DP, "samsung,exynos5-dp"), COMPAT(SAMSUNG_EXYNOS_DWMMC, "samsung,exynos-dwmmc"), COMPAT(SAMSUNG_EXYNOS_MMC, "samsung,exynos-mmc"), - COMPAT(SAMSUNG_EXYNOS_SERIAL, "samsung,exynos4210-uart"), COMPAT(MAXIM_MAX77686_PMIC, "maxim,max77686"), COMPAT(GENERIC_SPI_FLASH, "spi-flash"), COMPAT(MAXIM_98095_CODEC, "maxim,max98095-codec"),
Am Donnerstag, den 14.01.2016, 13:26 -0700 schrieb Simon Glass:
The original tegra20 display driver was written before Linux had device tree bindings for display. Since then Linux has developed a robust set of bindings covering various aspects of enabling a display.
This series moves closer to those bindings by using the panel and backlight as separate drivers. The device tree files for seaboard, ventana and harmony thereby become almost the same as Linux.
Unfortunately this breaks the other boards, which will need a similar sync. So I'm not sure how easy it will be to accept this series. Still, it seems worth sending it out in the hope that board maintainers can help. I have kept this series separate so that it can progress separately.
By pushing display timings into the DT you are actually diverging from mainline, as mainline doesn't require this, but instead infers the timings from the panel compatible. Is this a desired goal?
Regards, Lucas
Simon Glass (4): tegra: dts: Sync seaboard device tree file with Linux video: tegra: Move to using simple-panel and pwm-backlight tegra: video: Always use write-through cache on LCD fdt: Drop some unused compatible strings
arch/arm/dts/tegra20-harmony.dts | 751 ++++++++++++++++++++++++++++-- arch/arm/dts/tegra20-seaboard.dts | 934 ++++++++++++++++++++++++++++++++++---- arch/arm/dts/tegra20-ventana.dts | 685 ++++++++++++++++++++++++++-- configs/colibri_t20_defconfig | 5 +- configs/harmony_defconfig | 5 +- configs/medcom-wide_defconfig | 5 +- configs/paz00_defconfig | 5 +- configs/seaboard_defconfig | 5 +- configs/tec_defconfig | 5 +- configs/ventana_defconfig | 5 +- drivers/video/tegra.c | 333 +++----------- include/fdtdec.h | 4 - lib/fdtdec.c | 4 - 13 files changed, 2307 insertions(+), 439 deletions(-)
Hi Lucas,
This is not divergence. Please take a look at the patch series. The device tree files are very close to the same now. The existing U-Boot support has display timings in the device tree too, so this is not being added.
The display timings are a small part of the work, but in the back of my mind is that we don't want to have a big table of display panel timings as exists in Linux. This is a waste of space when a board will only use one panel.
Regards, Lucas
On 01/14/2016 04:12 PM, Simon Glass wrote:
Hi Lucas,
Really? The DT content is different. Isn't that the definition of divergence?
That was rather the point of the panel-specific compatible values: To force the DT to contain a semantic definition of the type of panel, rather than a "generic" definition of timings. A benefit of the semantic representation is that if we later find bugs that need to be fixed on certain panels, if we know the panel type, then bug fixes can be applied. Equally, if we enhance the SW to require more data about the panel, that can be added to a driver without the need to change the DT, thus allowing old DTs to continue to work. More semantic rather than purely "syntactic" knowledge is available. However, if we only have a generic timing definition (or other data suitable for current SW features or code-paths), then panel-specific bug fixes will never be possible since SW can't know the identify of the panel. The disadvantage of requiring a mapping table between panel type and display timings was considered reasonable for SW stacks at which DT was targeted (i.e. main OSs rather than HW-specific bootloaders). Even so, to avoid the bloat issue, you can always just #ifdef the mapping table and end up with the same code size; even less perhaps since no timing DT parsing code is required.
At least, that was the reasoning when the DT bindings for Tegra panels were first created; IIRC there was discussion of bindings for generic panels, timings, panel power sequences, etc., and they were rejected for the reason I explained above and perhaps others. However, it does seem someone has changed their mind again given that the generic panel-timings binding does exist now. This is one of the many things that sucks about DT; no decision is ever kept, so consistency in design and implementation isn't possible:-(
Hi Stephen,
Hi Lucas,
You might infer that from the movie, but divergence really means that things are getting further apart. So I think here we have convergence.
Sounds a bit contrived to me. The hardware includes the panel, so IMO it makes perfect sense to describe it in the DT. Plus it is more efficient as I mentioned.
On 01/18/2016 06:58 PM, Simon Glass wrote:
Hi Stephen,
Hi Lucas,
I believe this approach has been taken after years of experience with DT and having to retro-fit bug-fixes and new features into existing DTs.
Still, you'd get the best background from the Linux kernel DT maintainers on this topic, since they have experience with DT over more years than me. I'm simply reporting the arguments they've presented.
Hi Stephen,
Hi Lucas,
To be fair, the panel bindings came about after the display-timings binding. Perhaps the main reason why the panel bindings are what they are today is because I consider them devices no different at all from peripherals and the like. Back at the time, most of the pushback was because people believed that panels were somehow special in that they would simply require the video timings to make them work, and hence having some generic helpers to parse them from DT would be enough and is what many drivers ended up implementing.
But it turned out that there's more to panels than just the video timings. Many panels do have a varying number of inputs that need to be controlled before you can use them. There are voltage supplies and reset or powerdown GPIOs, PWM inputs for backlight etc. Like Stephen said it was at some point attempted to describe this completely generically in DT using power sequences, but that effort turned out to be much too complicated even considering only a subset of relatively simple panels.
Taking into account the various types of smart panels out there things get even more complicated. All of a sudden you need a sort of register programming sequence to enable or disable the panel. Of course with a generic panel binding you need to find a way to put that into the DT along with everything else. And then you need a way to specify where to write these registers in the enable/disable sequence, in some cases you might even need to split it up into several chunks, etc.
So the end result was that while you had a generic way for describing the video timings, every driver had to implement its own support infrastructure for the various resources that you need to turn on. In fact this became quite the opposite of generic.
Now when you consider panels to be devices and give them a proper compatible string things actually get almost trivial. Now each panel can have a binding that fully describes the supplies and GPIOs and the driver that binds to the device can contain the enable and disable sequences in code. This is completely normal for any other kind of device, why would panels need to be special? Now that a panel is simply a device like any other you can make things truly generic, create the abstractions you need and simply hook up outputs to panels and make them work together.
There is still some commonality in many panels, so in Linux we ended up implementing a "simple" panel driver, which can drive panels that have a backlight, a power supply and an enable GPIO, with an optional DDC bus that can be used to read EDID. That driver supports 34 different panels at the time of this writing and it's still fairly small. But there is a slew of options to reduce that size even further if you really need to. You could for example have Kconfig options for panel vendors, or even per-panel Kconfig options to minimize the data used for the panel. I suspect that you might end up with even less data than the equivalent DT content.
Thierry
Hi Stephen,
Hi Lucas,
Am Donnerstag, den 14.01.2016, 13:26 -0700 schrieb Simon Glass: > >The original tegra20 display driver was written before Linux had >device tree >bindings for display. Since then Linux has developed a robust set of >bindings >covering various aspects of enabling a display. > >This series moves closer to those bindings by using the panel and >backlight >as separate drivers. The device tree files for seaboard, ventana and >harmony >thereby become almost the same as Linux. > >Unfortunately this breaks the other boards, which will need a similar >sync. >So I'm not sure how easy it will be to accept this series. Still, it >seems >worth sending it out in the hope that board maintainers can help. I >have >kept this series separate so that it can progress separately. > By pushing display timings into the DT you are actually diverging from mainline, as mainline doesn't require this, but instead infers the timings from the panel compatible. Is this a desired goal?
So far I've just implemented simple-panel, but the option is there to create your own driver in UCLASS_PANEL if needed. I have not needed any special panel features yet, but we'll see how it goes. I suppose a lot of panels are pretty simple/similar.
I didn't see any delay stuff in Linux - or at least it is there but was zero for seaboard. So probably I was worrying about that unnecessarily.
Can't that be handled by placing the new code under an ifdef, so the source code can support either the old or the new scheme, then each board can be converted over and the ifdef flipped in its per-board config file, then the ifdef removed once all boards are converted?
Hi Stephen,
To some extent, although there is the common tegra20.dtsi and lots of common code. It was more pain than I was willing to bear.
Another option is to eventually disable LCD for boards where the maintainers don't respond.
Lucas Stach
Stephen Warren
Thierry Reding
