[Patch v4 0/7] Transition of fsl qspi driver to spi-mem framework
This entire patch series migrate freescale qspi driver to spi-mem framework.
v4 version of series include removal of buildman failure on LS2080AQDS build which was observed in cleanup patches. Also, more clear commit message of patch 5.
v3 version of series includes correction of copyright in qspi driver and also move SPI_FLASH_SPANSION from header to defconfigs in same patch.
v2 version of series includes changes in qspi driver to have 1k size instead of complete flash size so as to make driver independent of flash size. This also makes it align with linux version of driver. Also added support for imx platforms to set TDH bits correctly. There are other minor changes in commit messages.
Dependency on patches[1][2]. These patches are required to resolve booting crash observed in LS1012ARDB. One crash was related to pfe driver as it was accessing flash memory directly and other was based on environment. [1] https://patchwork.ozlabs.org/patch/1219462/ [2] https://patchwork.ozlabs.org/patch/1208299/
Patch 1 adds new qspi driver incorporating spi-mem framework and also removal of old driver which was based on spi-nor. The driver is a ported version of linux qspi driver. Initial port was done by Frieder. Now, no more direct memory access to spi-nor memory is possible i.e accessing flash memory using absolute address is not possible.
Patch 2 removes unused qspi config options.
Patch 3 moves FSL_QSPI to defconfig instead of defining it in header files.
Patch 4 removes unused num-cs property from imx platforms.
Patch 5 enables SPI_FLASH_SPANSION in ls1012a defconfig as FSL_QSPI is already enabled.
Patch 6 enables SPI_FLASH_SPANSION in defconfigs of LS1046a boards instead of defining in header files.
Patch 7 updates the device-tree properties treewide for layerscape boards by aligning with linux device-tree properties.
Frieder Schrempf (1): imx: imx6sx: Remove unused 'num-cs' property
Kuldeep Singh (6): spi: Transform the FSL QuadSPI driver to use the SPI MEM API treewide: Remove unused FSL QSPI config options configs: ls1043a: Move CONFIG_FSL_QSPI to defconfig configs: ls1012a: Enable CONFIG_SPI_FLASH_SPANSION in defconfigs configs: ls1046a: Move SPI_FLASH_SPANSION to defconfig treewide: Update fsl qspi node dt properties as per spi-mem driver
arch/arm/dts/fsl-ls1012a-2g5rdb.dts | 5 +- arch/arm/dts/fsl-ls1012a-frdm.dtsi | 5 +- arch/arm/dts/fsl-ls1012a-qds.dtsi | 5 +- arch/arm/dts/fsl-ls1012a-rdb.dtsi | 5 +- arch/arm/dts/fsl-ls1012a.dtsi | 4 +- arch/arm/dts/fsl-ls1043a-qds.dtsi | 5 +- arch/arm/dts/fsl-ls1043a.dtsi | 6 +- arch/arm/dts/fsl-ls1046a-frwy.dts | 5 +- arch/arm/dts/fsl-ls1046a-qds.dtsi | 5 +- arch/arm/dts/fsl-ls1046a-rdb.dts | 5 +- arch/arm/dts/fsl-ls1046a.dtsi | 4 +- arch/arm/dts/fsl-ls1088a-qds.dts | 5 +- arch/arm/dts/fsl-ls1088a-rdb.dts | 5 +- arch/arm/dts/fsl-ls1088a.dtsi | 2 +- arch/arm/dts/fsl-ls2080a-qds.dts | 5 +- arch/arm/dts/fsl-ls2080a.dtsi | 4 +- arch/arm/dts/fsl-ls2088a-rdb-qspi.dts | 5 +- arch/arm/dts/imx6sx-sabreauto-u-boot.dtsi | 2 - arch/arm/dts/imx6sx-sdb-u-boot.dtsi | 2 - arch/arm/dts/ls1021a-twr.dtsi | 5 +- arch/arm/dts/ls1021a.dtsi | 6 +- arch/arm/include/asm/arch-fsl-layerscape/config.h | 1 - arch/arm/include/asm/arch-ls102xa/config.h | 1 - configs/ls1012a2g5rdb_qspi_defconfig | 1 + configs/ls1012a2g5rdb_tfa_defconfig | 1 + configs/ls1012afrdm_qspi_defconfig | 1 + configs/ls1012afrdm_tfa_defconfig | 1 + configs/ls1012aqds_qspi_defconfig | 1 + configs/ls1012aqds_tfa_SECURE_BOOT_defconfig | 1 + configs/ls1012aqds_tfa_defconfig | 1 + configs/ls1012ardb_qspi_SECURE_BOOT_defconfig | 1 + configs/ls1012ardb_qspi_defconfig | 1 + configs/ls1012ardb_tfa_SECURE_BOOT_defconfig | 1 + configs/ls1012ardb_tfa_defconfig | 1 + configs/ls1043aqds_qspi_defconfig | 1 + configs/ls1043aqds_sdcard_qspi_defconfig | 1 + configs/ls1043aqds_tfa_SECURE_BOOT_defconfig | 2 + configs/ls1043aqds_tfa_defconfig | 1 + configs/ls1046aqds_qspi_defconfig | 1 + configs/ls1046aqds_sdcard_qspi_defconfig | 1 + configs/ls1046aqds_tfa_SECURE_BOOT_defconfig | 1 + configs/ls1046aqds_tfa_defconfig | 1 + configs/ls1046ardb_qspi_SECURE_BOOT_defconfig | 1 + configs/ls1046ardb_qspi_defconfig | 1 + configs/ls1046ardb_tfa_SECURE_BOOT_defconfig | 1 + configs/ls1046ardb_tfa_defconfig | 1 + drivers/spi/fsl_qspi.c | 1574 ++++++++------------- drivers/spi/fsl_qspi.h | 145 -- include/configs/ls1012a_common.h | 17 +- include/configs/ls1012afrwy.h | 3 - include/configs/ls1012ardb.h | 3 - include/configs/ls1021aiot.h | 6 - include/configs/ls1021aqds.h | 11 - include/configs/ls1021atwr.h | 10 - include/configs/ls1043aqds.h | 10 - include/configs/ls1046afrwy.h | 9 - include/configs/ls1046aqds.h | 19 - include/configs/ls1046ardb.h | 20 - include/configs/ls1088a_common.h | 6 - include/configs/ls1088aqds.h | 8 - include/configs/ls1088ardb.h | 18 - include/configs/ls2080aqds.h | 5 - include/configs/ls2080ardb.h | 6 +- include/configs/mx6sxsabreauto.h | 6 - include/configs/mx6sxsabresd.h | 11 - include/configs/mx6ul_14x14_evk.h | 6 - include/configs/mx6ullevk.h | 6 - include/configs/mx7dsabresd.h | 8 - include/configs/pcm052.h | 7 - include/configs/vf610twr.h | 8 - scripts/config_whitelist.txt | 5 - 71 files changed, 666 insertions(+), 1382 deletions(-) delete mode 100644 drivers/spi/fsl_qspi.h
To support the SPI MEM API, instead of modifying the existing U-Boot driver, this patch adds a port of the existing Linux driver. This also has the advantage that porting changes and fixes from Linux will be easier. Porting of driver left most of the functions unchanged while few of the changes are: -Remove lock(mutexes) and irq handler as u-boot is a single core execution. -Remove invalid masterid as it was required specially for multicore execution in LS2088ARDB which is not the case in u-boot. -Remove clock support as changing spi speed is not supported in uboot and nor in linux.
Currently tested on LS1088ARDB, LS1012ARDB, LS1046ARDB, LS1046AFRWY, LS1043AQDS, LS1021ATWR, LS2088ARDB, I.MX6ULL EVK.
Signed-off-by: Frieder Schrempf frieder.schrempf@kontron.de Signed-off-by: Ashish Kumar Ashish.Kumar@nxp.com Signed-off-by: Kuldeep Singh kuldeep.singh@nxp.com Reviewed-by: Stefan Roese sr@denx.de Tested-by: Stefan Roese sr@denx.de --- Depends on https://patchwork.ozlabs.org/patch/1219462/ Depends on https://patchwork.ozlabs.org/patch/1208299/
v4: Add i.mx among tested boards v3: Use 1k size to make driver independent of flash size. v2: Merge removal of old driver and addition of new driver in single patch
drivers/spi/fsl_qspi.c | 1574 +++++++++++++++++++----------------------------- drivers/spi/fsl_qspi.h | 145 ----- 2 files changed, 605 insertions(+), 1114 deletions(-) delete mode 100644 drivers/spi/fsl_qspi.h
diff --git a/drivers/spi/fsl_qspi.c b/drivers/spi/fsl_qspi.c index 8e2a09d..4b86b5f 100644 --- a/drivers/spi/fsl_qspi.c +++ b/drivers/spi/fsl_qspi.c @@ -1,1142 +1,778 @@ // SPDX-License-Identifier: GPL-2.0+ + /* - * Copyright 2013-2015 Freescale Semiconductor, Inc. + * Freescale QuadSPI driver. + * + * Copyright (C) 2013 Freescale Semiconductor, Inc. + * Copyright (C) 2018 Bootlin + * Copyright (C) 2018 exceet electronics GmbH + * Copyright (C) 2018 Kontron Electronics GmbH + * Copyright 2019-2020 NXP + * + * This driver is a ported version of Linux Freescale QSPI driver taken from + * v5.5-rc1 tag having following information. * - * Freescale Quad Serial Peripheral Interface (QSPI) driver + * Transition to SPI MEM interface: + * Authors: + * Boris Brezillon bbrezillon@kernel.org + * Frieder Schrempf frieder.schrempf@kontron.de + * Yogesh Gaur yogeshnarayan.gaur@nxp.com + * Suresh Gupta suresh.gupta@nxp.com + * + * Based on the original fsl-quadspi.c spi-nor driver. + * Transition to spi-mem in spi-fsl-qspi.c */
#include <common.h> -#include <malloc.h> -#include <spi.h> #include <asm/io.h> -#include <linux/sizes.h> -#include <linux/iopoll.h> #include <dm.h> -#include <errno.h> -#include <watchdog.h> -#include <wait_bit.h> -#include "fsl_qspi.h" +#include <linux/iopoll.h> +#include <linux/sizes.h> +#include <spi.h> +#include <spi-mem.h>
DECLARE_GLOBAL_DATA_PTR;
-#define OFFSET_BITS_MASK GENMASK(23, 0) - -#define FLASH_STATUS_WEL 0x02 - -/* SEQID */ -#define SEQID_WREN 1 -#define SEQID_FAST_READ 2 -#define SEQID_RDSR 3 -#define SEQID_SE 4 -#define SEQID_CHIP_ERASE 5 -#define SEQID_PP 6 -#define SEQID_RDID 7 -#define SEQID_BE_4K 8 -#ifdef CONFIG_SPI_FLASH_BAR -#define SEQID_BRRD 9 -#define SEQID_BRWR 10 -#define SEQID_RDEAR 11 -#define SEQID_WREAR 12 -#endif -#define SEQID_WRAR 13 -#define SEQID_RDAR 14 - -/* QSPI CMD */ -#define QSPI_CMD_PP 0x02 /* Page program (up to 256 bytes) */ -#define QSPI_CMD_RDSR 0x05 /* Read status register */ -#define QSPI_CMD_WREN 0x06 /* Write enable */ -#define QSPI_CMD_FAST_READ 0x0b /* Read data bytes (high frequency) */ -#define QSPI_CMD_BE_4K 0x20 /* 4K erase */ -#define QSPI_CMD_CHIP_ERASE 0xc7 /* Erase whole flash chip */ -#define QSPI_CMD_SE 0xd8 /* Sector erase (usually 64KiB) */ -#define QSPI_CMD_RDID 0x9f /* Read JEDEC ID */ - -/* Used for Micron, winbond and Macronix flashes */ -#define QSPI_CMD_WREAR 0xc5 /* EAR register write */ -#define QSPI_CMD_RDEAR 0xc8 /* EAR reigster read */ - -/* Used for Spansion flashes only. */ -#define QSPI_CMD_BRRD 0x16 /* Bank register read */ -#define QSPI_CMD_BRWR 0x17 /* Bank register write */ - -/* Used for Spansion S25FS-S family flash only. */ -#define QSPI_CMD_RDAR 0x65 /* Read any device register */ -#define QSPI_CMD_WRAR 0x71 /* Write any device register */ - -/* 4-byte address QSPI CMD - used on Spansion and some Macronix flashes */ -#define QSPI_CMD_FAST_READ_4B 0x0c /* Read data bytes (high frequency) */ -#define QSPI_CMD_PP_4B 0x12 /* Page program (up to 256 bytes) */ -#define QSPI_CMD_SE_4B 0xdc /* Sector erase (usually 64KiB) */ - -/* fsl_qspi_platdata flags */ -#define QSPI_FLAG_REGMAP_ENDIAN_BIG BIT(0) - -/* default SCK frequency, unit: HZ */ -#define FSL_QSPI_DEFAULT_SCK_FREQ 50000000 - -/* QSPI max chipselect signals number */ -#define FSL_QSPI_MAX_CHIPSELECT_NUM 4 - -/* Controller needs driver to swap endian */ +/* + * The driver only uses one single LUT entry, that is updated on + * each call of exec_op(). Index 0 is preset at boot with a basic + * read operation, so let's use the last entry (15). + */ +#define SEQID_LUT 15 + +/* Registers used by the driver */ +#define QUADSPI_MCR 0x00 +#define QUADSPI_MCR_RESERVED_MASK GENMASK(19, 16) +#define QUADSPI_MCR_MDIS_MASK BIT(14) +#define QUADSPI_MCR_CLR_TXF_MASK BIT(11) +#define QUADSPI_MCR_CLR_RXF_MASK BIT(10) +#define QUADSPI_MCR_DDR_EN_MASK BIT(7) +#define QUADSPI_MCR_END_CFG_MASK GENMASK(3, 2) +#define QUADSPI_MCR_SWRSTHD_MASK BIT(1) +#define QUADSPI_MCR_SWRSTSD_MASK BIT(0) + +#define QUADSPI_IPCR 0x08 +#define QUADSPI_IPCR_SEQID(x) ((x) << 24) +#define QUADSPI_FLSHCR 0x0c +#define QUADSPI_FLSHCR_TCSS_MASK GENMASK(3, 0) +#define QUADSPI_FLSHCR_TCSH_MASK GENMASK(11, 8) +#define QUADSPI_FLSHCR_TDH_MASK GENMASK(17, 16) + +#define QUADSPI_BUF3CR 0x1c +#define QUADSPI_BUF3CR_ALLMST_MASK BIT(31) +#define QUADSPI_BUF3CR_ADATSZ(x) ((x) << 8) +#define QUADSPI_BUF3CR_ADATSZ_MASK GENMASK(15, 8) + +#define QUADSPI_BFGENCR 0x20 +#define QUADSPI_BFGENCR_SEQID(x) ((x) << 12) + +#define QUADSPI_BUF0IND 0x30 +#define QUADSPI_BUF1IND 0x34 +#define QUADSPI_BUF2IND 0x38 +#define QUADSPI_SFAR 0x100 + +#define QUADSPI_SMPR 0x108 +#define QUADSPI_SMPR_DDRSMP_MASK GENMASK(18, 16) +#define QUADSPI_SMPR_FSDLY_MASK BIT(6) +#define QUADSPI_SMPR_FSPHS_MASK BIT(5) +#define QUADSPI_SMPR_HSENA_MASK BIT(0) + +#define QUADSPI_RBCT 0x110 +#define QUADSPI_RBCT_WMRK_MASK GENMASK(4, 0) +#define QUADSPI_RBCT_RXBRD_USEIPS BIT(8) + +#define QUADSPI_TBDR 0x154 + +#define QUADSPI_SR 0x15c +#define QUADSPI_SR_IP_ACC_MASK BIT(1) +#define QUADSPI_SR_AHB_ACC_MASK BIT(2) + +#define QUADSPI_FR 0x160 +#define QUADSPI_FR_TFF_MASK BIT(0) + +#define QUADSPI_RSER 0x164 +#define QUADSPI_RSER_TFIE BIT(0) + +#define QUADSPI_SPTRCLR 0x16c +#define QUADSPI_SPTRCLR_IPPTRC BIT(8) +#define QUADSPI_SPTRCLR_BFPTRC BIT(0) + +#define QUADSPI_SFA1AD 0x180 +#define QUADSPI_SFA2AD 0x184 +#define QUADSPI_SFB1AD 0x188 +#define QUADSPI_SFB2AD 0x18c +#define QUADSPI_RBDR(x) (0x200 + ((x) * 4)) + +#define QUADSPI_LUTKEY 0x300 +#define QUADSPI_LUTKEY_VALUE 0x5AF05AF0 + +#define QUADSPI_LCKCR 0x304 +#define QUADSPI_LCKER_LOCK BIT(0) +#define QUADSPI_LCKER_UNLOCK BIT(1) + +#define QUADSPI_LUT_BASE 0x310 +#define QUADSPI_LUT_OFFSET (SEQID_LUT * 4 * 4) +#define QUADSPI_LUT_REG(idx) \ + (QUADSPI_LUT_BASE + QUADSPI_LUT_OFFSET + (idx) * 4) + +/* Instruction set for the LUT register */ +#define LUT_STOP 0 +#define LUT_CMD 1 +#define LUT_ADDR 2 +#define LUT_DUMMY 3 +#define LUT_MODE 4 +#define LUT_MODE2 5 +#define LUT_MODE4 6 +#define LUT_FSL_READ 7 +#define LUT_FSL_WRITE 8 +#define LUT_JMP_ON_CS 9 +#define LUT_ADDR_DDR 10 +#define LUT_MODE_DDR 11 +#define LUT_MODE2_DDR 12 +#define LUT_MODE4_DDR 13 +#define LUT_FSL_READ_DDR 14 +#define LUT_FSL_WRITE_DDR 15 +#define LUT_DATA_LEARN 16 + +/* + * The PAD definitions for LUT register. + * + * The pad stands for the number of IO lines [0:3]. + * For example, the quad read needs four IO lines, + * so you should use LUT_PAD(4). + */ +#define LUT_PAD(x) (fls(x) - 1) + +/* + * Macro for constructing the LUT entries with the following + * register layout: + * + * --------------------------------------------------- + * | INSTR1 | PAD1 | OPRND1 | INSTR0 | PAD0 | OPRND0 | + * --------------------------------------------------- + */ +#define LUT_DEF(idx, ins, pad, opr) \ + ((((ins) << 10) | ((pad) << 8) | (opr)) << (((idx) % 2) * 16)) + +/* Controller needs driver to swap endianness */ #define QUADSPI_QUIRK_SWAP_ENDIAN BIT(0)
-enum fsl_qspi_devtype { - FSL_QUADSPI_VYBRID, - FSL_QUADSPI_IMX6SX, - FSL_QUADSPI_IMX6UL_7D, - FSL_QUADSPI_IMX7ULP, -}; +/* Controller needs 4x internal clock */ +#define QUADSPI_QUIRK_4X_INT_CLK BIT(1)
-struct fsl_qspi_devtype_data { - enum fsl_qspi_devtype devtype; - u32 rxfifo; - u32 txfifo; - u32 ahb_buf_size; - u32 driver_data; -}; +/* + * TKT253890, the controller needs the driver to fill the txfifo with + * 16 bytes at least to trigger a data transfer, even though the extra + * data won't be transferred. + */ +#define QUADSPI_QUIRK_TKT253890 BIT(2)
-/** - * struct fsl_qspi_platdata - platform data for Freescale QSPI - * - * @flags: Flags for QSPI QSPI_FLAG_... - * @speed_hz: Default SCK frequency - * @reg_base: Base address of QSPI registers - * @amba_base: Base address of QSPI memory mapping - * @amba_total_size: size of QSPI memory mapping - * @flash_num: Number of active slave devices - * @num_chipselect: Number of QSPI chipselect signals +/* TKT245618, the controller cannot wake up from wait mode */ +#define QUADSPI_QUIRK_TKT245618 BIT(3) + +/* + * Controller adds QSPI_AMBA_BASE (base address of the mapped memory) + * internally. No need to add it when setting SFXXAD and SFAR registers */ -struct fsl_qspi_platdata { - u32 flags; - u32 speed_hz; - fdt_addr_t reg_base; - fdt_addr_t amba_base; - fdt_size_t amba_total_size; - u32 flash_num; - u32 num_chipselect; -}; +#define QUADSPI_QUIRK_BASE_INTERNAL BIT(4)
-/** - * struct fsl_qspi_priv - private data for Freescale QSPI - * - * @flags: Flags for QSPI QSPI_FLAG_... - * @bus_clk: QSPI input clk frequency - * @speed_hz: Default SCK frequency - * @cur_seqid: current LUT table sequence id - * @sf_addr: flash access offset - * @amba_base: Base address of QSPI memory mapping of every CS - * @amba_total_size: size of QSPI memory mapping - * @cur_amba_base: Base address of QSPI memory mapping of current CS - * @flash_num: Number of active slave devices - * @num_chipselect: Number of QSPI chipselect signals - * @regs: Point to QSPI register structure for I/O access +/* + * Controller uses TDH bits in register QUADSPI_FLSHCR. + * They need to be set in accordance with the DDR/SDR mode. */ -struct fsl_qspi_priv { - u32 flags; - u32 bus_clk; - u32 speed_hz; - u32 cur_seqid; - u32 sf_addr; - u32 amba_base[FSL_QSPI_MAX_CHIPSELECT_NUM]; - u32 amba_total_size; - u32 cur_amba_base; - u32 flash_num; - u32 num_chipselect; - struct fsl_qspi_regs *regs; - struct fsl_qspi_devtype_data *devtype_data; +#define QUADSPI_QUIRK_USE_TDH_SETTING BIT(5) + +struct fsl_qspi_devtype_data { + unsigned int rxfifo; + unsigned int txfifo; + unsigned int ahb_buf_size; + unsigned int quirks; + bool little_endian; };
static const struct fsl_qspi_devtype_data vybrid_data = { - .devtype = FSL_QUADSPI_VYBRID, - .rxfifo = 128, - .txfifo = 64, - .ahb_buf_size = 1024, - .driver_data = QUADSPI_QUIRK_SWAP_ENDIAN, + .rxfifo = SZ_128, + .txfifo = SZ_64, + .ahb_buf_size = SZ_1K, + .quirks = QUADSPI_QUIRK_SWAP_ENDIAN, + .little_endian = true, };
static const struct fsl_qspi_devtype_data imx6sx_data = { - .devtype = FSL_QUADSPI_IMX6SX, - .rxfifo = 128, - .txfifo = 512, - .ahb_buf_size = 1024, - .driver_data = 0, + .rxfifo = SZ_128, + .txfifo = SZ_512, + .ahb_buf_size = SZ_1K, + .quirks = QUADSPI_QUIRK_4X_INT_CLK | QUADSPI_QUIRK_TKT245618, + .little_endian = true, +}; + +static const struct fsl_qspi_devtype_data imx7d_data = { + .rxfifo = SZ_128, + .txfifo = SZ_512, + .ahb_buf_size = SZ_1K, + .quirks = QUADSPI_QUIRK_TKT253890 | QUADSPI_QUIRK_4X_INT_CLK | + QUADSPI_QUIRK_USE_TDH_SETTING, + .little_endian = true, };
-static const struct fsl_qspi_devtype_data imx6ul_7d_data = { - .devtype = FSL_QUADSPI_IMX6UL_7D, - .rxfifo = 128, - .txfifo = 512, - .ahb_buf_size = 1024, - .driver_data = 0, +static const struct fsl_qspi_devtype_data imx6ul_data = { + .rxfifo = SZ_128, + .txfifo = SZ_512, + .ahb_buf_size = SZ_1K, + .quirks = QUADSPI_QUIRK_TKT253890 | QUADSPI_QUIRK_4X_INT_CLK | + QUADSPI_QUIRK_USE_TDH_SETTING, + .little_endian = true, };
-static const struct fsl_qspi_devtype_data imx7ulp_data = { - .devtype = FSL_QUADSPI_IMX7ULP, - .rxfifo = 64, - .txfifo = 64, - .ahb_buf_size = 128, - .driver_data = 0, +static const struct fsl_qspi_devtype_data ls1021a_data = { + .rxfifo = SZ_128, + .txfifo = SZ_64, + .ahb_buf_size = SZ_1K, + .quirks = 0, + .little_endian = false, };
-static u32 qspi_read32(u32 flags, u32 *addr) +static const struct fsl_qspi_devtype_data ls1088a_data = { + .rxfifo = SZ_128, + .txfifo = SZ_128, + .ahb_buf_size = SZ_1K, + .quirks = QUADSPI_QUIRK_TKT253890, + .little_endian = true, +}; + +static const struct fsl_qspi_devtype_data ls2080a_data = { + .rxfifo = SZ_128, + .txfifo = SZ_64, + .ahb_buf_size = SZ_1K, + .quirks = QUADSPI_QUIRK_TKT253890 | QUADSPI_QUIRK_BASE_INTERNAL, + .little_endian = true, +}; + +struct fsl_qspi { + void __iomem *iobase; + void __iomem *ahb_addr; + u32 memmap_phy; + const struct fsl_qspi_devtype_data *devtype_data; + int selected; +}; + +static inline int needs_swap_endian(struct fsl_qspi *q) { - return flags & QSPI_FLAG_REGMAP_ENDIAN_BIG ? - in_be32(addr) : in_le32(addr); + return q->devtype_data->quirks & QUADSPI_QUIRK_SWAP_ENDIAN; }
-static void qspi_write32(u32 flags, u32 *addr, u32 val) +static inline int needs_4x_clock(struct fsl_qspi *q) { - flags & QSPI_FLAG_REGMAP_ENDIAN_BIG ? - out_be32(addr, val) : out_le32(addr, val); + return q->devtype_data->quirks & QUADSPI_QUIRK_4X_INT_CLK; }
-static inline int is_controller_busy(const struct fsl_qspi_priv *priv) +static inline int needs_fill_txfifo(struct fsl_qspi *q) { - u32 val; - u32 mask = QSPI_SR_BUSY_MASK | QSPI_SR_AHB_ACC_MASK | - QSPI_SR_IP_ACC_MASK; - - if (priv->flags & QSPI_FLAG_REGMAP_ENDIAN_BIG) - mask = (u32)cpu_to_be32(mask); - - return readl_poll_timeout(&priv->regs->sr, val, !(val & mask), 1000); + return q->devtype_data->quirks & QUADSPI_QUIRK_TKT253890; }
-/* QSPI support swapping the flash read/write data - * in hardware for LS102xA, but not for VF610 */ -static inline u32 qspi_endian_xchg(struct fsl_qspi_priv *priv, u32 data) +static inline int needs_wakeup_wait_mode(struct fsl_qspi *q) { - if (priv->devtype_data->driver_data & QUADSPI_QUIRK_SWAP_ENDIAN) - return swab32(data); - else - return data; + return q->devtype_data->quirks & QUADSPI_QUIRK_TKT245618; }
-static void qspi_set_lut(struct fsl_qspi_priv *priv) +static inline int needs_amba_base_offset(struct fsl_qspi *q) { - struct fsl_qspi_regs *regs = priv->regs; - u32 lut_base; - - /* Unlock the LUT */ - qspi_write32(priv->flags, ®s->lutkey, LUT_KEY_VALUE); - qspi_write32(priv->flags, ®s->lckcr, QSPI_LCKCR_UNLOCK); - - /* Write Enable */ - lut_base = SEQID_WREN * 4; - qspi_write32(priv->flags, ®s->lut[lut_base], OPRND0(QSPI_CMD_WREN) | - PAD0(LUT_PAD1) | INSTR0(LUT_CMD)); - qspi_write32(priv->flags, ®s->lut[lut_base + 1], 0); - qspi_write32(priv->flags, ®s->lut[lut_base + 2], 0); - qspi_write32(priv->flags, ®s->lut[lut_base + 3], 0); - - /* Fast Read */ - lut_base = SEQID_FAST_READ * 4; -#ifdef CONFIG_SPI_FLASH_BAR - qspi_write32(priv->flags, ®s->lut[lut_base], - OPRND0(QSPI_CMD_FAST_READ) | PAD0(LUT_PAD1) | - INSTR0(LUT_CMD) | OPRND1(ADDR24BIT) | - PAD1(LUT_PAD1) | INSTR1(LUT_ADDR)); -#else - if (FSL_QSPI_FLASH_SIZE <= SZ_16M) - qspi_write32(priv->flags, ®s->lut[lut_base], - OPRND0(QSPI_CMD_FAST_READ) | PAD0(LUT_PAD1) | - INSTR0(LUT_CMD) | OPRND1(ADDR24BIT) | - PAD1(LUT_PAD1) | INSTR1(LUT_ADDR)); - else - qspi_write32(priv->flags, ®s->lut[lut_base], - OPRND0(QSPI_CMD_FAST_READ_4B) | - PAD0(LUT_PAD1) | INSTR0(LUT_CMD) | - OPRND1(ADDR32BIT) | PAD1(LUT_PAD1) | - INSTR1(LUT_ADDR)); -#endif - qspi_write32(priv->flags, ®s->lut[lut_base + 1], - OPRND0(8) | PAD0(LUT_PAD1) | INSTR0(LUT_DUMMY) | - OPRND1(priv->devtype_data->rxfifo) | PAD1(LUT_PAD1) | - INSTR1(LUT_READ)); - qspi_write32(priv->flags, ®s->lut[lut_base + 2], 0); - qspi_write32(priv->flags, ®s->lut[lut_base + 3], 0); - - /* Read Status */ - lut_base = SEQID_RDSR * 4; - qspi_write32(priv->flags, ®s->lut[lut_base], OPRND0(QSPI_CMD_RDSR) | - PAD0(LUT_PAD1) | INSTR0(LUT_CMD) | OPRND1(1) | - PAD1(LUT_PAD1) | INSTR1(LUT_READ)); - qspi_write32(priv->flags, ®s->lut[lut_base + 1], 0); - qspi_write32(priv->flags, ®s->lut[lut_base + 2], 0); - qspi_write32(priv->flags, ®s->lut[lut_base + 3], 0); - - /* Erase a sector */ - lut_base = SEQID_SE * 4; -#ifdef CONFIG_SPI_FLASH_BAR - qspi_write32(priv->flags, ®s->lut[lut_base], OPRND0(QSPI_CMD_SE) | - PAD0(LUT_PAD1) | INSTR0(LUT_CMD) | OPRND1(ADDR24BIT) | - PAD1(LUT_PAD1) | INSTR1(LUT_ADDR)); -#else - if (FSL_QSPI_FLASH_SIZE <= SZ_16M) - qspi_write32(priv->flags, ®s->lut[lut_base], - OPRND0(QSPI_CMD_SE) | PAD0(LUT_PAD1) | - INSTR0(LUT_CMD) | OPRND1(ADDR24BIT) | - PAD1(LUT_PAD1) | INSTR1(LUT_ADDR)); - else - qspi_write32(priv->flags, ®s->lut[lut_base], - OPRND0(QSPI_CMD_SE_4B) | PAD0(LUT_PAD1) | - INSTR0(LUT_CMD) | OPRND1(ADDR32BIT) | - PAD1(LUT_PAD1) | INSTR1(LUT_ADDR)); -#endif - qspi_write32(priv->flags, ®s->lut[lut_base + 1], 0); - qspi_write32(priv->flags, ®s->lut[lut_base + 2], 0); - qspi_write32(priv->flags, ®s->lut[lut_base + 3], 0); - - /* Erase the whole chip */ - lut_base = SEQID_CHIP_ERASE * 4; - qspi_write32(priv->flags, ®s->lut[lut_base], - OPRND0(QSPI_CMD_CHIP_ERASE) | - PAD0(LUT_PAD1) | INSTR0(LUT_CMD)); - qspi_write32(priv->flags, ®s->lut[lut_base + 1], 0); - qspi_write32(priv->flags, ®s->lut[lut_base + 2], 0); - qspi_write32(priv->flags, ®s->lut[lut_base + 3], 0); - - /* Page Program */ - lut_base = SEQID_PP * 4; -#ifdef CONFIG_SPI_FLASH_BAR - qspi_write32(priv->flags, ®s->lut[lut_base], OPRND0(QSPI_CMD_PP) | - PAD0(LUT_PAD1) | INSTR0(LUT_CMD) | OPRND1(ADDR24BIT) | - PAD1(LUT_PAD1) | INSTR1(LUT_ADDR)); -#else - if (FSL_QSPI_FLASH_SIZE <= SZ_16M) - qspi_write32(priv->flags, ®s->lut[lut_base], - OPRND0(QSPI_CMD_PP) | PAD0(LUT_PAD1) | - INSTR0(LUT_CMD) | OPRND1(ADDR24BIT) | - PAD1(LUT_PAD1) | INSTR1(LUT_ADDR)); - else - qspi_write32(priv->flags, ®s->lut[lut_base], - OPRND0(QSPI_CMD_PP_4B) | PAD0(LUT_PAD1) | - INSTR0(LUT_CMD) | OPRND1(ADDR32BIT) | - PAD1(LUT_PAD1) | INSTR1(LUT_ADDR)); -#endif - /* Use IDATSZ in IPCR to determine the size and here set 0. */ - qspi_write32(priv->flags, ®s->lut[lut_base + 1], OPRND0(0) | - PAD0(LUT_PAD1) | INSTR0(LUT_WRITE)); - qspi_write32(priv->flags, ®s->lut[lut_base + 2], 0); - qspi_write32(priv->flags, ®s->lut[lut_base + 3], 0); - - /* READ ID */ - lut_base = SEQID_RDID * 4; - qspi_write32(priv->flags, ®s->lut[lut_base], OPRND0(QSPI_CMD_RDID) | - PAD0(LUT_PAD1) | INSTR0(LUT_CMD) | OPRND1(8) | - PAD1(LUT_PAD1) | INSTR1(LUT_READ)); - qspi_write32(priv->flags, ®s->lut[lut_base + 1], 0); - qspi_write32(priv->flags, ®s->lut[lut_base + 2], 0); - qspi_write32(priv->flags, ®s->lut[lut_base + 3], 0); - - /* SUB SECTOR 4K ERASE */ - lut_base = SEQID_BE_4K * 4; - qspi_write32(priv->flags, ®s->lut[lut_base], OPRND0(QSPI_CMD_BE_4K) | - PAD0(LUT_PAD1) | INSTR0(LUT_CMD) | OPRND1(ADDR24BIT) | - PAD1(LUT_PAD1) | INSTR1(LUT_ADDR)); - -#ifdef CONFIG_SPI_FLASH_BAR - /* - * BRRD BRWR RDEAR WREAR are all supported, because it is hard to - * dynamically check whether to set BRRD BRWR or RDEAR WREAR during - * initialization. - */ - lut_base = SEQID_BRRD * 4; - qspi_write32(priv->flags, ®s->lut[lut_base], OPRND0(QSPI_CMD_BRRD) | - PAD0(LUT_PAD1) | INSTR0(LUT_CMD) | OPRND1(1) | - PAD1(LUT_PAD1) | INSTR1(LUT_READ)); - - lut_base = SEQID_BRWR * 4; - qspi_write32(priv->flags, ®s->lut[lut_base], OPRND0(QSPI_CMD_BRWR) | - PAD0(LUT_PAD1) | INSTR0(LUT_CMD) | OPRND1(1) | - PAD1(LUT_PAD1) | INSTR1(LUT_WRITE)); - - lut_base = SEQID_RDEAR * 4; - qspi_write32(priv->flags, ®s->lut[lut_base], OPRND0(QSPI_CMD_RDEAR) | - PAD0(LUT_PAD1) | INSTR0(LUT_CMD) | OPRND1(1) | - PAD1(LUT_PAD1) | INSTR1(LUT_READ)); - - lut_base = SEQID_WREAR * 4; - qspi_write32(priv->flags, ®s->lut[lut_base], OPRND0(QSPI_CMD_WREAR) | - PAD0(LUT_PAD1) | INSTR0(LUT_CMD) | OPRND1(1) | - PAD1(LUT_PAD1) | INSTR1(LUT_WRITE)); -#endif - - /* - * Read any device register. - * Used for Spansion S25FS-S family flash only. - */ - lut_base = SEQID_RDAR * 4; - qspi_write32(priv->flags, ®s->lut[lut_base], - OPRND0(QSPI_CMD_RDAR) | PAD0(LUT_PAD1) | - INSTR0(LUT_CMD) | OPRND1(ADDR24BIT) | - PAD1(LUT_PAD1) | INSTR1(LUT_ADDR)); - qspi_write32(priv->flags, ®s->lut[lut_base + 1], - OPRND0(8) | PAD0(LUT_PAD1) | INSTR0(LUT_DUMMY) | - OPRND1(1) | PAD1(LUT_PAD1) | - INSTR1(LUT_READ)); + return !(q->devtype_data->quirks & QUADSPI_QUIRK_BASE_INTERNAL); +}
- /* - * Write any device register. - * Used for Spansion S25FS-S family flash only. - */ - lut_base = SEQID_WRAR * 4; - qspi_write32(priv->flags, ®s->lut[lut_base], - OPRND0(QSPI_CMD_WRAR) | PAD0(LUT_PAD1) | - INSTR0(LUT_CMD) | OPRND1(ADDR24BIT) | - PAD1(LUT_PAD1) | INSTR1(LUT_ADDR)); - qspi_write32(priv->flags, ®s->lut[lut_base + 1], - OPRND0(1) | PAD0(LUT_PAD1) | INSTR0(LUT_WRITE)); - - /* Lock the LUT */ - qspi_write32(priv->flags, ®s->lutkey, LUT_KEY_VALUE); - qspi_write32(priv->flags, ®s->lckcr, QSPI_LCKCR_LOCK); +static inline int needs_tdh_setting(struct fsl_qspi *q) +{ + return q->devtype_data->quirks & QUADSPI_QUIRK_USE_TDH_SETTING; }
-#if defined(CONFIG_SYS_FSL_QSPI_AHB) /* - * If we have changed the content of the flash by writing or erasing, - * we need to invalidate the AHB buffer. If we do not do so, we may read out - * the wrong data. The spec tells us reset the AHB domain and Serial Flash - * domain at the same time. + * An IC bug makes it necessary to rearrange the 32-bit data. + * Later chips, such as IMX6SLX, have fixed this bug. */ -static inline void qspi_ahb_invalid(struct fsl_qspi_priv *priv) +static inline u32 fsl_qspi_endian_xchg(struct fsl_qspi *q, u32 a) { - struct fsl_qspi_regs *regs = priv->regs; - u32 reg; - - reg = qspi_read32(priv->flags, ®s->mcr); - reg |= QSPI_MCR_SWRSTHD_MASK | QSPI_MCR_SWRSTSD_MASK; - qspi_write32(priv->flags, ®s->mcr, reg); - - /* - * The minimum delay : 1 AHB + 2 SFCK clocks. - * Delay 1 us is enough. - */ - udelay(1); - - reg &= ~(QSPI_MCR_SWRSTHD_MASK | QSPI_MCR_SWRSTSD_MASK); - qspi_write32(priv->flags, ®s->mcr, reg); + return needs_swap_endian(q) ? __swab32(a) : a; }
-/* Read out the data from the AHB buffer. */ -static inline void qspi_ahb_read(struct fsl_qspi_priv *priv, u8 *rxbuf, int len) +/* + * R/W functions for big- or little-endian registers: + * The QSPI controller's endianness is independent of + * the CPU core's endianness. So far, although the CPU + * core is little-endian the QSPI controller can use + * big-endian or little-endian. + */ +static void qspi_writel(struct fsl_qspi *q, u32 val, void __iomem *addr) { - struct fsl_qspi_regs *regs = priv->regs; - u32 mcr_reg; - void *rx_addr; - - mcr_reg = qspi_read32(priv->flags, ®s->mcr); - - qspi_write32(priv->flags, ®s->mcr, - QSPI_MCR_CLR_RXF_MASK | QSPI_MCR_CLR_TXF_MASK | - mcr_reg); + if (q->devtype_data->little_endian) + out_le32(addr, val); + else + out_be32(addr, val); +}
- rx_addr = (void *)(uintptr_t)(priv->cur_amba_base + priv->sf_addr); - /* Read out the data directly from the AHB buffer. */ - memcpy(rxbuf, rx_addr, len); +static u32 qspi_readl(struct fsl_qspi *q, void __iomem *addr) +{ + if (q->devtype_data->little_endian) + return in_le32(addr);
- qspi_write32(priv->flags, ®s->mcr, mcr_reg); + return in_be32(addr); }
-static void qspi_enable_ddr_mode(struct fsl_qspi_priv *priv) +static int fsl_qspi_check_buswidth(struct fsl_qspi *q, u8 width) { - u32 reg, reg2; - struct fsl_qspi_regs *regs = priv->regs; + switch (width) { + case 1: + case 2: + case 4: + return 0; + }
- reg = qspi_read32(priv->flags, ®s->mcr); - /* Disable the module */ - qspi_write32(priv->flags, ®s->mcr, reg | QSPI_MCR_MDIS_MASK); - - /* Set the Sampling Register for DDR */ - reg2 = qspi_read32(priv->flags, ®s->smpr); - reg2 &= ~QSPI_SMPR_DDRSMP_MASK; - reg2 |= (2 << QSPI_SMPR_DDRSMP_SHIFT); - qspi_write32(priv->flags, ®s->smpr, reg2); - - /* Enable the module again (enable the DDR too) */ - reg |= QSPI_MCR_DDR_EN_MASK; - /* Enable bit 29 for imx6sx */ - reg |= BIT(29); - qspi_write32(priv->flags, ®s->mcr, reg); - - /* Enable the TDH to 1 for some platforms like imx6ul, imx7d, etc - * These two bits are reserved on other platforms - */ - reg = qspi_read32(priv->flags, ®s->flshcr); - reg &= ~(BIT(17)); - reg |= BIT(16); - qspi_write32(priv->flags, ®s->flshcr, reg); + return -ENOTSUPP; }
-/* - * There are two different ways to read out the data from the flash: - * the "IP Command Read" and the "AHB Command Read". - * - * The IC guy suggests we use the "AHB Command Read" which is faster - * then the "IP Command Read". (What's more is that there is a bug in - * the "IP Command Read" in the Vybrid.) - * - * After we set up the registers for the "AHB Command Read", we can use - * the memcpy to read the data directly. A "missed" access to the buffer - * causes the controller to clear the buffer, and use the sequence pointed - * by the QUADSPI_BFGENCR[SEQID] to initiate a read from the flash. - */ -static void qspi_init_ahb_read(struct fsl_qspi_priv *priv) +static bool fsl_qspi_supports_op(struct spi_slave *slave, + const struct spi_mem_op *op) { - struct fsl_qspi_regs *regs = priv->regs; + struct fsl_qspi *q = dev_get_priv(slave->dev->parent); + int ret; + + ret = fsl_qspi_check_buswidth(q, op->cmd.buswidth); + + if (op->addr.nbytes) + ret |= fsl_qspi_check_buswidth(q, op->addr.buswidth); + + if (op->dummy.nbytes) + ret |= fsl_qspi_check_buswidth(q, op->dummy.buswidth);
- /* AHB configuration for access buffer 0/1/2 .*/ - qspi_write32(priv->flags, ®s->buf0cr, QSPI_BUFXCR_INVALID_MSTRID); - qspi_write32(priv->flags, ®s->buf1cr, QSPI_BUFXCR_INVALID_MSTRID); - qspi_write32(priv->flags, ®s->buf2cr, QSPI_BUFXCR_INVALID_MSTRID); - qspi_write32(priv->flags, ®s->buf3cr, QSPI_BUF3CR_ALLMST_MASK | - ((priv->devtype_data->ahb_buf_size >> 3) << QSPI_BUF3CR_ADATSZ_SHIFT)); + if (op->data.nbytes) + ret |= fsl_qspi_check_buswidth(q, op->data.buswidth);
- /* We only use the buffer3 */ - qspi_write32(priv->flags, ®s->buf0ind, 0); - qspi_write32(priv->flags, ®s->buf1ind, 0); - qspi_write32(priv->flags, ®s->buf2ind, 0); + if (ret) + return false;
/* - * Set the default lut sequence for AHB Read. - * Parallel mode is disabled. + * The number of instructions needed for the op, needs + * to fit into a single LUT entry. */ - qspi_write32(priv->flags, ®s->bfgencr, - SEQID_FAST_READ << QSPI_BFGENCR_SEQID_SHIFT); - - /*Enable DDR Mode*/ - qspi_enable_ddr_mode(priv); + if (op->addr.nbytes + + (op->dummy.nbytes ? 1 : 0) + + (op->data.nbytes ? 1 : 0) > 6) + return false; + + /* Max 64 dummy clock cycles supported */ + if (op->dummy.nbytes && + (op->dummy.nbytes * 8 / op->dummy.buswidth > 64)) + return false; + + /* Max data length, check controller limits and alignment */ + if (op->data.dir == SPI_MEM_DATA_IN && + (op->data.nbytes > q->devtype_data->ahb_buf_size || + (op->data.nbytes > q->devtype_data->rxfifo - 4 && + !IS_ALIGNED(op->data.nbytes, 8)))) + return false; + + if (op->data.dir == SPI_MEM_DATA_OUT && + op->data.nbytes > q->devtype_data->txfifo) + return false; + + return true; } -#endif
-#ifdef CONFIG_SPI_FLASH_BAR -/* Bank register read/write, EAR register read/write */ -static void qspi_op_rdbank(struct fsl_qspi_priv *priv, u8 *rxbuf, u32 len) +static void fsl_qspi_prepare_lut(struct fsl_qspi *q, + const struct spi_mem_op *op) { - struct fsl_qspi_regs *regs = priv->regs; - u32 reg, mcr_reg, data, seqid; + void __iomem *base = q->iobase; + u32 lutval[4] = {}; + int lutidx = 1, i;
- mcr_reg = qspi_read32(priv->flags, ®s->mcr); - qspi_write32(priv->flags, ®s->mcr, - QSPI_MCR_CLR_RXF_MASK | QSPI_MCR_CLR_TXF_MASK | - mcr_reg); - qspi_write32(priv->flags, ®s->rbct, QSPI_RBCT_RXBRD_USEIPS); + lutval[0] |= LUT_DEF(0, LUT_CMD, LUT_PAD(op->cmd.buswidth), + op->cmd.opcode);
- qspi_write32(priv->flags, ®s->sfar, priv->cur_amba_base); + /* + * For some unknown reason, using LUT_ADDR doesn't work in some + * cases (at least with only one byte long addresses), so + * let's use LUT_MODE to write the address bytes one by one + */ + for (i = 0; i < op->addr.nbytes; i++) { + u8 addrbyte = op->addr.val >> (8 * (op->addr.nbytes - i - 1));
- if (priv->cur_seqid == QSPI_CMD_BRRD) - seqid = SEQID_BRRD; - else - seqid = SEQID_RDEAR; - - qspi_write32(priv->flags, ®s->ipcr, - (seqid << QSPI_IPCR_SEQID_SHIFT) | len); - - /* Wait previous command complete */ - while (qspi_read32(priv->flags, ®s->sr) & QSPI_SR_BUSY_MASK) - ; - - while (1) { - WATCHDOG_RESET(); - - reg = qspi_read32(priv->flags, ®s->rbsr); - if (reg & QSPI_RBSR_RDBFL_MASK) { - data = qspi_read32(priv->flags, ®s->rbdr[0]); - data = qspi_endian_xchg(priv, data); - memcpy(rxbuf, &data, len); - qspi_write32(priv->flags, ®s->mcr, - qspi_read32(priv->flags, ®s->mcr) | - QSPI_MCR_CLR_RXF_MASK); - break; - } + lutval[lutidx / 2] |= LUT_DEF(lutidx, LUT_MODE, + LUT_PAD(op->addr.buswidth), + addrbyte); + lutidx++; }
- qspi_write32(priv->flags, ®s->mcr, mcr_reg); -} -#endif - -static void qspi_op_rdid(struct fsl_qspi_priv *priv, u32 *rxbuf, u32 len) -{ - struct fsl_qspi_regs *regs = priv->regs; - u32 mcr_reg, rbsr_reg, data, size; - int i; - - mcr_reg = qspi_read32(priv->flags, ®s->mcr); - qspi_write32(priv->flags, ®s->mcr, - QSPI_MCR_CLR_RXF_MASK | QSPI_MCR_CLR_TXF_MASK | - mcr_reg); - qspi_write32(priv->flags, ®s->rbct, QSPI_RBCT_RXBRD_USEIPS); - - qspi_write32(priv->flags, ®s->sfar, priv->cur_amba_base); - - qspi_write32(priv->flags, ®s->ipcr, - (SEQID_RDID << QSPI_IPCR_SEQID_SHIFT) | 0); - while (qspi_read32(priv->flags, ®s->sr) & QSPI_SR_BUSY_MASK) - ; - - i = 0; - while ((priv->devtype_data->rxfifo >= len) && (len > 0)) { - WATCHDOG_RESET(); - - rbsr_reg = qspi_read32(priv->flags, ®s->rbsr); - if (rbsr_reg & QSPI_RBSR_RDBFL_MASK) { - data = qspi_read32(priv->flags, ®s->rbdr[i]); - data = qspi_endian_xchg(priv, data); - size = (len < 4) ? len : 4; - memcpy(rxbuf, &data, size); - len -= size; - rxbuf++; - i++; - } + if (op->dummy.nbytes) { + lutval[lutidx / 2] |= LUT_DEF(lutidx, LUT_DUMMY, + LUT_PAD(op->dummy.buswidth), + op->dummy.nbytes * 8 / + op->dummy.buswidth); + lutidx++; }
- qspi_write32(priv->flags, ®s->mcr, mcr_reg); -} - -/* If not use AHB read, read data from ip interface */ -static void qspi_op_read(struct fsl_qspi_priv *priv, u32 *rxbuf, u32 len) -{ - struct fsl_qspi_regs *regs = priv->regs; - u32 mcr_reg, data; - int i, size; - u32 to_or_from; - u32 seqid; - - if (priv->cur_seqid == QSPI_CMD_RDAR) - seqid = SEQID_RDAR; - else - seqid = SEQID_FAST_READ; - - mcr_reg = qspi_read32(priv->flags, ®s->mcr); - qspi_write32(priv->flags, ®s->mcr, - QSPI_MCR_CLR_RXF_MASK | QSPI_MCR_CLR_TXF_MASK | - mcr_reg); - qspi_write32(priv->flags, ®s->rbct, QSPI_RBCT_RXBRD_USEIPS); - - to_or_from = priv->sf_addr + priv->cur_amba_base; - - while (len > 0) { - WATCHDOG_RESET(); - - qspi_write32(priv->flags, ®s->sfar, to_or_from); - - size = (len > priv->devtype_data->rxfifo) ? - priv->devtype_data->rxfifo : len; - - qspi_write32(priv->flags, ®s->ipcr, - (seqid << QSPI_IPCR_SEQID_SHIFT) | - size); - while (qspi_read32(priv->flags, ®s->sr) & QSPI_SR_BUSY_MASK) - ; - - to_or_from += size; - len -= size; - - i = 0; - while ((priv->devtype_data->rxfifo >= size) && (size > 0)) { - data = qspi_read32(priv->flags, ®s->rbdr[i]); - data = qspi_endian_xchg(priv, data); - if (size < 4) - memcpy(rxbuf, &data, size); - else - memcpy(rxbuf, &data, 4); - rxbuf++; - size -= 4; - i++; - } - qspi_write32(priv->flags, ®s->mcr, - qspi_read32(priv->flags, ®s->mcr) | - QSPI_MCR_CLR_RXF_MASK); + if (op->data.nbytes) { + lutval[lutidx / 2] |= LUT_DEF(lutidx, + op->data.dir == SPI_MEM_DATA_IN ? + LUT_FSL_READ : LUT_FSL_WRITE, + LUT_PAD(op->data.buswidth), + 0); + lutidx++; }
- qspi_write32(priv->flags, ®s->mcr, mcr_reg); -} + lutval[lutidx / 2] |= LUT_DEF(lutidx, LUT_STOP, 0, 0);
-static void qspi_op_write(struct fsl_qspi_priv *priv, u8 *txbuf, u32 len) -{ - struct fsl_qspi_regs *regs = priv->regs; - u32 mcr_reg, data, reg, status_reg, seqid; - int i, size, tx_size; - u32 to_or_from = 0; - - mcr_reg = qspi_read32(priv->flags, ®s->mcr); - qspi_write32(priv->flags, ®s->mcr, - QSPI_MCR_CLR_RXF_MASK | QSPI_MCR_CLR_TXF_MASK | - mcr_reg); - qspi_write32(priv->flags, ®s->rbct, QSPI_RBCT_RXBRD_USEIPS); - - status_reg = 0; - while ((status_reg & FLASH_STATUS_WEL) != FLASH_STATUS_WEL) { - WATCHDOG_RESET(); - - qspi_write32(priv->flags, ®s->ipcr, - (SEQID_WREN << QSPI_IPCR_SEQID_SHIFT) | 0); - while (qspi_read32(priv->flags, ®s->sr) & QSPI_SR_BUSY_MASK) - ; - - qspi_write32(priv->flags, ®s->ipcr, - (SEQID_RDSR << QSPI_IPCR_SEQID_SHIFT) | 1); - while (qspi_read32(priv->flags, ®s->sr) & QSPI_SR_BUSY_MASK) - ; - - reg = qspi_read32(priv->flags, ®s->rbsr); - if (reg & QSPI_RBSR_RDBFL_MASK) { - status_reg = qspi_read32(priv->flags, ®s->rbdr[0]); - status_reg = qspi_endian_xchg(priv, status_reg); - } - qspi_write32(priv->flags, ®s->mcr, - qspi_read32(priv->flags, ®s->mcr) | - QSPI_MCR_CLR_RXF_MASK); - } + /* unlock LUT */ + qspi_writel(q, QUADSPI_LUTKEY_VALUE, q->iobase + QUADSPI_LUTKEY); + qspi_writel(q, QUADSPI_LCKER_UNLOCK, q->iobase + QUADSPI_LCKCR); + + dev_dbg(q->dev, "CMD[%x] lutval[0:%x \t 1:%x \t 2:%x \t 3:%x]\n", + op->cmd.opcode, lutval[0], lutval[1], lutval[2], lutval[3]);
- /* Default is page programming */ - seqid = SEQID_PP; - if (priv->cur_seqid == QSPI_CMD_WRAR) - seqid = SEQID_WRAR; -#ifdef CONFIG_SPI_FLASH_BAR - if (priv->cur_seqid == QSPI_CMD_BRWR) - seqid = SEQID_BRWR; - else if (priv->cur_seqid == QSPI_CMD_WREAR) - seqid = SEQID_WREAR; -#endif + /* fill LUT */ + for (i = 0; i < ARRAY_SIZE(lutval); i++) + qspi_writel(q, lutval[i], base + QUADSPI_LUT_REG(i));
- to_or_from = priv->sf_addr + priv->cur_amba_base; + /* lock LUT */ + qspi_writel(q, QUADSPI_LUTKEY_VALUE, q->iobase + QUADSPI_LUTKEY); + qspi_writel(q, QUADSPI_LCKER_LOCK, q->iobase + QUADSPI_LCKCR); +}
- qspi_write32(priv->flags, ®s->sfar, to_or_from); +/* + * If we have changed the content of the flash by writing or erasing, or if we + * read from flash with a different offset into the page buffer, we need to + * invalidate the AHB buffer. If we do not do so, we may read out the wrong + * data. The spec tells us reset the AHB domain and Serial Flash domain at + * the same time. + */ +static void fsl_qspi_invalidate(struct fsl_qspi *q) +{ + u32 reg;
- tx_size = (len > priv->devtype_data->txfifo) ? - priv->devtype_data->txfifo : len; + reg = qspi_readl(q, q->iobase + QUADSPI_MCR); + reg |= QUADSPI_MCR_SWRSTHD_MASK | QUADSPI_MCR_SWRSTSD_MASK; + qspi_writel(q, reg, q->iobase + QUADSPI_MCR);
- size = tx_size / 16; /* - * There must be atleast 128bit data - * available in TX FIFO for any pop operation + * The minimum delay : 1 AHB + 2 SFCK clocks. + * Delay 1 us is enough. */ - if (tx_size % 16) - size++; - for (i = 0; i < size * 4; i++) { - memcpy(&data, txbuf, 4); - data = qspi_endian_xchg(priv, data); - qspi_write32(priv->flags, ®s->tbdr, data); - txbuf += 4; - } - - qspi_write32(priv->flags, ®s->ipcr, - (seqid << QSPI_IPCR_SEQID_SHIFT) | tx_size); - while (qspi_read32(priv->flags, ®s->sr) & QSPI_SR_BUSY_MASK) - ; + udelay(1);
- qspi_write32(priv->flags, ®s->mcr, mcr_reg); + reg &= ~(QUADSPI_MCR_SWRSTHD_MASK | QUADSPI_MCR_SWRSTSD_MASK); + qspi_writel(q, reg, q->iobase + QUADSPI_MCR); }
-static void qspi_op_rdsr(struct fsl_qspi_priv *priv, void *rxbuf, u32 len) +static void fsl_qspi_select_mem(struct fsl_qspi *q, struct spi_slave *slave) { - struct fsl_qspi_regs *regs = priv->regs; - u32 mcr_reg, reg, data; - - mcr_reg = qspi_read32(priv->flags, ®s->mcr); - qspi_write32(priv->flags, ®s->mcr, - QSPI_MCR_CLR_RXF_MASK | QSPI_MCR_CLR_TXF_MASK | - mcr_reg); - qspi_write32(priv->flags, ®s->rbct, QSPI_RBCT_RXBRD_USEIPS); - - qspi_write32(priv->flags, ®s->sfar, priv->cur_amba_base); - - qspi_write32(priv->flags, ®s->ipcr, - (SEQID_RDSR << QSPI_IPCR_SEQID_SHIFT) | 0); - while (qspi_read32(priv->flags, ®s->sr) & QSPI_SR_BUSY_MASK) - ; - - while (1) { - WATCHDOG_RESET(); - - reg = qspi_read32(priv->flags, ®s->rbsr); - if (reg & QSPI_RBSR_RDBFL_MASK) { - data = qspi_read32(priv->flags, ®s->rbdr[0]); - data = qspi_endian_xchg(priv, data); - memcpy(rxbuf, &data, len); - qspi_write32(priv->flags, ®s->mcr, - qspi_read32(priv->flags, ®s->mcr) | - QSPI_MCR_CLR_RXF_MASK); - break; - } - } + struct dm_spi_slave_platdata *plat = + dev_get_parent_platdata(slave->dev); + + if (q->selected == plat->cs) + return;
- qspi_write32(priv->flags, ®s->mcr, mcr_reg); + q->selected = plat->cs; + fsl_qspi_invalidate(q); }
-static void qspi_op_erase(struct fsl_qspi_priv *priv) +static void fsl_qspi_read_ahb(struct fsl_qspi *q, const struct spi_mem_op *op) { - struct fsl_qspi_regs *regs = priv->regs; - u32 mcr_reg; - u32 to_or_from = 0; - - mcr_reg = qspi_read32(priv->flags, ®s->mcr); - qspi_write32(priv->flags, ®s->mcr, - QSPI_MCR_CLR_RXF_MASK | QSPI_MCR_CLR_TXF_MASK | - mcr_reg); - qspi_write32(priv->flags, ®s->rbct, QSPI_RBCT_RXBRD_USEIPS); - - to_or_from = priv->sf_addr + priv->cur_amba_base; - qspi_write32(priv->flags, ®s->sfar, to_or_from); - - qspi_write32(priv->flags, ®s->ipcr, - (SEQID_WREN << QSPI_IPCR_SEQID_SHIFT) | 0); - while (qspi_read32(priv->flags, ®s->sr) & QSPI_SR_BUSY_MASK) - ; - - if (priv->cur_seqid == QSPI_CMD_SE) { - qspi_write32(priv->flags, ®s->ipcr, - (SEQID_SE << QSPI_IPCR_SEQID_SHIFT) | 0); - } else if (priv->cur_seqid == QSPI_CMD_BE_4K) { - qspi_write32(priv->flags, ®s->ipcr, - (SEQID_BE_4K << QSPI_IPCR_SEQID_SHIFT) | 0); - } - while (qspi_read32(priv->flags, ®s->sr) & QSPI_SR_BUSY_MASK) - ; - - qspi_write32(priv->flags, ®s->mcr, mcr_reg); + memcpy_fromio(op->data.buf.in, + q->ahb_addr + q->selected * q->devtype_data->ahb_buf_size, + op->data.nbytes); }
-int qspi_xfer(struct fsl_qspi_priv *priv, unsigned int bitlen, - const void *dout, void *din, unsigned long flags) +static void fsl_qspi_fill_txfifo(struct fsl_qspi *q, + const struct spi_mem_op *op) { - u32 bytes = DIV_ROUND_UP(bitlen, 8); - static u32 wr_sfaddr; - u32 txbuf; - - WATCHDOG_RESET(); - - if (dout) { - if (flags & SPI_XFER_BEGIN) { - priv->cur_seqid = *(u8 *)dout; - memcpy(&txbuf, dout, 4); - } - - if (flags == SPI_XFER_END) { - priv->sf_addr = wr_sfaddr; - qspi_op_write(priv, (u8 *)dout, bytes); - return 0; - } - - if (priv->cur_seqid == QSPI_CMD_FAST_READ || - priv->cur_seqid == QSPI_CMD_RDAR) { - priv->sf_addr = swab32(txbuf) & OFFSET_BITS_MASK; - } else if ((priv->cur_seqid == QSPI_CMD_SE) || - (priv->cur_seqid == QSPI_CMD_BE_4K)) { - priv->sf_addr = swab32(txbuf) & OFFSET_BITS_MASK; - qspi_op_erase(priv); - } else if (priv->cur_seqid == QSPI_CMD_PP || - priv->cur_seqid == QSPI_CMD_WRAR) { - wr_sfaddr = swab32(txbuf) & OFFSET_BITS_MASK; - } else if ((priv->cur_seqid == QSPI_CMD_BRWR) || - (priv->cur_seqid == QSPI_CMD_WREAR)) { -#ifdef CONFIG_SPI_FLASH_BAR - wr_sfaddr = 0; -#endif - } - } + void __iomem *base = q->iobase; + int i; + u32 val;
- if (din) { - if (priv->cur_seqid == QSPI_CMD_FAST_READ) { -#ifdef CONFIG_SYS_FSL_QSPI_AHB - qspi_ahb_read(priv, din, bytes); -#else - qspi_op_read(priv, din, bytes); -#endif - } else if (priv->cur_seqid == QSPI_CMD_RDAR) { - qspi_op_read(priv, din, bytes); - } else if (priv->cur_seqid == QSPI_CMD_RDID) - qspi_op_rdid(priv, din, bytes); - else if (priv->cur_seqid == QSPI_CMD_RDSR) - qspi_op_rdsr(priv, din, bytes); -#ifdef CONFIG_SPI_FLASH_BAR - else if ((priv->cur_seqid == QSPI_CMD_BRRD) || - (priv->cur_seqid == QSPI_CMD_RDEAR)) { - priv->sf_addr = 0; - qspi_op_rdbank(priv, din, bytes); - } -#endif + for (i = 0; i < ALIGN_DOWN(op->data.nbytes, 4); i += 4) { + memcpy(&val, op->data.buf.out + i, 4); + val = fsl_qspi_endian_xchg(q, val); + qspi_writel(q, val, base + QUADSPI_TBDR); }
-#ifdef CONFIG_SYS_FSL_QSPI_AHB - if ((priv->cur_seqid == QSPI_CMD_SE) || - (priv->cur_seqid == QSPI_CMD_PP) || - (priv->cur_seqid == QSPI_CMD_BE_4K) || - (priv->cur_seqid == QSPI_CMD_WREAR) || - (priv->cur_seqid == QSPI_CMD_BRWR)) - qspi_ahb_invalid(priv); -#endif + if (i < op->data.nbytes) { + memcpy(&val, op->data.buf.out + i, op->data.nbytes - i); + val = fsl_qspi_endian_xchg(q, val); + qspi_writel(q, val, base + QUADSPI_TBDR); + }
- return 0; + if (needs_fill_txfifo(q)) { + for (i = op->data.nbytes; i < 16; i += 4) + qspi_writel(q, 0, base + QUADSPI_TBDR); + } }
-void qspi_module_disable(struct fsl_qspi_priv *priv, u8 disable) +static void fsl_qspi_read_rxfifo(struct fsl_qspi *q, + const struct spi_mem_op *op) { - u32 mcr_val; + void __iomem *base = q->iobase; + int i; + u8 *buf = op->data.buf.in; + u32 val;
- mcr_val = qspi_read32(priv->flags, &priv->regs->mcr); - if (disable) - mcr_val |= QSPI_MCR_MDIS_MASK; - else - mcr_val &= ~QSPI_MCR_MDIS_MASK; - qspi_write32(priv->flags, &priv->regs->mcr, mcr_val); + for (i = 0; i < ALIGN_DOWN(op->data.nbytes, 4); i += 4) { + val = qspi_readl(q, base + QUADSPI_RBDR(i / 4)); + val = fsl_qspi_endian_xchg(q, val); + memcpy(buf + i, &val, 4); + } + + if (i < op->data.nbytes) { + val = qspi_readl(q, base + QUADSPI_RBDR(i / 4)); + val = fsl_qspi_endian_xchg(q, val); + memcpy(buf + i, &val, op->data.nbytes - i); + } }
-void qspi_cfg_smpr(struct fsl_qspi_priv *priv, u32 clear_bits, u32 set_bits) +static int fsl_qspi_readl_poll_tout(struct fsl_qspi *q, void __iomem *base, + u32 mask, u32 delay_us, u32 timeout_us) { - u32 smpr_val; + u32 reg;
- smpr_val = qspi_read32(priv->flags, &priv->regs->smpr); - smpr_val &= ~clear_bits; - smpr_val |= set_bits; - qspi_write32(priv->flags, &priv->regs->smpr, smpr_val); + if (!q->devtype_data->little_endian) + mask = (u32)cpu_to_be32(mask); + + return readl_poll_timeout(base, reg, !(reg & mask), timeout_us); }
-static int fsl_qspi_child_pre_probe(struct udevice *dev) +static int fsl_qspi_do_op(struct fsl_qspi *q, const struct spi_mem_op *op) { - struct spi_slave *slave = dev_get_parent_priv(dev); - struct fsl_qspi_priv *priv = dev_get_priv(dev_get_parent(dev)); + void __iomem *base = q->iobase; + int err = 0;
- slave->max_write_size = priv->devtype_data->txfifo; + /* + * Always start the sequence at the same index since we update + * the LUT at each exec_op() call. And also specify the DATA + * length, since it's has not been specified in the LUT. + */ + qspi_writel(q, op->data.nbytes | QUADSPI_IPCR_SEQID(SEQID_LUT), + base + QUADSPI_IPCR);
- return 0; + /* wait for the controller being ready */ + err = fsl_qspi_readl_poll_tout(q, base + QUADSPI_SR, + (QUADSPI_SR_IP_ACC_MASK | + QUADSPI_SR_AHB_ACC_MASK), + 10, 1000); + + if (!err && op->data.nbytes && op->data.dir == SPI_MEM_DATA_IN) + fsl_qspi_read_rxfifo(q, op); + + return err; }
-static int fsl_qspi_probe(struct udevice *bus) +static int fsl_qspi_exec_op(struct spi_slave *slave, + const struct spi_mem_op *op) { - u32 amba_size_per_chip; - struct fsl_qspi_platdata *plat = dev_get_platdata(bus); - struct fsl_qspi_priv *priv = dev_get_priv(bus); - struct dm_spi_bus *dm_spi_bus; - int i, ret; + struct fsl_qspi *q = dev_get_priv(slave->dev->parent); + void __iomem *base = q->iobase; + u32 addr_offset = 0; + int err = 0;
- dm_spi_bus = bus->uclass_priv; + /* wait for the controller being ready */ + fsl_qspi_readl_poll_tout(q, base + QUADSPI_SR, (QUADSPI_SR_IP_ACC_MASK | + QUADSPI_SR_AHB_ACC_MASK), 10, 1000);
- dm_spi_bus->max_hz = plat->speed_hz; + fsl_qspi_select_mem(q, slave);
- priv->regs = (struct fsl_qspi_regs *)(uintptr_t)plat->reg_base; - priv->flags = plat->flags; + if (needs_amba_base_offset(q)) + addr_offset = q->memmap_phy; + + qspi_writel(q, + q->selected * q->devtype_data->ahb_buf_size + addr_offset, + base + QUADSPI_SFAR); + + qspi_writel(q, qspi_readl(q, base + QUADSPI_MCR) | + QUADSPI_MCR_CLR_RXF_MASK | QUADSPI_MCR_CLR_TXF_MASK, + base + QUADSPI_MCR); + + qspi_writel(q, QUADSPI_SPTRCLR_BFPTRC | QUADSPI_SPTRCLR_IPPTRC, + base + QUADSPI_SPTRCLR); + + fsl_qspi_prepare_lut(q, op);
- priv->speed_hz = plat->speed_hz; /* - * QSPI SFADR width is 32bits, the max dest addr is 4GB-1. - * AMBA memory zone should be located on the 0~4GB space - * even on a 64bits cpu. + * If we have large chunks of data, we read them through the AHB bus + * by accessing the mapped memory. In all other cases we use + * IP commands to access the flash. */ - priv->amba_base[0] = (u32)plat->amba_base; - priv->amba_total_size = (u32)plat->amba_total_size; - priv->flash_num = plat->flash_num; - priv->num_chipselect = plat->num_chipselect; - - priv->devtype_data = (struct fsl_qspi_devtype_data *)dev_get_driver_data(bus); - if (!priv->devtype_data) { - printf("ERROR : No devtype_data found\n"); - return -ENODEV; + if (op->data.nbytes > (q->devtype_data->rxfifo - 4) && + op->data.dir == SPI_MEM_DATA_IN) { + fsl_qspi_read_ahb(q, op); + } else { + qspi_writel(q, QUADSPI_RBCT_WMRK_MASK | + QUADSPI_RBCT_RXBRD_USEIPS, base + QUADSPI_RBCT); + + if (op->data.nbytes && op->data.dir == SPI_MEM_DATA_OUT) + fsl_qspi_fill_txfifo(q, op); + + err = fsl_qspi_do_op(q, op); }
- debug("devtype=%d, txfifo=%d, rxfifo=%d, ahb=%d, data=0x%x\n", - priv->devtype_data->devtype, - priv->devtype_data->txfifo, - priv->devtype_data->rxfifo, - priv->devtype_data->ahb_buf_size, - priv->devtype_data->driver_data); + /* Invalidate the data in the AHB buffer. */ + fsl_qspi_invalidate(q);
- /* make sure controller is not busy anywhere */ - ret = is_controller_busy(priv); + return err; +}
- if (ret) { - debug("ERROR : The controller is busy\n"); - return ret; +static int fsl_qspi_adjust_op_size(struct spi_slave *slave, + struct spi_mem_op *op) +{ + struct fsl_qspi *q = dev_get_priv(slave->dev->parent); + + if (op->data.dir == SPI_MEM_DATA_OUT) { + if (op->data.nbytes > q->devtype_data->txfifo) + op->data.nbytes = q->devtype_data->txfifo; + } else { + if (op->data.nbytes > q->devtype_data->ahb_buf_size) + op->data.nbytes = q->devtype_data->ahb_buf_size; + else if (op->data.nbytes > (q->devtype_data->rxfifo - 4)) + op->data.nbytes = ALIGN_DOWN(op->data.nbytes, 8); }
- qspi_write32(priv->flags, &priv->regs->mcr, - QSPI_MCR_RESERVED_MASK | QSPI_MCR_MDIS_MASK | - QSPI_MCR_END_CFD_LE); + return 0; +} + +static int fsl_qspi_default_setup(struct fsl_qspi *q) +{ + void __iomem *base = q->iobase; + u32 reg, addr_offset = 0; + + /* Reset the module */ + qspi_writel(q, QUADSPI_MCR_SWRSTSD_MASK | QUADSPI_MCR_SWRSTHD_MASK, + base + QUADSPI_MCR); + udelay(1);
- qspi_cfg_smpr(priv, ~(QSPI_SMPR_FSDLY_MASK | QSPI_SMPR_DDRSMP_MASK | - QSPI_SMPR_FSPHS_MASK | QSPI_SMPR_HSENA_MASK), 0); + /* Disable the module */ + qspi_writel(q, QUADSPI_MCR_MDIS_MASK | QUADSPI_MCR_RESERVED_MASK, + base + QUADSPI_MCR);
/* - * Assign AMBA memory zone for every chipselect - * QuadSPI has two channels, every channel has two chipselects. - * If the property 'num-cs' in dts is 2, the AMBA memory will be divided - * into two parts and assign to every channel. This indicate that every - * channel only has one valid chipselect. - * If the property 'num-cs' in dts is 4, the AMBA memory will be divided - * into four parts and assign to every chipselect. - * Every channel will has two valid chipselects. + * Previous boot stages (BootROM, bootloader) might have used DDR + * mode and did not clear the TDH bits. As we currently use SDR mode + * only, clear the TDH bits if necessary. */ - amba_size_per_chip = priv->amba_total_size >> - (priv->num_chipselect >> 1); - for (i = 1 ; i < priv->num_chipselect ; i++) - priv->amba_base[i] = - amba_size_per_chip + priv->amba_base[i - 1]; + if (needs_tdh_setting(q)) + qspi_writel(q, qspi_readl(q, base + QUADSPI_FLSHCR) & + ~QUADSPI_FLSHCR_TDH_MASK, + base + QUADSPI_FLSHCR); + + reg = qspi_readl(q, base + QUADSPI_SMPR); + qspi_writel(q, reg & ~(QUADSPI_SMPR_FSDLY_MASK + | QUADSPI_SMPR_FSPHS_MASK + | QUADSPI_SMPR_HSENA_MASK + | QUADSPI_SMPR_DDRSMP_MASK), base + QUADSPI_SMPR); + + /* We only use the buffer3 for AHB read */ + qspi_writel(q, 0, base + QUADSPI_BUF0IND); + qspi_writel(q, 0, base + QUADSPI_BUF1IND); + qspi_writel(q, 0, base + QUADSPI_BUF2IND); + + qspi_writel(q, QUADSPI_BFGENCR_SEQID(SEQID_LUT), + q->iobase + QUADSPI_BFGENCR); + qspi_writel(q, QUADSPI_RBCT_WMRK_MASK, base + QUADSPI_RBCT); + qspi_writel(q, QUADSPI_BUF3CR_ALLMST_MASK | + QUADSPI_BUF3CR_ADATSZ(q->devtype_data->ahb_buf_size / 8), + base + QUADSPI_BUF3CR); + + if (needs_amba_base_offset(q)) + addr_offset = q->memmap_phy;
/* - * Any read access to non-implemented addresses will provide - * undefined results. - * - * In case single die flash devices, TOP_ADDR_MEMA2 and - * TOP_ADDR_MEMB2 should be initialized/programmed to - * TOP_ADDR_MEMA1 and TOP_ADDR_MEMB1 respectively - in effect, - * setting the size of these devices to 0. This would ensure - * that the complete memory map is assigned to only one flash device. + * In HW there can be a maximum of four chips on two buses with + * two chip selects on each bus. We use four chip selects in SW + * to differentiate between the four chips. + * We use ahb_buf_size for each chip and set SFA1AD, SFA2AD, SFB1AD, + * SFB2AD accordingly. */ - qspi_write32(priv->flags, &priv->regs->sfa1ad, - priv->amba_base[0] + amba_size_per_chip); - switch (priv->num_chipselect) { - case 1: - break; - case 2: - qspi_write32(priv->flags, &priv->regs->sfa2ad, - priv->amba_base[1]); - qspi_write32(priv->flags, &priv->regs->sfb1ad, - priv->amba_base[1] + amba_size_per_chip); - qspi_write32(priv->flags, &priv->regs->sfb2ad, - priv->amba_base[1] + amba_size_per_chip); - break; - case 4: - qspi_write32(priv->flags, &priv->regs->sfa2ad, - priv->amba_base[2]); - qspi_write32(priv->flags, &priv->regs->sfb1ad, - priv->amba_base[3]); - qspi_write32(priv->flags, &priv->regs->sfb2ad, - priv->amba_base[3] + amba_size_per_chip); - break; - default: - debug("Error: Unsupported chipselect number %u!\n", - priv->num_chipselect); - qspi_module_disable(priv, 1); - return -EINVAL; - } - - qspi_set_lut(priv); - -#ifdef CONFIG_SYS_FSL_QSPI_AHB - qspi_init_ahb_read(priv); -#endif - - qspi_module_disable(priv, 0); - + qspi_writel(q, q->devtype_data->ahb_buf_size + addr_offset, + base + QUADSPI_SFA1AD); + qspi_writel(q, q->devtype_data->ahb_buf_size * 2 + addr_offset, + base + QUADSPI_SFA2AD); + qspi_writel(q, q->devtype_data->ahb_buf_size * 3 + addr_offset, + base + QUADSPI_SFB1AD); + qspi_writel(q, q->devtype_data->ahb_buf_size * 4 + addr_offset, + base + QUADSPI_SFB2AD); + + q->selected = -1; + + /* Enable the module */ + qspi_writel(q, QUADSPI_MCR_RESERVED_MASK | QUADSPI_MCR_END_CFG_MASK, + base + QUADSPI_MCR); return 0; }
-static int fsl_qspi_ofdata_to_platdata(struct udevice *bus) +static const struct spi_controller_mem_ops fsl_qspi_mem_ops = { + .adjust_op_size = fsl_qspi_adjust_op_size, + .supports_op = fsl_qspi_supports_op, + .exec_op = fsl_qspi_exec_op, +}; + +static int fsl_qspi_probe(struct udevice *bus) { - struct fdt_resource res_regs, res_mem; - struct fsl_qspi_platdata *plat = bus->platdata; + struct dm_spi_bus *dm_bus = bus->uclass_priv; + struct fsl_qspi *q = dev_get_priv(bus); const void *blob = gd->fdt_blob; int node = dev_of_offset(bus); - int ret, flash_num = 0, subnode; + struct fdt_resource res; + int ret;
- if (fdtdec_get_bool(blob, node, "big-endian")) - plat->flags |= QSPI_FLAG_REGMAP_ENDIAN_BIG; + q->devtype_data = (struct fsl_qspi_devtype_data *) + dev_get_driver_data(bus);
- ret = fdt_get_named_resource(blob, node, "reg", "reg-names", - "QuadSPI", &res_regs); + /* find the resources */ + ret = fdt_get_named_resource(blob, node, "reg", "reg-names", "QuadSPI", + &res); if (ret) { - debug("Error: can't get regs base addresses(ret = %d)!\n", ret); + dev_err(dev, "Can't get regs base addresses(ret = %d)!\n", ret); return -ENOMEM; } + + q->iobase = map_physmem(res.start, res.end - res.start, MAP_NOCACHE); + ret = fdt_get_named_resource(blob, node, "reg", "reg-names", - "QuadSPI-memory", &res_mem); + "QuadSPI-memory", &res); if (ret) { - debug("Error: can't get AMBA base addresses(ret = %d)!\n", ret); + dev_err(dev, "Can't get AMBA base addresses(ret = %d)!\n", ret); return -ENOMEM; }
- /* Count flash numbers */ - fdt_for_each_subnode(subnode, blob, node) - ++flash_num; + q->ahb_addr = map_physmem(res.start, res.end - res.start, MAP_NOCACHE); + q->memmap_phy = res.start;
- if (flash_num == 0) { - debug("Error: Missing flashes!\n"); - return -ENODEV; - } + dm_bus->max_hz = fdtdec_get_int(blob, node, "spi-max-frequency", + 66000000);
- plat->speed_hz = fdtdec_get_int(blob, node, "spi-max-frequency", - FSL_QSPI_DEFAULT_SCK_FREQ); - plat->num_chipselect = fdtdec_get_int(blob, node, "num-cs", - FSL_QSPI_MAX_CHIPSELECT_NUM); - - plat->reg_base = res_regs.start; - plat->amba_base = res_mem.start; - plat->amba_total_size = res_mem.end - res_mem.start + 1; - plat->flash_num = flash_num; - - debug("%s: regs=<0x%llx> <0x%llx, 0x%llx>, max-frequency=%d, endianess=%s\n", - __func__, - (u64)plat->reg_base, - (u64)plat->amba_base, - (u64)plat->amba_total_size, - plat->speed_hz, - plat->flags & QSPI_FLAG_REGMAP_ENDIAN_BIG ? "be" : "le" - ); + fsl_qspi_default_setup(q);
return 0; }
static int fsl_qspi_xfer(struct udevice *dev, unsigned int bitlen, - const void *dout, void *din, unsigned long flags) + const void *dout, void *din, unsigned long flags) { - struct fsl_qspi_priv *priv; - struct udevice *bus; - - bus = dev->parent; - priv = dev_get_priv(bus); - - return qspi_xfer(priv, bitlen, dout, din, flags); + return 0; }
static int fsl_qspi_claim_bus(struct udevice *dev) { - struct fsl_qspi_priv *priv; - struct udevice *bus; - struct dm_spi_slave_platdata *slave_plat = dev_get_parent_platdata(dev); - int ret; - - bus = dev->parent; - priv = dev_get_priv(bus); - - /* make sure controller is not busy anywhere */ - ret = is_controller_busy(priv); - - if (ret) { - debug("ERROR : The controller is busy\n"); - return ret; - } - - priv->cur_amba_base = priv->amba_base[slave_plat->cs]; - - qspi_module_disable(priv, 0); - return 0; }
static int fsl_qspi_release_bus(struct udevice *dev) { - struct fsl_qspi_priv *priv; - struct udevice *bus; - - bus = dev->parent; - priv = dev_get_priv(bus); - - qspi_module_disable(priv, 1); - return 0; }
static int fsl_qspi_set_speed(struct udevice *bus, uint speed) { - /* Nothing to do */ return 0; }
static int fsl_qspi_set_mode(struct udevice *bus, uint mode) { - /* Nothing to do */ return 0; }
@@ -1146,14 +782,17 @@ static const struct dm_spi_ops fsl_qspi_ops = { .xfer = fsl_qspi_xfer, .set_speed = fsl_qspi_set_speed, .set_mode = fsl_qspi_set_mode, + .mem_ops = &fsl_qspi_mem_ops, };
static const struct udevice_id fsl_qspi_ids[] = { - { .compatible = "fsl,vf610-qspi", .data = (ulong)&vybrid_data }, - { .compatible = "fsl,imx6sx-qspi", .data = (ulong)&imx6sx_data }, - { .compatible = "fsl,imx6ul-qspi", .data = (ulong)&imx6ul_7d_data }, - { .compatible = "fsl,imx7d-qspi", .data = (ulong)&imx6ul_7d_data }, - { .compatible = "fsl,imx7ulp-qspi", .data = (ulong)&imx7ulp_data }, + { .compatible = "fsl,vf610-qspi", .data = (ulong)&vybrid_data, }, + { .compatible = "fsl,imx6sx-qspi", .data = (ulong)&imx6sx_data, }, + { .compatible = "fsl,imx6ul-qspi", .data = (ulong)&imx6ul_data, }, + { .compatible = "fsl,imx7d-qspi", .data = (ulong)&imx7d_data, }, + { .compatible = "fsl,ls1021a-qspi", .data = (ulong)&ls1021a_data, }, + { .compatible = "fsl,ls1088a-qspi", .data = (ulong)&ls1088a_data, }, + { .compatible = "fsl,ls2080a-qspi", .data = (ulong)&ls2080a_data, }, { } };
@@ -1162,9 +801,6 @@ U_BOOT_DRIVER(fsl_qspi) = { .id = UCLASS_SPI, .of_match = fsl_qspi_ids, .ops = &fsl_qspi_ops, - .ofdata_to_platdata = fsl_qspi_ofdata_to_platdata, - .platdata_auto_alloc_size = sizeof(struct fsl_qspi_platdata), - .priv_auto_alloc_size = sizeof(struct fsl_qspi_priv), + .priv_auto_alloc_size = sizeof(struct fsl_qspi), .probe = fsl_qspi_probe, - .child_pre_probe = fsl_qspi_child_pre_probe, }; diff --git a/drivers/spi/fsl_qspi.h b/drivers/spi/fsl_qspi.h deleted file mode 100644 index 9e61a85..0000000 --- a/drivers/spi/fsl_qspi.h +++ /dev/null @@ -1,145 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0+ */ -/* - * Copyright 2013-2014 Freescale Semiconductor, Inc. - * - * Register definitions for Freescale QSPI - */ - -#ifndef _FSL_QSPI_H_ -#define _FSL_QSPI_H_ - -struct fsl_qspi_regs { - u32 mcr; - u32 rsvd0[1]; - u32 ipcr; - u32 flshcr; - u32 buf0cr; - u32 buf1cr; - u32 buf2cr; - u32 buf3cr; - u32 bfgencr; - u32 soccr; - u32 rsvd1[2]; - u32 buf0ind; - u32 buf1ind; - u32 buf2ind; - u32 rsvd2[49]; - u32 sfar; - u32 rsvd3[1]; - u32 smpr; - u32 rbsr; - u32 rbct; - u32 rsvd4[15]; - u32 tbsr; - u32 tbdr; - u32 rsvd5[1]; - u32 sr; - u32 fr; - u32 rser; - u32 spndst; - u32 sptrclr; - u32 rsvd6[4]; - u32 sfa1ad; - u32 sfa2ad; - u32 sfb1ad; - u32 sfb2ad; - u32 rsvd7[28]; - u32 rbdr[32]; - u32 rsvd8[32]; - u32 lutkey; - u32 lckcr; - u32 rsvd9[2]; - u32 lut[64]; -}; - -#define QSPI_IPCR_SEQID_SHIFT 24 -#define QSPI_IPCR_SEQID_MASK (0xf << QSPI_IPCR_SEQID_SHIFT) - -#define QSPI_MCR_END_CFD_SHIFT 2 -#define QSPI_MCR_END_CFD_MASK (3 << QSPI_MCR_END_CFD_SHIFT) -#ifdef CONFIG_SYS_FSL_QSPI_AHB -/* AHB needs 64bit operation */ -#define QSPI_MCR_END_CFD_LE (3 << QSPI_MCR_END_CFD_SHIFT) -#else -#define QSPI_MCR_END_CFD_LE (1 << QSPI_MCR_END_CFD_SHIFT) -#endif -#define QSPI_MCR_DDR_EN_SHIFT 7 -#define QSPI_MCR_DDR_EN_MASK (1 << QSPI_MCR_DDR_EN_SHIFT) -#define QSPI_MCR_CLR_RXF_SHIFT 10 -#define QSPI_MCR_CLR_RXF_MASK (1 << QSPI_MCR_CLR_RXF_SHIFT) -#define QSPI_MCR_CLR_TXF_SHIFT 11 -#define QSPI_MCR_CLR_TXF_MASK (1 << QSPI_MCR_CLR_TXF_SHIFT) -#define QSPI_MCR_MDIS_SHIFT 14 -#define QSPI_MCR_MDIS_MASK (1 << QSPI_MCR_MDIS_SHIFT) -#define QSPI_MCR_RESERVED_SHIFT 16 -#define QSPI_MCR_RESERVED_MASK (0xf << QSPI_MCR_RESERVED_SHIFT) -#define QSPI_MCR_SWRSTHD_SHIFT 1 -#define QSPI_MCR_SWRSTHD_MASK (1 << QSPI_MCR_SWRSTHD_SHIFT) -#define QSPI_MCR_SWRSTSD_SHIFT 0 -#define QSPI_MCR_SWRSTSD_MASK (1 << QSPI_MCR_SWRSTSD_SHIFT) - -#define QSPI_SMPR_HSENA_SHIFT 0 -#define QSPI_SMPR_HSENA_MASK (1 << QSPI_SMPR_HSENA_SHIFT) -#define QSPI_SMPR_FSPHS_SHIFT 5 -#define QSPI_SMPR_FSPHS_MASK (1 << QSPI_SMPR_FSPHS_SHIFT) -#define QSPI_SMPR_FSDLY_SHIFT 6 -#define QSPI_SMPR_FSDLY_MASK (1 << QSPI_SMPR_FSDLY_SHIFT) -#define QSPI_SMPR_DDRSMP_SHIFT 16 -#define QSPI_SMPR_DDRSMP_MASK (7 << QSPI_SMPR_DDRSMP_SHIFT) - -#define QSPI_BUFXCR_INVALID_MSTRID 0xe -#define QSPI_BUF3CR_ALLMST_SHIFT 31 -#define QSPI_BUF3CR_ALLMST_MASK (1 << QSPI_BUF3CR_ALLMST_SHIFT) -#define QSPI_BUF3CR_ADATSZ_SHIFT 8 -#define QSPI_BUF3CR_ADATSZ_MASK (0xFF << QSPI_BUF3CR_ADATSZ_SHIFT) - -#define QSPI_BFGENCR_SEQID_SHIFT 12 -#define QSPI_BFGENCR_SEQID_MASK (0xf << QSPI_BFGENCR_SEQID_SHIFT) -#define QSPI_BFGENCR_PAR_EN_SHIFT 16 -#define QSPI_BFGENCR_PAR_EN_MASK (1 << QSPI_BFGENCR_PAR_EN_SHIFT) - -#define QSPI_RBSR_RDBFL_SHIFT 8 -#define QSPI_RBSR_RDBFL_MASK (0x3f << QSPI_RBSR_RDBFL_SHIFT) - -#define QSPI_RBCT_RXBRD_SHIFT 8 -#define QSPI_RBCT_RXBRD_USEIPS (1 << QSPI_RBCT_RXBRD_SHIFT) - -#define QSPI_SR_AHB_ACC_SHIFT 2 -#define QSPI_SR_AHB_ACC_MASK (1 << QSPI_SR_AHB_ACC_SHIFT) -#define QSPI_SR_IP_ACC_SHIFT 1 -#define QSPI_SR_IP_ACC_MASK (1 << QSPI_SR_IP_ACC_SHIFT) -#define QSPI_SR_BUSY_SHIFT 0 -#define QSPI_SR_BUSY_MASK (1 << QSPI_SR_BUSY_SHIFT) - -#define QSPI_LCKCR_LOCK 0x1 -#define QSPI_LCKCR_UNLOCK 0x2 - -#define LUT_KEY_VALUE 0x5af05af0 - -#define OPRND0_SHIFT 0 -#define OPRND0(x) ((x) << OPRND0_SHIFT) -#define PAD0_SHIFT 8 -#define PAD0(x) ((x) << PAD0_SHIFT) -#define INSTR0_SHIFT 10 -#define INSTR0(x) ((x) << INSTR0_SHIFT) -#define OPRND1_SHIFT 16 -#define OPRND1(x) ((x) << OPRND1_SHIFT) -#define PAD1_SHIFT 24 -#define PAD1(x) ((x) << PAD1_SHIFT) -#define INSTR1_SHIFT 26 -#define INSTR1(x) ((x) << INSTR1_SHIFT) - -#define LUT_CMD 1 -#define LUT_ADDR 2 -#define LUT_DUMMY 3 -#define LUT_READ 7 -#define LUT_WRITE 8 - -#define LUT_PAD1 0 -#define LUT_PAD2 1 -#define LUT_PAD4 2 - -#define ADDR24BIT 0x18 -#define ADDR32BIT 0x20 - -#endif /* _FSL_QSPI_H_ */
Jagan,
Changes looks fine to me, feel free to apply:
Acked-by: Vignesh Raghavendra vigneshr@ti.com
Regards Vignesh
- Copyright 2013-2015 Freescale Semiconductor, Inc.
- Freescale QuadSPI driver.
- Copyright (C) 2013 Freescale Semiconductor, Inc.
- Copyright (C) 2018 Bootlin
- Copyright (C) 2018 exceet electronics GmbH
- Copyright (C) 2018 Kontron Electronics GmbH
- Copyright 2019-2020 NXP
- This driver is a ported version of Linux Freescale QSPI driver taken from
- v5.5-rc1 tag having following information.
- Freescale Quad Serial Peripheral Interface (QSPI) driver
- Transition to SPI MEM interface:
- Authors:
Boris Brezillon <bbrezillon@kernel.org>
Frieder Schrempf <frieder.schrempf@kontron.de>
Yogesh Gaur <yogeshnarayan.gaur@nxp.com>
Suresh Gupta <suresh.gupta@nxp.com>
- Based on the original fsl-quadspi.c spi-nor driver.
- Transition to spi-mem in spi-fsl-qspi.c
- The driver only uses one single LUT entry, that is updated on
- each call of exec_op(). Index 0 is preset at boot with a basic
- read operation, so let's use the last entry (15).
- (QUADSPI_LUT_BASE + QUADSPI_LUT_OFFSET + (idx) * 4)
- The PAD definitions for LUT register.
- The pad stands for the number of IO lines [0:3].
- For example, the quad read needs four IO lines,
- so you should use LUT_PAD(4).
- Macro for constructing the LUT entries with the following
- register layout:
- | INSTR1 | PAD1 | OPRND1 | INSTR0 | PAD0 | OPRND0 |
- ((((ins) << 10) | ((pad) << 8) | (opr)) << (((idx) % 2) * 16))
- u32 rxfifo;
- u32 txfifo;
- u32 ahb_buf_size;
- u32 driver_data;
- TKT253890, the controller needs the driver to fill the txfifo with
- 16 bytes at least to trigger a data transfer, even though the extra
- data won't be transferred.
- struct fsl_qspi_platdata - platform data for Freescale QSPI
- @flags: Flags for QSPI QSPI_FLAG_...
- @speed_hz: Default SCK frequency
- @reg_base: Base address of QSPI registers
- @amba_base: Base address of QSPI memory mapping
- @amba_total_size: size of QSPI memory mapping
- @flash_num: Number of active slave devices
- @num_chipselect: Number of QSPI chipselect signals
- Controller adds QSPI_AMBA_BASE (base address of the mapped memory)
- internally. No need to add it when setting SFXXAD and SFAR registers
- u32 flags;
- u32 speed_hz;
- u32 flash_num;
- struct fsl_qspi_priv - private data for Freescale QSPI
- @bus_clk: QSPI input clk frequency
- @cur_seqid: current LUT table sequence id
- @sf_addr: flash access offset
- @amba_base: Base address of QSPI memory mapping of every CS
- @cur_amba_base: Base address of QSPI memory mapping of current CS
- @regs: Point to QSPI register structure for I/O access
- Controller uses TDH bits in register QUADSPI_FLSHCR.
- They need to be set in accordance with the DDR/SDR mode.
- u32 flags;
- u32 bus_clk;
- u32 speed_hz;
- u32 cur_seqid;
- u32 sf_addr;
- u32 flash_num;
- unsigned int rxfifo;
- unsigned int txfifo;
- unsigned int ahb_buf_size;
- unsigned int quirks;
- bool little_endian;
- .rxfifo = 128,
- .txfifo = 64,
- .rxfifo = SZ_128,
- .txfifo = SZ_64,
- .ahb_buf_size = SZ_1K,
- .quirks = QUADSPI_QUIRK_SWAP_ENDIAN,
- .little_endian = true,
- .rxfifo = 128,
- .txfifo = 512,
- .driver_data = 0,
- .rxfifo = SZ_128,
- .txfifo = SZ_512,
- .quirks = QUADSPI_QUIRK_4X_INT_CLK | QUADSPI_QUIRK_TKT245618,
- .rxfifo = SZ_128,
- .txfifo = SZ_512,
- .quirks = QUADSPI_QUIRK_TKT253890 | QUADSPI_QUIRK_4X_INT_CLK |
- .rxfifo = 128,
- .txfifo = 512,
- .driver_data = 0,
- .rxfifo = SZ_128,
- .txfifo = SZ_512,
- .rxfifo = 64,
- .txfifo = 64,
- .driver_data = 0,
- .rxfifo = SZ_128,
- .txfifo = SZ_64,
- .quirks = 0,
- .little_endian = false,
- .rxfifo = SZ_128,
- .txfifo = SZ_128,
- .quirks = QUADSPI_QUIRK_TKT253890,
- .rxfifo = SZ_128,
- .txfifo = SZ_64,
- .quirks = QUADSPI_QUIRK_TKT253890 | QUADSPI_QUIRK_BASE_INTERNAL,
+struct fsl_qspi {
- void __iomem *iobase;
- void __iomem *ahb_addr;
- u32 memmap_phy;
- const struct fsl_qspi_devtype_data *devtype_data;
- int selected;
- return q->devtype_data->quirks & QUADSPI_QUIRK_SWAP_ENDIAN;
- return q->devtype_data->quirks & QUADSPI_QUIRK_4X_INT_CLK;
- u32 val;
- return q->devtype_data->quirks & QUADSPI_QUIRK_TKT253890;
- in hardware for LS102xA, but not for VF610 */
- else
return data;
- return q->devtype_data->quirks & QUADSPI_QUIRK_TKT245618;
- u32 lut_base;
- /* Fast Read */
-#else
- else
INSTR1(LUT_ADDR));
-#endif
INSTR1(LUT_READ));
- /* Read Status */
-#else
- else
-#endif
-#else
- else
-#endif
- /* READ ID */
* initialization.
-#endif
INSTR1(LUT_READ));
- return !(q->devtype_data->quirks & QUADSPI_QUIRK_BASE_INTERNAL);
- return q->devtype_data->quirks & QUADSPI_QUIRK_USE_TDH_SETTING;
- If we have changed the content of the flash by writing or erasing,
- we need to invalidate the AHB buffer. If we do not do so, we may read out
- the wrong data. The spec tells us reset the AHB domain and Serial Flash
- domain at the same time.
- An IC bug makes it necessary to rearrange the 32-bit data.
- Later chips, such as IMX6SLX, have fixed this bug.
- u32 reg;
- udelay(1);
- return needs_swap_endian(q) ? __swab32(a) : a;
- R/W functions for big- or little-endian registers:
- The QSPI controller's endianness is independent of
- the CPU core's endianness. So far, although the CPU
- core is little-endian the QSPI controller can use
- big-endian or little-endian.
- u32 mcr_reg;
- void *rx_addr;
mcr_reg);
- if (q->devtype_data->little_endian)
- else
- return in_be32(addr);
- u32 reg, reg2;
- switch (width) {
- case 1:
- case 2:
- case 4:
- reg |= BIT(29);
- reg |= BIT(16);
- return -ENOTSUPP;
- There are two different ways to read out the data from the flash:
- the "IP Command Read" and the "AHB Command Read".
- The IC guy suggests we use the "AHB Command Read" which is faster
- then the "IP Command Read". (What's more is that there is a bug in
- the "IP Command Read" in the Vybrid.)
- After we set up the registers for the "AHB Command Read", we can use
- the memcpy to read the data directly. A "missed" access to the buffer
- causes the controller to clear the buffer, and use the sequence pointed
- by the QUADSPI_BFGENCR[SEQID] to initiate a read from the flash.
- struct fsl_qspi *q = dev_get_priv(slave->dev->parent);
- int ret;
- ret = fsl_qspi_check_buswidth(q, op->cmd.buswidth);
- if (op->addr.nbytes)
- if (op->dummy.nbytes)
- if (op->data.nbytes)
if (ret)
return false;
*/* to fit into a single LUT entry.
- if (op->addr.nbytes +
return false;
- /* Max 64 dummy clock cycles supported */
- if (op->dummy.nbytes &&
return false;
- /* Max data length, check controller limits and alignment */
- if (op->data.dir == SPI_MEM_DATA_IN &&
return false;
- if (op->data.dir == SPI_MEM_DATA_OUT &&
return false;
- return true;
} -#endif
- void __iomem *base = q->iobase;
- u32 lutval[4] = {};
- int lutidx = 1, i;
mcr_reg);
- lutval[0] |= LUT_DEF(0, LUT_CMD, LUT_PAD(op->cmd.buswidth),
op->cmd.opcode);
- for (i = 0; i < op->addr.nbytes; i++) {
seqid = SEQID_BRRD;
- else
- while (1) {
WATCHDOG_RESET();
break;
addrbyte);
}lutidx++;
-} -#endif
- int i;
mcr_reg);
- i = 0;
WATCHDOG_RESET();
len -= size;
rxbuf++;
i++;
- if (op->dummy.nbytes) {
}lutidx++;
- int i, size;
- u32 to_or_from;
- u32 seqid;
seqid = SEQID_RDAR;
- else
mcr_reg);
- while (len > 0) {
WATCHDOG_RESET();
size);
to_or_from += size;
len -= size;
i = 0;
if (size < 4)
else
rxbuf++;
size -= 4;
i++;
- if (op->data.nbytes) {
0);
}lutidx++;
- lutval[lutidx / 2] |= LUT_DEF(lutidx, LUT_STOP, 0, 0);
mcr_reg);
- status_reg = 0;
WATCHDOG_RESET();
- /* unlock LUT */
- qspi_writel(q, QUADSPI_LUTKEY_VALUE, q->iobase + QUADSPI_LUTKEY);
- qspi_writel(q, QUADSPI_LCKER_UNLOCK, q->iobase + QUADSPI_LCKCR);
- dev_dbg(q->dev, "CMD[%x] lutval[0:%x \t 1:%x \t 2:%x \t 3:%x]\n",
- seqid = SEQID_PP;
seqid = SEQID_WRAR;
seqid = SEQID_BRWR;
-#endif
- /* fill LUT */
- for (i = 0; i < ARRAY_SIZE(lutval); i++)
- /* lock LUT */
- qspi_writel(q, QUADSPI_LCKER_LOCK, q->iobase + QUADSPI_LCKCR);
- If we have changed the content of the flash by writing or erasing, or if we
- read from flash with a different offset into the page buffer, we need to
- invalidate the AHB buffer. If we do not do so, we may read out the wrong
- data. The spec tells us reset the AHB domain and Serial Flash domain at
- the same time.
- u32 reg;
- reg = qspi_readl(q, q->iobase + QUADSPI_MCR);
- reg |= QUADSPI_MCR_SWRSTHD_MASK | QUADSPI_MCR_SWRSTSD_MASK;
- qspi_writel(q, reg, q->iobase + QUADSPI_MCR);
*/* Delay 1 us is enough.
- if (tx_size % 16)
size++;
txbuf += 4;
- udelay(1);
- reg &= ~(QUADSPI_MCR_SWRSTHD_MASK | QUADSPI_MCR_SWRSTSD_MASK);
mcr_reg);
- while (1) {
WATCHDOG_RESET();
break;
- struct dm_spi_slave_platdata *plat =
- if (q->selected == plat->cs)
return;
- q->selected = plat->cs;
- fsl_qspi_invalidate(q);
- u32 mcr_reg;
mcr_reg);
- memcpy_fromio(op->data.buf.in,
op->data.nbytes);
- u32 txbuf;
- WATCHDOG_RESET();
- if (dout) {
wr_sfaddr = 0;
-#endif
- int i;
- u32 val;
- if (din) {
-#else
-#endif
priv->sf_addr = 0;
-#endif
- for (i = 0; i < ALIGN_DOWN(op->data.nbytes, 4); i += 4) {
}qspi_writel(q, val, base + QUADSPI_TBDR);
-#endif
- if (i < op->data.nbytes) {
- if (needs_fill_txfifo(q)) {
- u32 mcr_val;
- int i;
- u8 *buf = op->data.buf.in;
- u32 val;
- if (disable)
- else
- u32 smpr_val;
- u32 reg;
- if (!q->devtype_data->little_endian)
- return readl_poll_timeout(base, reg, !(reg & mask), timeout_us);
- int err = 0;
- qspi_writel(q, op->data.nbytes | QUADSPI_IPCR_SEQID(SEQID_LUT),
- /* wait for the controller being ready */
- err = fsl_qspi_readl_poll_tout(q, base + QUADSPI_SR,
10, 1000);
- if (!err && op->data.nbytes && op->data.dir == SPI_MEM_DATA_IN)
- return err;
- int i, ret;
- u32 addr_offset = 0;
- int err = 0;
- fsl_qspi_readl_poll_tout(q, base + QUADSPI_SR, (QUADSPI_SR_IP_ACC_MASK |
- fsl_qspi_select_mem(q, slave);
- if (needs_amba_base_offset(q))
- qspi_writel(q,
- qspi_writel(q, qspi_readl(q, base + QUADSPI_MCR) |
- qspi_writel(q, QUADSPI_SPTRCLR_BFPTRC | QUADSPI_SPTRCLR_IPPTRC,
- fsl_qspi_prepare_lut(q, op);
*/* IP commands to access the flash.
return -ENODEV;
- if (op->data.nbytes > (q->devtype_data->rxfifo - 4) &&
- } else {
}err = fsl_qspi_do_op(q, op);
- /* Invalidate the data in the AHB buffer. */
- return err;
- if (ret) {
return ret;
- if (op->data.dir == SPI_MEM_DATA_OUT) {
- } else {
}op->data.nbytes = ALIGN_DOWN(op->data.nbytes, 8);
- u32 reg, addr_offset = 0;
- /* Reset the module */
- qspi_writel(q, QUADSPI_MCR_SWRSTSD_MASK | QUADSPI_MCR_SWRSTHD_MASK,
- udelay(1);
*/* only, clear the TDH bits if necessary.
*/* SFB2AD accordingly.
- case 1:
break;
- case 2:
break;
- case 4:
break;
- default:
return -EINVAL;
-#endif
- qspi_writel(q, q->devtype_data->ahb_buf_size + addr_offset,
- qspi_writel(q, q->devtype_data->ahb_buf_size * 2 + addr_offset,
- qspi_writel(q, q->devtype_data->ahb_buf_size * 3 + addr_offset,
- qspi_writel(q, q->devtype_data->ahb_buf_size * 4 + addr_offset,
- q->selected = -1;
- /* Enable the module */
- qspi_writel(q, QUADSPI_MCR_RESERVED_MASK | QUADSPI_MCR_END_CFG_MASK,
return 0;base + QUADSPI_MCR);
- .adjust_op_size = fsl_qspi_adjust_op_size,
- .supports_op = fsl_qspi_supports_op,
- .exec_op = fsl_qspi_exec_op,
- struct dm_spi_bus *dm_bus = bus->uclass_priv;
- struct fsl_qspi *q = dev_get_priv(bus); const void *blob = gd->fdt_blob; int node = dev_of_offset(bus);
- struct fdt_resource res;
- int ret;
- q->devtype_data = (struct fsl_qspi_devtype_data *)
- /* find the resources */
- ret = fdt_get_named_resource(blob, node, "reg", "reg-names", "QuadSPI",
if (ret) {&res);
return -ENOMEM; }dev_err(dev, "Can't get regs base addresses(ret = %d)!\n", ret);
- q->iobase = map_physmem(res.start, res.end - res.start, MAP_NOCACHE);
if (ret) {"QuadSPI-memory", &res);
return -ENOMEM; }dev_err(dev, "Can't get AMBA base addresses(ret = %d)!\n", ret);
++flash_num;
- q->ahb_addr = map_physmem(res.start, res.end - res.start, MAP_NOCACHE);
- q->memmap_phy = res.start;
return -ENODEV;
- dm_bus->max_hz = fdtdec_get_int(blob, node, "spi-max-frequency",
66000000);
__func__,
plat->speed_hz,
- int ret;
- if (ret) {
return ret;
- .mem_ops = &fsl_qspi_mem_ops,
- { .compatible = "fsl,vf610-qspi", .data = (ulong)&vybrid_data, },
- { .compatible = "fsl,imx6sx-qspi", .data = (ulong)&imx6sx_data, },
- { .compatible = "fsl,imx6ul-qspi", .data = (ulong)&imx6ul_data, },
- { .compatible = "fsl,imx7d-qspi", .data = (ulong)&imx7d_data, },
- { .compatible = "fsl,ls1021a-qspi", .data = (ulong)&ls1021a_data, },
- { .compatible = "fsl,ls1088a-qspi", .data = (ulong)&ls1088a_data, },
- { .compatible = "fsl,ls2080a-qspi", .data = (ulong)&ls2080a_data, }, { }
- .priv_auto_alloc_size = sizeof(struct fsl_qspi), .probe = fsl_qspi_probe,
- Copyright 2013-2014 Freescale Semiconductor, Inc.
- Register definitions for Freescale QSPI
- u32 mcr;
- u32 rsvd0[1];
- u32 ipcr;
- u32 flshcr;
- u32 buf0cr;
- u32 buf1cr;
- u32 buf2cr;
- u32 buf3cr;
- u32 bfgencr;
- u32 soccr;
- u32 rsvd1[2];
- u32 buf0ind;
- u32 buf1ind;
- u32 buf2ind;
- u32 rsvd2[49];
- u32 sfar;
- u32 rsvd3[1];
- u32 smpr;
- u32 rbsr;
- u32 rbct;
- u32 rsvd4[15];
- u32 tbsr;
- u32 tbdr;
- u32 rsvd5[1];
- u32 sr;
- u32 fr;
- u32 rser;
- u32 spndst;
- u32 sptrclr;
- u32 rsvd6[4];
- u32 sfa1ad;
- u32 sfa2ad;
- u32 sfb1ad;
- u32 sfb2ad;
- u32 rsvd7[28];
- u32 rbdr[32];
- u32 rsvd8[32];
- u32 lutkey;
- u32 lckcr;
- u32 rsvd9[2];
- u32 lut[64];
Some of these options are not used by the driver anymore and some of them are obsolete as the information is gathered from the dt. Also consolidating defines in common headers.
Signed-off-by: Frieder Schrempf frieder.schrempf@kontron.de Signed-off-by: Ashish Kumar Ashish.Kumar@nxp.com Signed-off-by: Kuldeep Singh kuldeep.singh@nxp.com --- Depends on https://patchwork.ozlabs.org/patch/1219462/ Depends on https://patchwork.ozlabs.org/patch/1208299/
v4: Remove buildman failure by removinf #endif in LS2080AQDS v3: No change v2: No change
arch/arm/include/asm/arch-fsl-layerscape/config.h | 1 - arch/arm/include/asm/arch-ls102xa/config.h | 1 - include/configs/ls1012a_common.h | 16 +--------------- include/configs/ls1012afrwy.h | 3 --- include/configs/ls1012ardb.h | 3 --- include/configs/ls1021aiot.h | 6 ------ include/configs/ls1021aqds.h | 11 ----------- include/configs/ls1021atwr.h | 10 ---------- include/configs/ls1043aqds.h | 2 -- include/configs/ls1046afrwy.h | 9 --------- include/configs/ls1046aqds.h | 11 ----------- include/configs/ls1046ardb.h | 13 ------------- include/configs/ls1088a_common.h | 6 ------ include/configs/ls1088aqds.h | 8 -------- include/configs/ls1088ardb.h | 18 ------------------ include/configs/ls2080aqds.h | 5 ----- include/configs/ls2080ardb.h | 6 +----- include/configs/mx6sxsabreauto.h | 6 ------ include/configs/mx6sxsabresd.h | 11 ----------- include/configs/mx6ul_14x14_evk.h | 6 ------ include/configs/mx6ullevk.h | 6 ------ include/configs/mx7dsabresd.h | 8 -------- include/configs/pcm052.h | 7 ------- include/configs/vf610twr.h | 8 -------- scripts/config_whitelist.txt | 5 ----- 25 files changed, 2 insertions(+), 184 deletions(-)
diff --git a/arch/arm/include/asm/arch-fsl-layerscape/config.h b/arch/arm/include/asm/arch-fsl-layerscape/config.h index a83c70e..913f7b1 100644 --- a/arch/arm/include/asm/arch-fsl-layerscape/config.h +++ b/arch/arm/include/asm/arch-fsl-layerscape/config.h @@ -304,7 +304,6 @@ #define CONFIG_SYS_FSL_ESDHC_BE #define CONFIG_SYS_FSL_WDOG_BE #define CONFIG_SYS_FSL_DSPI_BE -#define CONFIG_SYS_FSL_QSPI_BE #define CONFIG_SYS_FSL_CCSR_GUR_BE #define CONFIG_SYS_FSL_PEX_LUT_BE
diff --git a/arch/arm/include/asm/arch-ls102xa/config.h b/arch/arm/include/asm/arch-ls102xa/config.h index 9705378..3884948 100644 --- a/arch/arm/include/asm/arch-ls102xa/config.h +++ b/arch/arm/include/asm/arch-ls102xa/config.h @@ -94,7 +94,6 @@ #define CONFIG_SYS_FSL_ESDHC_BE #define CONFIG_SYS_FSL_WDOG_BE #define CONFIG_SYS_FSL_DSPI_BE -#define CONFIG_SYS_FSL_QSPI_BE #define CONFIG_SYS_FSL_DCU_BE #define CONFIG_SYS_FSL_SEC_MON_LE #define CONFIG_SYS_FSL_SFP_VER_3_2 diff --git a/include/configs/ls1012a_common.h b/include/configs/ls1012a_common.h index 2579e2f..1568451 100644 --- a/include/configs/ls1012a_common.h +++ b/include/configs/ls1012a_common.h @@ -37,23 +37,9 @@ #define CONFIG_SYS_MALLOC_LEN (CONFIG_ENV_SIZE + 128 * 1024)
/*SPI device */ -#if defined(CONFIG_QSPI_BOOT) || defined(CONFIG_TFABOOT) #define CONFIG_SYS_FMAN_FW_ADDR 0x400d0000 +#define CONFIG_SYS_FSL_QSPI_BASE 0x40000000 #define CONFIG_SPI_FLASH_SPANSION -#define CONFIG_FSL_SPI_INTERFACE -#define CONFIG_SF_DATAFLASH - -#define QSPI0_AMBA_BASE 0x40000000 -#define CONFIG_SPI_FLASH_SPANSION - -#define FSL_QSPI_FLASH_SIZE SZ_64M -#define FSL_QSPI_FLASH_NUM 2 - -/* - * Environment - */ -#define CONFIG_ENV_OVERWRITE -#endif
/* SATA */ #define CONFIG_SCSI_AHCI_PLAT diff --git a/include/configs/ls1012afrwy.h b/include/configs/ls1012afrwy.h index c0519e3..0496b51 100644 --- a/include/configs/ls1012afrwy.h +++ b/include/configs/ls1012afrwy.h @@ -33,9 +33,6 @@ func(USB, usb, 0) #endif
-#undef FSL_QSPI_FLASH_SIZE -#define FSL_QSPI_FLASH_SIZE SZ_16M - /* MMC */ #ifdef CONFIG_MMC #define CONFIG_SYS_FSL_MMC_HAS_CAPBLT_VS33 diff --git a/include/configs/ls1012ardb.h b/include/configs/ls1012ardb.h index 0341495..9ca2859 100644 --- a/include/configs/ls1012ardb.h +++ b/include/configs/ls1012ardb.h @@ -16,9 +16,6 @@ #define CONFIG_SYS_MEMTEST_START 0x80000000 #define CONFIG_SYS_MEMTEST_END 0x9fffffff
- -/* ENV */ -#define CONFIG_SYS_FSL_QSPI_BASE 0x40000000 /* * I2C IO expander */ diff --git a/include/configs/ls1021aiot.h b/include/configs/ls1021aiot.h index 0b2d331..236a8d5 100644 --- a/include/configs/ls1021aiot.h +++ b/include/configs/ls1021aiot.h @@ -131,12 +131,6 @@ /* SPI */ #if defined(CONFIG_QSPI_BOOT) || defined(CONFIG_SD_BOOT_QSPI) #define CONFIG_SPI_FLASH_SPANSION - -/* QSPI */ -#define QSPI0_AMBA_BASE 0x40000000 -#define FSL_QSPI_FLASH_SIZE (1 << 24) -#define FSL_QSPI_FLASH_NUM 2 -#define CONFIG_SPI_FLASH_SPANSION #endif
/* DM SPI */ diff --git a/include/configs/ls1021aqds.h b/include/configs/ls1021aqds.h index 8427be5..d5e55a8 100644 --- a/include/configs/ls1021aqds.h +++ b/include/configs/ls1021aqds.h @@ -357,20 +357,9 @@ unsigned long get_board_ddr_clk(void); * MMC */
-/* SPI */ -#if defined(CONFIG_QSPI_BOOT) || defined(CONFIG_SD_BOOT_QSPI) -/* QSPI */ -#define QSPI0_AMBA_BASE 0x40000000 -#define FSL_QSPI_FLASH_SIZE (1 << 24) -#define FSL_QSPI_FLASH_NUM 2 - -/* DSPI */ - /* DM SPI */ #if defined(CONFIG_FSL_DSPI) || defined(CONFIG_FSL_QSPI) #define CONFIG_DM_SPI_FLASH -#define CONFIG_SPI_FLASH_DATAFLASH -#endif #endif
/* diff --git a/include/configs/ls1021atwr.h b/include/configs/ls1021atwr.h index 1919d1e..4a0cf24 100644 --- a/include/configs/ls1021atwr.h +++ b/include/configs/ls1021atwr.h @@ -228,16 +228,6 @@ * MMC */
-/* SPI */ -#if defined(CONFIG_QSPI_BOOT) || defined(CONFIG_SD_BOOT_QSPI) -/* QSPI */ -#define QSPI0_AMBA_BASE 0x40000000 -#define FSL_QSPI_FLASH_SIZE (1 << 24) -#define FSL_QSPI_FLASH_NUM 2 - -/* DSPI */ -#endif - /* DM SPI */ #if defined(CONFIG_FSL_DSPI) || defined(CONFIG_FSL_QSPI) #define CONFIG_DM_SPI_FLASH diff --git a/include/configs/ls1043aqds.h b/include/configs/ls1043aqds.h index 3708062..063e724 100644 --- a/include/configs/ls1043aqds.h +++ b/include/configs/ls1043aqds.h @@ -384,8 +384,6 @@ unsigned long get_board_ddr_clk(void); (defined(CONFIG_QSPI_BOOT) || defined(CONFIG_SD_BOOT_QSPI)) #ifdef CONFIG_FSL_QSPI #define CONFIG_SPI_FLASH_SPANSION -#define FSL_QSPI_FLASH_SIZE (1 << 24) -#define FSL_QSPI_FLASH_NUM 2 #endif #endif
diff --git a/include/configs/ls1046afrwy.h b/include/configs/ls1046afrwy.h index 4ccd3b0..88d06ce 100644 --- a/include/configs/ls1046afrwy.h +++ b/include/configs/ls1046afrwy.h @@ -96,10 +96,7 @@ /* * Environment */ -#define CONFIG_ENV_OVERWRITE - #define CONFIG_SYS_MMC_ENV_DEV 0 - #define CONFIG_SYS_FSL_QSPI_BASE 0x40000000
/* FMan */ @@ -117,12 +114,6 @@
#endif
-/* QSPI device */ -#ifdef CONFIG_FSL_QSPI -#define FSL_QSPI_FLASH_SIZE SZ_64M -#define FSL_QSPI_FLASH_NUM 1 -#endif - #undef CONFIG_BOOTCOMMAND #define QSPI_NOR_BOOTCOMMAND "run distro_bootcmd; run qspi_bootcmd; " \ "env exists secureboot && esbc_halt;;" diff --git a/include/configs/ls1046aqds.h b/include/configs/ls1046aqds.h index 0b17b1e..437b6ac 100644 --- a/include/configs/ls1046aqds.h +++ b/include/configs/ls1046aqds.h @@ -46,8 +46,6 @@ unsigned long get_board_ddr_clk(void); defined(CONFIG_QSPI_BOOT) || defined(CONFIG_SD_BOOT_QSPI) #ifdef CONFIG_FSL_QSPI #define CONFIG_SPI_FLASH_SPANSION -#define FSL_QSPI_FLASH_SIZE (1 << 24) -#define FSL_QSPI_FLASH_NUM 2 #endif #endif
@@ -425,16 +423,7 @@ unsigned long get_board_ddr_clk(void); /* * Environment */ -#define CONFIG_ENV_OVERWRITE - -#ifdef CONFIG_TFABOOT #define CONFIG_SYS_MMC_ENV_DEV 0 -#else -#ifdef CONFIG_NAND_BOOT -#elif defined(CONFIG_SD_BOOT) -#define CONFIG_SYS_MMC_ENV_DEV 0 -#endif -#endif
#define CONFIG_CMDLINE_TAG
diff --git a/include/configs/ls1046ardb.h b/include/configs/ls1046ardb.h index efedfd5..61a4a40 100644 --- a/include/configs/ls1046ardb.h +++ b/include/configs/ls1046ardb.h @@ -153,19 +153,8 @@ /* * Environment */ -#ifndef SPL_NO_ENV -#define CONFIG_ENV_OVERWRITE -#endif - -#ifdef CONFIG_TFABOOT #define CONFIG_SYS_MMC_ENV_DEV 0 - #define CONFIG_SYS_FSL_QSPI_BASE 0x40000000 -#else -#if defined(CONFIG_SD_BOOT) -#define CONFIG_SYS_MMC_ENV_DEV 0 -#endif -#endif
#define AQR105_IRQ_MASK 0x80000000 /* FMan */ @@ -195,8 +184,6 @@ #ifndef SPL_NO_QSPI #ifdef CONFIG_FSL_QSPI #define CONFIG_SPI_FLASH_SPANSION -#define FSL_QSPI_FLASH_SIZE (1 << 26) -#define FSL_QSPI_FLASH_NUM 2 #endif #endif
diff --git a/include/configs/ls1088a_common.h b/include/configs/ls1088a_common.h index ab5b396..a737342 100644 --- a/include/configs/ls1088a_common.h +++ b/include/configs/ls1088a_common.h @@ -35,13 +35,7 @@ #endif
/* Link Definitions */ -#ifdef CONFIG_TFABOOT -#define CONFIG_SYS_FSL_QSPI_BASE 0x20000000 -#else -#ifdef CONFIG_QSPI_BOOT #define CONFIG_SYS_FSL_QSPI_BASE 0x20000000 -#endif -#endif
#define CONFIG_SKIP_LOWLEVEL_INIT
diff --git a/include/configs/ls1088aqds.h b/include/configs/ls1088aqds.h index a5125c8..9556935 100644 --- a/include/configs/ls1088aqds.h +++ b/include/configs/ls1088aqds.h @@ -358,14 +358,6 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_SYS_EEPROM_PAGE_WRITE_BITS 3 #define CONFIG_SYS_EEPROM_PAGE_WRITE_DELAY_MS 5
-/* QSPI device */ -#if defined(CONFIG_TFABOOT) || \ - defined(CONFIG_QSPI_BOOT) || defined(CONFIG_SD_BOOT_QSPI) -#define FSL_QSPI_FLASH_SIZE (1 << 26) -#define FSL_QSPI_FLASH_NUM 2 - -#endif - #ifdef CONFIG_FSL_DSPI #define CONFIG_SPI_FLASH_STMICRO #define CONFIG_SPI_FLASH_SST diff --git a/include/configs/ls1088ardb.h b/include/configs/ls1088ardb.h index d02ad08..4451496 100644 --- a/include/configs/ls1088ardb.h +++ b/include/configs/ls1088ardb.h @@ -8,16 +8,7 @@
#include "ls1088a_common.h"
-#ifdef CONFIG_TFABOOT #define CONFIG_SYS_MMC_ENV_DEV 0 -#else -#if defined(CONFIG_QSPI_BOOT) -#elif defined(CONFIG_SD_BOOT) -#define CONFIG_SYS_MMC_ENV_DEV 0 -#else -#define CONFIG_ENV_IS_IN_FLASH -#endif -#endif /* CONFIG_TFABOOT */
#if defined(CONFIG_TFABOOT) || \ defined(CONFIG_QSPI_BOOT) || defined(CONFIG_SD_BOOT_QSPI) @@ -268,15 +259,6 @@ #define CONFIG_SYS_EEPROM_PAGE_WRITE_BITS 3 #define CONFIG_SYS_EEPROM_PAGE_WRITE_DELAY_MS 5
-#ifndef SPL_NO_QSPI -/* QSPI device */ -#if defined(CONFIG_TFABOOT) || \ - defined(CONFIG_QSPI_BOOT) || defined(CONFIG_SD_BOOT_QSPI) -#define FSL_QSPI_FLASH_SIZE (1 << 26) -#define FSL_QSPI_FLASH_NUM 2 -#endif -#endif - #define CONFIG_CMD_MEMINFO #define CONFIG_SYS_MEMTEST_START 0x80000000 #define CONFIG_SYS_MEMTEST_END 0x9fffffff diff --git a/include/configs/ls2080aqds.h b/include/configs/ls2080aqds.h index 9539e2a..8fc2640 100644 --- a/include/configs/ls2080aqds.h +++ b/include/configs/ls2080aqds.h @@ -276,7 +276,6 @@ unsigned long get_board_ddr_clk(void); #define I2C_MUX_CH_DEFAULT 0x8
/* SPI */ -#if defined(CONFIG_FSL_QSPI) || defined(CONFIG_FSL_DSPI) #ifdef CONFIG_FSL_DSPI #define CONFIG_SPI_FLASH_STMICRO #define CONFIG_SPI_FLASH_SST @@ -285,8 +284,6 @@ unsigned long get_board_ddr_clk(void);
#ifdef CONFIG_FSL_QSPI #define CONFIG_SPI_FLASH_SPANSION -#define FSL_QSPI_FLASH_SIZE (1 << 26) /* 64MB */ -#define FSL_QSPI_FLASH_NUM 4 #endif /* * Verify QSPI when boot from NAND, QIXIS brdcfg9 need configure. @@ -295,8 +292,6 @@ unsigned long get_board_ddr_clk(void); */ #define FSL_QIXIS_BRDCFG9_QSPI 0x1
-#endif - /* * MMC */ diff --git a/include/configs/ls2080ardb.h b/include/configs/ls2080ardb.h index de14fb4..893e6f8 100644 --- a/include/configs/ls2080ardb.h +++ b/include/configs/ls2080ardb.h @@ -273,13 +273,9 @@ unsigned long get_board_sys_clk(void); #define I2C_MUX_CH_DEFAULT 0x8
/* SPI */ -#if defined(CONFIG_FSL_QSPI) || defined(CONFIG_FSL_DSPI) -#ifdef CONFIG_FSL_DSPI +#if defined(CONFIG_FSL_DSPI) #define CONFIG_SPI_FLASH_STMICRO #endif -#define FSL_QSPI_FLASH_SIZE SZ_64M /* 64MB */ -#define FSL_QSPI_FLASH_NUM 2 -#endif
/* * RTC configuration diff --git a/include/configs/mx6sxsabreauto.h b/include/configs/mx6sxsabreauto.h index 0bcf031..16a4511 100644 --- a/include/configs/mx6sxsabreauto.h +++ b/include/configs/mx6sxsabreauto.h @@ -145,12 +145,6 @@
#define CONFIG_IMX_THERMAL
-#ifdef CONFIG_FSL_QSPI -#define CONFIG_SYS_FSL_QSPI_AHB -#define FSL_QSPI_FLASH_SIZE SZ_32M -#define FSL_QSPI_FLASH_NUM 2 -#endif - #define CONFIG_SYS_FSL_USDHC_NUM 2 #if defined(CONFIG_ENV_IS_IN_MMC) #define CONFIG_SYS_MMC_ENV_DEV 0 /*USDHC3*/ diff --git a/include/configs/mx6sxsabresd.h b/include/configs/mx6sxsabresd.h index 55aace1..03816df 100644 --- a/include/configs/mx6sxsabresd.h +++ b/include/configs/mx6sxsabresd.h @@ -175,17 +175,6 @@
-#ifdef CONFIG_FSL_QSPI -#define CONFIG_SYS_FSL_QSPI_LE -#define CONFIG_SYS_FSL_QSPI_AHB -#ifdef CONFIG_MX6SX_SABRESD_REVA -#define FSL_QSPI_FLASH_SIZE SZ_16M -#else -#define FSL_QSPI_FLASH_SIZE SZ_32M -#endif -#define FSL_QSPI_FLASH_NUM 2 -#endif - #ifndef CONFIG_SPL_BUILD #ifdef CONFIG_VIDEO #define CONFIG_VIDEO_MXS diff --git a/include/configs/mx6ul_14x14_evk.h b/include/configs/mx6ul_14x14_evk.h index 5cc15b6..50167f4 100644 --- a/include/configs/mx6ul_14x14_evk.h +++ b/include/configs/mx6ul_14x14_evk.h @@ -162,12 +162,6 @@ #define CONFIG_SYS_MMC_ENV_PART 0 /* user area */ #define CONFIG_MMCROOT "/dev/mmcblk1p2" /* USDHC2 */
-#ifdef CONFIG_FSL_QSPI -#define CONFIG_SYS_FSL_QSPI_AHB -#define FSL_QSPI_FLASH_NUM 1 -#define FSL_QSPI_FLASH_SIZE SZ_32M -#endif - /* USB Configs */ #ifdef CONFIG_CMD_USB #define CONFIG_EHCI_HCD_INIT_AFTER_RESET diff --git a/include/configs/mx6ullevk.h b/include/configs/mx6ullevk.h index 7cce911..425f391 100644 --- a/include/configs/mx6ullevk.h +++ b/include/configs/mx6ullevk.h @@ -160,10 +160,4 @@
#define CONFIG_SOFT_SPI
-#ifdef CONFIG_FSL_QSPI -#define CONFIG_SYS_FSL_QSPI_AHB -#define FSL_QSPI_FLASH_NUM 1 -#define FSL_QSPI_FLASH_SIZE SZ_32M -#endif - #endif diff --git a/include/configs/mx7dsabresd.h b/include/configs/mx7dsabresd.h index b1726b1..50a133d 100644 --- a/include/configs/mx7dsabresd.h +++ b/include/configs/mx7dsabresd.h @@ -154,12 +154,4 @@ #define CONFIG_VIDEO_BMP_LOGO #endif
-#ifdef CONFIG_FSL_QSPI -#define CONFIG_SYS_FSL_QSPI_AHB -#define FSL_QSPI_FLASH_NUM 1 -#define FSL_QSPI_FLASH_SIZE SZ_64M -#define QSPI0_BASE_ADDR QSPI1_IPS_BASE_ADDR -#define QSPI0_AMBA_BASE QSPI0_ARB_BASE_ADDR -#endif - #endif /* __CONFIG_H */ diff --git a/include/configs/pcm052.h b/include/configs/pcm052.h index 72f8d08..d4d6ad2 100644 --- a/include/configs/pcm052.h +++ b/include/configs/pcm052.h @@ -26,13 +26,6 @@ #define CONFIG_SYS_NAND_ONFI_DETECTION
#define CONFIG_SYS_MAX_NAND_DEVICE 1 -/* QSPI Configs*/ -#ifdef CONFIG_FSL_QSPI -#define FSL_QSPI_FLASH_SIZE (SZ_16M) -#define FSL_QSPI_FLASH_NUM 2 -#define CONFIG_SYS_FSL_QSPI_LE -#endif -
#define CONFIG_LOADADDR 0x82000000
diff --git a/include/configs/vf610twr.h b/include/configs/vf610twr.h index 3ab3231..d52a5a7 100644 --- a/include/configs/vf610twr.h +++ b/include/configs/vf610twr.h @@ -43,14 +43,6 @@ #define CONFIG_FEC_XCV_TYPE RMII #define CONFIG_FEC_MXC_PHYADDR 0
-/* QSPI Configs*/ - -#ifdef CONFIG_FSL_QSPI -#define FSL_QSPI_FLASH_SIZE (1 << 24) -#define FSL_QSPI_FLASH_NUM 2 -#define CONFIG_SYS_FSL_QSPI_LE -#endif - /* I2C Configs */ #define CONFIG_SYS_I2C #define CONFIG_SYS_I2C_MXC diff --git a/scripts/config_whitelist.txt b/scripts/config_whitelist.txt index cd15473..3c88408 100644 --- a/scripts/config_whitelist.txt +++ b/scripts/config_whitelist.txt @@ -597,7 +597,6 @@ CONFIG_FSL_SERDES CONFIG_FSL_SERDES1 CONFIG_FSL_SERDES2 CONFIG_FSL_SGMII_RISER -CONFIG_FSL_SPI_INTERFACE CONFIG_FSL_TBCLK_EXTRA_DIV CONFIG_FSL_TRUST_ARCH_v1 CONFIG_FSL_VIA @@ -1542,7 +1541,6 @@ CONFIG_SET_BOOTARGS CONFIG_SET_DFU_ALT_BUF_LEN CONFIG_SET_DFU_ALT_INFO CONFIG_SFIO -CONFIG_SF_DATAFLASH CONFIG_SGI_IP28 CONFIG_SH4_PCI CONFIG_SH73A0 @@ -2604,12 +2602,9 @@ CONFIG_SYS_FSL_QBMAN_SIZE_1 CONFIG_SYS_FSL_QMAN_ADDR CONFIG_SYS_FSL_QMAN_OFFSET CONFIG_SYS_FSL_QMAN_V3 -CONFIG_SYS_FSL_QSPI_AHB CONFIG_SYS_FSL_QSPI_BASE CONFIG_SYS_FSL_QSPI_BASE1 CONFIG_SYS_FSL_QSPI_BASE2 -CONFIG_SYS_FSL_QSPI_BE -CONFIG_SYS_FSL_QSPI_LE CONFIG_SYS_FSL_QSPI_SIZE CONFIG_SYS_FSL_QSPI_SIZE1 CONFIG_SYS_FSL_QSPI_SIZE2
Move CONFIG_FSL_QSPI to the board defconfigs and while at it also move CONFIG_SPI_FLASH_SPANSION for LS1043AQDS.
Signed-off-by: Frieder Schrempf frieder.schrempf@kontron.de Signed-off-by: Kuldeep Singh kuldeep.singh@nxp.com --- Depends on https://patchwork.ozlabs.org/patch/1219462/ Depends on https://patchwork.ozlabs.org/patch/1208299/
v4: Move SPI_FLASH_SPANSION to defconfig v3: no change v2: No change
configs/ls1043aqds_qspi_defconfig | 1 + configs/ls1043aqds_sdcard_qspi_defconfig | 1 + configs/ls1043aqds_tfa_SECURE_BOOT_defconfig | 2 ++ configs/ls1043aqds_tfa_defconfig | 1 + include/configs/ls1043aqds.h | 8 -------- 5 files changed, 5 insertions(+), 8 deletions(-)
diff --git a/configs/ls1043aqds_qspi_defconfig b/configs/ls1043aqds_qspi_defconfig index 36e6f4c..6cdd134 100644 --- a/configs/ls1043aqds_qspi_defconfig +++ b/configs/ls1043aqds_qspi_defconfig @@ -40,6 +40,7 @@ CONFIG_DM_MMC=y CONFIG_FSL_ESDHC=y CONFIG_SPI_FLASH=y # CONFIG_SPI_FLASH_BAR is not set +CONFIG_SPI_FLASH_SPANSION=y CONFIG_PHYLIB=y CONFIG_E1000=y CONFIG_FMAN_ENET=y diff --git a/configs/ls1043aqds_sdcard_qspi_defconfig b/configs/ls1043aqds_sdcard_qspi_defconfig index 41d9f87..2c9a229 100644 --- a/configs/ls1043aqds_sdcard_qspi_defconfig +++ b/configs/ls1043aqds_sdcard_qspi_defconfig @@ -54,6 +54,7 @@ CONFIG_DM_MMC=y CONFIG_FSL_ESDHC=y CONFIG_SPI_FLASH=y # CONFIG_SPI_FLASH_BAR is not set +CONFIG_SPI_FLASH_SPANSION=y CONFIG_PHYLIB=y CONFIG_E1000=y CONFIG_FMAN_ENET=y diff --git a/configs/ls1043aqds_tfa_SECURE_BOOT_defconfig b/configs/ls1043aqds_tfa_SECURE_BOOT_defconfig index 0ece698..5075436 100644 --- a/configs/ls1043aqds_tfa_SECURE_BOOT_defconfig +++ b/configs/ls1043aqds_tfa_SECURE_BOOT_defconfig @@ -44,6 +44,7 @@ CONFIG_SYS_FLASH_CFI=y CONFIG_MTD_RAW_NAND=y CONFIG_SPI_FLASH=y CONFIG_SF_DEFAULT_BUS=1 +CONFIG_SPI_FLASH_SPANSION=y CONFIG_PHYLIB=y CONFIG_E1000=y CONFIG_FMAN_ENET=y @@ -55,6 +56,7 @@ CONFIG_DM_SCSI=y CONFIG_SYS_NS16550=y CONFIG_SPI=y CONFIG_DM_SPI=y +CONFIG_FSL_QSPI=y CONFIG_USB=y CONFIG_DM_USB=y CONFIG_USB_XHCI_HCD=y diff --git a/configs/ls1043aqds_tfa_defconfig b/configs/ls1043aqds_tfa_defconfig index 4c757e2..a670963 100644 --- a/configs/ls1043aqds_tfa_defconfig +++ b/configs/ls1043aqds_tfa_defconfig @@ -54,6 +54,7 @@ CONFIG_MTD_RAW_NAND=y CONFIG_SPI_FLASH=y CONFIG_SF_DEFAULT_BUS=1 # CONFIG_SPI_FLASH_BAR is not set +CONFIG_SPI_FLASH_SPANSION=y CONFIG_PHYLIB=y CONFIG_E1000=y CONFIG_FMAN_ENET=y diff --git a/include/configs/ls1043aqds.h b/include/configs/ls1043aqds.h index 063e724..fef5a2e 100644 --- a/include/configs/ls1043aqds.h +++ b/include/configs/ls1043aqds.h @@ -379,14 +379,6 @@ unsigned long get_board_ddr_clk(void); #define VDD_MV_MIN 819 #define VDD_MV_MAX 1212
-/* QSPI device */ -#if defined(CONFIG_TFABOOT) || \ - (defined(CONFIG_QSPI_BOOT) || defined(CONFIG_SD_BOOT_QSPI)) -#ifdef CONFIG_FSL_QSPI -#define CONFIG_SPI_FLASH_SPANSION -#endif -#endif - /* * Miscellaneous configurable options */
This property is not used by the driver anymore so let's remove it. Other dts still have 'num-cs' set, but they need a resync with the Linux kernel anyway, so let's only do the U-Boot-specific files for now.
v4: No change v3: No change v2: No change
arch/arm/dts/imx6sx-sabreauto-u-boot.dtsi | 2 -- arch/arm/dts/imx6sx-sdb-u-boot.dtsi | 2 -- 2 files changed, 4 deletions(-)
diff --git a/arch/arm/dts/imx6sx-sabreauto-u-boot.dtsi b/arch/arm/dts/imx6sx-sabreauto-u-boot.dtsi index 549461d..5200448 100644 --- a/arch/arm/dts/imx6sx-sabreauto-u-boot.dtsi +++ b/arch/arm/dts/imx6sx-sabreauto-u-boot.dtsi @@ -4,8 +4,6 @@ */
&qspi1 { - num-cs = <2>; - flash0: n25q256a@0 { compatible = "jedec,spi-nor"; }; diff --git a/arch/arm/dts/imx6sx-sdb-u-boot.dtsi b/arch/arm/dts/imx6sx-sdb-u-boot.dtsi index 8f9236d..3c0fd87 100644 --- a/arch/arm/dts/imx6sx-sdb-u-boot.dtsi +++ b/arch/arm/dts/imx6sx-sdb-u-boot.dtsi @@ -4,8 +4,6 @@ */
&qspi2 { - num-cs = <2>; - flash0: n25q256a@0 { compatible = "jedec,spi-nor"; };
-----Original Message----- From: U-Boot u-boot-bounces@lists.denx.de On Behalf Of Kuldeep Singh Sent: Monday, January 13, 2020 12:56 PM To: u-boot@lists.denx.de Cc: sr@denx.de Subject: [Patch v4 4/7] imx: imx6sx: Remove unused 'num-cs' property
&qspi1 {
- num-cs = <2>;
diff --git a/arch/arm/dts/imx6sx-sdb-u-boot.dtsi b/arch/arm/dts/imx6sx-sdb- u-boot.dtsi index 8f9236d..3c0fd87 100644 --- a/arch/arm/dts/imx6sx-sdb-u-boot.dtsi +++ b/arch/arm/dts/imx6sx-sdb-u-boot.dtsi @@ -4,8 +4,6 @@ */
&qspi2 {
- num-cs = <2>;
-- 2.7.4
Stefano/Fabio,
Please review/ack this patch.
Thanks Priyanka
Hi Priyanka,
On Wed, Feb 19, 2020 at 7:13 AM Priyanka Jain (OSS) priyanka.jain@oss.nxp.com wrote:
Stefano/Fabio,
Last month I did a patch series to sync the imx6sx device tree files with upstream kernel, but thanks to your email I have just realized that I missed to send it to the list.
Just sent it to the list: https://lists.denx.de/pipermail/u-boot/2020-February/400727.html
After my series gets applied this patch will no longer be needed.
Regards,
Fabio Estevam
Hi Fabio,
-----Original Message----- From: Fabio Estevam festevam@gmail.com Sent: Wednesday, February 19, 2020 6:31 PM To: Priyanka Jain (OSS) priyanka.jain@oss.nxp.com Cc: Kuldeep Singh kuldeep.singh@nxp.com; u-boot@lists.denx.de; Stefano Babic sbabic@denx.de; sr@denx.de Subject: [EXT] Re: [Patch v4 4/7] imx: imx6sx: Remove unused 'num-cs' property
Caution: EXT Email
Hi Priyanka,
Stefano/Fabio,
Just sent it to the list: https://eur01.safelinks.protection.outlook.com/?url=https%3A%2F%2Flists. denx.de%2Fpipermail%2Fu-boot%2F2020- February%2F400727.html&data=02%7C01%7Ckuldeep.singh%40nxp.c om%7C051c54e8e136406ca45d08d7b53bc31f%7C686ea1d3bc2b4c6fa92cd 99c5c301635%7C0%7C0%7C637177140593582319&sdata=OhuEC000t b6rbd5LXYhM0jxfbaVbVC8%2BepA5cNx%2BdxI%3D&reserved=0
Ok. I will drop this patch from series.
Thanks Kuldeep
Regards,
Fabio Estevam
Since CONFIG_FSL_QSPI is already enabled for LS1012A in defconfigs. Also enable CONFIG_SPI_FLASH_SPANSION for LS1012A boards having spansion flashes.
v4: Reword commit message. Add "in defconfigs" v3: Reword commit message. v2: No change
configs/ls1012a2g5rdb_qspi_defconfig | 1 + configs/ls1012a2g5rdb_tfa_defconfig | 1 + configs/ls1012afrdm_qspi_defconfig | 1 + configs/ls1012afrdm_tfa_defconfig | 1 + configs/ls1012aqds_qspi_defconfig | 1 + configs/ls1012aqds_tfa_SECURE_BOOT_defconfig | 1 + configs/ls1012aqds_tfa_defconfig | 1 + configs/ls1012ardb_qspi_SECURE_BOOT_defconfig | 1 + configs/ls1012ardb_qspi_defconfig | 1 + configs/ls1012ardb_tfa_SECURE_BOOT_defconfig | 1 + configs/ls1012ardb_tfa_defconfig | 1 + include/configs/ls1012a_common.h | 1 - 12 files changed, 11 insertions(+), 1 deletion(-)
diff --git a/configs/ls1012a2g5rdb_qspi_defconfig b/configs/ls1012a2g5rdb_qspi_defconfig index 3c99a43..c98974e 100644 --- a/configs/ls1012a2g5rdb_qspi_defconfig +++ b/configs/ls1012a2g5rdb_qspi_defconfig @@ -40,6 +40,7 @@ CONFIG_FSL_ESDHC=y CONFIG_MTD=y CONFIG_DM_SPI_FLASH=y # CONFIG_SPI_FLASH_BAR is not set +CONFIG_SPI_FLASH_SPANSION=y # CONFIG_SPI_FLASH_USE_4K_SECTORS is not set CONFIG_FSL_PFE=y CONFIG_DM_ETH=y diff --git a/configs/ls1012a2g5rdb_tfa_defconfig b/configs/ls1012a2g5rdb_tfa_defconfig index 0865ac2..8647223 100644 --- a/configs/ls1012a2g5rdb_tfa_defconfig +++ b/configs/ls1012a2g5rdb_tfa_defconfig @@ -40,6 +40,7 @@ CONFIG_FSL_ESDHC=y CONFIG_MTD=y CONFIG_DM_SPI_FLASH=y # CONFIG_SPI_FLASH_BAR is not set +CONFIG_SPI_FLASH_SPANSION=y # CONFIG_SPI_FLASH_USE_4K_SECTORS is not set CONFIG_FSL_PFE=y CONFIG_DM_ETH=y diff --git a/configs/ls1012afrdm_qspi_defconfig b/configs/ls1012afrdm_qspi_defconfig index 7ff0955..3db5181 100644 --- a/configs/ls1012afrdm_qspi_defconfig +++ b/configs/ls1012afrdm_qspi_defconfig @@ -36,6 +36,7 @@ CONFIG_DM=y CONFIG_MTD=y CONFIG_DM_SPI_FLASH=y # CONFIG_SPI_FLASH_BAR is not set +CONFIG_SPI_FLASH_SPANSION=y # CONFIG_SPI_FLASH_USE_4K_SECTORS is not set CONFIG_FSL_PFE=y CONFIG_DM_ETH=y diff --git a/configs/ls1012afrdm_tfa_defconfig b/configs/ls1012afrdm_tfa_defconfig index 8e8ddd7..ffbf79f 100644 --- a/configs/ls1012afrdm_tfa_defconfig +++ b/configs/ls1012afrdm_tfa_defconfig @@ -36,6 +36,7 @@ CONFIG_DM=y CONFIG_MTD=y CONFIG_DM_SPI_FLASH=y # CONFIG_SPI_FLASH_BAR is not set +CONFIG_SPI_FLASH_SPANSION=y # CONFIG_SPI_FLASH_USE_4K_SECTORS is not set CONFIG_FSL_PFE=y CONFIG_DM_ETH=y diff --git a/configs/ls1012aqds_qspi_defconfig b/configs/ls1012aqds_qspi_defconfig index 0a719c3..559db02 100644 --- a/configs/ls1012aqds_qspi_defconfig +++ b/configs/ls1012aqds_qspi_defconfig @@ -57,6 +57,7 @@ CONFIG_SF_DEFAULT_BUS=1 CONFIG_SF_DEFAULT_MODE=0 CONFIG_SF_DEFAULT_SPEED=10000000 # CONFIG_SPI_FLASH_BAR is not set +CONFIG_SPI_FLASH_SPANSION=y # CONFIG_SPI_FLASH_USE_4K_SECTORS is not set CONFIG_FSL_PFE=y CONFIG_DM_ETH=y diff --git a/configs/ls1012aqds_tfa_SECURE_BOOT_defconfig b/configs/ls1012aqds_tfa_SECURE_BOOT_defconfig index 25d06d2..f012c34 100644 --- a/configs/ls1012aqds_tfa_SECURE_BOOT_defconfig +++ b/configs/ls1012aqds_tfa_SECURE_BOOT_defconfig @@ -47,6 +47,7 @@ CONFIG_SF_DEFAULT_BUS=1 CONFIG_SF_DEFAULT_MODE=0 CONFIG_SF_DEFAULT_SPEED=10000000 # CONFIG_SPI_FLASH_BAR is not set +CONFIG_SPI_FLASH_SPANSION=y # CONFIG_SPI_FLASH_USE_4K_SECTORS is not set CONFIG_FSL_PFE=y CONFIG_DM_ETH=y diff --git a/configs/ls1012aqds_tfa_defconfig b/configs/ls1012aqds_tfa_defconfig index bde53a4..37693a0 100644 --- a/configs/ls1012aqds_tfa_defconfig +++ b/configs/ls1012aqds_tfa_defconfig @@ -57,6 +57,7 @@ CONFIG_SF_DEFAULT_BUS=1 CONFIG_SF_DEFAULT_MODE=0 CONFIG_SF_DEFAULT_SPEED=10000000 # CONFIG_SPI_FLASH_BAR is not set +CONFIG_SPI_FLASH_SPANSION=y # CONFIG_SPI_FLASH_USE_4K_SECTORS is not set CONFIG_FSL_PFE=y CONFIG_DM_ETH=y diff --git a/configs/ls1012ardb_qspi_SECURE_BOOT_defconfig b/configs/ls1012ardb_qspi_SECURE_BOOT_defconfig index 9989f7b..5129ec5 100644 --- a/configs/ls1012ardb_qspi_SECURE_BOOT_defconfig +++ b/configs/ls1012ardb_qspi_SECURE_BOOT_defconfig @@ -39,6 +39,7 @@ CONFIG_FSL_ESDHC=y CONFIG_MTD=y CONFIG_DM_SPI_FLASH=y # CONFIG_SPI_FLASH_BAR is not set +CONFIG_SPI_FLASH_SPANSION=y # CONFIG_SPI_FLASH_USE_4K_SECTORS is not set CONFIG_E1000=y CONFIG_PCI=y diff --git a/configs/ls1012ardb_qspi_defconfig b/configs/ls1012ardb_qspi_defconfig index 80ca9bd..e4f3272 100644 --- a/configs/ls1012ardb_qspi_defconfig +++ b/configs/ls1012ardb_qspi_defconfig @@ -41,6 +41,7 @@ CONFIG_FSL_ESDHC=y CONFIG_MTD=y CONFIG_DM_SPI_FLASH=y # CONFIG_SPI_FLASH_BAR is not set +CONFIG_SPI_FLASH_SPANSION=y # CONFIG_SPI_FLASH_USE_4K_SECTORS is not set CONFIG_FSL_PFE=y CONFIG_DM_ETH=y diff --git a/configs/ls1012ardb_tfa_SECURE_BOOT_defconfig b/configs/ls1012ardb_tfa_SECURE_BOOT_defconfig index 8eb71fc..3dc7e5a 100644 --- a/configs/ls1012ardb_tfa_SECURE_BOOT_defconfig +++ b/configs/ls1012ardb_tfa_SECURE_BOOT_defconfig @@ -39,6 +39,7 @@ CONFIG_FSL_ESDHC=y CONFIG_MTD=y CONFIG_DM_SPI_FLASH=y # CONFIG_SPI_FLASH_BAR is not set +CONFIG_SPI_FLASH_SPANSION=y # CONFIG_SPI_FLASH_USE_4K_SECTORS is not set CONFIG_E1000=y CONFIG_PCI=y diff --git a/configs/ls1012ardb_tfa_defconfig b/configs/ls1012ardb_tfa_defconfig index 1cc358c..b4c5d36 100644 --- a/configs/ls1012ardb_tfa_defconfig +++ b/configs/ls1012ardb_tfa_defconfig @@ -42,6 +42,7 @@ CONFIG_FSL_ESDHC=y CONFIG_MTD=y CONFIG_DM_SPI_FLASH=y # CONFIG_SPI_FLASH_BAR is not set +CONFIG_SPI_FLASH_SPANSION=y # CONFIG_SPI_FLASH_USE_4K_SECTORS is not set CONFIG_FSL_PFE=y CONFIG_DM_ETH=y diff --git a/include/configs/ls1012a_common.h b/include/configs/ls1012a_common.h index 1568451..efd0ee4 100644 --- a/include/configs/ls1012a_common.h +++ b/include/configs/ls1012a_common.h @@ -39,7 +39,6 @@ /*SPI device */ #define CONFIG_SYS_FMAN_FW_ADDR 0x400d0000 #define CONFIG_SYS_FSL_QSPI_BASE 0x40000000 -#define CONFIG_SPI_FLASH_SPANSION
Enable CONFIG_SPI_FLASH_SPANSION in defconfigs of LS1046ARDB and LS1046AQDS which have two spansion flases i.e s25fs512s each of size 64M.
configs/ls1046aqds_qspi_defconfig | 1 + configs/ls1046aqds_sdcard_qspi_defconfig | 1 + configs/ls1046aqds_tfa_SECURE_BOOT_defconfig | 1 + configs/ls1046aqds_tfa_defconfig | 1 + configs/ls1046ardb_qspi_SECURE_BOOT_defconfig | 1 + configs/ls1046ardb_qspi_defconfig | 1 + configs/ls1046ardb_tfa_SECURE_BOOT_defconfig | 1 + configs/ls1046ardb_tfa_defconfig | 1 + include/configs/ls1046aqds.h | 8 -------- include/configs/ls1046ardb.h | 7 ------- 10 files changed, 8 insertions(+), 15 deletions(-)
diff --git a/configs/ls1046aqds_qspi_defconfig b/configs/ls1046aqds_qspi_defconfig index 7339aba..b2098c8 100644 --- a/configs/ls1046aqds_qspi_defconfig +++ b/configs/ls1046aqds_qspi_defconfig @@ -38,6 +38,7 @@ CONFIG_FSL_CAAM=y CONFIG_DM_MMC=y CONFIG_FSL_ESDHC=y # CONFIG_SPI_FLASH_BAR is not set +CONFIG_SPI_FLASH_SPANSION=y # CONFIG_SPI_FLASH_USE_4K_SECTORS is not set CONFIG_PHYLIB=y CONFIG_E1000=y diff --git a/configs/ls1046aqds_sdcard_qspi_defconfig b/configs/ls1046aqds_sdcard_qspi_defconfig index 10e6933..4c21e6a 100644 --- a/configs/ls1046aqds_sdcard_qspi_defconfig +++ b/configs/ls1046aqds_sdcard_qspi_defconfig @@ -54,6 +54,7 @@ CONFIG_FSL_CAAM=y CONFIG_DM_MMC=y CONFIG_FSL_ESDHC=y # CONFIG_SPI_FLASH_BAR is not set +CONFIG_SPI_FLASH_SPANSION=y # CONFIG_SPI_FLASH_USE_4K_SECTORS is not set CONFIG_PHYLIB=y CONFIG_E1000=y diff --git a/configs/ls1046aqds_tfa_SECURE_BOOT_defconfig b/configs/ls1046aqds_tfa_SECURE_BOOT_defconfig index e173747..0edbac3 100644 --- a/configs/ls1046aqds_tfa_SECURE_BOOT_defconfig +++ b/configs/ls1046aqds_tfa_SECURE_BOOT_defconfig @@ -43,6 +43,7 @@ CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_SYS_FLASH_CFI=y CONFIG_MTD_RAW_NAND=y CONFIG_SF_DEFAULT_BUS=1 +CONFIG_SPI_FLASH_SPANSION=y CONFIG_PHYLIB=y CONFIG_E1000=y CONFIG_FMAN_ENET=y diff --git a/configs/ls1046aqds_tfa_defconfig b/configs/ls1046aqds_tfa_defconfig index 83e94ec..5cb973e 100644 --- a/configs/ls1046aqds_tfa_defconfig +++ b/configs/ls1046aqds_tfa_defconfig @@ -53,6 +53,7 @@ CONFIG_SYS_FLASH_CFI=y CONFIG_MTD_RAW_NAND=y CONFIG_SF_DEFAULT_BUS=1 # CONFIG_SPI_FLASH_BAR is not set +CONFIG_SPI_FLASH_SPANSION=y CONFIG_PHYLIB=y CONFIG_E1000=y CONFIG_FMAN_ENET=y diff --git a/configs/ls1046ardb_qspi_SECURE_BOOT_defconfig b/configs/ls1046ardb_qspi_SECURE_BOOT_defconfig index 469ef76..ef82b39 100644 --- a/configs/ls1046ardb_qspi_SECURE_BOOT_defconfig +++ b/configs/ls1046ardb_qspi_SECURE_BOOT_defconfig @@ -34,6 +34,7 @@ CONFIG_FSL_ESDHC=y CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y # CONFIG_SPI_FLASH_BAR is not set +CONFIG_SPI_FLASH_SPANSION=y # CONFIG_SPI_FLASH_USE_4K_SECTORS is not set CONFIG_PHYLIB=y CONFIG_PHY_AQUANTIA=y diff --git a/configs/ls1046ardb_qspi_defconfig b/configs/ls1046ardb_qspi_defconfig index 934f04a..9418128 100644 --- a/configs/ls1046ardb_qspi_defconfig +++ b/configs/ls1046ardb_qspi_defconfig @@ -37,6 +37,7 @@ CONFIG_FSL_ESDHC=y CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y # CONFIG_SPI_FLASH_BAR is not set +CONFIG_SPI_FLASH_SPANSION=y # CONFIG_SPI_FLASH_USE_4K_SECTORS is not set CONFIG_PHYLIB=y CONFIG_PHY_AQUANTIA=y diff --git a/configs/ls1046ardb_tfa_SECURE_BOOT_defconfig b/configs/ls1046ardb_tfa_SECURE_BOOT_defconfig index 9aeb331..d980212 100644 --- a/configs/ls1046ardb_tfa_SECURE_BOOT_defconfig +++ b/configs/ls1046ardb_tfa_SECURE_BOOT_defconfig @@ -34,6 +34,7 @@ CONFIG_FSL_ESDHC=y CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y # CONFIG_SPI_FLASH_BAR is not set +CONFIG_SPI_FLASH_SPANSION=y # CONFIG_SPI_FLASH_USE_4K_SECTORS is not set CONFIG_PHYLIB=y CONFIG_PHY_AQUANTIA=y diff --git a/configs/ls1046ardb_tfa_defconfig b/configs/ls1046ardb_tfa_defconfig index 2772fa5..21b6041 100644 --- a/configs/ls1046ardb_tfa_defconfig +++ b/configs/ls1046ardb_tfa_defconfig @@ -39,6 +39,7 @@ CONFIG_FSL_ESDHC=y CONFIG_MTD=y CONFIG_MTD_RAW_NAND=y # CONFIG_SPI_FLASH_BAR is not set +CONFIG_SPI_FLASH_SPANSION=y # CONFIG_SPI_FLASH_USE_4K_SECTORS is not set CONFIG_PHYLIB=y CONFIG_PHY_AQUANTIA=y diff --git a/include/configs/ls1046aqds.h b/include/configs/ls1046aqds.h index 437b6ac..8d74f32 100644 --- a/include/configs/ls1046aqds.h +++ b/include/configs/ls1046aqds.h @@ -41,14 +41,6 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_SPI_FLASH_EON /* cs2 */ #endif
-/* QSPI */ -#if defined(CONFIG_TFABOOT) || \ - defined(CONFIG_QSPI_BOOT) || defined(CONFIG_SD_BOOT_QSPI) -#ifdef CONFIG_FSL_QSPI -#define CONFIG_SPI_FLASH_SPANSION -#endif -#endif - #ifdef CONFIG_SYS_DPAA_FMAN #define CONFIG_PHY_VITESSE #define CONFIG_PHY_REALTEK diff --git a/include/configs/ls1046ardb.h b/include/configs/ls1046ardb.h index 61a4a40..6db48f7 100644 --- a/include/configs/ls1046ardb.h +++ b/include/configs/ls1046ardb.h @@ -180,13 +180,6 @@
#endif
-/* QSPI device */ -#ifndef SPL_NO_QSPI -#ifdef CONFIG_FSL_QSPI -#define CONFIG_SPI_FLASH_SPANSION -#endif -#endif - #ifndef SPL_NO_MISC #undef CONFIG_BOOTCOMMAND #ifdef CONFIG_TFABOOT
According to new qspi driver, some properties like "bus-num, num-cs, big-endian" are no longer used. Device endiannes can be determined from device-type data in driver.
Now use board specific compatibles, generic node names and specific labels to align with linux device-tree properties.
Also consolidate spi-max-frequency to 50Mhz treewide.
arch/arm/dts/fsl-ls1012a-2g5rdb.dts | 5 ++--- arch/arm/dts/fsl-ls1012a-frdm.dtsi | 5 ++--- arch/arm/dts/fsl-ls1012a-qds.dtsi | 5 ++--- arch/arm/dts/fsl-ls1012a-rdb.dtsi | 5 ++--- arch/arm/dts/fsl-ls1012a.dtsi | 4 +--- arch/arm/dts/fsl-ls1043a-qds.dtsi | 5 ++--- arch/arm/dts/fsl-ls1043a.dtsi | 6 ++---- arch/arm/dts/fsl-ls1046a-frwy.dts | 5 ++--- arch/arm/dts/fsl-ls1046a-qds.dtsi | 5 ++--- arch/arm/dts/fsl-ls1046a-rdb.dts | 5 ++--- arch/arm/dts/fsl-ls1046a.dtsi | 4 +--- arch/arm/dts/fsl-ls1088a-qds.dts | 5 ++--- arch/arm/dts/fsl-ls1088a-rdb.dts | 5 ++--- arch/arm/dts/fsl-ls1088a.dtsi | 2 +- arch/arm/dts/fsl-ls2080a-qds.dts | 5 ++--- arch/arm/dts/fsl-ls2080a.dtsi | 4 ++-- arch/arm/dts/fsl-ls2088a-rdb-qspi.dts | 5 ++--- arch/arm/dts/ls1021a-twr.dtsi | 5 ++--- arch/arm/dts/ls1021a.dtsi | 6 ++---- 19 files changed, 35 insertions(+), 56 deletions(-)
diff --git a/arch/arm/dts/fsl-ls1012a-2g5rdb.dts b/arch/arm/dts/fsl-ls1012a-2g5rdb.dts index fecef88..6402cf5 100644 --- a/arch/arm/dts/fsl-ls1012a-2g5rdb.dts +++ b/arch/arm/dts/fsl-ls1012a-2g5rdb.dts @@ -21,14 +21,13 @@ };
&qspi { - bus-num = <0>; status = "okay";
- qflash0: s25fl128s@0 { + s25fs512s0: flash@0 { #address-cells = <1>; #size-cells = <1>; compatible = "jedec,spi-nor"; - spi-max-frequency = <20000000>; + spi-max-frequency = <50000000>; reg = <0>; }; }; diff --git a/arch/arm/dts/fsl-ls1012a-frdm.dtsi b/arch/arm/dts/fsl-ls1012a-frdm.dtsi index a357793..88aa24a 100644 --- a/arch/arm/dts/fsl-ls1012a-frdm.dtsi +++ b/arch/arm/dts/fsl-ls1012a-frdm.dtsi @@ -15,14 +15,13 @@ };
- qflash0: s25fl128s@0 { + s25fs512s0: flash@0 { #address-cells = <1>; #size-cells = <1>; compatible = "jedec,spi-nor"; - spi-max-frequency = <20000000>; + spi-max-frequency = <50000000>; reg = <0>; }; }; diff --git a/arch/arm/dts/fsl-ls1012a-qds.dtsi b/arch/arm/dts/fsl-ls1012a-qds.dtsi index a330597..910d2a5 100644 --- a/arch/arm/dts/fsl-ls1012a-qds.dtsi +++ b/arch/arm/dts/fsl-ls1012a-qds.dtsi @@ -43,14 +43,13 @@ };
- qflash0: s25fl128s@0 { + s25fs512s0: flash@0 { #address-cells = <1>; #size-cells = <1>; compatible = "jedec,spi-nor"; - spi-max-frequency = <20000000>; + spi-max-frequency = <50000000>; reg = <0>; }; }; diff --git a/arch/arm/dts/fsl-ls1012a-rdb.dtsi b/arch/arm/dts/fsl-ls1012a-rdb.dtsi index 55155fd..3757051 100644 --- a/arch/arm/dts/fsl-ls1012a-rdb.dtsi +++ b/arch/arm/dts/fsl-ls1012a-rdb.dtsi @@ -19,14 +19,13 @@ };
- qflash0: s25fl128s@0 { + s25fs512s0: flash@0 { #address-cells = <1>; #size-cells = <1>; compatible = "jedec,spi-nor"; - spi-max-frequency = <20000000>; + spi-max-frequency = <50000000>; reg = <0>; }; }; diff --git a/arch/arm/dts/fsl-ls1012a.dtsi b/arch/arm/dts/fsl-ls1012a.dtsi index 1125e57..2d70c82 100644 --- a/arch/arm/dts/fsl-ls1012a.dtsi +++ b/arch/arm/dts/fsl-ls1012a.dtsi @@ -107,14 +107,12 @@ };
qspi: quadspi@1550000 { - compatible = "fsl,vf610-qspi"; + compatible = "fsl,ls1021a-qspi"; #address-cells = <1>; #size-cells = <0>; reg = <0x0 0x1550000 0x0 0x10000>, <0x0 0x40000000 0x0 0x4000000>; reg-names = "QuadSPI", "QuadSPI-memory"; - num-cs = <1>; - big-endian; status = "disabled"; };
diff --git a/arch/arm/dts/fsl-ls1043a-qds.dtsi b/arch/arm/dts/fsl-ls1043a-qds.dtsi index 70e1a6a..884bdad 100644 --- a/arch/arm/dts/fsl-ls1043a-qds.dtsi +++ b/arch/arm/dts/fsl-ls1043a-qds.dtsi @@ -53,14 +53,13 @@ };
- qflash0: s25fl128s@0 { + s25fl128s0: flash@0 { #address-cells = <1>; #size-cells = <1>; compatible = "jedec,spi-nor"; - spi-max-frequency = <20000000>; + spi-max-frequency = <50000000>; reg = <0>; }; }; diff --git a/arch/arm/dts/fsl-ls1043a.dtsi b/arch/arm/dts/fsl-ls1043a.dtsi index b159c3c..1c1bd50 100644 --- a/arch/arm/dts/fsl-ls1043a.dtsi +++ b/arch/arm/dts/fsl-ls1043a.dtsi @@ -210,14 +210,12 @@ status = "disabled"; }; qspi: quadspi@1550000 { - compatible = "fsl,vf610-qspi"; + compatible = "fsl,ls1021a-qspi"; #address-cells = <1>; #size-cells = <0>; reg = <0x0 0x1550000 0x0 0x10000>, - <0x0 0x40000000 0x0 0x4000000>; + <0x0 0x40000000 0x0 0x1000000>; reg-names = "QuadSPI", "QuadSPI-memory"; - num-cs = <2>; - big-endian; status = "disabled"; };
diff --git a/arch/arm/dts/fsl-ls1046a-frwy.dts b/arch/arm/dts/fsl-ls1046a-frwy.dts index 3d41e3b..8dace8f 100644 --- a/arch/arm/dts/fsl-ls1046a-frwy.dts +++ b/arch/arm/dts/fsl-ls1046a-frwy.dts @@ -19,13 +19,12 @@ };
- qflash0: mt25qu512abb8esf@0 { + mt25qu512a0: flash@0 { #address-cells = <1>; #size-cells = <1>; - compatible = "spi-flash"; + compatible = "jedec,spi-nor"; spi-max-frequency = <50000000>; reg = <0>; }; diff --git a/arch/arm/dts/fsl-ls1046a-qds.dtsi b/arch/arm/dts/fsl-ls1046a-qds.dtsi index c95f44f..8aa56a8 100644 --- a/arch/arm/dts/fsl-ls1046a-qds.dtsi +++ b/arch/arm/dts/fsl-ls1046a-qds.dtsi @@ -53,14 +53,13 @@ };
- qflash0: s25fl128s@0 { + s25fs512s0: flash@0 { #address-cells = <1>; #size-cells = <1>; compatible = "jedec,spi-nor"; - spi-max-frequency = <20000000>; + spi-max-frequency = <50000000>; reg = <0>; }; }; diff --git a/arch/arm/dts/fsl-ls1046a-rdb.dts b/arch/arm/dts/fsl-ls1046a-rdb.dts index a05c9e9..94fab66 100644 --- a/arch/arm/dts/fsl-ls1046a-rdb.dts +++ b/arch/arm/dts/fsl-ls1046a-rdb.dts @@ -20,10 +20,9 @@ };
- qflash0: s25fs512s@0 { + s25fs512s0: flash@0 { #address-cells = <1>; #size-cells = <1>; compatible = "jedec,spi-nor"; @@ -31,7 +30,7 @@ reg = <0>; };
- qflash1: s25fs512s@1 { + s25fs512s1: flash@1 { #address-cells = <1>; #size-cells = <1>; compatible = "jedec,spi-nor"; diff --git a/arch/arm/dts/fsl-ls1046a.dtsi b/arch/arm/dts/fsl-ls1046a.dtsi index fdf93fd..47777e9 100644 --- a/arch/arm/dts/fsl-ls1046a.dtsi +++ b/arch/arm/dts/fsl-ls1046a.dtsi @@ -211,14 +211,12 @@ };
qspi: quadspi@1550000 { - compatible = "fsl,vf610-qspi"; + compatible = "fsl,ls1021a-qspi"; #address-cells = <1>; #size-cells = <0>; reg = <0x0 0x1550000 0x0 0x10000>, <0x0 0x40000000 0x0 0x10000000>; reg-names = "QuadSPI", "QuadSPI-memory"; - num-cs = <4>; - big-endian; status = "disabled"; };
diff --git a/arch/arm/dts/fsl-ls1088a-qds.dts b/arch/arm/dts/fsl-ls1088a-qds.dts index f07d0c6..4f37a28 100644 --- a/arch/arm/dts/fsl-ls1088a-qds.dts +++ b/arch/arm/dts/fsl-ls1088a-qds.dts @@ -108,10 +108,9 @@ };
- qflash0: s25fs512s@0 { + s25fs512s0: flash@0 { #address-cells = <1>; #size-cells = <1>; compatible = "jedec,spi-nor"; @@ -119,7 +118,7 @@ reg = <0>; };
- qflash1: s25fs512s@1 { + s25fs512s1: flash@1 { #address-cells = <1>; #size-cells = <1>; compatible = "jedec,spi-nor"; diff --git a/arch/arm/dts/fsl-ls1088a-rdb.dts b/arch/arm/dts/fsl-ls1088a-rdb.dts index 0fe3519..858aef8 100644 --- a/arch/arm/dts/fsl-ls1088a-rdb.dts +++ b/arch/arm/dts/fsl-ls1088a-rdb.dts @@ -41,10 +41,9 @@ };
- qflash0: s25fs512s@0 { + s25fs512s0: flash@0 { #address-cells = <1>; #size-cells = <1>; compatible = "jedec,spi-nor"; @@ -52,7 +51,7 @@ reg = <0>; };
- qflash1: s25fs512s@1 { + s25fs512s1: flash@1 { #address-cells = <1>; #size-cells = <1>; compatible = "jedec,spi-nor"; diff --git a/arch/arm/dts/fsl-ls1088a.dtsi b/arch/arm/dts/fsl-ls1088a.dtsi index abc8b21..87f7814 100644 --- a/arch/arm/dts/fsl-ls1088a.dtsi +++ b/arch/arm/dts/fsl-ls1088a.dtsi @@ -98,7 +98,7 @@ };
qspi: quadspi@1550000 { - compatible = "fsl,vf610-qspi"; + compatible = "fsl,ls1088a-qspi"; #address-cells = <1>; #size-cells = <0>; reg = <0x0 0x20c0000 0x0 0x10000>, diff --git a/arch/arm/dts/fsl-ls2080a-qds.dts b/arch/arm/dts/fsl-ls2080a-qds.dts index 13461b5..f91a48d 100644 --- a/arch/arm/dts/fsl-ls2080a-qds.dts +++ b/arch/arm/dts/fsl-ls2080a-qds.dts @@ -72,14 +72,13 @@ };
- qflash0: s25fs256s@0 { + s25fs256s0: flash@0 { #address-cells = <1>; #size-cells = <1>; compatible = "jedec,spi-nor"; - spi-max-frequency = <20000000>; + spi-max-frequency = <50000000>; reg = <0>; }; }; diff --git a/arch/arm/dts/fsl-ls2080a.dtsi b/arch/arm/dts/fsl-ls2080a.dtsi index 99ed33a..0eed7cc 100644 --- a/arch/arm/dts/fsl-ls2080a.dtsi +++ b/arch/arm/dts/fsl-ls2080a.dtsi @@ -102,13 +102,13 @@ };
qspi: quadspi@1550000 { - compatible = "fsl,vf610-qspi"; + compatible = "fsl,ls2080a-qspi"; #address-cells = <1>; #size-cells = <0>; reg = <0x0 0x20c0000 0x0 0x10000>, <0x0 0x20000000 0x0 0x10000000>; reg-names = "QuadSPI", "QuadSPI-memory"; - num-cs = <4>; + status = "disabled"; };
esdhc: esdhc@0 { diff --git a/arch/arm/dts/fsl-ls2088a-rdb-qspi.dts b/arch/arm/dts/fsl-ls2088a-rdb-qspi.dts index 72b2177..cabe43f 100644 --- a/arch/arm/dts/fsl-ls2088a-rdb-qspi.dts +++ b/arch/arm/dts/fsl-ls2088a-rdb-qspi.dts @@ -37,10 +37,9 @@ };
- qflash0: s25fs512s@0 { + s25fs512s0: flash@0 { #address-cells = <1>; #size-cells = <1>; compatible = "jedec,spi-nor"; @@ -48,7 +47,7 @@ reg = <0>; };
- qflash1: s25fs512s@1 { + s25fs512s1: flash@1 { #address-cells = <1>; #size-cells = <1>; compatible = "jedec,spi-nor"; diff --git a/arch/arm/dts/ls1021a-twr.dtsi b/arch/arm/dts/ls1021a-twr.dtsi index 27c96f9..bf96af7 100644 --- a/arch/arm/dts/ls1021a-twr.dtsi +++ b/arch/arm/dts/ls1021a-twr.dtsi @@ -24,14 +24,13 @@ };
- qflash0: n25q128a13@0 { + n25q128a130: flash@0 { #address-cells = <1>; #size-cells = <1>; compatible = "jedec,spi-nor"; - spi-max-frequency = <20000000>; + spi-max-frequency = <50000000>; reg = <0>; }; }; diff --git a/arch/arm/dts/ls1021a.dtsi b/arch/arm/dts/ls1021a.dtsi index e419d9c..0eeec43 100644 --- a/arch/arm/dts/ls1021a.dtsi +++ b/arch/arm/dts/ls1021a.dtsi @@ -169,14 +169,12 @@ };
qspi: quadspi@1550000 { - compatible = "fsl,vf610-qspi"; + compatible = "fsl,ls1021a-qspi"; #address-cells = <1>; #size-cells = <0>; reg = <0x1550000 0x10000>, - <0x40000000 0x4000000>; + <0x40000000 0x1000000>; reg-names = "QuadSPI", "QuadSPI-memory"; - num-cs = <2>; - big-endian; status = "disabled"; };
Hi Vignesh,
On Mon, Jan 13, 2020 at 12:57 PM Kuldeep Singh kuldeep.singh@nxp.com wrote:
This entire patch series migrate freescale qspi driver to spi-mem framework.
v4 version of series include removal of buildman failure on LS2080AQDS build which was observed in cleanup patches. Also, more clear commit message of patch 5.
v3 version of series includes correction of copyright in qspi driver and also move SPI_FLASH_SPANSION from header to defconfigs in same patch.
v2 version of series includes changes in qspi driver to have 1k size instead of complete flash size so as to make driver independent of flash size. This also makes it align with linux version of driver. Also added support for imx platforms to set TDH bits correctly. There are other minor changes in commit messages.
Dependency on patches[1][2]. These patches are required to resolve booting crash observed in LS1012ARDB. One crash was related to pfe driver as it was accessing flash memory directly and other was based on environment. [1] https://patchwork.ozlabs.org/patch/1219462/ [2] https://patchwork.ozlabs.org/patch/1208299/
Patch 1 adds new qspi driver incorporating spi-mem framework and also removal of old driver which was based on spi-nor. The driver is a ported version of linux qspi driver. Initial port was done by Frieder. Now, no more direct memory access to spi-nor memory is possible i.e accessing flash memory using absolute address is not possible.
Patch 2 removes unused qspi config options.
Patch 3 moves FSL_QSPI to defconfig instead of defining it in header files.
Patch 4 removes unused num-cs property from imx platforms.
Patch 5 enables SPI_FLASH_SPANSION in ls1012a defconfig as FSL_QSPI is already enabled.
Patch 6 enables SPI_FLASH_SPANSION in defconfigs of LS1046a boards instead of defining in header files.
Patch 7 updates the device-tree properties treewide for layerscape boards by aligning with linux device-tree properties.
Frieder Schrempf (1): imx: imx6sx: Remove unused 'num-cs' property
Kuldeep Singh (6): spi: Transform the FSL QuadSPI driver to use the SPI MEM API treewide: Remove unused FSL QSPI config options configs: ls1043a: Move CONFIG_FSL_QSPI to defconfig configs: ls1012a: Enable CONFIG_SPI_FLASH_SPANSION in defconfigs configs: ls1046a: Move SPI_FLASH_SPANSION to defconfig treewide: Update fsl qspi node dt properties as per spi-mem driver
arch/arm/dts/fsl-ls1012a-2g5rdb.dts | 5 +- arch/arm/dts/fsl-ls1012a-frdm.dtsi | 5 +- arch/arm/dts/fsl-ls1012a-qds.dtsi | 5 +- arch/arm/dts/fsl-ls1012a-rdb.dtsi | 5 +- arch/arm/dts/fsl-ls1012a.dtsi | 4 +- arch/arm/dts/fsl-ls1043a-qds.dtsi | 5 +- arch/arm/dts/fsl-ls1043a.dtsi | 6 +- arch/arm/dts/fsl-ls1046a-frwy.dts | 5 +- arch/arm/dts/fsl-ls1046a-qds.dtsi | 5 +- arch/arm/dts/fsl-ls1046a-rdb.dts | 5 +- arch/arm/dts/fsl-ls1046a.dtsi | 4 +- arch/arm/dts/fsl-ls1088a-qds.dts | 5 +- arch/arm/dts/fsl-ls1088a-rdb.dts | 5 +- arch/arm/dts/fsl-ls1088a.dtsi | 2 +- arch/arm/dts/fsl-ls2080a-qds.dts | 5 +- arch/arm/dts/fsl-ls2080a.dtsi | 4 +- arch/arm/dts/fsl-ls2088a-rdb-qspi.dts | 5 +- arch/arm/dts/imx6sx-sabreauto-u-boot.dtsi | 2 - arch/arm/dts/imx6sx-sdb-u-boot.dtsi | 2 - arch/arm/dts/ls1021a-twr.dtsi | 5 +- arch/arm/dts/ls1021a.dtsi | 6 +- arch/arm/include/asm/arch-fsl-layerscape/config.h | 1 - arch/arm/include/asm/arch-ls102xa/config.h | 1 - configs/ls1012a2g5rdb_qspi_defconfig | 1 + configs/ls1012a2g5rdb_tfa_defconfig | 1 + configs/ls1012afrdm_qspi_defconfig | 1 + configs/ls1012afrdm_tfa_defconfig | 1 + configs/ls1012aqds_qspi_defconfig | 1 + configs/ls1012aqds_tfa_SECURE_BOOT_defconfig | 1 + configs/ls1012aqds_tfa_defconfig | 1 + configs/ls1012ardb_qspi_SECURE_BOOT_defconfig | 1 + configs/ls1012ardb_qspi_defconfig | 1 + configs/ls1012ardb_tfa_SECURE_BOOT_defconfig | 1 + configs/ls1012ardb_tfa_defconfig | 1 + configs/ls1043aqds_qspi_defconfig | 1 + configs/ls1043aqds_sdcard_qspi_defconfig | 1 + configs/ls1043aqds_tfa_SECURE_BOOT_defconfig | 2 + configs/ls1043aqds_tfa_defconfig | 1 + configs/ls1046aqds_qspi_defconfig | 1 + configs/ls1046aqds_sdcard_qspi_defconfig | 1 + configs/ls1046aqds_tfa_SECURE_BOOT_defconfig | 1 + configs/ls1046aqds_tfa_defconfig | 1 + configs/ls1046ardb_qspi_SECURE_BOOT_defconfig | 1 + configs/ls1046ardb_qspi_defconfig | 1 + configs/ls1046ardb_tfa_SECURE_BOOT_defconfig | 1 + configs/ls1046ardb_tfa_defconfig | 1 + drivers/spi/fsl_qspi.c | 1574 ++++++++------------- drivers/spi/fsl_qspi.h | 145 -- include/configs/ls1012a_common.h | 17 +- include/configs/ls1012afrwy.h | 3 - include/configs/ls1012ardb.h | 3 - include/configs/ls1021aiot.h | 6 - include/configs/ls1021aqds.h | 11 - include/configs/ls1021atwr.h | 10 - include/configs/ls1043aqds.h | 10 - include/configs/ls1046afrwy.h | 9 - include/configs/ls1046aqds.h | 19 - include/configs/ls1046ardb.h | 20 - include/configs/ls1088a_common.h | 6 - include/configs/ls1088aqds.h | 8 - include/configs/ls1088ardb.h | 18 - include/configs/ls2080aqds.h | 5 - include/configs/ls2080ardb.h | 6 +- include/configs/mx6sxsabreauto.h | 6 - include/configs/mx6sxsabresd.h | 11 - include/configs/mx6ul_14x14_evk.h | 6 - include/configs/mx6ullevk.h | 6 - include/configs/mx7dsabresd.h | 8 - include/configs/pcm052.h | 7 - include/configs/vf610twr.h | 8 - scripts/config_whitelist.txt | 5 - 71 files changed, 666 insertions(+), 1382 deletions(-) delete mode 100644 drivers/spi/fsl_qspi.h
Look fine to me, do you have any comments?
Hi Kuldeep,
Seems like defconfig changes of these were depends on net changes isn't it? if yes, we need to wait for them to merge first.
Jagan.
Hi Jagan,
-----Original Message----- From: Jagan Teki jagan@amarulasolutions.com Sent: Monday, January 27, 2020 12:50 PM To: Kuldeep Singh kuldeep.singh@nxp.com Cc: U-Boot-Denx u-boot@lists.denx.de; Priyanka Jain priyanka.jain@nxp.com; Ashish Kumar ashish.kumar@nxp.com; Stefan Roese sr@denx.de; Schrempf Frieder frieder.schrempf@kontron.de; Vignesh R vigneshr@ti.com Subject: [EXT] Re: [Patch v4 0/7] Transition of fsl qspi driver to spi-mem framework
Caution: EXT Email
Hi Kuldeep,
patch.
environment.
[1] https://eur01.safelinks.protection.outlook.com/?url=https%3A%2F%2Fpatc
hwork.ozlabs.org%2Fpatch%2F1219462%2F&data=02%7C01%7Ckuldeep.s ingh
%40nxp.com%7C94b5e5528efc47df25ea08d7a2f94efd%7C686ea1d3bc2b4c6
fa92cd9
9c5c301635%7C0%7C0%7C637157063972042137&sdata=DZFAEmt0sA4c cCPmu%2F
cArl99B02G2KmiAUYou1RXXBI%3D&reserved=0 [2] https://eur01.safelinks.protection.outlook.com/?url=https%3A%2F%2Fpatc
hwork.ozlabs.org%2Fpatch%2F1208299%2F&data=02%7C01%7Ckuldeep.s ingh
fa92cd9
9c5c301635%7C0%7C0%7C637157063972042137&sdata=3qr7QKERZgk8 V83QbYMM
Nb4xM4rUaqm2v3lZ5gzsGAQ%3D&reserved=0
Actually, net change is required to resolve the booting crash on LS1012ARDB with this driver. This series can be applied even without net pfe patch.
Thanks Kuldeep
Jagan.
On 27.01.20 10:20, Kuldeep Singh wrote:
Hi Jagan,
Caution: EXT Email
Hi Kuldeep,
patch.
environment.
fa92cd9
fa92cd9
It could be applied without and as you sad it would break the boot for LS1012ARDB.
Therefore no, I don't think we should apply patches that knowingly break things, just because changes elsewhere are not merged yet.
So can the maintainers (Joe, Jagan, ...) please figure out how to get [1] merged so we don't block this patch any longer?
Thanks, Frieder
On Mon, Jan 27, 2020 at 3:17 PM Schrempf Frieder frieder.schrempf@kontron.de wrote:
Hi Jagan,
Caution: EXT Email
Hi Kuldeep,
patch.
environment.
fa92cd9
fa92cd9
I would say, I can apply this spi driver change (since I'm belongs) for now. and rest of config and arch changes would take care of associated board and arch maintainers.
Jagan.
++Joe
-----Original Message----- From: Jagan Teki jagan@amarulasolutions.com Sent: Monday, January 27, 2020 3:44 PM To: Schrempf Frieder frieder.schrempf@kontron.de; Kuldeep Singh kuldeep.singh@nxp.com Cc: U-Boot-Denx u-boot@lists.denx.de; Priyanka Jain priyanka.jain@nxp.com; Ashish Kumar ashish.kumar@nxp.com; Stefan Roese sr@denx.de; Vignesh R vigneshr@ti.com Subject: Re: [EXT] Re: [Patch v4 0/7] Transition of fsl qspi driver to spi-mem framework
Caution: EXT Email
Hi Jagan,
Caution: EXT Email
Hi Kuldeep,
defconfigs
in same
patch.
driver.
environment.
[1]
patc
hwork.ozlabs.org%2Fpatch%2F1219462%2F&data=02%7C01%7Ckulde ep.s
ingh
bc2b4c6
fa92cd9
9c5c301635%7C0%7C0%7C637157063972042137&sdata=DZFAEmt0sA 4c
cCPmu%2F
patc
hwork.ozlabs.org%2Fpatch%2F1208299%2F&data=02%7C01%7Ckulde ep.s
ingh
bc2b4c6
fa92cd9
9c5c301635%7C0%7C0%7C637157063972042137&sdata=3qr7QKERZg k8
V83QbYMM
files.
boards
defconfigs
Thanks Jagan, for applying spi driver change. I will ask Priyanka to take care of other patches in series.
Thanks Kuldeep
Jagan.
-----Original Message----- From: U-Boot u-boot-bounces@lists.denx.de On Behalf Of Kuldeep Singh Sent: Tuesday, February 4, 2020 1:09 PM To: Jagan Teki jagan@amarulasolutions.com; U-Boot-Denx <u- boot@lists.denx.de>; Priyanka Jain priyanka.jain@nxp.com; Joe Hershberger joe.hershberger@ni.com Cc: Stefan Roese sr@denx.de Subject: RE: [EXT] Re: [Patch v4 0/7] Transition of fsl qspi driver to spi-mem framework
Caution: EXT Email
++Joe
Stefan
Caution: EXT Email
Hi Jagan,
Caution: EXT Email
Hi Kuldeep,
defconfigs
in same
patch.
driver.
environment.
[1]
patc
ep.s
ingh
3
bc2b4c6
fa92cd9
4c
cCPmu%2F
patc
ep.s
ingh
3
bc2b4c6
fa92cd9
k8
V83QbYMM
Frieder.
files.
boards
defconfigs
As per Fabio's comments on patch 4, it needs to be dropped from this series. Moreover patch 2 i.e removing unused config options will now be splitted into two patches as it includes changes for imx and layerscape platforms which will go via Stefano and Priyanka's tree respectively. Patch 1 (driver) also require a change to remove compilation warning/error observed after rebasing the series.
Thanks Kuldeep
participants (6)
Fabio Estevam
Jagan Teki
Kuldeep Singh
Priyanka Jain (OSS)
Schrempf Frieder
Vignesh Raghavendra
