[PATCH] arm: stm32mp1: force boot_device variable for invalid TAMP register value
When the TAMP register 20 have an invalid value (0x0 for example after TAMPER error) the "boot_device" U-Boot env variable have no value and no error is displayed in U-Boot log.
The STM32MP boot command bootcmd_stm32mp failed with strange trace: "Boot over !"
and the next command in bootcmd_stm32mp failed with few indication: if test ${boot_device} = serial || test ${boot_device} = usb; then stm32prog ${boot_device} ${boot_instance};
As it is difficult to investigate, the current patch avoids this issue: - change the debug message to error: "unexpected boot mode" is displayed - display trace "Boot over invalid!" in bootcmd_stm32mp - execute "run distro_bootcmd" to try all the possible target
Signed-off-by: Patrick Delaunay patrick.delaunay@foss.st.com ---
arch/arm/mach-stm32mp/cpu.c | 4 +++- 1 file changed, 3 insertions(+), 1 deletion(-)
diff --git a/arch/arm/mach-stm32mp/cpu.c b/arch/arm/mach-stm32mp/cpu.c index 592bfd413d..5ea1ddc497 100644 --- a/arch/arm/mach-stm32mp/cpu.c +++ b/arch/arm/mach-stm32mp/cpu.c @@ -542,7 +542,9 @@ static void setup_boot_mode(void) env_set("boot_instance", "0"); break; default: - log_debug("unexpected boot mode = %x\n", boot_mode); + env_set("boot_device", "invalid"); + env_set("boot_instance", ""); + log_err("unexpected boot mode = %x\n", boot_mode); break; }
Hi Patrick
break; }log_err("unexpected boot mode = %x\n", boot_mode);
Reviewed-by: Patrice Chotard patrice.chotard@foss.st.com Thanks Patrice
Applied to u-boot-stm/master, thanks!
Regards Patrick
Regards Patrick
Patrice CHOTARD
Patrick DELAUNAY
Patrick Delaunay
