[PATCH] arm: exynos: Map iRAM APM area for Exynos850 SoC
This iRAM APM area is needed for I3C access to PMIC via APM block. Without this mapping any access to APM iRAM leads to "Synchronous Abort" exception.
Signed-off-by: Sam Protsenko semen.protsenko@linaro.org --- arch/arm/mach-exynos/mmu-arm64.c | 8 ++++++++ 1 file changed, 8 insertions(+)
diff --git a/arch/arm/mach-exynos/mmu-arm64.c b/arch/arm/mach-exynos/mmu-arm64.c index 30e522804fbf..4c154950f73b 100644 --- a/arch/arm/mach-exynos/mmu-arm64.c +++ b/arch/arm/mach-exynos/mmu-arm64.c @@ -101,6 +101,14 @@ struct mm_region *mem_map = exynos7880_mem_map;
static struct mm_region exynos850_mem_map[] = { { + /* iRAM */ + .virt = 0x02000000UL, + .phys = 0x02000000UL, + .size = SZ_2M, + .attrs = PTE_BLOCK_MEMTYPE(MT_DEVICE_NGNRE) | + PTE_BLOCK_NON_SHARE | + PTE_BLOCK_PXN | PTE_BLOCK_UXN + }, { /* Peripheral block */ .virt = 0x10000000UL, .phys = 0x10000000UL,
On Sun, 26 May 2024 at 06:53, Sam Protsenko semen.protsenko@linaro.org wrote:
/* iRAM */
.size = SZ_2M,
-- 2.39.2
applied to u-boot-samsung.
Minkyu Kang
Sam Protsenko
