[U-Boot] [PATCH] Gracefully handle 64-bit Load Address and Entry Point Address mkimage parameters
Recent MIPS Linux kernels are using a 64-bit value for the load address (0xffffffff80010000) for the Creator CI20 board kernel. When this argument was passed to the mkimage program running on a 32-bit machine such as the Creator CI20 board the load address was incorrectly obtained from the first half of the argument, 0xffffffff by the strtoul. The mkimage should be able to tolerate the longer, 64-bit signed version of the arguments with the use of strtoull. --- tools/mkimage.c | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/tools/mkimage.c b/tools/mkimage.c index 8f8b6df..b6c2958 100644 --- a/tools/mkimage.c +++ b/tools/mkimage.c @@ -129,7 +129,7 @@ int main(int argc, char **argv) case 'a': if (--argc <= 0) usage (); - params.addr = strtoul (*++argv, &ptr, 16); + params.addr = strtoull (*++argv, &ptr, 16); if (*ptr) { fprintf (stderr, "%s: invalid load address %s\n", @@ -146,7 +146,7 @@ int main(int argc, char **argv) case 'e': if (--argc <= 0) usage (); - params.ep = strtoul (*++argv, &ptr, 16); + params.ep = strtoull (*++argv, &ptr, 16); if (*ptr) { fprintf (stderr, "%s: invalid entry point %s\n",
Dear William,
Hm... I think we have multiple problems here.
First, the old legacy uImage header usersd 32 bit data types for the addresses. This is a binary data structure, and there is no way to extend it for 64 bit addresses without breaking compatibility.
I don't see what you win here... strtoull() returns unsigned long long, but params.addr is an unsigned int, so the value will be truncated to 32 bit. Are you sure this is what you want?
Ditto...
Also please note that your patch triggers a number of checkpatch warnings and an error, especially:
WARNING: space prohibited between function name and open parenthesis '(' #108: FILE: tools/mkimage.c:132: + params.addr = strtoull (*++argv, &ptr, 16);
WARNING: space prohibited between function name and open parenthesis '(' #117: FILE: tools/mkimage.c:149: + params.ep = strtoull (*++argv, &ptr, 16);
ERROR: Missing Signed-off-by: line(s)
On 02/15/2016 06:34 AM, Wolfgang Denk wrote:
Dear William,
The write up in the patch wasn't as clear as it should have been. I have revised the patch to try to make the reason for this patch clearer. The MIP Linux kernel is using sign-extending 32-bit values to 64-bit values, so the truncation of the strtoll values to 32-bits is actually desired. The revised patch now passes the linux kernel checkpatch.pl checks. I will be resending the patch in a moment.
-Will
Ditto...
William Cohen
