[U-Boot] [PATCH v3 1/2] armv8: layerscape: Enable EHCI access for LS1012A
Program Central Security Unit (CSU) to grant access permission for USB 2.0 controller, otherwiase EHCI funciton will down.
Signed-off-by: Ran Wang ran.wang_1@nxp.com --- Change in v3: - None
Change in v2: - Add EL checking code to make sure related programming only happen in EL3
arch/arm/cpu/armv8/fsl-layerscape/soc.c | 9 +++++++++ arch/arm/include/asm/arch-fsl-layerscape/ns_access.h | 1 + 2 files changed, 10 insertions(+)
diff --git a/arch/arm/cpu/armv8/fsl-layerscape/soc.c b/arch/arm/cpu/armv8/fsl-layerscape/soc.c index 6a56269..d8c3083 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/soc.c +++ b/arch/arm/cpu/armv8/fsl-layerscape/soc.c @@ -14,6 +14,7 @@ #include <asm/io.h> #include <asm/global_data.h> #include <asm/arch-fsl-layerscape/config.h> +#include <asm/arch-fsl-layerscape/ns_access.h> #ifdef CONFIG_LAYERSCAPE_NS_ACCESS #include <fsl_csu.h> #endif @@ -668,6 +669,14 @@ void fsl_lsch2_early_init_f(void) CCI400_DVM_MESSAGE_REQ_EN | CCI400_SNOOP_REQ_EN); }
+ /* + * Program Central Security Unit (CSU) to grant access + * permission for USB 2.0 controller + */ +#if defined(CONFIG_ARCH_LS1012A) && defined(CONFIG_USB_EHCI_FSL) + if (current_el() == 3) + set_devices_ns_access(CSU_CSLX_USB_2, CSU_ALL_RW); +#endif /* Erratum */ erratum_a008850_early(); /* part 1 of 2 */ erratum_a009929(); diff --git a/arch/arm/include/asm/arch-fsl-layerscape/ns_access.h b/arch/arm/include/asm/arch-fsl-layerscape/ns_access.h index fe97a93..d1b8efa 100644 --- a/arch/arm/include/asm/arch-fsl-layerscape/ns_access.h +++ b/arch/arm/include/asm/arch-fsl-layerscape/ns_access.h @@ -40,6 +40,7 @@ enum csu_cslx_ind { CSU_CSLX_ESDHC, CSU_CSLX_IFC = 45, CSU_CSLX_I2C1, + CSU_CSLX_USB_2, CSU_CSLX_I2C3 = 48, CSU_CSLX_I2C2, CSU_CSLX_DUART2 = 50,
Since more c files will include ns_access.h, this move will fix some compiling warnings and make it sense.
Signed-off-by: Ran Wang ran.wang_1@nxp.com --- Change in v3: - New file
.../include/asm/arch-fsl-layerscape/ns_access.h | 80 ---------------------- board/freescale/common/ns_access.c | 80 ++++++++++++++++++++++ 2 files changed, 80 insertions(+), 80 deletions(-)
diff --git a/arch/arm/include/asm/arch-fsl-layerscape/ns_access.h b/arch/arm/include/asm/arch-fsl-layerscape/ns_access.h index d1b8efa..2e33d53 100644 --- a/arch/arm/include/asm/arch-fsl-layerscape/ns_access.h +++ b/arch/arm/include/asm/arch-fsl-layerscape/ns_access.h @@ -89,84 +89,4 @@ enum csu_cslx_ind { CSU_CSLX_DSCR = 121, };
-static struct csu_ns_dev ns_dev[] = { - {CSU_CSLX_PCIE2_IO, CSU_ALL_RW}, - {CSU_CSLX_PCIE1_IO, CSU_ALL_RW}, - {CSU_CSLX_MG2TPR_IP, CSU_ALL_RW}, - {CSU_CSLX_IFC_MEM, CSU_ALL_RW}, - {CSU_CSLX_OCRAM, CSU_ALL_RW}, - {CSU_CSLX_GIC, CSU_ALL_RW}, - {CSU_CSLX_PCIE1, CSU_ALL_RW}, - {CSU_CSLX_OCRAM2, CSU_ALL_RW}, - {CSU_CSLX_QSPI_MEM, CSU_ALL_RW}, - {CSU_CSLX_PCIE2, CSU_ALL_RW}, - {CSU_CSLX_SATA, CSU_ALL_RW}, - {CSU_CSLX_USB1, CSU_ALL_RW}, - {CSU_CSLX_QM_BM_SWPORTAL, CSU_ALL_RW}, - {CSU_CSLX_PCIE3, CSU_ALL_RW}, - {CSU_CSLX_PCIE3_IO, CSU_ALL_RW}, - {CSU_CSLX_USB3, CSU_ALL_RW}, - {CSU_CSLX_USB2, CSU_ALL_RW}, - {CSU_CSLX_PFE, CSU_ALL_RW}, - {CSU_CSLX_SERDES, CSU_ALL_RW}, - {CSU_CSLX_QDMA, CSU_ALL_RW}, - {CSU_CSLX_LPUART2, CSU_ALL_RW}, - {CSU_CSLX_LPUART1, CSU_ALL_RW}, - {CSU_CSLX_LPUART4, CSU_ALL_RW}, - {CSU_CSLX_LPUART3, CSU_ALL_RW}, - {CSU_CSLX_LPUART6, CSU_ALL_RW}, - {CSU_CSLX_LPUART5, CSU_ALL_RW}, - {CSU_CSLX_DSPI1, CSU_ALL_RW}, - {CSU_CSLX_QSPI, CSU_ALL_RW}, - {CSU_CSLX_ESDHC, CSU_ALL_RW}, - {CSU_CSLX_IFC, CSU_ALL_RW}, - {CSU_CSLX_I2C1, CSU_ALL_RW}, - {CSU_CSLX_I2C3, CSU_ALL_RW}, - {CSU_CSLX_I2C2, CSU_ALL_RW}, - {CSU_CSLX_DUART2, CSU_ALL_RW}, - {CSU_CSLX_DUART1, CSU_ALL_RW}, - {CSU_CSLX_WDT2, CSU_ALL_RW}, - {CSU_CSLX_WDT1, CSU_ALL_RW}, - {CSU_CSLX_EDMA, CSU_ALL_RW}, - {CSU_CSLX_SYS_CNT, CSU_ALL_RW}, - {CSU_CSLX_DMA_MUX2, CSU_ALL_RW}, - {CSU_CSLX_DMA_MUX1, CSU_ALL_RW}, - {CSU_CSLX_DDR, CSU_ALL_RW}, - {CSU_CSLX_QUICC, CSU_ALL_RW}, - {CSU_CSLX_DCFG_CCU_RCPM, CSU_ALL_RW}, - {CSU_CSLX_SECURE_BOOTROM, CSU_ALL_RW}, - {CSU_CSLX_SFP, CSU_ALL_RW}, - {CSU_CSLX_TMU, CSU_ALL_RW}, - {CSU_CSLX_SECURE_MONITOR, CSU_ALL_RW}, - {CSU_CSLX_SCFG, CSU_ALL_RW}, - {CSU_CSLX_FM, CSU_ALL_RW}, - {CSU_CSLX_SEC5_5, CSU_ALL_RW}, - {CSU_CSLX_BM, CSU_ALL_RW}, - {CSU_CSLX_QM, CSU_ALL_RW}, - {CSU_CSLX_GPIO2, CSU_ALL_RW}, - {CSU_CSLX_GPIO1, CSU_ALL_RW}, - {CSU_CSLX_GPIO4, CSU_ALL_RW}, - {CSU_CSLX_GPIO3, CSU_ALL_RW}, - {CSU_CSLX_PLATFORM_CONT, CSU_ALL_RW}, - {CSU_CSLX_CSU, CSU_ALL_RW}, - {CSU_CSLX_IIC4, CSU_ALL_RW}, - {CSU_CSLX_WDT4, CSU_ALL_RW}, - {CSU_CSLX_WDT3, CSU_ALL_RW}, - {CSU_CSLX_ESDHC2, CSU_ALL_RW}, - {CSU_CSLX_WDT5, CSU_ALL_RW}, - {CSU_CSLX_SAI2, CSU_ALL_RW}, - {CSU_CSLX_SAI1, CSU_ALL_RW}, - {CSU_CSLX_SAI4, CSU_ALL_RW}, - {CSU_CSLX_SAI3, CSU_ALL_RW}, - {CSU_CSLX_FTM2, CSU_ALL_RW}, - {CSU_CSLX_FTM1, CSU_ALL_RW}, - {CSU_CSLX_FTM4, CSU_ALL_RW}, - {CSU_CSLX_FTM3, CSU_ALL_RW}, - {CSU_CSLX_FTM6, CSU_ALL_RW}, - {CSU_CSLX_FTM5, CSU_ALL_RW}, - {CSU_CSLX_FTM8, CSU_ALL_RW}, - {CSU_CSLX_FTM7, CSU_ALL_RW}, - {CSU_CSLX_DSCR, CSU_ALL_RW}, -}; - #endif diff --git a/board/freescale/common/ns_access.c b/board/freescale/common/ns_access.c index 0c3a54c..a7c16e7 100644 --- a/board/freescale/common/ns_access.c +++ b/board/freescale/common/ns_access.c @@ -10,6 +10,86 @@ #include <asm/arch/ns_access.h> #include <asm/arch/fsl_serdes.h>
+static struct csu_ns_dev ns_dev[] = { + {CSU_CSLX_PCIE2_IO, CSU_ALL_RW}, + {CSU_CSLX_PCIE1_IO, CSU_ALL_RW}, + {CSU_CSLX_MG2TPR_IP, CSU_ALL_RW}, + {CSU_CSLX_IFC_MEM, CSU_ALL_RW}, + {CSU_CSLX_OCRAM, CSU_ALL_RW}, + {CSU_CSLX_GIC, CSU_ALL_RW}, + {CSU_CSLX_PCIE1, CSU_ALL_RW}, + {CSU_CSLX_OCRAM2, CSU_ALL_RW}, + {CSU_CSLX_QSPI_MEM, CSU_ALL_RW}, + {CSU_CSLX_PCIE2, CSU_ALL_RW}, + {CSU_CSLX_SATA, CSU_ALL_RW}, + {CSU_CSLX_USB1, CSU_ALL_RW}, + {CSU_CSLX_QM_BM_SWPORTAL, CSU_ALL_RW}, + {CSU_CSLX_PCIE3, CSU_ALL_RW}, + {CSU_CSLX_PCIE3_IO, CSU_ALL_RW}, + {CSU_CSLX_USB3, CSU_ALL_RW}, + {CSU_CSLX_USB2, CSU_ALL_RW}, + {CSU_CSLX_PFE, CSU_ALL_RW}, + {CSU_CSLX_SERDES, CSU_ALL_RW}, + {CSU_CSLX_QDMA, CSU_ALL_RW}, + {CSU_CSLX_LPUART2, CSU_ALL_RW}, + {CSU_CSLX_LPUART1, CSU_ALL_RW}, + {CSU_CSLX_LPUART4, CSU_ALL_RW}, + {CSU_CSLX_LPUART3, CSU_ALL_RW}, + {CSU_CSLX_LPUART6, CSU_ALL_RW}, + {CSU_CSLX_LPUART5, CSU_ALL_RW}, + {CSU_CSLX_DSPI1, CSU_ALL_RW}, + {CSU_CSLX_QSPI, CSU_ALL_RW}, + {CSU_CSLX_ESDHC, CSU_ALL_RW}, + {CSU_CSLX_IFC, CSU_ALL_RW}, + {CSU_CSLX_I2C1, CSU_ALL_RW}, + {CSU_CSLX_I2C3, CSU_ALL_RW}, + {CSU_CSLX_I2C2, CSU_ALL_RW}, + {CSU_CSLX_DUART2, CSU_ALL_RW}, + {CSU_CSLX_DUART1, CSU_ALL_RW}, + {CSU_CSLX_WDT2, CSU_ALL_RW}, + {CSU_CSLX_WDT1, CSU_ALL_RW}, + {CSU_CSLX_EDMA, CSU_ALL_RW}, + {CSU_CSLX_SYS_CNT, CSU_ALL_RW}, + {CSU_CSLX_DMA_MUX2, CSU_ALL_RW}, + {CSU_CSLX_DMA_MUX1, CSU_ALL_RW}, + {CSU_CSLX_DDR, CSU_ALL_RW}, + {CSU_CSLX_QUICC, CSU_ALL_RW}, + {CSU_CSLX_DCFG_CCU_RCPM, CSU_ALL_RW}, + {CSU_CSLX_SECURE_BOOTROM, CSU_ALL_RW}, + {CSU_CSLX_SFP, CSU_ALL_RW}, + {CSU_CSLX_TMU, CSU_ALL_RW}, + {CSU_CSLX_SECURE_MONITOR, CSU_ALL_RW}, + {CSU_CSLX_SCFG, CSU_ALL_RW}, + {CSU_CSLX_FM, CSU_ALL_RW}, + {CSU_CSLX_SEC5_5, CSU_ALL_RW}, + {CSU_CSLX_BM, CSU_ALL_RW}, + {CSU_CSLX_QM, CSU_ALL_RW}, + {CSU_CSLX_GPIO2, CSU_ALL_RW}, + {CSU_CSLX_GPIO1, CSU_ALL_RW}, + {CSU_CSLX_GPIO4, CSU_ALL_RW}, + {CSU_CSLX_GPIO3, CSU_ALL_RW}, + {CSU_CSLX_PLATFORM_CONT, CSU_ALL_RW}, + {CSU_CSLX_CSU, CSU_ALL_RW}, + {CSU_CSLX_IIC4, CSU_ALL_RW}, + {CSU_CSLX_WDT4, CSU_ALL_RW}, + {CSU_CSLX_WDT3, CSU_ALL_RW}, + {CSU_CSLX_ESDHC2, CSU_ALL_RW}, + {CSU_CSLX_WDT5, CSU_ALL_RW}, + {CSU_CSLX_SAI2, CSU_ALL_RW}, + {CSU_CSLX_SAI1, CSU_ALL_RW}, + {CSU_CSLX_SAI4, CSU_ALL_RW}, + {CSU_CSLX_SAI3, CSU_ALL_RW}, + {CSU_CSLX_FTM2, CSU_ALL_RW}, + {CSU_CSLX_FTM1, CSU_ALL_RW}, + {CSU_CSLX_FTM4, CSU_ALL_RW}, + {CSU_CSLX_FTM3, CSU_ALL_RW}, + {CSU_CSLX_FTM6, CSU_ALL_RW}, + {CSU_CSLX_FTM5, CSU_ALL_RW}, + {CSU_CSLX_FTM8, CSU_ALL_RW}, + {CSU_CSLX_FTM7, CSU_ALL_RW}, + {CSU_CSLX_DSCR, CSU_ALL_RW}, +}; + void set_devices_ns_access(unsigned long index, u16 val) { u32 *base = (u32 *)CONFIG_SYS_FSL_CSU_ADDR;
Change in v3:
- New file
Two issues with this patch. First this patch should be in front of your patch #1. Otherwise you patch #1 has this compiling warning
warning: ?ns_dev? defined but not used [-Wunused-variable]
Second issue is for ls1021a. You will see compiling failure.
York
Hi York,
-----Original Message----- From: York Sun Sent: Friday, August 10, 2018 03:46 To: Ran Wang ran.wang_1@nxp.com Cc: u-boot@lists.denx.de Subject: Re: [PATCH v3 2/2] armv8: layerscape: move ns_dev[] define from h to c file.
Change in v3:
- New file
OK, will change the patch order
Yes, I just located the issue, will fix it in next version, thanks for point out
Ran
York
Ran Wang
York Sun
