[PATCH v4 0/5] psci: add support for SYSTEM_RESET2 and PSCI_FEATURES
1. Adds support for: * PSCI_FEATURES, introduced in PSCI 1.0. This provides API that allows discovering whether a specific PSCI function is implemented and its features. * SYSTEM_RESET2, introduced in PSCI 1.1, which extends existing SYSTEM_RESET. It provides support for vendor-specific resets, providing reset_type as an additional param.
2. PSCI sysreset driver is refactored to use new API. 3. do_reset cmd is extended, optional param added for providing type of reset
CI: https://dev.azure.com/igoropaniuk/u-boot/_build/results?buildId=23&view=...
Changes in v4: - Fix htmldoc build issue
Changes in v3: - Drop RFC tag - Add usage doc for reset cmd - Reimplement param handling for reset cmd - Droped updates in reset usage string
Changes in v2: - do_reset cmd updates
Igor Opaniuk (5): psci: add v1.0/v1.1 definitions from Linux psci: add features/reset2 support sysreset: psci: use psci driver exported functions sysreset: provide type of reset in do_reset cmd doc: usage: add usage details for reset cmd
cmd/boot.c | 2 +- doc/usage/index.rst | 1 + doc/usage/reset.rst | 26 ++++++++++++ drivers/firmware/psci.c | 68 ++++++++++++++++++++++++++++++ drivers/sysreset/sysreset-uclass.c | 11 ++++- drivers/sysreset/sysreset_psci.c | 8 +--- include/linux/psci.h | 31 ++++++++++++++ 7 files changed, 139 insertions(+), 8 deletions(-) create mode 100644 doc/usage/reset.rst
Sync and add PSCI API versions 1.0/1.1 definitions from Linux.
Signed-off-by: Igor Opaniuk igor.opaniuk@foundries.io ---
include/linux/psci.h | 28 ++++++++++++++++++++++++++++ 1 file changed, 28 insertions(+)
diff --git a/include/linux/psci.h b/include/linux/psci.h index 841dbc8da7..38edde3137 100644 --- a/include/linux/psci.h +++ b/include/linux/psci.h @@ -46,6 +46,14 @@ #define PSCI_0_2_FN64_MIGRATE PSCI_0_2_FN64(5) #define PSCI_0_2_FN64_MIGRATE_INFO_UP_CPU PSCI_0_2_FN64(7)
+#define PSCI_1_0_FN_PSCI_FEATURES PSCI_0_2_FN(10) +#define PSCI_1_0_FN_SYSTEM_SUSPEND PSCI_0_2_FN(14) +#define PSCI_1_0_FN_SET_SUSPEND_MODE PSCI_0_2_FN(15) +#define PSCI_1_1_FN_SYSTEM_RESET2 PSCI_0_2_FN(18) + +#define PSCI_1_0_FN64_SYSTEM_SUSPEND PSCI_0_2_FN64(14) +#define PSCI_1_1_FN64_SYSTEM_RESET2 PSCI_0_2_FN64(18) + /* PSCI v0.2 power state encoding for CPU_SUSPEND function */ #define PSCI_0_2_POWER_STATE_ID_MASK 0xffff #define PSCI_0_2_POWER_STATE_ID_SHIFT 0 @@ -56,6 +64,13 @@ #define PSCI_0_2_POWER_STATE_AFFL_MASK \ (0x3 << PSCI_0_2_POWER_STATE_AFFL_SHIFT)
+/* PSCI extended power state encoding for CPU_SUSPEND function */ +#define PSCI_1_0_EXT_POWER_STATE_ID_MASK 0xfffffff +#define PSCI_1_0_EXT_POWER_STATE_ID_SHIFT 0 +#define PSCI_1_0_EXT_POWER_STATE_TYPE_SHIFT 30 +#define PSCI_1_0_EXT_POWER_STATE_TYPE_MASK \ + (0x1 << PSCI_1_0_EXT_POWER_STATE_TYPE_SHIFT) + /* PSCI v0.2 affinity level state returned by AFFINITY_INFO */ #define PSCI_0_2_AFFINITY_LEVEL_ON 0 #define PSCI_0_2_AFFINITY_LEVEL_OFF 1 @@ -75,6 +90,18 @@ (((ver) & PSCI_VERSION_MAJOR_MASK) >> PSCI_VERSION_MAJOR_SHIFT) #define PSCI_VERSION_MINOR(ver) \ ((ver) & PSCI_VERSION_MINOR_MASK) +#define PSCI_VERSION(maj, min) \ + ((((maj) << PSCI_VERSION_MAJOR_SHIFT) & PSCI_VERSION_MAJOR_MASK) | \ + ((min) & PSCI_VERSION_MINOR_MASK)) + +/* PSCI features decoding (>=1.0) */ +#define PSCI_1_0_FEATURES_CPU_SUSPEND_PF_SHIFT 1 +#define PSCI_1_0_FEATURES_CPU_SUSPEND_PF_MASK \ + (0x1 << PSCI_1_0_FEATURES_CPU_SUSPEND_PF_SHIFT) + +#define PSCI_1_0_OS_INITIATED BIT(0) +#define PSCI_1_0_SUSPEND_MODE_PC 0 +#define PSCI_1_0_SUSPEND_MODE_OSI 1
/* PSCI return values (inclusive of all PSCI versions) */ #define PSCI_RET_SUCCESS 0 @@ -86,6 +113,7 @@ #define PSCI_RET_INTERNAL_FAILURE -6 #define PSCI_RET_NOT_PRESENT -7 #define PSCI_RET_DISABLED -8 +#define PSCI_RET_INVALID_ADDRESS -9
#ifdef CONFIG_ARM_PSCI_FW unsigned long invoke_psci_fn(unsigned long a0, unsigned long a1,
Adds support for: * PSCI_FEATURES, which was introduced in PSCI 1.0. This provides API that allows discovering whether a specific PSCI function is implemented and its features. * SYSTEM_RESET2, which was introduced in PSCI 1.1, which extends existing SYSTEM_RESET. It provides support for vendor-specific resets, providing reset_type as an additional param.
For additional details visit [1].
Implementations of some functions were borrowed from Linux PSCI driver code [2].
[1] https://developer.arm.com/documentation/den0022/latest/ [2] drivers/firmware/psci/psci.c
drivers/firmware/psci.c | 68 +++++++++++++++++++++++++++++++++++++++++ include/linux/psci.h | 3 ++ 2 files changed, 71 insertions(+)
diff --git a/drivers/firmware/psci.c b/drivers/firmware/psci.c index 68953cc4f4..be57552aba 100644 --- a/drivers/firmware/psci.c +++ b/drivers/firmware/psci.c @@ -13,6 +13,7 @@ #include <log.h> #include <dm/lists.h> #include <efi_loader.h> +#include <sysreset.h> #include <linux/delay.h> #include <linux/libfdt.h> #include <linux/arm-smccc.h> @@ -26,6 +27,18 @@ #define PSCI_METHOD_HVC 1 #define PSCI_METHOD_SMC 2
+/* + * While a 64-bit OS can make calls with SMC32 calling conventions, for some + * calls it is necessary to use SMC64 to pass or return 64-bit values. + * For such calls PSCI_FN_NATIVE(version, name) will choose the appropriate + * (native-width) function ID. + */ +#if defined(CONFIG_ARM64) +#define PSCI_FN_NATIVE(version, name) PSCI_##version##_FN64_##name +#else +#define PSCI_FN_NATIVE(version, name) PSCI_##version##_FN_##name +#endif + #if CONFIG_IS_ENABLED(EFI_LOADER) int __efi_runtime_data psci_method; #else @@ -53,6 +66,34 @@ unsigned long __efi_runtime invoke_psci_fn return res.a0; }
+static int psci_features(u32 psci_func_id) +{ + return invoke_psci_fn(PSCI_1_0_FN_PSCI_FEATURES, + psci_func_id, 0, 0); +} + +static u32 psci_0_2_get_version(void) +{ + return invoke_psci_fn(PSCI_0_2_FN_PSCI_VERSION, 0, 0, 0); +} + +static bool psci_is_system_reset2_supported(void) +{ + int ret; + u32 ver; + + ver = psci_0_2_get_version(); + + if (PSCI_VERSION_MAJOR(ver) >= 1) { + ret = psci_features(PSCI_FN_NATIVE(1_1, SYSTEM_RESET2)); + + if (ret != PSCI_RET_NOT_SUPPORTED) + return true; + } + + return false; +} + static int psci_bind(struct udevice *dev) { /* No SYSTEM_RESET support for PSCI 0.1 */ @@ -141,6 +182,33 @@ void reset_misc(void) } #endif /* CONFIG_PSCI_RESET */
+void psci_sys_reset(u32 type) +{ + bool reset2_supported; + + do_psci_probe(); + + reset2_supported = psci_is_system_reset2_supported(); + + if (type == SYSRESET_WARM && reset2_supported) { + /* + * reset_type[31] = 0 (architectural) + * reset_type[30:0] = 0 (SYSTEM_WARM_RESET) + * cookie = 0 (ignored by the implementation) + */ + invoke_psci_fn(PSCI_FN_NATIVE(1_1, SYSTEM_RESET2), 0, 0, 0); + } else { + invoke_psci_fn(PSCI_0_2_FN_SYSTEM_RESET, 0, 0, 0); + } +} + +void psci_sys_poweroff(void) +{ + do_psci_probe(); + + invoke_psci_fn(PSCI_0_2_FN_SYSTEM_OFF, 0, 0, 0); +} + #ifdef CONFIG_CMD_POWEROFF int do_poweroff(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]) { diff --git a/include/linux/psci.h b/include/linux/psci.h index 38edde3137..c78c1079a8 100644 --- a/include/linux/psci.h +++ b/include/linux/psci.h @@ -118,6 +118,9 @@ #ifdef CONFIG_ARM_PSCI_FW unsigned long invoke_psci_fn(unsigned long a0, unsigned long a1, unsigned long a2, unsigned long a3); +void psci_sys_reset(u32 type); +void psci_sys_poweroff(void); + #else static inline unsigned long invoke_psci_fn(unsigned long a0, unsigned long a1, unsigned long a2, unsigned long a3)
On Thu, Apr 01, 2021 at 02:01:53AM +0300, Igor Opaniuk wrote:
Adds support for:
- PSCI_FEATURES, which was introduced in PSCI 1.0. This provides API
- SYSTEM_RESET2, which was introduced in PSCI 1.1, which extends existing
Adds support for:
I'm seeing a build failure on stm32mp1 from this patch:
drivers/firmware/psci.c:69:12: error: conflicting types for 'psci_features' 69 | static int psci_features(u32 psci_func_id) | ^~~~~~~~~~~~~ In file included from drivers/firmware/psci.c:23: ./arch/arm/include/asm/system.h:548:5: note: previous declaration of 'psci_features' was here 548 | s32 psci_features(u32 function_id, u32 psci_fid); | ^~~~~~~~~~~~~ make[2]: *** [scripts/Makefile.build:266: drivers/firmware/psci.o] Error 1 make[1]: *** [scripts/Makefile.build:419: drivers/firmware] Error 2
Use psci driver exported functions for reset/poweroff, instead of invoking directly invoke_psci_fn.
drivers/sysreset/sysreset_psci.c | 8 ++------ 1 file changed, 2 insertions(+), 6 deletions(-)
diff --git a/drivers/sysreset/sysreset_psci.c b/drivers/sysreset/sysreset_psci.c index c7907b3226..83ecbcb9d2 100644 --- a/drivers/sysreset/sysreset_psci.c +++ b/drivers/sysreset/sysreset_psci.c @@ -11,22 +11,18 @@
static int psci_sysreset_request(struct udevice *dev, enum sysreset_t type) { - unsigned long function_id; - switch (type) { case SYSRESET_WARM: case SYSRESET_COLD: - function_id = PSCI_0_2_FN_SYSTEM_RESET; + psci_sys_reset(type); break; case SYSRESET_POWER_OFF: - function_id = PSCI_0_2_FN_SYSTEM_OFF; + psci_sys_poweroff(); break; default: return -ENOSYS; }
- invoke_psci_fn(function_id, 0, 0, 0); - return -EINPROGRESS; }
Add additional param for reset cmd, which provides type of reset.
cmd/boot.c | 2 +- drivers/sysreset/sysreset-uclass.c | 11 ++++++++++- 2 files changed, 11 insertions(+), 2 deletions(-)
diff --git a/cmd/boot.c b/cmd/boot.c index 36aba22b30..b84c0ed89e 100644 --- a/cmd/boot.c +++ b/cmd/boot.c @@ -56,7 +56,7 @@ U_BOOT_CMD( #endif
U_BOOT_CMD( - reset, 1, 0, do_reset, + reset, 2, 0, do_reset, "Perform RESET of the CPU", "" ); diff --git a/drivers/sysreset/sysreset-uclass.c b/drivers/sysreset/sysreset-uclass.c index 6c9dc7a384..0412c4a29b 100644 --- a/drivers/sysreset/sysreset-uclass.c +++ b/drivers/sysreset/sysreset-uclass.c @@ -122,10 +122,19 @@ void reset_cpu(ulong addr) #if IS_ENABLED(CONFIG_SYSRESET_CMD_RESET) int do_reset(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]) { + enum sysreset_t reset_type = SYSRESET_COLD; + + if (argc > 2) + return CMD_RET_USAGE; + + if (argc == 2 && argv[1][0] == '-' && argv[1][1] == 'w') { + reset_type = SYSRESET_WARM; + } + printf("resetting ...\n"); mdelay(100);
- sysreset_walk_halt(SYSRESET_COLD); + sysreset_walk_halt(reset_type);
return 0; }
Add usage details for reset command.
doc/usage/index.rst | 1 + doc/usage/reset.rst | 26 ++++++++++++++++++++++++++ 2 files changed, 27 insertions(+) create mode 100644 doc/usage/reset.rst
diff --git a/doc/usage/index.rst b/doc/usage/index.rst index 6c59bbadab..b1181011ae 100644 --- a/doc/usage/index.rst +++ b/doc/usage/index.rst @@ -34,3 +34,4 @@ Shell commands qfw sbi true + reset diff --git a/doc/usage/reset.rst b/doc/usage/reset.rst new file mode 100644 index 0000000000..384d5d60f8 --- /dev/null +++ b/doc/usage/reset.rst @@ -0,0 +1,26 @@ +.. SPDX-License-Identifier: GPL-2.0+ + +reset command +============= + +Synopsis +-------- + +:: + + reset [-w] + +Description +----------- + +Perform reset of the CPU. By default does COLD reset, which resets CPU, +DDR and peripherals, on some boards also resets external PMIC. + +-w + Do warm WARM, reset CPU but keep peripheral/DDR/PMIC active. + + +Return value +------------ + +The return value $? is always set to 0 (true).
Alex G.
Igor Opaniuk
