[U-Boot] [PATCH] TI DaVinci Sonata: Add Config option for 64 bit Support
Adding the CONFIG_SYS_64BIT_VSPRINTF fot the DM644x based Sonata
Signed-off-by: Sandeep Paulraj s-paulraj@ti.com --- Previous patch incorrectly said that it was meant for the DM355 EVM include/configs/davinci_sonata.h | 1 + 1 files changed, 1 insertions(+), 0 deletions(-)
diff --git a/include/configs/davinci_sonata.h b/include/configs/davinci_sonata.h index 5a55c56..9138b2b 100644 --- a/include/configs/davinci_sonata.h +++ b/include/configs/davinci_sonata.h @@ -125,6 +125,7 @@ #define CONFIG_SYS_NAND_HW_ECC #define CONFIG_SYS_MAX_NAND_DEVICE 1 /* Max number of NAND devices */ #define CONFIG_ENV_OFFSET 0x0 /* Block 0--not used by bootcode */ +#define CONFIG_SYS_64BIT_VSPRINTF /* needed for nand_util.c */ #define DEF_BOOTM "" #elif defined(CONFIG_SYS_USE_NOR) #ifdef CONFIG_NOR_UART_BOOT
s-paulraj@ti.com
