[U-Boot] [PULL] u-boot-usb/master
The following changes since commit 2cee0408e5c6f5dbdfa89fb40168ba2ead3f61a6:
Merge branch 'master' of git://www.denx.de/git/u-boot-coldfire (2013-11-06 16:18:25 -0500)
git://git.denx.de/u-boot-usb.git master
for you to fetch changes up to 47d79deb996797dddd0984cef8b48a566c82180e:
usb: dfu: make nand upload working (2013-11-08 20:46:20 +0100)
---------------------------------------------------------------- Bo Shen (3): usb: dfu: decrease dfu->r_left along with the transfer usb: dfu: correct dfu buffer inited value usb: dfu: make nand upload working
Heiko Schocher (1): usb, g_dnl: make iSerialNumber board configurable
Mateusz Kulikowski (1): usb: ohci-hcd: submit_common_msg: report actual_length properly
Przemyslaw Marczak (5): usb: ums: code refactoring to improve reusability on other boards. usb: ums: allows using every mmc device with ums. usb: ums: fix disk capacity miscalculation and code cleanup usb: ums: move ums code from trats to Samsung common directory usb: ums: add ums exit feature by ctrl+c or by detach usb cable
README | 7 +++++++ board/samsung/common/Makefile | 1 + board/samsung/common/ums.c | 76 ++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++ board/samsung/trats/trats.c | 62 -------------------------------------------------------------- common/cmd_usb_mass_storage.c | 51 +++++++++++++++++++++++---------------------------- drivers/dfu/dfu.c | 3 ++- drivers/dfu/dfu_nand.c | 1 + drivers/usb/gadget/f_mass_storage.c | 67 +++++++++++++++++++++++++++++++++++++++++++------------------------ drivers/usb/gadget/g_dnl.c | 20 ++++++++++++++++++++ drivers/usb/gadget/storage_common.c | 27 +++------------------------ drivers/usb/host/ohci-hcd.c | 2 +- include/configs/trats.h | 2 -- include/g_dnl.h | 1 + include/usb.h | 10 ++++++++++ include/usb_mass_storage.h | 33 +++++++++++++++++---------------- 15 files changed, 205 insertions(+), 158 deletions(-) create mode 100644 board/samsung/common/ums.c
README | 7 +++++++ board/samsung/common/Makefile | 1 board/samsung/common/ums.c | 76 ++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++ board/samsung/trats/trats.c | 62 -------------------------------------------------------------- common/cmd_usb_mass_storage.c | 51 +++++++++++++++++++++++---------------------------- drivers/dfu/dfu.c | 3 ++- drivers/dfu/dfu_nand.c | 1 drivers/usb/gadget/f_mass_storage.c | 67 +++++++++++++++++++++++++++++++++++++++++++------------------------ drivers/usb/gadget/g_dnl.c | 20 ++++++++++++++++++++ drivers/usb/gadget/storage_common.c | 27 +++------------------------ drivers/usb/host/ohci-hcd.c | 2 +- include/configs/trats.h | 2 -- include/g_dnl.h | 1 include/usb.h | 10 ++++++++++ include/usb_mass_storage.h | 33 +++++++++++++++++---------------- 15 files changed, 205 insertions(+), 158 deletions(-) create mode 100644 board/samsung/common/ums.c
