[PATCH 1/2] rockchip: rk3399: fix incorrect ifdef check on SPL_DM_REGULATOR
From: Quentin Schulz quentin.schulz@theobroma-systems.com
The check to perform is on CONFIG_SPL_DM_REGULATOR and not SPL_DM_REGULATOR.
Fixes: 07586ee4322a ("rockchip: rk3399: Support common spl_board_init") Cc: Quentin Schulz foss+uboot@0leil.net Signed-off-by: Quentin Schulz quentin.schulz@theobroma-systems.com --- arch/arm/mach-rockchip/rk3399/rk3399.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/arch/arm/mach-rockchip/rk3399/rk3399.c b/arch/arm/mach-rockchip/rk3399/rk3399.c index de11a3fa30..ad274b66ce 100644 --- a/arch/arm/mach-rockchip/rk3399/rk3399.c +++ b/arch/arm/mach-rockchip/rk3399/rk3399.c @@ -275,7 +275,7 @@ void spl_board_init(void) rk3399_force_power_on_reset(); #endif
-#if defined(SPL_DM_REGULATOR) +#if defined(CONFIG_SPL_DM_REGULATOR) /* * Turning the eMMC and SPI back on (if disabled via the Qseven * BIOS_ENABLE) signal is done through a always-on regulator).
The check to perform is on CONFIG_SPL_GPIO and not SPL_GPIO. Because this was never compiled in, it missed an include of cru.h that was not detected before. Let's include it too.
Fixes: 07586ee4322a ("rockchip: rk3399: Support common spl_board_init") Cc: Quentin Schulz foss+uboot@0leil.net Signed-off-by: Quentin Schulz quentin.schulz@theobroma-systems.com --- arch/arm/mach-rockchip/rk3399/rk3399.c | 6 ++++-- 1 file changed, 4 insertions(+), 2 deletions(-)
diff --git a/arch/arm/mach-rockchip/rk3399/rk3399.c b/arch/arm/mach-rockchip/rk3399/rk3399.c index ad274b66ce..6d30b70565 100644 --- a/arch/arm/mach-rockchip/rk3399/rk3399.c +++ b/arch/arm/mach-rockchip/rk3399/rk3399.c @@ -221,7 +221,9 @@ void spl_perform_fixups(struct spl_image_info *spl_image) "u-boot,spl-boot-device", boot_ofpath); }
-#if defined(SPL_GPIO) +#if defined(CONFIG_SPL_GPIO) + +#include <asm/arch-rockchip/cru.h> static void rk3399_force_power_on_reset(void) { ofnode node; @@ -253,7 +255,7 @@ void spl_board_init(void) { led_setup();
-#if defined(SPL_GPIO) +#if defined(CONFIG_SPL_GPIO) struct rockchip_cru *cru = rockchip_get_cru();
#if IS_ENABLED(…)
if (IS_ENABLED(…)) { }
struct rockchip_cru *cru = rockchip_get_cru(); /*
-- 2.36.1
This should use IS_ENABLED(...) or CONFIG_IS_ENABLED(...) and be a regular if-block instead of an #ifdef.
-- 2.36.1
Philipp Tomsich
Quentin Schulz
