[U-Boot] [PATCH v3] Add 16-bit single register pin controller support
Enables the pinctrl-single driver to support 16-bit registers. Only 32-bit registers were supported previously. Reduced width registers are required for some platforms, such as OMAP.
Signed-off-by: James Balean james@balean.com.au Cc: Felix Brack fb@ltec.ch Cc: Simon Glass sjg@chromium.org --- Changes for v3: - Fixes incorrect v2 submission. - Inline rather than separate read/write function calls.
drivers/pinctrl/pinctrl-single.c | 16 ++++++++-------- 1 file changed, 8 insertions(+), 8 deletions(-)
diff --git a/drivers/pinctrl/pinctrl-single.c b/drivers/pinctrl/pinctrl-single.c index d2dcec0..f19f779 100644 --- a/drivers/pinctrl/pinctrl-single.c +++ b/drivers/pinctrl/pinctrl-single.c @@ -47,27 +47,27 @@ static int single_configure_pins(struct udevice *dev, int n, reg; u32 val;
- for (n = 0; n < count; n++) { + for (n = 0; n < count; n++, pins++) { reg = fdt32_to_cpu(pins->reg); if ((reg < 0) || (reg > pdata->offset)) { dev_dbg(dev, " invalid register offset 0x%08x\n", reg); - pins++; continue; } reg += pdata->base; + val = fdt32_to_cpu(pins->val) & pdata->mask; switch (pdata->width) { + case 16: + writew((readw(reg) & ~pdata->mask) | val, reg); + break; case 32: - val = readl(reg) & ~pdata->mask; - val |= fdt32_to_cpu(pins->val) & pdata->mask; - writel(val, reg); - dev_dbg(dev, " reg/val 0x%08x/0x%08x\n", - reg, val); + writel((readl(reg) & ~pdata->mask) | val, reg); break; default: dev_warn(dev, "unsupported register width %i\n", pdata->width); + continue; } - pins++; + dev_dbg(dev, " reg/val 0x%08x/0x%08x\n",reg, val); } return 0; }
Hello James,
Disregarding one missing space this looks good to me.
Changes for v3:
- for (n = 0; n < count; n++, pins++) { reg = fdt32_to_cpu(pins->reg); if ((reg < 0) || (reg > pdata->offset)) { dev_dbg(dev, " invalid register offset 0x%08x\n", reg);
} reg += pdata->base;pins++; continue;
switch (pdata->width) {val = fdt32_to_cpu(pins->val) & pdata->mask;
case 16:
case 32:break;
writel(val, reg);
reg, val);
default: dev_warn(dev, "unsupported register width %i\n", pdata->width);writel((readl(reg) & ~pdata->mask) | val, reg); break;
}continue;
pins++;
Missing space just before 'reg'.
} return 0; }
Reviewed-by: Felix Brack fb@ltec.ch
For the 32 bit path and an AM355x based hardware: Tested-by: Felix Brack fb@ltec.ch
regards Felix
Changes for v3:
Signed-off-by: James Balean james@balean.com.au Cc: Felix Brack fb@ltec.ch Cc: Simon Glass sjg@chromium.org Reviewed-by: Felix Brack fb@ltec.ch Tested-by: Felix Brack fb@ltec.ch Reviewed-by: Simon Glass sjg@chromium.org
Felix Brack
James Balean
