[PATCH] misc: i2c_eeprom: consider pagesize when writing to eeprom
Calculate the maximum length of the buffer when writing accross the page boundary. If the buffer length exceeds the page boundary, split it. Use this length instead of comparing the length with the pagesize, because the write start address can be somewhere in the middle of a page.
Signed-off-by: Alex Michel alex.michel@wiedemann-group.com --- drivers/misc/i2c_eeprom.c | 13 ++++++++++++- 1 file changed, 12 insertions(+), 1 deletion(-)
diff --git a/drivers/misc/i2c_eeprom.c b/drivers/misc/i2c_eeprom.c index bdd7e018cc..f345e34179 100644 --- a/drivers/misc/i2c_eeprom.c +++ b/drivers/misc/i2c_eeprom.c @@ -60,6 +60,17 @@ static int i2c_eeprom_std_read(struct udevice *dev, int offset, u int8_t *buf, return dm_i2c_read(dev, offset, buf, size); }
+static int i2c_eeprom_len(unsigned offset, unsigned len, unsigned pagesize) +{ + int page_offset = ((offset) & (pagesize - 1)); + unsigned maxlen = pagesize - page_offset; + + if (len > maxlen) + len = maxlen; + + return len; +} + static int i2c_eeprom_std_write(struct udevice *dev, int offset, const uint8_t *buf, int size) { @@ -67,7 +78,7 @@ static int i2c_eeprom_std_write(struct udevice *dev, int offset, int ret;
while (size > 0) { - int write_size = min_t(int, size, priv->pagesize); + int write_size = i2c_eeprom_len(offset, size, priv->pagesize);
ret = dm_i2c_write(dev, offset, buf, write_size); if (ret)
Please fix the checkpatch.pl errors with this patch, thanks.
Calculate the maximum length of the buffer when writing across the page boundary. If the buffer length (len) exceeds the page boundary (pagesize), split it. Use this length instead of comparing the length with the pagesize, because if the write start address (offset) is not at the beginning of a page and the page_offset + len is greater than the page boundary (pagesize), the write operation would overflow the current page and the behaviour can be undefined (e.g. at24).
Signed-off-by: Alex Michel alex.michel@wiedemann-group.com --- Changes for v2: - fixed deviations from checkpatch.pl - improved commit message --- drivers/misc/i2c_eeprom.c | 13 ++++++++++++- 1 file changed, 12 insertions(+), 1 deletion(-)
diff --git a/drivers/misc/i2c_eeprom.c b/drivers/misc/i2c_eeprom.c index bdd7e018cc..0eecbd07ba 100644 --- a/drivers/misc/i2c_eeprom.c +++ b/drivers/misc/i2c_eeprom.c @@ -60,6 +60,17 @@ static int i2c_eeprom_std_read(struct udevice *dev, int offset, uint8_t *buf, return dm_i2c_read(dev, offset, buf, size); }
+static int i2c_eeprom_len(unsigned int offset, unsigned int len, unsigned int pagesize) +{ + int page_offset = ((offset) & (pagesize - 1)); + unsigned int maxlen = pagesize - page_offset; + + if (len > maxlen) + len = maxlen; + + return len; +} + static int i2c_eeprom_std_write(struct udevice *dev, int offset, const uint8_t *buf, int size) { @@ -67,7 +78,7 @@ static int i2c_eeprom_std_write(struct udevice *dev, int offset, int ret;
ret = dm_i2c_write(dev, offset, buf, write_size); if (ret) -- 2.34.1
Changes for v2:
int page_offset = offset & (pagesize - 1); 2 many ()
Lothar Waßmann
Signed-off-by: Alex Michel alex.michel@wiedemann-group.com --- Changes for v2: - fixed deviations from checkpatch.pl - improved commit message Changes for v3: - cleaned up brackets --- drivers/misc/i2c_eeprom.c | 13 ++++++++++++- 1 file changed, 12 insertions(+), 1 deletion(-)
diff --git a/drivers/misc/i2c_eeprom.c b/drivers/misc/i2c_eeprom.c index bdd7e018cc..947eeb5648 100644 --- a/drivers/misc/i2c_eeprom.c +++ b/drivers/misc/i2c_eeprom.c @@ -60,6 +60,17 @@ static int i2c_eeprom_std_read(struct udevice *dev, int offset, uint8_t *buf, return dm_i2c_read(dev, offset, buf, size); }
+static int i2c_eeprom_len(unsigned int offset, unsigned int len, unsigned int pagesize) +{ + int page_offset = offset & (pagesize - 1); + unsigned int maxlen = pagesize - page_offset; + + if (len > maxlen) + len = maxlen; + + return len; +} + static int i2c_eeprom_std_write(struct udevice *dev, int offset, const uint8_t *buf, int size) { @@ -67,7 +78,7 @@ static int i2c_eeprom_std_write(struct udevice *dev, int offset, int ret;
[snip]
[snip]
while (size > 0) {
[snip]
We don't need to promote the types to unsigned here do we?
Signed-off-by: Alex Michel alex.michel@wiedemann-group.com --- Changes for v2: - fixed deviations from checkpatch.pl - improved commit message Changes for v3: - cleaned up brackets Changes for v4: - use "int" instead of "unsigned int" --- drivers/misc/i2c_eeprom.c | 13 ++++++++++++- 1 file changed, 12 insertions(+), 1 deletion(-)
diff --git a/drivers/misc/i2c_eeprom.c b/drivers/misc/i2c_eeprom.c index bdd7e018cc..0d35efb7f7 100644 --- a/drivers/misc/i2c_eeprom.c +++ b/drivers/misc/i2c_eeprom.c @@ -60,6 +60,17 @@ static int i2c_eeprom_std_read(struct udevice *dev, int offset, uint8_t *buf, return dm_i2c_read(dev, offset, buf, size); }
+static int i2c_eeprom_len(int offset, int len, int pagesize) +{ + int page_offset = offset & (pagesize - 1); + int maxlen = pagesize - page_offset; + + if (len > maxlen) + len = maxlen; + + return len; +} + static int i2c_eeprom_std_write(struct udevice *dev, int offset, const uint8_t *buf, int size) { @@ -67,7 +78,7 @@ static int i2c_eeprom_std_write(struct udevice *dev, int offset, int ret;
Lothar Waßmann
Michel Alex
