[U-Boot] [PATCH 1/2] MX28: Add CONFIG_MX28_DEBUG
This functionality allows configuring SCRATCH0 and SCRATCH1 registers to special values, which make the SPL hang after the CPU was properly initialized.
This is for bootstrap purposes only and MUST BE DISABLED for normal operation.
Signed-off-by: Marek Vasut marex@denx.de Cc: Wolfgang Denk wd@denx.de Cc: Stefano Babic sbabic@denx.de Cc: Fabio Estevam fabio.estevam@freescale.com --- arch/arm/cpu/arm926ejs/mxs/Makefile | 3 ++ arch/arm/cpu/arm926ejs/mxs/mxs_init.h | 6 +++ arch/arm/cpu/arm926ejs/mxs/spl_boot.c | 2 + arch/arm/cpu/arm926ejs/mxs/spl_debug.c | 63 ++++++++++++++++++++++++++++++++ 4 files changed, 74 insertions(+) create mode 100644 arch/arm/cpu/arm926ejs/mxs/spl_debug.c
diff --git a/arch/arm/cpu/arm926ejs/mxs/Makefile b/arch/arm/cpu/arm926ejs/mxs/Makefile index eeecf89..e75eabd 100644 --- a/arch/arm/cpu/arm926ejs/mxs/Makefile +++ b/arch/arm/cpu/arm926ejs/mxs/Makefile @@ -29,6 +29,9 @@ COBJS = clock.o mxs.o iomux.o timer.o
ifdef CONFIG_SPL_BUILD COBJS += spl_boot.o spl_lradc_init.o spl_mem_init.o spl_power_init.o +ifdef CONFIG_MX28_DEBUG +COBJS += spl_debug.o +endif endif
SRCS := $(START:.o=.S) $(COBJS:.o=.c) diff --git a/arch/arm/cpu/arm926ejs/mxs/mxs_init.h b/arch/arm/cpu/arm926ejs/mxs/mxs_init.h index 2ddc5bc..e6f837c 100644 --- a/arch/arm/cpu/arm926ejs/mxs/mxs_init.h +++ b/arch/arm/cpu/arm926ejs/mxs/mxs_init.h @@ -42,4 +42,10 @@ uint32_t mxs_mem_get_size(void); void mxs_lradc_init(void); void mxs_lradc_enable_batt_measurement(void);
+#ifdef CONFIG_MX28_DEBUG +void mx28_common_spl_debug_halt(void); +#else +static inline void mx28_common_spl_debug_halt(void) {} +#endif + #endif /* __M28_INIT_H__ */ diff --git a/arch/arm/cpu/arm926ejs/mxs/spl_boot.c b/arch/arm/cpu/arm926ejs/mxs/spl_boot.c index ad66c57..f4f0c09 100644 --- a/arch/arm/cpu/arm926ejs/mxs/spl_boot.c +++ b/arch/arm/cpu/arm926ejs/mxs/spl_boot.c @@ -108,6 +108,8 @@ void mxs_common_spl_init(const iomux_cfg_t *iomux_setup,
data->boot_mode_idx = bootmode;
+ mx28_common_spl_debug_halt(); + mxs_power_wait_pswitch(); }
diff --git a/arch/arm/cpu/arm926ejs/mxs/spl_debug.c b/arch/arm/cpu/arm926ejs/mxs/spl_debug.c new file mode 100644 index 0000000..f0aef20 --- /dev/null +++ b/arch/arm/cpu/arm926ejs/mxs/spl_debug.c @@ -0,0 +1,63 @@ +/* + * Freescale i.MX28 Boot debug helpers + * + * Copyright (C) 2012 Marek Vasut marex@denx.de + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <config.h> +#include <asm/io.h> +#include <asm/arch/iomux-mx28.h> +#include <asm/arch/imx-regs.h> +#include <asm/arch/sys_proto.h> +#include <asm/gpio.h> + +#include "mxs_init.h" + +void mx28_common_spl_debug_halt(void) +{ + /* + * Check for magic setup of DIGCTL_SCRATCH0 and DIGCTL_SCRATCH1 + * registers, which tells the system to halt after initializing + * hardware. This is useful at bootstrap stage, otherwise shall + * be disabled. + */ + struct mxs_digctl_regs *digctl_regs = + (struct mxs_digctl_regs *)MXS_DIGCTL_BASE; + + const uint32_t magic0 = 0xc001f00d; + const uint32_t magic1 = 0x1337b4b3; + uint32_t reg; + + reg = readl(&digctl_regs->hw_digctl_scratch0); + if (reg != magic0) + return; + + reg = readl(&digctl_regs->hw_digctl_scratch1); + if (reg != magic1) + return; + + serial_init(); + serial_puts("Hardware init complete, SPL halted.\n"); + + /* Both magic values matched, hang. */ + asm volatile("x: b x\n"); +}
This is useful if the power management on the chip isn't properly initialized. It's possible to use the internal LRADC to sample various power rails and debug the problem.
Signed-off-by: Marek Vasut marex@denx.de Cc: Wolfgang Denk wd@denx.de Cc: Stefano Babic sbabic@denx.de Cc: Fabio Estevam fabio.estevam@freescale.com --- arch/arm/cpu/arm926ejs/mxs/mxs_init.h | 2 + arch/arm/cpu/arm926ejs/mxs/spl_boot.c | 3 ++ arch/arm/cpu/arm926ejs/mxs/spl_debug.c | 89 ++++++++++++++++++++++++++++++++ 3 files changed, 94 insertions(+)
diff --git a/arch/arm/cpu/arm926ejs/mxs/mxs_init.h b/arch/arm/cpu/arm926ejs/mxs/mxs_init.h index e6f837c..acb62fa 100644 --- a/arch/arm/cpu/arm926ejs/mxs/mxs_init.h +++ b/arch/arm/cpu/arm926ejs/mxs/mxs_init.h @@ -44,8 +44,10 @@ void mxs_lradc_enable_batt_measurement(void);
#ifdef CONFIG_MX28_DEBUG void mx28_common_spl_debug_halt(void); +void mx28_read_lradc(void); #else static inline void mx28_common_spl_debug_halt(void) {} +static inline void mx28_read_lradc(void) {} #endif
#endif /* __M28_INIT_H__ */ diff --git a/arch/arm/cpu/arm926ejs/mxs/spl_boot.c b/arch/arm/cpu/arm926ejs/mxs/spl_boot.c index f4f0c09..ea52a53 100644 --- a/arch/arm/cpu/arm926ejs/mxs/spl_boot.c +++ b/arch/arm/cpu/arm926ejs/mxs/spl_boot.c @@ -104,6 +104,9 @@ void mxs_common_spl_init(const iomux_cfg_t *iomux_setup, mxs_power_init();
mxs_mem_init(); + + mx28_read_lradc(); + data->mem_dram_size = mxs_mem_get_size();
data->boot_mode_idx = bootmode; diff --git a/arch/arm/cpu/arm926ejs/mxs/spl_debug.c b/arch/arm/cpu/arm926ejs/mxs/spl_debug.c index f0aef20..51f9b79 100644 --- a/arch/arm/cpu/arm926ejs/mxs/spl_debug.c +++ b/arch/arm/cpu/arm926ejs/mxs/spl_debug.c @@ -61,3 +61,92 @@ void mx28_common_spl_debug_halt(void) /* Both magic values matched, hang. */ asm volatile("x: b x\n"); } + +static void my_print_int(uint32_t val) +{ + /* 0xffffffff = 4,294,967,295 */ + char buf[10] = {0}; + int i = 0; + + if (!val) { + serial_putc('0'); + return; + } + + for (i = 0; i < 9; i++) { + buf[i] = val % 10; + val /= 10; + } + + for (; i >= 0; i--) + if (buf[i]) + break; + for (; i >= 0; i--) + serial_putc(buf[i] + '0'); +} + +static const char * const mx28_lradc_chan_names[16] = { + "[General Purpose 0]", + "[General Purpose 1]", + "[General Purpose 2]", + "[General Purpose 3]", + "[General Purpose 4]", + "[General Purpose 5]", + "[General Purpose 6]", + "[General Purpose 7 / Battery]", + "[Temperature sense 0]", + "[Temperature sense 1]", + "[VDDIO]", + "[VTH]", + "[VDDA]", + "[VDDD]", + "[VBG]", + "[5V input]", +}; + +static void mx28_read_lradc_chans(int offset) +{ + struct mxs_lradc_regs *regs = (struct mxs_lradc_regs *)MXS_LRADC_BASE; + int i; + uint32_t val; + + mxs_reset_block(®s->hw_lradc_ctrl0_reg); + + /* Flush the block */ + writel(0, ®s->hw_lradc_ctrl0); + writel(0, ®s->hw_lradc_ctrl1); + writel(0, ®s->hw_lradc_ctrl2); + writel(0, ®s->hw_lradc_ctrl3); + + /* Empty the channels */ + for (i = 0; i < 8; i++) + writel(0, ®s->hw_lradc_ch0_reg + i); + + /* Map channels and trigger them */ + writel(offset ? 0xfedcba98 : 0x76543210, ®s->hw_lradc_ctrl4); + writel(0xff, ®s->hw_lradc_ctrl0_set); + + while ((readl(®s->hw_lradc_ctrl1) & 0xff) != 0xff) + ; + + /* Read and report the channels */ + for (i = 0; i < 8; i++) { + val = readl(®s->hw_lradc_ch0_reg + i); + val &= LRADC_CH_VALUE_MASK; + serial_puts("Channel "); + my_print_int(i + (offset * 8)); + serial_putc(' '); + serial_puts(mx28_lradc_chan_names[i + (offset * 8)]); + serial_puts(" = "); + my_print_int(val); + serial_putc('\n'); + } +} + +void mx28_read_lradc(void) +{ + serial_init(); + serial_putc('\n'); + mx28_read_lradc_chans(0); + mx28_read_lradc_chans(1); +}
Hi Marek,
- mx28_common_spl_debug_halt();
- mxs_power_wait_pswitch();
I admit I use the same trick when the first initialization fails and I want to check what happens. Make the SOC hanging helps, sure.
However, this is part of the porting / development. Why should we introduce this code into mainline ? In the official configuration file CONFIG_MX28_DEBUG must be off, and then all this stuff is dead code.
Regards, Stefano
Dear Stefano Babic,
Hi Marek,
endif
Yea ... so either way if it's merged or not, I hope it might help someone :)
Indeed, I'll shift this decision on you ;-)
Regards, Stefano
Best regards, Marek Vasut
Stefano Babic
