Re: [DNX#2006033142000552] [U-Boot-Users] [PATCH] support for mainstone devel [...]
Hello list,
inside the automatic U-Boot patch tracking system a new ticket [DNX#2006033142000552] was created:
<snip>
Attached are files to add support for the Mainstone development board (PXA270 CPU). This work was based on the Lubbock module.
CHANGELOG:
- Add support for the Mainstone development board Patch by Frank Agius, 26 Oct 2005
FrankĀ Agius SAMSys Technologies, Inc.
Index: MAKEALL
RCS file: /cvsroot/u-boot/u-boot/MAKEALL,v retrieving revision 1.128 diff -p -u -r1.128 MAKEALL --- MAKEALL 21 Oct 2005 20:39:10 -0000 1.128 +++ MAKEALL 26 Oct 2005 13:57:35 -0000 @@ -202,8 +202,8 @@ LIST_ARM11=" \
LIST_pxa=" \ adsvix cerf250 cradle csb226 \
- innokom lubbock pxa255_idp wepep250 \
- xaeniax xm250 xsengine \
- innokom lubbock mainstone pxa255_idp \
- wepep250 xaeniax xm250 xsengine \
LIST_ixp="ixdp425" Index: Makefile =================================================================== RCS file: /cvsroot/u-boot/u-boot/Makefile,v retrieving revision 1.212 diff -p -u -r1.212 Makefile --- Makefile 15 Oct 2005 17:08:09 -0000 1.212 +++ Makefile 26 Oct 2005 13:57:36 -0000 @@ -1601,6 +1601,9 @@ lubbock_config : unconfig logodl_config : unconfig @./mkconfig $(@:_config=) arm pxa logodl
+mainstone_config: unconfig
- @./mkconfig $(@:_config=) arm pxa mainstone
pxa255_idp_config: unconfig @./mkconfig $(@:_config=) arm pxa pxa255_idp
Index: README
RCS file: /cvsroot/u-boot/u-boot/README,v retrieving revision 1.138 diff -p -u -r1.138 README --- README 12 Oct 2005 23:47:18 -0000 1.138 +++ README 26 Oct 2005 13:57:37 -0000 @@ -308,9 +308,9 @@ The following options need to be configu CONFIG_H2_OMAP1610, CONFIG_HHP_CRADLE, CONFIG_IMPA7, CONFIG_INNOVATOROMAP1510, CONFIG_INNOVATOROMAP1610, CONFIG_KB9202, CONFIG_LART, CONFIG_LPD7A400, CONFIG_LUBBOCK,
CONFIG_OSK_OMAP5912, CONFIG_OMAP2420H4,
CONFIG_SHANNON,
CONFIG_P2_OMAP730, CONFIG_SMDK2400,
CONFIG_SMDK2410,
CONFIG_TRAB, CONFIG_VCMA9
CONFIG_MAINSTONE, CONFIG_OSK_OMAP5912,
CONFIG_OMAP2420H4,
CONFIG_SHANNON, CONFIG_P2_OMAP730,
CONFIG_SMDK2400,
CONFIG_SMDK2410, CONFIG_TRAB, CONFIG_VCMA9
MicroBlaze based boards:
Index: drivers/smc91111.c
RCS file: /cvsroot/u-boot/u-boot/drivers/smc91111.c,v retrieving revision 1.19 diff -p -u -r1.19 smc91111.c --- drivers/smc91111.c 22 Nov 2004 22:20:09 -0000 1.19 +++ drivers/smc91111.c 26 Oct 2005 13:57:40 -0000 @@ -495,7 +495,15 @@ static void smc_enable() SMC_SELECT_BANK( 0 ); /* see the header file for options in TCR/RCR DEFAULT*/ SMC_outw( TCR_DEFAULT, TCR_REG ); +#ifdef CONFIG_SMC_PXA270
- /* The promiscuous bit set because I could not receive ARP reply
* packets from the server when I send a ARP request. It only works
* when I set the promiscuous bit
- SMC_outw( RCR_DEFAULT | RCR_PRMS, RCR_REG );
+#else SMC_outw( RCR_DEFAULT, RCR_REG ); +#endif
/* clear MII_DIS */ /* smc_write_phy_register(PHY_CNTL_REG, 0x0000); */ @@ -529,7 +537,6 @@ static void smc_shutdown() SMC_outb( TCR_CLEAR, TCR_REG ); }
</snip>
Your U-Boot support team
DENX Support System
