[U-Boot-Users] [PATCH] 86xx: Fix lingering CFG_CMD_* references in sbc8641d.h
Remove a leftover in net/tftp.c while we're at it.
Signed-off-by: Jon Loeliger jdl@freescale.com ---
Someone, who should have known-better, should have caught this earlier. :-)
include/configs/sbc8641d.h | 6 +++--- net/tftp.c | 2 +- 2 files changed, 4 insertions(+), 4 deletions(-)
diff --git a/include/configs/sbc8641d.h b/include/configs/sbc8641d.h index 68d31ca..277b611 100644 --- a/include/configs/sbc8641d.h +++ b/include/configs/sbc8641d.h @@ -492,7 +492,7 @@ #define CFG_LOAD_ADDR 0x2000000 /* default load address */ #define CFG_PROMPT "=> " /* Monitor Command Prompt */
-#if (CONFIG_COMMANDS & CFG_CMD_KGDB) +#if defined(CONFIG_CMD_KGDB) #define CFG_CBSIZE 1024 /* Console I/O Buffer Size */ #else #define CFG_CBSIZE 256 /* Console I/O Buffer Size */ @@ -513,7 +513,7 @@ /* Cache Configuration */ #define CFG_DCACHE_SIZE 32768 #define CFG_CACHELINE_SIZE 32 -#if (CONFIG_COMMANDS & CFG_CMD_KGDB) +#if defined(CONFIG_CMD_KGDB) #define CFG_CACHELINE_SHIFT 5 /*log base 2 of the above value*/ #endif
@@ -525,7 +525,7 @@ #define BOOTFLAG_COLD 0x01 /* Normal Power-On: Boot from FLASH */ #define BOOTFLAG_WARM 0x02 /* Software reboot */
-#if (CONFIG_COMMANDS & CFG_CMD_KGDB) +#if defined(CONFIG_CMD_KGDB) #define CONFIG_KGDB_BAUDRATE 230400 /* speed to run kgdb serial port */ #define CONFIG_KGDB_SER_INDEX 2 /* which serial port to use */ #endif diff --git a/net/tftp.c b/net/tftp.c index 888ec98..d6db91c 100644 --- a/net/tftp.c +++ b/net/tftp.c @@ -614,4 +614,4 @@ static void parse_multicast_oack(char *pkt, int len)
#endif /* Multicast TFTP */
-#endif /* CFG_CMD_NET */ +#endif
Applied, thanks.
I wonder who you might have in mind... There are at leats two of us.
Applied, thanks.
Thanks.
Oh, that's all mine, I'm afraid. ;-)
jdl
Jon Loeliger
