Re: [PATCH v4 1/4] fu540: prci: add request and free clock handlers
Hi Sagar,
From: Sagar Shrikant Kadam [mailto:sagar.kadam@sifive.com] Sent: Sunday, June 21, 2020 9:10 PM To: u-boot@lists.denx.de Cc: Rick Jian-Zhi Chen(陳建志); lukma@denx.de; bmeng.cn@gmail.com; jagan@amarulasolutions.com; pragnesh.patel@sifive.com; anup.patel@wdc.com; sjg@chromium.org; seanga2@gmail.com; Sagar Shrikant Kadam Subject: [PATCH v4 1/4] fu540: prci: add request and free clock handlers
Add clk_request handler to check if a valid clock is requested. Here clk_free handler is added for debug purpose which will display details of clock passed to clk_free.
Signed-off-by: Sagar Shrikant Kadam sagar.kadam@sifive.com Reviewed-by: Pragnesh Patel Pragnesh.patel@sifive.com
This v4 series still have some conflicts with master. Please check about it.
Applying: fu540: prci: add request and free clock handlers Applying: riscv: dts: hifive-unleashed-a00: add cpu aliases Applying: riscv: cpu: fixes to display proper CPU features error: patch failed: drivers/cpu/riscv_cpu.c:38 error: drivers/cpu/riscv_cpu.c: patch does not apply Patch failed at 0003 riscv: cpu: fixes to display proper CPU features
Thanks, Rick
drivers/clk/sifive/fu540-prci.c | 21 +++++++++++++++++++++ 1 file changed, 21 insertions(+)
diff --git a/drivers/clk/sifive/fu540-prci.c b/drivers/clk/sifive/fu540-prci.c index fe6e0d4..9a9ff6b 100644 --- a/drivers/clk/sifive/fu540-prci.c +++ b/drivers/clk/sifive/fu540-prci.c @@ -686,6 +686,25 @@ static ulong sifive_fu540_prci_set_rate(struct clk *clk, ulong rate) return rate; }
+static int sifive_fu540_prci_clk_request(struct clk *clk) {
debug("%s(clk=%p) (dev=%p, id=%lu)\n", __func__, clk, clk->dev,
clk->id);
if (clk->id >= ARRAY_SIZE(__prci_init_clocks))
return -EINVAL;
+static int sifive_fu540_prci_clk_free(struct clk *clk) {
clk->id);
static int sifive_fu540_prci_enable(struct clk *clk) { struct __prci_clock *pc; @@ -755,6 +774,8 @@ static struct clk_ops sifive_fu540_prci_ops = { .get_rate = sifive_fu540_prci_get_rate, .enable = sifive_fu540_prci_enable, .disable = sifive_fu540_prci_disable,
.request = sifive_fu540_prci_clk_request,
.rfree = sifive_fu540_prci_clk_free,
static const struct udevice_id sifive_fu540_prci_ids[] = {
2.7.4
Hello Rick,
-----Original Message----- From: Rick Chen rickchen36@gmail.com Sent: Monday, June 22, 2020 7:24 AM To: Sagar Kadam sagar.kadam@sifive.com Cc: U-Boot Mailing List u-boot@lists.denx.de; Lukasz Majewski lukma@denx.de; Bin Meng bmeng.cn@gmail.com; Jagan Teki jagan@amarulasolutions.com; Pragnesh Patel pragnesh.patel@sifive.com; Anup Patel anup.patel@wdc.com; Simon Glass sjg@chromium.org; Sean Anderson seanga2@gmail.com; rick rick@andestech.com; Alan Kao alankao@andestech.com; ycliang@andestech.com Subject: Re: [PATCH v4 1/4] fu540: prci: add request and free clock handlers
[External Email] Do not click links or attachments unless you recognize the sender and know the content is safe
Hi Sagar,
Thanks for trying this out This series is dependent on following two patches [1] and [2] below which are part of "Add Sipeed Maix support." series [1] https://patchwork.ozlabs.org/patch/1295345 [2] https://patchwork.ozlabs.org/patch/1295346 and I also mentioned in cover-letter. Sorry If I missed to add some additional information there.
The dependent are added like -u-boot master [commit 2b8692bac1e8]. -Patches [1] + [2]. -This series.
I guess the PR for the series was sent earlier followed with some discussion https://www.mail-archive.com/u-boot@lists.denx.de/msg370739.html and I think this series was deferred in that PR. Please let me know if you have some suggestions here?
Thanks & BR, Sagar Kadam
Thanks, Rick
*clk, ulong rate)
return rate;
clk->id);
return -EINVAL;
clk->id);
2.7.4
Hi Sagar
Hello Rick,
Hi Sagar,
According to this dependency I will apply yours in -next behind of Sean's
Thanks, Rick
Thanks, Rick
*clk, ulong rate)
return rate;
clk->id);
return -EINVAL;
clk->id);
2.7.4
Hi Rick,
On Wed, Jun 24, 2020 at 9:36 AM Rick Chen rickchen36@gmail.com wrote:
Hi Sagar
Hello Rick,
Hi Sagar,
I just sent comments to this series, please hold on.
Regards, Bin
Hi Bin
Hi Rick,
Hi Sagar
Hello Rick,
Hi Sagar,
OK.
Thanks, Rick
Regards, Bin
Hi Rick,
-----Original Message----- From: Rick Chen rickchen36@gmail.com Sent: Wednesday, June 24, 2020 7:16 AM To: Bin Meng bmeng.cn@gmail.com Cc: Sagar Kadam sagar.kadam@sifive.com; U-Boot Mailing List <u- boot@lists.denx.de>; Lukasz Majewski lukma@denx.de; Jagan Teki jagan@amarulasolutions.com; Pragnesh Patel pragnesh.patel@sifive.com; Anup Patel anup.patel@wdc.com; Simon Glass sjg@chromium.org; Sean Anderson seanga2@gmail.com; rick rick@andestech.com; Alan Kao alankao@andestech.com; ycliang@andestech.com Subject: Re: [PATCH v4 1/4] fu540: prci: add request and free clock handlers
Hi Bin
Hi Rick,
wrote:
Hi Sagar
Hello Rick,
Hi Sagar,
OK.
Thanks for holding on. Yes, Bin has sent few comments. I will submit V5 for this.
Thanks & BR, Sagar
Thanks, Rick
Regards, Bin
Bin Meng
Rick Chen
Sagar Kadam
