[U-Boot] [PATCH] configs: Remove am335x_boneblack_defconfig
The am335x_evm_defconfig supports all am335x_boneblack variants. Remove the redundant am335x_boneblack_defconfig.
Signed-off-by: Faiz Abbas faiz_abbas@ti.com --- configs/am335x_boneblack_defconfig | 50 ------------------------------ 1 file changed, 50 deletions(-) delete mode 100644 configs/am335x_boneblack_defconfig
diff --git a/configs/am335x_boneblack_defconfig b/configs/am335x_boneblack_defconfig deleted file mode 100644 index 439d0cba05..0000000000 --- a/configs/am335x_boneblack_defconfig +++ /dev/null @@ -1,50 +0,0 @@ -CONFIG_ARM=y -CONFIG_ARCH_OMAP2PLUS=y -CONFIG_TI_COMMON_CMD_OPTIONS=y -CONFIG_AM33XX=y -CONFIG_SPL=y -CONFIG_DISTRO_DEFAULTS=y -CONFIG_SYS_EXTRA_OPTIONS="EMMC_BOOT" -CONFIG_BOOTCOMMAND="if test ${boot_fit} -eq 1; then run update_to_fit; fi; run findfdt; run init_console; run envboot; run distro_bootcmd" -CONFIG_SYS_CONSOLE_INFO_QUIET=y -CONFIG_VERSION_VARIABLE=y -CONFIG_ARCH_MISC_INIT=y -CONFIG_SPL_MUSB_NEW_SUPPORT=y -# CONFIG_SPL_NAND_SUPPORT is not set -CONFIG_SPL_OS_BOOT=y -CONFIG_AUTOBOOT_KEYED=y -CONFIG_AUTOBOOT_PROMPT="Press SPACE to abort autoboot in %d seconds\n" -CONFIG_AUTOBOOT_DELAY_STR="d" -CONFIG_AUTOBOOT_STOP_STR=" " -CONFIG_CMD_SPL=y -# CONFIG_CMD_FLASH is not set -# CONFIG_CMD_SETEXPR is not set -CONFIG_ENV_IS_IN_MMC=y -CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y -CONFIG_BOOTCOUNT_LIMIT=y -CONFIG_DFU_TFTP=y -CONFIG_DFU_MMC=y -CONFIG_DFU_RAM=y -CONFIG_USB_FUNCTION_FASTBOOT=y -CONFIG_FASTBOOT_FLASH=y -CONFIG_FASTBOOT_FLASH_MMC_DEV=1 -CONFIG_FASTBOOT_CMD_OEM_FORMAT=y -CONFIG_MMC_OMAP_HS=y -CONFIG_SPI_FLASH=y -CONFIG_SPI_FLASH_WINBOND=y -CONFIG_MII=y -CONFIG_DRIVER_TI_CPSW=y -CONFIG_SPI=y -CONFIG_OMAP3_SPI=y -CONFIG_USB=y -CONFIG_USB_MUSB_HOST=y -CONFIG_USB_MUSB_GADGET=y -CONFIG_USB_MUSB_DSPS=y -CONFIG_USB_GADGET=y -CONFIG_USB_GADGET_MANUFACTURER="Texas Instruments" -CONFIG_USB_GADGET_VENDOR_NUM=0x0451 -CONFIG_USB_GADGET_PRODUCT_NUM=0xd022 -CONFIG_USB_ETHER=y -CONFIG_USBNET_HOST_ADDR="de:ad:be:af:00:00" -CONFIG_LZO=y -CONFIG_OF_LIBFDT=y
Since the thinking at the time was to have env somewhere usable on these platforms (it was not on the _evm variant at the time), yes:
But the _vboot one needs to be updated as that's one of the canonical examples of using FIT images and verified boot in U-Boot. Thanks!
Signed-off-by: Faiz Abbas faiz_abbas@ti.com Reviewed-by: Tom Rini trini@konsulko.com
Faiz Abbas
