[PATCH v9 00/15] FWU: Add FWU Multi Bank Update feature support
The patchset adds support for the FWU Multi Bank Update[1] feature. Certain aspects of the Dependable Boot[2] specification have also been implemented.
The FWU multi bank update feature is used for supporting multiple sets(also called banks) of firmware image(s), allowing the platform to boot from a different bank, in case it fails to boot from the active bank. This functionality is supported by keeping the relevant information in a structure called metadata, which provides information on the images. Among other parameters, the metadata structure contains information on the currect active bank that is being used to boot image(s).
Functionality is being added to work with the UEFI capsule driver in u-boot. The metadata is read to gather information on the update bank, which is the bank to which the firmware images would be flashed to. On a successful completion of the update of all components, the active bank field in the metadata is updated, to reflect the bank from which the platform will boot on the subsequent boots.
Currently, the feature is being enabled on the STM32MP157C-DK2 and Synquacer boards. The DK2 board boots a FIP image from a uSD card partitioned with the GPT partioning scheme, while the Synquacer board boots a FIP image from a MTD partitioned SPI NOR flash device.
This feature also requires changes in a previous stage of bootloader, which parses the metadata and selects the bank to boot the image(s) from. Support has being added in tf-a(BL2 stage) for the STM32MP157C-DK2 board to boot the active bank images. These changes have been merged to the upstream tf-a repository.
The patch for adding a python test for the feature has been developed, and was sent in the version 5 of the patches[3]. However, the test script depends on adding support for the feature on MTD SPI NOR devices, and that is being done as part of the Synquacer patches. Hence these set of patches do not have the test script for the feature. That will be added through the patches for adding support for the feauture on Synquacer platform.
[1] - https://developer.arm.com/documentation/den0118/a [2] - https://git.codelinaro.org/linaro/dependable-boot/mbfw/uploads/6f7ddfe3be24e... [3] - https://lists.denx.de/pipermail/u-boot/2022-June/485992.html
Changes since V8: * Declare the metadata struct on the stack rather than heap * Move the API's to fwu.c and only keep the DM ops in the uclass driver * Fix return codes as suggested by Simon * Change log_err to log_debug as suggested by Simon * Remove the __packed attribute on the metadata structures as suggested by Simon * Add comments to the API functions * Rename fwu_mdata_gpt_blk.c as gpt_blk.c as suggested by Simon * Use natural integer types instead of specific width integers as suggested by Simon * Fix return codes as suggested by Simon * Code cleanup of some superfluous error checks, like for dev_get_uclass_plat() function * Use blk_get_from_parent() for getting the parent of the block device containing the FWU metadata * Use STM32MP_FIP_IMAGE_GUID for the FIP GUID value as suggested by Yann * Update the logic to get the update index as suggested by Jassi * Call fwu_boottime_checks through the event interface * Move addition of the FWU Kconfig symbols and Makefile to this patch * Fixed spelling mistake in the commit message
Sughosh Ganu (15): dt/bindings: Add bindings for GPT based FWU Metadata storage device FWU: Add FWU metadata structure and driver for accessing metadata FWU: Add FWU metadata access driver for GPT partitioned block devices stm32mp1: dk2: Add a node for the FWU metadata device stm32mp1: dk2: Add image information for capsule updates FWU: Add helper functions for accessing FWU metadata FWU: STM32MP1: Add support to read boot index from backup register event: Add an event for main_loop FWU: Add boot time checks as highlighted by the FWU specification FWU: Add support for the FWU Multi Bank Update feature FWU: cmd: Add a command to read FWU metadata test: dm: Add test cases for FWU Metadata uclass mkeficapsule: Add support for generating empty capsules mkeficapsule: Add support for setting OEM flags in capsule header FWU: doc: Add documentation for the FWU feature
arch/arm/dts/stm32mp157c-dk2-u-boot.dtsi | 7 + arch/arm/mach-stm32mp/include/mach/stm32.h | 5 + arch/sandbox/Kconfig | 6 + arch/sandbox/dts/test.dts | 7 +- board/sandbox/sandbox.c | 10 + board/st/stm32mp1/stm32mp1.c | 46 ++ cmd/Kconfig | 6 + cmd/Makefile | 1 + cmd/fwu_mdata.c | 79 +++ common/board_r.c | 3 + common/event.c | 3 + configs/sandbox64_defconfig | 5 +- doc/develop/uefi/fwu_updates.rst | 165 +++++ doc/develop/uefi/index.rst | 1 + doc/develop/uefi/uefi.rst | 2 + .../firmware/fwu-mdata-gpt.yaml | 32 + doc/mkeficapsule.1 | 33 +- drivers/Kconfig | 2 + drivers/Makefile | 1 + drivers/fwu-mdata/Kconfig | 16 + drivers/fwu-mdata/Makefile | 8 + drivers/fwu-mdata/fwu-mdata-uclass.c | 107 ++++ drivers/fwu-mdata/gpt_blk.c | 378 +++++++++++ include/configs/stm32mp15_common.h | 4 + include/dm/uclass-id.h | 1 + include/event.h | 3 + include/fwu.h | 298 +++++++++ include/fwu_mdata.h | 67 ++ lib/Kconfig | 6 + lib/Makefile | 1 + lib/efi_loader/efi_capsule.c | 213 ++++++- lib/efi_loader/efi_setup.c | 4 +- lib/fwu_updates/Kconfig | 32 + lib/fwu_updates/Makefile | 7 + lib/fwu_updates/fwu.c | 600 ++++++++++++++++++ lib/fwu_updates/fwu_gpt.c | 115 ++++ test/dm/Makefile | 1 + test/dm/fwu_mdata.c | 149 +++++ test/dm/fwu_mdata_disk_image.h | 112 ++++ .../test_capsule_firmware_fit.py | 1 - .../test_capsule_firmware_signed_fit.py | 1 - tools/Makefile | 2 +- tools/eficapsule.h | 8 + tools/mkeficapsule.c | 109 +++- 44 files changed, 2631 insertions(+), 26 deletions(-) create mode 100644 cmd/fwu_mdata.c create mode 100644 doc/develop/uefi/fwu_updates.rst create mode 100644 doc/device-tree-bindings/firmware/fwu-mdata-gpt.yaml create mode 100644 drivers/fwu-mdata/Kconfig create mode 100644 drivers/fwu-mdata/Makefile create mode 100644 drivers/fwu-mdata/fwu-mdata-uclass.c create mode 100644 drivers/fwu-mdata/gpt_blk.c create mode 100644 include/fwu.h create mode 100644 include/fwu_mdata.h create mode 100644 lib/fwu_updates/Kconfig create mode 100644 lib/fwu_updates/Makefile create mode 100644 lib/fwu_updates/fwu.c create mode 100644 lib/fwu_updates/fwu_gpt.c create mode 100644 test/dm/fwu_mdata.c create mode 100644 test/dm/fwu_mdata_disk_image.h
Add bindings needed for accessing the FWU metadata partitions. These include the compatible string which point to the access method and the actual device which stores the FWU metadata.
The current patch adds basic bindings needed for accessing the metadata structure on GPT partitioned block devices.
Signed-off-by: Sughosh Ganu sughosh.ganu@linaro.org Reviewed-by: Heinrich Schuchardt xypron.glpk@gmx.de --- Changes since V8: None
.../firmware/fwu-mdata-gpt.yaml | 32 +++++++++++++++++++ 1 file changed, 32 insertions(+) create mode 100644 doc/device-tree-bindings/firmware/fwu-mdata-gpt.yaml
diff --git a/doc/device-tree-bindings/firmware/fwu-mdata-gpt.yaml b/doc/device-tree-bindings/firmware/fwu-mdata-gpt.yaml new file mode 100644 index 0000000000..0735191ff1 --- /dev/null +++ b/doc/device-tree-bindings/firmware/fwu-mdata-gpt.yaml @@ -0,0 +1,32 @@ +# SPDX-License-Identifier: (GPL-2.0 OR BSD-2-Clause) +%YAML 1.2 +--- +$id: http://devicetree.org/schemas/firmware/fwu-mdata-gpt.yaml# +$schema: http://devicetree.org/meta-schemas/core.yaml# + +title: FWU metadata on device with GPT partitioned layout + +maintainers: + - Sughosh Ganu sughosh.ganu@linaro.org + +properties: + compatible: + items: + - const: u-boot,fwu-mdata-gpt + + fwu-mdata-store: + maxItems: 1 + description: Phandle of the device which contains the FWU medatata partition. + +required: + - compatible + - fwu-mdata-store + +additionalProperties: false + +examples: + - | + fwu-mdata { + compatible = "u-boot,fwu-mdata-gpt"; + fwu-mdata-store = <&sdmmc1>; + };
+maintainers:
+properties:
- compatible:
- items:
- fwu-mdata-store:
- maxItems: 1
- description: Phandle of the device which contains the FWU medatata partition.
+required:
- compatible
- fwu-mdata-store
+examples:
- fwu-mdata {
-- 2.34.1
Reviewed-by: Ilias Apalodimas ilias.apalodimas@linaro.org
Acked-by: Etienne Carriere etienne.carriere@linaro.org
+maintainers:
+properties:
- compatible:
- items:
- fwu-mdata-store:
- maxItems: 1
+required:
- compatible
- fwu-mdata-store
+examples:
- fwu-mdata {
-- 2.34.1
In the FWU Multi Bank Update feature, the information about the updatable images is stored as part of the metadata, which is stored on a dedicated partition. Add the metadata structure, and a driver model uclass which provides functions to access the metadata. These are generic API's, and implementations can be added based on parameters like how the metadata partition is accessed and what type of storage device houses the metadata.
Signed-off-by: Sughosh Ganu sughosh.ganu@linaro.org Reviewed-by: Patrick Delaunay patrick.delaunay@foss.st.com --- Changes since V8: * Declare the metadata struct on the stack rather than heap * Move the API's to fwu.c and only keep the DM ops in the uclass driver * Fix return codes as suggested by Simon * Change log_err to log_debug as suggested by Simon * Remove the __packed attribute on the metadata structures as suggested by Simon * Add comments to the API functions
drivers/fwu-mdata/fwu-mdata-uclass.c | 107 ++++++++ include/dm/uclass-id.h | 1 + include/fwu.h | 210 ++++++++++++++++ include/fwu_mdata.h | 67 +++++ lib/fwu_updates/fwu.c | 357 +++++++++++++++++++++++++++ 5 files changed, 742 insertions(+) create mode 100644 drivers/fwu-mdata/fwu-mdata-uclass.c create mode 100644 include/fwu.h create mode 100644 include/fwu_mdata.h create mode 100644 lib/fwu_updates/fwu.c
diff --git a/drivers/fwu-mdata/fwu-mdata-uclass.c b/drivers/fwu-mdata/fwu-mdata-uclass.c new file mode 100644 index 0000000000..65ae93c21f --- /dev/null +++ b/drivers/fwu-mdata/fwu-mdata-uclass.c @@ -0,0 +1,107 @@ +// SPDX-License-Identifier: GPL-2.0-or-later +/* + * Copyright (c) 2022, Linaro Limited + */ + +#define LOG_CATEGORY UCLASS_FWU_MDATA + +#include <common.h> +#include <dm.h> +#include <efi_loader.h> +#include <fwu.h> +#include <fwu_mdata.h> +#include <log.h> + +#include <linux/errno.h> +#include <linux/types.h> +#include <u-boot/crc.h> + +/** + * fwu_mdata_check() - Check if the FWU metadata is valid + * @dev: FWU metadata device + * + * Validate both copies of the FWU metadata. If one of the copies + * has gone bad, restore it from the other bad copy. + * + * Return: 0 if OK, -ve on error + * + */ +int fwu_mdata_check(struct udevice *dev) +{ + const struct fwu_mdata_ops *ops = device_get_ops(dev); + + if (!ops->mdata_check) { + log_debug("mdata_check() method not defined\n"); + return -ENOSYS; + } + + return ops->mdata_check(dev); +} + +/** + * fwu_get_mdata() - Get a FWU metadata copy + * @dev: FWU metadata device + * @mdata: Copy of the FWU metadata + * + * Get a valid copy of the FWU metadata. + * + * Note: This function is to be called first when modifying any fields + * in the metadata. The sequence of calls to modify any field in the + * metadata would be 1) fwu_get_mdata 2) Modify metadata, followed by + * 3) fwu_update_mdata + * + * Return: 0 if OK, -ve on error + * + */ +int fwu_get_mdata(struct udevice *dev, struct fwu_mdata *mdata) +{ + const struct fwu_mdata_ops *ops = device_get_ops(dev); + + if (!ops->get_mdata) { + log_debug("get_mdata() method not defined\n"); + return -ENOSYS; + } + + return ops->get_mdata(dev, mdata); +} + +/** + * fwu_update_mdata() - Update the FWU metadata + * @dev: FWU metadata device + * @mdata: Copy of the FWU metadata + * + * Update the FWU metadata structure by writing to the + * FWU metadata partitions. + * + * Note: This function is not to be called directly to update the + * metadata fields. The sequence of function calls should be + * 1) fwu_get_mdata() 2) Modify the medata fields 3) fwu_update_mdata() + * + * Return: 0 if OK, -ve on error + * + */ +int fwu_update_mdata(struct udevice *dev, struct fwu_mdata *mdata) +{ + void *buf; + const struct fwu_mdata_ops *ops = device_get_ops(dev); + + if (!ops->update_mdata) { + log_debug("get_mdata() method not defined\n"); + return -ENOSYS; + } + + /* + * Calculate the crc32 for the updated FWU metadata + * and put the updated value in the FWU metadata crc32 + * field + */ + buf = &mdata->version; + mdata->crc32 = crc32(0, buf, sizeof(*mdata) - sizeof(u32)); + + return ops->update_mdata(dev, mdata); +} + +UCLASS_DRIVER(fwu_mdata) = { + .id = UCLASS_FWU_MDATA, + .name = "fwu-mdata", +}; diff --git a/include/dm/uclass-id.h b/include/dm/uclass-id.h index a432e43871..598a8c10a0 100644 --- a/include/dm/uclass-id.h +++ b/include/dm/uclass-id.h @@ -58,6 +58,7 @@ enum uclass_id { UCLASS_FIRMWARE, /* Firmware */ UCLASS_FUZZING_ENGINE, /* Fuzzing engine */ UCLASS_FS_FIRMWARE_LOADER, /* Generic loader */ + UCLASS_FWU_MDATA, /* FWU Metadata Access */ UCLASS_GPIO, /* Bank of general-purpose I/O pins */ UCLASS_HASH, /* Hash device */ UCLASS_HWSPINLOCK, /* Hardware semaphores */ diff --git a/include/fwu.h b/include/fwu.h new file mode 100644 index 0000000000..2335981d28 --- /dev/null +++ b/include/fwu.h @@ -0,0 +1,210 @@ +/* SPDX-License-Identifier: GPL-2.0-or-later */ +/* + * Copyright (c) 2022, Linaro Limited + */ + +#if !defined _FWU_H_ +#define _FWU_H_ + +#include <blk.h> +#include <efi.h> + +#include <linux/types.h> + +struct fwu_mdata; +struct udevice; + +/** + * @mdata_check: check the validity of the FWU metadata partitions + * @get_mdata() - Get a FWU metadata copy + * @update_mdata() - Update the FWU metadata copy + */ +struct fwu_mdata_ops { + /** + * mdata_check() - Check if the FWU metadata is valid + * @dev: FWU device + * + * Validate both copies of the FWU metadata. If one of the copies + * has gone bad, restore it from the other bad copy. + * + * Return: 0 if OK, -ve on error + */ + int (*mdata_check)(struct udevice *dev); + + /** + * get_mdata() - Get a FWU metadata copy + * @dev: FWU device + * @mdata: Pointer to FWU metadata + * + * Get a valid copy of the FWU metadata. + * + * Return: 0 if OK, -ve on error + */ + int (*get_mdata)(struct udevice *dev, struct fwu_mdata *mdata); + + /** + * fwu_update_mdata() - Update the FWU metadata + * @dev: FWU device + * @mdata: Copy of the FWU metadata + * + * Update the FWU metadata structure by writing to the + * FWU metadata partitions. + * + * Return: 0 if OK, -ve on error + */ + int (*update_mdata)(struct udevice *dev, struct fwu_mdata *mdata); +}; + +#define FWU_MDATA_VERSION 0x1 + +/* +* GUID value defined in the FWU specification for identification +* of the FWU metadata partition. +*/ +#define FWU_MDATA_GUID \ + EFI_GUID(0x8a7a84a0, 0x8387, 0x40f6, 0xab, 0x41, \ + 0xa8, 0xb9, 0xa5, 0xa6, 0x0d, 0x23) + +/** + * fwu_get_mdata() - Get a FWU metadata copy + * @dev: FWU metadata device + * @mdata: Copy of the FWU metadata + * + * Get a valid copy of the FWU metadata. + * + * Note: This function is to be called first when modifying any fields + * in the metadata. The sequence of calls to modify any field in the + * metadata would be 1) fwu_get_mdata 2) Modify metadata, followed by + * 3) fwu_update_mdata + * + * Return: 0 if OK, -ve on error + * + */ +int fwu_get_mdata(struct udevice *dev, struct fwu_mdata *mdata); + +/** + * fwu_update_mdata() - Update the FWU metadata + * @dev: FWU metadata device + * @mdata: Copy of the FWU metadata + * + * Update the FWU metadata structure by writing to the + * FWU metadata partitions. + * + * Note: This function is not to be called directly to update the + * metadata fields. The sequence of function calls should be + * 1) fwu_get_mdata() 2) Modify the medata fields 3) fwu_update_mdata() + * + * Return: 0 if OK, -ve on error + * + */ +int fwu_update_mdata(struct udevice *dev, struct fwu_mdata *mdata); + +/** + * fwu_get_active_index() - Get active_index from the FWU metadata + * @active_idxp: active_index value to be read + * + * Read the active_index field from the FWU metadata and place it in + * the variable pointed to be the function argument. + * + * Return: 0 if OK, -ve on error + * + */ +int fwu_get_active_index(u32 *active_idxp); + +/** + * fwu_update_active_index() - Update active_index from the FWU metadata + * @active_idx: active_index value to be updated + * + * Update the active_index field in the FWU metadata + * + * Return: 0 if OK, -ve on error + * + */ +int fwu_update_active_index(uint active_idx); + +/** + * fwu_get_image_alt_num() - Get the dfu alt number to be used for capsule update + * @image_type_id: pointer to the image GUID as passed in the capsule + * @update_bank: Bank to which the update is to be made + * @alt_num: The alt_num for the image + * + * Based on the GUID value passed in the capsule, along with the bank to which the + * image needs to be updated, get the dfu alt number which will be used for the + * capsule update + * + * Return: 0 if OK, -ve on error + * + */ +int fwu_get_image_alt_num(efi_guid_t *image_type_id, u32 update_bank, + int *alt_num); + +/** + * fwu_mdata_check() - Check if the FWU metadata is valid + * @dev: FWU metadata device + * + * Validate both copies of the FWU metadata. If one of the copies + * has gone bad, restore it from the other bad copy. + * + * Return: 0 if OK, -ve on error + * + */ +int fwu_mdata_check(struct udevice *dev); + +/** + * fwu_revert_boot_index() - Revert the active index in the FWU metadata + * + * Revert the active_index value in the FWU metadata, by swapping the values + * of active_index and previous_active_index in both copies of the + * FWU metadata. + * + * Return: 0 if OK, -ve on error + * + */ +int fwu_revert_boot_index(void); + +/** + * fwu_verify_mdata() - Verify the FWU metadata + * @mdata: FWU metadata structure + * @pri_part: FWU metadata partition is primary or secondary + * + * Verify the FWU metadata by computing the CRC32 for the metadata + * structure and comparing it against the CRC32 value stored as part + * of the structure. + * + * Return: 0 if OK, -ve on error + * + */ +int fwu_verify_mdata(struct fwu_mdata *mdata, bool pri_part); + +/** + * fwu_accept_image() - Set the Acceptance bit for the image + * @img_type_id: GUID of the image type for which the accepted bit is to be + * cleared + * @bank: Bank of which the image's Accept bit is to be set + * + * Set the accepted bit for the image specified by the img_guid parameter. This + * indicates acceptance of image for subsequent boots by some governing component + * like OS(or firmware). + * + * Return: 0 if OK, -ve on error + * + */ +int fwu_accept_image(efi_guid_t *img_type_id, u32 bank); + +/** + * fwu_clear_accept_image() - Clear the Acceptance bit for the image + * @img_type_id: GUID of the image type for which the accepted bit is to be + * cleared + * @bank: Bank of which the image's Accept bit is to be cleared + * + * Clear the accepted bit for the image type specified by the img_type_id parameter. + * This function is called after the image has been updated. The accepted bit is + * cleared to be set subsequently after passing the image acceptance criteria, by + * either the OS(or firmware) + * + * Return: 0 if OK, -ve on error + * + */ +int fwu_clear_accept_image(efi_guid_t *img_type_id, u32 bank); + +#endif /* _FWU_H_ */ diff --git a/include/fwu_mdata.h b/include/fwu_mdata.h new file mode 100644 index 0000000000..8fda4f4ac2 --- /dev/null +++ b/include/fwu_mdata.h @@ -0,0 +1,67 @@ +/* SPDX-License-Identifier: GPL-2.0-or-later */ +/* + * Copyright (c) 2022, Linaro Limited + */ + +#if !defined _FWU_MDATA_H_ +#define _FWU_MDATA_H_ + +#include <efi.h> + +/** + * struct fwu_image_bank_info - firmware image information + * @image_uuid: Guid value of the image in this bank + * @accepted: Acceptance status of the image + * @reserved: Reserved + * + * The structure contains image specific fields which are + * used to identify the image and to specify the image's + * acceptance status + */ +struct fwu_image_bank_info { + efi_guid_t image_uuid; + uint32_t accepted; + uint32_t reserved; +}; + +/** + * struct fwu_image_entry - information for a particular type of image + * @image_type_uuid: Guid value for identifying the image type + * @location_uuid: Guid of the storage volume where the image is located + * @img_bank_info: Array containing properties of images + * + * This structure contains information on various types of updatable + * firmware images. Each image type then contains an array of image + * information per bank. + */ +struct fwu_image_entry { + efi_guid_t image_type_uuid; + efi_guid_t location_uuid; + struct fwu_image_bank_info img_bank_info[CONFIG_FWU_NUM_BANKS]; +}; + +/** + * struct fwu_mdata - FWU metadata structure for multi-bank updates + * @crc32: crc32 value for the FWU metadata + * @version: FWU metadata version + * @active_index: Index of the bank currently used for booting images + * @previous_active_inde: Index of the bank used before the current bank + * being used for booting + * @img_entry: Array of information on various firmware images that can + * be updated + * + * This structure is used to store all the needed information for performing + * multi bank updates on the platform. This contains info on the bank being + * used to boot along with the information needed for identification of + * individual images + */ +struct fwu_mdata { + uint32_t crc32; + uint32_t version; + uint32_t active_index; + uint32_t previous_active_index; + + struct fwu_image_entry img_entry[CONFIG_FWU_NUM_IMAGES_PER_BANK]; +}; + +#endif /* _FWU_MDATA_H_ */ diff --git a/lib/fwu_updates/fwu.c b/lib/fwu_updates/fwu.c new file mode 100644 index 0000000000..a871d77b4c --- /dev/null +++ b/lib/fwu_updates/fwu.c @@ -0,0 +1,357 @@ +// SPDX-License-Identifier: GPL-2.0-or-later +/* + * Copyright (c) 2022, Linaro Limited + */ + +#include <dm.h> +#include <efi_loader.h> +#include <fwu.h> +#include <fwu_mdata.h> +#include <log.h> + +#include <linux/errno.h> +#include <linux/types.h> +#include <u-boot/crc.h> + +#define IMAGE_ACCEPT_SET BIT(0) +#define IMAGE_ACCEPT_CLEAR BIT(1) + +static int fwu_get_dev(struct udevice **dev) + +{ + int ret; + + ret = uclass_first_device(UCLASS_FWU_MDATA, dev); + if (ret) { + log_debug("Cannot find fwu device\n"); + return ret; + } + + return 0; +} + +/** + * fwu_verify_mdata() - Verify the FWU metadata + * @mdata: FWU metadata structure + * @pri_part: FWU metadata partition is primary or secondary + * + * Verify the FWU metadata by computing the CRC32 for the metadata + * structure and comparing it against the CRC32 value stored as part + * of the structure. + * + * Return: 0 if OK, -ve on error + * + */ +int fwu_verify_mdata(struct fwu_mdata *mdata, bool pri_part) +{ + u32 calc_crc32; + void *buf; + + buf = &mdata->version; + calc_crc32 = crc32(0, buf, sizeof(*mdata) - sizeof(u32)); + + if (calc_crc32 != mdata->crc32) { + log_debug("crc32 check failed for %s FWU metadata partition\n", + pri_part ? "primary" : "secondary"); + return -EINVAL; + } + + return 0; +} + +/** + * fwu_get_active_index() - Get active_index from the FWU metadata + * @active_idx: active_index value to be read + * + * Read the active_index field from the FWU metadata and place it in + * the variable pointed to be the function argument. + * + * Return: 0 if OK, -ve on error + * + */ +int fwu_get_active_index(u32 *active_idx) +{ + int ret; + struct udevice *dev; + struct fwu_mdata mdata = { 0 }; + + ret = fwu_get_dev(&dev); + if (ret) + return ret; + + ret = fwu_get_mdata(dev, &mdata); + if (ret < 0) { + log_debug("Unable to get valid FWU metadata\n"); + goto out; + } + + /* + * Found the FWU metadata partition, now read the active_index + * value + */ + *active_idx = mdata.active_index; + if (*active_idx >= CONFIG_FWU_NUM_BANKS) { + log_debug("Active index value read is incorrect\n"); + ret = -EINVAL; + } + +out: + return ret; +} + +/** + * fwu_update_active_index() - Update active_index from the FWU metadata + * @active_idx: active_index value to be updated + * + * Update the active_index field in the FWU metadata + * + * Return: 0 if OK, -ve on error + * + */ +int fwu_update_active_index(uint active_idx) +{ + int ret; + struct udevice *dev; + struct fwu_mdata mdata = { 0 }; + + if (active_idx >= CONFIG_FWU_NUM_BANKS) { + log_debug("Invalid active index value\n"); + return -EINVAL; + } + + ret = fwu_get_dev(&dev); + if (ret) + return ret; + + ret = fwu_get_mdata(dev, &mdata); + if (ret < 0) { + log_debug("Unable to get valid FWU metadata\n"); + goto out; + } + + /* + * Update the active index and previous_active_index fields + * in the FWU metadata + */ + mdata.previous_active_index = mdata.active_index; + mdata.active_index = active_idx; + + /* + * Now write this updated FWU metadata to both the + * FWU metadata partitions + */ + ret = fwu_update_mdata(dev, &mdata); + if (ret < 0) { + log_debug("Failed to update FWU metadata partitions\n"); + ret = -EIO; + } + +out: + return ret; +} + +/** + * fwu_get_image_alt_num() - Get the dfu alt number to be used for capsule update + * @image_type_id: pointer to the image GUID as passed in the capsule + * @update_bank: Bank to which the update is to be made + * @alt_num: The alt_num for the image + * + * Based on the GUID value passed in the capsule, along with the bank to which the + * image needs to be updated, get the dfu alt number which will be used for the + * capsule update + * + * Return: 0 if OK, -ve on error + * + */ +int fwu_get_image_alt_num(efi_guid_t *image_type_id, u32 update_bank, + int *alt_num) +{ + int ret, i; + efi_guid_t *image_guid; + struct udevice *dev; + struct fwu_mdata mdata = { 0 }; + struct fwu_image_entry *img_entry; + struct fwu_image_bank_info *img_bank_info; + + ret = fwu_get_dev(&dev); + if (ret) + return ret; + + ret = fwu_get_mdata(dev, &mdata); + if (ret) { + log_debug("Unable to get valid FWU metadata\n"); + goto out; + } + + ret = -EINVAL; + /* + * The FWU metadata has been read. Now get the image_uuid for the + * image with the update_bank. + */ + for (i = 0; i < CONFIG_FWU_NUM_IMAGES_PER_BANK; i++) { + if (!guidcmp(image_type_id, + &mdata.img_entry[i].image_type_uuid)) { + img_entry = &mdata.img_entry[i]; + img_bank_info = &img_entry->img_bank_info[update_bank]; + image_guid = &img_bank_info->image_uuid; + ret = fwu_plat_get_alt_num(dev, image_guid, alt_num); + if (ret) { + log_debug("alt_num not found for partition with GUID %pUs\n", + image_guid); + } else { + log_debug("alt_num %d for partition %pUs\n", + *alt_num, image_guid); + } + + goto out; + } + } + + log_debug("Partition with the image type %pUs not found\n", + image_type_id); + +out: + return ret; +} + +/** + * fwu_revert_boot_index() - Revert the active index in the FWU metadata + * + * Revert the active_index value in the FWU metadata, by swapping the values + * of active_index and previous_active_index in both copies of the + * FWU metadata. + * + * Return: 0 if OK, -ve on error + * + */ +int fwu_revert_boot_index(void) +{ + int ret; + u32 cur_active_index; + struct udevice *dev; + struct fwu_mdata mdata = { 0 }; + + ret = fwu_get_dev(&dev); + if (ret) + return ret; + + ret = fwu_get_mdata(dev, &mdata); + if (ret < 0) { + log_debug("Unable to get valid FWU metadata\n"); + goto out; + } + + /* + * Swap the active index and previous_active_index fields + * in the FWU metadata + */ + cur_active_index = mdata.active_index; + mdata.active_index = mdata.previous_active_index; + mdata.previous_active_index = cur_active_index; + + /* + * Now write this updated FWU metadata to both the + * FWU metadata partitions + */ + ret = fwu_update_mdata(dev, &mdata); + if (ret < 0) { + log_debug("Failed to update FWU metadata partitions\n"); + ret = -EIO; + } + +out: + return ret; +} + +/** + * fwu_clrset_image_accept() - Set or Clear the Acceptance bit for the image + * @img_type_id: GUID of the image type for which the accepted bit is to be + * set or cleared + * @bank: Bank of which the image's Accept bit is to be set or cleared + * @action: Action which specifies whether image's Accept bit is to be set or + * cleared + * + * Set/Clear the accepted bit for the image specified by the img_guid parameter. + * This indicates acceptance or rejection of image for subsequent boots by some + * governing component like OS(or firmware). + * + * Return: 0 if OK, -ve on error + * + */ +static int fwu_clrset_image_accept(efi_guid_t *img_type_id, u32 bank, u8 action) +{ + int ret, i; + struct udevice *dev; + struct fwu_mdata mdata = { 0 }; + struct fwu_image_entry *img_entry; + struct fwu_image_bank_info *img_bank_info; + + ret = fwu_get_dev(&dev); + if (ret) + return ret; + + ret = fwu_get_mdata(dev, &mdata); + if (ret < 0) { + log_debug("Unable to get valid FWU metadata\n"); + goto out; + } + + img_entry = &mdata.img_entry[0]; + for (i = 0; i < CONFIG_FWU_NUM_IMAGES_PER_BANK; i++) { + if (!guidcmp(&img_entry[i].image_type_uuid, img_type_id)) { + img_bank_info = &img_entry[i].img_bank_info[bank]; + if (action == IMAGE_ACCEPT_SET) + img_bank_info->accepted |= FWU_IMAGE_ACCEPTED; + else + img_bank_info->accepted = 0; + + ret = fwu_update_mdata(dev, &mdata); + goto out; + } + } + + /* Image not found */ + ret = -ENOENT; + +out: + return ret; +} + +/** + * fwu_accept_image() - Set the Acceptance bit for the image + * @img_type_id: GUID of the image type for which the accepted bit is to be + * cleared + * @bank: Bank of which the image's Accept bit is to be set + * + * Set the accepted bit for the image specified by the img_guid parameter. This + * indicates acceptance of image for subsequent boots by some governing component + * like OS(or firmware). + * + * Return: 0 if OK, -ve on error + * + */ +int fwu_accept_image(efi_guid_t *img_type_id, u32 bank) +{ + return fwu_clrset_image_accept(img_type_id, bank, + IMAGE_ACCEPT_SET); +} + +/** + * fwu_clear_accept_image() - Clear the Acceptance bit for the image + * @img_type_id: GUID of the image type for which the accepted bit is to be + * cleared + * @bank: Bank of which the image's Accept bit is to be cleared + * + * Clear the accepted bit for the image type specified by the img_type_id parameter. + * This function is called after the image has been updated. The accepted bit is + * cleared to be set subsequently after passing the image acceptance criteria, by + * either the OS(or firmware) + * + * Return: 0 if OK, -ve on error + * + */ +int fwu_clear_accept_image(efi_guid_t *img_type_id, u32 bank) +{ + return fwu_clrset_image_accept(img_type_id, bank, + IMAGE_ACCEPT_CLEAR); +}
Changes since V8:
- Declare the metadata struct on the stack rather than heap
- Move the API's to fwu.c and only keep the DM ops in the uclass driver
- Fix return codes as suggested by Simon
- Change log_err to log_debug as suggested by Simon
- Remove the __packed attribute on the metadata structures as suggested by Simon
- Add comments to the API functions
Reviewed-by: Etienne Carriere etienne.carriere@linaro.org
- Copyright (c) 2022, Linaro Limited
- fwu_mdata_check() - Check if the FWU metadata is valid
- @dev: FWU metadata device
- Validate both copies of the FWU metadata. If one of the copies
- has gone bad, restore it from the other bad copy.
- Return: 0 if OK, -ve on error
return -ENOSYS;
- fwu_get_mdata() - Get a FWU metadata copy
- @mdata: Copy of the FWU metadata
- Get a valid copy of the FWU metadata.
- Note: This function is to be called first when modifying any fields
- in the metadata. The sequence of calls to modify any field in the
- metadata would be 1) fwu_get_mdata 2) Modify metadata, followed by
- fwu_update_mdata
return -ENOSYS;
- fwu_update_mdata() - Update the FWU metadata
- Update the FWU metadata structure by writing to the
- FWU metadata partitions.
- Note: This function is not to be called directly to update the
- metadata fields. The sequence of function calls should be
- fwu_get_mdata() 2) Modify the medata fields 3) fwu_update_mdata()
void *buf;
return -ENOSYS;
* field
- @mdata_check: check the validity of the FWU metadata partitions
- @get_mdata() - Get a FWU metadata copy
- @update_mdata() - Update the FWU metadata copy
* @dev: FWU device
* @dev: FWU device
* @dev: FWU device
- fwu_update_mdata
- fwu_get_active_index() - Get active_index from the FWU metadata
- @active_idxp: active_index value to be read
- Read the active_index field from the FWU metadata and place it in
- the variable pointed to be the function argument.
- fwu_update_active_index() - Update active_index from the FWU metadata
- @active_idx: active_index value to be updated
- Update the active_index field in the FWU metadata
- fwu_get_image_alt_num() - Get the dfu alt number to be used for capsule update
- @image_type_id: pointer to the image GUID as passed in the capsule
- @update_bank: Bank to which the update is to be made
- @alt_num: The alt_num for the image
- Based on the GUID value passed in the capsule, along with the bank to which the
- image needs to be updated, get the dfu alt number which will be used for the
- capsule update
int *alt_num);
- fwu_revert_boot_index() - Revert the active index in the FWU metadata
- Revert the active_index value in the FWU metadata, by swapping the values
- of active_index and previous_active_index in both copies of the
- FWU metadata.
- fwu_verify_mdata() - Verify the FWU metadata
- @mdata: FWU metadata structure
- @pri_part: FWU metadata partition is primary or secondary
- Verify the FWU metadata by computing the CRC32 for the metadata
- structure and comparing it against the CRC32 value stored as part
- of the structure.
- fwu_accept_image() - Set the Acceptance bit for the image
- @img_type_id: GUID of the image type for which the accepted bit is to be
cleared
- @bank: Bank of which the image's Accept bit is to be set
- Set the accepted bit for the image specified by the img_guid parameter. This
- indicates acceptance of image for subsequent boots by some governing component
- like OS(or firmware).
- fwu_clear_accept_image() - Clear the Acceptance bit for the image
cleared
- @bank: Bank of which the image's Accept bit is to be cleared
- Clear the accepted bit for the image type specified by the img_type_id parameter.
- This function is called after the image has been updated. The accepted bit is
- cleared to be set subsequently after passing the image acceptance criteria, by
- either the OS(or firmware)
+#include <efi.h>
- struct fwu_image_bank_info - firmware image information
- @image_uuid: Guid value of the image in this bank
- @accepted: Acceptance status of the image
- @reserved: Reserved
- The structure contains image specific fields which are
- used to identify the image and to specify the image's
- acceptance status
uint32_t accepted;
uint32_t reserved;
- struct fwu_image_entry - information for a particular type of image
- @image_type_uuid: Guid value for identifying the image type
- @location_uuid: Guid of the storage volume where the image is located
- @img_bank_info: Array containing properties of images
- This structure contains information on various types of updatable
- firmware images. Each image type then contains an array of image
- information per bank.
- struct fwu_mdata - FWU metadata structure for multi-bank updates
- @crc32: crc32 value for the FWU metadata
- @version: FWU metadata version
- @active_index: Index of the bank currently used for booting images
- @previous_active_inde: Index of the bank used before the current bank
- @img_entry: Array of information on various firmware images that can
be updated
- This structure is used to store all the needed information for performing
- multi bank updates on the platform. This contains info on the bank being
- used to boot along with the information needed for identification of
- individual images
+struct fwu_mdata {
uint32_t crc32;
uint32_t version;
int ret;
if (ret) {
return ret;
- of the structure.
u32 calc_crc32;
void *buf;
return -EINVAL;
- @active_idx: active_index value to be read
int ret;
if (ret)
return ret;
if (ret < 0) {
goto out;
* value
ret = -EINVAL;
+out:
return ret;
int ret;
return -EINVAL;
if (ret)
return ret;
if (ret < 0) {
goto out;
if (ret < 0) {
ret = -EIO;
+out:
return ret;
- capsule update
int *alt_num)
int ret, i;
if (ret)
return ret;
if (ret) {
goto out;
ret = -EINVAL;
if (ret) {
image_guid);
} else {
goto out;
image_type_id);
+out:
return ret;
- FWU metadata.
int ret;
if (ret)
return ret;
if (ret < 0) {
goto out;
if (ret < 0) {
ret = -EIO;
+out:
return ret;
- fwu_clrset_image_accept() - Set or Clear the Acceptance bit for the image
set or cleared
- @bank: Bank of which the image's Accept bit is to be set or cleared
- @action: Action which specifies whether image's Accept bit is to be set or
cleared
- Set/Clear the accepted bit for the image specified by the img_guid parameter.
- This indicates acceptance or rejection of image for subsequent boots by some
- governing component like OS(or firmware).
int ret, i;
if (ret)
return ret;
if (ret < 0) {
goto out;
else
goto out;
ret = -ENOENT;
+out:
return ret;
cleared
IMAGE_ACCEPT_SET);
cleared
2.34.1
Hi Sughosh,
Changes since V8:
- const struct fwu_mdata_ops *ops = device_get_ops(dev);
- if (!ops->mdata_check) {
return -ENOSYS;
- return ops->mdata_check(dev);
- fwu_update_mdata
- if (!ops->get_mdata) {
return -ENOSYS;
- return ops->get_mdata(dev, mdata);
- void *buf;
- if (!ops->update_mdata) {
return -ENOSYS;
* field
- buf = &mdata->version;
- mdata->crc32 = crc32(0, buf, sizeof(*mdata) - sizeof(u32));
- return ops->update_mdata(dev, mdata);
- .id = UCLASS_FWU_MDATA,
- .name = "fwu-mdata",
- UCLASS_FWU_MDATA, /* FWU Metadata Access */ UCLASS_GPIO, /* Bank of general-purpose I/O pins */ UCLASS_HASH, /* Hash device */ UCLASS_HWSPINLOCK, /* Hardware semaphores */
* @dev: FWU device
- int (*mdata_check)(struct udevice *dev);
* @dev: FWU device
- int (*get_mdata)(struct udevice *dev, struct fwu_mdata *mdata);
* @dev: FWU device
- int (*update_mdata)(struct udevice *dev, struct fwu_mdata *mdata);
- EFI_GUID(0x8a7a84a0, 0x8387, 0x40f6, 0xab, 0x41, \
- fwu_update_mdata
- capsule update
int *alt_num);
- FWU metadata.
- of the structure.
cleared
cleared
+#include <efi.h>
- acceptance status
- efi_guid_t image_uuid;
- uint32_t accepted;
- uint32_t reserved;
- efi_guid_t image_type_uuid;
- efi_guid_t location_uuid;
- struct fwu_image_bank_info img_bank_info[CONFIG_FWU_NUM_BANKS];
be updated
- individual images
+struct fwu_mdata {
- uint32_t crc32;
- uint32_t version;
- uint32_t active_index;
- uint32_t previous_active_index;
- struct fwu_image_entry img_entry[CONFIG_FWU_NUM_IMAGES_PER_BANK];
- int ret;
- ret = uclass_first_device(UCLASS_FWU_MDATA, dev);
- if (ret) {
return ret;
- of the structure.
- u32 calc_crc32;
- void *buf;
- calc_crc32 = crc32(0, buf, sizeof(*mdata) - sizeof(u32));
- if (calc_crc32 != mdata->crc32) {
return -EINVAL;
- int ret;
- struct udevice *dev;
- struct fwu_mdata mdata = { 0 };
- ret = fwu_get_dev(&dev);
- if (ret)
return ret;
- ret = fwu_get_mdata(dev, &mdata);
- if (ret < 0) {
goto out;
This pattern is repeated on the entire patch. Moreover the struct udevice *dev is seems only needed for calling fwu_get_mdata(). So is there any reason why can we can't change fwu_get_mdata() and fold in the fwu_get_dev()?
* value
- *active_idx = mdata.active_index;
- if (*active_idx >= CONFIG_FWU_NUM_BANKS) {
ret = -EINVAL;
+out:
- return ret;
- int ret;
- if (active_idx >= CONFIG_FWU_NUM_BANKS) {
return -EINVAL;
- if (ret)
return ret;
- if (ret < 0) {
goto out;
- mdata.previous_active_index = mdata.active_index;
- mdata.active_index = active_idx;
- ret = fwu_update_mdata(dev, &mdata);
- if (ret < 0) {
ret = -EIO;
+out:
- return ret;
- capsule update
int *alt_num)
- int ret, i;
- efi_guid_t *image_guid;
- struct fwu_image_entry *img_entry;
- struct fwu_image_bank_info *img_bank_info;
- if (ret)
return ret;
- if (ret) {
goto out;
- ret = -EINVAL;
- for (i = 0; i < CONFIG_FWU_NUM_IMAGES_PER_BANK; i++) {
if (ret) {
image_guid);
} else {
Nit you don't need {}
goto out;
- log_debug("Partition with the image type %pUs not found\n",
image_type_id);
+out:
- return ret;
- FWU metadata.
- int ret;
- u32 cur_active_index;
- if (ret)
return ret;
- if (ret < 0) {
goto out;
- cur_active_index = mdata.active_index;
- mdata.active_index = mdata.previous_active_index;
- mdata.previous_active_index = cur_active_index;
- if (ret < 0) {
ret = -EIO;
+out:
- return ret;
set or cleared
cleared
- int ret, i;
- if (ret)
return ret;
- if (ret < 0) {
goto out;
- img_entry = &mdata.img_entry[0];
else
goto out;
- /* Image not found */
- ret = -ENOENT;
+out:
- return ret;
cleared
- return fwu_clrset_image_accept(img_type_id, bank,
IMAGE_ACCEPT_SET);
cleared
2.34.1
Thanks /Ilias
hi Ilias,
On Wed, 7 Sept 2022 at 12:15, Ilias Apalodimas ilias.apalodimas@linaro.org wrote:
Hi Sughosh,
Changes since V8:
<snip>
int ret;
if (ret) {
return ret;
- of the structure.
u32 calc_crc32;
void *buf;
return -EINVAL;
int ret;
if (ret)
return ret;
if (ret < 0) {
goto out;
Sure, I will move the fetching of the device to fwu_get_mdata(). Will also remove the braces as per your other review comment. Thanks.
-sughosh
* value
ret = -EINVAL;
+out:
return ret;
int ret;
return -EINVAL;
if (ret)
return ret;
if (ret < 0) {
goto out;
if (ret < 0) {
ret = -EIO;
+out:
return ret;
- capsule update
int *alt_num)
int ret, i;
if (ret)
return ret;
if (ret) {
goto out;
ret = -EINVAL;
if (ret) {
image_guid);
} else {
goto out;
image_type_id);
+out:
return ret;
- FWU metadata.
int ret;
if (ret)
return ret;
if (ret < 0) {
goto out;
if (ret < 0) {
ret = -EIO;
+out:
return ret;
set or cleared
cleared
int ret, i;
if (ret)
return ret;
if (ret < 0) {
goto out;
else
goto out;
ret = -ENOENT;
+out:
return ret;
cleared
IMAGE_ACCEPT_SET);
cleared
2.34.1
Thanks /Ilias
In the FWU Multi Bank Update feature, the information about the updatable images is stored as part of the metadata, on a separate partition. Add a driver for reading from and writing to the metadata when the updatable images and the metadata are stored on a block device which is formated with GPT based partition scheme.
Signed-off-by: Sughosh Ganu sughosh.ganu@linaro.org Reviewed-by: Patrick Delaunay patrick.delaunay@foss.st.com --- Changes since V8: * Rename fwu_mdata_gpt_blk.c as gpt_blk.c as suggested by Simon * Use natural integer types instead of specific width integers as suggested by Simon * Fix return codes as suggested by Simon * Code cleanup of some superfluous error checks, like for dev_get_uclass_plat() function * Use blk_get_from_parent() for getting the parent of the block device containing the FWU metadata * Add comments to the API functions
drivers/fwu-mdata/Kconfig | 16 ++ drivers/fwu-mdata/Makefile | 8 + drivers/fwu-mdata/gpt_blk.c | 378 ++++++++++++++++++++++++++++++++++++ include/fwu.h | 4 + 4 files changed, 406 insertions(+) create mode 100644 drivers/fwu-mdata/Kconfig create mode 100644 drivers/fwu-mdata/Makefile create mode 100644 drivers/fwu-mdata/gpt_blk.c
diff --git a/drivers/fwu-mdata/Kconfig b/drivers/fwu-mdata/Kconfig new file mode 100644 index 0000000000..7322da48b1 --- /dev/null +++ b/drivers/fwu-mdata/Kconfig @@ -0,0 +1,16 @@ +config FWU_MDATA + bool "Driver support for accessing FWU Metadata" + depends on DM + help + Enable support for accessing FWU Metadata partitions. The + FWU Metadata partitions reside on the same storage device + which contains the other FWU updatable firmware images. + +config FWU_MDATA_GPT_BLK + bool "FWU Metadata access for GPT partitioned Block devices" + select PARTITION_TYPE_GUID + select PARTITION_UUIDS + depends on DM && HAVE_BLOCK_DEVICE && EFI_PARTITION + help + Enable support for accessing FWU Metadata on GPT partitioned + block devices. diff --git a/drivers/fwu-mdata/Makefile b/drivers/fwu-mdata/Makefile new file mode 100644 index 0000000000..3fee64c10c --- /dev/null +++ b/drivers/fwu-mdata/Makefile @@ -0,0 +1,8 @@ +# SPDX-License-Identifier: GPL-2.0-or-later +# +# Copyright (c) 2022, Linaro Limited +# + + +obj-$(CONFIG_FWU_MDATA) += fwu-mdata-uclass.o +obj-$(CONFIG_FWU_MDATA_GPT_BLK) += gpt_blk.o diff --git a/drivers/fwu-mdata/gpt_blk.c b/drivers/fwu-mdata/gpt_blk.c new file mode 100644 index 0000000000..4f0558825b --- /dev/null +++ b/drivers/fwu-mdata/gpt_blk.c @@ -0,0 +1,378 @@ +// SPDX-License-Identifier: GPL-2.0-or-later +/* + * Copyright (c) 2022, Linaro Limited + */ + +#define LOG_CATEGORY UCLASS_FWU_MDATA + +#include <blk.h> +#include <dm.h> +#include <efi_loader.h> +#include <fwu.h> +#include <fwu_mdata.h> +#include <log.h> +#include <memalign.h> +#include <part.h> +#include <part_efi.h> + +#include <dm/device-internal.h> +#include <linux/errno.h> +#include <linux/types.h> + +#define PRIMARY_PART BIT(0) +#define SECONDARY_PART BIT(1) +#define BOTH_PARTS (PRIMARY_PART | SECONDARY_PART) + +#define MDATA_READ BIT(0) +#define MDATA_WRITE BIT(1) + +static int gpt_get_mdata_partitions(struct blk_desc *desc, + uint *primary_mpart, + uint *secondary_mpart) +{ + int i, ret; + u32 mdata_parts; + efi_guid_t part_type_guid; + struct disk_partition info; + const efi_guid_t fwu_mdata_guid = FWU_MDATA_GUID; + + mdata_parts = 0; + for (i = 1; i < MAX_SEARCH_PARTITIONS; i++) { + if (part_get_info(desc, i, &info)) + continue; + uuid_str_to_bin(info.type_guid, part_type_guid.b, + UUID_STR_FORMAT_GUID); + + if (!guidcmp(&fwu_mdata_guid, &part_type_guid)) { + ++mdata_parts; + if (!*primary_mpart) + *primary_mpart = i; + else + *secondary_mpart = i; + } + } + + if (mdata_parts != 2) { + log_debug("Expect two copies of the FWU metadata instead of %d\n", + mdata_parts); + ret = -EINVAL; + } else { + ret = 0; + } + + return ret; +} + +static int gpt_get_mdata_disk_part(struct blk_desc *desc, + struct disk_partition *info, + u32 part_num) +{ + int ret; + char *mdata_guid_str = "8a7a84a0-8387-40f6-ab41-a8b9a5a60d23"; + + ret = part_get_info(desc, part_num, info); + if (ret < 0) { + log_debug("Unable to get the partition info for the FWU metadata part %d", + part_num); + return -ENOENT; + } + + /* Check that it is indeed the FWU metadata partition */ + if (!strncmp(info->type_guid, mdata_guid_str, UUID_STR_LEN)) { + /* Found the FWU metadata partition */ + return 0; + } + + return -ENOENT; +} + +static int gpt_read_write_mdata(struct blk_desc *desc, + struct fwu_mdata *mdata, + u8 access, u32 part_num) +{ + int ret; + u32 len, blk_start, blkcnt; + struct disk_partition info; + + ALLOC_CACHE_ALIGN_BUFFER_PAD(struct fwu_mdata, mdata_aligned, 1, + desc->blksz); + + ret = gpt_get_mdata_disk_part(desc, &info, part_num); + if (ret < 0) { + printf("Unable to get the FWU metadata partition\n"); + return -ENOENT; + } + + len = sizeof(*mdata); + blkcnt = BLOCK_CNT(len, desc); + if (blkcnt > info.size) { + log_debug("Block count exceeds FWU metadata partition size\n"); + return -ERANGE; + } + + blk_start = info.start; + if (access == MDATA_READ) { + if (blk_dread(desc, blk_start, blkcnt, mdata_aligned) != blkcnt) { + log_debug("Error reading FWU metadata from the device\n"); + return -EIO; + } + memcpy(mdata, mdata_aligned, sizeof(struct fwu_mdata)); + } else { + if (blk_dwrite(desc, blk_start, blkcnt, mdata) != blkcnt) { + log_debug("Error writing FWU metadata to the device\n"); + return -EIO; + } + } + + return 0; +} + +static int gpt_read_mdata(struct blk_desc *desc, + struct fwu_mdata *mdata, u32 part_num) +{ + return gpt_read_write_mdata(desc, mdata, MDATA_READ, part_num); +} + +static int gpt_write_mdata_partition(struct blk_desc *desc, + struct fwu_mdata *mdata, + u32 part_num) +{ + return gpt_read_write_mdata(desc, mdata, MDATA_WRITE, part_num); +} + +static int fwu_gpt_update_mdata(struct udevice *dev, struct fwu_mdata *mdata) +{ + int ret; + struct blk_desc *desc; + uint primary_mpart = 0, secondary_mpart = 0; + struct fwu_mdata_gpt_blk_priv *priv = dev_get_priv(dev); + + desc = dev_get_uclass_plat(priv->blk_dev); + + ret = gpt_get_mdata_partitions(desc, &primary_mpart, + &secondary_mpart); + if (ret < 0) { + log_debug("Error getting the FWU metadata partitions\n"); + return -ENOENT; + } + + /* First write the primary partition */ + ret = gpt_write_mdata_partition(desc, mdata, primary_mpart); + if (ret < 0) { + log_debug("Updating primary FWU metadata partition failed\n"); + return ret; + } + + /* And now the replica */ + ret = gpt_write_mdata_partition(desc, mdata, secondary_mpart); + if (ret < 0) { + log_debug("Updating secondary FWU metadata partition failed\n"); + return ret; + } + + return 0; +} + +static int gpt_get_mdata(struct blk_desc *desc, struct fwu_mdata *mdata) +{ + int ret; + uint primary_mpart = 0, secondary_mpart = 0; + + ret = gpt_get_mdata_partitions(desc, &primary_mpart, + &secondary_mpart); + + if (ret < 0) { + log_debug("Error getting the FWU metadata partitions\n"); + return -ENOENT; + } + + ret = gpt_read_mdata(desc, mdata, primary_mpart); + if (ret < 0) { + log_debug("Failed to read the FWU metadata from the device\n"); + return -EIO; + } + + ret = fwu_verify_mdata(mdata, 1); + if (!ret) + return 0; + + /* + * Verification of the primary FWU metadata copy failed. + * Try to read the replica. + */ + memset(mdata, '\0', sizeof(struct fwu_mdata)); + ret = gpt_read_mdata(desc, mdata, secondary_mpart); + if (ret < 0) { + log_debug("Failed to read the FWU metadata from the device\n"); + return -EIO; + } + + ret = fwu_verify_mdata(mdata, 0); + if (!ret) + return 0; + + /* Both the FWU metadata copies are corrupted. */ + return -EIO; +} + +static int gpt_check_mdata_validity(struct udevice *dev) +{ + int ret; + struct blk_desc *desc; + struct fwu_mdata pri_mdata; + struct fwu_mdata secondary_mdata; + uint primary_mpart = 0, secondary_mpart = 0; + uint valid_partitions, invalid_partitions; + struct fwu_mdata_gpt_blk_priv *priv = dev_get_priv(dev); + + desc = dev_get_uclass_plat(priv->blk_dev); + + /* + * Two FWU metadata partitions are expected. + * If we don't have two, user needs to create + * them first + */ + valid_partitions = 0; + ret = gpt_get_mdata_partitions(desc, &primary_mpart, + &secondary_mpart); + + if (ret < 0) { + log_debug("Error getting the FWU metadata partitions\n"); + return -ENOENT; + } + + ret = gpt_read_mdata(desc, &pri_mdata, primary_mpart); + if (ret < 0) { + log_debug("Failed to read the FWU metadata from the device\n"); + goto secondary_read; + } + + ret = fwu_verify_mdata(&pri_mdata, 1); + if (!ret) + valid_partitions |= PRIMARY_PART; + +secondary_read: + /* Now check the secondary partition */ + ret = gpt_read_mdata(desc, &secondary_mdata, secondary_mpart); + if (ret < 0) { + log_debug("Failed to read the FWU metadata from the device\n"); + goto mdata_restore; + } + + ret = fwu_verify_mdata(&secondary_mdata, 0); + if (!ret) + valid_partitions |= SECONDARY_PART; + +mdata_restore: + if (valid_partitions == (PRIMARY_PART | SECONDARY_PART)) { + ret = -1; + /* + * Before returning, check that both the + * FWU metadata copies are the same. If not, + * the FWU metadata copies need to be + * re-populated. + */ + if (!memcmp(&pri_mdata, &secondary_mdata, + sizeof(struct fwu_mdata))) { + ret = 0; + } else { + log_debug("Both FWU metadata copies are valid but do not match. Please check!\n"); + } + goto out; + } + + ret = -1; + if (!(valid_partitions & BOTH_PARTS)) + goto out; + + invalid_partitions = valid_partitions ^ BOTH_PARTS; + ret = gpt_write_mdata_partition(desc, + (invalid_partitions == PRIMARY_PART) ? + &secondary_mdata : &pri_mdata, + (invalid_partitions == PRIMARY_PART) ? + primary_mpart : secondary_mpart); + + if (ret < 0) + log_debug("Restoring %s FWU metadata partition failed\n", + (invalid_partitions == PRIMARY_PART) ? + "primary" : "secondary"); + +out: + return ret; +} + +static int fwu_gpt_mdata_check(struct udevice *dev) +{ + /* + * Check if both the copies of the FWU + * metadata are valid. If one has gone + * bad, restore it from the other good + * copy. + */ + return gpt_check_mdata_validity(dev); +} + +static int fwu_gpt_get_mdata(struct udevice *dev, struct fwu_mdata *mdata) +{ + struct fwu_mdata_gpt_blk_priv *priv = dev_get_priv(dev); + + return gpt_get_mdata(dev_get_uclass_plat(priv->blk_dev), mdata); +} + +static int fwu_get_mdata_device(struct udevice *dev, struct udevice **mdata_dev) +{ + u32 phandle; + int ret, size; + struct udevice *parent; + const fdt32_t *phandle_p = NULL; + + phandle_p = dev_read_prop(dev, "fwu-mdata-store", &size); + if (!phandle_p) { + log_debug("fwu-mdata-store property not found\n"); + return -ENOENT; + } + + phandle = fdt32_to_cpu(*phandle_p); + + ret = device_get_global_by_ofnode(ofnode_get_by_phandle(phandle), + &parent); + if (ret) + return ret; + + return blk_get_from_parent(parent, mdata_dev); +} + +static int fwu_mdata_gpt_blk_probe(struct udevice *dev) +{ + int ret; + struct udevice *mdata_dev = NULL; + struct fwu_mdata_gpt_blk_priv *priv = dev_get_priv(dev); + + ret = fwu_get_mdata_device(dev, &mdata_dev); + if (ret) + return ret; + + priv->blk_dev = mdata_dev; + + return 0; +} + +static const struct fwu_mdata_ops fwu_gpt_blk_ops = { + .mdata_check = fwu_gpt_mdata_check, + .get_mdata = fwu_gpt_get_mdata, + .update_mdata = fwu_gpt_update_mdata, +}; + +static const struct udevice_id fwu_mdata_ids[] = { + { .compatible = "u-boot,fwu-mdata-gpt" }, + { } +}; + +U_BOOT_DRIVER(fwu_mdata_gpt_blk) = { + .name = "fwu-mdata-gpt-blk", + .id = UCLASS_FWU_MDATA, + .of_match = fwu_mdata_ids, + .ops = &fwu_gpt_blk_ops, + .probe = fwu_mdata_gpt_blk_probe, + .priv_auto = sizeof(struct fwu_mdata_gpt_blk_priv), +}; diff --git a/include/fwu.h b/include/fwu.h index 2335981d28..ecabf11210 100644 --- a/include/fwu.h +++ b/include/fwu.h @@ -14,6 +14,10 @@ struct fwu_mdata; struct udevice;
+struct fwu_mdata_gpt_blk_priv { + struct udevice *blk_dev; +}; + /** * @mdata_check: check the validity of the FWU metadata partitions * @get_mdata() - Get a FWU metadata copy
Hi Sughosh,
Reviewed-by: Etienne Carriere etienne.carriere@linaro.org with comment addressed.
formatted
Changes since V8:
- Rename fwu_mdata_gpt_blk.c as gpt_blk.c as suggested by Simon
- Use natural integer types instead of specific width integers as suggested by Simon
- Code cleanup of some superfluous error checks, like for dev_get_uclass_plat() function
- Use blk_get_from_parent() for getting the parent of the block device containing the FWU metadata
depends on DM
help
help
block devices.
int i, ret;
u32 mdata_parts;
mdata_parts = 0;
continue;
++mdata_parts;
*primary_mpart = i;
else
mdata_parts);
ret = -EINVAL;
} else {
ret = 0;
return ret;
u32 part_num)
int ret;
if (ret < 0) {
missing terminal '\n'
part_num);
return -ENOENT;
return -ENOENT;
int ret;
desc->blksz);
if (ret < 0) {
return -ENOENT;
return -ERANGE;
return -EIO;
} else {
return -EIO;
u32 part_num)
int ret;
&secondary_mpart);
if (ret < 0) {
return -ENOENT;
if (ret < 0) {
return ret;
if (ret < 0) {
return ret;
int ret;
&secondary_mpart);
if (ret < 0) {
return -ENOENT;
if (ret < 0) {
return -EIO;
if (!ret)
if (ret < 0) {
return -EIO;
if (!ret)
return -EIO;
int ret;
* them first
&secondary_mpart);
if (ret < 0) {
return -ENOENT;
if (ret < 0) {
if (!ret)
+secondary_read:
if (ret < 0) {
goto mdata_restore;
if (!ret)
+mdata_restore:
ret = -1;
* re-populated.
ret = 0;
} else {
goto out;
ret = -1;
goto out;
if (ret < 0)
+out:
return ret;
* copy.
u32 phandle;
int ret, size;
if (!phandle_p) {
return -ENOENT;
&parent);
if (ret)
return ret;
int ret;
if (ret)
return ret;
-- 2.34.1
hi Etienne,
On Tue, 6 Sept 2022 at 12:31, Etienne Carriere etienne.carriere@linaro.org wrote:
Hi Sughosh,
Will address both your review comments. Thanks.
-sughosh
formatted
Changes since V8:
depends on DM
help
help
block devices.
int i, ret;
u32 mdata_parts;
mdata_parts = 0;
continue;
++mdata_parts;
*primary_mpart = i;
else
mdata_parts);
ret = -EINVAL;
} else {
ret = 0;
return ret;
u32 part_num)
int ret;
if (ret < 0) {
part_num);
return -ENOENT;
return -ENOENT;
int ret;
desc->blksz);
if (ret < 0) {
return -ENOENT;
return -ERANGE;
return -EIO;
} else {
return -EIO;
u32 part_num)
int ret;
&secondary_mpart);
if (ret < 0) {
return -ENOENT;
if (ret < 0) {
return ret;
if (ret < 0) {
return ret;
int ret;
&secondary_mpart);
if (ret < 0) {
return -ENOENT;
if (ret < 0) {
return -EIO;
if (!ret)
if (ret < 0) {
return -EIO;
if (!ret)
return -EIO;
int ret;
* them first
&secondary_mpart);
if (ret < 0) {
return -ENOENT;
if (ret < 0) {
if (!ret)
+secondary_read:
if (ret < 0) {
goto mdata_restore;
if (!ret)
+mdata_restore:
ret = -1;
* re-populated.
ret = 0;
} else {
goto out;
ret = -1;
goto out;
if (ret < 0)
+out:
return ret;
* copy.
u32 phandle;
int ret, size;
if (!phandle_p) {
return -ENOENT;
&parent);
if (ret)
return ret;
int ret;
if (ret)
return ret;
-- 2.34.1
The FWU metadata structure is accessed through the driver model interface. On the stm32mp157c-dk2 board, the FWU metadata is stored on the uSD card. Add the fwu-mdata node on the u-boot specifc dtsi file for accessing the metadata structure.
Signed-off-by: Sughosh Ganu sughosh.ganu@linaro.org Reviewed-by: Patrick Delaunay patrick.delaunay@foss.st.com Acked-by: Ilias Apalodimas ilias.apalodimas@linaro.org --- Changes since V8: None
arch/arm/dts/stm32mp157c-dk2-u-boot.dtsi | 7 +++++++ 1 file changed, 7 insertions(+)
diff --git a/arch/arm/dts/stm32mp157c-dk2-u-boot.dtsi b/arch/arm/dts/stm32mp157c-dk2-u-boot.dtsi index 06ef3a4095..24f86209db 100644 --- a/arch/arm/dts/stm32mp157c-dk2-u-boot.dtsi +++ b/arch/arm/dts/stm32mp157c-dk2-u-boot.dtsi @@ -4,3 +4,10 @@ */
#include "stm32mp157a-dk1-u-boot.dtsi" + +/ { + fwu-mdata { + compatible = "u-boot,fwu-mdata-gpt"; + fwu-mdata-store = <&sdmmc1>; + }; +};
fwu-mdata {
2.34.1
Enabling capsule update functionality on the platform requires populating information on the images that are to be updated using the functionality. Do so for the DK2 board.
Signed-off-by: Sughosh Ganu sughosh.ganu@linaro.org --- Changes since V8: * Use STM32MP_FIP_IMAGE_GUID for the FIP GUID value as suggested by Yann
board/st/stm32mp1/stm32mp1.c | 23 +++++++++++++++++++++++ include/configs/stm32mp15_common.h | 4 ++++ 2 files changed, 27 insertions(+)
diff --git a/board/st/stm32mp1/stm32mp1.c b/board/st/stm32mp1/stm32mp1.c index 9496890d16..bfec0a710d 100644 --- a/board/st/stm32mp1/stm32mp1.c +++ b/board/st/stm32mp1/stm32mp1.c @@ -11,6 +11,7 @@ #include <clk.h> #include <config.h> #include <dm.h> +#include <efi_loader.h> #include <env.h> #include <env_internal.h> #include <fdt_simplefb.h> @@ -87,6 +88,16 @@ #define USB_START_LOW_THRESHOLD_UV 1230000 #define USB_START_HIGH_THRESHOLD_UV 2150000
+#if CONFIG_IS_ENABLED(EFI_HAVE_CAPSULE_SUPPORT) +struct efi_fw_image fw_images[1]; + +struct efi_capsule_update_info update_info = { + .images = fw_images, +}; + +u8 num_image_type_guids = ARRAY_SIZE(fw_images); +#endif /* EFI_HAVE_CAPSULE_SUPPORT */ + int board_early_init_f(void) { /* nothing to do, only used in SPL */ @@ -670,6 +681,18 @@ int board_init(void)
setup_led(LEDST_ON);
+#if CONFIG_IS_ENABLED(EFI_HAVE_CAPSULE_SUPPORT) + if (board_is_stm32mp15x_dk2()) { + efi_guid_t image_type_guid = STM32MP_FIP_IMAGE_GUID; + guidcpy(&fw_images[0].image_type_id, &image_type_guid); + fw_images[0].fw_name = u"STM32MP-FIP"; + /* + * For FWU multi bank update, the image + * index will be computed at runtime + */ + fw_images[0].image_index = 0; + } +#endif return 0; }
diff --git a/include/configs/stm32mp15_common.h b/include/configs/stm32mp15_common.h index c5412ffeb3..bb19dae945 100644 --- a/include/configs/stm32mp15_common.h +++ b/include/configs/stm32mp15_common.h @@ -34,6 +34,10 @@ #define CONFIG_SERVERIP 192.168.1.1 #endif
+#define STM32MP_FIP_IMAGE_GUID \ + EFI_GUID(0x19d5df83, 0x11b0, 0x457b, 0xbe, 0x2c, \ + 0x75, 0x59, 0xc1, 0x31, 0x42, 0xa5) + /*****************************************************************************/ #ifdef CONFIG_DISTRO_DEFAULTS /*****************************************************************************/
Changes since V8:
- Use STM32MP_FIP_IMAGE_GUID for the FIP GUID value as suggested by Yann
- .images = fw_images,
- if (board_is_stm32mp15x_dk2()) {
+#endif return 0; }
- EFI_GUID(0x19d5df83, 0x11b0, 0x457b, 0xbe, 0x2c, \
/*****************************************************************************/ #ifdef CONFIG_DISTRO_DEFAULTS /*****************************************************************************/ -- 2.34.1
Hello Sughosh,
Changes since V8:
Sorry for this late comment. Should this be restricted to mp15-dk2? I would remove the test and apply when CONFIG_EFI_HAVE_CAPSULE_SUPPORT is enable.
+#endif return 0; }
hi Etienne,
On Tue, 6 Sept 2022 at 00:49, Etienne Carriere etienne.carriere@linaro.org wrote:
Hello Sughosh,
Changes since V8:
You are right. With the changes made in the V9 version of this patch, I believe this check is redundant. I will remove this in the next version. Thanks.
-sughosh
+#endif return 0; }
Add weak functions for getting the update index value and dfu alternate number needed for FWU Multi Bank update functionality.
The current implementation for getting the update index value is for platforms with 2 banks. If a platform supports more than 2 banks, it can implement it's own function. The function to get the dfu alternate number has been added for platforms with GPT partitioned storage devices. Platforms with other storage partition scheme need to implement their own function.
Signed-off-by: Sughosh Ganu sughosh.ganu@linaro.org Reviewed-by: Patrick Delaunay patrick.delaunay@foss.st.com --- Changes since V8: * Add comments for API functions * Update the logic to get the update index as suggested by Jassi
include/fwu.h | 29 ++++++++++ lib/fwu_updates/fwu.c | 27 +++++++++ lib/fwu_updates/fwu_gpt.c | 115 ++++++++++++++++++++++++++++++++++++++ 3 files changed, 171 insertions(+) create mode 100644 lib/fwu_updates/fwu_gpt.c
diff --git a/include/fwu.h b/include/fwu.h index ecabf11210..7ebd3a7115 100644 --- a/include/fwu.h +++ b/include/fwu.h @@ -211,4 +211,33 @@ int fwu_accept_image(efi_guid_t *img_type_id, u32 bank); */ int fwu_clear_accept_image(efi_guid_t *img_type_id, u32 bank);
+/** + * fwu_plat_get_alt_num() - Get the DFU Alt Num for the image from the platform + * @dev: FWU device + * @image_guid: Image GUID for which DFU alt number needs to be retrieved + * @alt_num: Pointer to the alt_num + * + * Get the DFU alt number from the platform for the image specified by the + * image GUID. + * + * Return: 0 if OK, -ve on error + * + */ +int fwu_plat_get_alt_num(struct udevice *dev, efi_guid_t *image_guid, + int *alt_num); + +/** + * fwu_plat_get_update_index() - Get the value of the update bank + * @update_idx: Bank number to which images are to be updated + * + * Get the value of the bank(partition) to which the update needs to be + * made. + * + * Note: This is a weak function and platforms can override this with + * their own implementation for selection of the update bank. + * + * Return: 0 if OK, -ve on error + * + */ +int fwu_plat_get_update_index(uint *update_idx); #endif /* _FWU_H_ */ diff --git a/lib/fwu_updates/fwu.c b/lib/fwu_updates/fwu.c index a871d77b4c..94b15859a5 100644 --- a/lib/fwu_updates/fwu.c +++ b/lib/fwu_updates/fwu.c @@ -355,3 +355,30 @@ int fwu_clear_accept_image(efi_guid_t *img_type_id, u32 bank) return fwu_clrset_image_accept(img_type_id, bank, IMAGE_ACCEPT_CLEAR); } + +/** + * fwu_plat_get_update_index() - Get the value of the update bank + * @update_idx: Bank number to which images are to be updated + * + * Get the value of the bank(partition) to which the update needs to be + * made. + * + * Note: This is a weak function and platforms can override this with + * their own implementation for selection of the update bank. + * + * Return: 0 if OK, -ve on error + * + */ +__weak int fwu_plat_get_update_index(uint *update_idx) +{ + int ret; + u32 active_idx; + + ret = fwu_get_active_index(&active_idx); + if (ret < 0) + return -1; + + *update_idx = (active_idx + 1) % CONFIG_FWU_NUM_BANKS; + + return ret; +} diff --git a/lib/fwu_updates/fwu_gpt.c b/lib/fwu_updates/fwu_gpt.c new file mode 100644 index 0000000000..a3134b80c9 --- /dev/null +++ b/lib/fwu_updates/fwu_gpt.c @@ -0,0 +1,115 @@ +// SPDX-License-Identifier: GPL-2.0-or-later +/* + * Copyright (c) 2022, Linaro Limited + */ + +#include <blk.h> +#include <dfu.h> +#include <efi.h> +#include <efi_loader.h> +#include <fwu.h> +#include <log.h> +#include <part.h> + +#include <linux/errno.h> + +static int get_gpt_dfu_identifier(struct blk_desc *desc, efi_guid_t *image_guid) +{ + int i; + struct disk_partition info; + efi_guid_t unique_part_guid; + + for (i = 1; i < MAX_SEARCH_PARTITIONS; i++) { + if (part_get_info(desc, i, &info)) + continue; + uuid_str_to_bin(info.uuid, unique_part_guid.b, + UUID_STR_FORMAT_GUID); + + if (!guidcmp(&unique_part_guid, image_guid)) + return i; + } + + log_err("No partition found with image_guid %pUs\n", image_guid); + return -ENOENT; +} + +static int fwu_gpt_get_alt_num(struct blk_desc *desc, efi_guid_t *image_guid, + int *alt_num, unsigned char dfu_dev) +{ + int ret = -1; + int i, part, dev_num; + int nalt; + struct dfu_entity *dfu; + + dev_num = desc->devnum; + part = get_gpt_dfu_identifier(desc, image_guid); + if (part < 0) + return -ENOENT; + + dfu_init_env_entities(NULL, NULL); + + nalt = 0; + list_for_each_entry(dfu, &dfu_list, list) { + nalt++; + } + + if (!nalt) { + log_warning("No entities in dfu_alt_info\n"); + dfu_free_entities(); + return -ENOENT; + } + + for (i = 0; i < nalt; i++) { + dfu = dfu_get_entity(i); + + if (!dfu) + continue; + + /* + * Currently, Multi Bank update + * feature is being supported + * only on GPT partitioned + * MMC/SD devices. + */ + if (dfu->dev_type != dfu_dev) + continue; + + if (dfu->layout == DFU_RAW_ADDR && + dfu->data.mmc.dev_num == dev_num && + dfu->data.mmc.part == part) { + *alt_num = dfu->alt; + ret = 0; + break; + } + } + + dfu_free_entities(); + + return ret; +} + +/** + * fwu_plat_get_alt_num() - Get the DFU alt number + * @dev: FWU metadata device + * @image_guid: GUID value of the image for which the alt num is to + * be obtained + * @alt_num: The DFU alt number for the image that is to be updated + * + * Get the DFU alt number for the image that is to be updated. The + * image is identified with the image_guid parameter that is passed + * to the function. + * + * Note: This is a weak function and platforms can override this with + * their own implementation for obtaining the alt number value. + * + * Return: 0 if OK, -ve on error + * + */ +__weak int fwu_plat_get_alt_num(struct udevice *dev, efi_guid_t *image_guid, + int *alt_num) +{ + struct fwu_mdata_gpt_blk_priv *priv = dev_get_priv(dev); + + return fwu_gpt_get_alt_num(dev_get_uclass_plat(priv->blk_dev), + image_guid, alt_num, DFU_DEV_MMC); +}
Changes since V8:
- Add comments for API functions
- Update the logic to get the update index as suggested by Jassi
- fwu_plat_get_alt_num() - Get the DFU Alt Num for the image from the platform
- @dev: FWU device
- @image_guid: Image GUID for which DFU alt number needs to be retrieved
- @alt_num: Pointer to the alt_num
- Get the DFU alt number from the platform for the image specified by the
- image GUID.
int *alt_num);
- fwu_plat_get_update_index() - Get the value of the update bank
- @update_idx: Bank number to which images are to be updated
- Get the value of the bank(partition) to which the update needs to be
- made.
- Note: This is a weak function and platforms can override this with
- their own implementation for selection of the update bank.
- made.
int ret;
u32 active_idx;
if (ret < 0)
return -1;
return ret;
int i;
continue;
return i;
return -ENOENT;
int ret = -1;
int nalt;
if (part < 0)
return -ENOENT;
nalt = 0;
nalt++;
if (!nalt) {
return -ENOENT;
if (!dfu)
continue;
* MMC/SD devices.
continue;
ret = 0;
break;
return ret;
- fwu_plat_get_alt_num() - Get the DFU alt number
- @image_guid: GUID value of the image for which the alt num is to
be obtained
- @alt_num: The DFU alt number for the image that is to be updated
- Get the DFU alt number for the image that is to be updated. The
- image is identified with the image_guid parameter that is passed
- to the function.
- their own implementation for obtaining the alt number value.
int *alt_num)
2.34.1
Changes since V8:
- @dev: FWU device
- image GUID.
int *alt_num);
- made.
- made.
- int ret;
- u32 active_idx;
- ret = fwu_get_active_index(&active_idx);
- if (ret < 0)
return -1;
- *update_idx = (active_idx + 1) % CONFIG_FWU_NUM_BANKS;
- return ret;
- int i;
- struct disk_partition info;
- efi_guid_t unique_part_guid;
- for (i = 1; i < MAX_SEARCH_PARTITIONS; i++) {
continue;
return i;
- log_err("No partition found with image_guid %pUs\n", image_guid);
- return -ENOENT;
- int ret = -1;
- int i, part, dev_num;
- int nalt;
- struct dfu_entity *dfu;
- dev_num = desc->devnum;
- part = get_gpt_dfu_identifier(desc, image_guid);
- if (part < 0)
return -ENOENT;
- dfu_init_env_entities(NULL, NULL);
- nalt = 0;
- list_for_each_entry(dfu, &dfu_list, list) {
nalt++;
Nit, you don't need {}
- if (!nalt) {
return -ENOENT;
- for (i = 0; i < nalt; i++) {
if (!dfu)
continue;
* MMC/SD devices.
continue;
ret = 0;
Can we make this function return the partition number and < 0 on failure? If it's too big of a change, I don't mind keeping it as is
Regards /Ilias
break;
- dfu_free_entities();
- return ret;
be obtained
- to the function.
int *alt_num)
- struct fwu_mdata_gpt_blk_priv *priv = dev_get_priv(dev);
- return fwu_gpt_get_alt_num(dev_get_uclass_plat(priv->blk_dev),
2.34.1
hi Ilias,
On Wed, 7 Sept 2022 at 11:29, Ilias Apalodimas ilias.apalodimas@linaro.org wrote:
Changes since V8:
- @dev: FWU device
- image GUID.
int *alt_num);
- made.
- made.
int ret;
u32 active_idx;
if (ret < 0)
return -1;
return ret;
int i;
continue;
return i;
return -ENOENT;
int ret = -1;
int nalt;
if (part < 0)
return -ENOENT;
nalt = 0;
nalt++;
Will remove
if (!nalt) {
return -ENOENT;
if (!dfu)
continue;
* MMC/SD devices.
continue;
ret = 0;
If you don't have a strong opinion on this, I would prefer to keep it as is, since this is consistent with the behaviour of the other functions where the value is being obtained through a pointer and the function is returning the status.
-sughosh
Regards /Ilias
break;
return ret;
be obtained
- to the function.
int *alt_num)
2.34.1
The FWU Multi Bank Update feature allows the platform to boot the firmware images from one of the partitions(banks). The first stage bootloader(fsbl) passes the value of the boot index, i.e. the bank from which the firmware images were booted from to U-Boot. On the STM32MP157C-DK2 board, this value is passed through one of the SoC's backup register. Add a function to read the boot index value from the backup register.
arch/arm/mach-stm32mp/include/mach/stm32.h | 5 +++++ board/st/stm32mp1/stm32mp1.c | 23 ++++++++++++++++++++++ include/fwu.h | 12 +++++++++++ 3 files changed, 40 insertions(+)
diff --git a/arch/arm/mach-stm32mp/include/mach/stm32.h b/arch/arm/mach-stm32mp/include/mach/stm32.h index c70375a723..c85ae6a34e 100644 --- a/arch/arm/mach-stm32mp/include/mach/stm32.h +++ b/arch/arm/mach-stm32mp/include/mach/stm32.h @@ -112,11 +112,16 @@ enum boot_device { #ifdef CONFIG_STM32MP15x #define TAMP_BACKUP_MAGIC_NUMBER TAMP_BACKUP_REGISTER(4) #define TAMP_BACKUP_BRANCH_ADDRESS TAMP_BACKUP_REGISTER(5) +#define TAMP_FWU_BOOT_INFO_REG TAMP_BACKUP_REGISTER(10) #define TAMP_COPRO_RSC_TBL_ADDRESS TAMP_BACKUP_REGISTER(17) #define TAMP_COPRO_STATE TAMP_BACKUP_REGISTER(18) #define TAMP_BOOT_CONTEXT TAMP_BACKUP_REGISTER(20) #define TAMP_BOOTCOUNT TAMP_BACKUP_REGISTER(21)
+#define TAMP_FWU_BOOT_IDX_MASK GENMASK(3, 0) + +#define TAMP_FWU_BOOT_IDX_OFFSET 0 + #define TAMP_COPRO_STATE_OFF 0 #define TAMP_COPRO_STATE_INIT 1 #define TAMP_COPRO_STATE_CRUN 2 diff --git a/board/st/stm32mp1/stm32mp1.c b/board/st/stm32mp1/stm32mp1.c index bfec0a710d..dd95babb49 100644 --- a/board/st/stm32mp1/stm32mp1.c +++ b/board/st/stm32mp1/stm32mp1.c @@ -966,3 +966,26 @@ static void board_copro_image_process(ulong fw_image, size_t fw_size) }
U_BOOT_FIT_LOADABLE_HANDLER(IH_TYPE_COPRO, board_copro_image_process); + +#if defined(CONFIG_FWU_MULTI_BANK_UPDATE) + +#include <fwu.h> + +/** + * fwu_plat_get_bootidx() - Get the value of the boot index + * @boot_idx: Boot index value + * + * Get the value of the bank(partition) from which the platform + * has booted. This value is passed to U-Boot from the earlier + * stage bootloader which loads and boots all the relevant + * firmware images + * + */ +void fwu_plat_get_bootidx(void *boot_idx) +{ + u32 *bootidx = boot_idx; + + *bootidx = (readl(TAMP_FWU_BOOT_INFO_REG) >> + TAMP_FWU_BOOT_IDX_OFFSET) & TAMP_FWU_BOOT_IDX_MASK; +} +#endif /* CONFIG_FWU_MULTI_BANK_UPDATE */ diff --git a/include/fwu.h b/include/fwu.h index 7ebd3a7115..b8c207deaf 100644 --- a/include/fwu.h +++ b/include/fwu.h @@ -240,4 +240,16 @@ int fwu_plat_get_alt_num(struct udevice *dev, efi_guid_t *image_guid, * */ int fwu_plat_get_update_index(uint *update_idx); + +/** + * fwu_plat_get_bootidx() - Get the value of the boot index + * @boot_idx: Boot index value + * + * Get the value of the bank(partition) from which the platform + * has booted. This value is passed to U-Boot from the earlier + * stage bootloader which loads and boots all the relevant + * firmware images + * + */ +void fwu_plat_get_bootidx(void *boot_idx); #endif /* _FWU_H_ */
Hi Sughosh,
I have a last comment on this series, related to the below patch and patch "test: dm: Add test cases for FWU Metadata uclass".
+#include <fwu.h>
- fwu_plat_get_bootidx() - Get the value of the boot index
- @boot_idx: Boot index value
- Get the value of the bank(partition) from which the platform
- has booted. This value is passed to U-Boot from the earlier
- stage bootloader which loads and boots all the relevant
- firmware images
- firmware images
It's maybe not clean to pass a void * to something callee shall write to. Could the reference be passed with an explicit type pointer as 'unsigned int *'?
Best regards, Etienne
2.34.1
hi Etienne,
On Tue, 6 Sept 2022 at 12:57, Etienne Carriere etienne.carriere@linaro.org wrote:
Hi Sughosh,
+#include <fwu.h>
- firmware images
- firmware images
The reason I chose this to be a void pointer is that different platforms might have different means of passing the boot index value -- on certain platforms this might be passed through a 32 bit register, 8 bit register on some other. Since this is a platform function, the corresponding platform would know how the index value is being passed and would use the correct sized pointer.
-sughosh
2.34.1
hi Etienne,
On Tue, 6 Sept 2022 at 13:07, Sughosh Ganu sughosh.ganu@linaro.org wrote:
hi Etienne,
Hi Sughosh,
+#include <fwu.h>
- firmware images
- firmware images
Sorry, I got this wrong. This can indeed be passed as an unsigned int pointer. Will fix this in the next version. Thanks.
-sughosh
-sughosh
2.34.1
Add an event type EVT_MAIN_LOOP that can be used for registering events that need to be run after the platform has been initialised and before the main_loop function is called.
Signed-off-by: Sughosh Ganu sughosh.ganu@linaro.org --- Changes since V8: New patch
common/board_r.c | 3 +++ common/event.c | 3 +++ include/event.h | 3 +++ 3 files changed, 9 insertions(+)
diff --git a/common/board_r.c b/common/board_r.c index 56eb60fa27..1db061e65c 100644 --- a/common/board_r.c +++ b/common/board_r.c @@ -576,6 +576,9 @@ static int run_main_loop(void) #ifdef CONFIG_SANDBOX sandbox_main_loop_init(); #endif + + event_notify_null(EVT_MAIN_LOOP); + /* main_loop() can return to retry autoboot, if so just run it again */ for (;;) main_loop(); diff --git a/common/event.c b/common/event.c index 3e34550978..231b9e6ffd 100644 --- a/common/event.c +++ b/common/event.c @@ -38,6 +38,9 @@ const char *const type_name[] = {
/* fdt hooks */ "ft_fixup", + + /* main loop events */ + "main_loop", };
_Static_assert(ARRAY_SIZE(type_name) == EVT_COUNT, "event type_name size"); diff --git a/include/event.h b/include/event.h index e8f2f55c63..0748d676df 100644 --- a/include/event.h +++ b/include/event.h @@ -34,6 +34,9 @@ enum event_t { /* Device tree fixups before booting */ EVT_FT_FIXUP,
+ /* To be called from main_loop */ + EVT_MAIN_LOOP, + EVT_COUNT };
But please add more detail below.
"main_loop",
This is vague. Please indicate exactly when it is called, i.e. only once, just before the main loop is run for the first time.
EVT_MAIN_LOOP,
EVT_COUNT
-- 2.34.1
Regards, SImon
The FWU Multi Bank Update specification requires the Update Agent to carry out certain checks at the time of platform boot. The Update Agent is the component which is responsible for updating the firmware components and maintaining and keeping the metadata in sync.
The spec requires that the Update Agent perform the following checks at the time of boot * Sanity check of both the metadata copies maintained by the platform. * Get the boot index passed to U-Boot by the prior stage bootloader and use this value for metadata bookkeeping. * Check if the system is booting in Trial State. If the system boots in the Trial State for more than a specified number of boot counts, change the Active Bank to be booting the platform from.
Call these checks through the main loop event at the time of platform boot.
Signed-off-by: Sughosh Ganu sughosh.ganu@linaro.org --- Changes since V8: * Call fwu_boottime_checks through the event interface * Add comments for API functions
include/fwu.h | 13 +++ lib/efi_loader/efi_setup.c | 1 + lib/fwu_updates/fwu.c | 189 ++++++++++++++++++++++++++++++++++++- 3 files changed, 202 insertions(+), 1 deletion(-)
diff --git a/include/fwu.h b/include/fwu.h index b8c207deaf..31c9923ff5 100644 --- a/include/fwu.h +++ b/include/fwu.h @@ -252,4 +252,17 @@ int fwu_plat_get_update_index(uint *update_idx); * */ void fwu_plat_get_bootidx(void *boot_idx); + +/** + * fwu_update_checks_pass() - Check if FWU update can be done + * + * Check if the FWU update can be executed. The updates are + * allowed only when the platform is not in Trial State and + * the boot time checks have passed + * + * Return: 1 if OK, 0 on error + * + */ +u8 fwu_update_checks_pass(void); + #endif /* _FWU_H_ */ diff --git a/lib/efi_loader/efi_setup.c b/lib/efi_loader/efi_setup.c index 751beda590..23dc7a0710 100644 --- a/lib/efi_loader/efi_setup.c +++ b/lib/efi_loader/efi_setup.c @@ -199,6 +199,7 @@ static efi_status_t __efi_init_early(void) goto out;
ret = efi_disk_init(); + out: return ret; } diff --git a/lib/fwu_updates/fwu.c b/lib/fwu_updates/fwu.c index 94b15859a5..27f48855af 100644 --- a/lib/fwu_updates/fwu.c +++ b/lib/fwu_updates/fwu.c @@ -4,10 +4,19 @@ */
#include <dm.h> +#include <efi.h> #include <efi_loader.h> +#include <efi_variable.h> +#include <event.h> #include <fwu.h> #include <fwu_mdata.h> -#include <log.h> +#include <malloc.h> + +#include <linux/errno.h> +#include <linux/types.h> + +static u8 trial_state; +static u8 boottime_check;
#include <linux/errno.h> #include <linux/types.h> @@ -16,6 +25,112 @@ #define IMAGE_ACCEPT_SET BIT(0) #define IMAGE_ACCEPT_CLEAR BIT(1)
+static int trial_counter_update(u16 *trial_state_ctr) +{ + bool delete; + u32 var_attr; + efi_status_t status; + efi_uintn_t var_size; + + delete = !trial_state_ctr ? true : false; + var_size = !trial_state_ctr ? 0 : (efi_uintn_t)sizeof(*trial_state_ctr); + var_attr = !trial_state_ctr ? 0 : EFI_VARIABLE_NON_VOLATILE | + EFI_VARIABLE_BOOTSERVICE_ACCESS; + status = efi_set_variable_int(u"TrialStateCtr", + &efi_global_variable_guid, + var_attr, + var_size, trial_state_ctr, false); + + if ((delete && (status != EFI_NOT_FOUND && + status != EFI_SUCCESS)) || + (!delete && status != EFI_SUCCESS)) + return -1; + + return 0; +} + +static int in_trial_state(struct fwu_mdata *mdata) +{ + u32 i, active_bank; + struct fwu_image_entry *img_entry; + struct fwu_image_bank_info *img_bank_info; + + active_bank = mdata->active_index; + img_entry = &mdata->img_entry[0]; + for (i = 0; i < CONFIG_FWU_NUM_IMAGES_PER_BANK; i++) { + img_bank_info = &img_entry[i].img_bank_info[active_bank]; + if (!img_bank_info->accepted) { + return 1; + } + } + + return 0; +} + +static int fwu_trial_state_check(struct udevice *dev) +{ + int ret; + efi_status_t status; + efi_uintn_t var_size; + u16 trial_state_ctr; + u32 var_attributes, active_idx; + struct fwu_mdata mdata = { 0 }; + + ret = fwu_get_mdata(dev, &mdata); + if (ret) + return ret; + + if ((trial_state = in_trial_state(&mdata))) { + var_size = (efi_uintn_t)sizeof(trial_state_ctr); + log_info("System booting in Trial State\n"); + var_attributes = EFI_VARIABLE_NON_VOLATILE | + EFI_VARIABLE_BOOTSERVICE_ACCESS; + status = efi_get_variable_int(u"TrialStateCtr", + &efi_global_variable_guid, + &var_attributes, + &var_size, &trial_state_ctr, + NULL); + if (status != EFI_SUCCESS) { + log_err("Unable to read TrialStateCtr variable\n"); + ret = -1; + goto out; + } + + ++trial_state_ctr; + if (trial_state_ctr > CONFIG_FWU_TRIAL_STATE_CNT) { + log_info("Trial State count exceeded. Revert back to previous_active_index\n"); + active_idx = mdata.active_index; + ret = fwu_revert_boot_index(); + if (ret) { + log_err("Unable to revert active_index\n"); + goto out; + } + + /* Delete the TrialStateCtr variable */ + ret = trial_counter_update(NULL); + if (ret) { + log_err("Unable to delete TrialStateCtr variable\n"); + goto out; + } + } else { + ret = trial_counter_update(&trial_state_ctr); + if (ret) { + log_err("Unable to increment TrialStateCtr variable\n"); + goto out; + } + } + } else { + /* Delete the variable */ + ret = trial_counter_update(NULL); + if (ret) { + log_err("Unable to delete TrialStateCtr variable\n"); + } + } + +out: + return ret; +} + static int fwu_get_dev(struct udevice **dev)
{ @@ -382,3 +497,75 @@ __weak int fwu_plat_get_update_index(uint *update_idx)
return ret; } + +/** + * fwu_update_checks_pass() - Check if FWU update can be done + * + * Check if the FWU update can be executed. The updates are + * allowed only when the platform is not in Trial State and + * the boot time checks have passed + * + * Return: 1 if OK, 0 on error + * + */ +u8 fwu_update_checks_pass(void) +{ + return !trial_state && boottime_check; +} + +static int fwu_boottime_checks(void *ctx, struct event *event) +{ + int ret; + struct udevice *dev; + u32 boot_idx, active_idx; + + ret = fwu_get_dev(&dev); + if (ret) + return ret; + + ret = fwu_mdata_check(dev); + if (ret) { + return 0; + } + + /* + * Get the Boot Index, i.e. the bank from + * which the platform has booted. This value + * gets passed from the ealier stage bootloader + * which booted u-boot, e.g. tf-a. If the + * boot index is not the same as the + * active_index read from the FWU metadata, + * update the active_index. + */ + fwu_plat_get_bootidx(&boot_idx); + if (boot_idx >= CONFIG_FWU_NUM_BANKS) { + log_err("Received incorrect value of boot_index\n"); + return 0; + } + + ret = fwu_get_active_index(&active_idx); + if (ret) { + log_err("Unable to read active_index\n"); + return 0; + } + + if (boot_idx != active_idx) { + log_info("Boot idx %u is not matching active idx %u, changing active_idx\n", + boot_idx, active_idx); + ret = fwu_update_active_index(boot_idx); + if (!ret) + boottime_check = 1; + + return 0; + } + + if (efi_init_obj_list() != EFI_SUCCESS) + return 0; + + ret = fwu_trial_state_check(dev); + if (!ret) + boottime_check = 1; + + return 0; +} +EVENT_SPY(EVT_MAIN_LOOP, fwu_boottime_checks);
- Sanity check of both the metadata copies maintained by the platform.
- Get the boot index passed to U-Boot by the prior stage bootloader and use this value for metadata bookkeeping.
- Check if the system is booting in Trial State. If the system boots in the Trial State for more than a specified number of boot counts, change the Active Bank to be booting the platform from.
Changes since V8:
- Call fwu_boottime_checks through the event interface
- fwu_update_checks_pass() - Check if FWU update can be done
- Check if the FWU update can be executed. The updates are
- allowed only when the platform is not in Trial State and
- the boot time checks have passed
- Return: 1 if OK, 0 on error
bool delete;
u32 var_attr;
var_attr,
return -1;
u32 i, active_bank;
return 1;
int ret;
if (ret)
return ret;
&var_attributes,
NULL);
ret = -1;
goto out;
++trial_state_ctr;
if (ret) {
goto out;
if (ret) {
goto out;
} else {
if (ret) {
goto out;
} else {
if (ret) {
+out:
return ret;
return ret;
int ret;
if (ret)
return ret;
if (ret) {
if (ret) {
if (!ret)
boottime_check = 1;
if (!ret)
boottime_check = 1;
2.34.1
Hi Sughosh,
Reviewed-by: Etienne Carriere etienne.carriere@linaro.org with a minor comment.
Changes since V8:
bool delete;
u32 var_attr;
var_attr,
return -1;
u32 i, active_bank;
return 1;
int ret;
if (ret)
return ret;
&var_attributes,
NULL);
ret = -1;
goto out;
++trial_state_ctr;
Can be removed. active_idx is not used.
Br, Etienne
if (ret) {
goto out;
if (ret) {
goto out;
} else {
if (ret) {
goto out;
} else {
if (ret) {
+out:
return ret;
return ret;
int ret;
if (ret)
return ret;
if (ret) {
if (ret) {
if (!ret)
boottime_check = 1;
if (!ret)
boottime_check = 1;
2.34.1
hi Etienne,
Hi Sughosh,
Changes since V8:
bool delete;
u32 var_attr;
var_attr,
return -1;
u32 i, active_bank;
return 1;
int ret;
if (ret)
return ret;
&var_attributes,
NULL);
ret = -1;
goto out;
++trial_state_ctr;
Will remove. Thanks.
-sughosh
Br, Etienne
if (ret) {
goto out;
if (ret) {
goto out;
} else {
if (ret) {
goto out;
} else {
if (ret) {
+out:
return ret;
return ret;
int ret;
if (ret)
return ret;
if (ret) {
if (ret) {
if (!ret)
boottime_check = 1;
if (!ret)
boottime_check = 1;
2.34.1
The FWU Multi Bank Update feature supports updation of firmware images to one of multiple sets(also called banks) of images. The firmware images are clubbed together in banks, with the system booting images from the active bank. Information on the images such as which bank they belong to is stored as part of the metadata structure, which is stored on the same storage media as the firmware images on a dedicated partition.
At the time of update, the metadata is read to identify the bank to which the images need to be flashed(update bank). On a successful update, the metadata is modified to set the updated bank as active bank to subsequently boot from.
Signed-off-by: Sughosh Ganu sughosh.ganu@linaro.org --- Changes since V8: * Add comments for API functions * Move addition of the FWU Kconfig symbols and Makefile to this patch
drivers/Kconfig | 2 + drivers/Makefile | 1 + include/fwu.h | 30 +++++ lib/Kconfig | 6 + lib/Makefile | 1 + lib/efi_loader/efi_capsule.c | 213 ++++++++++++++++++++++++++++++++++- lib/efi_loader/efi_setup.c | 3 +- lib/fwu_updates/Kconfig | 32 ++++++ lib/fwu_updates/Makefile | 7 ++ lib/fwu_updates/fwu.c | 23 ++++ 10 files changed, 312 insertions(+), 6 deletions(-) create mode 100644 lib/fwu_updates/Kconfig create mode 100644 lib/fwu_updates/Makefile
diff --git a/drivers/Kconfig b/drivers/Kconfig index 8b6fead351..75ac149d31 100644 --- a/drivers/Kconfig +++ b/drivers/Kconfig @@ -44,6 +44,8 @@ source "drivers/fuzz/Kconfig"
source "drivers/fpga/Kconfig"
+source "drivers/fwu-mdata/Kconfig" + source "drivers/gpio/Kconfig"
source "drivers/hwspinlock/Kconfig" diff --git a/drivers/Makefile b/drivers/Makefile index eba9940231..af7ed7bdf3 100644 --- a/drivers/Makefile +++ b/drivers/Makefile @@ -84,6 +84,7 @@ obj-y += cache/ obj-$(CONFIG_CPU) += cpu/ obj-y += crypto/ obj-$(CONFIG_FASTBOOT) += fastboot/ +obj-$(CONFIG_FWU_MDATA) += fwu-mdata/ obj-y += misc/ obj-$(CONFIG_MMC) += mmc/ obj-$(CONFIG_NVME) += nvme/ diff --git a/include/fwu.h b/include/fwu.h index 31c9923ff5..e05e1d1a00 100644 --- a/include/fwu.h +++ b/include/fwu.h @@ -60,6 +60,7 @@ struct fwu_mdata_ops { };
#define FWU_MDATA_VERSION 0x1 +#define FWU_IMAGE_ACCEPTED 0x1
/* * GUID value defined in the FWU specification for identification @@ -69,6 +70,24 @@ struct fwu_mdata_ops { EFI_GUID(0x8a7a84a0, 0x8387, 0x40f6, 0xab, 0x41, \ 0xa8, 0xb9, 0xa5, 0xa6, 0x0d, 0x23)
+/* +* GUID value defined in the Dependable Boot specification for +* identification of the revert capsule, used for reverting +* any image in the updated bank. +*/ +#define FWU_OS_REQUEST_FW_REVERT_GUID \ + EFI_GUID(0xacd58b4b, 0xc0e8, 0x475f, 0x99, 0xb5, \ + 0x6b, 0x3f, 0x7e, 0x07, 0xaa, 0xf0) + +/* +* GUID value defined in the Dependable Boot specification for +* identification of the accept capsule, used for accepting +* an image in the updated bank. +*/ +#define FWU_OS_REQUEST_FW_ACCEPT_GUID \ + EFI_GUID(0x0c996046, 0xbcc0, 0x4d04, 0x85, 0xec, \ + 0xe1, 0xfc, 0xed, 0xf1, 0xc6, 0xf8) + /** * fwu_get_mdata() - Get a FWU metadata copy * @dev: FWU metadata device @@ -265,4 +284,15 @@ void fwu_plat_get_bootidx(void *boot_idx); */ u8 fwu_update_checks_pass(void);
+/** + * fwu_trial_state_ctr_start() - Start the Trial State counter + * + * Start the counter to identify the platform booting in the + * Trial State. The counter is implemented as an EFI variable. + * + * Return: 0 if OK, -ve on error + * + */ +int fwu_trial_state_ctr_start(void); + #endif /* _FWU_H_ */ diff --git a/lib/Kconfig b/lib/Kconfig index 6121c80dc8..6abe1d0a86 100644 --- a/lib/Kconfig +++ b/lib/Kconfig @@ -978,3 +978,9 @@ config LMB_RESERVED_REGIONS memory blocks.
endmenu + +menu "FWU Multi Bank Updates" + +source lib/fwu_updates/Kconfig + +endmenu diff --git a/lib/Makefile b/lib/Makefile index e3deb15287..f2cfd1e428 100644 --- a/lib/Makefile +++ b/lib/Makefile @@ -9,6 +9,7 @@ obj-$(CONFIG_EFI) += efi/ obj-$(CONFIG_EFI_LOADER) += efi_driver/ obj-$(CONFIG_EFI_LOADER) += efi_loader/ obj-$(CONFIG_CMD_BOOTEFI_SELFTEST) += efi_selftest/ +obj-$(CONFIG_FWU_MULTI_BANK_UPDATE) += fwu_updates/ obj-$(CONFIG_LZMA) += lzma/ obj-$(CONFIG_BZIP2) += bzip2/ obj-$(CONFIG_FIT) += libfdt/ diff --git a/lib/efi_loader/efi_capsule.c b/lib/efi_loader/efi_capsule.c index a6b98f066a..44c56443dc 100644 --- a/lib/efi_loader/efi_capsule.c +++ b/lib/efi_loader/efi_capsule.c @@ -14,6 +14,7 @@ #include <env.h> #include <fdtdec.h> #include <fs.h> +#include <fwu.h> #include <hang.h> #include <malloc.h> #include <mapmem.h> @@ -32,6 +33,17 @@ static const efi_guid_t efi_guid_firmware_management_capsule_id = EFI_FIRMWARE_MANAGEMENT_CAPSULE_ID_GUID; const efi_guid_t efi_guid_firmware_management_protocol = EFI_FIRMWARE_MANAGEMENT_PROTOCOL_GUID; +const efi_guid_t fwu_guid_os_request_fw_revert = + FWU_OS_REQUEST_FW_REVERT_GUID; +const efi_guid_t fwu_guid_os_request_fw_accept = + FWU_OS_REQUEST_FW_ACCEPT_GUID; + +#define FW_ACCEPT_OS (u32)0x8000 + +__maybe_unused static u32 update_index; +__maybe_unused static bool capsule_update; +__maybe_unused static bool fw_accept_os; +static bool image_index_check = true;
#ifdef CONFIG_EFI_CAPSULE_ON_DISK /* for file system access */ @@ -205,7 +217,8 @@ efi_fmp_find(efi_guid_t *image_type, u8 image_index, u64 instance, log_debug("+++ desc[%d] index: %d, name: %ls\n", j, desc->image_index, desc->image_id_name); if (!guidcmp(&desc->image_type_id, image_type) && - (desc->image_index == image_index) && + (!image_index_check || + desc->image_index == image_index) && (!instance || !desc->hardware_instance || desc->hardware_instance == instance)) @@ -388,6 +401,83 @@ efi_status_t efi_capsule_authenticate(const void *capsule, efi_uintn_t capsule_s } #endif /* CONFIG_EFI_CAPSULE_AUTHENTICATE */
+static bool fwu_empty_capsule(struct efi_capsule_header *capsule) +{ + return !guidcmp(&capsule->capsule_guid, + &fwu_guid_os_request_fw_revert) || + !guidcmp(&capsule->capsule_guid, + &fwu_guid_os_request_fw_accept); +} + +static efi_status_t fwu_to_efi_error(int err) +{ + efi_status_t ret; + + switch(err) { + case 0: + ret = EFI_SUCCESS; + break; + case -ENODEV: + case -ERANGE: + case -EIO: + ret = EFI_DEVICE_ERROR; + break; + case -EINVAL: + ret = EFI_INVALID_PARAMETER; + break; + default: + ret = EFI_OUT_OF_RESOURCES; + } + + return ret; +} + +static efi_status_t fwu_empty_capsule_process( + struct efi_capsule_header *capsule) +{ + int status; + u32 active_idx; + efi_status_t ret; + efi_guid_t *image_guid; + + if (!guidcmp(&capsule->capsule_guid, + &fwu_guid_os_request_fw_revert)) { + /* + * One of the previously updated image has + * failed the OS acceptance test. OS has + * requested to revert back to the earlier + * boot index + */ + status = fwu_revert_boot_index(); + ret = fwu_to_efi_error(status); + if (ret == EFI_SUCCESS) + log_info("Reverted the FWU active_index. Recommend rebooting the system\n"); + else + log_err("Failed to revert the FWU boot index\n"); + } else { + /* + * Image accepted by the OS. Set the acceptance + * status for the image. + */ + image_guid = (void *)(char *)capsule + + capsule->header_size; + + status = fwu_get_active_index(&active_idx); + ret = fwu_to_efi_error(status); + if (ret != EFI_SUCCESS) { + log_err("Unable to get the active_index from the FWU metadata\n"); + return ret; + } + + status = fwu_accept_image(image_guid, active_idx); + ret = fwu_to_efi_error(status); + if (ret != EFI_SUCCESS) + log_err("Unable to set the Accept bit for the image %pUs\n", + image_guid); + } + + return ret; +}
/** * efi_capsule_update_firmware - update firmware from capsule @@ -407,10 +497,42 @@ static efi_status_t efi_capsule_update_firmware( void *image_binary, *vendor_code; efi_handle_t *handles; efi_uintn_t no_handles; - int item; + int item, alt_no; struct efi_firmware_management_protocol *fmp; u16 *abort_reason; + efi_guid_t image_type_id; efi_status_t ret = EFI_SUCCESS; + int status; + u8 image_index; + + if (IS_ENABLED(CONFIG_FWU_MULTI_BANK_UPDATE)) { + if (!fwu_empty_capsule(capsule_data) && + !fwu_update_checks_pass()) { + log_err("FWU checks failed. Cannot start update\n"); + return EFI_INVALID_PARAMETER; + } + + if (fwu_empty_capsule(capsule_data)) { + capsule_update = false; + return fwu_empty_capsule_process(capsule_data); + } else { + capsule_update = true; + } + + /* Obtain the update_index from the platform */ + status = fwu_plat_get_update_index(&update_index); + if (status < 0) { + log_err("Failed to get the FWU update_index value\n"); + return EFI_DEVICE_ERROR; + } + + fw_accept_os = capsule_data->flags & FW_ACCEPT_OS ? 0x1 : 0x0; + /* + * For Multi Bank updates, the image index is determined at + * runtime based on the value of the update bank. + */ + image_index_check = false; + }
/* sanity check */ if (capsule_data->header_size < sizeof(*capsule) || @@ -485,8 +607,31 @@ static efi_status_t efi_capsule_update_firmware( goto out; }
+ if (IS_ENABLED(CONFIG_FWU_MULTI_BANK_UPDATE)) { + /* + * Based on the value of update_image_type_id, + * derive the alt number value. This will be + * passed as update_image_index to the + * set_image function. + */ + image_type_id = image->update_image_type_id; + status = fwu_get_image_alt_num(&image_type_id, + update_index, + &alt_no); + ret = fwu_to_efi_error(status); + if (ret != EFI_SUCCESS) { + log_err("Unable to get the alt no for the image type %pUs\n", + &image_type_id); + goto out; + } + log_debug("alt_no %u for Image Type Id %pUs\n", + alt_no, &image_type_id); + image_index = alt_no + 1; + } else { + image_index = image->update_image_index; + } abort_reason = NULL; - ret = EFI_CALL(fmp->set_image(fmp, image->update_image_index, + ret = EFI_CALL(fmp->set_image(fmp, image_index, image_binary, image_binary_size, vendor_code, NULL, @@ -497,6 +642,33 @@ static efi_status_t efi_capsule_update_firmware( efi_free_pool(abort_reason); goto out; } + + if (IS_ENABLED(CONFIG_FWU_MULTI_BANK_UPDATE)) { + if (!fw_accept_os) { + /* + * The OS will not be accepting the firmware + * images. Set the accept bit of all the + * images contained in this capsule. + */ + status = fwu_accept_image(&image_type_id, + update_index); + } else { + status = fwu_clear_accept_image(&image_type_id, + update_index); + } + ret = fwu_to_efi_error(status); + if (ret != EFI_SUCCESS) { + log_err("Unable to %s the accept bit for the image %pUs\n", + fw_accept_os ? "clear" : "set", + &image_type_id); + goto out; + } + + log_debug("%s the accepted bit for Image %pUs\n", + fw_accept_os ? "Cleared" : "Set", + &image_type_id); + } + }
out: @@ -1102,8 +1274,10 @@ efi_status_t efi_launch_capsules(void) { struct efi_capsule_header *capsule = NULL; u16 **files; + int status; unsigned int nfiles, index, i; efi_status_t ret; + bool update_status = true;
if (check_run_capsules() != EFI_SUCCESS) return EFI_SUCCESS; @@ -1131,12 +1305,14 @@ efi_status_t efi_launch_capsules(void) ret = efi_capsule_read_file(files[i], &capsule); if (ret == EFI_SUCCESS) { ret = efi_capsule_update_firmware(capsule); - if (ret != EFI_SUCCESS) + if (ret != EFI_SUCCESS) { log_err("Applying capsule %ls failed.\n", files[i]); - else + update_status = false; + } else { log_info("Applying capsule %ls succeeded.\n", files[i]); + }
/* create CapsuleXXXX */ set_capsule_result(index, capsule, ret); @@ -1144,6 +1320,7 @@ efi_status_t efi_launch_capsules(void) free(capsule); } else { log_err("Reading capsule %ls failed\n", files[i]); + update_status = false; } /* delete a capsule either in case of success or failure */ ret = efi_capsule_delete_file(files[i]); @@ -1151,7 +1328,33 @@ efi_status_t efi_launch_capsules(void) log_err("Deleting capsule %ls failed\n", files[i]); } + efi_capsule_scan_done(); + if (IS_ENABLED(CONFIG_FWU_MULTI_BANK_UPDATE)) { + if (update_status == true && capsule_update == true) { + /* + * All the capsules have been updated successfully, + * update the FWU metadata. + */ + log_debug("Update Complete. Now updating active_index to %u\n", + update_index); + status = fwu_update_active_index(update_index); + ret = fwu_to_efi_error(status); + if (ret != EFI_SUCCESS) { + log_err("Failed to update FWU metadata index values\n"); + } else { + log_debug("Successfully updated the active_index\n"); + ret = EFI_SUCCESS; + if (fw_accept_os) { + status = fwu_trial_state_ctr_start(); + if (status < 0) + ret = EFI_DEVICE_ERROR; + } + } + } else if (capsule_update == true && update_status == false) { + log_err("All capsules were not updated. Not updating FWU metadata\n"); + } + }
for (i = 0; i < nfiles; i++) free(files[i]); diff --git a/lib/efi_loader/efi_setup.c b/lib/efi_loader/efi_setup.c index 23dc7a0710..60012e873e 100644 --- a/lib/efi_loader/efi_setup.c +++ b/lib/efi_loader/efi_setup.c @@ -351,7 +351,8 @@ efi_status_t efi_init_obj_list(void) goto out;
/* Execute capsules after reboot */ - if (IS_ENABLED(CONFIG_EFI_CAPSULE_ON_DISK) && + if (!IS_ENABLED(CONFIG_FWU_MULTI_BANK_UPDATE) && + IS_ENABLED(CONFIG_EFI_CAPSULE_ON_DISK) && !IS_ENABLED(CONFIG_EFI_CAPSULE_ON_DISK_EARLY)) ret = efi_launch_capsules(); out: diff --git a/lib/fwu_updates/Kconfig b/lib/fwu_updates/Kconfig new file mode 100644 index 0000000000..e33085f1d3 --- /dev/null +++ b/lib/fwu_updates/Kconfig @@ -0,0 +1,32 @@ +config FWU_MULTI_BANK_UPDATE + bool "Enable FWU Multi Bank Update Feature" + depends on EFI_HAVE_CAPSULE_SUPPORT + select PARTITION_TYPE_GUID + select EFI_SETUP_EARLY + select EVENT + help + Feature for updating firmware images on platforms having + multiple banks(copies) of the firmware images. One of the + bank is selected for updating all the firmware components + +config FWU_NUM_BANKS + int "Number of Banks defined by the platform" + depends on FWU_MULTI_BANK_UPDATE + help + Define the number of banks of firmware images on a platform + +config FWU_NUM_IMAGES_PER_BANK + int "Number of firmware images per bank" + depends on FWU_MULTI_BANK_UPDATE + help + Define the number of firmware images per bank. This value + should be the same for all the banks. + +config FWU_TRIAL_STATE_CNT + int "Number of times system boots in Trial State" + depends on FWU_MULTI_BANK_UPDATE + default 3 + help + With FWU Multi Bank Update feature enabled, number of times + the platform is allowed to boot in Trial State after an + update. diff --git a/lib/fwu_updates/Makefile b/lib/fwu_updates/Makefile new file mode 100644 index 0000000000..1993088e5b --- /dev/null +++ b/lib/fwu_updates/Makefile @@ -0,0 +1,7 @@ +# SPDX-License-Identifier: GPL-2.0-or-later +# +# Copyright (c) 2022, Linaro Limited +# + +obj-$(CONFIG_FWU_MULTI_BANK_UPDATE) += fwu.o +obj-$(CONFIG_FWU_MDATA_GPT_BLK) += fwu_gpt.o diff --git a/lib/fwu_updates/fwu.c b/lib/fwu_updates/fwu.c index 27f48855af..de2412785d 100644 --- a/lib/fwu_updates/fwu.c +++ b/lib/fwu_updates/fwu.c @@ -513,7 +513,30 @@ u8 fwu_update_checks_pass(void) return !trial_state && boottime_check; }
+/** + * fwu_trial_state_ctr_start() - Start the Trial State counter + * + * Start the counter to identify the platform booting in the + * Trial State. The counter is implemented as an EFI variable. + * + * Return: 0 if OK, -ve on error + * + */ +int fwu_trial_state_ctr_start(void) +{ + int ret; + u16 trial_state_ctr; + + trial_state_ctr = 0; + ret = trial_counter_update(&trial_state_ctr); + if (ret) + log_err("Unable to initialise TrialStateCtr\n"); + + return ret; +} + static int fwu_boottime_checks(void *ctx, struct event *event) + { int ret; struct udevice *dev;
Hi Sughosh,
Overall, I think the code is covering all the cases for A/B updates. Irrelevant to this patchset, but in the future I think we shopuld look into having efi_launch_capsules() call efi_update_capsule() would be cleaner.
I think you can get rid all of these
This can be calculated at runtime
Dittio, you just need a call to figure out if it's an empty capsule or not
Same for this one
Can't this just be an ifdef in the if statement that uses it?
- return !guidcmp(&capsule->capsule_guid,
- efi_status_t ret;
- switch(err) {
- case 0:
ret = EFI_SUCCESS;
break;
- case -ENODEV:
- case -ERANGE:
- case -EIO:
break;
- case -EINVAL:
break;
- default:
- return ret;
- struct efi_capsule_header *capsule)
- int status;
- u32 active_idx;
- efi_status_t ret;
- efi_guid_t *image_guid;
- if (!guidcmp(&capsule->capsule_guid,
* boot index
else
- } else {
return ret;
image_guid);
- return ret;
- efi_capsule_update_firmware - update firmware from capsule
- int item;
int status;
u8 image_index;
} else {
if (status < 0) {
update_index,
&alt_no);
&image_type_id);
goto out;
} else {
abort_reason = NULL;}
update_index);
} else {
update_index);
&image_type_id);
goto out;
&image_type_id);
else
} /* create CapsuleXXXX */ set_capsule_result(index, capsule, ret);
} /* delete a capsule either in case of success or failure */ ret = efi_capsule_delete_file(files[i]);update_status = false;
update_index);
} else {
ret = EFI_SUCCESS;
if (fw_accept_os) {
if (status < 0)
- if (!IS_ENABLED(CONFIG_FWU_MULTI_BANK_UPDATE) &&
ret = efi_launch_capsules();IS_ENABLED(CONFIG_EFI_CAPSULE_ON_DISK) && !IS_ENABLED(CONFIG_EFI_CAPSULE_ON_DISK_EARLY))
- bool "Enable FWU Multi Bank Update Feature"
- depends on EFI_HAVE_CAPSULE_SUPPORT
- select PARTITION_TYPE_GUID
- select EFI_SETUP_EARLY
- select EVENT
- help
- int "Number of Banks defined by the platform"
- depends on FWU_MULTI_BANK_UPDATE
- help
- int "Number of firmware images per bank"
- help
- int "Number of times system boots in Trial State"
- default 3
- help
update.
- fwu_trial_state_ctr_start() - Start the Trial State counter
- Start the counter to identify the platform booting in the
- Trial State. The counter is implemented as an EFI variable.
- Return: 0 if OK, -ve on error
- int ret;
- u16 trial_state_ctr;
- trial_state_ctr = 0;
- ret = trial_counter_update(&trial_state_ctr);
- if (ret)
- return ret;
{ int ret; struct udevice *dev; -- 2.34.1
Thanks /Ilias
Hi Sughosh,
Changes since V8:
- Move addition of the FWU Kconfig symbols and Makefile to this patch
- GUID value defined in the FWU specification for identification
- EFI_GUID(0xacd58b4b, 0xc0e8, 0x475f, 0x99, 0xb5, \
- EFI_GUID(0x0c996046, 0xbcc0, 0x4d04, 0x85, 0xec, \
- fwu_get_mdata() - Get a FWU metadata copy
- @dev: FWU metadata device
endmenu
- efi_status_t ret;
- switch(err) {
- case 0:
ret = EFI_SUCCESS;
break;
- case -ENODEV:
- case -ERANGE:
- case -EIO:
break;
- case -EINVAL:
break;
- default:
- return ret;
- int status;
- u32 active_idx;
- efi_status_t ret;
* boot index
else
- } else {
return ret;
image_guid);
- return ret;
- int item;
int status;
u8 image_index;
} else {
if (status < 0) {
update_index,
&alt_no);
I have a concern here. The function's name, fwd_get_image_alt_num(), suggests that it is somehow related to dfu (alto number) feature. Actually, however, I hope not; the function's purpose is simply to convert "update_index" to a proper value under some condition (i.e. A/B update).
From design's point of view, the entire code in efi_capsule.c should
stay generic enough to support various type of underling firmware frameworks. Please note that efi_firmware.c is just one of such implementations of firmware update protocols.
So please think of changing the function's name if I am correct.
Furthermore, it would be better to call fwu_get_image_alt_num() in FMP drivers (in this case, efi_firmware.c). (Not sure though)
&image_type_id);
goto out;
} else {
update_index);
} else {
update_index);
&image_type_id);
goto out;
&image_type_id);
else
update_index);
} else {
ret = EFI_SUCCESS;
if (fw_accept_os) {
if (status < 0)
Why do you need this?
As a matter of fact, your commits rely on CAPSULE_ON_DISK.
This kconfig is always on since the commit a9bf024b2933 (efi_loader: disk: a helper function to create efi_disk objects from udevice).
Do you want to enable CAPSULE_ON_DISK_EARLY?
-Takahiro Akashi
- select EVENT
- help
- help
- help
- default 3
- help
update.
- int ret;
- if (ret)
- return ret;
hi Takahiro,
On Thu, 8 Sept 2022 at 07:45, Takahiro Akashi takahiro.akashi@linaro.org wrote:
Hi Sughosh,
Changes since V8:
endmenu
efi_status_t ret;
switch(err) {
case 0:
ret = EFI_SUCCESS;
break;
case -ENODEV:
case -ERANGE:
case -EIO:
break;
case -EINVAL:
break;
default:
return ret;
int status;
u32 active_idx;
efi_status_t ret;
* boot index
else
} else {
return ret;
image_guid);
return ret;
int item;
int status;
u8 image_index;
} else {
if (status < 0) {
} /* sanity check */ if (capsule_data->header_size < sizeof(*capsule) ||
update_index,
&alt_no);
From design's point of view, the entire code in efi_capsule.c should stay generic enough to support various type of underling firmware frameworks. Please note that efi_firmware.c is just one of such implementations of firmware update protocols.
Okay. I see your point. I will change the name of the API to make it generic so as to not tie it with the DFU alt number. Regarding your thoughts on putting this in the FMP drivers, I feel that rather than having the function get called from every FMP driver, it would be better to keep it where it currently is.
&image_type_id);
goto out;
} else {
update_index);
} else {
update_index);
&image_type_id);
goto out;
&image_type_id);
bool update_status = true; if (check_run_capsules() != EFI_SUCCESS) return EFI_SUCCESS;
else
update_index);
} else {
ret = EFI_SUCCESS;
if (fw_accept_os) {
if (status < 0)
} for (i = 0; i < nfiles; i++) free(files[i]);
Earlier, before a57ad20d07e, efi_init_obj_list() was getting called with CONFIG_EFI_SETUP_EARLY being set. With this, efi_launch_capsules() would be called before a call to fwu_boottime_checks(), which was the reason for the check above. With a57ad20d07e, this is no longer needed. I will remove this in the next version.
Yes, will change.
Yes, I can enable that, maybe as an imply.
-sughosh
-Takahiro Akashi
select EVENT
help
help
help
default 3
help
update.
int ret;
if (ret)
return ret;
Add a command to read the metadata as specified in the FWU specification and print the fields of the metadata.
Signed-off-by: Sughosh Ganu sughosh.ganu@linaro.org Reviewed-by: Ilias Apalodimas ilias.apalodimas@linaro.org --- Changes since V8: None
cmd/Kconfig | 6 ++++ cmd/Makefile | 1 + cmd/fwu_mdata.c | 79 +++++++++++++++++++++++++++++++++++++++++++++++++ 3 files changed, 86 insertions(+) create mode 100644 cmd/fwu_mdata.c
diff --git a/cmd/Kconfig b/cmd/Kconfig index 211ebe9c87..3abc60b63e 100644 --- a/cmd/Kconfig +++ b/cmd/Kconfig @@ -161,6 +161,12 @@ config CMD_CPU internal name) and clock frequency. Other information may be available depending on the CPU driver.
+config CMD_FWU_METADATA + bool "fwu metadata read" + depends on FWU_MULTI_BANK_UPDATE + help + Command to read the metadata and dump it's contents + config CMD_LICENSE bool "license" select BUILD_BIN2C diff --git a/cmd/Makefile b/cmd/Makefile index 6e87522b62..ff6e160f4a 100644 --- a/cmd/Makefile +++ b/cmd/Makefile @@ -76,6 +76,7 @@ obj-$(CONFIG_CMD_FPGA) += fpga.o obj-$(CONFIG_CMD_FPGAD) += fpgad.o obj-$(CONFIG_CMD_FS_GENERIC) += fs.o obj-$(CONFIG_CMD_FUSE) += fuse.o +obj-$(CONFIG_CMD_FWU_METADATA) += fwu_mdata.o obj-$(CONFIG_CMD_GETTIME) += gettime.o obj-$(CONFIG_CMD_GPIO) += gpio.o obj-$(CONFIG_CMD_HVC) += smccc.o diff --git a/cmd/fwu_mdata.c b/cmd/fwu_mdata.c new file mode 100644 index 0000000000..725b4c17d3 --- /dev/null +++ b/cmd/fwu_mdata.c @@ -0,0 +1,79 @@ +/* SPDX-License-Identifier: GPL-2.0-or-later */ +/* + * Copyright (c) 2022, Linaro Limited + */ + +#include <command.h> +#include <dm.h> +#include <fwu.h> +#include <fwu_mdata.h> +#include <log.h> +#include <stdio.h> +#include <stdlib.h> + +#include <linux/types.h> + +static void print_mdata(struct fwu_mdata *mdata) +{ + int i, j; + struct fwu_image_entry *img_entry; + struct fwu_image_bank_info *img_info; + + printf("\tFWU Metadata\n"); + printf("crc32: %#x\n", mdata->crc32); + printf("version: %#x\n", mdata->version); + printf("active_index: %#x\n", mdata->active_index); + printf("previous_active_index: %#x\n", mdata->previous_active_index); + + printf("\tImage Info\n"); + for (i = 0; i < CONFIG_FWU_NUM_IMAGES_PER_BANK; i++) { + img_entry = &mdata->img_entry[i]; + printf("\nImage Type Guid: %pUL\n", + &img_entry->image_type_uuid); + printf("Location Guid: %pUL\n", &img_entry->location_uuid); + for (j = 0; j < CONFIG_FWU_NUM_BANKS; j++) { + img_info = &img_entry->img_bank_info[j]; + printf("Image Guid: %pUL\n", &img_info->image_uuid); + printf("Image Acceptance: %s\n", + img_info->accepted == 0x1 ? "yes" : "no"); + } + } +} + +int do_fwu_mdata_read(struct cmd_tbl *cmdtp, int flag, + int argc, char * const argv[]) +{ + struct udevice *dev; + int ret = CMD_RET_SUCCESS, res; + struct fwu_mdata mdata = { 0 }; + + if (uclass_get_device(UCLASS_FWU_MDATA, 0, &dev) || !dev) { + log_err("Unable to get FWU metadata device\n"); + return CMD_RET_FAILURE; + } + + res = fwu_mdata_check(dev); + if (res < 0) { + log_err("FWU Metadata check failed\n"); + ret = CMD_RET_FAILURE; + goto out; + } + + res = fwu_get_mdata(dev, &mdata); + if (res < 0) { + log_err("Unable to get valid FWU metadata\n"); + ret = CMD_RET_FAILURE; + goto out; + } + + print_mdata(&mdata); + +out: + return ret; +} + +U_BOOT_CMD( + fwu_mdata_read, 1, 1, do_fwu_mdata_read, + "Read and print FWU metadata", + "" +);
help
- Copyright (c) 2022, Linaro Limited
int i, j;
if (res < 0) {
goto out;
if (res < 0) {
goto out;
+out:
return ret;
+U_BOOT_CMD(
2.34.1
Add test cases for accessing the FWU Metadata on the sandbox platform. The sandbox platform also uses the metadata access driver for GPT partitioned block devices.
The FWU feature will be tested on the sandbox64 variant with a raw capsule. Remove the FIT capsule testing from sandbox64 defconfig -- the FIT capsule test will be run on the sandbox_flattree variant.
Signed-off-by: Sughosh Ganu sughosh.ganu@linaro.org Suggested-by: Heinrich Schuchardt xypron.glpk@gmx.de --- Changes since V8: New patch
arch/sandbox/Kconfig | 6 + arch/sandbox/dts/test.dts | 7 +- board/sandbox/sandbox.c | 10 ++ configs/sandbox64_defconfig | 5 +- lib/fwu_updates/fwu.c | 6 + test/dm/Makefile | 1 + test/dm/fwu_mdata.c | 149 ++++++++++++++++++ test/dm/fwu_mdata_disk_image.h | 112 +++++++++++++ .../test_capsule_firmware_fit.py | 1 - .../test_capsule_firmware_signed_fit.py | 1 - tools/Makefile | 2 +- 11 files changed, 295 insertions(+), 5 deletions(-) create mode 100644 test/dm/fwu_mdata.c create mode 100644 test/dm/fwu_mdata_disk_image.h
diff --git a/arch/sandbox/Kconfig b/arch/sandbox/Kconfig index 852a7c8bf2..40cdea7d46 100644 --- a/arch/sandbox/Kconfig +++ b/arch/sandbox/Kconfig @@ -84,3 +84,9 @@ config SYS_FDT_LOAD_ADDR See `doc/arch/sandbox.rst` for more information.
endmenu + +config FWU_NUM_BANKS + default 2 + +config FWU_NUM_IMAGES_PER_BANK + default 2 diff --git a/arch/sandbox/dts/test.dts b/arch/sandbox/dts/test.dts index 2761588f0d..2cba13e98d 100644 --- a/arch/sandbox/dts/test.dts +++ b/arch/sandbox/dts/test.dts @@ -948,7 +948,7 @@ };
/* This is used for the fastboot tests */ - mmc0 { + mmc0: mmc0 { compatible = "sandbox,mmc"; };
@@ -1683,6 +1683,11 @@ compatible = "sandbox,regmap_test"; }; }; + + fwu-mdata { + compatible = "u-boot,fwu-mdata-gpt"; + fwu-mdata-store = <&mmc0>; + }; };
#include "sandbox_pmic.dtsi" diff --git a/board/sandbox/sandbox.c b/board/sandbox/sandbox.c index ca9a2ca5b1..76170f4cc8 100644 --- a/board/sandbox/sandbox.c +++ b/board/sandbox/sandbox.c @@ -164,3 +164,13 @@ int init_addr_map(void)
return 0; } + +#if defined(CONFIG_FWU_MULTI_BANK_UPDATE) +void fwu_plat_get_bootidx(void *boot_idx) +{ + u32 *idx = boot_idx; + + /* Dummy value */ + *idx = 0; +} +#endif diff --git a/configs/sandbox64_defconfig b/configs/sandbox64_defconfig index 290d1506c2..8d456e33d9 100644 --- a/configs/sandbox64_defconfig +++ b/configs/sandbox64_defconfig @@ -242,9 +242,12 @@ CONFIG_LZ4=y CONFIG_ERRNO_STR=y CONFIG_EFI_RUNTIME_UPDATE_CAPSULE=y CONFIG_EFI_CAPSULE_ON_DISK=y -CONFIG_EFI_CAPSULE_FIRMWARE_FIT=y +CONFIG_EFI_CAPSULE_FIRMWARE_RAW=y CONFIG_EFI_SECURE_BOOT=y CONFIG_TEST_FDTDEC=y CONFIG_UNIT_TEST=y CONFIG_UT_TIME=y CONFIG_UT_DM=y +CONFIG_FWU_MDATA=y +CONFIG_FWU_MDATA_GPT_BLK=y +CONFIG_FWU_MULTI_BANK_UPDATE=y diff --git a/lib/fwu_updates/fwu.c b/lib/fwu_updates/fwu.c index de2412785d..1fb6feabfd 100644 --- a/lib/fwu_updates/fwu.c +++ b/lib/fwu_updates/fwu.c @@ -542,6 +542,12 @@ static int fwu_boottime_checks(void *ctx, struct event *event) struct udevice *dev; u32 boot_idx, active_idx;
+ /* Don't have boot time checks on sandbox */ + if (IS_ENABLED(CONFIG_SANDBOX)) { + boottime_check = 1; + return 0; + } + ret = fwu_get_dev(&dev); if (ret) return ret; diff --git a/test/dm/Makefile b/test/dm/Makefile index 52fe178a82..61837703e8 100644 --- a/test/dm/Makefile +++ b/test/dm/Makefile @@ -47,6 +47,7 @@ ifneq ($(CONFIG_EFI_PARTITION),) obj-$(CONFIG_FASTBOOT_FLASH_MMC) += fastboot.o endif obj-$(CONFIG_FIRMWARE) += firmware.o +obj-$(CONFIG_FWU_MDATA_GPT_BLK) += fwu_mdata.o obj-$(CONFIG_DM_HWSPINLOCK) += hwspinlock.o obj-$(CONFIG_DM_I2C) += i2c.o obj-$(CONFIG_SOUND) += i2s.o diff --git a/test/dm/fwu_mdata.c b/test/dm/fwu_mdata.c new file mode 100644 index 0000000000..8120af334e --- /dev/null +++ b/test/dm/fwu_mdata.c @@ -0,0 +1,149 @@ +// SPDX-License-Identifier: GPL-2.0-or-later +/* + * Copyright (c) 2022, Linaro Limited + * Copyright (c) 2022, Heinrich Schuchardt xypron.glpk@gmx.de + */ + +#include <blk.h> +#include <common.h> +#include <dm.h> +#include <fwu.h> +#include <fwu_mdata.h> +#include <log.h> +#include <malloc.h> +#include <memalign.h> +#include <part.h> + +#include <dm/test.h> +#include <test/ut.h> + +#include "fwu_mdata_disk_image.h" + +/* Block size of compressed disk image */ +#define COMPRESSED_DISK_IMAGE_BLOCK_SIZE 8 + +static struct udevice *mmc_dev; +static struct blk_desc *dev_desc; + +/* One 8 byte block of the compressed disk image */ +struct line { + size_t addr; + char *line; +}; + +/* Compressed disk image */ +struct compressed_disk_image { + size_t length; + struct line lines[]; +}; + +static const struct compressed_disk_image img = FWU_MDATA_DISK_IMG; + +/* Decompressed disk image */ +static u8 *image; + +static int setup_blk_device(struct unit_test_state *uts) +{ + ut_assertok(uclass_get_device(UCLASS_MMC, 0, &mmc_dev)); + ut_assertok(blk_get_device_by_str("mmc", "0", &dev_desc)); + + return 0; +} + +static int populate_mmc_disk_image(struct unit_test_state *uts) +{ + u8 *buf; + size_t i; + size_t addr; + size_t len; + + buf = malloc(img.length); + if (!buf) + return -ENOMEM; + + memset(buf, 0, img.length); + + for (i = 0; ; i++) { + if (!img.lines[i].line) + break; + addr = img.lines[i].addr; + len = COMPRESSED_DISK_IMAGE_BLOCK_SIZE; + if (addr + len > img.length) + len = img.length - addr; + memcpy(buf + addr, img.lines[i].line, len); + } + image = buf; + + return 0; +} + +static int write_mmc_blk_device(struct unit_test_state *uts) +{ + lbaint_t blkcnt; + + blkcnt = BLOCK_CNT(img.length, dev_desc); + + ut_asserteq(blkcnt, blk_dwrite(dev_desc, 0, blkcnt, image)); + + return 0; +} + +static int dm_test_fwu_mdata_read(struct unit_test_state *uts) +{ + struct udevice *dev; + struct fwu_mdata mdata = { 0 }; + + ut_assertok(uclass_first_device(UCLASS_FWU_MDATA, &dev)); + ut_assertok(setup_blk_device(uts)); + ut_assertok(populate_mmc_disk_image(uts)); + ut_assertok(write_mmc_blk_device(uts)); + + ut_assertok(fwu_get_mdata(dev, &mdata)); + + ut_asserteq(mdata.version, 0x1); + + return 0; +} +DM_TEST(dm_test_fwu_mdata_read, UT_TESTF_SCAN_FDT); + +static int dm_test_fwu_mdata_write(struct unit_test_state *uts) +{ + u32 active_idx; + struct udevice *dev; + struct fwu_mdata mdata = { 0 }; + + ut_assertok(setup_blk_device(uts)); + ut_assertok(populate_mmc_disk_image(uts)); + ut_assertok(write_mmc_blk_device(uts)); + + ut_assertok(uclass_first_device(UCLASS_FWU_MDATA, &dev)); + ut_assertnonnull(dev); + + ut_assertok(fwu_get_mdata(dev, &mdata)); + + active_idx = (mdata.active_index + 1) % CONFIG_FWU_NUM_BANKS; + ut_assertok(fwu_update_active_index(active_idx)); + + ut_assertok(fwu_get_mdata(dev, &mdata)); + ut_asserteq(mdata.active_index, active_idx); + + return 0; +} +DM_TEST(dm_test_fwu_mdata_write, UT_TESTF_SCAN_FDT); + +static int dm_test_fwu_mdata_check(struct unit_test_state *uts) +{ + struct udevice *dev; + + ut_assertok(setup_blk_device(uts)); + ut_assertok(populate_mmc_disk_image(uts)); + ut_assertok(write_mmc_blk_device(uts)); + + ut_assertok(uclass_first_device(UCLASS_FWU_MDATA, &dev)); + ut_assertnonnull(dev); + + ut_assertok(fwu_mdata_check(dev)); + + return 0; +} +DM_TEST(dm_test_fwu_mdata_check, UT_TESTF_SCAN_FDT); diff --git a/test/dm/fwu_mdata_disk_image.h b/test/dm/fwu_mdata_disk_image.h new file mode 100644 index 0000000000..b9803417c8 --- /dev/null +++ b/test/dm/fwu_mdata_disk_image.h @@ -0,0 +1,112 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Non-zero 8 byte strings of a disk image + * + * Generated with tools/file2include + */ + +#define FWU_MDATA_DISK_IMG { 0x00010000, { \ + {0x000001c0, "\x02\x00\xee\x02\x02\x00\x01\x00"}, /* ........ */ \ + {0x000001c8, "\x00\x00\x7f\x00\x00\x00\x00\x00"}, /* ........ */ \ + {0x000001f8, "\x00\x00\x00\x00\x00\x00\x55\xaa"}, /* ......U. */ \ + {0x00000200, "\x45\x46\x49\x20\x50\x41\x52\x54"}, /* EFI PART */ \ + {0x00000208, "\x00\x00\x01\x00\x5c\x00\x00\x00"}, /* ....... */ \ + {0x00000210, "\xa6\xf6\x92\x20\x00\x00\x00\x00"}, /* ... .... */ \ + {0x00000218, "\x01\x00\x00\x00\x00\x00\x00\x00"}, /* ........ */ \ + {0x00000220, "\x7f\x00\x00\x00\x00\x00\x00\x00"}, /* ........ */ \ + {0x00000228, "\x22\x00\x00\x00\x00\x00\x00\x00"}, /* "....... */ \ + {0x00000230, "\x5e\x00\x00\x00\x00\x00\x00\x00"}, /* ^....... */ \ + {0x00000238, "\xde\x99\xa2\x7e\x46\x34\xeb\x47"}, /* ...~F4.G */ \ + {0x00000240, "\x87\xf6\x4f\x75\xe8\xd5\x7d\xc7"}, /* ..Ou..}. */ \ + {0x00000248, "\x02\x00\x00\x00\x00\x00\x00\x00"}, /* ........ */ \ + {0x00000250, "\x80\x00\x00\x00\x80\x00\x00\x00"}, /* ........ */ \ + {0x00000258, "\x2a\x64\x03\x83\x00\x00\x00\x00"}, /* .d...... */ \ + {0x00000400, "\xa0\x84\x7a\x8a\x87\x83\xf6\x40"}, /* ..z....@ */ \ + {0x00000408, "\xab\x41\xa8\xb9\xa5\xa6\x0d\x23"}, /* .A.....# */ \ + {0x00000410, "\x3d\x6c\xb9\xaa\x20\xb2\x18\x4c"}, /* =l.. ..L */ \ + {0x00000418, "\xbc\x87\x1c\x9f\xe0\x35\x9b\x73"}, /* .....5.s */ \ + {0x00000420, "\x22\x00\x00\x00\x00\x00\x00\x00"}, /* "....... */ \ + {0x00000428, "\x31\x00\x00\x00\x00\x00\x00\x00"}, /* 1....... */ \ + {0x00000438, "\x55\x00\x6e\x00\x6b\x00\x6e\x00"}, /* U.n.k.n. */ \ + {0x00000440, "\x6f\x00\x77\x00\x6e\x00\x00\x00"}, /* o.w.n... */ \ + {0x00000480, "\xa0\x84\x7a\x8a\x87\x83\xf6\x40"}, /* ..z....@ */ \ + {0x00000488, "\xab\x41\xa8\xb9\xa5\xa6\x0d\x23"}, /* .A.....# */ \ + {0x00000490, "\x57\x24\xf6\xe6\x0b\x6f\x66\x4e"}, /* W$...ofN */ \ + {0x00000498, "\xb3\xd5\x99\x50\xa5\xc6\x4e\xc1"}, /* ...P..N. */ \ + {0x000004a0, "\x32\x00\x00\x00\x00\x00\x00\x00"}, /* 2....... */ \ + {0x000004a8, "\x41\x00\x00\x00\x00\x00\x00\x00"}, /* A....... */ \ + {0x000004b8, "\x55\x00\x6e\x00\x6b\x00\x6e\x00"}, /* U.n.k.n. */ \ + {0x000004c0, "\x6f\x00\x77\x00\x6e\x00\x00\x00"}, /* o.w.n... */ \ + {0x00004400, "\x4e\xd5\x3f\x43\x01\x00\x00\x00"}, /* N.?C.... */ \ + {0x00004408, "\x00\x00\x00\x00\x01\x00\x00\x00"}, /* ........ */ \ + {0x00004410, "\x52\xcf\xd7\x09\x20\x07\x10\x47"}, /* R... ..G */ \ + {0x00004418, "\x91\xd1\x08\x46\x9b\x7f\xe9\xc8"}, /* ...F.... */ \ + {0x00004420, "\xeb\x2b\x27\x49\xd8\x8d\xdf\x46"}, /* .+'I...F */ \ + {0x00004428, "\x8d\x75\x35\x6c\x65\xef\xf4\x17"}, /* .u5le... */ \ + {0x00004430, "\x86\x7a\x05\x10\xf1\xda\x93\x4f"}, /* .z.....O */ \ + {0x00004438, "\xba\x7f\xb1\x95\xf7\xfa\x41\x70"}, /* ......Ap */ \ + {0x00004440, "\x01\x00\x00\x00\x00\x00\x00\x00"}, /* ........ */ \ + {0x00004448, "\x3e\xed\x62\xdb\x37\x62\xb4\x4f"}, /* >.b.7b.O */ \ + {0x00004450, "\x80\xc4\x1b\x74\xd8\x46\xa8\xe7"}, /* ...t.F.. */ \ + {0x00004458, "\x01\x00\x00\x00\x00\x00\x00\x00"}, /* ........ */ \ + {0x00004460, "\xf5\x21\x70\x5a\xf2\xfe\xb4\x48"}, /* .!pZ...H */ \ + {0x00004468, "\xaa\xba\x83\x2e\x77\x74\x18\xc0"}, /* ....wt.. */ \ + {0x00004470, "\xeb\x2b\x27\x49\xd8\x8d\xdf\x46"}, /* .+'I...F */ \ + {0x00004478, "\x8d\x75\x35\x6c\x65\xef\xf4\x17"}, /* .u5le... */ \ + {0x00004480, "\x3b\x0e\xd2\x0b\x9f\xab\x86\x49"}, /* ;......I */ \ + {0x00004488, "\xb7\x90\x8d\xf3\x9c\x9c\xa3\x82"}, /* ........ */ \ + {0x00004490, "\x01\x00\x00\x00\x00\x00\x00\x00"}, /* ........ */ \ + {0x00004498, "\x6d\xe4\x25\x0e\x15\xb6\xd3\x4c"}, /* m.%....L */ \ + {0x000044a0, "\x94\xda\x51\x79\x8f\xb1\x9e\xb1"}, /* ..Qy.... */ \ + {0x000044a8, "\x01\x00\x00\x00\x00\x00\x00\x00"}, /* ........ */ \ + {0x00006400, "\x4e\xd5\x3f\x43\x01\x00\x00\x00"}, /* N.?C.... */ \ + {0x00006408, "\x00\x00\x00\x00\x01\x00\x00\x00"}, /* ........ */ \ + {0x00006410, "\x52\xcf\xd7\x09\x20\x07\x10\x47"}, /* R... ..G */ \ + {0x00006418, "\x91\xd1\x08\x46\x9b\x7f\xe9\xc8"}, /* ...F.... */ \ + {0x00006420, "\xeb\x2b\x27\x49\xd8\x8d\xdf\x46"}, /* .+'I...F */ \ + {0x00006428, "\x8d\x75\x35\x6c\x65\xef\xf4\x17"}, /* .u5le... */ \ + {0x00006430, "\x86\x7a\x05\x10\xf1\xda\x93\x4f"}, /* .z.....O */ \ + {0x00006438, "\xba\x7f\xb1\x95\xf7\xfa\x41\x70"}, /* ......Ap */ \ + {0x00006440, "\x01\x00\x00\x00\x00\x00\x00\x00"}, /* ........ */ \ + {0x00006448, "\x3e\xed\x62\xdb\x37\x62\xb4\x4f"}, /* >.b.7b.O */ \ + {0x00006450, "\x80\xc4\x1b\x74\xd8\x46\xa8\xe7"}, /* ...t.F.. */ \ + {0x00006458, "\x01\x00\x00\x00\x00\x00\x00\x00"}, /* ........ */ \ + {0x00006460, "\xf5\x21\x70\x5a\xf2\xfe\xb4\x48"}, /* .!pZ...H */ \ + {0x00006468, "\xaa\xba\x83\x2e\x77\x74\x18\xc0"}, /* ....wt.. */ \ + {0x00006470, "\xeb\x2b\x27\x49\xd8\x8d\xdf\x46"}, /* .+'I...F */ \ + {0x00006478, "\x8d\x75\x35\x6c\x65\xef\xf4\x17"}, /* .u5le... */ \ + {0x00006480, "\x3b\x0e\xd2\x0b\x9f\xab\x86\x49"}, /* ;......I */ \ + {0x00006488, "\xb7\x90\x8d\xf3\x9c\x9c\xa3\x82"}, /* ........ */ \ + {0x00006490, "\x01\x00\x00\x00\x00\x00\x00\x00"}, /* ........ */ \ + {0x00006498, "\x6d\xe4\x25\x0e\x15\xb6\xd3\x4c"}, /* m.%....L */ \ + {0x000064a0, "\x94\xda\x51\x79\x8f\xb1\x9e\xb1"}, /* ..Qy.... */ \ + {0x000064a8, "\x01\x00\x00\x00\x00\x00\x00\x00"}, /* ........ */ \ + {0x0000be00, "\xa0\x84\x7a\x8a\x87\x83\xf6\x40"}, /* ..z....@ */ \ + {0x0000be08, "\xab\x41\xa8\xb9\xa5\xa6\x0d\x23"}, /* .A.....# */ \ + {0x0000be10, "\x3d\x6c\xb9\xaa\x20\xb2\x18\x4c"}, /* =l.. ..L */ \ + {0x0000be18, "\xbc\x87\x1c\x9f\xe0\x35\x9b\x73"}, /* .....5.s */ \ + {0x0000be20, "\x22\x00\x00\x00\x00\x00\x00\x00"}, /* "....... */ \ + {0x0000be28, "\x31\x00\x00\x00\x00\x00\x00\x00"}, /* 1....... */ \ + {0x0000be38, "\x55\x00\x6e\x00\x6b\x00\x6e\x00"}, /* U.n.k.n. */ \ + {0x0000be40, "\x6f\x00\x77\x00\x6e\x00\x00\x00"}, /* o.w.n... */ \ + {0x0000be80, "\xa0\x84\x7a\x8a\x87\x83\xf6\x40"}, /* ..z....@ */ \ + {0x0000be88, "\xab\x41\xa8\xb9\xa5\xa6\x0d\x23"}, /* .A.....# */ \ + {0x0000be90, "\x57\x24\xf6\xe6\x0b\x6f\x66\x4e"}, /* W$...ofN */ \ + {0x0000be98, "\xb3\xd5\x99\x50\xa5\xc6\x4e\xc1"}, /* ...P..N. */ \ + {0x0000bea0, "\x32\x00\x00\x00\x00\x00\x00\x00"}, /* 2....... */ \ + {0x0000bea8, "\x41\x00\x00\x00\x00\x00\x00\x00"}, /* A....... */ \ + {0x0000beb8, "\x55\x00\x6e\x00\x6b\x00\x6e\x00"}, /* U.n.k.n. */ \ + {0x0000bec0, "\x6f\x00\x77\x00\x6e\x00\x00\x00"}, /* o.w.n... */ \ + {0x0000fe00, "\x45\x46\x49\x20\x50\x41\x52\x54"}, /* EFI PART */ \ + {0x0000fe08, "\x00\x00\x01\x00\x5c\x00\x00\x00"}, /* ....... */ \ + {0x0000fe10, "\xa2\xce\x23\xfc\x00\x00\x00\x00"}, /* ..#..... */ \ + {0x0000fe18, "\x7f\x00\x00\x00\x00\x00\x00\x00"}, /* ........ */ \ + {0x0000fe20, "\x01\x00\x00\x00\x00\x00\x00\x00"}, /* ........ */ \ + {0x0000fe28, "\x22\x00\x00\x00\x00\x00\x00\x00"}, /* "....... */ \ + {0x0000fe30, "\x5e\x00\x00\x00\x00\x00\x00\x00"}, /* ^....... */ \ + {0x0000fe38, "\xde\x99\xa2\x7e\x46\x34\xeb\x47"}, /* ...~F4.G */ \ + {0x0000fe40, "\x87\xf6\x4f\x75\xe8\xd5\x7d\xc7"}, /* ..Ou..}. */ \ + {0x0000fe48, "\x5f\x00\x00\x00\x00\x00\x00\x00"}, /* _....... */ \ + {0x0000fe50, "\x80\x00\x00\x00\x80\x00\x00\x00"}, /* ........ */ \ + {0x0000fe58, "\x2a\x64\x03\x83\x00\x00\x00\x00"}, /* .d...... */ \ + {0, NULL} } } diff --git a/test/py/tests/test_efi_capsule/test_capsule_firmware_fit.py b/test/py/tests/test_efi_capsule/test_capsule_firmware_fit.py index 8f75b554ad..d28b53a1a1 100644 --- a/test/py/tests/test_efi_capsule/test_capsule_firmware_fit.py +++ b/test/py/tests/test_efi_capsule/test_capsule_firmware_fit.py @@ -13,7 +13,6 @@ import pytest from capsule_defs import *
-@pytest.mark.boardspec('sandbox64') @pytest.mark.boardspec('sandbox_flattree') @pytest.mark.buildconfigspec('efi_capsule_firmware_fit') @pytest.mark.buildconfigspec('efi_capsule_on_disk') diff --git a/test/py/tests/test_efi_capsule/test_capsule_firmware_signed_fit.py b/test/py/tests/test_efi_capsule/test_capsule_firmware_signed_fit.py index d6ca9b1674..8c2d616fd0 100644 --- a/test/py/tests/test_efi_capsule/test_capsule_firmware_signed_fit.py +++ b/test/py/tests/test_efi_capsule/test_capsule_firmware_signed_fit.py @@ -14,7 +14,6 @@ with signed capsule files containing FIT images import pytest from capsule_defs import CAPSULE_DATA_DIR, CAPSULE_INSTALL_DIR
-@pytest.mark.boardspec('sandbox64') @pytest.mark.boardspec('sandbox_flattree') @pytest.mark.buildconfigspec('efi_capsule_firmware_fit') @pytest.mark.buildconfigspec('efi_capsule_authenticate') diff --git a/tools/Makefile b/tools/Makefile index 3626919633..c479d3cb4c 100644 --- a/tools/Makefile +++ b/tools/Makefile @@ -74,7 +74,7 @@ mkenvimage-objs := mkenvimage.o os_support.o lib/crc32.o hostprogs-y += dumpimage mkimage hostprogs-$(CONFIG_TOOLS_LIBCRYPTO) += fit_info fit_check_sign
-hostprogs-$(CONFIG_CMD_BOOTEFI_SELFTEST) += file2include +hostprogs-$(CONFIG_CMD_BOOTEFI_SELFTEST)$(CONFIG_FWU_MDATA_GPT_BLK) += file2include
FIT_OBJS-y := fit_common.o fit_image.o image-host.o boot/image-fit.o FIT_SIG_OBJS-$(CONFIG_TOOLS_LIBCRYPTO) := image-sig-host.o boot/image-fit-sig.o
endmenu
- default 2
- default 2
- mmc0 {
- mmc0: mmc0 { compatible = "sandbox,mmc"; };
- fwu-mdata {
return 0; }
- u32 *idx = boot_idx;
- /* Dummy value */
- *idx = 0;
- /* Don't have boot time checks on sandbox */
- if (IS_ENABLED(CONFIG_SANDBOX)) {
boottime_check = 1;
- ret = fwu_get_dev(&dev); if (ret) return ret;
- Copyright (c) 2022, Heinrich Schuchardt xypron.glpk@gmx.de
- size_t addr;
- char *line;
- size_t length;
- struct line lines[];
- ut_assertok(uclass_get_device(UCLASS_MMC, 0, &mmc_dev));
- ut_assertok(blk_get_device_by_str("mmc", "0", &dev_desc));
- u8 *buf;
- size_t i;
- size_t addr;
- size_t len;
- buf = malloc(img.length);
- if (!buf)
return -ENOMEM;
- memset(buf, 0, img.length);
- for (i = 0; ; i++) {
break;
- image = buf;
- lbaint_t blkcnt;
- blkcnt = BLOCK_CNT(img.length, dev_desc);
- ut_asserteq(blkcnt, blk_dwrite(dev_desc, 0, blkcnt, image));
- struct udevice *dev;
- struct fwu_mdata mdata = { 0 };
- ut_assertok(uclass_first_device(UCLASS_FWU_MDATA, &dev));
- ut_assertok(setup_blk_device(uts));
- ut_assertok(populate_mmc_disk_image(uts));
- ut_assertok(write_mmc_blk_device(uts));
- ut_assertok(fwu_get_mdata(dev, &mdata));
- ut_asserteq(mdata.version, 0x1);
- u32 active_idx;
- ut_assertnonnull(dev);
- active_idx = (mdata.active_index + 1) % CONFIG_FWU_NUM_BANKS;
- ut_assertok(fwu_update_active_index(active_idx));
- ut_asserteq(mdata.active_index, active_idx);
- ut_assertok(fwu_mdata_check(dev));
- Non-zero 8 byte strings of a disk image
- Generated with tools/file2include
- {0x000001c0, "\x02\x00\xee\x02\x02\x00\x01\x00"}, /* ........ */ \
- {0x000001c8, "\x00\x00\x7f\x00\x00\x00\x00\x00"}, /* ........ */ \
- {0x000001f8, "\x00\x00\x00\x00\x00\x00\x55\xaa"}, /* ......U. */ \
- {0x00000200, "\x45\x46\x49\x20\x50\x41\x52\x54"}, /* EFI PART */ \
- {0x00000208, "\x00\x00\x01\x00\x5c\x00\x00\x00"}, /* ....... */ \
- {0x00000210, "\xa6\xf6\x92\x20\x00\x00\x00\x00"}, /* ... .... */ \
- {0x00000218, "\x01\x00\x00\x00\x00\x00\x00\x00"}, /* ........ */ \
- {0x00000220, "\x7f\x00\x00\x00\x00\x00\x00\x00"}, /* ........ */ \
- {0x00000228, "\x22\x00\x00\x00\x00\x00\x00\x00"}, /* "....... */ \
- {0x00000230, "\x5e\x00\x00\x00\x00\x00\x00\x00"}, /* ^....... */ \
- {0x00000238, "\xde\x99\xa2\x7e\x46\x34\xeb\x47"}, /* ...~F4.G */ \
- {0x00000240, "\x87\xf6\x4f\x75\xe8\xd5\x7d\xc7"}, /* ..Ou..}. */ \
- {0x00000248, "\x02\x00\x00\x00\x00\x00\x00\x00"}, /* ........ */ \
- {0x00000250, "\x80\x00\x00\x00\x80\x00\x00\x00"}, /* ........ */ \
- {0x00000258, "\x2a\x64\x03\x83\x00\x00\x00\x00"}, /* .d...... */ \
- {0x00000400, "\xa0\x84\x7a\x8a\x87\x83\xf6\x40"}, /* ..z....@ */ \
- {0x00000408, "\xab\x41\xa8\xb9\xa5\xa6\x0d\x23"}, /* .A.....# */ \
- {0x00000410, "\x3d\x6c\xb9\xaa\x20\xb2\x18\x4c"}, /* =l.. ..L */ \
- {0x00000418, "\xbc\x87\x1c\x9f\xe0\x35\x9b\x73"}, /* .....5.s */ \
- {0x00000420, "\x22\x00\x00\x00\x00\x00\x00\x00"}, /* "....... */ \
- {0x00000428, "\x31\x00\x00\x00\x00\x00\x00\x00"}, /* 1....... */ \
- {0x00000438, "\x55\x00\x6e\x00\x6b\x00\x6e\x00"}, /* U.n.k.n. */ \
- {0x00000440, "\x6f\x00\x77\x00\x6e\x00\x00\x00"}, /* o.w.n... */ \
- {0x00000480, "\xa0\x84\x7a\x8a\x87\x83\xf6\x40"}, /* ..z....@ */ \
- {0x00000488, "\xab\x41\xa8\xb9\xa5\xa6\x0d\x23"}, /* .A.....# */ \
- {0x00000490, "\x57\x24\xf6\xe6\x0b\x6f\x66\x4e"}, /* W$...ofN */ \
- {0x00000498, "\xb3\xd5\x99\x50\xa5\xc6\x4e\xc1"}, /* ...P..N. */ \
- {0x000004a0, "\x32\x00\x00\x00\x00\x00\x00\x00"}, /* 2....... */ \
- {0x000004a8, "\x41\x00\x00\x00\x00\x00\x00\x00"}, /* A....... */ \
- {0x000004b8, "\x55\x00\x6e\x00\x6b\x00\x6e\x00"}, /* U.n.k.n. */ \
- {0x000004c0, "\x6f\x00\x77\x00\x6e\x00\x00\x00"}, /* o.w.n... */ \
- {0x00004400, "\x4e\xd5\x3f\x43\x01\x00\x00\x00"}, /* N.?C.... */ \
- {0x00004408, "\x00\x00\x00\x00\x01\x00\x00\x00"}, /* ........ */ \
- {0x00004410, "\x52\xcf\xd7\x09\x20\x07\x10\x47"}, /* R... ..G */ \
- {0x00004418, "\x91\xd1\x08\x46\x9b\x7f\xe9\xc8"}, /* ...F.... */ \
- {0x00004420, "\xeb\x2b\x27\x49\xd8\x8d\xdf\x46"}, /* .+'I...F */ \
- {0x00004428, "\x8d\x75\x35\x6c\x65\xef\xf4\x17"}, /* .u5le... */ \
- {0x00004430, "\x86\x7a\x05\x10\xf1\xda\x93\x4f"}, /* .z.....O */ \
- {0x00004438, "\xba\x7f\xb1\x95\xf7\xfa\x41\x70"}, /* ......Ap */ \
- {0x00004440, "\x01\x00\x00\x00\x00\x00\x00\x00"}, /* ........ */ \
- {0x00004448, "\x3e\xed\x62\xdb\x37\x62\xb4\x4f"}, /* >.b.7b.O */ \
- {0x00004450, "\x80\xc4\x1b\x74\xd8\x46\xa8\xe7"}, /* ...t.F.. */ \
- {0x00004458, "\x01\x00\x00\x00\x00\x00\x00\x00"}, /* ........ */ \
- {0x00004460, "\xf5\x21\x70\x5a\xf2\xfe\xb4\x48"}, /* .!pZ...H */ \
- {0x00004468, "\xaa\xba\x83\x2e\x77\x74\x18\xc0"}, /* ....wt.. */ \
- {0x00004470, "\xeb\x2b\x27\x49\xd8\x8d\xdf\x46"}, /* .+'I...F */ \
- {0x00004478, "\x8d\x75\x35\x6c\x65\xef\xf4\x17"}, /* .u5le... */ \
- {0x00004480, "\x3b\x0e\xd2\x0b\x9f\xab\x86\x49"}, /* ;......I */ \
- {0x00004488, "\xb7\x90\x8d\xf3\x9c\x9c\xa3\x82"}, /* ........ */ \
- {0x00004490, "\x01\x00\x00\x00\x00\x00\x00\x00"}, /* ........ */ \
- {0x00004498, "\x6d\xe4\x25\x0e\x15\xb6\xd3\x4c"}, /* m.%....L */ \
- {0x000044a0, "\x94\xda\x51\x79\x8f\xb1\x9e\xb1"}, /* ..Qy.... */ \
- {0x000044a8, "\x01\x00\x00\x00\x00\x00\x00\x00"}, /* ........ */ \
- {0x00006400, "\x4e\xd5\x3f\x43\x01\x00\x00\x00"}, /* N.?C.... */ \
- {0x00006408, "\x00\x00\x00\x00\x01\x00\x00\x00"}, /* ........ */ \
- {0x00006410, "\x52\xcf\xd7\x09\x20\x07\x10\x47"}, /* R... ..G */ \
- {0x00006418, "\x91\xd1\x08\x46\x9b\x7f\xe9\xc8"}, /* ...F.... */ \
- {0x00006420, "\xeb\x2b\x27\x49\xd8\x8d\xdf\x46"}, /* .+'I...F */ \
- {0x00006428, "\x8d\x75\x35\x6c\x65\xef\xf4\x17"}, /* .u5le... */ \
- {0x00006430, "\x86\x7a\x05\x10\xf1\xda\x93\x4f"}, /* .z.....O */ \
- {0x00006438, "\xba\x7f\xb1\x95\xf7\xfa\x41\x70"}, /* ......Ap */ \
- {0x00006440, "\x01\x00\x00\x00\x00\x00\x00\x00"}, /* ........ */ \
- {0x00006448, "\x3e\xed\x62\xdb\x37\x62\xb4\x4f"}, /* >.b.7b.O */ \
- {0x00006450, "\x80\xc4\x1b\x74\xd8\x46\xa8\xe7"}, /* ...t.F.. */ \
- {0x00006458, "\x01\x00\x00\x00\x00\x00\x00\x00"}, /* ........ */ \
- {0x00006460, "\xf5\x21\x70\x5a\xf2\xfe\xb4\x48"}, /* .!pZ...H */ \
- {0x00006468, "\xaa\xba\x83\x2e\x77\x74\x18\xc0"}, /* ....wt.. */ \
- {0x00006470, "\xeb\x2b\x27\x49\xd8\x8d\xdf\x46"}, /* .+'I...F */ \
- {0x00006478, "\x8d\x75\x35\x6c\x65\xef\xf4\x17"}, /* .u5le... */ \
- {0x00006480, "\x3b\x0e\xd2\x0b\x9f\xab\x86\x49"}, /* ;......I */ \
- {0x00006488, "\xb7\x90\x8d\xf3\x9c\x9c\xa3\x82"}, /* ........ */ \
- {0x00006490, "\x01\x00\x00\x00\x00\x00\x00\x00"}, /* ........ */ \
- {0x00006498, "\x6d\xe4\x25\x0e\x15\xb6\xd3\x4c"}, /* m.%....L */ \
- {0x000064a0, "\x94\xda\x51\x79\x8f\xb1\x9e\xb1"}, /* ..Qy.... */ \
- {0x000064a8, "\x01\x00\x00\x00\x00\x00\x00\x00"}, /* ........ */ \
- {0x0000be00, "\xa0\x84\x7a\x8a\x87\x83\xf6\x40"}, /* ..z....@ */ \
- {0x0000be08, "\xab\x41\xa8\xb9\xa5\xa6\x0d\x23"}, /* .A.....# */ \
- {0x0000be10, "\x3d\x6c\xb9\xaa\x20\xb2\x18\x4c"}, /* =l.. ..L */ \
- {0x0000be18, "\xbc\x87\x1c\x9f\xe0\x35\x9b\x73"}, /* .....5.s */ \
- {0x0000be20, "\x22\x00\x00\x00\x00\x00\x00\x00"}, /* "....... */ \
- {0x0000be28, "\x31\x00\x00\x00\x00\x00\x00\x00"}, /* 1....... */ \
- {0x0000be38, "\x55\x00\x6e\x00\x6b\x00\x6e\x00"}, /* U.n.k.n. */ \
- {0x0000be40, "\x6f\x00\x77\x00\x6e\x00\x00\x00"}, /* o.w.n... */ \
- {0x0000be80, "\xa0\x84\x7a\x8a\x87\x83\xf6\x40"}, /* ..z....@ */ \
- {0x0000be88, "\xab\x41\xa8\xb9\xa5\xa6\x0d\x23"}, /* .A.....# */ \
- {0x0000be90, "\x57\x24\xf6\xe6\x0b\x6f\x66\x4e"}, /* W$...ofN */ \
- {0x0000be98, "\xb3\xd5\x99\x50\xa5\xc6\x4e\xc1"}, /* ...P..N. */ \
- {0x0000bea0, "\x32\x00\x00\x00\x00\x00\x00\x00"}, /* 2....... */ \
- {0x0000bea8, "\x41\x00\x00\x00\x00\x00\x00\x00"}, /* A....... */ \
- {0x0000beb8, "\x55\x00\x6e\x00\x6b\x00\x6e\x00"}, /* U.n.k.n. */ \
- {0x0000bec0, "\x6f\x00\x77\x00\x6e\x00\x00\x00"}, /* o.w.n... */ \
- {0x0000fe00, "\x45\x46\x49\x20\x50\x41\x52\x54"}, /* EFI PART */ \
- {0x0000fe08, "\x00\x00\x01\x00\x5c\x00\x00\x00"}, /* ....... */ \
- {0x0000fe10, "\xa2\xce\x23\xfc\x00\x00\x00\x00"}, /* ..#..... */ \
- {0x0000fe18, "\x7f\x00\x00\x00\x00\x00\x00\x00"}, /* ........ */ \
- {0x0000fe20, "\x01\x00\x00\x00\x00\x00\x00\x00"}, /* ........ */ \
- {0x0000fe28, "\x22\x00\x00\x00\x00\x00\x00\x00"}, /* "....... */ \
- {0x0000fe30, "\x5e\x00\x00\x00\x00\x00\x00\x00"}, /* ^....... */ \
- {0x0000fe38, "\xde\x99\xa2\x7e\x46\x34\xeb\x47"}, /* ...~F4.G */ \
- {0x0000fe40, "\x87\xf6\x4f\x75\xe8\xd5\x7d\xc7"}, /* ..Ou..}. */ \
- {0x0000fe48, "\x5f\x00\x00\x00\x00\x00\x00\x00"}, /* _....... */ \
- {0x0000fe50, "\x80\x00\x00\x00\x80\x00\x00\x00"}, /* ........ */ \
- {0x0000fe58, "\x2a\x64\x03\x83\x00\x00\x00\x00"}, /* .d...... */ \
- {0, NULL} } }
FIT_OBJS-y := fit_common.o fit_image.o image-host.o boot/image-fit.o FIT_SIG_OBJS-$(CONFIG_TOOLS_LIBCRYPTO) := image-sig-host.o boot/image-fit-sig.o -- 2.34.1
Acked-by: Ilias Apalodimas ilias.apalodimas@linaro.org
The Dependable Boot specification[1] describes the structure of the firmware accept and revert capsules. These are empty capsules which are used for signalling the acceptance or rejection of the updated firmware by the OS. Add support for generating these empty capsules.
[1] - https://git.codelinaro.org/linaro/dependable-boot/mbfw/uploads/6f7ddfe3be24e...
Signed-off-by: Sughosh Ganu sughosh.ganu@linaro.org --- Changes since V8: None
doc/mkeficapsule.1 | 29 +++++++++---- tools/eficapsule.h | 8 ++++ tools/mkeficapsule.c | 96 ++++++++++++++++++++++++++++++++++++++++---- 3 files changed, 119 insertions(+), 14 deletions(-)
diff --git a/doc/mkeficapsule.1 b/doc/mkeficapsule.1 index 09bdc24295..77ca061efd 100644 --- a/doc/mkeficapsule.1 +++ b/doc/mkeficapsule.1 @@ -8,7 +8,7 @@ mkeficapsule - Generate EFI capsule file for U-Boot
.SH SYNOPSIS .B mkeficapsule -.RI [ options "] " image-blob " " capsule-file +.RI [ options ] " " [ image-blob ] " " capsule-file
.SH "DESCRIPTION" .B mkeficapsule @@ -23,8 +23,13 @@ Optionally, a capsule file can be signed with a given private key. In this case, the update will be authenticated by verifying the signature before applying.
+Additionally, an empty capsule file can be generated for acceptance or +rejection of firmware images by a governing component like an Operating +System. The empty capsules do not require an image-blob input file. + + .B mkeficapsule -takes any type of image files, including: +takes any type of image files when generating non empty capsules, including: .TP .I raw image format is a single binary blob of any type of firmware. @@ -36,18 +41,16 @@ multiple binary blobs in a single capsule file. This type of image file can be generated by .BR mkimage .
-.PP -If you want to use other types than above two, you should explicitly -specify a guid for the FMP driver. - .SH "OPTIONS" + .TP .BI "-g\fR,\fB --guid " guid-string Specify guid for image blob type. The format is: xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx
The first three elements are in little endian, while the rest -is in big endian. +is in big endian. The option must be specified for all non empty and +image acceptance capsules
.TP .BI "-i\fR,\fB --index " index @@ -57,6 +60,18 @@ Specify an image index .BI "-I\fR,\fB --instance " instance Specify a hardware instance
+.PP +For generation of firmware accept empty capsule +.BR --guid +is mandatory +.TP +.BI "-A\fR,\fB --fw-accept " +Generate a firmware acceptance empty capsule + +.TP +.BI "-R\fR,\fB --fw-revert " +Generate a firmware revert empty capsule + .TP .BR -h ", " --help Print a help message diff --git a/tools/eficapsule.h b/tools/eficapsule.h index d63b831443..072a4b5598 100644 --- a/tools/eficapsule.h +++ b/tools/eficapsule.h @@ -41,6 +41,14 @@ typedef struct { EFI_GUID(0x4aafd29d, 0x68df, 0x49ee, 0x8a, 0xa9, \ 0x34, 0x7d, 0x37, 0x56, 0x65, 0xa7)
+#define FW_ACCEPT_OS_GUID \ + EFI_GUID(0x0c996046, 0xbcc0, 0x4d04, 0x85, 0xec, \ + 0xe1, 0xfc, 0xed, 0xf1, 0xc6, 0xf8) + +#define FW_REVERT_OS_GUID \ + EFI_GUID(0xacd58b4b, 0xc0e8, 0x475f, 0x99, 0xb5, \ + 0x6b, 0x3f, 0x7e, 0x07, 0xaa, 0xf0) + /* flags */ #define CAPSULE_FLAGS_PERSIST_ACROSS_RESET 0x00010000
diff --git a/tools/mkeficapsule.c b/tools/mkeficapsule.c index 5f74d23b9e..25bfb39e5b 100644 --- a/tools/mkeficapsule.c +++ b/tools/mkeficapsule.c @@ -29,7 +29,13 @@ static const char *tool_name = "mkeficapsule"; efi_guid_t efi_guid_fm_capsule = EFI_FIRMWARE_MANAGEMENT_CAPSULE_ID_GUID; efi_guid_t efi_guid_cert_type_pkcs7 = EFI_CERT_TYPE_PKCS7_GUID;
-static const char *opts_short = "g:i:I:v:p:c:m:dh"; +static const char *opts_short = "g:i:I:v:p:c:m:dhAR"; + +enum { + CAPSULE_NORMAL_BLOB = 0, + CAPSULE_ACCEPT, + CAPSULE_REVERT, +} capsule_type;
static struct option options[] = { {"guid", required_argument, NULL, 'g'}, @@ -39,6 +45,8 @@ static struct option options[] = { {"certificate", required_argument, NULL, 'c'}, {"monotonic-count", required_argument, NULL, 'm'}, {"dump-sig", no_argument, NULL, 'd'}, + {"fw-accept", no_argument, NULL, 'A'}, + {"fw-revert", no_argument, NULL, 'R'}, {"help", no_argument, NULL, 'h'}, {NULL, 0, NULL, 0}, }; @@ -55,6 +63,8 @@ static void print_usage(void) "\t-c, --certificate <cert file> signer's certificate file\n" "\t-m, --monotonic-count <count> monotonic count\n" "\t-d, --dump_sig dump signature (*.p7)\n" + "\t-A, --fw-accept firmware accept capsule, requires GUID, no image blob\n" + "\t-R, --fw-revert firmware revert capsule, takes no GUID, no image blob\n" "\t-h, --help print a help message\n", tool_name); } @@ -564,6 +574,49 @@ void convert_uuid_to_guid(unsigned char *buf) buf[7] = c; }
+static int create_empty_capsule(char *path, efi_guid_t *guid, bool fw_accept) +{ + struct efi_capsule_header header = { 0 }; + FILE *f = NULL; + int ret = -1; + efi_guid_t fw_accept_guid = FW_ACCEPT_OS_GUID; + efi_guid_t fw_revert_guid = FW_REVERT_OS_GUID; + efi_guid_t capsule_guid; + + f = fopen(path, "w"); + if (!f) { + fprintf(stderr, "cannot open %s\n", path); + goto err; + } + + capsule_guid = fw_accept ? fw_accept_guid : fw_revert_guid; + + memcpy(&header.capsule_guid, &capsule_guid, sizeof(efi_guid_t)); + header.header_size = sizeof(header); + header.flags = 0; + + header.capsule_image_size = fw_accept ? + sizeof(header) + sizeof(efi_guid_t) : sizeof(header); + + if (write_capsule_file(f, &header, sizeof(header), + "Capsule header")) + goto err; + + if (fw_accept) { + if (write_capsule_file(f, guid, sizeof(*guid), + "FW Accept Capsule Payload")) + goto err; + } + + ret = 0; + +err: + if (f) + fclose(f); + + return ret; +} + /** * main - main entry function of mkeficapsule * @argc: Number of arguments @@ -592,6 +645,7 @@ int main(int argc, char **argv) privkey_file = NULL; cert_file = NULL; dump_sig = 0; + capsule_type = CAPSULE_NORMAL_BLOB; for (;;) { c = getopt_long(argc, argv, opts_short, options, &idx); if (c == -1) @@ -639,22 +693,50 @@ int main(int argc, char **argv) case 'd': dump_sig = 1; break; - case 'h': + case 'A': + if (capsule_type) { + fprintf(stderr, + "Select either of Accept or Revert capsule generation\n"); + exit(1); + } + capsule_type = CAPSULE_ACCEPT; + break; + case 'R': + if (capsule_type) { + fprintf(stderr, + "Select either of Accept or Revert capsule generation\n"); + exit(1); + } + capsule_type = CAPSULE_REVERT; + break; + default: print_usage(); exit(EXIT_SUCCESS); } }
/* check necessary parameters */ - if ((argc != optind + 2) || !guid || - ((privkey_file && !cert_file) || - (!privkey_file && cert_file))) { + if ((capsule_type == CAPSULE_NORMAL_BLOB && + ((argc != optind + 2) || !guid || + ((privkey_file && !cert_file) || + (!privkey_file && cert_file)))) || + (capsule_type != CAPSULE_NORMAL_BLOB && + ((argc != optind + 1) || + ((capsule_type == CAPSULE_ACCEPT) && !guid) || + ((capsule_type == CAPSULE_REVERT) && guid)))) { print_usage(); exit(EXIT_FAILURE); }
- if (create_fwbin(argv[argc - 1], argv[argc - 2], guid, index, instance, - mcount, privkey_file, cert_file) < 0) { + if (capsule_type != CAPSULE_NORMAL_BLOB) { + if (create_empty_capsule(argv[argc - 1], guid, + capsule_type == CAPSULE_ACCEPT) < 0) { + fprintf(stderr, "Creating empty capsule failed\n"); + exit(EXIT_FAILURE); + } + } else if (create_fwbin(argv[argc - 1], argv[argc - 2], guid, + index, instance, mcount, privkey_file, + cert_file) < 0) { fprintf(stderr, "Creating firmware capsule failed\n"); exit(EXIT_FAILURE); }
.SH "OPTIONS"
+enum {
- CAPSULE_NORMAL_BLOB = 0,
- CAPSULE_ACCEPT,
- CAPSULE_REVERT,
+} capsule_type;
- {"fw-accept", no_argument, NULL, 'A'},
- {"fw-revert", no_argument, NULL, 'R'}, {"help", no_argument, NULL, 'h'}, {NULL, 0, NULL, 0},
"\t-h, --help print a help message\n", tool_name);"\t-R, --fw-revert firmware revert capsule, takes no GUID, no image blob\n"
- struct efi_capsule_header header = { 0 };
- FILE *f = NULL;
- int ret = -1;
- efi_guid_t fw_accept_guid = FW_ACCEPT_OS_GUID;
- efi_guid_t fw_revert_guid = FW_REVERT_OS_GUID;
- efi_guid_t capsule_guid;
- f = fopen(path, "w");
- if (!f) {
goto err;
- capsule_guid = fw_accept ? fw_accept_guid : fw_revert_guid;
- memcpy(&header.capsule_guid, &capsule_guid, sizeof(efi_guid_t));
- header.header_size = sizeof(header);
- header.flags = 0;
- header.capsule_image_size = fw_accept ?
- if (write_capsule_file(f, &header, sizeof(header),
"Capsule header"))
goto err;
- if (fw_accept) {
goto err;
- ret = 0;
+err:
- if (f)
fclose(f);
- return ret;
- main - main entry function of mkeficapsule
- @argc: Number of arguments
- capsule_type = CAPSULE_NORMAL_BLOB; for (;;) { c = getopt_long(argc, argv, opts_short, options, &idx); if (c == -1)
case 'h':
case 'A':
if (capsule_type) {
fprintf(stderr,
exit(1);
break;
case 'R':
if (capsule_type) {
fprintf(stderr,
exit(1);
break;
- if ((capsule_type == CAPSULE_NORMAL_BLOB &&
print_usage(); exit(EXIT_FAILURE); }((capsule_type == CAPSULE_REVERT) && guid)))) {
- if (capsule_type != CAPSULE_NORMAL_BLOB) {
exit(EXIT_FAILURE);
- } else if (create_fwbin(argv[argc - 1], argv[argc - 2], guid,
fprintf(stderr, "Creating firmware capsule failed\n"); exit(EXIT_FAILURE); }cert_file) < 0) {
-- 2.34.1
Add support for setting OEM flags in the capsule header. As per the UEFI specification, bits 0-15 of the flags member of the capsule header can be defined per capsule GUID.
The oemflags will be used for the FWU Multi Bank update feature, as specified by the Dependable Boot specification[1]. Bit 15 of the flags member will be used to determine if the acceptance/rejection of the updated images is to be done by the firmware or an external component like the OS.
doc/mkeficapsule.1 | 4 ++++ tools/mkeficapsule.c | 17 ++++++++++++++--- 2 files changed, 18 insertions(+), 3 deletions(-)
diff --git a/doc/mkeficapsule.1 b/doc/mkeficapsule.1 index 77ca061efd..6fb2dd0810 100644 --- a/doc/mkeficapsule.1 +++ b/doc/mkeficapsule.1 @@ -72,6 +72,10 @@ Generate a firmware acceptance empty capsule .BI "-R\fR,\fB --fw-revert " Generate a firmware revert empty capsule
+.TP +.BI "-o\fR,\fB --capoemflag " +Capsule OEM flag, value between 0x0000 to 0xffff + .TP .BR -h ", " --help Print a help message diff --git a/tools/mkeficapsule.c b/tools/mkeficapsule.c index 25bfb39e5b..b24f873b48 100644 --- a/tools/mkeficapsule.c +++ b/tools/mkeficapsule.c @@ -29,7 +29,7 @@ static const char *tool_name = "mkeficapsule"; efi_guid_t efi_guid_fm_capsule = EFI_FIRMWARE_MANAGEMENT_CAPSULE_ID_GUID; efi_guid_t efi_guid_cert_type_pkcs7 = EFI_CERT_TYPE_PKCS7_GUID;
-static const char *opts_short = "g:i:I:v:p:c:m:dhAR"; +static const char *opts_short = "g:i:I:v:p:c:m:o:dhAR";
enum { CAPSULE_NORMAL_BLOB = 0, @@ -47,6 +47,7 @@ static struct option options[] = { {"dump-sig", no_argument, NULL, 'd'}, {"fw-accept", no_argument, NULL, 'A'}, {"fw-revert", no_argument, NULL, 'R'}, + {"capoemflag", required_argument, NULL, 'o'}, {"help", no_argument, NULL, 'h'}, {NULL, 0, NULL, 0}, }; @@ -65,6 +66,7 @@ static void print_usage(void) "\t-d, --dump_sig dump signature (*.p7)\n" "\t-A, --fw-accept firmware accept capsule, requires GUID, no image blob\n" "\t-R, --fw-revert firmware revert capsule, takes no GUID, no image blob\n" + "\t-o, --capoemflag Capsule OEM Flag, an integer between 0x0000 and 0xffff\n" "\t-h, --help print a help message\n", tool_name); } @@ -387,6 +389,7 @@ static void free_sig_data(struct auth_context *ctx) * @mcount: Monotonic count in authentication information * @private_file: Path to a private key file * @cert_file: Path to a certificate file + * @oemflags: Capsule OEM Flags, bits 0-15 * * This function actually does the job of creating an uefi capsule file. * All the arguments must be supplied. @@ -399,7 +402,8 @@ static void free_sig_data(struct auth_context *ctx) */ static int create_fwbin(char *path, char *bin, efi_guid_t *guid, unsigned long index, unsigned long instance, - uint64_t mcount, char *privkey_file, char *cert_file) + uint64_t mcount, char *privkey_file, char *cert_file, + uint16_t oemflags) { struct efi_capsule_header header; struct efi_firmware_management_capsule_header capsule; @@ -464,6 +468,8 @@ static int create_fwbin(char *path, char *bin, efi_guid_t *guid, header.header_size = sizeof(header); /* TODO: The current implementation ignores flags */ header.flags = CAPSULE_FLAGS_PERSIST_ACROSS_RESET; + if (oemflags) + header.flags |= oemflags; header.capsule_image_size = sizeof(header) + sizeof(capsule) + sizeof(uint64_t) + sizeof(image) @@ -635,6 +641,7 @@ int main(int argc, char **argv) unsigned char uuid_buf[16]; unsigned long index, instance; uint64_t mcount; + uint16_t oemflags; char *privkey_file, *cert_file; int c, idx;
@@ -646,6 +653,7 @@ int main(int argc, char **argv) cert_file = NULL; dump_sig = 0; capsule_type = CAPSULE_NORMAL_BLOB; + oemflags = 0; for (;;) { c = getopt_long(argc, argv, opts_short, options, &idx); if (c == -1) @@ -709,6 +717,9 @@ int main(int argc, char **argv) } capsule_type = CAPSULE_REVERT; break; + case 'o': + oemflags = strtoul(optarg, NULL, 0); + break; default: print_usage(); exit(EXIT_SUCCESS); @@ -736,7 +747,7 @@ int main(int argc, char **argv) } } else if (create_fwbin(argv[argc - 1], argv[argc - 2], guid, index, instance, mcount, privkey_file, - cert_file) < 0) { + cert_file, oemflags) < 0) { fprintf(stderr, "Creating firmware capsule failed\n"); exit(EXIT_FAILURE); }
Add documentation for the FWU Multi Bank Update feature. The document describes the steps needed for setting up the platform for the feature, as well as steps for enabling the feature on the platform.
Signed-off-by: Sughosh Ganu sughosh.ganu@linaro.org Reviewed-by: Ilias Apalodimas ilias.apalodimas@linaro.org Reviewed-by: Simon Glass sjg@chromium.org --- Changes since V8: * Fixed spelling mistake in the commit message
doc/develop/uefi/fwu_updates.rst | 165 +++++++++++++++++++++++++++++++ doc/develop/uefi/index.rst | 1 + doc/develop/uefi/uefi.rst | 2 + 3 files changed, 168 insertions(+) create mode 100644 doc/develop/uefi/fwu_updates.rst
diff --git a/doc/develop/uefi/fwu_updates.rst b/doc/develop/uefi/fwu_updates.rst new file mode 100644 index 0000000000..fad3fbb3a8 --- /dev/null +++ b/doc/develop/uefi/fwu_updates.rst @@ -0,0 +1,165 @@ +.. SPDX-License-Identifier: GPL-2.0+ +.. Copyright (c) 2022 Linaro Limited + +FWU Multi Bank Updates in U-Boot +================================ + +The FWU Multi Bank Update feature implements the firmware update +mechanism described in the PSA Firmware Update for A-profile Arm +Architecture specification [1]. Certain aspects of the Dependable +Boot specification [2] are also implemented. The feature provides a +mechanism to have multiple banks of updatable firmware images and for +updating the firmware images on the non-booted bank. On a successful +update, the platform boots from the updated bank on subsequent +boot. The UEFI capsule-on-disk update feature is used for performing +the actual updates of the updatable firmware images. + +The bookkeeping of the updatable images is done through a structure +called metadata. Currently, the FWU metadata supports identification +of images based on image GUIDs stored on a GPT partitioned storage +media. There are plans to extend the metadata structure for non GPT +partitioned devices as well. + +Accessing the FWU metadata is done through generic API's which are +defined in a driver which complies with the U-Boot's driver model. A +new uclass UCLASS_FWU_MDATA has been added for accessing the FWU +metadata. Individual drivers can be added based on the type of storage +media, and it's partitioning method. Details of the storage device +containing the FWU metadata partitions are specified through a U-Boot +specific device tree property `fwu-mdata-store`. Please refer to +U-Boot `doc <doc/device-tree-bindings/firmware/fwu-mdata-gpt.yaml>`__ +for the device tree bindings. + +Enabling the FWU Multi Bank Update feature +------------------------------------------ + +The feature can be enabled by specifying the following configs:: + + CONFIG_EFI_CAPSULE_ON_DISK=y + CONFIG_EFI_CAPSULE_FIRMWARE_MANAGEMENT=y + CONFIG_EFI_CAPSULE_FIRMWARE=y + CONFIG_EFI_CAPSULE_FIRMWARE_RAW=y + + CONFIG_FWU_MULTI_BANK_UPDATE=y + CONFIG_CMD_FWU_METADATA=y + CONFIG_DM_FWU_MDATA=y + CONFIG_FWU_MDATA_GPT_BLK=y + CONFIG_FWU_NUM_BANKS=<val> + CONFIG_FWU_NUM_IMAGES_PER_BANK=<val> + +in the .config file + +The first group of configuration settings enable the UEFI +capsule-on-disk update functionality. The second group of configs +enable the FWU Multi Bank Update functionality. Please refer to the +section :ref:`uefi_capsule_update_ref` for more details on generation +of the UEFI capsule. + +Setting up the device for GPT partitioned storage +------------------------------------------------- + +Before enabling the functionality in U-Boot, a GPT partitioned storage +device is required. Assuming a GPT partitioned storage device, the +storage media needs to be partitioned with the correct number of +partitions, given the number of banks and number of images per bank +that the platform is going to support. Each updatable firmware image +will be stored on an separate partition. In addition, the two copies +of the FWU metadata will be stored on two separate partitions. + +As an example, a platform supporting two banks with each bank +containing three images would need to have 2 * 3 = 6 partitions plus +the two metadata partitions, or 8 partitions. In addition the storage +media can have additional partitions of non-updatable images, like the +EFI System Partition(ESP), a partition for the root file system +etc. An example list of images on the storage medium would be + +* FWU metadata 1 +* U-Boot 1 +* OP-TEE 1 +* FWU metadata 2 +* OP-TEE 2 +* U-Boot 2 +* ESP +* rootfs + +When generating the partitions, a few aspects need to be taken care +of. Each GPT partition entry in the GPT header has two GUIDs:: + +* PartitionTypeGUID +* UniquePartitionGUID + +The PartitionTypeGUID value should correspond to the +``image_type_uuid`` field of the FWU metadata. This field is used to +identify a given type of updatable firmware image, e.g. U-Boot, +OP-TEE, FIP etc. This GUID should also be used for specifying the +`--guid` parameter when generating the capsule. + +The UniquePartitionGUID value should correspond to the ``image_uuid`` +field in the FWU metadata. This GUID is used to identify images of a +given image type in different banks. + +Similarly, the FWU specifications defines the GUID value to be used +for the metadata partitions. This would be the PartitionTypeGUID for +the metadata partitions. + +When generating the metadata, the ``image_type_uuid`` and the +``image_uuid`` values should match the *PartitionTypeGUID* and the +*UniquePartitionGUID* values respectively. + +Performing the Update +--------------------- + +Once the storage media has been partitioned and populated with the +metadata partitions, the UEFI capsule-on-disk update functionality can +be used for performing the update. Refer to the section +:ref:`uefi_capsule_update_ref` for details on how the update can be +invoked. + +On a successful update, the FWU metadata gets updated to reflect the +bank from which the platform would be booting on subsequent boot. + +Based on the value of bit15 of the Flags member of the capsule header, +the updated images would either be accepted by the U-Boot's UEFI +implementation, or by the Operating System. If the Operating System is +accepting the firmware images, it does so by generating an empty +*accept* capsule. The Operating System can also reject the updated +firmware by generating a *revert* capsule. The empty capsule can be +applied by using the exact same procedure used for performing the +capsule-on-disk update. + +The task of accepting the different firmware images, post an update +may be done by multiple, separate components in the Operating +System. To help identify the firmware image that is being accepted, +the accept capsule passes the image GUID of the firmware image being +accepted. The relevant code in U-Boot then sets the Accept bit of the +corresponding firmware image for which the accept capsule was +found. Only when all the firmware components in a bank have been +accepted does the platform transition to the regular state from trial +state. + +The revert capsule on the other hand does not pass any image GUID, +since reverting any image of the bank has the same result of the +platform booting from the other bank on subsequent boot. + +Generating an empty capsule +--------------------------- + +The empty capsule can be generated using the mkeficapsule utility. To +build the tool, enable:: + + CONFIG_TOOLS_MKEFICAPSULE=y + +Run the following commands to generate the accept/revert capsules:: + +.. code-block:: bash + + $ ./tools/mkeficapsule \ + [--fw-accept --guid <image guid>] | \ + [--fw-revert] \ + <capsule_file_name> + +Links +----- + +* [1] https://developer.arm.com/documentation/den0118/a/ - FWU Specification +* [2] https://git.codelinaro.org/linaro/dependable-boot/mbfw/uploads/6f7ddfe3be24e... - Dependable Boot Specification diff --git a/doc/develop/uefi/index.rst b/doc/develop/uefi/index.rst index 7e65dbc5d5..e26b1fbe05 100644 --- a/doc/develop/uefi/index.rst +++ b/doc/develop/uefi/index.rst @@ -13,3 +13,4 @@ can be run an UEFI payload. uefi.rst u-boot_on_efi.rst iscsi.rst + fwu_updates.rst diff --git a/doc/develop/uefi/uefi.rst b/doc/develop/uefi/uefi.rst index 941e427093..536b278dd9 100644 --- a/doc/develop/uefi/uefi.rst +++ b/doc/develop/uefi/uefi.rst @@ -277,6 +277,8 @@ Enable ``CONFIG_OPTEE``, ``CONFIG_CMD_OPTEE_RPMB`` and ``CONFIG_EFI_MM_COMM_TEE`
[1] https://optee.readthedocs.io/en/latest/building/efi_vars/stmm.html
+.. _uefi_capsule_update_ref: + Enabling UEFI Capsule Update feature ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
participants (5)
Etienne Carriere
Ilias Apalodimas
Sughosh Ganu
Takahiro Akashi
