[PATCH v3 0/4] fs/squashfs: Add new decompression algorithms
Hello,
Following the SquashFS support, this series adds support for LZO and ZSTD algorithms.
Changes in v3: - Reorganize patches order. - Remove memory leak from sqfs_zstd_decompress(). Changes in v2: - Change tests architecture. - Add tests for LZO and ZSTD. - Skip compression algorithms unsupported by the host's squashfs-tools version. - Add sqfs_decompress_init() and sqfs_decompress_cleanup() to SquashFS support.
Joao Marcos Costa (4): fs/squashfs: Add init. and clean-up functions to decompression fs/squashfs: add support for ZSTD decompression fs/squashfs: add support for LZO decompression test/py: Add tests for LZO and ZSTD
fs/squashfs/sqfs.c | 87 ++++++++------- fs/squashfs/sqfs_decompressor.c | 103 +++++++++++++++++- fs/squashfs/sqfs_decompressor.h | 3 + fs/squashfs/sqfs_filesystem.h | 12 +- .../test_fs/test_squashfs/sqfs_common.py | 76 +++++++++---- .../test_fs/test_squashfs/test_sqfs_load.py | 40 ++++--- .../test_fs/test_squashfs/test_sqfs_ls.py | 33 ++++-- 7 files changed, 261 insertions(+), 93 deletions(-)
Add sqfs_decompressor_init() and sqfs_decompressor_cleanup(). These functions are called respectively in sqfs_probe() and sqfs_close(). For now, only ZSTD requires an initialization logic. ZSTD support will be added in a follow-up commit.
Move squashfs_ctxt definition to sqfs_filesystem.h. This structure is passed to sqfs_decompressor_init() and sqfs_decompressor_cleanup(), so it can no longer be local to sqfs.c.
Signed-off-by: Joao Marcos Costa joaomarcos.costa@bootlin.com --- Changes in v3: - Remove memory leak from sqfs_zstd_decompress() - Rename structure in sqfs.c and remove the 'static' so it can be exported to sqfs_decompressor.c Changes in v2: - This patch was not present in the previous version. fs/squashfs/sqfs.c | 87 +++++++++++++++++---------------- fs/squashfs/sqfs_decompressor.c | 36 ++++++++++++-- fs/squashfs/sqfs_decompressor.h | 3 ++ fs/squashfs/sqfs_filesystem.h | 9 +++- 4 files changed, 89 insertions(+), 46 deletions(-)
diff --git a/fs/squashfs/sqfs.c b/fs/squashfs/sqfs.c index 340e5ebdb9..2836b3de8b 100644 --- a/fs/squashfs/sqfs.c +++ b/fs/squashfs/sqfs.c @@ -23,22 +23,16 @@ #include "sqfs_filesystem.h" #include "sqfs_utils.h"
-struct squashfs_ctxt { - struct disk_partition cur_part_info; - struct blk_desc *cur_dev; - struct squashfs_super_block *sblk; -}; - -static struct squashfs_ctxt ctxt; +struct squashfs_ctxt sqfs_ctxt;
static int sqfs_disk_read(__u32 block, __u32 nr_blocks, void *buf) { ulong ret;
- if (!ctxt.cur_dev) + if (!sqfs_ctxt.cur_dev) return -1;
- ret = blk_dread(ctxt.cur_dev, ctxt.cur_part_info.start + block, + ret = blk_dread(sqfs_ctxt.cur_dev, sqfs_ctxt.cur_part_info.start + block, nr_blocks, buf);
if (ret != nr_blocks) @@ -49,7 +43,7 @@ static int sqfs_disk_read(__u32 block, __u32 nr_blocks, void *buf)
static int sqfs_read_sblk(struct squashfs_super_block **sblk) { - *sblk = malloc_cache_aligned(ctxt.cur_dev->blksz); + *sblk = malloc_cache_aligned(sqfs_ctxt.cur_dev->blksz); if (!*sblk) return -ENOMEM;
@@ -91,10 +85,10 @@ static int sqfs_calc_n_blks(__le64 start, __le64 end, u64 *offset) u64 start_, table_size;
table_size = le64_to_cpu(end) - le64_to_cpu(start); - start_ = le64_to_cpu(start) / ctxt.cur_dev->blksz; - *offset = le64_to_cpu(start) - (start_ * ctxt.cur_dev->blksz); + start_ = le64_to_cpu(start) / sqfs_ctxt.cur_dev->blksz; + *offset = le64_to_cpu(start) - (start_ * sqfs_ctxt.cur_dev->blksz);
- return DIV_ROUND_UP(table_size + *offset, ctxt.cur_dev->blksz); + return DIV_ROUND_UP(table_size + *offset, sqfs_ctxt.cur_dev->blksz); }
/* @@ -107,7 +101,7 @@ static int sqfs_frag_lookup(u32 inode_fragment_index, u64 start, n_blks, src_len, table_offset, start_block; unsigned char *metadata_buffer, *metadata, *table; struct squashfs_fragment_block_entry *entries; - struct squashfs_super_block *sblk = ctxt.sblk; + struct squashfs_super_block *sblk = sqfs_ctxt.sblk; unsigned long dest_len; int block, offset, ret; u16 header, comp_type; @@ -118,13 +112,13 @@ static int sqfs_frag_lookup(u32 inode_fragment_index, return -EINVAL;
start = get_unaligned_le64(&sblk->fragment_table_start) / - ctxt.cur_dev->blksz; + sqfs_ctxt.cur_dev->blksz; n_blks = sqfs_calc_n_blks(sblk->fragment_table_start, sblk->export_table_start, &table_offset);
/* Allocate a proper sized buffer to store the fragment index table */ - table = malloc_cache_aligned(n_blks * ctxt.cur_dev->blksz); + table = malloc_cache_aligned(n_blks * sqfs_ctxt.cur_dev->blksz); if (!table) return -ENOMEM;
@@ -143,11 +137,11 @@ static int sqfs_frag_lookup(u32 inode_fragment_index, start_block = get_unaligned_le64(table + table_offset + block * sizeof(u64));
- start = start_block / ctxt.cur_dev->blksz; + start = start_block / sqfs_ctxt.cur_dev->blksz; n_blks = sqfs_calc_n_blks(cpu_to_le64(start_block), sblk->fragment_table_start, &table_offset);
- metadata_buffer = malloc_cache_aligned(n_blks * ctxt.cur_dev->blksz); + metadata_buffer = malloc_cache_aligned(n_blks * sqfs_ctxt.cur_dev->blksz); if (!metadata_buffer) { ret = -ENOMEM; goto free_table; @@ -434,7 +428,7 @@ static char *sqfs_resolve_symlink(struct squashfs_symlink_inode *sym, static int sqfs_search_dir(struct squashfs_dir_stream *dirs, char **token_list, int token_count, u32 *m_list, int m_count) { - struct squashfs_super_block *sblk = ctxt.sblk; + struct squashfs_super_block *sblk = sqfs_ctxt.sblk; char *path, *target, **sym_tokens, *res, *rem; int j, ret, new_inode_number, offset; struct squashfs_symlink_inode *sym; @@ -633,7 +627,7 @@ static int sqfs_get_metablk_pos(u32 *pos_list, void *table, u32 offset,
static int sqfs_read_inode_table(unsigned char **inode_table) { - struct squashfs_super_block *sblk = ctxt.sblk; + struct squashfs_super_block *sblk = sqfs_ctxt.sblk; u64 start, n_blks, table_offset, table_size; int j, ret = 0, metablks_count, comp_type; unsigned char *src_table, *itb; @@ -645,12 +639,12 @@ static int sqfs_read_inode_table(unsigned char **inode_table) table_size = get_unaligned_le64(&sblk->directory_table_start) - get_unaligned_le64(&sblk->inode_table_start); start = get_unaligned_le64(&sblk->inode_table_start) / - ctxt.cur_dev->blksz; + sqfs_ctxt.cur_dev->blksz; n_blks = sqfs_calc_n_blks(sblk->inode_table_start, sblk->directory_table_start, &table_offset);
/* Allocate a proper sized buffer (itb) to store the inode table */ - itb = malloc_cache_aligned(n_blks * ctxt.cur_dev->blksz); + itb = malloc_cache_aligned(n_blks * sqfs_ctxt.cur_dev->blksz); if (!itb) return -ENOMEM;
@@ -718,7 +712,7 @@ static int sqfs_read_directory_table(unsigned char **dir_table, u32 **pos_list) { u64 start, n_blks, table_offset, table_size; int j, ret = 0, metablks_count = -1, comp_type; - struct squashfs_super_block *sblk = ctxt.sblk; + struct squashfs_super_block *sblk = sqfs_ctxt.sblk; unsigned char *src_table, *dtb; u32 src_len, dest_offset = 0; unsigned long dest_len; @@ -730,12 +724,12 @@ static int sqfs_read_directory_table(unsigned char **dir_table, u32 **pos_list) table_size = get_unaligned_le64(&sblk->fragment_table_start) - get_unaligned_le64(&sblk->directory_table_start); start = get_unaligned_le64(&sblk->directory_table_start) / - ctxt.cur_dev->blksz; + sqfs_ctxt.cur_dev->blksz; n_blks = sqfs_calc_n_blks(sblk->directory_table_start, sblk->fragment_table_start, &table_offset);
/* Allocate a proper sized buffer (dtb) to store the directory table */ - dtb = malloc_cache_aligned(n_blks * ctxt.cur_dev->blksz); + dtb = malloc_cache_aligned(n_blks * sqfs_ctxt.cur_dev->blksz); if (!dtb) return -ENOMEM;
@@ -891,7 +885,7 @@ free_path:
int sqfs_readdir(struct fs_dir_stream *fs_dirs, struct fs_dirent **dentp) { - struct squashfs_super_block *sblk = ctxt.sblk; + struct squashfs_super_block *sblk = sqfs_ctxt.sblk; struct squashfs_dir_stream *dirs; struct squashfs_lreg_inode *lreg; struct squashfs_base_inode *base; @@ -1007,8 +1001,8 @@ int sqfs_probe(struct blk_desc *fs_dev_desc, struct disk_partition *fs_partition struct squashfs_super_block *sblk; int ret;
- ctxt.cur_dev = fs_dev_desc; - ctxt.cur_part_info = *fs_partition; + sqfs_ctxt.cur_dev = fs_dev_desc; + sqfs_ctxt.cur_part_info = *fs_partition;
ret = sqfs_read_sblk(&sblk); if (ret) @@ -1017,11 +1011,19 @@ int sqfs_probe(struct blk_desc *fs_dev_desc, struct disk_partition *fs_partition /* Make sure it has a valid SquashFS magic number*/ if (get_unaligned_le32(&sblk->s_magic) != SQFS_MAGIC_NUMBER) { printf("Bad magic number for SquashFS image.\n"); - ctxt.cur_dev = NULL; + sqfs_ctxt.cur_dev = NULL; return -EINVAL; }
- ctxt.sblk = sblk; + sqfs_ctxt.sblk = sblk; + + ret = sqfs_decompressor_init(&sqfs_ctxt); + + if (ret) { + sqfs_ctxt.cur_dev = NULL; + free(sqfs_ctxt.sblk); + return -EINVAL; + }
return 0; } @@ -1196,7 +1198,7 @@ int sqfs_read(const char *filename, void *buf, loff_t offset, loff_t len, char *fragment, *file, *resolved, *data; u64 start, n_blks, table_size, data_offset, table_offset; int ret, j, i_number, comp_type, datablk_count = 0; - struct squashfs_super_block *sblk = ctxt.sblk; + struct squashfs_super_block *sblk = sqfs_ctxt.sblk; struct squashfs_fragment_block_entry frag_entry; struct squashfs_file_info finfo = {0}; struct squashfs_symlink_inode *symlink; @@ -1315,13 +1317,13 @@ int sqfs_read(const char *filename, void *buf, loff_t offset, loff_t len, }
for (j = 0; j < datablk_count; j++) { - start = data_offset / ctxt.cur_dev->blksz; + start = data_offset / sqfs_ctxt.cur_dev->blksz; table_size = SQFS_BLOCK_SIZE(finfo.blk_sizes[j]); - table_offset = data_offset - (start * ctxt.cur_dev->blksz); + table_offset = data_offset - (start * sqfs_ctxt.cur_dev->blksz); n_blks = DIV_ROUND_UP(table_size + table_offset, - ctxt.cur_dev->blksz); + sqfs_ctxt.cur_dev->blksz);
- data_buffer = malloc_cache_aligned(n_blks * ctxt.cur_dev->blksz); + data_buffer = malloc_cache_aligned(n_blks * sqfs_ctxt.cur_dev->blksz);
if (!data_buffer) { ret = -ENOMEM; @@ -1369,12 +1371,12 @@ int sqfs_read(const char *filename, void *buf, loff_t offset, loff_t len, goto free_buffer; }
- start = frag_entry.start / ctxt.cur_dev->blksz; + start = frag_entry.start / sqfs_ctxt.cur_dev->blksz; table_size = SQFS_BLOCK_SIZE(frag_entry.size); - table_offset = frag_entry.start - (start * ctxt.cur_dev->blksz); - n_blks = DIV_ROUND_UP(table_size + table_offset, ctxt.cur_dev->blksz); + table_offset = frag_entry.start - (start * sqfs_ctxt.cur_dev->blksz); + n_blks = DIV_ROUND_UP(table_size + table_offset, sqfs_ctxt.cur_dev->blksz);
- fragment = malloc_cache_aligned(n_blks * ctxt.cur_dev->blksz); + fragment = malloc_cache_aligned(n_blks * sqfs_ctxt.cur_dev->blksz);
if (!fragment) { ret = -ENOMEM; @@ -1435,7 +1437,7 @@ free_paths:
int sqfs_size(const char *filename, loff_t *size) { - struct squashfs_super_block *sblk = ctxt.sblk; + struct squashfs_super_block *sblk = sqfs_ctxt.sblk; struct squashfs_symlink_inode *symlink; struct fs_dir_stream *dirsp = NULL; struct squashfs_base_inode *base; @@ -1523,8 +1525,9 @@ free_strings:
void sqfs_close(void) { - free(ctxt.sblk); - ctxt.cur_dev = NULL; + free(sqfs_ctxt.sblk); + sqfs_ctxt.cur_dev = NULL; + sqfs_decompressor_cleanup(&sqfs_ctxt); }
void sqfs_closedir(struct fs_dir_stream *dirs) diff --git a/fs/squashfs/sqfs_decompressor.c b/fs/squashfs/sqfs_decompressor.c index 09ca6cf6d0..577cffd8bb 100644 --- a/fs/squashfs/sqfs_decompressor.c +++ b/fs/squashfs/sqfs_decompressor.c @@ -14,9 +14,39 @@ #endif
#include "sqfs_decompressor.h" -#include "sqfs_filesystem.h" #include "sqfs_utils.h"
+extern struct squashfs_ctxt sqfs_ctxt; + +int sqfs_decompressor_init(struct squashfs_ctxt *ctxt) +{ + u16 comp_type = get_unaligned_le16(&ctxt->sblk->compression); + + switch (comp_type) { +#if IS_ENABLED(CONFIG_ZLIB) + case SQFS_COMP_ZLIB: + break; +#endif + default: + printf("Error: unknown compression type.\n"); + return -EINVAL; + } + + return 0; +} + +void sqfs_decompressor_cleanup(struct squashfs_ctxt *ctxt) +{ + u16 comp_type = get_unaligned_le16(&ctxt->sblk->compression); + + switch (comp_type) { +#if IS_ENABLED(CONFIG_ZLIB) + case SQFS_COMP_ZLIB: + break; +#endif + } +} + #if IS_ENABLED(CONFIG_ZLIB) static void zlib_decompression_status(int ret) { @@ -35,14 +65,14 @@ static void zlib_decompression_status(int ret) #endif
int sqfs_decompress(u16 comp_type, void *dest, unsigned long *dest_len, - void *source, u32 lenp) + void *source, u32 src_len) { int ret = 0;
switch (comp_type) { #if IS_ENABLED(CONFIG_ZLIB) case SQFS_COMP_ZLIB: - ret = uncompress(dest, dest_len, source, lenp); + ret = uncompress(dest, dest_len, source, src_len); if (ret) { zlib_decompression_status(ret); return -EINVAL; diff --git a/fs/squashfs/sqfs_decompressor.h b/fs/squashfs/sqfs_decompressor.h index 378965dda8..450257e5ce 100644 --- a/fs/squashfs/sqfs_decompressor.h +++ b/fs/squashfs/sqfs_decompressor.h @@ -9,6 +9,7 @@ #define SQFS_DECOMPRESSOR_H
#include <stdint.h> +#include "sqfs_filesystem.h"
#define SQFS_COMP_ZLIB 1 #define SQFS_COMP_LZMA 2 @@ -54,5 +55,7 @@ union squashfs_compression_opts {
int sqfs_decompress(u16 comp_type, void *dest, unsigned long *dest_len, void *source, u32 lenp); +int sqfs_decompressor_init(struct squashfs_ctxt *ctxt); +void sqfs_decompressor_cleanup(struct squashfs_ctxt *ctxt);
#endif /* SQFS_DECOMPRESSOR_H */ diff --git a/fs/squashfs/sqfs_filesystem.h b/fs/squashfs/sqfs_filesystem.h index d63e3a41ad..ff2b0b1d34 100644 --- a/fs/squashfs/sqfs_filesystem.h +++ b/fs/squashfs/sqfs_filesystem.h @@ -9,8 +9,9 @@ #define SQFS_FILESYSTEM_H
#include <asm/unaligned.h> -#include <stdint.h> #include <fs.h> +#include <part.h> +#include <stdint.h>
#define SQFS_UNCOMPRESSED_DATA 0x0002 #define SQFS_MAGIC_NUMBER 0x73717368 @@ -72,6 +73,12 @@ struct squashfs_super_block { __le64 export_table_start; };
+struct squashfs_ctxt { + struct disk_partition cur_part_info; + struct blk_desc *cur_dev; + struct squashfs_super_block *sblk; +}; + struct squashfs_directory_index { u32 index; u32 start;
Hello,
In your commit title: spurious . after "init".
On Tue, 18 Aug 2020 16:31:15 +0200 Joao Marcos Costa joaomarcos.costa@bootlin.com wrote:
Why are you dropping the "static" here ? This symbol only needs to be visible from that file. If you keep the "static" keyword, you can keep the variable named "ctxt" and avoid a lengthy patch.
- ret = sqfs_decompressor_init(&sqfs_ctxt);
See you're passing a reference to the squashfs context here, so this variable does not need to be visible by other files.
Thomas
Add call to ZSTD's ZSTD_decompressDCtx(). In this use case, the caller can upper bound the decompressed size, which will be the SquashFS data block (or metadata block) size, so there is no need to use streaming API. Add ZSTD's worskpace to squashfs_ctxt structure.
Signed-off-by: Joao Marcos Costa joaomarcos.costa@bootlin.com --- Changes in v3: - Remove memory leak from sqfs_zstd_decompress() Changes in v2: - No changes since last version. fs/squashfs/sqfs_decompressor.c | 42 +++++++++++++++++++++++++++++++++ fs/squashfs/sqfs_filesystem.h | 3 +++ 2 files changed, 45 insertions(+)
diff --git a/fs/squashfs/sqfs_decompressor.c b/fs/squashfs/sqfs_decompressor.c index 577cffd8bb..8fdaaa853c 100644 --- a/fs/squashfs/sqfs_decompressor.c +++ b/fs/squashfs/sqfs_decompressor.c @@ -13,6 +13,10 @@ #include <u-boot/zlib.h> #endif
+#if IS_ENABLED(CONFIG_ZSTD) +#include <linux/zstd.h> +#endif + #include "sqfs_decompressor.h" #include "sqfs_utils.h"
@@ -26,6 +30,13 @@ int sqfs_decompressor_init(struct squashfs_ctxt *ctxt) #if IS_ENABLED(CONFIG_ZLIB) case SQFS_COMP_ZLIB: break; +#endif +#if IS_ENABLED(CONFIG_ZSTD) + case SQFS_COMP_ZSTD: + ctxt->zstd_workspace = malloc(ZSTD_DCtxWorkspaceBound()); + if (!ctxt->zstd_workspace) + return -ENOMEM; + break; #endif default: printf("Error: unknown compression type.\n"); @@ -43,6 +54,11 @@ void sqfs_decompressor_cleanup(struct squashfs_ctxt *ctxt) #if IS_ENABLED(CONFIG_ZLIB) case SQFS_COMP_ZLIB: break; +#endif +#if IS_ENABLED(CONFIG_ZSTD) + case SQFS_COMP_ZSTD: + free(ctxt->zstd_workspace); + break; #endif } } @@ -64,6 +80,22 @@ static void zlib_decompression_status(int ret) } #endif
+#if IS_ENABLED(CONFIG_ZSTD) +static int sqfs_zstd_decompress(void *dest, unsigned long dest_len, + void *source, u32 src_len) +{ + ZSTD_DCtx *ctx; + size_t wsize; + int ret; + + wsize = ZSTD_DCtxWorkspaceBound(); + ctx = ZSTD_initDCtx(sqfs_ctxt.zstd_workspace, wsize); + ret = ZSTD_decompressDCtx(ctx, dest, dest_len, source, src_len); + + return ZSTD_isError(ret); +} +#endif /* CONFIG_ZSTD */ + int sqfs_decompress(u16 comp_type, void *dest, unsigned long *dest_len, void *source, u32 src_len) { @@ -80,6 +112,16 @@ int sqfs_decompress(u16 comp_type, void *dest, unsigned long *dest_len,
break; #endif +#if IS_ENABLED(CONFIG_ZSTD) + case SQFS_COMP_ZSTD: + ret = sqfs_zstd_decompress(dest, *dest_len, source, src_len); + if (ret) { + printf("ZSTD Error code: %d\n", ZSTD_getErrorCode(ret)); + return -EINVAL; + } + + break; +#endif default: printf("Error: unknown compression type.\n"); return -EINVAL; diff --git a/fs/squashfs/sqfs_filesystem.h b/fs/squashfs/sqfs_filesystem.h index ff2b0b1d34..856cd15e34 100644 --- a/fs/squashfs/sqfs_filesystem.h +++ b/fs/squashfs/sqfs_filesystem.h @@ -77,6 +77,9 @@ struct squashfs_ctxt { struct disk_partition cur_part_info; struct blk_desc *cur_dev; struct squashfs_super_block *sblk; +#if IS_ENABLED(CONFIG_ZSTD) + void *zstd_workspace; +#endif };
Hello,
On Tue, 18 Aug 2020 16:31:16 +0200 Joao Marcos Costa joaomarcos.costa@bootlin.com wrote:
Pass the squashfs_context structure as argument to the decompressor function, so that sqfs_ctxt doesn't need to be a global variable.
Thomas
On Tue, 18 Aug 2020 16:35:27 +0200 Thomas Petazzoni thomas.petazzoni@bootlin.com wrote:
Hello,
Thomas
Thanks for the remarks, I am preparing a v4 and I will send it in a few minutes.
Best regards, Joao
Add call to lzo's lzo1x_decompress_safe() into sqfs_decompress().
U-Boot's LZO sources may still have some unsolved issues that could make the decompression crash when dealing with fragmented files, so those should be avoided. The "-no-fragments" option can be passed to mksquashfs.
Signed-off-by: Joao Marcos Costa joaomarcos.costa@bootlin.com --- Changes in v3: - Change commit message. Changes in v2: - Change commit message. fs/squashfs/sqfs_decompressor.c | 25 +++++++++++++++++++++++++ 1 file changed, 25 insertions(+)
diff --git a/fs/squashfs/sqfs_decompressor.c b/fs/squashfs/sqfs_decompressor.c index 8fdaaa853c..f57d7e2626 100644 --- a/fs/squashfs/sqfs_decompressor.c +++ b/fs/squashfs/sqfs_decompressor.c @@ -9,6 +9,11 @@ #include <stdint.h> #include <stdio.h> #include <stdlib.h> + +#if IS_ENABLED(CONFIG_LZO) +#include <linux/lzo.h> +#endif + #if IS_ENABLED(CONFIG_ZLIB) #include <u-boot/zlib.h> #endif @@ -27,6 +32,10 @@ int sqfs_decompressor_init(struct squashfs_ctxt *ctxt) u16 comp_type = get_unaligned_le16(&ctxt->sblk->compression);
switch (comp_type) { +#if IS_ENABLED(CONFIG_LZO) + case SQFS_COMP_LZO: + break; +#endif #if IS_ENABLED(CONFIG_ZLIB) case SQFS_COMP_ZLIB: break; @@ -51,6 +60,10 @@ void sqfs_decompressor_cleanup(struct squashfs_ctxt *ctxt) u16 comp_type = get_unaligned_le16(&ctxt->sblk->compression);
switch (comp_type) { +#if IS_ENABLED(CONFIG_LZO) + case SQFS_COMP_LZO: + break; +#endif #if IS_ENABLED(CONFIG_ZLIB) case SQFS_COMP_ZLIB: break; @@ -102,6 +115,18 @@ int sqfs_decompress(u16 comp_type, void *dest, unsigned long *dest_len, int ret = 0;
switch (comp_type) { +#if IS_ENABLED(CONFIG_LZO) + case SQFS_COMP_LZO: { + size_t lzo_dest_len = *dest_len; + ret = lzo1x_decompress_safe(source, src_len, dest, &lzo_dest_len); + if (ret) { + printf("LZO decompression failed. Error code: %d\n", ret); + return -EINVAL; + } + + break; + } +#endif #if IS_ENABLED(CONFIG_ZLIB) case SQFS_COMP_ZLIB: ret = uncompress(dest, dest_len, source, src_len);
Improve SquashFS tests architecture. Add 'Compression' class. LZO algorithm may crash if the file is fragmented, so the fragments are disabled when testing LZO.
Signed-off-by: Joao Marcos Costa joaomarcos.costa@bootlin.com --- Changes in v3: - No changes since the last version. Changes in v2: - This patch was not present in the previous version. .../test_fs/test_squashfs/sqfs_common.py | 76 ++++++++++++++----- .../test_fs/test_squashfs/test_sqfs_load.py | 40 ++++++---- .../test_fs/test_squashfs/test_sqfs_ls.py | 33 +++++--- 3 files changed, 102 insertions(+), 47 deletions(-)
diff --git a/test/py/tests/test_fs/test_squashfs/sqfs_common.py b/test/py/tests/test_fs/test_squashfs/sqfs_common.py index 2dc344d1b2..c96f92c1d8 100644 --- a/test/py/tests/test_fs/test_squashfs/sqfs_common.py +++ b/test/py/tests/test_fs/test_squashfs/sqfs_common.py @@ -5,6 +5,7 @@ import os import random import string +import subprocess
def sqfs_get_random_letters(size): letters = [] @@ -19,24 +20,57 @@ def sqfs_generate_file(path, size): file.write(content) file.close()
-# generate image with three files and a symbolic link -def sqfs_generate_image(cons): - src = os.path.join(cons.config.build_dir, "sqfs_src/") - dest = os.path.join(cons.config.build_dir, "sqfs") - os.mkdir(src) - sqfs_generate_file(src + "frag_only", 100) - sqfs_generate_file(src + "blks_frag", 5100) - sqfs_generate_file(src + "blks_only", 4096) - os.symlink("frag_only", src + "sym") - os.system("mksquashfs " + src + " " + dest + " -b 4096 -always-use-fragments") - -# removes all files created by sqfs_generate_image() -def sqfs_clean(cons): - src = os.path.join(cons.config.build_dir, "sqfs_src/") - dest = os.path.join(cons.config.build_dir, "sqfs") - os.remove(src + "frag_only") - os.remove(src + "blks_frag") - os.remove(src + "blks_only") - os.remove(src + "sym") - os.rmdir(src) - os.remove(dest) +class Compression: + def __init__(self, name, files, sizes, block_size = 4096): + self.name = name + self.files = files + self.sizes = sizes + self.mksquashfs_opts = " -b " + str(block_size) + " -comp " + self.name + + def add_opt(self, opt): + self.mksquashfs_opts += " " + opt + + def gen_image(self, build_dir): + src = os.path.join(build_dir, "sqfs_src/") + os.mkdir(src) + for (f, s) in zip(self.files, self.sizes): + sqfs_generate_file(src + f, s) + + # the symbolic link always targets the first file + os.symlink(self.files[0], src + "sym") + + sqfs_img = os.path.join(build_dir, "sqfs-" + self.name) + i_o = src + " " + sqfs_img + opts = self.mksquashfs_opts + try: + subprocess.run(["mksquashfs " + i_o + opts], shell = True, check = True) + except: + print("mksquashfs error. Compression type: " + self.name) + raise RuntimeError + + def clean_source(self, build_dir): + src = os.path.join(build_dir, "sqfs_src/") + for f in self.files: + os.remove(src + f) + os.remove(src + "sym") + os.rmdir(src) + + def cleanup(self, build_dir): + self.clean_source(build_dir) + sqfs_img = os.path.join(build_dir, "sqfs-" + self.name) + os.remove(sqfs_img) + +files = ["blks_only", "blks_frag", "frag_only"] +sizes = [4096, 5100, 100] +gzip = Compression("gzip", files, sizes) +zstd = Compression("zstd", files, sizes) +lzo = Compression("lzo", files, sizes) + +# use fragment blocks for files larger than block_size +gzip.add_opt("-always-use-fragments") +zstd.add_opt("-always-use-fragments") + +# avoid fragments if lzo is used +lzo.add_opt("-no-fragments") + +comp_opts = [gzip, zstd, lzo] diff --git a/test/py/tests/test_fs/test_squashfs/test_sqfs_load.py b/test/py/tests/test_fs/test_squashfs/test_sqfs_load.py index eb1baae5c5..9e90062384 100644 --- a/test/py/tests/test_fs/test_squashfs/test_sqfs_load.py +++ b/test/py/tests/test_fs/test_squashfs/test_sqfs_load.py @@ -12,23 +12,35 @@ from sqfs_common import * @pytest.mark.buildconfigspec('fs_squashfs') @pytest.mark.requiredtool('mksquashfs') def test_sqfs_load(u_boot_console): - cons = u_boot_console - sqfs_generate_image(cons) + build_dir = u_boot_console.config.build_dir command = "sqfsload host 0 $kernel_addr_r " - path = os.path.join(cons.config.build_dir, "sqfs")
- try: + for opt in comp_opts: + # generate and load the squashfs image + try: + opt.gen_image(build_dir) + except RuntimeError: + opt.clean_source(build_dir) + # skip unsupported compression types + continue + + path = os.path.join(build_dir, "sqfs-" + opt.name) output = u_boot_console.run_command("host bind 0 " + path) + output = u_boot_console.run_command(command + "xxx") assert "File not found." in output - output = u_boot_console.run_command(command + "frag_only") - assert "100 bytes read in" in output - output = u_boot_console.run_command(command + "blks_frag") - assert "5100 bytes read in" in output - output = u_boot_console.run_command(command + "blks_only") - assert "4096 bytes read in" in output + + for (f, s) in zip(opt.files, opt.sizes): + try: + output = u_boot_console.run_command(command + f) + assert str(s) in output + except: + assert False + opt.cleanup(build_dir) + + # test symbolic link output = u_boot_console.run_command(command + "sym") - assert "100 bytes read in" in output - except: - sqfs_clean(cons) - sqfs_clean(cons) + assert str(opt.sizes[0]) in output + + # remove generated files + opt.cleanup(build_dir) diff --git a/test/py/tests/test_fs/test_squashfs/test_sqfs_ls.py b/test/py/tests/test_fs/test_squashfs/test_sqfs_ls.py index 3a7b75c778..a0dca2e2fc 100644 --- a/test/py/tests/test_fs/test_squashfs/test_sqfs_ls.py +++ b/test/py/tests/test_fs/test_squashfs/test_sqfs_ls.py @@ -12,16 +12,25 @@ from sqfs_common import * @pytest.mark.buildconfigspec('fs_squashfs') @pytest.mark.requiredtool('mksquashfs') def test_sqfs_ls(u_boot_console): - cons = u_boot_console - sqfs_generate_image(cons) - path = os.path.join(cons.config.build_dir, "sqfs") - try: + build_dir = u_boot_console.config.build_dir + for opt in comp_opts: + try: + opt.gen_image(build_dir) + except RuntimeError: + opt.clean_source(build_dir) + # skip unsupported compression types + continue + path = os.path.join(build_dir, "sqfs-" + opt.name) output = u_boot_console.run_command("host bind 0 " + path) - output = u_boot_console.run_command("sqfsls host 0") - assert "4 file(s), 0 dir(s)" in output - assert "<SYM> sym" in output - output = u_boot_console.run_command("sqfsls host 0 xxx") - assert "** Cannot find directory. **" in output - except: - sqfs_clean(cons) - sqfs_clean(cons) + + try: + # list files in root directory + output = u_boot_console.run_command("sqfsls host 0") + assert str(len(opt.files) + 1) + " file(s), 0 dir(s)" in output + assert "<SYM> sym" in output + output = u_boot_console.run_command("sqfsls host 0 xxx") + assert "** Cannot find directory. **" in output + except: + opt.cleanup(build_dir) + assert False + opt.cleanup(build_dir)
Joao Marcos Costa
Thomas Petazzoni
