[U-Boot] [PATCH v2] BeagleBoard: Remove userbutton command and use gpio command instead
Remove userbutton command and do the detection in board config file using the gpio command
Signed-off-by: Joel A Fernandes agnel.joel@gmail.com Signed-off-by: Jason Kridner jkridner@beagleboard.org --- This addresses the suggestions at: http://patchwork.ozlabs.org/patch/110123/ Also, with the removal of the userbutton command, all checkpatch errors are automatically fixed.
v2 changes: Corrected comment about userbutton
board/ti/beagle/beagle.c | 55 ---------------------------------------- include/configs/omap3_beagle.h | 11 ++++++- 2 files changed, 9 insertions(+), 57 deletions(-)
diff --git a/board/ti/beagle/beagle.c b/board/ti/beagle/beagle.c index 8cdceaf..9ce8aeb 100644 --- a/board/ti/beagle/beagle.c +++ b/board/ti/beagle/beagle.c @@ -479,58 +479,3 @@ int ehci_hcd_init(void) }
#endif /* CONFIG_USB_EHCI */ - -/* - * This command returns the status of the user button on beagle xM - * Input - none - * Returns - 1 if button is held down - * 0 if button is not held down - */ -int do_userbutton (cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]) -{ - int button = 0; - int gpio; - - /* - * pass address parameter as argv[0] (aka command name), - * and all remaining args - */ - switch (get_board_revision()) { - case REVISION_AXBX: - case REVISION_CX: - case REVISION_C4: - gpio = 7; - break; - case REVISION_XM_A: - case REVISION_XM_B: - case REVISION_XM_C: - default: - gpio = 4; - break; - } - gpio_request(gpio, ""); - gpio_direction_input(gpio); - printf("The user button is currently "); - if (gpio_get_value(gpio)) - { - button = 1; - printf("PRESSED.\n"); - } - else - { - button = 0; - printf("NOT pressed.\n"); - } - - gpio_free(gpio); - - return !button; -} - -/* -------------------------------------------------------------------- */ - -U_BOOT_CMD( - userbutton, CONFIG_SYS_MAXARGS, 1, do_userbutton, - "Return the status of the BeagleBoard USER button", - "" -); diff --git a/include/configs/omap3_beagle.h b/include/configs/omap3_beagle.h index 1369c89..0cf81a6 100644 --- a/include/configs/omap3_beagle.h +++ b/include/configs/omap3_beagle.h @@ -164,6 +164,7 @@ #define CONFIG_CMD_PING #define CONFIG_CMD_DHCP #define CONFIG_CMD_SETEXPR /* Evaluate expressions */ +#define CONFIG_CMD_GPIO /* Enable gpio command */
#undef CONFIG_CMD_FLASH /* flinfo, erase, protect */ #undef CONFIG_CMD_FPGA /* FPGA configuration Support */ @@ -277,10 +278,16 @@ "ramboot=echo Booting from ramdisk ...; " \ "run ramargs; " \ "bootm ${loadaddr}\0" \ - + "userbutton=if gpio input 173; then run userbutton_xm; " \ + "else run userbutton_nonxm; fi;\0" \ + "userbutton_xm=gpio input 4;\0" \ + "userbutton_nonxm=gpio input 7;\0" +/* "run userbutton" will return 1 (false) if is pressed and 0 (true) if not */ #define CONFIG_BOOTCOMMAND \ "if mmc rescan ${mmcdev}; then " \ - "if userbutton; then " \ + "if run userbutton; then " \ + "setenv bootenv uEnv.txt;" \ + "else " \ "setenv bootenv user.txt;" \ "fi;" \ "echo SD/MMC found on device ${mmcdev};" \
On Sun, Sep 11, 2011 at 2:41 PM, Joel A Fernandes agnel.joel@gmail.com wrote:
Can you split these into two or three patches? I'm not sure what is normal, but I suspect that this is one of those things where you should remove a feature in one patch then add a replacement with another, rather than doing both in one patch. In general, I would add the replacement functionality before removing the old command.
More comments below...
- This command returns the status of the user button on beagle xM
- Input - none
- Returns - 1 if button is held down
- 0 if button is not held down
- int button = 0;
- int gpio;
- case REVISION_CX:
- case REVISION_C4:
- gpio = 7;
- break;
- default:
- gpio = 4;
- break;
- button = 1;
- else
- button = 0;
- gpio_free(gpio);
- return !button;
-U_BOOT_CMD(
- "userbutton=if gpio input 173; then run userbutton_xm; " \
- "else run userbutton_nonxm; fi;\0" \
There is an environment variable called 'beaglerev'. Is there an easy way to use it?
- "userbutton_xm=gpio input 4;\0" \
- "userbutton_nonxm=gpio input 7;\0"
- "if run userbutton; then " \
- "setenv bootenv uEnv.txt;" \
- "else " \
"setenv bootenv user.txt;" \ "fi;" \ "echo SD/MMC found on device ${mmcdev};" \ -- 1.7.1
Hi Jason,
On Sun, Sep 11, 2011 at 2:54 PM, Jason Kridner jkridner@beagleboard.org wrote:
Sure
Something like [1] would work? I'll try it out. Thanks
Thanks, Joel
[1] http://lists.linuxtogo.org/pipermail/openembedded-commits/2010-June/047925.h...
Jason Kridner
Joel A Fernandes
