[U-Boot] Pending TPM patches for release
Hi Tom,
I think there are only 5 patches pending for this release, of which one is probably better delayed until we have another config change to go with it.
I have pulled these in and build-tested.
So please see below for a pull request based on current mainline.
The following changes since commit 785881f775252940185e10fbb2d5299c9ffa6bce:
env: Add redundant env support to UBI env (2013-04-11 15:52:55 -0400)
git://git.denx.de/u-boot-x86.git tpm
for you to fetch changes up to 8732b0700d21588b4954d0f1b182f4c60725d228:
tpm: Add TPM command library (2013-04-12 14:13:13 -0700)
---------------------------------------------------------------- Che-liang Chiou (1): tpm: Add TPM command library
Rong Chang (1): tpm: Add Infineon slb9635_i2c TPM driver
Simon Glass (1): exynos: Enable I2C TPM for smdk5250
Taylor Hutt (1): tpm: Add casts for proper compilation
Makefile | 2 +- common/cmd_tpm.c | 709 +++++++++++++++++++++++++++----- drivers/tpm/Makefile | 4 + drivers/tpm/generic_lpc_tpm.c | 10 +- drivers/tpm/slb9635_i2c/compatibility.h | 51 +++ drivers/tpm/slb9635_i2c/tpm.c | 453 ++++++++++++++++++++ drivers/tpm/slb9635_i2c/tpm.h | 161 ++++++++ drivers/tpm/slb9635_i2c/tpm_tis_i2c.c | 561 +++++++++++++++++++++++++ drivers/tpm/tis_i2c.c | 181 ++++++++ include/configs/exynos5250-dt.h | 7 + include/fdtdec.h | 1 + include/tis.h | 73 ++++ include/tpm.h | 197 +++++++-- lib/Makefile | 1 + lib/fdtdec.c | 1 + lib/tpm.c | 581 ++++++++++++++++++++++++++ 16 files changed, 2845 insertions(+), 148 deletions(-) create mode 100644 drivers/tpm/slb9635_i2c/compatibility.h create mode 100644 drivers/tpm/slb9635_i2c/tpm.c create mode 100644 drivers/tpm/slb9635_i2c/tpm.h create mode 100644 drivers/tpm/slb9635_i2c/tpm_tis_i2c.c create mode 100644 drivers/tpm/tis_i2c.c create mode 100644 include/tis.h create mode 100644 lib/tpm.c
On Fri, Apr 12, 2013 at 02:17:54PM -0700, Simon Glass wrote:
Hi Tom,
