[PATCH v2 00/10] mips: octeon: Misc Octeon drivers, DT and Kconfig / defconfig updates
This patchset includes the following parts: - Octeon GPIO driver - Octeon SPI driver - New simple Octeon clk driver - DT updates (GPIO, SPI, I2C & CLK nodes) - Kconfig & defconfig updates
In v2 I've added the SPI driver as well, so combine all the drivers / patches in one patchset, that have been sent to the list before. Also GPIO and SPI have now been tested on ARM Octeon TX2 and have undergone minor changes because of this.
Thanks, Stefan
Changes in v2: - Tested on MIPS Octeon and ARM Octeon TX2 - Removed "struct pci_device_id" definition and U_BOOT_PCI_DEVICE() as its not needed for the PCI based probing on Octeon TX2 - Added "depends on DM_PCI" to Kconfig - Newly added to this series - Removed inclusion of "common.h" - Added "depends on DM_PCI" to Kconfig - Tested on MIPS Octeon and ARM Octeon TX2 - Fixed issues with Octeon TX2 registration. Now only one driver is registered and the "ops" is overwritten in the Octeon TX2 case. - Use dev_get_driver_data() to get the driver data struct - Removed "struct pci_device_id" definition and U_BOOT_PCI_DEVICE() as its not needed for the PCI based probing on Octeon TX2 - Newly added to this series - Newly added to this series - Kconfig and defconfig changes separated into 2 patches - Kconfig and defconfig changes separated into 2 patches
Changes in v1: - Removed common.h and reduced headers as suggested by Daniel
Stefan Roese (8): mips: octeon: mrvl,cn73xx.dtsi: Add GPIO DT nodes mips: octeon: dts: Add I2C DT nodes clk: clk_octeon: Add simple MIPS Octeon clock driver mips: octeon: dts: Add Octeon clock driver DT nodes mips: octeon: mrvl,cn73xx.dtsi: Add SPI DT node mips: octeon: mrvl,octeon-ebb7304.dts: Add SPI flash DT node mips: octeon: Update Octeon Kconfig mips: octeon: Update EBB7304 defconfig
Suneel Garapati (2): gpio: octeon_gpio: Add GPIO controller driver for Octeon drivers: spi: Add SPI controller driver for Octeon
arch/mips/Kconfig | 6 +- arch/mips/dts/mrvl,cn73xx.dtsi | 66 +++ arch/mips/dts/mrvl,octeon-ebb7304.dts | 21 +- configs/octeon_ebb7304_defconfig | 10 + drivers/clk/Kconfig | 7 + drivers/clk/Makefile | 1 + drivers/clk/clk_octeon.c | 72 +++ drivers/gpio/Kconfig | 10 + drivers/gpio/Makefile | 1 + drivers/gpio/octeon_gpio.c | 242 +++++++++ drivers/spi/Kconfig | 8 + drivers/spi/Makefile | 1 + drivers/spi/octeon_spi.c | 647 +++++++++++++++++++++++ include/dt-bindings/clock/octeon-clock.h | 12 + 14 files changed, 1101 insertions(+), 3 deletions(-) create mode 100644 drivers/clk/clk_octeon.c create mode 100644 drivers/gpio/octeon_gpio.c create mode 100644 drivers/spi/octeon_spi.c create mode 100644 include/dt-bindings/clock/octeon-clock.h
Add support for GPIO controllers found on Octeon II/III and Octeon TX TX2 SoC platforms.
Signed-off-by: Aaron Williams awilliams@marvell.com Signed-off-by: Suneel Garapati sgarapati@marvell.com Signed-off-by: Stefan Roese sr@denx.de Reviewed-by: Simon Glass sjg@chromium.org
drivers/gpio/Kconfig | 10 ++ drivers/gpio/Makefile | 1 + drivers/gpio/octeon_gpio.c | 242 +++++++++++++++++++++++++++++++++++++ 3 files changed, 253 insertions(+) create mode 100644 drivers/gpio/octeon_gpio.c
diff --git a/drivers/gpio/Kconfig b/drivers/gpio/Kconfig index 0e8ad9530d..f8a48dc675 100644 --- a/drivers/gpio/Kconfig +++ b/drivers/gpio/Kconfig @@ -335,6 +335,16 @@ config PIC32_GPIO help Say yes here to support Microchip PIC32 GPIOs.
+config OCTEON_GPIO + bool "Octeon II/III/TX/TX2 GPIO driver" + depends on DM_GPIO && DM_PCI && (ARCH_OCTEON || ARCH_OCTEONTX || ARCH_OCTEONTX2) + default y + help + Add support for the Marvell Octeon GPIO driver. This is used with + various Octeon parts such as Octeon II/III and OcteonTX/TX2. + Octeon II/III has 32 GPIOs (count defined via DT) and OcteonTX/TX2 + has 64 GPIOs (count defined via internal register). + config STM32_GPIO bool "ST STM32 GPIO driver" depends on DM_GPIO && (ARCH_STM32 || ARCH_STM32MP) diff --git a/drivers/gpio/Makefile b/drivers/gpio/Makefile index 7638259007..eb6364adb4 100644 --- a/drivers/gpio/Makefile +++ b/drivers/gpio/Makefile @@ -58,6 +58,7 @@ obj-$(CONFIG_HIKEY_GPIO) += hi6220_gpio.o obj-$(CONFIG_HSDK_CREG_GPIO) += hsdk-creg-gpio.o obj-$(CONFIG_IMX_RGPIO2P) += imx_rgpio2p.o obj-$(CONFIG_PIC32_GPIO) += pic32_gpio.o +obj-$(CONFIG_OCTEON_GPIO) += octeon_gpio.o obj-$(CONFIG_MVEBU_GPIO) += mvebu_gpio.o obj-$(CONFIG_MSM_GPIO) += msm_gpio.o obj-$(CONFIG_$(SPL_)PCF8575_GPIO) += pcf8575_gpio.o diff --git a/drivers/gpio/octeon_gpio.c b/drivers/gpio/octeon_gpio.c new file mode 100644 index 0000000000..45acaadcdb --- /dev/null +++ b/drivers/gpio/octeon_gpio.c @@ -0,0 +1,242 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright (C) 2018 Marvell International Ltd. + * + * (C) Copyright 2011 + * eInfochips Ltd. <www.einfochips.com> + * Written-by: Ajay Bhargav ajay.bhargav@einfochips.com + * + * (C) Copyright 2010 + * Marvell Semiconductor <www.marvell.com> + */ + +#include <dm.h> +#include <pci.h> +#include <pci_ids.h> +#include <asm/gpio.h> +#include <asm/io.h> +#include <linux/bitfield.h> +#include <linux/compat.h> +#include <dt-bindings/gpio/gpio.h> + +/* Returns the bit value to write or read based on the offset */ +#define GPIO_BIT(x) BIT_ULL((x) & 0x3f) + +#define GPIO_RX_DAT 0x00 +#define GPIO_TX_SET 0x08 +#define GPIO_TX_CLR 0x10 +#define GPIO_CONST 0x90 /* OcteonTX only */ + +/* Offset to register-set for 2nd GPIOs (> 63), OcteonTX only */ +#define GPIO1_OFFSET 0x1400 + +/* GPIO_CONST register bits */ +#define GPIO_CONST_GPIOS_MASK GENMASK_ULL(7, 0) + +/* GPIO_BIT_CFG register bits */ +#define GPIO_BIT_CFG_TX_OE BIT_ULL(0) +#define GPIO_BIT_CFG_PIN_XOR BIT_ULL(1) +#define GPIO_BIT_CFG_INT_EN BIT_ULL(2) +#define GPIO_BIT_CFG_PIN_SEL_MASK GENMASK_ULL(26, 16) + +enum { + PROBE_PCI = 0, /* PCI based probing */ + PROBE_DT, /* DT based probing */ +}; + +struct octeon_gpio_data { + int probe; + u32 reg_offs; + u32 gpio_bit_cfg_offs; +}; + +struct octeon_gpio { + void __iomem *base; + const struct octeon_gpio_data *data; +}; + +/* Returns the offset to the output register based on the offset and value */ +static u32 gpio_tx_reg(int offset, int value) +{ + u32 ret; + + ret = value ? GPIO_TX_SET : GPIO_TX_CLR; + if (offset > 63) + ret += GPIO1_OFFSET; + + return ret; +} + +/* Returns the offset to the input data register based on the offset */ +static u32 gpio_rx_dat_reg(int offset) +{ + u32 ret; + + ret = GPIO_RX_DAT; + if (offset > 63) + ret += GPIO1_OFFSET; + + return ret; +} + +static int octeon_gpio_dir_input(struct udevice *dev, unsigned int offset) +{ + struct octeon_gpio *gpio = dev_get_priv(dev); + + debug("%s(%s, %u)\n", __func__, dev->name, offset); + clrbits_64(gpio->base + gpio->data->gpio_bit_cfg_offs + 8 * offset, + GPIO_BIT_CFG_TX_OE | GPIO_BIT_CFG_PIN_XOR | + GPIO_BIT_CFG_INT_EN | GPIO_BIT_CFG_PIN_SEL_MASK); + + return 0; +} + +static int octeon_gpio_dir_output(struct udevice *dev, unsigned int offset, + int value) +{ + struct octeon_gpio *gpio = dev_get_priv(dev); + + debug("%s(%s, %u, %d)\n", __func__, dev->name, offset, value); + writeq(GPIO_BIT(offset), gpio->base + gpio->data->reg_offs + + gpio_tx_reg(offset, value)); + + clrsetbits_64(gpio->base + gpio->data->gpio_bit_cfg_offs + 8 * offset, + GPIO_BIT_CFG_PIN_SEL_MASK | GPIO_BIT_CFG_INT_EN, + GPIO_BIT_CFG_TX_OE); + + return 0; +} + +static int octeon_gpio_get_value(struct udevice *dev, unsigned int offset) +{ + struct octeon_gpio *gpio = dev_get_priv(dev); + u64 reg = readq(gpio->base + gpio->data->reg_offs + + gpio_rx_dat_reg(offset)); + + debug("%s(%s, %u): value: %d\n", __func__, dev->name, offset, + !!(reg & GPIO_BIT(offset))); + + return !!(reg & GPIO_BIT(offset)); +} + +static int octeon_gpio_set_value(struct udevice *dev, + unsigned int offset, int value) +{ + struct octeon_gpio *gpio = dev_get_priv(dev); + + debug("%s(%s, %u, %d)\n", __func__, dev->name, offset, value); + writeq(GPIO_BIT(offset), gpio->base + gpio->data->reg_offs + + gpio_tx_reg(offset, value)); + + return 0; +} + +static int octeon_gpio_get_function(struct udevice *dev, unsigned int offset) +{ + struct octeon_gpio *gpio = dev_get_priv(dev); + u64 val = readq(gpio->base + gpio->data->gpio_bit_cfg_offs + + 8 * offset); + int pin_sel; + + debug("%s(%s, %u): GPIO_BIT_CFG: 0x%llx\n", __func__, dev->name, + offset, val); + pin_sel = FIELD_GET(GPIO_BIT_CFG_PIN_SEL_MASK, val); + if (pin_sel) + return GPIOF_FUNC; + else if (val & GPIO_BIT_CFG_TX_OE) + return GPIOF_OUTPUT; + else + return GPIOF_INPUT; +} + +static int octeon_gpio_xlate(struct udevice *dev, struct gpio_desc *desc, + struct ofnode_phandle_args *args) +{ + if (args->args_count < 1) + return -EINVAL; + + desc->offset = args->args[0]; + desc->flags = 0; + if (args->args_count > 1) { + if (args->args[1] & GPIO_ACTIVE_LOW) + desc->flags |= GPIOD_ACTIVE_LOW; + /* In the future add tri-state flag support */ + } + return 0; +} + +static const struct dm_gpio_ops octeon_gpio_ops = { + .direction_input = octeon_gpio_dir_input, + .direction_output = octeon_gpio_dir_output, + .get_value = octeon_gpio_get_value, + .set_value = octeon_gpio_set_value, + .get_function = octeon_gpio_get_function, + .xlate = octeon_gpio_xlate, +}; + +static int octeon_gpio_probe(struct udevice *dev) +{ + struct gpio_dev_priv *uc_priv = dev_get_uclass_priv(dev); + struct octeon_gpio *priv = dev_get_priv(dev); + char *end; + + priv->data = (const struct octeon_gpio_data *)dev_get_driver_data(dev); + + if (priv->data->probe == PROBE_PCI) { + priv->base = dm_pci_map_bar(dev, PCI_BASE_ADDRESS_0, + PCI_REGION_MEM); + uc_priv->gpio_count = readq(priv->base + + priv->data->reg_offs + GPIO_CONST) & + GPIO_CONST_GPIOS_MASK; + } else { + priv->base = dev_remap_addr(dev); + uc_priv->gpio_count = ofnode_read_u32_default(dev->node, + "nr-gpios", 32); + } + + if (!priv->base) { + debug("%s(%s): Could not get base address\n", + __func__, dev->name); + return -ENODEV; + } + + uc_priv->bank_name = strdup(dev->name); + end = strchr(uc_priv->bank_name, '@'); + end[0] = 'A' + dev->seq; + end[1] = '\0'; + + debug("%s(%s): base address: %p, pin count: %d\n", + __func__, dev->name, priv->base, uc_priv->gpio_count); + + return 0; +} + +static const struct octeon_gpio_data gpio_octeon_data = { + .probe = PROBE_DT, + .reg_offs = 0x80, + .gpio_bit_cfg_offs = 0x100, +}; + +static const struct octeon_gpio_data gpio_octeontx_data = { + .probe = PROBE_PCI, + .reg_offs = 0x00, + .gpio_bit_cfg_offs = 0x400, +}; + +static const struct udevice_id octeon_gpio_ids[] = { + { .compatible = "cavium,thunder-8890-gpio", + .data = (ulong)&gpio_octeontx_data }, + { .compatible = "cavium,octeon-7890-gpio", + .data = (ulong)&gpio_octeon_data }, + { } +}; + +U_BOOT_DRIVER(octeon_gpio) = { + .name = "octeon_gpio", + .id = UCLASS_GPIO, + .of_match = of_match_ptr(octeon_gpio_ids), + .probe = octeon_gpio_probe, + .priv_auto_alloc_size = sizeof(struct octeon_gpio), + .ops = &octeon_gpio_ops, + .flags = DM_FLAG_PRE_RELOC, +};
Add the Octeon GPIO DT node to the dtsi file.
Signed-off-by: Stefan Roese sr@denx.de ---
(no changes since v1)
arch/mips/dts/mrvl,cn73xx.dtsi | 26 ++++++++++++++++++++++++++ 1 file changed, 26 insertions(+)
diff --git a/arch/mips/dts/mrvl,cn73xx.dtsi b/arch/mips/dts/mrvl,cn73xx.dtsi index a7bd55f8ad..8d32a49795 100644 --- a/arch/mips/dts/mrvl,cn73xx.dtsi +++ b/arch/mips/dts/mrvl,cn73xx.dtsi @@ -38,6 +38,32 @@ #size-cells = <1>; };
+ gpio: gpio-controller@1070000000800 { + #gpio-cells = <2>; + compatible = "cavium,octeon-7890-gpio"; + reg = <0x10700 0x00000800 0x0 0x100>; + gpio-controller; + nr-gpios = <32>; + /* Interrupts are specified by two parts: + * 1) GPIO pin number (0..15) + * 2) Triggering (1 - edge rising + * 2 - edge falling + * 4 - level active high + * 8 - level active low) + */ + interrupt-controller; + #interrupt-cells = <2>; + /* The GPIO pins connect to 16 consecutive CUI bits */ + interrupts = <0x03000 4>, <0x03001 4>, + <0x03002 4>, <0x03003 4>, + <0x03004 4>, <0x03005 4>, + <0x03006 4>, <0x03007 4>, + <0x03008 4>, <0x03009 4>, + <0x0300a 4>, <0x0300b 4>, + <0x0300c 4>, <0x0300d 4>, + <0x0300e 4>, <0x0300f 4>; + }; + reset: reset@1180006001600 { compatible = "mrvl,cn7xxx-rst"; reg = <0x11800 0x06001600 0x0 0x200>;
Add I2C DT nodes to the Octeon dts / dtsi files.
arch/mips/dts/mrvl,cn73xx.dtsi | 20 ++++++++++++++++++++ arch/mips/dts/mrvl,octeon-ebb7304.dts | 10 ++++++++++ 2 files changed, 30 insertions(+)
diff --git a/arch/mips/dts/mrvl,cn73xx.dtsi b/arch/mips/dts/mrvl,cn73xx.dtsi index 8d32a49795..4c7b6e4160 100644 --- a/arch/mips/dts/mrvl,cn73xx.dtsi +++ b/arch/mips/dts/mrvl,cn73xx.dtsi @@ -86,5 +86,25 @@ reg-shift = <3>; interrupts = <0x08040 4>; }; + + i2c0: i2c@1180000001000 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "cavium,octeon-7890-twsi"; + reg = <0x11800 0x00001000 0x0 0x200>; + /* INT_ST, INT_TS, INT_CORE */ + interrupts = <0x0b000 1>, <0x0b001 1>, <0x0b002 1>; + clock-frequency = <100000>; + }; + + i2c1: i2c@1180000001200 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "cavium,octeon-7890-twsi"; + reg = <0x11800 0x00001200 0x0 0x200>; + /* INT_ST, INT_TS, INT_CORE */ + interrupts = <0x0b100 1>, <0x0b101 1>, <0x0b102 1>; + clock-frequency = <100000>; + }; }; }; diff --git a/arch/mips/dts/mrvl,octeon-ebb7304.dts b/arch/mips/dts/mrvl,octeon-ebb7304.dts index 4e9c2de7d4..096e5c8f66 100644 --- a/arch/mips/dts/mrvl,octeon-ebb7304.dts +++ b/arch/mips/dts/mrvl,octeon-ebb7304.dts @@ -94,3 +94,13 @@ &uart0 { clock-frequency = <1200000000>; }; + +&i2c0 { + u-boot,dm-pre-reloc; /* Needed early for DDR SPD EEPROM */ + clock-frequency = <100000>; +}; + +&i2c1 { + u-boot,dm-pre-reloc; /* Needed early for DDR SPD EEPROM */ + clock-frequency = <100000>; +};
This patch adds a simple clock driver for the Marvell Octeon MIPS SoC family. Its for IO clock rate passing via DT in some of the Octeon driver, like I2C. So that we don't need to use the non-mainline API octeon_get_io_clock().
Signed-off-by: Stefan Roese sr@denx.de Cc: Lukasz Majewski lukma@denx.de ---
drivers/clk/Kconfig | 7 +++ drivers/clk/Makefile | 1 + drivers/clk/clk_octeon.c | 72 ++++++++++++++++++++++++ include/dt-bindings/clock/octeon-clock.h | 12 ++++ 4 files changed, 92 insertions(+) create mode 100644 drivers/clk/clk_octeon.c create mode 100644 include/dt-bindings/clock/octeon-clock.h
diff --git a/drivers/clk/Kconfig b/drivers/clk/Kconfig index 82cb1874e1..6003e140b5 100644 --- a/drivers/clk/Kconfig +++ b/drivers/clk/Kconfig @@ -83,6 +83,13 @@ config CLK_INTEL set up by U-Boot itself but only statically. Thus the driver does not support changing clock rates, only querying them.
+config CLK_OCTEON + bool "Clock controller driver for Marvell MIPS Octeon" + depends on CLK && ARCH_OCTEON + default y + help + Enable this to support the clocks on Octeon MIPS platforms. + config CLK_STM32F bool "Enable clock driver support for STM32F family" depends on CLK && (STM32F7 || STM32F4) diff --git a/drivers/clk/Makefile b/drivers/clk/Makefile index d911954581..cda4b4b605 100644 --- a/drivers/clk/Makefile +++ b/drivers/clk/Makefile @@ -29,6 +29,7 @@ obj-$(CONFIG_$(SPL_TPL_)CLK_INTEL) += intel/ obj-$(CONFIG_CLK_HSDK) += clk-hsdk-cgu.o obj-$(CONFIG_CLK_K210) += kendryte/ obj-$(CONFIG_CLK_MPC83XX) += mpc83xx_clk.o +obj-$(CONFIG_CLK_OCTEON) += clk_octeon.o obj-$(CONFIG_CLK_OWL) += owl/ obj-$(CONFIG_CLK_RENESAS) += renesas/ obj-$(CONFIG_CLK_SIFIVE) += sifive/ diff --git a/drivers/clk/clk_octeon.c b/drivers/clk/clk_octeon.c new file mode 100644 index 0000000000..fd559e05fc --- /dev/null +++ b/drivers/clk/clk_octeon.c @@ -0,0 +1,72 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2020 Stefan Roese sr@denx.de + */ + +#include <clk-uclass.h> +#include <dm.h> +#include <dt-bindings/clock/octeon-clock.h> + +DECLARE_GLOBAL_DATA_PTR; + +struct octeon_clk_priv { + u64 core_clk; + u64 io_clk; +}; + +static int octeon_clk_enable(struct clk *clk) +{ + /* Nothing to do on Octeon */ + return 0; +} + +static ulong octeon_clk_get_rate(struct clk *clk) +{ + struct octeon_clk_priv *priv = dev_get_priv(clk->dev); + + switch (clk->id) { + case OCTEON_CLK_CORE: + return priv->core_clk; + + case OCTEON_CLK_IO: + return priv->io_clk; + + default: + return 0; + } + + return 0; +} + +static struct clk_ops octeon_clk_ops = { + .enable = octeon_clk_enable, + .get_rate = octeon_clk_get_rate, +}; + +static const struct udevice_id octeon_clk_ids[] = { + { .compatible = "mrvl,octeon-clk" }, + { /* sentinel */ } +}; + +static int octeon_clk_probe(struct udevice *dev) +{ + struct octeon_clk_priv *priv = dev_get_priv(dev); + + /* + * The clock values are already read into GD, lets just store them + * in priv data + */ + priv->core_clk = gd->cpu_clk; + priv->io_clk = gd->bus_clk; + + return 0; +} + +U_BOOT_DRIVER(clk_octeon) = { + .name = "clk_octeon", + .id = UCLASS_CLK, + .of_match = octeon_clk_ids, + .ops = &octeon_clk_ops, + .probe = octeon_clk_probe, + .priv_auto_alloc_size = sizeof(struct octeon_clk_priv), +}; diff --git a/include/dt-bindings/clock/octeon-clock.h b/include/dt-bindings/clock/octeon-clock.h new file mode 100644 index 0000000000..34e6a3bf41 --- /dev/null +++ b/include/dt-bindings/clock/octeon-clock.h @@ -0,0 +1,12 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Copyright (C) 2020 Stefan Roese sr@denx.de + */ + +#ifndef __DT_BINDINGS_CLOCK_OCTEON_CLOCK_H +#define __DT_BINDINGS_CLOCK_OCTEON_CLOCK_H + +#define OCTEON_CLK_CORE 0 +#define OCTEON_CLK_IO 1 + +#endif /* __DT_BINDINGS_CLOCK_OCTEON_CLOCK_H */
This patch adds the DT nodes for the Octeon clock support via the common clk_ API.
arch/mips/dts/mrvl,cn73xx.dtsi | 10 ++++++++++ arch/mips/dts/mrvl,octeon-ebb7304.dts | 2 +- 2 files changed, 11 insertions(+), 1 deletion(-)
diff --git a/arch/mips/dts/mrvl,cn73xx.dtsi b/arch/mips/dts/mrvl,cn73xx.dtsi index 4c7b6e4160..7c0a8d73f0 100644 --- a/arch/mips/dts/mrvl,cn73xx.dtsi +++ b/arch/mips/dts/mrvl,cn73xx.dtsi @@ -5,6 +5,8 @@
/dts-v1/;
+#include <dt-bindings/clock/octeon-clock.h> + / { #address-cells = <2>; #size-cells = <2>; @@ -38,6 +40,12 @@ #size-cells = <1>; };
+ clk: clock { + compatible = "mrvl,octeon-clk"; + #clock-cells = <1>; + u-boot,dm-pre-reloc; + }; + gpio: gpio-controller@1070000000800 { #gpio-cells = <2>; compatible = "cavium,octeon-7890-gpio"; @@ -95,6 +103,7 @@ /* INT_ST, INT_TS, INT_CORE */ interrupts = <0x0b000 1>, <0x0b001 1>, <0x0b002 1>; clock-frequency = <100000>; + clocks = <&clk OCTEON_CLK_IO>; };
i2c1: i2c@1180000001200 { @@ -105,6 +114,7 @@ /* INT_ST, INT_TS, INT_CORE */ interrupts = <0x0b100 1>, <0x0b101 1>, <0x0b102 1>; clock-frequency = <100000>; + clocks = <&clk OCTEON_CLK_IO>; }; }; }; diff --git a/arch/mips/dts/mrvl,octeon-ebb7304.dts b/arch/mips/dts/mrvl,octeon-ebb7304.dts index 096e5c8f66..c229aa5fc0 100644 --- a/arch/mips/dts/mrvl,octeon-ebb7304.dts +++ b/arch/mips/dts/mrvl,octeon-ebb7304.dts @@ -5,7 +5,7 @@
/dts-v1/;
-/include/ "mrvl,cn73xx.dtsi" +#include "mrvl,cn73xx.dtsi"
/ { model = "cavium,ebb7304";
Adds support for SPI controllers found on Octeon II/III and Octeon TX TX2 SoC platforms.
Signed-off-by: Aaron Williams awilliams@marvell.com Signed-off-by: Suneel Garapati sgarapati@marvell.com Signed-off-by: Stefan Roese sr@denx.de Cc: Daniel Schwierzeck daniel.schwierzeck@gmail.com Cc: Aaron Williams awilliams@marvell.com Cc: Chandrakala Chavva cchavva@marvell.com Cc: Jagan Teki jagan@amarulasolutions.com
Changes in v2: - Newly added to this series - Removed inclusion of "common.h" - Added "depends on DM_PCI" to Kconfig - Tested on MIPS Octeon and ARM Octeon TX2 - Fixed issues with Octeon TX2 registration. Now only one driver is registered and the "ops" is overwritten in the Octeon TX2 case. - Use dev_get_driver_data() to get the driver data struct - Removed "struct pci_device_id" definition and U_BOOT_PCI_DEVICE() as its not needed for the PCI based probing on Octeon TX2
drivers/spi/Kconfig | 8 + drivers/spi/Makefile | 1 + drivers/spi/octeon_spi.c | 647 +++++++++++++++++++++++++++++++++++++++ 3 files changed, 656 insertions(+) create mode 100644 drivers/spi/octeon_spi.c
diff --git a/drivers/spi/Kconfig b/drivers/spi/Kconfig index 30d808d7bb..3fc2d0674a 100644 --- a/drivers/spi/Kconfig +++ b/drivers/spi/Kconfig @@ -240,6 +240,14 @@ config NXP_FSPI Enable the NXP FlexSPI (FSPI) driver. This driver can be used to access the SPI NOR flash on platforms embedding this NXP IP core.
+config OCTEON_SPI + bool "Octeon SPI driver" + depends on DM_PCI && (ARCH_OCTEON || ARCH_OCTEONTX || ARCH_OCTEONTX2) + help + Enable the Octeon SPI driver. This driver can be used to + access the SPI NOR flash on Octeon II/III and OcteonTX/TX2 + SoC platforms. + config OMAP3_SPI bool "McSPI driver for OMAP" help diff --git a/drivers/spi/Makefile b/drivers/spi/Makefile index 4e7461771f..b5c9ff1af8 100644 --- a/drivers/spi/Makefile +++ b/drivers/spi/Makefile @@ -43,6 +43,7 @@ obj-$(CONFIG_MXC_SPI) += mxc_spi.o obj-$(CONFIG_MXS_SPI) += mxs_spi.o obj-$(CONFIG_NXP_FSPI) += nxp_fspi.o obj-$(CONFIG_ATCSPI200_SPI) += atcspi200_spi.o +obj-$(CONFIG_OCTEON_SPI) += octeon_spi.o obj-$(CONFIG_OMAP3_SPI) += omap3_spi.o obj-$(CONFIG_PIC32_SPI) += pic32_spi.o obj-$(CONFIG_PL022_SPI) += pl022_spi.o diff --git a/drivers/spi/octeon_spi.c b/drivers/spi/octeon_spi.c new file mode 100644 index 0000000000..2fb39e444c --- /dev/null +++ b/drivers/spi/octeon_spi.c @@ -0,0 +1,647 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright (C) 2018 Marvell International Ltd. + * + * https://spdx.org/licenses + */ + +#include <clk.h> +#include <dm.h> +#include <malloc.h> +#include <spi.h> +#include <spi-mem.h> +#include <watchdog.h> +#include <asm/io.h> +#include <asm/unaligned.h> +#include <linux/bitfield.h> +#include <linux/compat.h> +#include <linux/delay.h> + +#define OCTEON_SPI_MAX_BYTES 9 +#define OCTEON_SPI_MAX_CLOCK_HZ 50000000 + +#define OCTEON_SPI_NUM_CS 4 + +#define OCTEON_SPI_CS_VALID(cs) ((cs) < OCTEON_SPI_NUM_CS) + +#define MPI_CFG 0x0000 +#define MPI_STS 0x0008 +#define MPI_TX 0x0010 +#define MPI_XMIT 0x0018 +#define MPI_WIDE_DAT 0x0040 +#define MPI_IO_CTL 0x0048 +#define MPI_DAT(X) (0x0080 + ((X) << 3)) +#define MPI_WIDE_BUF(X) (0x0800 + ((X) << 3)) +#define MPI_CYA_CFG 0x1000 +#define MPI_CLKEN 0x1080 + +#define MPI_CFG_ENABLE BIT_ULL(0) +#define MPI_CFG_IDLELO BIT_ULL(1) +#define MPI_CFG_CLK_CONT BIT_ULL(2) +#define MPI_CFG_WIREOR BIT_ULL(3) +#define MPI_CFG_LSBFIRST BIT_ULL(4) +#define MPI_CFG_CS_STICKY BIT_ULL(5) +#define MPI_CFG_CSHI BIT_ULL(7) +#define MPI_CFG_IDLECLKS GENMASK_ULL(9, 8) +#define MPI_CFG_TRITX BIT_ULL(10) +#define MPI_CFG_CSLATE BIT_ULL(11) +#define MPI_CFG_CSENA0 BIT_ULL(12) +#define MPI_CFG_CSENA1 BIT_ULL(13) +#define MPI_CFG_CSENA2 BIT_ULL(14) +#define MPI_CFG_CSENA3 BIT_ULL(15) +#define MPI_CFG_CLKDIV GENMASK_ULL(28, 16) +#define MPI_CFG_LEGACY_DIS BIT_ULL(31) +#define MPI_CFG_IOMODE GENMASK_ULL(35, 34) +#define MPI_CFG_TB100_EN BIT_ULL(49) + +#define MPI_DAT_DATA GENMASK_ULL(7, 0) + +#define MPI_STS_BUSY BIT_ULL(0) +#define MPI_STS_MPI_INTR BIT_ULL(1) +#define MPI_STS_RXNUM GENMASK_ULL(12, 8) + +#define MPI_TX_TOTNUM GENMASK_ULL(4, 0) +#define MPI_TX_TXNUM GENMASK_ULL(12, 8) +#define MPI_TX_LEAVECS BIT_ULL(16) +#define MPI_TX_CSID GENMASK_ULL(21, 20) + +#define MPI_XMIT_TOTNUM GENMASK_ULL(10, 0) +#define MPI_XMIT_TXNUM GENMASK_ULL(30, 20) +#define MPI_XMIT_BUF_SEL BIT_ULL(59) +#define MPI_XMIT_LEAVECS BIT_ULL(60) +#define MPI_XMIT_CSID GENMASK_ULL(62, 61) + +enum { + PROBE_PCI = 0, /* PCI based probing */ + PROBE_DT, /* DT based probing */ +}; + +/* Used on Octeon TX2 */ +void board_acquire_flash_arb(bool acquire); + +struct octeon_spi_data { + int probe; + u32 reg_offs; +}; + +/* Local driver data structure */ +struct octeon_spi { + void __iomem *base; /* Register base address */ + struct clk clk; + u32 clkdiv; /* Clock divisor for device speed */ +}; + +static u64 octeon_spi_set_mpicfg(struct udevice *dev) +{ + struct dm_spi_slave_platdata *slave = dev_get_parent_platdata(dev); + struct udevice *bus = dev_get_parent(dev); + struct octeon_spi *priv = dev_get_priv(bus); + u64 mpi_cfg; + uint max_speed = slave->max_hz; + bool cpha, cpol; + + if (!max_speed) + max_speed = 12500000; + if (max_speed > OCTEON_SPI_MAX_CLOCK_HZ) + max_speed = OCTEON_SPI_MAX_CLOCK_HZ; + + debug("\n slave params %d %d %d\n", slave->cs, + slave->max_hz, slave->mode); + cpha = !!(slave->mode & SPI_CPHA); + cpol = !!(slave->mode & SPI_CPOL); + + mpi_cfg = FIELD_PREP(MPI_CFG_CLKDIV, priv->clkdiv & 0x1fff) | + FIELD_PREP(MPI_CFG_CSHI, !!(slave->mode & SPI_CS_HIGH)) | + FIELD_PREP(MPI_CFG_LSBFIRST, !!(slave->mode & SPI_LSB_FIRST)) | + FIELD_PREP(MPI_CFG_WIREOR, !!(slave->mode & SPI_3WIRE)) | + FIELD_PREP(MPI_CFG_IDLELO, cpha != cpol) | + FIELD_PREP(MPI_CFG_CSLATE, cpha) | + MPI_CFG_CSENA0 | MPI_CFG_CSENA1 | + MPI_CFG_CSENA2 | MPI_CFG_CSENA1 | + MPI_CFG_ENABLE; + + debug("\n mpi_cfg %llx\n", mpi_cfg); + return mpi_cfg; +} + +/** + * Wait until the SPI bus is ready + * + * @param dev SPI device to wait for + */ +static void octeon_spi_wait_ready(struct udevice *dev) +{ + struct udevice *bus = dev_get_parent(dev); + struct octeon_spi *priv = dev_get_priv(bus); + void *base = priv->base; + u64 mpi_sts; + + do { + mpi_sts = readq(base + MPI_STS); + WATCHDOG_RESET(); + } while (mpi_sts & MPI_STS_BUSY); + + debug("%s(%s)\n", __func__, dev->name); +} + +/** + * Claim the bus for a slave device + * + * @param dev SPI bus + * + * @return 0 for success, -EINVAL if chip select is invalid + */ +static int octeon_spi_claim_bus(struct udevice *dev) +{ + struct udevice *bus = dev_get_parent(dev); + struct octeon_spi *priv = dev_get_priv(bus); + void *base = priv->base; + u64 mpi_cfg; + + debug("\n\n%s(%s)\n", __func__, dev->name); + if (!OCTEON_SPI_CS_VALID(spi_chip_select(dev))) + return -EINVAL; + + if (IS_ENABLED(CONFIG_ARCH_OCTEONTX2)) + board_acquire_flash_arb(true); + + mpi_cfg = readq(base + MPI_CFG); + mpi_cfg &= ~MPI_CFG_TRITX; + mpi_cfg |= MPI_CFG_ENABLE; + writeq(mpi_cfg, base + MPI_CFG); + mpi_cfg = readq(base + MPI_CFG); + udelay(5); /** Wait for bus to settle */ + + return 0; +} + +/** + * Release the bus to a slave device + * + * @param dev SPI bus + * + * @return 0 for success, -EINVAL if chip select is invalid + */ +static int octeon_spi_release_bus(struct udevice *dev) +{ + struct udevice *bus = dev_get_parent(dev); + struct octeon_spi *priv = dev_get_priv(bus); + void *base = priv->base; + u64 mpi_cfg; + + debug("%s(%s)\n\n", __func__, dev->name); + if (!OCTEON_SPI_CS_VALID(spi_chip_select(dev))) + return -EINVAL; + + if (IS_ENABLED(CONFIG_ARCH_OCTEONTX2)) + board_acquire_flash_arb(false); + + mpi_cfg = readq(base + MPI_CFG); + mpi_cfg &= ~MPI_CFG_ENABLE; + writeq(mpi_cfg, base + MPI_CFG); + mpi_cfg = readq(base + MPI_CFG); + udelay(1); + + return 0; +} + +static int octeon_spi_xfer(struct udevice *dev, unsigned int bitlen, + const void *dout, void *din, unsigned long flags) +{ + struct udevice *bus = dev_get_parent(dev); + struct octeon_spi *priv = dev_get_priv(bus); + void *base = priv->base; + u64 mpi_tx; + u64 mpi_cfg; + u64 wide_dat = 0; + int len = bitlen / 8; + int i; + const u8 *tx_data = dout; + u8 *rx_data = din; + int cs = spi_chip_select(dev); + + if (!OCTEON_SPI_CS_VALID(cs)) + return -EINVAL; + + debug("\n %s(%s, %u, %p, %p, 0x%lx), cs: %d\n", + __func__, dev->name, bitlen, dout, din, flags, cs); + + mpi_cfg = octeon_spi_set_mpicfg(dev); + if (mpi_cfg != readq(base + MPI_CFG)) { + writeq(mpi_cfg, base + MPI_CFG); + mpi_cfg = readq(base + MPI_CFG); + udelay(10); + } + + debug("\n mpi_cfg upd %llx\n", mpi_cfg); + + /* + * Start by writing and reading 8 bytes at a time. While we can support + * up to 10, it's easier to just use 8 with the MPI_WIDE_DAT register. + */ + while (len > 8) { + if (tx_data) { + wide_dat = get_unaligned((u64 *)tx_data); + debug(" tx: %016llx \t", (unsigned long long)wide_dat); + tx_data += 8; + writeq(wide_dat, base + MPI_WIDE_DAT); + } + + mpi_tx = FIELD_PREP(MPI_TX_CSID, cs) | + FIELD_PREP(MPI_TX_LEAVECS, 1) | + FIELD_PREP(MPI_TX_TXNUM, tx_data ? 8 : 0) | + FIELD_PREP(MPI_TX_TOTNUM, 8); + writeq(mpi_tx, base + MPI_TX); + + octeon_spi_wait_ready(dev); + + debug("\n "); + + if (rx_data) { + wide_dat = readq(base + MPI_WIDE_DAT); + debug(" rx: %016llx\t", (unsigned long long)wide_dat); + *(u64 *)rx_data = wide_dat; + rx_data += 8; + } + len -= 8; + } + + debug("\n "); + + /* Write and read the rest of the data */ + if (tx_data) { + for (i = 0; i < len; i++) { + debug(" tx: %02x\n", *tx_data); + writeq(*tx_data++, base + MPI_DAT(i)); + } + } + + mpi_tx = FIELD_PREP(MPI_TX_CSID, cs) | + FIELD_PREP(MPI_TX_LEAVECS, !(flags & SPI_XFER_END)) | + FIELD_PREP(MPI_TX_TXNUM, tx_data ? len : 0) | + FIELD_PREP(MPI_TX_TOTNUM, len); + writeq(mpi_tx, base + MPI_TX); + + octeon_spi_wait_ready(dev); + + debug("\n "); + + if (rx_data) { + for (i = 0; i < len; i++) { + *rx_data = readq(base + MPI_DAT(i)) & 0xff; + debug(" rx: %02x\n", *rx_data); + rx_data++; + } + } + + return 0; +} + +static int octeontx2_spi_xfer(struct udevice *dev, unsigned int bitlen, + const void *dout, void *din, unsigned long flags) +{ + struct udevice *bus = dev_get_parent(dev); + struct octeon_spi *priv = dev_get_priv(bus); + void *base = priv->base; + u64 mpi_xmit; + u64 mpi_cfg; + u64 wide_dat = 0; + int len = bitlen / 8; + int rem; + int i; + const u8 *tx_data = dout; + u8 *rx_data = din; + int cs = spi_chip_select(dev); + + if (!OCTEON_SPI_CS_VALID(cs)) + return -EINVAL; + + debug("\n %s(%s, %u, %p, %p, 0x%lx), cs: %d\n", + __func__, dev->name, bitlen, dout, din, flags, cs); + + mpi_cfg = octeon_spi_set_mpicfg(dev); + + mpi_cfg |= MPI_CFG_TRITX | MPI_CFG_LEGACY_DIS | MPI_CFG_CS_STICKY | + MPI_CFG_TB100_EN; + + mpi_cfg &= ~MPI_CFG_IOMODE; + if (flags & (SPI_TX_DUAL | SPI_RX_DUAL)) + mpi_cfg |= FIELD_PREP(MPI_CFG_IOMODE, 2); + if (flags & (SPI_TX_QUAD | SPI_RX_QUAD)) + mpi_cfg |= FIELD_PREP(MPI_CFG_IOMODE, 3); + + if (mpi_cfg != readq(base + MPI_CFG)) { + writeq(mpi_cfg, base + MPI_CFG); + mpi_cfg = readq(base + MPI_CFG); + udelay(10); + } + + debug("\n mpi_cfg upd %llx\n\n", mpi_cfg); + + /* Start by writing or reading 1024 bytes at a time. */ + while (len > 1024) { + if (tx_data) { + /* 8 bytes per iteration */ + for (i = 0; i < 128; i++) { + wide_dat = get_unaligned((u64 *)tx_data); + debug(" tx: %016llx \t", + (unsigned long long)wide_dat); + if ((i % 4) == 3) + debug("\n"); + tx_data += 8; + writeq(wide_dat, base + MPI_WIDE_BUF(i)); + } + } + + mpi_xmit = FIELD_PREP(MPI_XMIT_CSID, cs) | MPI_XMIT_LEAVECS | + FIELD_PREP(MPI_XMIT_TXNUM, tx_data ? 1024 : 0) | + FIELD_PREP(MPI_XMIT_TOTNUM, 1024); + writeq(mpi_xmit, base + MPI_XMIT); + + octeon_spi_wait_ready(dev); + + debug("\n "); + + if (rx_data) { + /* 8 bytes per iteration */ + for (i = 0; i < 128; i++) { + wide_dat = readq(base + MPI_WIDE_BUF(i)); + debug(" rx: %016llx\t", + (unsigned long long)wide_dat); + if ((i % 4) == 3) + debug("\n"); + *(u64 *)rx_data = wide_dat; + rx_data += 8; + } + } + len -= 1024; + } + + if (tx_data) { + rem = len % 8; + /* 8 bytes per iteration */ + for (i = 0; i < len / 8; i++) { + wide_dat = get_unaligned((u64 *)tx_data); + debug(" tx: %016llx \t", + (unsigned long long)wide_dat); + if ((i % 4) == 3) + debug("\n"); + tx_data += 8; + writeq(wide_dat, base + MPI_WIDE_BUF(i)); + } + if (rem) { + memcpy(&wide_dat, tx_data, rem); + debug(" rtx: %016llx\t", wide_dat); + writeq(wide_dat, base + MPI_WIDE_BUF(i)); + } + } + + mpi_xmit = FIELD_PREP(MPI_XMIT_CSID, cs) | + FIELD_PREP(MPI_XMIT_LEAVECS, !(flags & SPI_XFER_END)) | + FIELD_PREP(MPI_XMIT_TXNUM, tx_data ? len : 0) | + FIELD_PREP(MPI_XMIT_TOTNUM, len); + writeq(mpi_xmit, base + MPI_XMIT); + + octeon_spi_wait_ready(dev); + + debug("\n "); + + if (rx_data) { + rem = len % 8; + /* 8 bytes per iteration */ + for (i = 0; i < len / 8; i++) { + wide_dat = readq(base + MPI_WIDE_BUF(i)); + debug(" rx: %016llx\t", + (unsigned long long)wide_dat); + if ((i % 4) == 3) + debug("\n"); + *(u64 *)rx_data = wide_dat; + rx_data += 8; + } + if (rem) { + wide_dat = readq(base + MPI_WIDE_BUF(i)); + debug(" rrx: %016llx\t", + (unsigned long long)wide_dat); + memcpy(rx_data, &wide_dat, rem); + rx_data += rem; + } + } + + return 0; +} + +static bool octeon_spi_supports_op(struct spi_slave *slave, + const struct spi_mem_op *op) +{ + /* For now, support only below combinations + * 1-1-1 + * 1-1-2 1-2-2 + * 1-1-4 1-4-4 + */ + if (op->cmd.buswidth != 1) + return false; + return true; +} + +static int octeon_spi_exec_op(struct spi_slave *slave, + const struct spi_mem_op *op) +{ + unsigned long flags = SPI_XFER_BEGIN; + const void *tx; + void *rx; + u8 opcode, *buf; + u8 *addr; + int i, temp, ret; + + if (op->cmd.buswidth != 1) + return -ENOTSUPP; + + /* Send CMD */ + i = 0; + opcode = op->cmd.opcode; + + if (!op->data.nbytes && !op->addr.nbytes && !op->dummy.nbytes) + flags |= SPI_XFER_END; + + ret = octeontx2_spi_xfer(slave->dev, 8, (void *)&opcode, NULL, flags); + if (ret < 0) + return ret; + + /* Send Address and dummy */ + if (op->addr.nbytes) { + /* Alloc buffer for address+dummy */ + buf = (u8 *)calloc(1, op->addr.nbytes + op->dummy.nbytes); + if (!buf) { + printf("%s Out of memory\n", __func__); + return -ENOMEM; + } + addr = (u8 *)&op->addr.val; + for (temp = 0; temp < op->addr.nbytes; temp++) + buf[i++] = *(u8 *)(addr + op->addr.nbytes - 1 - temp); + for (temp = 0; temp < op->dummy.nbytes; temp++) + buf[i++] = 0xff; + if (op->addr.buswidth == 2) + flags |= SPI_RX_DUAL; + if (op->addr.buswidth == 4) + flags |= SPI_RX_QUAD; + + if (!op->data.nbytes) + flags |= SPI_XFER_END; + ret = octeontx2_spi_xfer(slave->dev, i * 8, (void *)buf, NULL, + flags); + free(buf); + if (ret < 0) + return ret; + } + if (!op->data.nbytes) + return 0; + + /* Send/Receive Data */ + flags |= SPI_XFER_END; + if (op->data.buswidth == 2) + flags |= SPI_RX_DUAL; + if (op->data.buswidth == 4) + flags |= SPI_RX_QUAD; + + rx = (op->data.dir == SPI_MEM_DATA_IN) ? op->data.buf.in : NULL; + tx = (op->data.dir == SPI_MEM_DATA_OUT) ? op->data.buf.out : NULL; + + ret = octeontx2_spi_xfer(slave->dev, (op->data.nbytes * 8), tx, rx, + flags); + return ret; +} + +static const struct spi_controller_mem_ops octeontx2_spi_mem_ops = { + .supports_op = octeon_spi_supports_op, + .exec_op = octeon_spi_exec_op, +}; + +/** + * Set the speed of the SPI bus + * + * @param bus bus to set + * @param max_hz maximum speed supported + */ +static int octeon_spi_set_speed(struct udevice *bus, uint max_hz) +{ + struct octeon_spi *priv = dev_get_priv(bus); + ulong clk_rate; + u32 calc_hz; + + if (max_hz > OCTEON_SPI_MAX_CLOCK_HZ) + max_hz = OCTEON_SPI_MAX_CLOCK_HZ; + + clk_rate = clk_get_rate(&priv->clk); + if (IS_ERR_VALUE(clk_rate)) + return -EINVAL; + + debug("%s(%s, %u, %lu)\n", __func__, bus->name, max_hz, clk_rate); + + priv->clkdiv = clk_rate / (2 * max_hz); + while (1) { + calc_hz = clk_rate / (2 * priv->clkdiv); + if (calc_hz <= max_hz) + break; + priv->clkdiv += 1; + } + + if (priv->clkdiv > 8191) + return -EINVAL; + + debug("%s: clkdiv=%d\n", __func__, priv->clkdiv); + + return 0; +} + +static int octeon_spi_set_mode(struct udevice *bus, uint mode) +{ + /* We don't set it here */ + return 0; +} + +static const struct dm_spi_ops octeon_spi_ops = { + .claim_bus = octeon_spi_claim_bus, + .release_bus = octeon_spi_release_bus, + .set_speed = octeon_spi_set_speed, + .set_mode = octeon_spi_set_mode, + .xfer = octeon_spi_xfer, +}; + +static const struct dm_spi_ops octeontx2_spi_ops = { + .claim_bus = octeon_spi_claim_bus, + .release_bus = octeon_spi_release_bus, + .set_speed = octeon_spi_set_speed, + .set_mode = octeon_spi_set_mode, + .xfer = octeontx2_spi_xfer, + .mem_ops = &octeontx2_spi_mem_ops, +}; + +static int octeon_spi_probe(struct udevice *dev) +{ + struct octeon_spi *priv = dev_get_priv(dev); + const struct octeon_spi_data *data; + int ret; + + data = (const struct octeon_spi_data *)dev_get_driver_data(dev); + if (data->probe == PROBE_PCI) { + pci_dev_t bdf = dm_pci_get_bdf(dev); + + debug("SPI PCI device: %x\n", bdf); + priv->base = dm_pci_map_bar(dev, PCI_BASE_ADDRESS_0, + PCI_REGION_MEM); + } else { + priv->base = dev_remap_addr(dev); + } + + priv->base += data->reg_offs; + + /* Octeon TX2 needs a different ops struct */ + if (device_is_compatible(dev, "cavium,thunderx-spi")) { + /* + * "ops" is const and can't be written directly. So we need + * to write the Octeon TX2 ops value using this trick + */ + writeq((u64)&octeontx2_spi_ops, (void *)&dev->driver->ops); + } + + ret = clk_get_by_index(dev, 0, &priv->clk); + if (ret < 0) + return ret; + + ret = clk_enable(&priv->clk); + if (ret) + return ret; + + debug("SPI bus %s %d at %p\n", dev->name, dev->seq, priv->base); + + return 0; +} + +static const struct octeon_spi_data spi_octeon_data = { + .probe = PROBE_DT, + .reg_offs = 0x0000, +}; + +static const struct octeon_spi_data spi_octeontx_data = { + .probe = PROBE_PCI, + .reg_offs = 0x1000, +}; + +static const struct udevice_id octeon_spi_ids[] = { + /* MIPS Octeon */ + { .compatible = "cavium,octeon-3010-spi", + .data = (ulong)&spi_octeon_data }, + /* ARM Octeon TX / TX2 */ + { .compatible = "cavium,thunder-8190-spi", + .data = (ulong)&spi_octeontx_data }, + { } +}; + +U_BOOT_DRIVER(octeon_spi) = { + .name = "spi_octeon", + .id = UCLASS_SPI, + .of_match = octeon_spi_ids, + .probe = octeon_spi_probe, + .priv_auto_alloc_size = sizeof(struct octeon_spi), + .ops = &octeon_spi_ops, +};
Am Donnerstag, den 23.07.2020, 12:17 +0200 schrieb Stefan Roese:
Changes in v2:
+config OCTEON_SPI
- bool "Octeon SPI driver"
- depends on DM_PCI && (ARCH_OCTEON || ARCH_OCTEONTX || ARCH_OCTEONTX2)
- help
SoC platforms.
- Copyright (C) 2018 Marvell International Ltd.
+enum {
- PROBE_PCI = 0, /* PCI based probing */
- PROBE_DT, /* DT based probing */
- int probe;
- u32 reg_offs;
- void __iomem *base; /* Register base address */
- struct clk clk;
- u32 clkdiv; /* Clock divisor for device speed */
- struct dm_spi_slave_platdata *slave = dev_get_parent_platdata(dev);
- struct udevice *bus = dev_get_parent(dev);
- struct octeon_spi *priv = dev_get_priv(bus);
- u64 mpi_cfg;
- uint max_speed = slave->max_hz;
- bool cpha, cpol;
- if (!max_speed)
- if (max_speed > OCTEON_SPI_MAX_CLOCK_HZ)
- debug("\n slave params %d %d %d\n", slave->cs,
- cpha = !!(slave->mode & SPI_CPHA);
- cpol = !!(slave->mode & SPI_CPOL);
- mpi_cfg = FIELD_PREP(MPI_CFG_CLKDIV, priv->clkdiv & 0x1fff) |
MPI_CFG_ENABLE;
- debug("\n mpi_cfg %llx\n", mpi_cfg);
- return mpi_cfg;
- Wait until the SPI bus is ready
- @param dev SPI device to wait for
- void *base = priv->base;
- u64 mpi_sts;
- do {
WATCHDOG_RESET();
- } while (mpi_sts & MPI_STS_BUSY);
- debug("%s(%s)\n", __func__, dev->name);
- Claim the bus for a slave device
- @param dev SPI bus
- @return 0 for success, -EINVAL if chip select is invalid
- u64 mpi_cfg;
- debug("\n\n%s(%s)\n", __func__, dev->name);
- if (!OCTEON_SPI_CS_VALID(spi_chip_select(dev)))
return -EINVAL;
- if (IS_ENABLED(CONFIG_ARCH_OCTEONTX2))
- mpi_cfg = readq(base + MPI_CFG);
- mpi_cfg &= ~MPI_CFG_TRITX;
- mpi_cfg |= MPI_CFG_ENABLE;
- writeq(mpi_cfg, base + MPI_CFG);
- udelay(5); /** Wait for bus to settle */
- Release the bus to a slave device
- u64 mpi_cfg;
- debug("%s(%s)\n\n", __func__, dev->name);
return -EINVAL;
- mpi_cfg &= ~MPI_CFG_ENABLE;
- udelay(1);
- u64 mpi_tx;
- u64 mpi_cfg;
- u64 wide_dat = 0;
- int len = bitlen / 8;
- int i;
- const u8 *tx_data = dout;
- u8 *rx_data = din;
- int cs = spi_chip_select(dev);
- if (!OCTEON_SPI_CS_VALID(cs))
return -EINVAL;
- debug("\n %s(%s, %u, %p, %p, 0x%lx), cs: %d\n",
- mpi_cfg = octeon_spi_set_mpicfg(dev);
- if (mpi_cfg != readq(base + MPI_CFG)) {
udelay(10);
- debug("\n mpi_cfg upd %llx\n", mpi_cfg);
- while (len > 8) {
if (tx_data) {
tx_data += 8;
debug("\n ");
if (rx_data) {
rx_data += 8;
len -= 8;
- debug("\n ");
- /* Write and read the rest of the data */
- if (tx_data) {
- mpi_tx = FIELD_PREP(MPI_TX_CSID, cs) |
- writeq(mpi_tx, base + MPI_TX);
- octeon_spi_wait_ready(dev);
- debug("\n ");
- if (rx_data) {
rx_data++;
- u64 mpi_xmit;
- u64 mpi_cfg;
- u64 wide_dat = 0;
- int rem;
- int i;
return -EINVAL;
- mpi_cfg |= MPI_CFG_TRITX | MPI_CFG_LEGACY_DIS | MPI_CFG_CS_STICKY |
MPI_CFG_TB100_EN;
- mpi_cfg &= ~MPI_CFG_IOMODE;
- if (flags & (SPI_TX_DUAL | SPI_RX_DUAL))
- if (flags & (SPI_TX_QUAD | SPI_RX_QUAD))
udelay(10);
- debug("\n mpi_cfg upd %llx\n\n", mpi_cfg);
- /* Start by writing or reading 1024 bytes at a time. */
- while (len > 1024) {
if (tx_data) {
if ((i % 4) == 3)
debug("\n");
tx_data += 8;
debug("\n ");
if (rx_data) {
if ((i % 4) == 3)
debug("\n");
rx_data += 8;
len -= 1024;
- if (tx_data) {
rem = len % 8;
if ((i % 4) == 3)
debug("\n");
tx_data += 8;
if (rem) {
- mpi_xmit = FIELD_PREP(MPI_XMIT_CSID, cs) |
- writeq(mpi_xmit, base + MPI_XMIT);
- debug("\n ");
- if (rx_data) {
rem = len % 8;
if ((i % 4) == 3)
debug("\n");
rx_data += 8;
if (rem) {
rx_data += rem;
- /* For now, support only below combinations
* 1-1-1
* 1-1-2 1-2-2
* 1-1-4 1-4-4
- if (op->cmd.buswidth != 1)
return false;
- return true;
- unsigned long flags = SPI_XFER_BEGIN;
- const void *tx;
- void *rx;
- u8 opcode, *buf;
- u8 *addr;
- int i, temp, ret;
return -ENOTSUPP;
- /* Send CMD */
- i = 0;
- opcode = op->cmd.opcode;
- if (!op->data.nbytes && !op->addr.nbytes && !op->dummy.nbytes)
- ret = octeontx2_spi_xfer(slave->dev, 8, (void *)&opcode, NULL, flags);
- if (ret < 0)
return ret;
- /* Send Address and dummy */
- if (op->addr.nbytes) {
if (!buf) {
return -ENOMEM;
buf[i++] = 0xff;
flags);
free(buf);
if (ret < 0)
return ret;
- if (!op->data.nbytes)
- /* Send/Receive Data */
- flags |= SPI_XFER_END;
- if (op->data.buswidth == 2)
- if (op->data.buswidth == 4)
- rx = (op->data.dir == SPI_MEM_DATA_IN) ? op->data.buf.in : NULL;
- tx = (op->data.dir == SPI_MEM_DATA_OUT) ? op->data.buf.out : NULL;
- ret = octeontx2_spi_xfer(slave->dev, (op->data.nbytes * 8), tx, rx,
flags);
- return ret;
- .supports_op = octeon_spi_supports_op,
- .exec_op = octeon_spi_exec_op,
- Set the speed of the SPI bus
- @param bus bus to set
- @param max_hz maximum speed supported
- ulong clk_rate;
- u32 calc_hz;
- if (max_hz > OCTEON_SPI_MAX_CLOCK_HZ)
- clk_rate = clk_get_rate(&priv->clk);
- if (IS_ERR_VALUE(clk_rate))
return -EINVAL;
- debug("%s(%s, %u, %lu)\n", __func__, bus->name, max_hz, clk_rate);
- priv->clkdiv = clk_rate / (2 * max_hz);
- while (1) {
break;
priv->clkdiv += 1;
- if (priv->clkdiv > 8191)
return -EINVAL;
- debug("%s: clkdiv=%d\n", __func__, priv->clkdiv);
- /* We don't set it here */
- .claim_bus = octeon_spi_claim_bus,
- .release_bus = octeon_spi_release_bus,
- .set_speed = octeon_spi_set_speed,
- .set_mode = octeon_spi_set_mode,
- .xfer = octeon_spi_xfer,
- .xfer = octeontx2_spi_xfer,
- .mem_ops = &octeontx2_spi_mem_ops,
- struct octeon_spi *priv = dev_get_priv(dev);
- const struct octeon_spi_data *data;
- int ret;
- data = (const struct octeon_spi_data *)dev_get_driver_data(dev);
- if (data->probe == PROBE_PCI) {
PCI_REGION_MEM);
- } else {
- priv->base += data->reg_offs;
- /* Octeon TX2 needs a different ops struct */
- if (device_is_compatible(dev, "cavium,thunderx-spi")) {
can't you simply add a xfer() function pointer to "struct octeon_spi_data" and assign the according xfer function to it? Then in octeon_spi_xfer() you can simply call that function pointer. With this you only need one instance of "struct dm_spi_ops" and don't need this ugly hack ;) Maybe you can add some common code to octeon_spi_xfer() itself and reduce the size of the SoC specific xfer functions.
- ret = clk_get_by_index(dev, 0, &priv->clk);
- if (ret < 0)
return ret;
- ret = clk_enable(&priv->clk);
- if (ret)
return ret;
- debug("SPI bus %s %d at %p\n", dev->name, dev->seq, priv->base);
- .probe = PROBE_DT,
- .reg_offs = 0x0000,
- .probe = PROBE_PCI,
- .reg_offs = 0x1000,
- /* MIPS Octeon */
- { .compatible = "cavium,octeon-3010-spi",
- /* ARM Octeon TX / TX2 */
- { .compatible = "cavium,thunder-8190-spi",
- .name = "spi_octeon",
- .id = UCLASS_SPI,
- .of_match = octeon_spi_ids,
- .probe = octeon_spi_probe,
- .priv_auto_alloc_size = sizeof(struct octeon_spi),
- .ops = &octeon_spi_ops,
Changes in v2:
+config OCTEON_SPI
- help
SoC platforms.
- config OMAP3_SPI bool "McSPI driver for OMAP" help
+enum {
- int probe;
- u32 reg_offs;
- struct clk clk;
- u64 mpi_cfg;
- bool cpha, cpol;
- if (!max_speed)
MPI_CFG_ENABLE;
- return mpi_cfg;
- u64 mpi_sts;
- do {
WATCHDOG_RESET();
- u64 mpi_cfg;
return -EINVAL;
- u64 mpi_cfg;
return -EINVAL;
- udelay(1);
- u64 mpi_tx;
- u64 mpi_cfg;
- u64 wide_dat = 0;
- int i;
return -EINVAL;
udelay(10);
- while (len > 8) {
if (tx_data) {
tx_data += 8;
debug("\n ");
if (rx_data) {
rx_data += 8;
len -= 8;
- debug("\n ");
- if (tx_data) {
- debug("\n ");
- if (rx_data) {
rx_data++;
- u64 mpi_xmit;
- u64 mpi_cfg;
- u64 wide_dat = 0;
- int rem;
- int i;
return -EINVAL;
MPI_CFG_TB100_EN;
udelay(10);
if (tx_data) {
if ((i % 4) == 3)
debug("\n");
tx_data += 8;
debug("\n ");
if (rx_data) {
if ((i % 4) == 3)
debug("\n");
rx_data += 8;
len -= 1024;
- if (tx_data) {
rem = len % 8;
if ((i % 4) == 3)
debug("\n");
tx_data += 8;
if (rem) {
- debug("\n ");
- if (rx_data) {
rem = len % 8;
if ((i % 4) == 3)
debug("\n");
rx_data += 8;
if (rem) {
rx_data += rem;
* 1-1-1
* 1-1-2 1-2-2
* 1-1-4 1-4-4
return false;
- return true;
- const void *tx;
- void *rx;
- u8 opcode, *buf;
- u8 *addr;
- int i, temp, ret;
return -ENOTSUPP;
- /* Send CMD */
- i = 0;
- if (ret < 0)
return ret;
if (!buf) {
return -ENOMEM;
buf[i++] = 0xff;
flags);
free(buf);
if (ret < 0)
return ret;
flags);
- return ret;
- ulong clk_rate;
- u32 calc_hz;
return -EINVAL;
- while (1) {
break;
priv->clkdiv += 1;
return -EINVAL;
- int ret;
PCI_REGION_MEM);
- } else {
Thanks for the suggestion. I'm leaving for a short vacation later today and will return end of next week. I'll look into it then.
Yes, maybe. Please keep in mind that I'm not the original author of the code, so refactoring is sometimes not that easy. But I'll look into this as well.
Thanks, Stefan
- if (ret < 0)
return ret;
- if (ret)
return ret;
- /* MIPS Octeon */
- .id = UCLASS_SPI,
Viele Grüße, Stefan
Hi Daniel,
<snip>
- int ret;
PCI_REGION_MEM);
- } else {
Unfortuantely its not that easy, as the Octeon TX2 ops struct also has a " mem_ops" member, which the driver does not support for the other Octeon models. I could clear this "mem_ops" member in the non Octeon TX2 case, which is a bit better than the 2nd ops struct. But its still not really elegent.
Or do you have some other idea on how to implement this in a "better way"?
Thanks, Stefan
Hi Daniel,
On 30.07.20 07:49, Stefan Roese wrote:
Hi Daniel,
<snip>
+static int octeon_spi_probe(struct udevice *dev) +{ +Â Â Â struct octeon_spi *priv = dev_get_priv(dev); +Â Â Â const struct octeon_spi_data *data; +Â Â Â int ret;
+Â Â Â data = (const struct octeon_spi_data *)dev_get_driver_data(dev); +Â Â Â if (data->probe == PROBE_PCI) { +Â Â Â Â Â Â Â pci_dev_t bdf = dm_pci_get_bdf(dev);
+Â Â Â Â Â Â Â debug("SPI PCI device: %x\n", bdf); +Â Â Â Â Â Â Â priv->base = dm_pci_map_bar(dev, PCI_BASE_ADDRESS_0, +Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â PCI_REGION_MEM); +Â Â Â } else { +Â Â Â Â Â Â Â priv->base = dev_remap_addr(dev); +Â Â Â }
+Â Â Â priv->base += data->reg_offs;
+Â Â Â /* Octeon TX2 needs a different ops struct */ +Â Â Â if (device_is_compatible(dev, "cavium,thunderx-spi")) { +Â Â Â Â Â Â Â /* +Â Â Â Â Â Â Â Â * "ops" is const and can't be written directly. So we need +Â Â Â Â Â Â Â Â * to write the Octeon TX2 ops value using this trick +Â Â Â Â Â Â Â Â */ +Â Â Â Â Â Â Â writeq((u64)&octeontx2_spi_ops, (void *)&dev->driver->ops); +Â Â Â }
BTW: If this SPI driver is the only patch in this series, that you feel is not ready, then I suggest to drop this one from this patch series and push the remaining ones to mainline (if they have no issues of course).
Thanks, Stefan
Am Donnerstag, den 30.07.2020, 08:23 +0200 schrieb Stefan Roese:
Hi Daniel,
Hi Daniel,
<snip>
- int ret;
PCI_REGION_MEM);
- } else {
I had a look and the struct dm_spi_ops don't have a strict requirement to be const. It doesn't matter for "struct driver : const void *ops" if it points to struct dm_spi_ops linked to .data or .rodata, it can only be assigned once.
If struct dm_spi_ops is linked to .data, you can simply re-assign some function pointers during probe. I would suggest the following change:
@@ -82,6 +82,7 @@ void board_acquire_flash_arb(bool acquire); struct octeon_spi_data { int probe; u32 reg_offs; + bool is_octeontx; };
/* Local driver data structure */ @@ -559,7 +560,7 @@ static int octeon_spi_set_mode(struct udevice *bus, uint mode) return 0; }
-static const struct dm_spi_ops octeon_spi_ops = { +static struct dm_spi_ops octeon_spi_ops = { .claim_bus = octeon_spi_claim_bus, .release_bus = octeon_spi_release_bus, .set_speed = octeon_spi_set_speed, @@ -567,15 +568,6 @@ static const struct dm_spi_ops octeon_spi_ops = { .xfer = octeon_spi_xfer, };
-static const struct dm_spi_ops octeontx2_spi_ops = { - .claim_bus = octeon_spi_claim_bus, - .release_bus = octeon_spi_release_bus, - .set_speed = octeon_spi_set_speed, - .set_mode = octeon_spi_set_mode, - .xfer = octeontx2_spi_xfer, - .mem_ops = &octeontx2_spi_mem_ops, -}; - static int octeon_spi_probe(struct udevice *dev) { struct octeon_spi *priv = dev_get_priv(dev); @@ -596,12 +588,9 @@ static int octeon_spi_probe(struct udevice *dev) priv->base += data->reg_offs;
/* Octeon TX2 needs a different ops struct */ - if (device_is_compatible(dev, "cavium,thunderx-spi")) { - /* - * "ops" is const and can't be written directly. So we need - * to write the Octeon TX2 ops value using this trick - */ - writeq((u64)&octeontx2_spi_ops, (void *)&dev->driver-
ops);
+ if (data->is_octeontx) { + octeon_spi_ops.xfer = octeontx2_spi_xfer; + octeon_spi_ops.mem_ops = &octeontx2_spi_mem_ops; }
ret = clk_get_by_index(dev, 0, &priv->clk); @@ -620,11 +609,13 @@ static int octeon_spi_probe(struct udevice *dev) static const struct octeon_spi_data spi_octeon_data = { .probe = PROBE_DT, .reg_offs = 0x0000, + .is_octeontx = false, };
static const struct octeon_spi_data spi_octeontx_data = { .probe = PROBE_PCI, .reg_offs = 0x1000, + .is_octeontx = true, };
if you are okay with my suggestion you could send a v3 of just the SPI driver. I think I'll have time tomorrow to prepare another pull request.
Hi Daniel,
Hi Daniel,
Hi Daniel,
<snip>
- int ret;
PCI_REGION_MEM);
- } else {
A, nice. Thanks for looking into this.
bool is_octeontx;
need
ops);
octeon_spi_ops.mem_ops = &octeontx2_spi_mem_ops; } ret = clk_get_by_index(dev, 0, &priv->clk);
This selection via driver_data does not work, as Octeon TX and Octeon TX2 have the same compatible for probing. I've changed this to a runtime compatible detection (TX2 only) instead and it works just fine.
Great. I'll make the necessary changes and will send out v3 shortly.
Thanks, Stefan
On Fri, Jul 24, 2020 at 7:26 PM Daniel Schwierzeck daniel.schwierzeck@gmail.com wrote:
Changes in v2:
+config OCTEON_SPI
help
SoC platforms.
+enum {
int probe;
u32 reg_offs;
struct clk clk;
u64 mpi_cfg;
bool cpha, cpol;
if (!max_speed)
MPI_CFG_ENABLE;
return mpi_cfg;
u64 mpi_sts;
do {
WATCHDOG_RESET();
u64 mpi_cfg;
return -EINVAL;
u64 mpi_cfg;
return -EINVAL;
udelay(1);
u64 mpi_tx;
u64 mpi_cfg;
u64 wide_dat = 0;
int i;
u8 *rx_data = din;
return -EINVAL;
udelay(10);
while (len > 8) {
if (tx_data) {
tx_data += 8;
debug("\n ");
if (rx_data) {
rx_data += 8;
len -= 8;
debug("\n ");
if (tx_data) {
debug("\n ");
if (rx_data) {
rx_data++;
u64 mpi_xmit;
u64 mpi_cfg;
u64 wide_dat = 0;
int rem;
int i;
u8 *rx_data = din;
return -EINVAL;
MPI_CFG_TB100_EN;
udelay(10);
if (tx_data) {
if ((i % 4) == 3)
debug("\n");
tx_data += 8;
debug("\n ");
if (rx_data) {
if ((i % 4) == 3)
debug("\n");
rx_data += 8;
len -= 1024;
if (tx_data) {
rem = len % 8;
if ((i % 4) == 3)
debug("\n");
tx_data += 8;
if (rem) {
debug("\n ");
if (rx_data) {
rem = len % 8;
if ((i % 4) == 3)
debug("\n");
rx_data += 8;
if (rem) {
rx_data += rem;
* 1-1-1
* 1-1-2 1-2-2
* 1-1-4 1-4-4
return false;
return true;
const void *tx;
void *rx;
u8 opcode, *buf;
u8 *addr;
int i, temp, ret;
return -ENOTSUPP;
/* Send CMD */
i = 0;
if (ret < 0)
return ret;
if (!buf) {
return -ENOMEM;
buf[i++] = 0xff;
flags);
free(buf);
if (ret < 0)
return ret;
flags);
return ret;
ulong clk_rate;
u32 calc_hz;
return -EINVAL;
while (1) {
break;
priv->clkdiv += 1;
return -EINVAL;
int ret;
PCI_REGION_MEM);
} else {
This seems to be a valid point.
Here are my comments.
1. Have common ops structure (w/o mem_ops) 2. In common xfer, identify compatible or flag via driver_data and call specific xfer 3. For mem_ops it is possible to assign them in the probe, if I'm not wrong like this. static int octeon_spi_probe(struct udevice *dev) { struct dm_spi_ops *ops = spi_get_ops(dev);
check if new compatible or flag ops->mem_ops = &octeontx2_spi_mem_ops; }
Jagan.
Hi Jagan,
Changes in v2:
+config OCTEON_SPI
help
SoC platforms.
+enum {
int probe;
u32 reg_offs;
struct clk clk;
u64 mpi_cfg;
bool cpha, cpol;
if (!max_speed)
MPI_CFG_ENABLE;
return mpi_cfg;
u64 mpi_sts;
do {
WATCHDOG_RESET();
u64 mpi_cfg;
return -EINVAL;
u64 mpi_cfg;
return -EINVAL;
udelay(1);
u64 mpi_tx;
u64 mpi_cfg;
u64 wide_dat = 0;
int i;
u8 *rx_data = din;
return -EINVAL;
udelay(10);
while (len > 8) {
if (tx_data) {
tx_data += 8;
debug("\n ");
if (rx_data) {
rx_data += 8;
len -= 8;
debug("\n ");
if (tx_data) {
debug("\n ");
if (rx_data) {
rx_data++;
u64 mpi_xmit;
u64 mpi_cfg;
u64 wide_dat = 0;
int rem;
int i;
u8 *rx_data = din;
return -EINVAL;
MPI_CFG_TB100_EN;
udelay(10);
if (tx_data) {
if ((i % 4) == 3)
debug("\n");
tx_data += 8;
debug("\n ");
if (rx_data) {
if ((i % 4) == 3)
debug("\n");
rx_data += 8;
len -= 1024;
if (tx_data) {
rem = len % 8;
if ((i % 4) == 3)
debug("\n");
tx_data += 8;
if (rem) {
debug("\n ");
if (rx_data) {
rem = len % 8;
if ((i % 4) == 3)
debug("\n");
rx_data += 8;
if (rem) {
rx_data += rem;
* 1-1-1
* 1-1-2 1-2-2
* 1-1-4 1-4-4
return false;
return true;
const void *tx;
void *rx;
u8 opcode, *buf;
u8 *addr;
int i, temp, ret;
return -ENOTSUPP;
/* Send CMD */
i = 0;
if (ret < 0)
return ret;
if (!buf) {
return -ENOMEM;
buf[i++] = 0xff;
flags);
free(buf);
if (ret < 0)
return ret;
flags);
return ret;
ulong clk_rate;
u32 calc_hz;
return -EINVAL;
while (1) {
break;
priv->clkdiv += 1;
return -EINVAL;
int ret;
PCI_REGION_MEM);
} else {
- Have common ops structure (w/o mem_ops)
- In common xfer, identify compatible or flag via driver_data and
Unfortunately not. "mem_ops" is also "const":
const struct spi_controller_mem_ops *mem_ops;
So overwriting is not possible, unless I remove the "const" from the declaration.
Thanks, Stefan
Changes in v2:
+config OCTEON_SPI
help
SoC platforms.
+enum {
int probe;
u32 reg_offs;
struct clk clk;
u64 mpi_cfg;
bool cpha, cpol;
if (!max_speed)
MPI_CFG_ENABLE;
return mpi_cfg;
u64 mpi_sts;
do {
WATCHDOG_RESET();
u64 mpi_cfg;
return -EINVAL;
u64 mpi_cfg;
return -EINVAL;
Does this acquire flash depends on soc? what exactly it does? I believe it can go in separate uclass drivers and spi drivers get that functionality like other drivers. I'm not fond of calling an architecture or other places code in the driver. However if it local spi driver then attach driver_data on respective compatible and use it locally.
Jagan.
Hi Jagan,
Changes in v2:
+config OCTEON_SPI
help
SoC platforms.
+enum {
int probe;
u32 reg_offs;
struct clk clk;
u64 mpi_cfg;
bool cpha, cpol;
if (!max_speed)
MPI_CFG_ENABLE;
return mpi_cfg;
u64 mpi_sts;
do {
WATCHDOG_RESET();
u64 mpi_cfg;
return -EINVAL;
u64 mpi_cfg;
return -EINVAL;
Yes. Only Octeon TX2 implements it - the other SoC's using this driver (MIPS Octeon and ARM Octeon TX) do not.
It controls the arbiter for the boot device between multiple internal resources (SCP, MCP, AP Secure, AP Nonsecure).
I could move this board_acquire_flash_arb() implementation into this SPI driver, which might make sense. Its not called from other places AFAICT.
Thanks, Stefan
Add the Octeon SPI DT node to the dtsi file.
arch/mips/dts/mrvl,cn73xx.dtsi | 10 ++++++++++ 1 file changed, 10 insertions(+)
diff --git a/arch/mips/dts/mrvl,cn73xx.dtsi b/arch/mips/dts/mrvl,cn73xx.dtsi index 7c0a8d73f0..f5ad4a6213 100644 --- a/arch/mips/dts/mrvl,cn73xx.dtsi +++ b/arch/mips/dts/mrvl,cn73xx.dtsi @@ -116,5 +116,15 @@ clock-frequency = <100000>; clocks = <&clk OCTEON_CLK_IO>; }; + + spi: spi@1070000001000 { + compatible = "cavium,octeon-3010-spi"; + reg = <0x10700 0x00001000 0x0 0x100>; + interrupts = <0x05001 1>; + #address-cells = <1>; + #size-cells = <0>; + spi-max-frequency = <25000000>; + clocks = <&clk OCTEON_CLK_IO>; + }; }; };
Add the SPI flash DT node for the EBB7304.
arch/mips/dts/mrvl,octeon-ebb7304.dts | 9 +++++++++ 1 file changed, 9 insertions(+)
diff --git a/arch/mips/dts/mrvl,octeon-ebb7304.dts b/arch/mips/dts/mrvl,octeon-ebb7304.dts index c229aa5fc0..6b2e5e84bc 100644 --- a/arch/mips/dts/mrvl,octeon-ebb7304.dts +++ b/arch/mips/dts/mrvl,octeon-ebb7304.dts @@ -13,6 +13,7 @@
aliases { serial0 = &uart0; + spi0 = &spi; };
chosen { @@ -104,3 +105,11 @@ u-boot,dm-pre-reloc; /* Needed early for DDR SPD EEPROM */ clock-frequency = <100000>; }; + +&spi { + flash@0 { + compatible = "micron,n25q128a11", "jedec,spi-nor"; + spi-max-frequency = <2000000>; + reg = <0>; + }; +};
This patch selects DM_SPI & DM_I2C for MIPS Octeon. DM_GPIO, DM_SERIAL and DM_ETH are already selected.
Additionally the selections are now alphabetically sorted.
Changes in v2: - Kconfig and defconfig changes separated into 2 patches
arch/mips/Kconfig | 6 ++++-- 1 file changed, 4 insertions(+), 2 deletions(-)
diff --git a/arch/mips/Kconfig b/arch/mips/Kconfig index 997e145450..e0f6b6c4b3 100644 --- a/arch/mips/Kconfig +++ b/arch/mips/Kconfig @@ -112,9 +112,11 @@ config ARCH_OCTEON select DISPLAY_CPUINFO select DMA_ADDR_T_64BIT select DM - select DM_SERIAL - select DM_GPIO select DM_ETH + select DM_GPIO + select DM_I2C + select DM_SERIAL + select DM_SPI select MIPS_L2_CACHE select MIPS_MACH_EARLY_INIT select MIPS_TUNE_OCTEON3
This patch enables the following options for the Octeon EBB7304 EVB:
- PCI & DM_PCI - DM_SPI_FLASH & SPI flash device support - SPI & Octeon SPI driver - GPIO cmd support - I2C cmd support
configs/octeon_ebb7304_defconfig | 10 ++++++++++ 1 file changed, 10 insertions(+)
diff --git a/configs/octeon_ebb7304_defconfig b/configs/octeon_ebb7304_defconfig index d810b1e45f..17fdc68c03 100644 --- a/configs/octeon_ebb7304_defconfig +++ b/configs/octeon_ebb7304_defconfig @@ -12,6 +12,8 @@ CONFIG_ARCH_OCTEON=y CONFIG_DEBUG_UART=y CONFIG_SYS_CONSOLE_INFO_QUIET=y CONFIG_HUSH_PARSER=y +CONFIG_CMD_GPIO=y +CONFIG_CMD_I2C=y CONFIG_CMD_MTD=y CONFIG_CMD_PCI=y CONFIG_CMD_DHCP=y @@ -29,10 +31,18 @@ CONFIG_CFI_FLASH=y CONFIG_SYS_FLASH_USE_BUFFER_WRITE=y CONFIG_FLASH_CFI_MTD=y CONFIG_SYS_FLASH_CFI=y +CONFIG_DM_SPI_FLASH=y +CONFIG_SPI_FLASH_ATMEL=y +CONFIG_SPI_FLASH_SPANSION=y +CONFIG_SPI_FLASH_STMICRO=y # CONFIG_NETDEVICES is not set +CONFIG_PCI=y +CONFIG_DM_PCI=y CONFIG_DEBUG_UART_SHIFT=3 CONFIG_DEBUG_UART_ANNOUNCE=y CONFIG_SYS_NS16550=y +CONFIG_SPI=y +CONFIG_OCTEON_SPI=y CONFIG_SYSRESET=y CONFIG_SYSRESET_OCTEON=y CONFIG_HEXDUMP=y
Daniel Schwierzeck
Jagan Teki
Stefan Roese
