[U-Boot] [PATCH] hummingboard: Remove unused directory
The 'mx6-microsom' directory was only used for the previous mx6solo hummingboard support, which has been removed in favour of the SPL version.
Remove the remaining piece of the old mx6solo hummingboard support.
Signed-off-by: Fabio Estevam fabio.estevam@freescale.com --- board/solidrun/mx6-microsom/800mhz_2x128mx16.cfg | 74 --------------------- board/solidrun/mx6-microsom/clocks.cfg | 33 ---------- .../mx6-microsom/ddr-800mhz-32bit-setup.cfg | 76 ---------------------- 3 files changed, 183 deletions(-) delete mode 100644 board/solidrun/mx6-microsom/800mhz_2x128mx16.cfg delete mode 100644 board/solidrun/mx6-microsom/clocks.cfg delete mode 100644 board/solidrun/mx6-microsom/ddr-800mhz-32bit-setup.cfg
diff --git a/board/solidrun/mx6-microsom/800mhz_2x128mx16.cfg b/board/solidrun/mx6-microsom/800mhz_2x128mx16.cfg deleted file mode 100644 index 40747ab..0000000 --- a/board/solidrun/mx6-microsom/800mhz_2x128mx16.cfg +++ /dev/null @@ -1,74 +0,0 @@ -/* - * Copyright (C) 2013 Boundary Devices - * Copyright (C) 2013 SolidRun ltd. - * Copyright (C) 2013 Jon Nettleton jon.nettleton@gmail.com - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -/* ZQ Calibrations */ -DATA 4, MX6_MMDC_P0_MPZQHWCTRL, 0xa1390003 -DATA 4, MX6_MMDC_P1_MPZQHWCTRL, 0xa1390003 -/* write leveling */ -DATA 4, MX6_MMDC_P0_MPWLDECTRL0, 0x005a0057 -DATA 4, MX6_MMDC_P0_MPWLDECTRL1, 0x004a0052 -/* - * DQS gating, read delay, write delay calibration values - * based on calibration compare of 0x00ffff00 - */ -DATA 4, MX6_MMDC_P0_MPDGCTRL0, 0x02480240 -DATA 4, MX6_MMDC_P0_MPDGCTRL1, 0x02340230 -DATA 4, MX6_MMDC_P0_MPRDDLCTL, 0x40404440 -DATA 4, MX6_MMDC_P0_MPWRDLCTL, 0x38343034 -/* read data bit delay */ -DATA 4, MX6_MMDC_P0_MPRDDQBY0DL, 0x33333333 -DATA 4, MX6_MMDC_P0_MPRDDQBY1DL, 0x33333333 -DATA 4, MX6_MMDC_P0_MPRDDQBY2DL, 0x33333333 -DATA 4, MX6_MMDC_P0_MPRDDQBY3DL, 0x33333333 -/* Complete calibration by forced measurement */ -DATA 4, MX6_MMDC_P0_MPMUR0, 0x00000800 -DATA 4, MX6_MMDC_P1_MPMUR0, 0x00000800 - -/* - * MMDC init: - * in DDR3, 32-bit mode, only MMDC0 is initiated: - */ -DATA 4, MX6_MMDC_P0_MDPDC, 0x0002002d -DATA 4, MX6_MMDC_P0_MDOTC, 0x00333040 - -DATA 4, MX6_MMDC_P0_MDCFG0, 0x3f435313 -DATA 4, MX6_MMDC_P0_MDCFG1, 0xb66e8b63 - -DATA 4, MX6_MMDC_P0_MDCFG2, 0x01ff00db -DATA 4, MX6_MMDC_P0_MDMISC, 0x00011740 -DATA 4, MX6_MMDC_P0_MDSCR, 0x00008000 -DATA 4, MX6_MMDC_P0_MDRWD, 0x000026d2 -DATA 4, MX6_MMDC_P0_MDOR, 0x00431023 -/* CS0_END - 0x2fffffff, 512M */ -DATA 4, MX6_MMDC_P0_MDASP, 0x00000017 - -/* MMDC0_MAARCR ADOPT optimized priorities. Dyn jump disabled */ -DATA 4, 0x021b0400, 0x11420000 - -/* MMDC0_MDCTL- row-14bits; col-10bits; burst length 8;32-bit data bus */ -DATA 4, MX6_MMDC_P0_MDCTL, 0x83190000 - -/* - * Initialize 2GB DDR3 - Hynix H5TQ2G63BFR-H9C - * MR2 - */ -DATA 4, MX6_MMDC_P0_MDSCR, 0x00008032 -/* MR3 */ -DATA 4, MX6_MMDC_P0_MDSCR, 0x00008033 -/* MR1 */ -DATA 4, MX6_MMDC_P0_MDSCR, 0x00008031 -/* MR0 */ -DATA 4, MX6_MMDC_P0_MDSCR, 0x05208030 -/* ZQ calibration */ -DATA 4, MX6_MMDC_P0_MDSCR, 0x04008040 -/* final DDR setup */ -DATA 4, MX6_MMDC_P0_MDREF, 0x00007800 -DATA 4, MX6_MMDC_P0_MPODTCTRL, 0x00000007 -DATA 4, MX6_MMDC_P0_MDPDC, 0x0002556d -DATA 4, MX6_MMDC_P0_MAPSR, 0x00011006 -DATA 4, MX6_MMDC_P0_MDSCR, 0x00000000 diff --git a/board/solidrun/mx6-microsom/clocks.cfg b/board/solidrun/mx6-microsom/clocks.cfg deleted file mode 100644 index 1288811..0000000 --- a/board/solidrun/mx6-microsom/clocks.cfg +++ /dev/null @@ -1,33 +0,0 @@ -/* - * Copyright (C) 2013 Boundary Devices - * Copyright (C) 2013 SolidRun ltd. - * Copyright (C) 2013 Jon Nettleton jon.nettleton@gmail.com - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -/* set the default clock gate to save power */ -DATA 4, CCM_CCGR0, 0x00C03F3F -DATA 4, CCM_CCGR1, 0x0030FC03 -DATA 4, CCM_CCGR2, 0x0FFFC000 -DATA 4, CCM_CCGR3, 0x3FF00000 -DATA 4, CCM_CCGR4, 0x00FFF300 -DATA 4, CCM_CCGR5, 0x0F0000C3 -DATA 4, CCM_CCGR6, 0x000003FF - -/* enable AXI cache for VDOA/VPU/IPU */ -DATA 4, MX6_IOMUXC_GPR4, 0xF00000CF -/* set IPU AXI-id0 Qos=0xf(bypass) AXI-id1 Qos=0x7 */ -DATA 4, MX6_IOMUXC_GPR6, 0x007F007F -DATA 4, MX6_IOMUXC_GPR7, 0x007F007F - -/* - * Setup CCM_CCOSR register as follows: - * - * cko1_en = 1 --> CKO1 enabled - * cko1_div = 111 --> divide by 8 - * cko1_sel = 1011 --> ahb_clk_root - * - * This sets CKO1 at ahb_clk_root/8 = 132/8 = 16.5 MHz - */ -DATA 4, CCM_CCOSR, 0x000000fb diff --git a/board/solidrun/mx6-microsom/ddr-800mhz-32bit-setup.cfg b/board/solidrun/mx6-microsom/ddr-800mhz-32bit-setup.cfg deleted file mode 100644 index f92fc19..0000000 --- a/board/solidrun/mx6-microsom/ddr-800mhz-32bit-setup.cfg +++ /dev/null @@ -1,76 +0,0 @@ -/* - * Copyright (C) 2013 Boundary Devices - * Copyright (C) 2013 SolidRun ltd. - * Copyright (C) 2013 Jon Nettleton jon.nettleton@gmail.com - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -/* - * DDR3 settings - * MX6Q ddr is limited to 1066 Mhz currently 1056 MHz(528 MHz clock), - * memory bus width: 64 bits x16/x32/x64 - * MX6DL ddr is limited to 800 MHz(400 MHz clock) - * memory bus width: 64 bits x16/x32/x64 - * MX6SOLO ddr is limited to 800 MHz(400 MHz clock) - * memory bus width: 32 bits x16/x32 - */ -/* DDR IO TYPE */ -DATA 4, MX6_IOM_GRP_DDR_TYPE, 0x000c0000 -DATA 4, MX6_IOM_GRP_DDRPKE, 0x00000000 -/* Clock */ -DATA 4, MX6_IOM_DRAM_SDCLK_0, 0x00000028 -DATA 4, MX6_IOM_DRAM_SDCLK_1, 0x00000028 -/* Address */ -DATA 4, MX6_IOM_DRAM_CAS, 0x00000010 -DATA 4, MX6_IOM_DRAM_RAS, 0x00000010 -DATA 4, MX6_IOM_GRP_ADDDS, 0x00000010 -/* Control */ -DATA 4, MX6_IOM_DRAM_RESET, 0x00000010 -DATA 4, MX6_IOM_DRAM_SDCKE0, 0x00003000 -DATA 4, MX6_IOM_DRAM_SDCKE1, 0x00003000 -DATA 4, MX6_IOM_DRAM_SDBA2, 0x00000000 -DATA 4, MX6_IOM_DRAM_SDODT0, 0x00000010 -DATA 4, MX6_IOM_DRAM_SDODT1, 0x00000010 -DATA 4, MX6_IOM_GRP_CTLDS, 0x00000010 - -/* - * Data Strobe: IOMUXC_SW_PAD_CTL_GRP_DDRMODE_CTL - DDR_INPUT=0, CMOS, - * CMOS mode saves power, but have less timing margin in case of DDR - * timing issue on your board you can try DDR_MODE: [= 0x00020000] - */ -DATA 4, MX6_IOM_DDRMODE_CTL, 0x00020000 - -DATA 4, MX6_IOM_DRAM_SDQS0, 0x00000028 -DATA 4, MX6_IOM_DRAM_SDQS1, 0x00000028 -DATA 4, MX6_IOM_DRAM_SDQS2, 0x00000028 -DATA 4, MX6_IOM_DRAM_SDQS3, 0x00000028 -DATA 4, MX6_IOM_DRAM_SDQS4, 0x00000000 -DATA 4, MX6_IOM_DRAM_SDQS5, 0x00000000 -DATA 4, MX6_IOM_DRAM_SDQS6, 0x00000000 -DATA 4, MX6_IOM_DRAM_SDQS7, 0x00000000 - -/* - * DATA:IOMUXC_SW_PAD_CTL_GRP_DDRMODE - DDR_INPUT=0, CMOS, - * CMOS mode saves power, but have less timing margin in case of DDR - * timing issue on your board you can try DDR_MODE: [= 0x00020000] - */ -DATA 4, MX6_IOM_GRP_DDRMODE, 0x00020000 - -DATA 4, MX6_IOM_GRP_B0DS, 0x00000028 -DATA 4, MX6_IOM_GRP_B1DS, 0x00000028 -DATA 4, MX6_IOM_GRP_B2DS, 0x00000028 -DATA 4, MX6_IOM_GRP_B3DS, 0x00000028 -DATA 4, MX6_IOM_GRP_B4DS, 0x00000000 -DATA 4, MX6_IOM_GRP_B5DS, 0x00000000 -DATA 4, MX6_IOM_GRP_B6DS, 0x00000000 -DATA 4, MX6_IOM_GRP_B7DS, 0x00000000 - -DATA 4, MX6_IOM_DRAM_DQM0, 0x00000028 -DATA 4, MX6_IOM_DRAM_DQM1, 0x00000028 -DATA 4, MX6_IOM_DRAM_DQM2, 0x00000028 -DATA 4, MX6_IOM_DRAM_DQM3, 0x00000028 -DATA 4, MX6_IOM_DRAM_DQM4, 0x00000000 -DATA 4, MX6_IOM_DRAM_DQM5, 0x00000000 -DATA 4, MX6_IOM_DRAM_DQM6, 0x00000000 -DATA 4, MX6_IOM_DRAM_DQM7, 0x00000000
- Copyright (C) 2013 Boundary Devices
- Copyright (C) 2013 SolidRun ltd.
- Copyright (C) 2013 Jon Nettleton jon.nettleton@gmail.com
- DQS gating, read delay, write delay calibration values
- based on calibration compare of 0x00ffff00
- MMDC init:
- in DDR3, 32-bit mode, only MMDC0 is initiated:
- Initialize 2GB DDR3 - Hynix H5TQ2G63BFR-H9C
- MR2
- Setup CCM_CCOSR register as follows:
- cko1_en = 1 --> CKO1 enabled
- cko1_div = 111 --> divide by 8
- cko1_sel = 1011 --> ahb_clk_root
- This sets CKO1 at ahb_clk_root/8 = 132/8 = 16.5 MHz
- DDR3 settings
- MX6Q ddr is limited to 1066 Mhz currently 1056 MHz(528 MHz clock),
- MX6DL ddr is limited to 800 MHz(400 MHz clock)
- MX6SOLO ddr is limited to 800 MHz(400 MHz clock)
- Data Strobe: IOMUXC_SW_PAD_CTL_GRP_DDRMODE_CTL - DDR_INPUT=0, CMOS,
- CMOS mode saves power, but have less timing margin in case of DDR
- timing issue on your board you can try DDR_MODE: [= 0x00020000]
- DATA:IOMUXC_SW_PAD_CTL_GRP_DDRMODE - DDR_INPUT=0, CMOS,
Thanks, Fabio !
Acked-by: Stefano Babic sbabic@denx.de
Best regards, Stefano Babic
Fabio Estevam
Stefano Babic
