[U-Boot] [PATCH 1/2] x86: ich6_gpio: Add use-lvl-write-cache for I/O access mode
Add a device-tree property use-lvl-write-cache that will cause writes to lvl to be cached instead of read from lvl before each write. This is required on some platforms that have the register implemented as dual read/write (such as Baytrail).
Prior to this fix the blue USB port on the Minnowboard Max was unusable since USB_HOST_EN0 was set high then immediately set low when USB_HOST_EN1 was written.
This also resolves the 'gpio clear | set' command warning like: "Warning: value of pin is still 0"
Signed-off-by: George McCollister george.mccollister@gmail.com <rebased on latest origin/master, fixed all baytrail boards> Signed-off-by: Bin Meng bmeng.cn@gmail.com
arch/x86/dts/bayleybay.dts | 6 ++++++ arch/x86/dts/baytrail_som-db5800-som-6867.dts | 6 ++++++ arch/x86/dts/conga-qeval20-qa3-e3845.dts | 6 ++++++ arch/x86/dts/dfi-bt700.dtsi | 6 ++++++ arch/x86/dts/minnowmax.dts | 6 ++++++ drivers/gpio/intel_ich6_gpio.c | 30 ++++++++++++++++++++++----- 6 files changed, 55 insertions(+), 5 deletions(-)
diff --git a/arch/x86/dts/bayleybay.dts b/arch/x86/dts/bayleybay.dts index 18b310d..1ae058d 100644 --- a/arch/x86/dts/bayleybay.dts +++ b/arch/x86/dts/bayleybay.dts @@ -189,6 +189,7 @@ u-boot,dm-pre-reloc; reg = <0 0x20>; bank-name = "A"; + use-lvl-write-cache; };
gpiob { @@ -196,6 +197,7 @@ u-boot,dm-pre-reloc; reg = <0x20 0x20>; bank-name = "B"; + use-lvl-write-cache; };
gpioc { @@ -203,6 +205,7 @@ u-boot,dm-pre-reloc; reg = <0x40 0x20>; bank-name = "C"; + use-lvl-write-cache; };
gpiod { @@ -210,6 +213,7 @@ u-boot,dm-pre-reloc; reg = <0x60 0x20>; bank-name = "D"; + use-lvl-write-cache; };
gpioe { @@ -217,6 +221,7 @@ u-boot,dm-pre-reloc; reg = <0x80 0x20>; bank-name = "E"; + use-lvl-write-cache; };
gpiof { @@ -224,6 +229,7 @@ u-boot,dm-pre-reloc; reg = <0xA0 0x20>; bank-name = "F"; + use-lvl-write-cache; }; }; }; diff --git a/arch/x86/dts/baytrail_som-db5800-som-6867.dts b/arch/x86/dts/baytrail_som-db5800-som-6867.dts index e1d81a7..aa8bfb8 100644 --- a/arch/x86/dts/baytrail_som-db5800-som-6867.dts +++ b/arch/x86/dts/baytrail_som-db5800-som-6867.dts @@ -212,6 +212,7 @@ u-boot,dm-pre-reloc; reg = <0 0x20>; bank-name = "A"; + use-lvl-write-cache; };
gpiob { @@ -219,6 +220,7 @@ u-boot,dm-pre-reloc; reg = <0x20 0x20>; bank-name = "B"; + use-lvl-write-cache; };
gpioc { @@ -226,6 +228,7 @@ u-boot,dm-pre-reloc; reg = <0x40 0x20>; bank-name = "C"; + use-lvl-write-cache; };
gpiod { @@ -233,6 +236,7 @@ u-boot,dm-pre-reloc; reg = <0x60 0x20>; bank-name = "D"; + use-lvl-write-cache; };
gpioe { @@ -240,6 +244,7 @@ u-boot,dm-pre-reloc; reg = <0x80 0x20>; bank-name = "E"; + use-lvl-write-cache; };
gpiof { @@ -247,6 +252,7 @@ u-boot,dm-pre-reloc; reg = <0xA0 0x20>; bank-name = "F"; + use-lvl-write-cache; }; }; }; diff --git a/arch/x86/dts/conga-qeval20-qa3-e3845.dts b/arch/x86/dts/conga-qeval20-qa3-e3845.dts index f0efe90..898e9c9 100644 --- a/arch/x86/dts/conga-qeval20-qa3-e3845.dts +++ b/arch/x86/dts/conga-qeval20-qa3-e3845.dts @@ -199,6 +199,7 @@ u-boot,dm-pre-reloc; reg = <0 0x20>; bank-name = "A"; + use-lvl-write-cache; };
gpiob { @@ -206,6 +207,7 @@ u-boot,dm-pre-reloc; reg = <0x20 0x20>; bank-name = "B"; + use-lvl-write-cache; };
gpioc { @@ -213,6 +215,7 @@ u-boot,dm-pre-reloc; reg = <0x40 0x20>; bank-name = "C"; + use-lvl-write-cache; };
gpiod { @@ -220,6 +223,7 @@ u-boot,dm-pre-reloc; reg = <0x60 0x20>; bank-name = "D"; + use-lvl-write-cache; };
gpioe { @@ -227,6 +231,7 @@ u-boot,dm-pre-reloc; reg = <0x80 0x20>; bank-name = "E"; + use-lvl-write-cache; };
gpiof { @@ -234,6 +239,7 @@ u-boot,dm-pre-reloc; reg = <0xA0 0x20>; bank-name = "F"; + use-lvl-write-cache; }; }; }; diff --git a/arch/x86/dts/dfi-bt700.dtsi b/arch/x86/dts/dfi-bt700.dtsi index 75ee6ad..546981a 100644 --- a/arch/x86/dts/dfi-bt700.dtsi +++ b/arch/x86/dts/dfi-bt700.dtsi @@ -201,6 +201,7 @@ u-boot,dm-pre-reloc; reg = <0 0x20>; bank-name = "A"; + use-lvl-write-cache; };
gpiob { @@ -208,6 +209,7 @@ u-boot,dm-pre-reloc; reg = <0x20 0x20>; bank-name = "B"; + use-lvl-write-cache; };
gpioc { @@ -215,6 +217,7 @@ u-boot,dm-pre-reloc; reg = <0x40 0x20>; bank-name = "C"; + use-lvl-write-cache; };
gpiod { @@ -222,6 +225,7 @@ u-boot,dm-pre-reloc; reg = <0x60 0x20>; bank-name = "D"; + use-lvl-write-cache; };
gpioe { @@ -229,6 +233,7 @@ u-boot,dm-pre-reloc; reg = <0x80 0x20>; bank-name = "E"; + use-lvl-write-cache; };
gpiof { @@ -236,6 +241,7 @@ u-boot,dm-pre-reloc; reg = <0xA0 0x20>; bank-name = "F"; + use-lvl-write-cache; }; }; }; diff --git a/arch/x86/dts/minnowmax.dts b/arch/x86/dts/minnowmax.dts index d51318b..bc382a8 100644 --- a/arch/x86/dts/minnowmax.dts +++ b/arch/x86/dts/minnowmax.dts @@ -218,6 +218,7 @@ u-boot,dm-pre-reloc; reg = <0 0x20>; bank-name = "A"; + use-lvl-write-cache; };
gpiob { @@ -225,6 +226,7 @@ u-boot,dm-pre-reloc; reg = <0x20 0x20>; bank-name = "B"; + use-lvl-write-cache; };
gpioc { @@ -232,6 +234,7 @@ u-boot,dm-pre-reloc; reg = <0x40 0x20>; bank-name = "C"; + use-lvl-write-cache; };
gpiod { @@ -239,6 +242,7 @@ u-boot,dm-pre-reloc; reg = <0x60 0x20>; bank-name = "D"; + use-lvl-write-cache; };
gpioe { @@ -246,6 +250,7 @@ u-boot,dm-pre-reloc; reg = <0x80 0x20>; bank-name = "E"; + use-lvl-write-cache; };
gpiof { @@ -253,6 +258,7 @@ u-boot,dm-pre-reloc; reg = <0xA0 0x20>; bank-name = "F"; + use-lvl-write-cache; }; }; }; diff --git a/drivers/gpio/intel_ich6_gpio.c b/drivers/gpio/intel_ich6_gpio.c index 8b78226..0a9eb03 100644 --- a/drivers/gpio/intel_ich6_gpio.c +++ b/drivers/gpio/intel_ich6_gpio.c @@ -46,22 +46,31 @@ struct ich6_bank_priv { uint16_t use_sel; uint16_t io_sel; uint16_t lvl; + u32 lvl_write_cache; + bool use_lvl_write_cache; };
#define GPIO_USESEL_OFFSET(x) (x) #define GPIO_IOSEL_OFFSET(x) (x + 4) #define GPIO_LVL_OFFSET(x) (x + 8)
-static int _ich6_gpio_set_value(uint16_t base, unsigned offset, int value) +static int _ich6_gpio_set_value(struct ich6_bank_priv *bank, unsigned offset, + int value) { u32 val;
- val = inl(base); + if (bank->use_lvl_write_cache) + val = bank->lvl_write_cache; + else + val = inl(bank->lvl); + if (value) val |= (1UL << offset); else val &= ~(1UL << offset); - outl(val, base); + outl(val, bank->lvl); + if (bank->use_lvl_write_cache) + bank->lvl_write_cache = val;
return 0; } @@ -112,6 +121,7 @@ static int ich6_gpio_probe(struct udevice *dev) struct ich6_bank_platdata *plat = dev_get_platdata(dev); struct gpio_dev_priv *uc_priv = dev_get_uclass_priv(dev); struct ich6_bank_priv *bank = dev_get_priv(dev); + const void *prop;
uc_priv->gpio_count = GPIO_PER_BANK; uc_priv->bank_name = plat->bank_name; @@ -119,6 +129,14 @@ static int ich6_gpio_probe(struct udevice *dev) bank->io_sel = plat->base_addr + 4; bank->lvl = plat->base_addr + 8;
+ prop = fdt_getprop(gd->fdt_blob, dev->of_offset, + "use-lvl-write-cache", NULL); + if (prop) + bank->use_lvl_write_cache = true; + else + bank->use_lvl_write_cache = false; + bank->lvl_write_cache = 0; + return 0; }
@@ -160,7 +178,7 @@ static int ich6_gpio_direction_output(struct udevice *dev, unsigned offset, if (ret) return ret;
- return _ich6_gpio_set_value(bank->lvl, offset, value); + return _ich6_gpio_set_value(bank, offset, value); }
static int ich6_gpio_get_value(struct udevice *dev, unsigned offset) @@ -170,6 +188,8 @@ static int ich6_gpio_get_value(struct udevice *dev, unsigned offset) int r;
tmplong = inl(bank->lvl); + if (bank->use_lvl_write_cache) + tmplong |= bank->lvl_write_cache; r = (tmplong & (1UL << offset)) ? 1 : 0; return r; } @@ -178,7 +198,7 @@ static int ich6_gpio_set_value(struct udevice *dev, unsigned offset, int value) { struct ich6_bank_priv *bank = dev_get_priv(dev); - return _ich6_gpio_set_value(bank->lvl, offset, value); + return _ich6_gpio_set_value(bank, offset, value); }
static int ich6_gpio_get_function(struct udevice *dev, unsigned offset)
Remove 'pad-offset' of soc_gpio_s5_0, soc_gpio_s5_1, soc_gpio_s5_2, pin_usb_host_en0 and pin_usb_host_en1. These offsets are actually wrong. Correct value should be added by 0x2000, but since they are supposed to be 'mode-gpio', 'pad-offset' is not needed at all.
Signed-off-by: Bin Meng bmeng.cn@gmail.com ---
arch/x86/dts/minnowmax.dts | 5 ----- 1 file changed, 5 deletions(-)
diff --git a/arch/x86/dts/minnowmax.dts b/arch/x86/dts/minnowmax.dts index bc382a8..af64c68 100644 --- a/arch/x86/dts/minnowmax.dts +++ b/arch/x86/dts/minnowmax.dts @@ -35,7 +35,6 @@ /* GPIO E0 */ soc_gpio_s5_0@0 { gpio-offset = <0x80 0>; - pad-offset = <0x1d0>; mode-gpio; output-value = <0>; direction = <PIN_OUTPUT>; @@ -44,7 +43,6 @@ /* GPIO E1 */ soc_gpio_s5_1@0 { gpio-offset = <0x80 1>; - pad-offset = <0x210>; mode-gpio; output-value = <0>; direction = <PIN_OUTPUT>; @@ -53,7 +51,6 @@ /* GPIO E2 */ soc_gpio_s5_2@0 { gpio-offset = <0x80 2>; - pad-offset = <0x1e0>; mode-gpio; output-value = <0>; direction = <PIN_OUTPUT>; @@ -61,7 +58,6 @@
pin_usb_host_en0@0 { gpio-offset = <0x80 8>; - pad-offset = <0x260>; mode-gpio; output-value = <1>; direction = <PIN_OUTPUT>; @@ -69,7 +65,6 @@
pin_usb_host_en1@0 { gpio-offset = <0x80 9>; - pad-offset = <0x250>; mode-gpio; output-value = <1>; direction = <PIN_OUTPUT>;
Thanks, Stefan
applied to u-boot-x86, thanks!
Thanks, Stefan
I think we need a binding file for intel,ich6-gpio.
Yes!
Bin Meng
Stefan Roese
