[U-Boot-Users] Booting IXP425 with RAMDISK support
Dear friends,
i am unable to boot my ixdp425 boot with RAM disk support. I have compiled 2.4.19-rmk7-ds1 kernel with RAM disk, initrd, ext2 file system support. i have loaded my compressed RAM disk into flash too.
while booting the kernel i got the following errors.
## Booting image at 50040000 ... Image Name: Linux Kernel Image Image Type: ARM Linux Kernel Image (gzip compressed) Data Size: 618414 Bytes = 603.9 kB Load Address: 00008000 Entry Point: 00008000 Verifying Checksum ... OK Uncompressing Kernel Image ... OK ## Loading Ramdisk Image at 50160000 ... Image Name: Simple Ramdisk Image Type: ARM Linux RAMDisk Image (gzip compressed) Data Size: 2803063 Bytes = 2.7 MB Load Address: 00000000 Entry Point: 00000000 Verifying Checksum ... OK
Starting kernel ...
Uncompressing Linux........................................... done, booting the kernel. Linux version 2.4.19-rmk7-ds1 (root@Gargouille.comodoindia) (gcc version 3.2.1) #4 Mon May 31 12:19:01 IST 2004 CPU: XScale-IXP4xx/IXC11xx revision 1 Machine: Intel IXDP425 Development Platform alloc_bootmem_low memtable_init On node 0 totalpages: 4096 zone(0): 4096 pages. zone(1): 0 pages. zone(2): 0 pages. Kernel command line: root=/dev/ram rw mem=16M console=ttyS0,115200 Calibrating delay loop... 263.78 BogoMIPS Memory: 16MB = 16MB total Memory: 14736KB available (985K code, 239K data, 208K init) XScale Cache/TLB Locking Copyright(c) 2001 MontaVista Software, Inc. Dentry cache hash table entries: 2048 (order: 2, 16384 bytes) Inode cache hash table entries: 1024 (order: 1, 8192 bytes) Mount-cache hash table entries: 512 (order: 0, 4096 bytes) Buffer-cache hash table entries: 1024 (order: 0, 4096 bytes) Page-cache hash table entries: 4096 (order: 2, 16384 bytes) POSIX conformance testing by UNIFIX PCI: bus0: Fast back to back transfers enabled Linux NET4.0 for Linux 2.4 Based upon Swansea University Computer Society NET3.039 Sangoma WANPIPE Router v1.1 (c) 1995-2000 Sangoma Technologies Inc. Initializing RT netlink socket Starting kswapd i2c-dev.o: Registered 'IXP425 I2C Adapter' as minor 0 pty: 256 Unix98 ptys configured Serial driver version 5.05c (2001-07-08) with MANY_PORTS SHARE_IRQ SERIAL_PCI enabled ttyS00 at 0xff000003x (irq = 15) is a XScale UART ttyS01 at 0xff001003x (irq = 13) is a XScale UART Loaded PCF8594C2 I2C EEPROM NVRAM driver RAMDISK driver initialized: 16 RAM disks of 4192K size 1024 blocksize loop: loaded (max 8 devices) Using buffer write method Using static MTD partitions. Creating 2 MTD partitions on "IXP425 Flash": 0x00040000-0x00440000 : "image" 0x00440000-0x00fc0000 : "user" blkmtd: starting blkmtd: error, missing `device' name ftl_cs: FTL header not found. ftl_cs: FTL header not found. NET4: Linux TCP/IP 1.0 for NET4.0 IP Protocols: ICMP, UDP, TCP IP: routing cache hash table of 512 buckets, 4Kbytes TCP: Hash tables configured (established 1024 bind 2048) NET4: Unix domain sockets 1.0/SMP for Linux NET4.0. NetWinder Floating Point Emulator V0.95 (c) 1998-1999 Rebel.com Kernel panic: VFS: Unable to mount root fs on 01:00
expecting ur commands
Thanks Prakash
Annamalai Prakash
