[U-Boot] [PATCH] imx: Fix potential lmb memory overwritten by stack
At default, u-boot reserves the memory from SP - 4KB to DRAM end for lmb in arch_lmb_reserve. So lmb won't allocate any memory from it. But we found the 4K gap for SP is not enough now, because some FDT updating operations are added in our u-boot before jumping to kernel, which needs larger stack. This causes the lmb allocated memory is overwritten by stack.
Fix the issue by implementing the board_lmb_reserve to reserve from SP - 16KB to memory end for lmb.
Signed-off-by: Ye Li ye.li@nxp.com --- arch/arm/mach-imx/misc.c | 32 ++++++++++++++++++++++++++++++++ 1 file changed, 32 insertions(+)
diff --git a/arch/arm/mach-imx/misc.c b/arch/arm/mach-imx/misc.c index 1bb8c50..31e95a9 100644 --- a/arch/arm/mach-imx/misc.c +++ b/arch/arm/mach-imx/misc.c @@ -9,6 +9,8 @@ #include <asm/io.h> #include <asm/mach-imx/regs-common.h>
+DECLARE_GLOBAL_DATA_PTR; + /* 1 second delay should be plenty of time for block reset. */ #define RESET_MAX_TIMEOUT 1000000
@@ -71,3 +73,33 @@ int mxs_reset_block(struct mxs_register_32 *reg)
return 0; } + +static ulong get_sp(void) +{ + ulong ret; + + asm("mov %0, sp" : "=r"(ret) : ); + return ret; +} + +void board_lmb_reserve(struct lmb *lmb) +{ + ulong sp, bank_end; + int bank; + + sp = get_sp(); + debug("## Current stack ends at 0x%08lx ", sp); + + /* adjust sp by 16K to be safe */ + sp -= 4096 << 2; + for (bank = 0; bank < CONFIG_NR_DRAM_BANKS; bank++) { + if (sp < gd->bd->bi_dram[bank].start) + continue; + bank_end = gd->bd->bi_dram[bank].start + + gd->bd->bi_dram[bank].size; + if (sp >= bank_end) + continue; + lmb_reserve(lmb, sp, bank_end - sp); + break; + } +}
At default, u-boot reserves the memory from SP - 4KB to DRAM end for lmb in arch_lmb_reserve. So lmb won't allocate any memory from it. But we found the 4K gap for SP is not enough now, because some FDT updating operations are added in our u-boot before jumping to kernel, which needs larger stack. This causes the lmb allocated memory is overwritten by stack. Fix the issue by implementing the board_lmb_reserve to reserve from SP - 16KB to memory end for lmb. Signed-off-by: Ye Li ye.li@nxp.com
Best regards, Stefano Babic
sbabic@denx.de
Ye Li
