[U-Boot] [PATCH] mpc512x: Fix problem with I2C access before relocation
This is needed for the upcoming esd MECP5123 board port which uses I2C EEPROM for environment storage.
Signed-off-by: Stefan Roese sr@denx.de Cc: Reinhard Arlt reinhard.arlt@esd-electronics.com --- cpu/mpc512x/i2c.c | 2 +- 1 files changed, 1 insertions(+), 1 deletions(-)
diff --git a/cpu/mpc512x/i2c.c b/cpu/mpc512x/i2c.c index 97bda0d..e2d9097 100644 --- a/cpu/mpc512x/i2c.c +++ b/cpu/mpc512x/i2c.c @@ -33,7 +33,7 @@ DECLARE_GLOBAL_DATA_PTR; #include <i2c.h>
/* by default set I2C bus 0 active */ -static unsigned int bus_num = 0; +static unsigned int bus_num __attribute__ ((section (".data"))) = 0;
#define I2C_TIMEOUT 100 #define I2C_RETRIES 3
Dear Stefan Roese,
Stefan, please check if this is really what you want to do. Environmentin EEPROM is *strongly* discouraged. It is slow like hell, and even more unreliable. Do *not* do this. Check if you can use any other storage - NOR or NAND flash, or the like.
Heiko, if Stefan does not change his mind, then I suggest you ACK the patch and I apply it then to the 5xxx repo?
Hello Wolfgang,
Wolfgang Denk wrote:
Dear Stefan Roese,
This Patch is okay, independent if Stefan changes his mind or not, I think. Thanks to Stefan for finding this.
Acked-by: Heiko Schocherhs@denx.de
bye Heiko
Full ACK. This is a bugfix and should be applied in any case.
Thanks.
Best regards, Stefan
Hi Wolfgang,
I know that EEPROM has some disadvantages. But this is not my choice but the customers (esd) decision. esd has used I2C EEPROM for environment storage for a long time and even included write-protection to the EEPROM.
Dear Stefan Roese,
That's OK if they insist. But it is due diligence to at least point out the potential trouble they are inviting. Which we have done hereby.
But out of curiosity: please do me a favour and measure the time from power-up to U-Boot prompt. Then "setenv baudrate 115200; saveenv" and measure again. Thanks in advance.
Dear Stefan Roese,
Applied to u-boot-mpc5xxx repo, thanks.
Heiko Schocher
Stefan Roese
