[U-Boot] [PATCH] ARM: socfpga: Increase Malloc pool size to support FAT filesystem in SPL
This is minimum memory pool size required to get SPL booting to U-Boot, such as FPGA program and loading U-Boot image from FAT.
Signed-off-by: Tien Fong Chee tien.fong.chee@intel.com --- include/configs/socfpga_common.h | 2 +- 1 files changed, 1 insertions(+), 1 deletions(-)
diff --git a/include/configs/socfpga_common.h b/include/configs/socfpga_common.h index bd8f5c8..93273a8 100644 --- a/include/configs/socfpga_common.h +++ b/include/configs/socfpga_common.h @@ -258,7 +258,7 @@ unsigned int cm_get_qspi_controller_clk_hz(void); #if defined(CONFIG_TARGET_SOCFPGA_ARRIA10) /* SPL memory allocation configuration, this is for FAT implementation */ #ifndef CONFIG_SYS_SPL_MALLOC_START -#define CONFIG_SYS_SPL_MALLOC_SIZE 0x00010000 +#define CONFIG_SYS_SPL_MALLOC_SIZE 0x00012000 #define CONFIG_SYS_SPL_MALLOC_START (CONFIG_SYS_INIT_RAM_SIZE - \ CONFIG_SYS_SPL_MALLOC_SIZE + \ CONFIG_SYS_INIT_RAM_ADDR)
Rather, this is the minimal size needed for FAT to work ? But then , maybe you should just set the malloc area size a bit bigger to have some headroom available.
How did you come to the number 0x12000 ? Did you do some measurements ?
This is minimum memory pool size required to get SPL booting to U- Boot, such as FPGA program and loading U-Boot image from FAT.
Yes, the is minimal size based on that series of FPGA program patches. How much you think we should increase?
Yup, after applying these patches: 1. https://www.mail-archive.com/u-boot@lists.denx.de/msg313259.html%C2%A0- Saving 84kIB max cluster block from excludng both fat write and EXT4 in SPL.
2. https://www.mail-archive.com/u-boot@lists.denx.de/msg312340.html Maximise reusable from memory pool, so the amount required for mmeory pool can be reduced to only (1 max cluster size[0x100000] + other than max cluster size[0x2000]), total is 0x12000.
diff --git a/include/configs/socfpga_common.h b/include/configs/socfpga_common.h index bd8f5c8..93273a8 100644 --- a/include/configs/socfpga_common.h +++ b/include/configs/socfpga_common.h @@ -258,7 +258,7 @@ unsigned int cm_get_qspi_controller_clk_hz(void); #if defined(CONFIG_TARGET_SOCFPGA_ARRIA10) /* SPL memory allocation configuration, this is for FAT implementation */ #ifndef CONFIG_SYS_SPL_MALLOC_START -#define CONFIG_SYS_SPL_MALLOC_SIZE 0x00010000 +#define CONFIG_SYS_SPL_MALLOC_SIZE 0x00012000 #define CONFIG_SYS_SPL_MALLOC_START (CONFIG_SYS_INIT_RAM_SI ZE - \ CONFIG_SYS_SPL_MALLOC_SIZ E + \ CONFIG_SYS_INIT_RAM_ADDR)
Chee, Tien Fong
