[U-Boot] [PULL] u-boot-atmel/master -> u-boot-arm/master
Dear Albert Aribaud,
please pull the following fix ups from u-boot-atmel/master into u-boot-arm/master.
The following changes since commit d2c7074b9593d822e2359a09c21747248fdf5fac:
ARM: OMAP5: clocks: Update MPU settings for OPP_NOM (2013-12-12 17:43:39 -0500)
git://git.denx.de/u-boot-atmel.git master
for you to fetch changes up to d51a2a2d63d83207b56a7aef7a191d081058d6ae:
arm: atmel: at91sam9x5: move CONFIG_SYS_NO_FLASH to proper position (2013-12-17 17:21:18 +0100)
---------------------------------------------------------------- Bo Shen (3): arm: atmel: at91sam9x5: cleanup cs configure for spi arm: atmel: at91sam9x5: cleanup unneeded undef arm: atmel: at91sam9x5: move CONFIG_SYS_NO_FLASH to proper position
board/atmel/at91sam9x5ek/at91sam9x5ek.c | 1 - include/configs/at91sam9x5ek.h | 13 +++---------- 2 files changed, 3 insertions(+), 11 deletions(-)
Hi Andreas,
On Tue, 17 Dec 2013 17:25:55 +0100, Andreas Bießmann andreas.devel@googlemail.com wrote:
Applied to u-boot-arm/master, thanks!
Amicalement,
Albert ARIBAUD
Andreas Bießmann
