[PATCH v2 1/1] drivers: misc: Add socfpga_dtreg driver for Intel SoCFPGA
Add socfpga_dtreg driver enablement for Intel SoCFPGA.
Signed-off-by: Wan Yee Lau wan.yee.lau@intel.com --- Changes for v2: - Rearranged header file in socfpga_drteg.c, moved <asm/io.h> lower.
arch/arm/Kconfig | 2 + .../misc/socfpga_dtreg.txt | 74 +++++++++++ drivers/misc/Kconfig | 7 ++ drivers/misc/Makefile | 1 + drivers/misc/socfpga_dtreg.c | 117 ++++++++++++++++++ 5 files changed, 201 insertions(+) create mode 100644 doc/device-tree-bindings/misc/socfpga_dtreg.txt create mode 100644 drivers/misc/socfpga_dtreg.c
diff --git a/arch/arm/Kconfig b/arch/arm/Kconfig index 531b081de9..6087345eb8 100644 --- a/arch/arm/Kconfig +++ b/arch/arm/Kconfig @@ -1092,6 +1092,8 @@ config ARCH_SOCFPGA select SPL_LIBGENERIC_SUPPORT select SPL_OF_CONTROL select SPL_SEPARATE_BSS if TARGET_SOCFPGA_SOC64 + select SPL_DRIVERS_MISC if TARGET_SOCFPGA_SOC64 + select SPL_SOCFPGA_DT_REG if TARGET_SOCFPGA_SOC64 select SPL_SERIAL select SPL_SYSRESET select SPL_WATCHDOG diff --git a/doc/device-tree-bindings/misc/socfpga_dtreg.txt b/doc/device-tree-bindings/misc/socfpga_dtreg.txt new file mode 100644 index 0000000000..6057f792b9 --- /dev/null +++ b/doc/device-tree-bindings/misc/socfpga_dtreg.txt @@ -0,0 +1,74 @@ +* Firewall and privilege register settings in device tree + +Required properties: +-------------------- + +- compatible: should contain "intel,socfpga-dtreg" +- reg: Physical base address and size of block register. +- intel,offset-settings: 32-bit offset address of block register, + followed by 32-bit value settings and + the masking bits, only masking bit + set to 1 allows modification. + +The device tree node which describes secure and privilege register access +configuration in compile time. + +Most of these registers are expected to work except for the case which some +registers configuration are required for granting access to some other +registers, for example CCU registers have to be properly configured before +allowing register configuration access to fpga2sdram firewall as shown in +below example. + +Some registers depend on runtime data for proper configuration are expected +to be part of driver that generating these data for example configuration for +soc_noc_fw_ddr_mpu_inst_0_ddr_scr block register depend on DDR size parsed from +memory device tree node. + +Please refer details of tested examples below for both fpga2sdram and QoS +configuration with default reset value and the comments. + +Example: +-------- + +Configuration for multiple dtreg node support in device tree: + + socfpga_dtreg0: socfpga-dtreg0 { + compatible = "intel,socfpga-dtreg"; + #address-cells = <1>; + #size-cells = <1>; + bootph-all; + + coh_cpu0_bypass_OC_Firewall_main_Firewall@f7100200 { + reg = <0xf7100200 0x00000014>; + intel,offset-settings = + /* Disable ocram security at CCU for non secure access */ + <0x0000004 0x8000ffff 0xe007ffff>, + <0x0000008 0x8000ffff 0xe007ffff>, + <0x000000c 0x8000ffff 0xe007ffff>, + <0x0000010 0x8000ffff 0xe007ffff>; + bootph-all; + }; + }; + + socfpga_dtreg1: socfpga-dtreg1 { + compatible = "intel,socfpga-dtreg"; + #address-cells = <1>; + #size-cells = <1>; + bootph-all; + + soc_noc_fw_mpfe_csr_inst_0_mpfe_scr@f8020000 { + reg = <0xf8020000 0x0000001c>; + intel,offset-settings = + /* Disable MPFE firewall for SMMU */ + <0x00000000 0x00010101 0x00010101>, + /* Disable MPFE firewall for HMC adapter */ + <0x00000004 0x00000001 0x00010101>; + bootph-all; + }; + }; + +To call the nodes use: + + ret = uclass_get_device_by_name(UCLASS_NOP, "socfpga-dtreg0", &dev); + ret = uclass_get_device_by_name(UCLASS_NOP, "socfpga-dtreg1", &dev); + diff --git a/drivers/misc/Kconfig b/drivers/misc/Kconfig index fccd9b89b8..c423905ba2 100644 --- a/drivers/misc/Kconfig +++ b/drivers/misc/Kconfig @@ -683,4 +683,11 @@ config SL28CPLD the base driver which provides common access methods for the sub-drivers.
+config SPL_SOCFPGA_DT_REG + bool "Enable register setting from device tree in SPL" + depends on SPL + help + Enable register setting from device tree. This also + provides user a clean interface and all register settings are + centralized in one place, device tree. endmenu diff --git a/drivers/misc/Makefile b/drivers/misc/Makefile index b67b82358a..b74c8b9f80 100644 --- a/drivers/misc/Makefile +++ b/drivers/misc/Makefile @@ -89,3 +89,4 @@ obj-$(CONFIG_K3_AVS0) += k3_avs.o obj-$(CONFIG_ESM_K3) += k3_esm.o obj-$(CONFIG_ESM_PMIC) += esm_pmic.o obj-$(CONFIG_SL28CPLD) += sl28cpld.o +obj-$(CONFIG_SPL_SOCFPGA_SEC_REG) += socfpga_dtreg.o diff --git a/drivers/misc/socfpga_dtreg.c b/drivers/misc/socfpga_dtreg.c new file mode 100644 index 0000000000..a8554bfd1d --- /dev/null +++ b/drivers/misc/socfpga_dtreg.c @@ -0,0 +1,117 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright (C) 2024 Intel Corporation <www.intel.com> + */ + +#include <common.h> +#include <dm.h> +#include <errno.h> +#include <asm/io.h> +#include <linux/sizes.h> + +#define NUMBER_OF_ELEMENTS 3 + +static int socfpga_dtreg_probe(struct udevice *dev) +{ + const fdt32_t *list; + fdt_addr_t offset, base; + fdt_val_t val, read_val, mask, set_mask; + int size, i; + u32 blk_sz, reg; + ofnode node; + const char *name = NULL; + + debug("%s(dev=%p)\n", __func__, dev); + + if (!dev_has_ofnode(dev)) + return 0; + + dev_for_each_subnode(node, dev) { + name = ofnode_get_name(node); + if (!name) + return -EINVAL; + + if (ofnode_read_u32_index(node, "reg", 1, &blk_sz)) + return -EINVAL; + + base = ofnode_get_addr(node); + if (base == FDT_ADDR_T_NONE) + return -EINVAL; + + debug("%s(node_offset 0x%lx node_name %s ", __func__, + node.of_offset, name); + debug("node addr 0x%llx blk sz 0x%x)\n", base, blk_sz); + + list = ofnode_read_prop(node, "intel,offset-settings", &size); + if (!list) + return -EINVAL; + + debug("%s(intel,offset-settings property size=%x)\n", __func__, + size); + size /= sizeof(*list) * NUMBER_OF_ELEMENTS; + + /* + * First element: offset + * Second element: val + * Third element: mask + */ + for (i = 0; i < size; i++) { + offset = fdt32_to_cpu(*list++); + val = fdt32_to_cpu(*list++); + + /* Reads the masking bit value from the list */ + mask = fdt32_to_cpu(*list++); + + /* + * Reads out the offsets, value and masking bits + * Ex: <0x00000000 0x00000230 0xffffffff> + */ + debug("%s(intel,offset-settings 0x%llx : 0x%llx : 0x%llx)\n", + __func__, offset, val, mask); + + if (blk_sz < offset + SZ_4) { + printf("%s: Overflow as offset 0x%llx or reg", + __func__, offset); + printf(" write is more than block size 0x%x\n", + blk_sz); + return -EINVAL; + } + + if (mask != 0) { + if (mask == 0xffffffff) { + reg = base + offset; + writel(val, (uintptr_t)reg); + } else { + /* Mask the value with the masking bits */ + set_mask = val & mask; + + reg = base + offset; + + /* Clears and sets specific bits in the register */ + clrsetbits_le32((uintptr_t)reg, mask, set_mask); + } + } + + read_val = readl((uintptr_t)reg); + + /* Reads out the register, masked value and the read value */ + debug("%s(reg 0x%x = wr : 0x%llx rd : 0x%llx)\n", + __func__, reg, set_mask, read_val); + + } + } + + return 0; +}; + +static const struct udevice_id socfpga_dtreg_ids[] = { + {.compatible = "intel,socfpga-dtreg"}, + { } +}; + +U_BOOT_DRIVER(socfpga_dtreg) = { + .name = "socfpga-dtreg", + .id = UCLASS_NOP, + .of_match = socfpga_dtreg_ids, + .probe = socfpga_dtreg_probe, +}; -- 2.25.1
-----Original Message----- From: Lau, Wan Yee wan.yee.lau@intel.com Sent: Monday, February 5, 2024 11:47 AM To: u-boot@lists.denx.de Cc: Marek marex@denx.de; Simon simon.k.r.goldschmidt@gmail.com; Chee, Tien Fong tien.fong.chee@intel.com; Hea, Kok Kiang kok.kiang.hea@intel.com; Chong, Teik Heng teik.heng.chong@intel.com Subject: [PATCH v2 1/1] drivers: misc: Add socfpga_dtreg driver for Intel SoCFPGA
Changes for v2:
- select SPL_DRIVERS_MISC if TARGET_SOCFPGA_SOC64
- select SPL_SOCFPGA_DT_REG if TARGET_SOCFPGA_SOC64 select SPL_SERIAL select SPL_SYSRESET select SPL_WATCHDOG
diff --git a/doc/device-tree-bindings/misc/socfpga_dtreg.txt b/doc/device- tree-bindings/misc/socfpga_dtreg.txt new file mode 100644 index 0000000000..6057f792b9 --- /dev/null +++ b/doc/device-tree-bindings/misc/socfpga_dtreg.txt @@ -0,0 +1,74 @@ +* Firewall and privilege register settings in device tree
+The device tree node which describes secure and privilege register +access configuration in compile time.
+Most of these registers are expected to work except for the case which +some registers configuration are required for granting access to some +other registers, for example CCU registers have to be properly +configured before allowing register configuration access to fpga2sdram +firewall as shown in below example.
+Some registers depend on runtime data for proper configuration are +expected to be part of driver that generating these data for example +configuration for soc_noc_fw_ddr_mpu_inst_0_ddr_scr block register +depend on DDR size parsed from memory device tree node.
+Please refer details of tested examples below for both fpga2sdram and +QoS configuration with default reset value and the comments.
+Example: +--------
- socfpga_dtreg0: socfpga-dtreg0 {
#size-cells = <1>;
bootph-all;
access */
bootph-all;
- socfpga_dtreg1: socfpga-dtreg1 {
#size-cells = <1>;
bootph-all;
bootph-all;
- ret = uclass_get_device_by_name(UCLASS_NOP, "socfpga-dtreg0",
&dev);
- ret = uclass_get_device_by_name(UCLASS_NOP, "socfpga-dtreg1",
&dev);
- bool "Enable register setting from device tree in SPL"
- depends on SPL
- help
- Copyright (C) 2024 Intel Corporation <www.intel.com> */
+static int socfpga_dtreg_probe(struct udevice *dev) {
- const fdt32_t *list;
- fdt_addr_t offset, base;
- fdt_val_t val, read_val, mask, set_mask;
- int size, i;
- u32 blk_sz, reg;
- ofnode node;
- const char *name = NULL;
- debug("%s(dev=%p)\n", __func__, dev);
- if (!dev_has_ofnode(dev))
- dev_for_each_subnode(node, dev) {
if (!name)
return -EINVAL;
return -EINVAL;
return -EINVAL;
if (!list)
return -EINVAL;
__func__,
size);
0x%llx)\n",
__func__, offset);
blk_sz);
return -EINVAL;
if (mask != 0) {
} else {
bits */
register */
set_mask);
value */
- {.compatible = "intel,socfpga-dtreg"},
- .name = "socfpga-dtreg",
- .id = UCLASS_NOP,
- .of_match = socfpga_dtreg_ids,
- .probe = socfpga_dtreg_probe,
Reviewed-by: Tien Fong Chee tien.fong.chee@intel.com
Regards Tien Fong
Chee, Tien Fong
wan.yee.lauļ¼ intel.com
