[U-Boot-Users] [PATCH 1/2] Add memmem() library function
Signed-off-by: Grant Likely grant.likely@secretlab.ca ---
include/linux/string.h | 3 +++ lib_generic/string.c | 34 ++++++++++++++++++++++++++++++++++ 2 files changed, 37 insertions(+), 0 deletions(-)
diff --git a/include/linux/string.h b/include/linux/string.h index 6239039..e18bcbf 100644 --- a/include/linux/string.h +++ b/include/linux/string.h @@ -81,6 +81,9 @@ extern int memcmp(const void *,const void *,__kernel_size_t); #ifndef __HAVE_ARCH_MEMCHR extern void * memchr(const void *,int,__kernel_size_t); #endif +#ifndef __HAVE_ARCH_MEMMEM +extern void * memmem(const void *,__kernel_size_t,const void *,__kernel_size_t); +#endif
#ifdef __cplusplus } diff --git a/lib_generic/string.c b/lib_generic/string.c index e0b793a..36262de 100644 --- a/lib_generic/string.c +++ b/lib_generic/string.c @@ -574,5 +574,39 @@ void *memchr(const void *s, int c, size_t n) } return NULL; } +#endif + +#ifndef __HAVE_ARCH_MEMMEM +/** + * memmem - Find a sequence in an area of memory + * @a: The memory area + * @len1: Size of the memory area + * @b: The sequence to search for + * @len2: Size of the sequence + * + * returns the address of the first occurrence of @b, or %NULL + * if @b is not found + */ +void *memmem (const void *m, size_t ml, const void *s, size_t sl) +{ + const char * start = m; + const char * end = m + ml;
+ if (sl > ml) + return NULL; + + while (start < end) + { + size_t len = sl; + const char * ptr1 = start; + const char * ptr2 = s; + while (len > 0 && *ptr1++ == *ptr2++) + len--; + if (len == 0) + return (void *)start; + start++; + } + + return NULL; +} #endif
The TFTP OACK code trusts that the incoming packet is formated as ASCII text and can be processed by string functions. It also as a loop limit overflow bug where if the packet length is less than 8, it ends up looping over *all* of memory to find the 'blksize' string. This occurs because 'len' is an unsigned value, and 'len-8' is also calculated as unsigned which results in a huge loop limit.
This patch solves the problem by using memmem() to search for the sub string.
Signed-off-by: Grant Likely grant.likely@secretlab.ca --- Wolfgang, please test this version. I think I've got it right now.
Cheers, g.
net/tftp.c | 19 +++++++++---------- 1 files changed, 9 insertions(+), 10 deletions(-)
diff --git a/net/tftp.c b/net/tftp.c index fb2f505..e36d76f 100644 --- a/net/tftp.c +++ b/net/tftp.c @@ -238,9 +238,9 @@ TftpSend (void) static void TftpHandler (uchar * pkt, unsigned dest, unsigned src, unsigned len) { + char * blksize; ushort proto; ushort *s; - int i;
if (dest != TftpOurPort) { #ifdef CONFIG_MCAST_TFTP @@ -272,22 +272,21 @@ TftpHandler (uchar * pkt, unsigned dest, unsigned src, unsigned len)
case TFTP_OACK: #ifdef ET_DEBUG - printf("Got OACK: %s %s\n", pkt, pkt+strlen(pkt)+1); + printf("Got OACK:\n"); + print_buffer (0, pkt, 1, len, 16); #endif TftpState = STATE_OACK; TftpServerPort = src; + /* Check for 'blksize' option */ - for (i=0;i<len-8;i++) { - if (strcmp ((char*)pkt+i,"blksize") == 0) { - TftpBlkSize = (unsigned short) - simple_strtoul((char*)pkt+i+8,NULL,10); + blksize = memmem(pkt, len, "blksize", 8); /* str + '\0' */ + if ((blksize) && (blksize + 8 < (char*)pkt + len)) { + TftpBlkSize = simple_strtoul(blksize + 8, NULL, 10); #ifdef ET_DEBUG - printf ("Blocksize ack: %s, %d\n", - (char*)pkt+i+8,TftpBlkSize); + printf("Blocksize ack: %d\n", TftpBlkSize); #endif - break; - } } + #ifdef CONFIG_MCAST_TFTP parse_multicast_oack((char *)pkt,len-1); if ((Multicast) && (!MasterClient))
Grant Likely
