[U-Boot] [PATCH v2 0/3] Fix loading kernel on RK3288 Radxa Rock2 Square
I wasn't able to load the linux kernel using a Rock2 board using the latest master branch. The board hangs after it has handed executing over to the kernel. I found that the latest release that worked was v2016.03.
This patchset fixes kernel loading on rk3288 rock2 square board. I tested with with 3.14 adn 4.7-rc6 kernels. I used gcc-linaro-5.3-2016.02-x86_64_arm-linux-gnueabi.
Before fixing, the console output was:
Starting kernel ...
### ERROR ### Please RESET the board ###
Changes for v2: - Remove patch to change to high mem limit. - Rebase to u-boot/master.
Sandy Patterson (3): Revert "arm: Replace v7_maint_dcache_all(ARMV7_DCACHE_CLEAN_INVAL_ALL) with asm code" Revert "arm: Replace v7_maint_dcache_all(ARMV7_DCACHE_INVAL_ALL) with asm code" CONFIG_EFI_LOADER breaks rock2 kernel loading
arch/arm/cpu/armv7/Makefile | 2 +- arch/arm/cpu/armv7/cache_v7.c | 134 ++++++++++++++++++++++- arch/arm/cpu/armv7/cache_v7_asm.S | 154 --------------------------- arch/arm/mach-uniphier/arm32/lowlevel_init.S | 67 +++++++++++- configs/rock2_defconfig | 1 + 5 files changed, 198 insertions(+), 160 deletions(-) delete mode 100644 arch/arm/cpu/armv7/cache_v7_asm.S
Commit c09d29057a and df120142f36 break kernel loading on rock2 board.
console output: Starting kernel ...
This reverts commit c09d29057ab0b04db0857d319c6bff74de31b9c3.
Conflicts: arch/arm/cpu/armv7/cache_v7.c arch/arm/cpu/armv7/cache_v7_asm.S
Signed-off-by: Sandy Patterson apatterson@sightlogix.com ---
arch/arm/cpu/armv7/Makefile | 2 +- arch/arm/cpu/armv7/cache_v7.c | 114 +++++++++++++++++++- arch/arm/cpu/armv7/cache_v7_asm.S | 154 --------------------------- arch/arm/mach-uniphier/arm32/lowlevel_init.S | 67 +++++++++++- 4 files changed, 180 insertions(+), 157 deletions(-) delete mode 100644 arch/arm/cpu/armv7/cache_v7_asm.S
diff --git a/arch/arm/cpu/armv7/Makefile b/arch/arm/cpu/armv7/Makefile index 0d4bfbc..9d20f17 100644 --- a/arch/arm/cpu/armv7/Makefile +++ b/arch/arm/cpu/armv7/Makefile @@ -7,7 +7,7 @@
extra-y := start.o
-obj-y += cache_v7.o cache_v7_asm.o +obj-y += cache_v7.o
obj-y += cpu.o cp15.o obj-y += syslib.o diff --git a/arch/arm/cpu/armv7/cache_v7.c b/arch/arm/cpu/armv7/cache_v7.c index 52f1856..9fbabb4 100644 --- a/arch/arm/cpu/armv7/cache_v7.c +++ b/arch/arm/cpu/armv7/cache_v7.c @@ -28,6 +28,118 @@ static u32 get_ccsidr(void) return ccsidr; }
+static u32 get_clidr(void) +{ + u32 clidr; + + /* Read current CP15 Cache Level ID Register */ + asm volatile ("mrc p15,1,%0,c0,c0,1" : "=r" (clidr)); + return clidr; +} + +static void v7_inval_dcache_level_setway(u32 level, u32 num_sets, + u32 num_ways, u32 way_shift, + u32 log2_line_len) +{ + int way, set; + u32 setway; + + /* + * For optimal assembly code: + * a. count down + * b. have bigger loop inside + */ + for (way = num_ways - 1; way >= 0 ; way--) { + for (set = num_sets - 1; set >= 0; set--) { + setway = (level << 1) | (set << log2_line_len) | + (way << way_shift); + /* Invalidate data/unified cache line by set/way */ + asm volatile (" mcr p15, 0, %0, c7, c6, 2" + : : "r" (setway)); + } + } + /* DSB to make sure the operation is complete */ + DSB; +} + +static void v7_clean_inval_dcache_level_setway(u32 level, u32 num_sets, + u32 num_ways, u32 way_shift, + u32 log2_line_len) +{ + int way, set; + u32 setway; + + /* + * For optimal assembly code: + * a. count down + * b. have bigger loop inside + */ + for (way = num_ways - 1; way >= 0 ; way--) { + for (set = num_sets - 1; set >= 0; set--) { + setway = (level << 1) | (set << log2_line_len) | + (way << way_shift); + /* + * Clean & Invalidate data/unified + * cache line by set/way + */ + asm volatile (" mcr p15, 0, %0, c7, c14, 2" + : : "r" (setway)); + } + } + /* DSB to make sure the operation is complete */ + DSB; +} + +static void v7_maint_dcache_level_setway(u32 level, u32 operation) +{ + u32 ccsidr; + u32 num_sets, num_ways, log2_line_len, log2_num_ways; + u32 way_shift; + + set_csselr(level, ARMV7_CSSELR_IND_DATA_UNIFIED); + + ccsidr = get_ccsidr(); + + log2_line_len = ((ccsidr & CCSIDR_LINE_SIZE_MASK) >> + CCSIDR_LINE_SIZE_OFFSET) + 2; + /* Converting from words to bytes */ + log2_line_len += 2; + + num_ways = ((ccsidr & CCSIDR_ASSOCIATIVITY_MASK) >> + CCSIDR_ASSOCIATIVITY_OFFSET) + 1; + num_sets = ((ccsidr & CCSIDR_NUM_SETS_MASK) >> + CCSIDR_NUM_SETS_OFFSET) + 1; + /* + * According to ARMv7 ARM number of sets and number of ways need + * not be a power of 2 + */ + log2_num_ways = log_2_n_round_up(num_ways); + + way_shift = (32 - log2_num_ways); + if (operation == ARMV7_DCACHE_INVAL_ALL) { + v7_inval_dcache_level_setway(level, num_sets, num_ways, + way_shift, log2_line_len); + } else if (operation == ARMV7_DCACHE_CLEAN_INVAL_ALL) { + v7_clean_inval_dcache_level_setway(level, num_sets, num_ways, + way_shift, log2_line_len); + } +} + +static void v7_maint_dcache_all(u32 operation) +{ + u32 level, cache_type, level_start_bit = 0; + u32 clidr = get_clidr(); + + for (level = 0; level < 7; level++) { + cache_type = (clidr >> level_start_bit) & 0x7; + if ((cache_type == ARMV7_CLIDR_CTYPE_DATA_ONLY) || + (cache_type == ARMV7_CLIDR_CTYPE_INSTRUCTION_DATA) || + (cache_type == ARMV7_CLIDR_CTYPE_UNIFIED)) + v7_maint_dcache_level_setway(level, operation); + level_start_bit += 3; + } +} + static void v7_dcache_clean_inval_range(u32 start, u32 stop, u32 line_len) { u32 mva; @@ -106,7 +218,7 @@ void invalidate_dcache_all(void) */ void flush_dcache_all(void) { - v7_flush_dcache_all(); + v7_maint_dcache_all(ARMV7_DCACHE_CLEAN_INVAL_ALL);
v7_outer_cache_flush_all(); } diff --git a/arch/arm/cpu/armv7/cache_v7_asm.S b/arch/arm/cpu/armv7/cache_v7_asm.S deleted file mode 100644 index a433628..0000000 --- a/arch/arm/cpu/armv7/cache_v7_asm.S +++ /dev/null @@ -1,154 +0,0 @@ -/* - * SPDX-License-Identifier: GPL-2.0+ - */ - -#include <config.h> -#include <linux/linkage.h> -#include <linux/sizes.h> -#include <asm/system.h> - -#ifdef CONFIG_SYS_THUMB_BUILD -#define ARM(x...) -#define THUMB(x...) x -#else -#define ARM(x...) x -#define THUMB(x...) -#endif - -/* - * v7_flush_dcache_all() - * - * Flush the whole D-cache. - * - * Corrupted registers: r0-r7, r9-r11 (r6 only in Thumb mode) - * - * Note: copied from arch/arm/mm/cache-v7.S of Linux 4.4 - */ -ENTRY(__v7_flush_dcache_all) - dmb @ ensure ordering with previous memory accesses - mrc p15, 1, r0, c0, c0, 1 @ read clidr - mov r3, r0, lsr #23 @ move LoC into position - ands r3, r3, #7 << 1 @ extract LoC*2 from clidr - beq finished @ if loc is 0, then no need to clean -start_flush_levels: - mov r10, #0 @ start clean at cache level 0 -flush_levels: - add r2, r10, r10, lsr #1 @ work out 3x current cache level - mov r1, r0, lsr r2 @ extract cache type bits from clidr - and r1, r1, #7 @ mask of the bits for current cache only - cmp r1, #2 @ see what cache we have at this level - blt skip @ skip if no cache, or just i-cache - mcr p15, 2, r10, c0, c0, 0 @ select current cache level in cssr - isb @ isb to sych the new cssr&csidr - mrc p15, 1, r1, c0, c0, 0 @ read the new csidr - and r2, r1, #7 @ extract the length of the cache lines - add r2, r2, #4 @ add 4 (line length offset) - movw r4, #0x3ff - ands r4, r4, r1, lsr #3 @ find maximum number on the way size - clz r5, r4 @ find bit position of way size increment - movw r7, #0x7fff - ands r7, r7, r1, lsr #13 @ extract max number of the index size -loop1: - mov r9, r7 @ create working copy of max index -loop2: - ARM( orr r11, r10, r4, lsl r5 ) @ factor way and cache number into r11 - THUMB( lsl r6, r4, r5 ) - THUMB( orr r11, r10, r6 ) @ factor way and cache number into r11 - ARM( orr r11, r11, r9, lsl r2 ) @ factor index number into r11 - THUMB( lsl r6, r9, r2 ) - THUMB( orr r11, r11, r6 ) @ factor index number into r11 - mcr p15, 0, r11, c7, c14, 2 @ clean & invalidate by set/way - subs r9, r9, #1 @ decrement the index - bge loop2 - subs r4, r4, #1 @ decrement the way - bge loop1 -skip: - add r10, r10, #2 @ increment cache number - cmp r3, r10 - bgt flush_levels -finished: - mov r10, #0 @ swith back to cache level 0 - mcr p15, 2, r10, c0, c0, 0 @ select current cache level in cssr - dsb st - isb - bx lr -ENDPROC(__v7_flush_dcache_all) - -ENTRY(v7_flush_dcache_all) - ARM( stmfd sp!, {r4-r5, r7, r9-r11, lr} ) - THUMB( stmfd sp!, {r4-r7, r9-r11, lr} ) - bl __v7_flush_dcache_all - ARM( ldmfd sp!, {r4-r5, r7, r9-r11, lr} ) - THUMB( ldmfd sp!, {r4-r7, r9-r11, lr} ) - bx lr -ENDPROC(v7_flush_dcache_all) - -/* - * v7_invalidate_dcache_all() - * - * Invalidate the whole D-cache. - * - * Corrupted registers: r0-r7, r9-r11 (r6 only in Thumb mode) - * - * Note: copied from __v7_flush_dcache_all above with - * mcr p15, 0, r11, c7, c14, 2 - * Replaced with: - * mcr p15, 0, r11, c7, c6, 2 - */ -ENTRY(__v7_invalidate_dcache_all) - dmb @ ensure ordering with previous memory accesses - mrc p15, 1, r0, c0, c0, 1 @ read clidr - mov r3, r0, lsr #23 @ move LoC into position - ands r3, r3, #7 << 1 @ extract LoC*2 from clidr - beq inval_finished @ if loc is 0, then no need to clean - mov r10, #0 @ start clean at cache level 0 -inval_levels: - add r2, r10, r10, lsr #1 @ work out 3x current cache level - mov r1, r0, lsr r2 @ extract cache type bits from clidr - and r1, r1, #7 @ mask of the bits for current cache only - cmp r1, #2 @ see what cache we have at this level - blt inval_skip @ skip if no cache, or just i-cache - mcr p15, 2, r10, c0, c0, 0 @ select current cache level in cssr - isb @ isb to sych the new cssr&csidr - mrc p15, 1, r1, c0, c0, 0 @ read the new csidr - and r2, r1, #7 @ extract the length of the cache lines - add r2, r2, #4 @ add 4 (line length offset) - movw r4, #0x3ff - ands r4, r4, r1, lsr #3 @ find maximum number on the way size - clz r5, r4 @ find bit position of way size increment - movw r7, #0x7fff - ands r7, r7, r1, lsr #13 @ extract max number of the index size -inval_loop1: - mov r9, r7 @ create working copy of max index -inval_loop2: - ARM( orr r11, r10, r4, lsl r5 ) @ factor way and cache number into r11 - THUMB( lsl r6, r4, r5 ) - THUMB( orr r11, r10, r6 ) @ factor way and cache number into r11 - ARM( orr r11, r11, r9, lsl r2 ) @ factor index number into r11 - THUMB( lsl r6, r9, r2 ) - THUMB( orr r11, r11, r6 ) @ factor index number into r11 - mcr p15, 0, r11, c7, c6, 2 @ invalidate by set/way - subs r9, r9, #1 @ decrement the index - bge inval_loop2 - subs r4, r4, #1 @ decrement the way - bge inval_loop1 -inval_skip: - add r10, r10, #2 @ increment cache number - cmp r3, r10 - bgt inval_levels -inval_finished: - mov r10, #0 @ swith back to cache level 0 - mcr p15, 2, r10, c0, c0, 0 @ select current cache level in cssr - dsb st - isb - bx lr -ENDPROC(__v7_invalidate_dcache_all) - -ENTRY(v7_invalidate_dcache_all) - ARM( stmfd sp!, {r4-r5, r7, r9-r11, lr} ) - THUMB( stmfd sp!, {r4-r7, r9-r11, lr} ) - bl __v7_invalidate_dcache_all - ARM( ldmfd sp!, {r4-r5, r7, r9-r11, lr} ) - THUMB( ldmfd sp!, {r4-r7, r9-r11, lr} ) - bx lr -ENDPROC(v7_invalidate_dcache_all) diff --git a/arch/arm/mach-uniphier/arm32/lowlevel_init.S b/arch/arm/mach-uniphier/arm32/lowlevel_init.S index cc34116..6f05abf 100644 --- a/arch/arm/mach-uniphier/arm32/lowlevel_init.S +++ b/arch/arm/mach-uniphier/arm32/lowlevel_init.S @@ -38,7 +38,7 @@ ENTRY(lowlevel_init) * to do next is to create a page table and switch over to it. */ bl create_page_table - bl __v7_flush_dcache_all + bl v7_flush_dcache_all
/* Disable MMU and Dcache before switching Page Table */ mrc p15, 0, r0, c1, c0, 0 @ SCTLR (System Control Register) @@ -140,3 +140,68 @@ ENTRY(create_page_table) str r0, [r12, #4] @ mark the second section as Normal mov pc, lr ENDPROC(create_page_table) + +/* We don't use Thumb instructions for now */ +#define ARM(x...) x +#define THUMB(x...) + +/* + * v7_flush_dcache_all() + * + * Flush the whole D-cache. + * + * Corrupted registers: r0-r7, r9-r11 (r6 only in Thumb mode) + * + * - mm - mm_struct describing address space + * + * Note: copied from arch/arm/mm/cache-v7.S of Linux 4.4 + */ +ENTRY(v7_flush_dcache_all) + dmb @ ensure ordering with previous memory accesses + mrc p15, 1, r0, c0, c0, 1 @ read clidr + mov r3, r0, lsr #23 @ move LoC into position + ands r3, r3, #7 << 1 @ extract LoC*2 from clidr + beq finished @ if loc is 0, then no need to clean +start_flush_levels: + mov r10, #0 @ start clean at cache level 0 +flush_levels: + add r2, r10, r10, lsr #1 @ work out 3x current cache level + mov r1, r0, lsr r2 @ extract cache type bits from clidr + and r1, r1, #7 @ mask of the bits for current cache only + cmp r1, #2 @ see what cache we have at this level + blt skip @ skip if no cache, or just i-cache + mcr p15, 2, r10, c0, c0, 0 @ select current cache level in cssr + isb @ isb to sych the new cssr&csidr + mrc p15, 1, r1, c0, c0, 0 @ read the new csidr + and r2, r1, #7 @ extract the length of the cache lines + add r2, r2, #4 @ add 4 (line length offset) + movw r4, #0x3ff + ands r4, r4, r1, lsr #3 @ find maximum number on the way size + clz r5, r4 @ find bit position of way size increment + movw r7, #0x7fff + ands r7, r7, r1, lsr #13 @ extract max number of the index size +loop1: + mov r9, r7 @ create working copy of max index +loop2: + ARM( orr r11, r10, r4, lsl r5 ) @ factor way and cache number into r11 + THUMB( lsl r6, r4, r5 ) + THUMB( orr r11, r10, r6 ) @ factor way and cache number into r11 + ARM( orr r11, r11, r9, lsl r2 ) @ factor index number into r11 + THUMB( lsl r6, r9, r2 ) + THUMB( orr r11, r11, r6 ) @ factor index number into r11 + mcr p15, 0, r11, c7, c14, 2 @ clean & invalidate by set/way + subs r9, r9, #1 @ decrement the index + bge loop2 + subs r4, r4, #1 @ decrement the way + bge loop1 +skip: + add r10, r10, #2 @ increment cache number + cmp r3, r10 + bgt flush_levels +finished: + mov r10, #0 @ swith back to cache level 0 + mcr p15, 2, r10, c0, c0, 0 @ select current cache level in cssr + dsb st + isb + mov pc, lr +ENDPROC(v7_flush_dcache_all)
So, we cannot do this. The problem is two-fold. First, newer GCCs will cause failure to boot with the way the code was, which is how we found this problem. The second is that after some offline conversations with ARM Ltd people (and some other smart folks too, these operations cannot safely be done in C, there's just no way. So we borrowed what the kernel does. You need to figure out what behavior the (old?) kernel is relying on and either emulate that with a flag (like sunxi does, or at least did, at one point for some other issues of correct behavior vs existing kernels) or just not support those older kernels.
I see the problem with 4.7-rc6. Is there a different kernel I should test with?
-- Tom
No, I was hoping (from some other threads I had skimmed) that this was a problem only with an older 3.14.y. You need to figure out where / why the hang is happening.
This reverts commit df120142f36b6ff8b12187b8860269763b2b3203.
arch/arm/cpu/armv7/cache_v7.c | 20 +++++++++++++++++--- 1 file changed, 17 insertions(+), 3 deletions(-)
diff --git a/arch/arm/cpu/armv7/cache_v7.c b/arch/arm/cpu/armv7/cache_v7.c index 9fbabb4..e72bed5 100644 --- a/arch/arm/cpu/armv7/cache_v7.c +++ b/arch/arm/cpu/armv7/cache_v7.c @@ -10,8 +10,10 @@ #include <asm/armv7.h> #include <asm/utils.h>
-#define ARMV7_DCACHE_INVAL_RANGE 1 -#define ARMV7_DCACHE_CLEAN_INVAL_RANGE 2 +#define ARMV7_DCACHE_INVAL_ALL 1 +#define ARMV7_DCACHE_CLEAN_INVAL_ALL 2 +#define ARMV7_DCACHE_INVAL_RANGE 3 +#define ARMV7_DCACHE_CLEAN_INVAL_RANGE 4
#ifndef CONFIG_SYS_DCACHE_OFF
@@ -19,6 +21,18 @@ void v7_flush_dcache_all(void); void v7_invalidate_dcache_all(void);
+/* + * Write the level and type you want to Cache Size Selection Register(CSSELR) + * to get size details from Current Cache Size ID Register(CCSIDR) + */ +static void set_csselr(u32 level, u32 type) +{ + u32 csselr = level << 1 | type; + + /* Write to Cache Size Selection Register(CSSELR) */ + asm volatile ("mcr p15, 2, %0, c0, c0, 0" : : "r" (csselr)); +} + static u32 get_ccsidr(void) { u32 ccsidr; @@ -207,7 +221,7 @@ static void v7_inval_tlb(void)
void invalidate_dcache_all(void) { - v7_invalidate_dcache_all(); + v7_maint_dcache_all(ARMV7_DCACHE_INVAL_ALL);
v7_outer_cache_inval_all(); }
The problem seems to be invalidate_icache_all() inside the runtime. This patch just disables EFI_LOADER for rock2 board.
configs/rock2_defconfig | 1 + 1 file changed, 1 insertion(+)
diff --git a/configs/rock2_defconfig b/configs/rock2_defconfig index 3e16b80..3a06b7e 100644 --- a/configs/rock2_defconfig +++ b/configs/rock2_defconfig @@ -67,3 +67,4 @@ CONFIG_USE_PRIVATE_LIBGCC=y CONFIG_USE_TINY_PRINTF=y CONFIG_CMD_DHRYSTONE=y CONFIG_ERRNO_STR=y +# CONFIG_EFI_LOADER is not set
Hi Sandy,
Can you please give me an update on these patches? Did you discover the root cause? What patches do you think need to be applied for this release. I'd like to get a few more test reports too if possible.
Hi Simon,
I think you can drop this patch due to it fixes by a78cd86 - ARM: Rework and correct barrier which Tom had merge it into u-boot/master.
On 2016年08月09日 05:43, Simon Glass wrote:
Hi Sandy,
I also found that once the barrier stuff was in, the EFI_LOADER change was unnecessary.
On Mon, Aug 8, 2016 at 8:50 PM, Ziyuan Xu xzy.xu@rock-chips.com wrote:
Hi Simon,
Hi Sandy,
Hi Sandy,
Hi Simon,
That's great, thanks for letting me know.
BTW for the mailing list can you please avoid top-posting?
Hi Sandy,
Sandy Patterson
Ziyuan Xu
