[U-Boot] [PATCH 1/1] ppc4xx: Reset and relock memory DLL after SDRAM_CLKTR change
After changing SDRAM_CLKTR phase value rerun the memory preload initialization sequence (INITPLR) to reset and relock the memory DLL. Changing the SDRAM_CLKTR memory clock phase coarse timing adjustment effects the phase relationship of the internal, to the PPC chip, and external, to the PPC chip, versions of MEMCLK_OUT.
Signed-off-by: Adam Graham agraham@amcc.com Signed-off-by: Victor Gallardo vgallardo@amcc.com --- cpu/ppc4xx/4xx_ibm_ddr2_autocalib.c | 21 +++++++++++++++++++++ 1 files changed, 21 insertions(+), 0 deletions(-)
diff --git a/cpu/ppc4xx/4xx_ibm_ddr2_autocalib.c b/cpu/ppc4xx/4xx_ibm_ddr2_autocalib.c index 83b9883..47ab39b 100644 --- a/cpu/ppc4xx/4xx_ibm_ddr2_autocalib.c +++ b/cpu/ppc4xx/4xx_ibm_ddr2_autocalib.c @@ -174,6 +174,23 @@ static inline void ecc_clear_status_reg(void) #endif }
+/* + * Reset and relock memory DLL after SDRAM_CLKTR change + */ +static inline void relock_memory_DLL(void) +{ + u32 reg; + + mtsdram(SDRAM_MCOPT2, SDRAM_MCOPT2_IPTR_EXECUTE); + + do { + mfsdram(SDRAM_MCSTAT, reg); + } while (!(reg & SDRAM_MCSTAT_MIC_COMP)); + + mfsdram(SDRAM_MCOPT2, reg); + mtsdram(SDRAM_MCOPT2, reg | SDRAM_MCOPT2_DCEN_ENABLE); +} + static int ecc_check_status_reg(void) { u32 ecc_status; @@ -981,6 +998,8 @@ u32 DQS_autocalibration(void)
mtsdram(SDRAM_CLKTR, clkp << 30);
+ relock_memory_DLL(); + putc('\b'); putc(slash[loopi++ % 8]);
@@ -1170,6 +1189,8 @@ u32 DQS_autocalibration(void)
mtsdram(SDRAM_CLKTR, tcal.clocks.clktr << 30);
+ relock_memory_DLL(); + mfsdram(SDRAM_RQDC, rqdc_reg); rqdc_reg &= ~(SDRAM_RQDC_RQFD_MASK); mtsdram(SDRAM_RQDC, rqdc_reg |
Dear Adam Graham,
Line too long.
Adam,
Line too long.
Yes, please change your setup to wrap around 70 chars per line in the commit text. Please resend and I'll add this fix quickly so that it makes it into the next release.
Thanks.
Best regards, Stefan
Adam Graham
Stefan Roese
