[U-Boot] [RESEND PATCH] x86: ich-spi: Fix a bug of reading from a non-64 bytes aligned address
The ich spi controller driver spi_xfer() tries to align reading address to 64 bytes when doing spi data in, which causes a bug of either infinite loop or a huge size memcpy().
Actually the ich spi controller does not have such requirement of 64 bytes alignment when reading data from spi slave devices.
Signed-off-by: Bin Meng bmeng.cn@gmail.com Acked-by: Simon Glass sjg@chromium.org Tested-by: Simon Glass sjg@chromium.org
--- RESEND Notes: Simon, this patch can be applied now as it does not require any dependency to Jagan's recent patch series, nor my x86 patch series.
drivers/spi/ich.c | 17 ++--------------- 1 file changed, 2 insertions(+), 15 deletions(-)
diff --git a/drivers/spi/ich.c b/drivers/spi/ich.c index 0e00edf..7b24981 100644 --- a/drivers/spi/ich.c +++ b/drivers/spi/ich.c @@ -484,8 +484,6 @@ int spi_xfer(struct spi_slave *slave, unsigned int bitlen, const void *dout, struct spi_trans *trans = &ich->trans; unsigned type = flags & (SPI_XFER_BEGIN | SPI_XFER_END); int using_cmd = 0; - /* Align read transactions to 64-byte boundaries */ - char buff[ctlr.databytes];
/* Ee don't support writing partial bytes. */ if (bitlen % 8) { @@ -633,14 +631,9 @@ int spi_xfer(struct spi_slave *slave, unsigned int bitlen, const void *dout, */ while (trans->bytesout || trans->bytesin) { uint32_t data_length; - uint32_t aligned_offset; - uint32_t diff; - - aligned_offset = trans->offset & ~(ctlr.databytes - 1); - diff = trans->offset - aligned_offset;
/* SPI addresses are 24 bit only */ - ich_writel(aligned_offset & 0x00FFFFFF, ctlr.addr); + ich_writel(trans->offset & 0x00FFFFFF, ctlr.addr);
if (trans->bytesout) data_length = min(trans->bytesout, ctlr.databytes); @@ -674,13 +667,7 @@ int spi_xfer(struct spi_slave *slave, unsigned int bitlen, const void *dout, }
if (trans->bytesin) { - if (diff) { - data_length -= diff; - read_reg(ctlr.data, buff, ctlr.databytes); - memcpy(trans->in, buff + diff, data_length); - } else { - read_reg(ctlr.data, trans->in, data_length); - } + read_reg(ctlr.data, trans->in, data_length); spi_use_in(trans, data_length); if (with_address) trans->offset += data_length;
Applied to x86 - thanks!
- Simon
Bin Meng
