[U-Boot] [PATCH 00/10] net: Fix packet corruption issue when handling asynch replies
The issue [1] was reported by (Peter) Tran Tien Dat. Unfortunately his fix for the issue broke notmal operation and I don't feel is a good way to address the issue. Also, the situation was not covered in the unit tests, so we'll add them now.
First we refactor the unit test capability of the sandbox ethernet fake driver so that we can exercise that part of the network stack, then add the tests where we prove that the async replies work, but that in the process, the action expected by the user (ping in this case) is broken.
Lastly, we correct the problem and change the unit tests to also expect success of the user's operation.
[1] https://patchwork.ozlabs.org/patch/939617/
Joe Hershberger (10): net: sandbox: Move disabled flag into priv struct net: sandbox: Refactor sandbox send function net: sandbox: Make the fake eth driver response configurable net: sandbox: Share the priv structure with tests net: sandbox: Allow fake eth to handle more than 1 packet response net: Add an accessor to know if waiting for ARP net: sandbox: Add a priv ptr for tests to use test: eth: Add a test for ARP requests test: eth: Add a test for the target being pinged net: Don't overwrite waiting packets with asynchronous replies
arch/sandbox/include/asm/eth.h | 85 +++++++++ drivers/net/sandbox.c | 415 +++++++++++++++++++++++++++++++---------- include/net.h | 9 + net/arp.c | 20 +- net/arp.h | 1 + net/net.c | 8 + net/ping.c | 7 +- test/dm/eth.c | 160 ++++++++++++++++ 8 files changed, 596 insertions(+), 109 deletions(-)
Store the per-device data with the device.
Signed-off-by: Joe Hershberger joe.hershberger@ni.com ---
drivers/net/sandbox.c | 18 ++++++++++++++---- 1 file changed, 14 insertions(+), 4 deletions(-)
diff --git a/drivers/net/sandbox.c b/drivers/net/sandbox.c index b71c8f88d9..60fe065ee5 100644 --- a/drivers/net/sandbox.c +++ b/drivers/net/sandbox.c @@ -19,17 +19,18 @@ DECLARE_GLOBAL_DATA_PTR; * * fake_host_hwaddr: MAC address of mocked machine * fake_host_ipaddr: IP address of mocked machine + * disabled: Will not respond * recv_packet_buffer: buffer of the packet returned as received * recv_packet_length: length of the packet returned as received */ struct eth_sandbox_priv { uchar fake_host_hwaddr[ARP_HLEN]; struct in_addr fake_host_ipaddr; + bool disabled; uchar *recv_packet_buffer; int recv_packet_length; };
-static bool disabled[8] = {false}; static bool skip_timeout;
/* @@ -40,7 +41,16 @@ static bool skip_timeout; */ void sandbox_eth_disable_response(int index, bool disable) { - disabled[index] = disable; + struct udevice *dev; + struct eth_sandbox_priv *priv; + int ret; + + ret = uclass_get_device(UCLASS_ETH, index, &dev); + if (ret) + return; + + priv = dev_get_priv(dev); + priv->disabled = disable; }
/* @@ -71,8 +81,7 @@ static int sb_eth_send(struct udevice *dev, void *packet, int length)
debug("eth_sandbox: Send packet %d\n", length);
- if (dev->seq >= 0 && dev->seq < ARRAY_SIZE(disabled) && - disabled[dev->seq]) + if (priv->disabled) return 0;
if (ntohs(eth->et_protlen) == PROT_ARP) { @@ -212,6 +221,7 @@ static int sb_eth_ofdata_to_platdata(struct udevice *dev) return -EINVAL; } memcpy(priv->fake_host_hwaddr, mac, ARP_HLEN); + priv->disabled = false;
return 0; }
On Wed, Jul 25, 2018 at 5:40 AM Joe Hershberger joe.hershberger@ni.com wrote:
Make the behavior of the send function reusable.
arch/sandbox/include/asm/eth.h | 20 +++++ drivers/net/sandbox.c | 176 ++++++++++++++++++++++++----------------- 2 files changed, 124 insertions(+), 72 deletions(-)
diff --git a/arch/sandbox/include/asm/eth.h b/arch/sandbox/include/asm/eth.h index bfcd11b593..00062616a4 100644 --- a/arch/sandbox/include/asm/eth.h +++ b/arch/sandbox/include/asm/eth.h @@ -13,4 +13,24 @@ void sandbox_eth_disable_response(int index, bool disable);
void sandbox_eth_skip_timeout(void);
+/* + * sandbox_eth_arp_req_to_reply() + * + * Check for an arp request to be sent. If so, inject a reply + * + * returns 1 if injected, 0 if not + */ +int sandbox_eth_arp_req_to_reply(struct udevice *dev, void *packet, + unsigned int len); + +/* + * sandbox_eth_ping_req_to_reply() + * + * Check for a ping request to be sent. If so, inject a reply + * + * returns 1 if injected, 0 if not + */ +int sandbox_eth_ping_req_to_reply(struct udevice *dev, void *packet, + unsigned int len); + #endif /* __ETH_H */ diff --git a/drivers/net/sandbox.c b/drivers/net/sandbox.c index 60fe065ee5..5746af11a6 100644 --- a/drivers/net/sandbox.c +++ b/drivers/net/sandbox.c @@ -63,6 +63,108 @@ void sandbox_eth_skip_timeout(void) skip_timeout = true; }
+/* + * sandbox_eth_arp_req_to_reply() + * + * Check for an arp request to be sent. If so, inject a reply + * + * returns 1 if injected, 0 if not + */ +int sandbox_eth_arp_req_to_reply(struct udevice *dev, void *packet, + unsigned int len) +{ + struct eth_sandbox_priv *priv = dev_get_priv(dev); + struct ethernet_hdr *eth = packet; + struct arp_hdr *arp; + struct ethernet_hdr *eth_recv; + struct arp_hdr *arp_recv; + + if (ntohs(eth->et_protlen) != PROT_ARP) + return 0; + + arp = packet + ETHER_HDR_SIZE; + + if (ntohs(arp->ar_op) != ARPOP_REQUEST) + return 0; + + /* store this as the assumed IP of the fake host */ + priv->fake_host_ipaddr = net_read_ip(&arp->ar_tpa); + + /* Formulate a fake response */ + eth_recv = (void *)priv->recv_packet_buffer; + memcpy(eth_recv->et_dest, eth->et_src, ARP_HLEN); + memcpy(eth_recv->et_src, priv->fake_host_hwaddr, ARP_HLEN); + eth_recv->et_protlen = htons(PROT_ARP); + + arp_recv = (void *)eth_recv + ETHER_HDR_SIZE; + arp_recv->ar_hrd = htons(ARP_ETHER); + arp_recv->ar_pro = htons(PROT_IP); + arp_recv->ar_hln = ARP_HLEN; + arp_recv->ar_pln = ARP_PLEN; + arp_recv->ar_op = htons(ARPOP_REPLY); + memcpy(&arp_recv->ar_sha, priv->fake_host_hwaddr, ARP_HLEN); + net_write_ip(&arp_recv->ar_spa, priv->fake_host_ipaddr); + memcpy(&arp_recv->ar_tha, &arp->ar_sha, ARP_HLEN); + net_copy_ip(&arp_recv->ar_tpa, &arp->ar_spa); + + priv->recv_packet_length = ETHER_HDR_SIZE + ARP_HDR_SIZE; + + return 1; +} + +/* + * sandbox_eth_ping_req_to_reply() + * + * Check for a ping request to be sent. If so, inject a reply + * + * returns 1 if injected, 0 if not + */ +int sandbox_eth_ping_req_to_reply(struct udevice *dev, void *packet, + unsigned int len) +{ + struct eth_sandbox_priv *priv = dev_get_priv(dev); + struct ethernet_hdr *eth = packet; + struct ip_udp_hdr *ip; + struct icmp_hdr *icmp; + struct ethernet_hdr *eth_recv; + struct ip_udp_hdr *ipr; + struct icmp_hdr *icmpr; + + if (ntohs(eth->et_protlen) != PROT_IP) + return 0; + + ip = packet + ETHER_HDR_SIZE; + + if (ip->ip_p != IPPROTO_ICMP) + return 0; + + icmp = (struct icmp_hdr *)&ip->udp_src; + + if (icmp->type != ICMP_ECHO_REQUEST) + return 0; + + /* reply to the ping */ + eth_recv = (void *)priv->recv_packet_buffer; + memcpy(eth_recv, packet, len); + ipr = (void *)eth_recv + ETHER_HDR_SIZE; + icmpr = (struct icmp_hdr *)&ipr->udp_src; + memcpy(eth_recv->et_dest, eth->et_src, ARP_HLEN); + memcpy(eth_recv->et_src, priv->fake_host_hwaddr, ARP_HLEN); + ipr->ip_sum = 0; + ipr->ip_off = 0; + net_copy_ip((void *)&ipr->ip_dst, &ip->ip_src); + net_write_ip((void *)&ipr->ip_src, priv->fake_host_ipaddr); + ipr->ip_sum = compute_ip_checksum(ipr, IP_HDR_SIZE); + + icmpr->type = ICMP_ECHO_REPLY; + icmpr->checksum = 0; + icmpr->checksum = compute_ip_checksum(icmpr, ICMP_HDR_SIZE); + + priv->recv_packet_length = len; + + return 1; +} + static int sb_eth_start(struct udevice *dev) { struct eth_sandbox_priv *priv = dev_get_priv(dev); @@ -77,84 +179,14 @@ static int sb_eth_start(struct udevice *dev) static int sb_eth_send(struct udevice *dev, void *packet, int length) { struct eth_sandbox_priv *priv = dev_get_priv(dev); - struct ethernet_hdr *eth = packet;
- if (ntohs(eth->et_protlen) == PROT_ARP) { - struct arp_hdr *arp = packet + ETHER_HDR_SIZE; - - if (ntohs(arp->ar_op) == ARPOP_REQUEST) { - struct ethernet_hdr *eth_recv; - struct arp_hdr *arp_recv; - - /* store this as the assumed IP of the fake host */ - priv->fake_host_ipaddr = net_read_ip(&arp->ar_tpa); - /* Formulate a fake response */ - eth_recv = (void *)priv->recv_packet_buffer; - memcpy(eth_recv->et_dest, eth->et_src, ARP_HLEN); - memcpy(eth_recv->et_src, priv->fake_host_hwaddr, - ARP_HLEN); - eth_recv->et_protlen = htons(PROT_ARP); - - arp_recv = (void *)priv->recv_packet_buffer + - ETHER_HDR_SIZE; - arp_recv->ar_hrd = htons(ARP_ETHER); - arp_recv->ar_pro = htons(PROT_IP); - arp_recv->ar_hln = ARP_HLEN; - arp_recv->ar_pln = ARP_PLEN; - arp_recv->ar_op = htons(ARPOP_REPLY); - memcpy(&arp_recv->ar_sha, priv->fake_host_hwaddr, - ARP_HLEN); - net_write_ip(&arp_recv->ar_spa, priv->fake_host_ipaddr); - memcpy(&arp_recv->ar_tha, &arp->ar_sha, ARP_HLEN); - net_copy_ip(&arp_recv->ar_tpa, &arp->ar_spa); - - priv->recv_packet_length = ETHER_HDR_SIZE + - ARP_HDR_SIZE; - } - } else if (ntohs(eth->et_protlen) == PROT_IP) { - struct ip_udp_hdr *ip = packet + ETHER_HDR_SIZE; - - if (ip->ip_p == IPPROTO_ICMP) { - struct icmp_hdr *icmp = (struct icmp_hdr *)&ip->udp_src; - - if (icmp->type == ICMP_ECHO_REQUEST) { - struct ethernet_hdr *eth_recv; - struct ip_udp_hdr *ipr; - struct icmp_hdr *icmpr; - - /* reply to the ping */ - memcpy(priv->recv_packet_buffer, packet, - length); - eth_recv = (void *)priv->recv_packet_buffer; - ipr = (void *)priv->recv_packet_buffer + - ETHER_HDR_SIZE; - icmpr = (struct icmp_hdr *)&ipr->udp_src; - memcpy(eth_recv->et_dest, eth->et_src, - ARP_HLEN); - memcpy(eth_recv->et_src, priv->fake_host_hwaddr, - ARP_HLEN); - ipr->ip_sum = 0; - ipr->ip_off = 0; - net_copy_ip((void *)&ipr->ip_dst, &ip->ip_src); - net_write_ip((void *)&ipr->ip_src, - priv->fake_host_ipaddr); - ipr->ip_sum = compute_ip_checksum(ipr, - IP_HDR_SIZE); - - icmpr->type = ICMP_ECHO_REPLY; - icmpr->checksum = 0; - icmpr->checksum = compute_ip_checksum(icmpr, - ICMP_HDR_SIZE); - - priv->recv_packet_length = length; - } - } - } + sandbox_eth_arp_req_to_reply(dev, packet, length); + sandbox_eth_ping_req_to_reply(dev, packet, length);
return 0; }
Hi Joe,
- sandbox_eth_arp_req_to_reply()
- Check for an arp request to be sent. If so, inject a reply
comments for args?
- returns 1 if injected, 0 if not
unsigned int len);
- sandbox_eth_ping_req_to_reply()
- Check for a ping request to be sent. If so, inject a reply
unsigned int len);
unsigned int len)
It seems odd to put this check here? Why not check it before calling this function?
return 1;
Here functions are called unconditionally, but presumably only at most one function will do anything.
2.11.0
Hi Joe,
On Wed, Jul 25, 2018 at 5:46 AM Joe Hershberger joe.hershberger@ni.com wrote:
The meaning of return code 1/0 seems odd. Normally 0 means OK. Can we use -Exxx for the error condition?
unsigned int len);
unsigned int len);
[snip]
Regards, Bin
Make the send handler registerable so tests can check for different things.
arch/sandbox/include/asm/eth.h | 17 ++++++++++++++ drivers/net/sandbox.c | 53 ++++++++++++++++++++++++++++++++++++++---- 2 files changed, 66 insertions(+), 4 deletions(-)
diff --git a/arch/sandbox/include/asm/eth.h b/arch/sandbox/include/asm/eth.h index 00062616a4..04ce266e2a 100644 --- a/arch/sandbox/include/asm/eth.h +++ b/arch/sandbox/include/asm/eth.h @@ -33,4 +33,21 @@ int sandbox_eth_arp_req_to_reply(struct udevice *dev, void *packet, int sandbox_eth_ping_req_to_reply(struct udevice *dev, void *packet, unsigned int len);
+/** + * A packet handler + * + * dev - device pointer + * pkt - pointer to the "sent" packet + * len - packet length + */ +typedef int sandbox_eth_tx_hand_f(struct udevice *dev, void *pkt, + unsigned int len); + +/* + * Set packet handler + * + * handler - The func ptr to call on send. If NULL, set to default handler + */ +void sandbox_eth_set_tx_handler(int index, sandbox_eth_tx_hand_f *handler); + #endif /* __ETH_H */ diff --git a/drivers/net/sandbox.c b/drivers/net/sandbox.c index 5746af11a6..2eb1b418f5 100644 --- a/drivers/net/sandbox.c +++ b/drivers/net/sandbox.c @@ -10,6 +10,7 @@ #include <dm.h> #include <malloc.h> #include <net.h> +#include <asm/eth.h> #include <asm/test.h>
DECLARE_GLOBAL_DATA_PTR; @@ -22,6 +23,7 @@ DECLARE_GLOBAL_DATA_PTR; * disabled: Will not respond * recv_packet_buffer: buffer of the packet returned as received * recv_packet_length: length of the packet returned as received + * tx_handler - function to generate responses to sent packets */ struct eth_sandbox_priv { uchar fake_host_hwaddr[ARP_HLEN]; @@ -29,6 +31,7 @@ struct eth_sandbox_priv { bool disabled; uchar *recv_packet_buffer; int recv_packet_length; + sandbox_eth_tx_hand_f *tx_handler; };
static bool skip_timeout; @@ -165,6 +168,50 @@ int sandbox_eth_ping_req_to_reply(struct udevice *dev, void *packet, return 1; }
+/* + * sb_default_handler() + * + * perform typical responses to simple ping + * + * dev - device pointer + * pkt - "sent" packet buffer + * len - length of packet + */ +static int sb_default_handler(struct udevice *dev, void *packet, + unsigned int len) +{ + sandbox_eth_arp_req_to_reply(dev, packet, len); + sandbox_eth_ping_req_to_reply(dev, packet, len); + + return 0; +} + +/* + * sandbox_eth_set_tx_handler() + * + * Set a custom response to a packet being sent through the sandbox eth test + * driver + * + * index - interface to set the handler for + * handler - The func ptr to call on send. If NULL, set to default handler + */ +void sandbox_eth_set_tx_handler(int index, sandbox_eth_tx_hand_f *handler) +{ + struct udevice *dev; + struct eth_sandbox_priv *priv; + int ret; + + ret = uclass_get_device(UCLASS_ETH, index, &dev); + if (ret) + return; + + priv = dev_get_priv(dev); + if (handler) + priv->tx_handler = handler; + else + priv->tx_handler = sb_default_handler; +} + static int sb_eth_start(struct udevice *dev) { struct eth_sandbox_priv *priv = dev_get_priv(dev); @@ -185,10 +232,7 @@ static int sb_eth_send(struct udevice *dev, void *packet, int length) if (priv->disabled) return 0;
- sandbox_eth_arp_req_to_reply(dev, packet, length); - sandbox_eth_ping_req_to_reply(dev, packet, length); - - return 0; + return priv->tx_handler(dev, packet, length); }
static int sb_eth_recv(struct udevice *dev, int flags, uchar **packetp) @@ -254,6 +298,7 @@ static int sb_eth_ofdata_to_platdata(struct udevice *dev) } memcpy(priv->fake_host_hwaddr, mac, ARP_HLEN); priv->disabled = false; + priv->tx_handler = sb_default_handler;
return 0; }
On Wed, Jul 25, 2018 at 5:47 AM Joe Hershberger joe.hershberger@ni.com wrote:
If tests want to implement tx handlers, they will likely need access to the details in the priv structure.
arch/sandbox/include/asm/eth.h | 19 +++++++++++++++++++ drivers/net/sandbox.c | 19 ------------------- 2 files changed, 19 insertions(+), 19 deletions(-)
diff --git a/arch/sandbox/include/asm/eth.h b/arch/sandbox/include/asm/eth.h index 04ce266e2a..03c3fb2a28 100644 --- a/arch/sandbox/include/asm/eth.h +++ b/arch/sandbox/include/asm/eth.h @@ -43,6 +43,25 @@ int sandbox_eth_ping_req_to_reply(struct udevice *dev, void *packet, typedef int sandbox_eth_tx_hand_f(struct udevice *dev, void *pkt, unsigned int len);
+/** + * struct eth_sandbox_priv - memory for sandbox mock driver + * + * fake_host_hwaddr - MAC address of mocked machine + * fake_host_ipaddr - IP address of mocked machine + * disabled - Will not respond + * recv_packet_buffer - buffer of the packet returned as received + * recv_packet_length - length of the packet returned as received + * tx_handler - function to generate responses to sent packets + */ +struct eth_sandbox_priv { + uchar fake_host_hwaddr[ARP_HLEN]; + struct in_addr fake_host_ipaddr; + bool disabled; + uchar *recv_packet_buffer; + int recv_packet_length; + sandbox_eth_tx_hand_f *tx_handler; +}; + /* * Set packet handler * diff --git a/drivers/net/sandbox.c b/drivers/net/sandbox.c index 2eb1b418f5..0af7bc1439 100644 --- a/drivers/net/sandbox.c +++ b/drivers/net/sandbox.c @@ -15,25 +15,6 @@
-/** - * struct eth_sandbox_priv - memory for sandbox mock driver - * - * fake_host_hwaddr: MAC address of mocked machine - * fake_host_ipaddr: IP address of mocked machine - * disabled: Will not respond - * recv_packet_buffer: buffer of the packet returned as received - * recv_packet_length: length of the packet returned as received - * tx_handler - function to generate responses to sent packets - */ -struct eth_sandbox_priv { - uchar fake_host_hwaddr[ARP_HLEN]; - struct in_addr fake_host_ipaddr; - bool disabled; - uchar *recv_packet_buffer; - int recv_packet_length; - sandbox_eth_tx_hand_f *tx_handler; -}; - static bool skip_timeout;
On Wed, Jul 25, 2018 at 5:42 AM Joe Hershberger joe.hershberger@ni.com wrote:
Use up to the max allocated receive buffers so be able to test more complex situations.
arch/sandbox/include/asm/eth.h | 10 +++++--- drivers/net/sandbox.c | 57 ++++++++++++++++++++++++++++++++++-------- 2 files changed, 52 insertions(+), 15 deletions(-)
diff --git a/arch/sandbox/include/asm/eth.h b/arch/sandbox/include/asm/eth.h index 03c3fb2a28..6dabbf00ab 100644 --- a/arch/sandbox/include/asm/eth.h +++ b/arch/sandbox/include/asm/eth.h @@ -49,16 +49,18 @@ typedef int sandbox_eth_tx_hand_f(struct udevice *dev, void *pkt, * fake_host_hwaddr - MAC address of mocked machine * fake_host_ipaddr - IP address of mocked machine * disabled - Will not respond - * recv_packet_buffer - buffer of the packet returned as received - * recv_packet_length - length of the packet returned as received + * recv_packet_buffer - buffers of the packet returned as received + * recv_packet_length - lengths of the packet returned as received + * recv_packets - number of packets returned * tx_handler - function to generate responses to sent packets */ struct eth_sandbox_priv { uchar fake_host_hwaddr[ARP_HLEN]; struct in_addr fake_host_ipaddr; bool disabled; - uchar *recv_packet_buffer; - int recv_packet_length; + uchar * recv_packet_buffer[PKTBUFSRX]; + int recv_packet_length[PKTBUFSRX]; + int recv_packets; sandbox_eth_tx_hand_f *tx_handler; };
diff --git a/drivers/net/sandbox.c b/drivers/net/sandbox.c index 0af7bc1439..5117af8a82 100644 --- a/drivers/net/sandbox.c +++ b/drivers/net/sandbox.c @@ -71,11 +71,15 @@ int sandbox_eth_arp_req_to_reply(struct udevice *dev, void *packet, if (ntohs(arp->ar_op) != ARPOP_REQUEST) return 0;
+ /* Don't allow the buffer to overrun */ + if (priv->recv_packets >= PKTBUFSRX) + return 0; + /* store this as the assumed IP of the fake host */ priv->fake_host_ipaddr = net_read_ip(&arp->ar_tpa);
/* Formulate a fake response */ - eth_recv = (void *)priv->recv_packet_buffer; + eth_recv = (void *)priv->recv_packet_buffer[priv->recv_packets]; memcpy(eth_recv->et_dest, eth->et_src, ARP_HLEN); memcpy(eth_recv->et_src, priv->fake_host_hwaddr, ARP_HLEN); eth_recv->et_protlen = htons(PROT_ARP); @@ -91,7 +95,9 @@ int sandbox_eth_arp_req_to_reply(struct udevice *dev, void *packet, memcpy(&arp_recv->ar_tha, &arp->ar_sha, ARP_HLEN); net_copy_ip(&arp_recv->ar_tpa, &arp->ar_spa);
- priv->recv_packet_length = ETHER_HDR_SIZE + ARP_HDR_SIZE; + priv->recv_packet_length[priv->recv_packets] = + ETHER_HDR_SIZE + ARP_HDR_SIZE; + ++priv->recv_packets;
return 1; } @@ -127,8 +133,12 @@ int sandbox_eth_ping_req_to_reply(struct udevice *dev, void *packet, if (icmp->type != ICMP_ECHO_REQUEST) return 0;
+ /* Don't allow the buffer to overrun */ + if (priv->recv_packets >= PKTBUFSRX) + return 0; + /* reply to the ping */ - eth_recv = (void *)priv->recv_packet_buffer; + eth_recv = (void *)priv->recv_packet_buffer[priv->recv_packets]; memcpy(eth_recv, packet, len); ipr = (void *)eth_recv + ETHER_HDR_SIZE; icmpr = (struct icmp_hdr *)&ipr->udp_src; @@ -144,7 +154,8 @@ int sandbox_eth_ping_req_to_reply(struct udevice *dev, void *packet, icmpr->checksum = 0; icmpr->checksum = compute_ip_checksum(icmpr, ICMP_HDR_SIZE);
- priv->recv_packet_length = len; + priv->recv_packet_length[priv->recv_packets] = len; + ++priv->recv_packets;
return 1; } @@ -199,7 +210,11 @@ static int sb_eth_start(struct udevice *dev)
debug("eth_sandbox: Start\n");
- priv->recv_packet_buffer = net_rx_packets[0]; + priv->recv_packets = 0; + for (int i = 0; i < PKTBUFSRX; i++) { + priv->recv_packet_buffer[i] = net_rx_packets[i]; + priv->recv_packet_length[i] = 0; + }
return 0; } @@ -225,18 +240,37 @@ static int sb_eth_recv(struct udevice *dev, int flags, uchar **packetp) skip_timeout = false; }
- if (priv->recv_packet_length) { - int lcl_recv_packet_length = priv->recv_packet_length; + if (priv->recv_packets) { + int lcl_recv_packet_length = priv->recv_packet_length[0];
- debug("eth_sandbox: received packet %d\n", - priv->recv_packet_length); - priv->recv_packet_length = 0; - *packetp = priv->recv_packet_buffer; + debug("eth_sandbox: received packet[%d], %d waiting\n", + lcl_recv_packet_length, priv->recv_packets - 1); + *packetp = priv->recv_packet_buffer[0]; return lcl_recv_packet_length; } return 0; }
+static int sb_eth_free_pkt(struct udevice *dev, uchar *packet, int length) +{ + struct eth_sandbox_priv *priv = dev_get_priv(dev); + int i; + + if (!priv->recv_packets) + return 0; + + --priv->recv_packets; + for (i = 0; i < priv->recv_packets; i++) { + priv->recv_packet_length[i] = priv->recv_packet_length[i + 1]; + memcpy(priv->recv_packet_buffer[i], + priv->recv_packet_buffer[i + 1], + priv->recv_packet_length[i + 1]); + } + priv->recv_packet_length[priv->recv_packets] = 0; + + return 0; +} + static void sb_eth_stop(struct udevice *dev) { debug("eth_sandbox: Stop\n"); @@ -255,6 +289,7 @@ static const struct eth_ops sb_eth_ops = { .start = sb_eth_start, .send = sb_eth_send, .recv = sb_eth_recv, + .free_pkt = sb_eth_free_pkt, .stop = sb_eth_stop, .write_hwaddr = sb_eth_write_hwaddr, };
On Wed, Jul 25, 2018 at 5:41 AM Joe Hershberger joe.hershberger@ni.com wrote:
This single-sources the state of the ARP.
include/net.h | 1 + net/arp.c | 11 ++++++++--- 2 files changed, 9 insertions(+), 3 deletions(-)
diff --git a/include/net.h b/include/net.h index f9984ae86c..63718a47f2 100644 --- a/include/net.h +++ b/include/net.h @@ -635,6 +635,7 @@ rxhand_f *net_get_udp_handler(void); /* Get UDP RX packet handler */ void net_set_udp_handler(rxhand_f *); /* Set UDP RX packet handler */ rxhand_f *net_get_arp_handler(void); /* Get ARP RX packet handler */ void net_set_arp_handler(rxhand_f *); /* Set ARP RX packet handler */ +int arp_is_waiting(void); /* Waiting for ARP reply? */ void net_set_icmp_handler(rxhand_icmp_f *f); /* Set ICMP RX handler */ void net_set_timeout_handler(ulong, thand_f *);/* Set timeout handler */
diff --git a/net/arp.c b/net/arp.c index b8a71684cd..524361cf1b 100644 --- a/net/arp.c +++ b/net/arp.c @@ -100,7 +100,7 @@ int arp_timeout_check(void) { ulong t;
- if (!net_arp_wait_packet_ip.s_addr) + if (!arp_is_waiting()) return 0;
t = get_timer(0); @@ -187,8 +187,8 @@ void arp_receive(struct ethernet_hdr *et, struct ip_udp_hdr *ip, int len) return;
case ARPOP_REPLY: /* arp reply */ - /* are we waiting for a reply */ - if (!net_arp_wait_packet_ip.s_addr) + /* are we waiting for a reply? */ + if (!arp_is_waiting()) break;
#ifdef CONFIG_KEEP_SERVERADDR @@ -233,3 +233,8 @@ void arp_receive(struct ethernet_hdr *et, struct ip_udp_hdr *ip, int len) return; } } + +int arp_is_waiting(void) +{ + return !!net_arp_wait_packet_ip.s_addr; +}
Hi Joe,
On Wed, Jul 25, 2018 at 5:45 AM Joe Hershberger joe.hershberger@ni.com wrote:
Can we use 'bool' instead of 'int'?
if (!arp_is_waiting()) return 0; t = get_timer(0);
Regards, Bin
arch/sandbox/include/asm/eth.h | 9 +++++++++ drivers/net/sandbox.c | 20 ++++++++++++++++++++ 2 files changed, 29 insertions(+)
diff --git a/arch/sandbox/include/asm/eth.h b/arch/sandbox/include/asm/eth.h index 6dabbf00ab..6bb3f1bbfd 100644 --- a/arch/sandbox/include/asm/eth.h +++ b/arch/sandbox/include/asm/eth.h @@ -53,6 +53,7 @@ typedef int sandbox_eth_tx_hand_f(struct udevice *dev, void *pkt, * recv_packet_length - lengths of the packet returned as received * recv_packets - number of packets returned * tx_handler - function to generate responses to sent packets + * priv - a pointer to some structure a test may want to keep track of */ struct eth_sandbox_priv { uchar fake_host_hwaddr[ARP_HLEN]; @@ -62,6 +63,7 @@ struct eth_sandbox_priv { int recv_packet_length[PKTBUFSRX]; int recv_packets; sandbox_eth_tx_hand_f *tx_handler; + void *priv; };
/* @@ -71,4 +73,11 @@ struct eth_sandbox_priv { */ void sandbox_eth_set_tx_handler(int index, sandbox_eth_tx_hand_f *handler);
+/* + * Set priv ptr + * + * priv - priv void ptr to store in the device + */ +void sandbox_eth_set_priv(int index, void *priv); + #endif /* __ETH_H */ diff --git a/drivers/net/sandbox.c b/drivers/net/sandbox.c index 5117af8a82..29767ef291 100644 --- a/drivers/net/sandbox.c +++ b/drivers/net/sandbox.c @@ -204,6 +204,26 @@ void sandbox_eth_set_tx_handler(int index, sandbox_eth_tx_hand_f *handler) priv->tx_handler = sb_default_handler; }
+/* + * Set priv ptr + * + * priv - priv void ptr to store in the device + */ +void sandbox_eth_set_priv(int index, void *priv) +{ + struct udevice *dev; + struct eth_sandbox_priv *uc_priv; + int ret; + + ret = uclass_get_device(UCLASS_ETH, index, &dev); + if (ret) + return; + + uc_priv = dev_get_priv(dev); + + uc_priv->priv = priv; +} + static int sb_eth_start(struct udevice *dev) { struct eth_sandbox_priv *priv = dev_get_priv(dev);
Missing commit message - what is this for?
Hi Joe,
- recv_packet_length - lengths of the packet returned as received
- recv_packets - number of packets returned
- tx_handler - function to generate responses to sent packets
- priv - a pointer to some structure a test may want to keep track of
void *priv;
- Set priv ptr
- priv - priv void ptr to store in the device
- Set priv ptr
Can we use 'priv' instead? As the name uc_prive seems to mean uclass's prive, which isn't the truth.
int ret;
if (ret)
return;
static int sb_eth_start(struct udevice *dev) { struct eth_sandbox_priv *priv = dev_get_priv(dev); --
Regards, Bin
This tests that ARP requests made to this target's IP address are responded-to by the target when it is doing other networking operations.
This currently corrupts the ongoing operation of the device if it happens to be awaiting an ARP reply of its own to whatever serverip it is attempting to communicate with. In the test, add an expectation that the user operation (ping, in this case) will fail. A later patch will address this problem.
arch/sandbox/include/asm/eth.h | 9 +++++ drivers/net/sandbox.c | 41 +++++++++++++++++++++ test/dm/eth.c | 81 ++++++++++++++++++++++++++++++++++++++++++ 3 files changed, 131 insertions(+)
diff --git a/arch/sandbox/include/asm/eth.h b/arch/sandbox/include/asm/eth.h index 6bb3f1bbfd..7cd5b551d9 100644 --- a/arch/sandbox/include/asm/eth.h +++ b/arch/sandbox/include/asm/eth.h @@ -33,6 +33,15 @@ int sandbox_eth_arp_req_to_reply(struct udevice *dev, void *packet, int sandbox_eth_ping_req_to_reply(struct udevice *dev, void *packet, unsigned int len);
+/* + * sandbox_eth_recv_arp_req() + * + * Inject an ARP request for this target + * + * returns 1 if injected, 0 if not + */ +int sandbox_eth_recv_arp_req(struct udevice *dev); + /** * A packet handler * diff --git a/drivers/net/sandbox.c b/drivers/net/sandbox.c index 29767ef291..2c2a2c6311 100644 --- a/drivers/net/sandbox.c +++ b/drivers/net/sandbox.c @@ -161,6 +161,47 @@ int sandbox_eth_ping_req_to_reply(struct udevice *dev, void *packet, }
/* + * sandbox_eth_recv_arp_req() + * + * Inject an ARP request for this target + * + * returns 1 if injected, 0 if not + */ +int sandbox_eth_recv_arp_req(struct udevice *dev) +{ + struct eth_sandbox_priv *priv = dev_get_priv(dev); + struct ethernet_hdr *eth_recv; + struct arp_hdr *arp_recv; + + /* Don't allow the buffer to overrun */ + if (priv->recv_packets >= PKTBUFSRX) + return 0; + + /* Formulate a fake request */ + eth_recv = (void *)priv->recv_packet_buffer[priv->recv_packets]; + memcpy(eth_recv->et_dest, net_bcast_ethaddr, ARP_HLEN); + memcpy(eth_recv->et_src, priv->fake_host_hwaddr, ARP_HLEN); + eth_recv->et_protlen = htons(PROT_ARP); + + arp_recv = (void *)eth_recv + ETHER_HDR_SIZE; + arp_recv->ar_hrd = htons(ARP_ETHER); + arp_recv->ar_pro = htons(PROT_IP); + arp_recv->ar_hln = ARP_HLEN; + arp_recv->ar_pln = ARP_PLEN; + arp_recv->ar_op = htons(ARPOP_REQUEST); + memcpy(&arp_recv->ar_sha, priv->fake_host_hwaddr, ARP_HLEN); + net_write_ip(&arp_recv->ar_spa, priv->fake_host_ipaddr); + memcpy(&arp_recv->ar_tha, net_null_ethaddr, ARP_HLEN); + net_write_ip(&arp_recv->ar_tpa, net_ip); + + priv->recv_packet_length[priv->recv_packets] = + ETHER_HDR_SIZE + ARP_HDR_SIZE; + ++priv->recv_packets; + + return 1; +} + +/* * sb_default_handler() * * perform typical responses to simple ping diff --git a/test/dm/eth.c b/test/dm/eth.c index 1a7684a887..9b5f53e819 100644 --- a/test/dm/eth.c +++ b/test/dm/eth.c @@ -258,3 +258,84 @@ static int dm_test_net_retry(struct unit_test_state *uts) return retval; } DM_TEST(dm_test_net_retry, DM_TESTF_SCAN_FDT); + +static int sb_check_arp_reply(struct udevice *dev, void *packet, + unsigned int len) +{ + struct eth_sandbox_priv *priv = dev_get_priv(dev); + struct ethernet_hdr *eth = packet; + struct arp_hdr *arp; + struct unit_test_state *uts = priv->priv; + + if (ntohs(eth->et_protlen) != PROT_ARP) + return 0; + + arp = packet + ETHER_HDR_SIZE; + + if (ntohs(arp->ar_op) != ARPOP_REPLY) + return 0; + + /* This test would be worthless if we are not waiting */ + ut_assert(arp_is_waiting()); + + /* Validate response */ + ut_assert(memcmp(eth->et_src, net_ethaddr, ARP_HLEN) == 0); + ut_assert(memcmp(eth->et_dest, priv->fake_host_hwaddr, ARP_HLEN) == 0); + ut_assert(eth->et_protlen == htons(PROT_ARP)); + + ut_assert(arp->ar_hrd == htons(ARP_ETHER)); + ut_assert(arp->ar_pro == htons(PROT_IP)); + ut_assert(arp->ar_hln == ARP_HLEN); + ut_assert(arp->ar_pln == ARP_PLEN); + ut_assert(memcmp(&arp->ar_sha, net_ethaddr, ARP_HLEN) == 0); + ut_assert(net_read_ip(&arp->ar_spa).s_addr == net_ip.s_addr); + ut_assert(memcmp(&arp->ar_tha, priv->fake_host_hwaddr, ARP_HLEN) == 0); + ut_assert(net_read_ip(&arp->ar_tpa).s_addr == + string_to_ip("1.1.2.4").s_addr); + + return 0; +} + +static int sb_with_async_arp_handler(struct udevice *dev, void *packet, + unsigned int len) +{ + struct eth_sandbox_priv *priv = dev_get_priv(dev); + struct ethernet_hdr *eth = packet; + struct arp_hdr *arp = packet + ETHER_HDR_SIZE; + + /* + * If we are about to generate a reply to ARP, first inject a request + * from another host + */ + if (ntohs(eth->et_protlen) == PROT_ARP && + ntohs(arp->ar_op) == ARPOP_REQUEST) { + /* Make sure sandbox_eth_recv_arp_req() knows who is asking */ + priv->fake_host_ipaddr = string_to_ip("1.1.2.4"); + + sandbox_eth_recv_arp_req(dev); + } + + sandbox_eth_arp_req_to_reply(dev, packet, len); + sandbox_eth_ping_req_to_reply(dev, packet, len); + + return sb_check_arp_reply(dev, packet, len); +} + +static int dm_test_eth_async_arp_reply(struct unit_test_state *uts) +{ + net_ping_ip = string_to_ip("1.1.2.2"); + + sandbox_eth_set_tx_handler(0, sb_with_async_arp_handler); + sandbox_eth_set_priv(0, uts); + sandbox_eth_skip_timeout(); + + env_set("ethact", "eth@10002000"); + ut_assert(net_loop(PING) == -ETIMEDOUT); + ut_asserteq_str("eth@10002000", env_get("ethact")); + + sandbox_eth_set_tx_handler(0, NULL); + + return 0; +} + +DM_TEST(dm_test_eth_async_arp_reply, DM_TESTF_SCAN_FDT);
Nice!
Hi Joe,
On Wed, Jul 25, 2018 at 5:43 AM Joe Hershberger joe.hershberger@ni.com wrote:
But please see comments below:
- sandbox_eth_recv_arp_req()
- Inject an ARP request for this target
again the return codes, can we use -Exxx instead? I see the return error is not checked anywhere, maybe we should just make it return void?
- A packet handler
return 1;
- sb_default_handler()
- perform typical responses to simple ping
unsigned int len)
This is not used anywhere. What is this for?
unsigned int len)
* from another host
Looks this is not needed since it was not used anywhere.
Regards, Bin
The target will respond to pings while doing other network handling. Make sure that the response happens and is correct.
arch/sandbox/include/asm/eth.h | 9 +++++ drivers/net/sandbox.c | 51 ++++++++++++++++++++++++++ test/dm/eth.c | 81 ++++++++++++++++++++++++++++++++++++++++++ 3 files changed, 141 insertions(+)
diff --git a/arch/sandbox/include/asm/eth.h b/arch/sandbox/include/asm/eth.h index 7cd5b551d9..66f6b4078b 100644 --- a/arch/sandbox/include/asm/eth.h +++ b/arch/sandbox/include/asm/eth.h @@ -42,6 +42,15 @@ int sandbox_eth_ping_req_to_reply(struct udevice *dev, void *packet, */ int sandbox_eth_recv_arp_req(struct udevice *dev);
+/* + * sandbox_eth_recv_ping_req() + * + * Inject a ping request for this target + * + * returns 1 if injected, 0 if not + */ +int sandbox_eth_recv_ping_req(struct udevice *dev); + /** * A packet handler * diff --git a/drivers/net/sandbox.c b/drivers/net/sandbox.c index 2c2a2c6311..039c1e3222 100644 --- a/drivers/net/sandbox.c +++ b/drivers/net/sandbox.c @@ -202,6 +202,57 @@ int sandbox_eth_recv_arp_req(struct udevice *dev) }
/* + * sandbox_eth_recv_ping_req() + * + * Inject a ping request for this target + * + * returns 1 if injected, 0 if not + */ +int sandbox_eth_recv_ping_req(struct udevice *dev) +{ + struct eth_sandbox_priv *priv = dev_get_priv(dev); + struct ethernet_hdr *eth_recv; + struct ip_udp_hdr *ipr; + struct icmp_hdr *icmpr; + + /* Don't allow the buffer to overrun */ + if (priv->recv_packets >= PKTBUFSRX) + return 0; + + /* Formulate a fake ping */ + eth_recv = (void *)priv->recv_packet_buffer[priv->recv_packets]; + + memcpy(eth_recv->et_dest, net_ethaddr, ARP_HLEN); + memcpy(eth_recv->et_src, priv->fake_host_hwaddr, ARP_HLEN); + eth_recv->et_protlen = htons(PROT_IP); + + ipr = (void *)eth_recv + ETHER_HDR_SIZE; + ipr->ip_hl_v = 0x45; + ipr->ip_len = htons(IP_ICMP_HDR_SIZE); + ipr->ip_off = htons(IP_FLAGS_DFRAG); + ipr->ip_p = IPPROTO_ICMP; + ipr->ip_sum = 0; + net_write_ip(&ipr->ip_src, priv->fake_host_ipaddr); + net_write_ip(&ipr->ip_dst, net_ip); + ipr->ip_sum = compute_ip_checksum(ipr, IP_HDR_SIZE); + + icmpr = (struct icmp_hdr *)&ipr->udp_src; + + icmpr->type = ICMP_ECHO_REQUEST; + icmpr->code = 0; + icmpr->checksum = 0; + icmpr->un.echo.id = 0; + icmpr->un.echo.sequence = htons(1); + icmpr->checksum = compute_ip_checksum(icmpr, ICMP_HDR_SIZE); + + priv->recv_packet_length[priv->recv_packets] = + ETHER_HDR_SIZE + IP_ICMP_HDR_SIZE; + ++priv->recv_packets; + + return 1; +} + +/* * sb_default_handler() * * perform typical responses to simple ping diff --git a/test/dm/eth.c b/test/dm/eth.c index 9b5f53e819..77c602beaf 100644 --- a/test/dm/eth.c +++ b/test/dm/eth.c @@ -339,3 +339,84 @@ static int dm_test_eth_async_arp_reply(struct unit_test_state *uts) }
DM_TEST(dm_test_eth_async_arp_reply, DM_TESTF_SCAN_FDT); + +static int sb_check_ping_reply(struct udevice *dev, void *packet, + unsigned int len) +{ + struct eth_sandbox_priv *priv = dev_get_priv(dev); + struct ethernet_hdr *eth = packet; + struct ip_udp_hdr *ip; + struct icmp_hdr *icmp; + struct unit_test_state *uts = priv->priv; + + if (ntohs(eth->et_protlen) != PROT_IP) + return 0; + + ip = packet + ETHER_HDR_SIZE; + + if (ip->ip_p != IPPROTO_ICMP) + return 0; + + icmp = (struct icmp_hdr *)&ip->udp_src; + + if (icmp->type != ICMP_ECHO_REPLY) + return 0; + + /* This test would be worthless if we are not waiting */ + ut_assert(arp_is_waiting()); + + /* Validate response */ + ut_assert(memcmp(eth->et_src, net_ethaddr, ARP_HLEN) == 0); + ut_assert(memcmp(eth->et_dest, priv->fake_host_hwaddr, ARP_HLEN) == 0); + ut_assert(eth->et_protlen == htons(PROT_IP)); + + ut_assert(net_read_ip(&ip->ip_src).s_addr == net_ip.s_addr); + ut_assert(net_read_ip(&ip->ip_dst).s_addr == + string_to_ip("1.1.2.4").s_addr); + + return 0; +} + +static int sb_with_async_ping_handler(struct udevice *dev, void *packet, + unsigned int len) +{ + struct eth_sandbox_priv *priv = dev_get_priv(dev); + struct ethernet_hdr *eth = packet; + struct arp_hdr *arp = packet + ETHER_HDR_SIZE; + + /* + * If we are about to generate a reply to ARP, first inject a request + * from another host + */ + if (ntohs(eth->et_protlen) == PROT_ARP && + ntohs(arp->ar_op) == ARPOP_REQUEST) { + /* Make sure sandbox_eth_recv_arp_req() knows who is asking */ + priv->fake_host_ipaddr = string_to_ip("1.1.2.4"); + + sandbox_eth_recv_ping_req(dev); + } + + sandbox_eth_arp_req_to_reply(dev, packet, len); + sandbox_eth_ping_req_to_reply(dev, packet, len); + + return sb_check_ping_reply(dev, packet, len); +} + +static int dm_test_eth_async_ping_reply(struct unit_test_state *uts) +{ + net_ping_ip = string_to_ip("1.1.2.2"); + + sandbox_eth_set_tx_handler(0, sb_with_async_ping_handler); + sandbox_eth_set_priv(0, uts); + sandbox_eth_skip_timeout(); + + env_set("ethact", "eth@10002000"); + ut_assert(net_loop(PING) == -ETIMEDOUT); + ut_asserteq_str("eth@10002000", env_get("ethact")); + + sandbox_eth_set_tx_handler(0, NULL); + + return 0; +} + +DM_TEST(dm_test_eth_async_ping_reply, DM_TESTF_SCAN_FDT);
Hi Joe,
But please see comments below.
- sandbox_eth_recv_ping_req()
- Inject a ping request for this target
again the return code issue
- A packet handler
ipr->ip_sum = 0;
icmpr->code = 0;
return 1;
unsigned int len)
unsigned int len)
* from another host
ditto
Regards, Bin
Peter originally sent a fix, but it breaks a number of other things. This addresses the original reported issue in a different way.
That report was:
U-Boot has 1 common buffer to send Ethernet frames, pointed to by net_tx_packet. When sending to an IP address without knowing the MAC address, U-Boot makes an ARP request (using the arp_tx_packet buffer) to find out the MAC address of the IP addressr. When a matching ARP reply is received, U-Boot continues sending the frame stored in the net_tx_packet buffer.
However, in the mean time, if U-Boot needs to send out any network packets (e.g. replying ping packets or ARP requests for its own IP address etc.), it will use the net_tx_packet buffer to prepare the new packet. Thus this buffer is no longer the original packet meant to be transmitted after the ARP reply. The original packet will be lost.
This instead uses the ARP tx buffer to send async replies in the case where we are actively waiting for an ARP reply.
Reported-by: Tran Tien Dat peter.trantiendat@gmail.com ---
include/net.h | 8 ++++++++ net/arp.c | 9 +++++---- net/arp.h | 1 + net/net.c | 8 ++++++++ net/ping.c | 7 +++++-- test/dm/eth.c | 6 ++---- 6 files changed, 29 insertions(+), 10 deletions(-)
diff --git a/include/net.h b/include/net.h index 63718a47f2..03d1056bc5 100644 --- a/include/net.h +++ b/include/net.h @@ -654,6 +654,14 @@ static inline void net_set_state(enum net_loop_state state) net_state = state; }
+/* + * net_get_async_tx_pkt_buf - Get a packet buffer that is not in use for + * sending an asynchronous reply + * + * returns - ptr to packet buffer + */ +uchar * net_get_async_tx_pkt_buf(void); + /* Transmit a packet */ static inline void net_send_packet(uchar *pkt, int len) { diff --git a/net/arp.c b/net/arp.c index 524361cf1b..5af65dffd6 100644 --- a/net/arp.c +++ b/net/arp.c @@ -34,8 +34,7 @@ uchar *arp_wait_packet_ethaddr; int arp_wait_tx_packet_size; ulong arp_wait_timer_start; int arp_wait_try; - -static uchar *arp_tx_packet; /* THE ARP transmit packet */ +uchar *arp_tx_packet; /* THE ARP transmit packet */ static uchar arp_tx_packet_buf[PKTSIZE_ALIGN + PKTALIGN];
void arp_init(void) @@ -126,6 +125,7 @@ void arp_receive(struct ethernet_hdr *et, struct ip_udp_hdr *ip, int len) struct arp_hdr *arp; struct in_addr reply_ip_addr; int eth_hdr_size; + uchar *tx_packet;
/* * We have to deal with two types of ARP packets: @@ -182,8 +182,9 @@ void arp_receive(struct ethernet_hdr *et, struct ip_udp_hdr *ip, int len) (net_read_ip(&arp->ar_spa).s_addr & net_netmask.s_addr)) udelay(5000); #endif - memcpy(net_tx_packet, et, eth_hdr_size + ARP_HDR_SIZE); - net_send_packet(net_tx_packet, eth_hdr_size + ARP_HDR_SIZE); + tx_packet = net_get_async_tx_pkt_buf(); + memcpy(tx_packet, et, eth_hdr_size + ARP_HDR_SIZE); + net_send_packet(tx_packet, eth_hdr_size + ARP_HDR_SIZE); return;
case ARPOP_REPLY: /* arp reply */ diff --git a/net/arp.h b/net/arp.h index afb86958f3..25b3c00d5c 100644 --- a/net/arp.h +++ b/net/arp.h @@ -20,6 +20,7 @@ extern uchar *arp_wait_packet_ethaddr; extern int arp_wait_tx_packet_size; extern ulong arp_wait_timer_start; extern int arp_wait_try; +extern uchar *arp_tx_packet;
void arp_init(void); void arp_request(void); diff --git a/net/net.c b/net/net.c index f35695b4fc..bc3b66837d 100644 --- a/net/net.c +++ b/net/net.c @@ -799,6 +799,14 @@ void net_set_timeout_handler(ulong iv, thand_f *f) } }
+uchar *net_get_async_tx_pkt_buf(void) +{ + if (arp_is_waiting()) + return arp_tx_packet; /* If we are waiting, we already sent */ + else + return net_tx_packet; +} + int net_send_udp_packet(uchar *ether, struct in_addr dest, int dport, int sport, int payload_len) { diff --git a/net/ping.c b/net/ping.c index 3e5461a36a..821d35d01d 100644 --- a/net/ping.c +++ b/net/ping.c @@ -84,6 +84,7 @@ void ping_receive(struct ethernet_hdr *et, struct ip_udp_hdr *ip, int len) struct icmp_hdr *icmph = (struct icmp_hdr *)&ip->udp_src; struct in_addr src_ip; int eth_hdr_size; + uchar *tx_packet;
switch (icmph->type) { case ICMP_ECHO_REPLY: @@ -107,8 +108,10 @@ void ping_receive(struct ethernet_hdr *et, struct ip_udp_hdr *ip, int len) icmph->type = ICMP_ECHO_REPLY; icmph->checksum = 0; icmph->checksum = compute_ip_checksum(icmph, len - IP_HDR_SIZE); - memcpy(net_tx_packet, et, eth_hdr_size + len); - net_send_packet(net_tx_packet, eth_hdr_size + len); + + tx_packet = net_get_async_tx_pkt_buf(); + memcpy(tx_packet, et, eth_hdr_size + len); + net_send_packet(tx_packet, eth_hdr_size + len); return; /* default: return;*/ diff --git a/test/dm/eth.c b/test/dm/eth.c index 77c602beaf..e9ac046431 100644 --- a/test/dm/eth.c +++ b/test/dm/eth.c @@ -327,10 +327,9 @@ static int dm_test_eth_async_arp_reply(struct unit_test_state *uts)
sandbox_eth_set_tx_handler(0, sb_with_async_arp_handler); sandbox_eth_set_priv(0, uts); - sandbox_eth_skip_timeout();
env_set("ethact", "eth@10002000"); - ut_assert(net_loop(PING) == -ETIMEDOUT); + ut_assertok(net_loop(PING)); ut_asserteq_str("eth@10002000", env_get("ethact"));
sandbox_eth_set_tx_handler(0, NULL); @@ -408,10 +407,9 @@ static int dm_test_eth_async_ping_reply(struct unit_test_state *uts)
sandbox_eth_set_tx_handler(0, sb_with_async_ping_handler); sandbox_eth_set_priv(0, uts); - sandbox_eth_skip_timeout();
That report was:
On Wed, Jul 25, 2018 at 5:44 AM Joe Hershberger joe.hershberger@ni.com wrote:
That report was:
Reviewed-by: Bin Meng bmeng.cn@gmail.com Tested-by: Bin Meng bmeng.cn@gmail.com
Bin Meng
Joe Hershberger
