[U-Boot] [PATCH] arm: qemu: rework Kconfig
Define a missing CONFIG_SYS_SOC and move some CONFIG_SYS_* to a more canonical place (i.e. under board).
Signed-off-by: AKASHI Takahiro takahiro.akashi@linaro.org --- arch/arm/Kconfig | 1 + arch/arm/mach-qemu/Kconfig | 18 ++++++++++-------- board/emulation/qemu-arm/Kconfig | 9 +++++++++ 3 files changed, 20 insertions(+), 8 deletions(-) create mode 100644 board/emulation/qemu-arm/Kconfig
diff --git a/arch/arm/Kconfig b/arch/arm/Kconfig index b39d08539aee..6dadf5a56f0c 100644 --- a/arch/arm/Kconfig +++ b/arch/arm/Kconfig @@ -1474,6 +1474,7 @@ source "board/broadcom/bcmns2/Kconfig" source "board/cavium/thunderx/Kconfig" source "board/cirrus/edb93xx/Kconfig" source "board/eets/pdu001/Kconfig" +source "board/emulation/qemu-arm/Kconfig" source "board/freescale/ls2080a/Kconfig" source "board/freescale/ls2080aqds/Kconfig" source "board/freescale/ls2080ardb/Kconfig" diff --git a/arch/arm/mach-qemu/Kconfig b/arch/arm/mach-qemu/Kconfig index a2e4b98b8887..d75a95183a75 100644 --- a/arch/arm/mach-qemu/Kconfig +++ b/arch/arm/mach-qemu/Kconfig @@ -3,22 +3,24 @@ if ARCH_QEMU config SYS_VENDOR default "emulation"
-config SYS_BOARD - default "qemu-arm" +config SYS_SOC + default "qemu"
-config SYS_CONFIG_NAME - default "qemu-arm" - -endif +choice + prompt "QEMU cpu type"
config TARGET_QEMU_ARM_32BIT - bool "Support qemu_arm" + bool "Arm" depends on ARCH_QEMU select ARCH_SUPPORT_PSCI select CPU_V7A select SYS_ARCH_TIMER
config TARGET_QEMU_ARM_64BIT - bool "Support qemu_arm64" + bool "AArch64" depends on ARCH_QEMU select ARM64 + +endchoice + +endif diff --git a/board/emulation/qemu-arm/Kconfig b/board/emulation/qemu-arm/Kconfig new file mode 100644 index 000000000000..db8b2a4dfae2 --- /dev/null +++ b/board/emulation/qemu-arm/Kconfig @@ -0,0 +1,9 @@ +if TARGET_QEMU_ARM_32BIT || TARGET_QEMU_ARM_64BIT + +config SYS_BOARD + default "qemu-arm" + +config SYS_CONFIG_NAME + default "qemu-arm" + +endif
On Fri, Oct 19, 2018 at 4:55 PM AKASHI Takahiro takahiro.akashi@linaro.org wrote:
Please rebase your changes on top of http://patchwork.ozlabs.org/patch/984021/
Regards, Bin
OK, but has this patch already acked? Anyway, I will include this patch in my patch set of "efi_loader: improve boot sequence in distro_bootcmd."
Thanks, -Takahiro Akashi
Regards, Bin
Hi Takahiro,
On Mon, Oct 22, 2018 at 12:35 PM AKASHI Takahiro takahiro.akashi@linaro.org wrote:
Yes, it's in Simon's DM tree (guess it targets to next release)
Regards, Bin
AKASHI Takahiro
Bin Meng
