[U-Boot] [PATCH 03/13 v5] ARM: OMAP3: Add ARM Cortex A8 common directory
Signed-off-by: Dirk Behme dirk.behme@gmail.com
--- cpu/arm_cortexa8/Makefile | 47 ++++ cpu/arm_cortexa8/config.mk | 36 +++ cpu/arm_cortexa8/cpu.c | 238 ++++++++++++++++++++ cpu/arm_cortexa8/start.S | 516 +++++++++++++++++++++++++++++++++++++++++++++ 4 files changed, 837 insertions(+)
Index: u-boot-main/cpu/arm_cortexa8/cpu.c =================================================================== --- /dev/null +++ u-boot-main/cpu/arm_cortexa8/cpu.c @@ -0,0 +1,238 @@ +/* + * (C) Copyright 2008 Texas Insturments + * + * (C) Copyright 2002 + * Sysgo Real-Time Solutions, GmbH <www.elinos.com> + * Marius Groeger mgroeger@sysgo.de + * + * (C) Copyright 2002 + * Gary Jennejohn, DENX Software Engineering, gj@denx.de + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +/* + * CPU specific code + */ + +#include <common.h> +#include <command.h> +#include <asm/arch/sys_proto.h> + +#ifdef CONFIG_USE_IRQ +DECLARE_GLOBAL_DATA_PTR; +#endif + +#ifndef CONFIG_L2_OFF +void l2cache_disable(void); +#endif + +static void cache_flush(void); + +/* read co-processor 15, register #1 (control register) */ +static unsigned long read_p15_c1(void) +{ + unsigned long value; + + __asm__ __volatile__("mrc p15, 0, %0, c1, c0, 0\ + @ read control reg\n":"=r"(value) + ::"memory"); + return value; +} + +/* write to co-processor 15, register #1 (control register) */ +static void write_p15_c1(unsigned long value) +{ + __asm__ __volatile__("mcr p15, 0, %0, c1, c0, 0\ + @ write it back\n"::"r"(value) + : "memory"); + + read_p15_c1(); +} + +static void cp_delay(void) +{ + volatile int i; + + /* Many OMAP regs need at least 2 nops */ + for (i = 0; i < 100; i++) ; +} + +/* See also ARM Ref. Man. */ +#define C1_MMU (1<<0) /* mmu off/on */ +#define C1_ALIGN (1<<1) /* alignment faults off/on */ +#define C1_DC (1<<2) /* dcache off/on */ +#define C1_WB (1<<3) /* merging write buffer on/off */ +#define C1_BIG_ENDIAN (1<<7) /* big endian off/on */ +#define C1_SYS_PROT (1<<8) /* system protection */ +#define C1_ROM_PROT (1<<9) /* ROM protection */ +#define C1_IC (1<<12) /* icache off/on */ +#define C1_HIGH_VECTORS (1<<13) /* location of vectors: low/high addresses */ +#define RESERVED_1 (0xf << 3) /* must be 111b for R/W */ + +int cpu_init(void) +{ + /* + * setup up stacks if necessary + */ +#ifdef CONFIG_USE_IRQ + IRQ_STACK_START = + _armboot_start - CONFIG_SYS_MALLOC_LEN - CONFIG_SYS_GBL_DATA_SIZE - 4; + FIQ_STACK_START = IRQ_STACK_START - CONFIG_STACKSIZE_IRQ; +#endif + return 0; +} + +int cleanup_before_linux(void) +{ + unsigned int i; + + /* + * this function is called just before we call linux + * it prepares the processor for linux + * + * we turn off caches etc ... + */ + disable_interrupts(); + + /* turn off I/D-cache */ + icache_disable(); + dcache_disable(); + + /* invalidate I-cache */ + cache_flush(); + +#ifndef CONFIG_L2_OFF + /* turn off L2 cache */ + l2cache_disable(); + /* invalidate L2 cache also */ + v7_flush_dcache_all(get_device_type()); +#endif + i = 0; + /* mem barrier to sync up things */ + asm("mcr p15, 0, %0, c7, c10, 4": :"r"(i)); + +#ifndef CONFIG_L2_OFF + l2cache_enable(); +#endif + + return 0; +} + +int do_reset(cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]) +{ + disable_interrupts(); + reset_cpu(0); + + /* NOTREACHED */ + return 0; +} + +void icache_enable(void) +{ + ulong reg; + + reg = read_p15_c1(); /* get control reg. */ + cp_delay(); + write_p15_c1(reg | C1_IC); +} + +void icache_disable(void) +{ + ulong reg; + + reg = read_p15_c1(); + cp_delay(); + write_p15_c1(reg & ~C1_IC); +} + +void dcache_disable (void) +{ + ulong reg; + + reg = read_p15_c1 (); + cp_delay (); + write_p15_c1 (reg & ~C1_DC); +} + +void l2cache_enable() +{ + unsigned long i; + volatile unsigned int j; + + /* ES2 onwards we can disable/enable L2 ourselves */ + if (get_cpu_rev() == CPU_3430_ES2) { + __asm__ __volatile__("mrc p15, 0, %0, c1, c0, 1":"=r"(i)); + __asm__ __volatile__("orr %0, %0, #0x2":"=r"(i)); + __asm__ __volatile__("mcr p15, 0, %0, c1, c0, 1":"=r"(i)); + } else { + /* Save r0, r12 and restore them after usage */ + __asm__ __volatile__("mov %0, r12":"=r"(j)); + __asm__ __volatile__("mov %0, r0":"=r"(i)); + + /* GP Device ROM code API usage here */ + /* r12 = AUXCR Write function and r0 value */ + __asm__ __volatile__("mov r12, #0x3"); + __asm__ __volatile__("mrc p15, 0, r0, c1, c0, 1"); + __asm__ __volatile__("orr r0, r0, #0x2"); + /* SMI instruction to call ROM Code API */ + __asm__ __volatile__(".word 0xE1600070"); + __asm__ __volatile__("mov r0, %0":"=r"(i)); + __asm__ __volatile__("mov r12, %0":"=r"(j)); + } + +} + +void l2cache_disable() +{ + unsigned long i; + volatile unsigned int j; + + /* ES2 onwards we can disable/enable L2 ourselves */ + if (get_cpu_rev() == CPU_3430_ES2) { + __asm__ __volatile__("mrc p15, 0, %0, c1, c0, 1":"=r"(i)); + __asm__ __volatile__("bic %0, %0, #0x2":"=r"(i)); + __asm__ __volatile__("mcr p15, 0, %0, c1, c0, 1":"=r"(i)); + } else { + /* Save r0, r12 and restore them after usage */ + __asm__ __volatile__("mov %0, r12":"=r"(j)); + __asm__ __volatile__("mov %0, r0":"=r"(i)); + + /* GP Device ROM code API usage here */ + /* r12 = AUXCR Write function and r0 value */ + __asm__ __volatile__("mov r12, #0x3"); + __asm__ __volatile__("mrc p15, 0, r0, c1, c0, 1"); + __asm__ __volatile__("bic r0, r0, #0x2"); + /* SMI instruction to call ROM Code API */ + __asm__ __volatile__(".word 0xE1600070"); + __asm__ __volatile__("mov r0, %0":"=r"(i)); + __asm__ __volatile__("mov r12, %0":"=r"(j)); + } +} + +int icache_status(void) +{ + return (read_p15_c1() & C1_IC) != 0; +} + +static void cache_flush(void) +{ + asm ("mcr p15, 0, %0, c7, c5, 0": :"r" (0)); +} + Index: u-boot-main/cpu/arm_cortexa8/Makefile =================================================================== --- /dev/null +++ u-boot-main/cpu/arm_cortexa8/Makefile @@ -0,0 +1,47 @@ +# +# (C) Copyright 2000-2003 +# Wolfgang Denk, DENX Software Engineering, wd@denx.de. +# +# See file CREDITS for list of people who contributed to this +# project. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA +# + +include $(TOPDIR)/config.mk + +LIB = $(obj)lib$(CPU).a + +START := start.o +COBJS := cpu.o + +SRCS := $(START:.o=.S) $(COBJS:.o=.c) +OBJS := $(addprefix $(obj),$(COBJS)) +START := $(addprefix $(obj),$(START)) + +all: $(obj).depend $(START) $(LIB) + +$(LIB): $(OBJS) + $(AR) $(ARFLAGS) $@ $(OBJS) + +######################################################################### + +# defines $(obj).depend target +include $(SRCTREE)/rules.mk + +sinclude $(obj).depend + +######################################################################### \ No newline at end of file Index: u-boot-main/cpu/arm_cortexa8/config.mk =================================================================== --- /dev/null +++ u-boot-main/cpu/arm_cortexa8/config.mk @@ -0,0 +1,36 @@ +# +# (C) Copyright 2002 +# Gary Jennejohn, DENX Software Engineering, gj@denx.de +# +# See file CREDITS for list of people who contributed to this +# project. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA +# +PLATFORM_RELFLAGS += -fno-strict-aliasing -fno-common -ffixed-r8 \ + -msoft-float + +# Make ARMv5 to allow more compilers to work, even though its v7a. +PLATFORM_CPPFLAGS += -march=armv5 +# ========================================================================= +# +# Supply options according to compiler version +# +# ========================================================================= +PLATFORM_CPPFLAGS +=$(call cc-option) +PLATFORM_CPPFLAGS +=$(call cc-option,-mno-thumb-interwork,) +PLATFORM_RELFLAGS +=$(call cc-option,-mshort-load-bytes,\ + $(call cc-option,-malignment-traps,)) \ No newline at end of file Index: u-boot-main/cpu/arm_cortexa8/start.S =================================================================== --- /dev/null +++ u-boot-main/cpu/arm_cortexa8/start.S @@ -0,0 +1,516 @@ +/* + * armboot - Startup Code for OMAP3530/ARM Cortex CPU-core + * + * Copyright (c) 2004 Texas Instruments r-woodruff2@ti.com + * + * Copyright (c) 2001 Marius Gröger mag@sysgo.de + * Copyright (c) 2002 Alex Züpke azu@sysgo.de + * Copyright (c) 2002 Gary Jennejohn gj@denx.de + * Copyright (c) 2003 Richard Woodruff r-woodruff2@ti.com + * Copyright (c) 2003 Kshitij kshitij@ti.com + * Copyright (c) 2006-2008 Syed Mohammed Khasim x0khasim@ti.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <config.h> +#include <version.h> + +.globl _start +_start: b reset + ldr pc, _undefined_instruction + ldr pc, _software_interrupt + ldr pc, _prefetch_abort + ldr pc, _data_abort + ldr pc, _not_used + ldr pc, _irq + ldr pc, _fiq + +_undefined_instruction: .word undefined_instruction +_software_interrupt: .word software_interrupt +_prefetch_abort: .word prefetch_abort +_data_abort: .word data_abort +_not_used: .word not_used +_irq: .word irq +_fiq: .word fiq +_pad: .word 0x12345678 /* now 16*4=64 */ +.global _end_vect +_end_vect: + + .balignl 16,0xdeadbeef +/************************************************************************* + * + * Startup Code (reset vector) + * + * do important init only if we don't start from memory! + * setup Memory and board specific bits prior to relocation. + * relocate armboot to ram + * setup stack + * + *************************************************************************/ + +_TEXT_BASE: + .word TEXT_BASE + +.globl _armboot_start +_armboot_start: + .word _start + +/* + * These are defined in the board-specific linker script. + */ +.globl _bss_start +_bss_start: + .word __bss_start + +.globl _bss_end +_bss_end: + .word _end + +#ifdef CONFIG_USE_IRQ +/* IRQ stack memory (calculated at run-time) */ +.globl IRQ_STACK_START +IRQ_STACK_START: + .word 0x0badc0de + +/* IRQ stack memory (calculated at run-time) */ +.globl FIQ_STACK_START +FIQ_STACK_START: + .word 0x0badc0de +#endif + +/* + * the actual reset code + */ + +reset: + /* + * set the cpu to SVC32 mode + */ + mrs r0, cpsr + bic r0, r0, #0x1f + orr r0, r0, #0xd3 + msr cpsr,r0 + +#if (CONFIG_OMAP34XX) + /* Copy vectors to mask ROM indirect addr */ + adr r0, _start @ r0 <- current position of code + add r0, r0, #4 @ skip reset vector + mov r2, #64 @ r2 <- size to copy + add r2, r0, r2 @ r2 <- source end address + mov r1, #SRAM_OFFSET0 @ build vect addr + mov r3, #SRAM_OFFSET1 + add r1, r1, r3 + mov r3, #SRAM_OFFSET2 + add r1, r1, r3 +next: + ldmia r0!, {r3 - r10} @ copy from source address [r0] + stmia r1!, {r3 - r10} @ copy to target address [r1] + cmp r0, r2 @ until source end address [r2] + bne next @ loop until equal */ +#if !defined(CONFIG_SYS_NAND_BOOT) && !defined(CONFIG_SYS_ONENAND_BOOT) + /* No need to copy/exec the clock code - DPLL adjust already done + * in NAND/oneNAND Boot. + */ + bl cpy_clk_code @ put dpll adjust code behind vectors +#endif /* NAND Boot */ +#endif + /* the mask ROM code should have PLL and others stable */ +#ifndef CONFIG_SKIP_LOWLEVEL_INIT + bl cpu_init_crit +#endif + +#ifndef CONFIG_SKIP_RELOCATE_UBOOT +relocate: @ relocate U-Boot to RAM + adr r0, _start @ r0 <- current position of code + ldr r1, _TEXT_BASE @ test if we run from flash or RAM + cmp r0, r1 @ don't reloc during debug + beq stack_setup + + ldr r2, _armboot_start + ldr r3, _bss_start + sub r2, r3, r2 @ r2 <- size of armboot + add r2, r0, r2 @ r2 <- source end address + +copy_loop: @ copy 32 bytes at a time + ldmia r0!, {r3 - r10} @ copy from source address [r0] + stmia r1!, {r3 - r10} @ copy to target address [r1] + cmp r0, r2 @ until source end addreee [r2] + ble copy_loop +#endif /* CONFIG_SKIP_RELOCATE_UBOOT */ + + /* Set up the stack */ +stack_setup: + ldr r0, _TEXT_BASE @ upper 128 KiB: relocated uboot + sub r0, r0, #CONFIG_SYS_MALLOC_LEN @ malloc area + sub r0, r0, #CONFIG_SYS_GBL_DATA_SIZE @ bdinfo +#ifdef CONFIG_USE_IRQ + sub r0, r0, #(CONFIG_STACKSIZE_IRQ + CONFIG_STACKSIZE_FIQ) +#endif + sub sp, r0, #12 @ leave 3 words for abort-stack + and sp, sp, #~7 @ 8 byte alinged for (ldr/str)d + + /* Clear BSS (if any). Is below tx (watch load addr - need space) */ +clear_bss: + ldr r0, _bss_start @ find start of bss segment + ldr r1, _bss_end @ stop here + mov r2, #0x00000000 @ clear value +clbss_l: + str r2, [r0] @ clear BSS location + cmp r0, r1 @ are we at the end yet + add r0, r0, #4 @ increment clear index pointer + bne clbss_l @ keep clearing till at end + + ldr pc, _start_armboot @ jump to C code + +_start_armboot: .word start_armboot + + +/************************************************************************* + * + * CPU_init_critical registers + * + * setup important registers + * setup memory timing + * + *************************************************************************/ +cpu_init_crit: + /* + * Invalidate L1 I/D + */ + mov r0, #0 @ set up for MCR + mcr p15, 0, r0, c8, c7, 0 @ invalidate TLBs + mcr p15, 0, r0, c7, c5, 0 @ invalidate icache + + /* + * disable MMU stuff and caches + */ + mrc p15, 0, r0, c1, c0, 0 + bic r0, r0, #0x00002000 @ clear bits 13 (--V-) + bic r0, r0, #0x00000007 @ clear bits 2:0 (-CAM) + orr r0, r0, #0x00000002 @ set bit 1 (--A-) Align + orr r0, r0, #0x00000800 @ set bit 12 (Z---) BTB + mcr p15, 0, r0, c1, c0, 0 + + /* + * Jump to board specific initialization... + * The Mask ROM will have already initialized + * basic memory. Go here to bump up clock rate and handle + * wake up conditions. + */ + mov ip, lr @ persevere link reg across call + bl lowlevel_init @ go setup pll,mux,memory + mov lr, ip @ restore link + mov pc, lr @ back to my caller +/* + ************************************************************************* + * + * Interrupt handling + * + ************************************************************************* + */ +@ +@ IRQ stack frame. +@ +#define S_FRAME_SIZE 72 + +#define S_OLD_R0 68 +#define S_PSR 64 +#define S_PC 60 +#define S_LR 56 +#define S_SP 52 + +#define S_IP 48 +#define S_FP 44 +#define S_R10 40 +#define S_R9 36 +#define S_R8 32 +#define S_R7 28 +#define S_R6 24 +#define S_R5 20 +#define S_R4 16 +#define S_R3 12 +#define S_R2 8 +#define S_R1 4 +#define S_R0 0 + +#define MODE_SVC 0x13 +#define I_BIT 0x80 + +/* + * use bad_save_user_regs for abort/prefetch/undef/swi ... + * use irq_save_user_regs / irq_restore_user_regs for IRQ/FIQ handling + */ + + .macro bad_save_user_regs + sub sp, sp, #S_FRAME_SIZE @ carve out a frame on current + @ user stack + stmia sp, {r0 - r12} @ Save user registers (now in + @ svc mode) r0-r12 + + ldr r2, _armboot_start + sub r2, r2, #(CONFIG_SYS_MALLOC_LEN) + sub r2, r2, #(CONFIG_SYS_GBL_DATA_SIZE + 8) @ set base 2 words into abort + @ stack + ldmia r2, {r2 - r3} @ get values for "aborted" pc + @ and cpsr (into parm regs) + add r0, sp, #S_FRAME_SIZE @ grab pointer to old stack + + add r5, sp, #S_SP + mov r1, lr + stmia r5, {r0 - r3} @ save sp_SVC, lr_SVC, pc, cpsr + mov r0, sp @ save current stack into r0 + @ (param register) + .endm + + .macro irq_save_user_regs + sub sp, sp, #S_FRAME_SIZE + stmia sp, {r0 - r12} @ Calling r0-r12 + add r8, sp, #S_PC @ !! R8 NEEDS to be saved !! + @ a reserved stack spot would + @ be good. + stmdb r8, {sp, lr}^ @ Calling SP, LR + str lr, [r8, #0] @ Save calling PC + mrs r6, spsr + str r6, [r8, #4] @ Save CPSR + str r0, [r8, #8] @ Save OLD_R0 + mov r0, sp + .endm + + .macro irq_restore_user_regs + ldmia sp, {r0 - lr}^ @ Calling r0 - lr + mov r0, r0 + ldr lr, [sp, #S_PC] @ Get PC + add sp, sp, #S_FRAME_SIZE + subs pc, lr, #4 @ return & move spsr_svc into + @ cpsr + .endm + + .macro get_bad_stack + ldr r13, _armboot_start @ setup our mode stack (enter + @ in banked mode) + sub r13, r13, #(CONFIG_SYS_MALLOC_LEN) @ move past malloc pool + sub r13, r13, #(CONFIG_SYS_GBL_DATA_SIZE + 8) @ move to reserved a couple + @ spots for abort stack + + str lr, [r13] @ save caller lr in position 0 + @ of saved stack + mrs lr, spsr @ get the spsr + str lr, [r13, #4] @ save spsr in position 1 of + @ saved stack + + mov r13, #MODE_SVC @ prepare SVC-Mode + @ msr spsr_c, r13 + msr spsr, r13 @ switch modes, make sure + @ moves will execute + mov lr, pc @ capture return pc + movs pc, lr @ jump to next instruction & + @ switch modes. + .endm + + .macro get_bad_stack_swi + sub r13, r13, #4 @ space on current stack for + @ scratch reg. + str r0, [r13] @ save R0's value. + ldr r0, _armboot_start @ get data regions start + sub r0, r0, #(CONFIG_SYS_MALLOC_LEN) @ move past malloc pool + sub r0, r0, #(CONFIG_SYS_GBL_DATA_SIZE + 8) @ move past gbl and a couple + @ spots for abort stack + str lr, [r0] @ save caller lr in position 0 + @ of saved stack + mrs r0, spsr @ get the spsr + str lr, [r0, #4] @ save spsr in position 1 of + @ saved stack + ldr r0, [r13] @ restore r0 + add r13, r13, #4 @ pop stack entry + .endm + + .macro get_irq_stack @ setup IRQ stack + ldr sp, IRQ_STACK_START + .endm + + .macro get_fiq_stack @ setup FIQ stack + ldr sp, FIQ_STACK_START + .endm + +/* + * exception handlers + */ + .align 5 +undefined_instruction: + get_bad_stack + bad_save_user_regs + bl do_undefined_instruction + + .align 5 +software_interrupt: + get_bad_stack_swi + bad_save_user_regs + bl do_software_interrupt + + .align 5 +prefetch_abort: + get_bad_stack + bad_save_user_regs + bl do_prefetch_abort + + .align 5 +data_abort: + get_bad_stack + bad_save_user_regs + bl do_data_abort + + .align 5 +not_used: + get_bad_stack + bad_save_user_regs + bl do_not_used + +#ifdef CONFIG_USE_IRQ + + .align 5 +irq: + get_irq_stack + irq_save_user_regs + bl do_irq + irq_restore_user_regs + + .align 5 +fiq: + get_fiq_stack + /* someone ought to write a more effiction fiq_save_user_regs */ + irq_save_user_regs + bl do_fiq + irq_restore_user_regs + +#else + + .align 5 +irq: + get_bad_stack + bad_save_user_regs + bl do_irq + + .align 5 +fiq: + get_bad_stack + bad_save_user_regs + bl do_fiq + +#endif + +/* + * v7_flush_dcache_all() + * + * Flush the whole D-cache. + * + * Corrupted registers: r0-r5, r7, r9-r11 + * + * - mm - mm_struct describing address space + */ + .align 5 +.global v7_flush_dcache_all +v7_flush_dcache_all: + stmfd r13!, {r0 - r5, r7, r9 - r12, r14} + + mov r7, r0 @ take a backup of device type + cmp r0, #0x3 @ check if the device type is + @ GP + moveq r12, #0x1 @ set up to invalide L2 +smi: .word 0x01600070 @ Call SMI monitor (smieq) + cmp r7, #0x3 @ compare again in case its + @ lost + beq finished_inval @ if GP device, inval done + @ above + + mrc p15, 1, r0, c0, c0, 1 @ read clidr + ands r3, r0, #0x7000000 @ extract loc from clidr + mov r3, r3, lsr #23 @ left align loc bit field + beq finished_inval @ if loc is 0, then no need to + @ clean + mov r10, #0 @ start clean at cache level 0 +inval_loop1: + add r2, r10, r10, lsr #1 @ work out 3x current cache + @ level + mov r1, r0, lsr r2 @ extract cache type bits from + @ clidr + and r1, r1, #7 @ mask of the bits for current + @ cache only + cmp r1, #2 @ see what cache we have at + @ this level + blt skip_inval @ skip if no cache, or just + @ i-cache + mcr p15, 2, r10, c0, c0, 0 @ select current cache level + @ in cssr + mov r2, #0 @ operand for mcr SBZ + mcr p15, 0, r2, c7, c5, 4 @ flush prefetch buffer to + @ sych the new cssr&csidr, + @ with armv7 this is 'isb', + @ but we compile with armv5 + mrc p15, 1, r1, c0, c0, 0 @ read the new csidr + and r2, r1, #7 @ extract the length of the + @ cache lines + add r2, r2, #4 @ add 4 (line length offset) + ldr r4, =0x3ff + ands r4, r4, r1, lsr #3 @ find maximum number on the + @ way size + clz r5, r4 @ find bit position of way + @ size increment + ldr r7, =0x7fff + ands r7, r7, r1, lsr #13 @ extract max number of the + @ index size +inval_loop2: + mov r9, r4 @ create working copy of max + @ way size +inval_loop3: + orr r11, r10, r9, lsl r5 @ factor way and cache number + @ into r11 + orr r11, r11, r7, lsl r2 @ factor index number into r11 + mcr p15, 0, r11, c7, c6, 2 @ invalidate by set/way + subs r9, r9, #1 @ decrement the way + bge inval_loop3 + subs r7, r7, #1 @ decrement the index + bge inval_loop2 +skip_inval: + add r10, r10, #2 @ increment cache number + cmp r3, r10 + bgt inval_loop1 +finished_inval: + mov r10, #0 @ swith back to cache level 0 + mcr p15, 2, r10, c0, c0, 0 @ select current cache level + @ in cssr + mcr p15, 0, r10, c7, c5, 4 @ flush prefetch buffer, + @ with armv7 this is 'isb', + @ but we compile with armv5 + + ldmfd r13!, {r0 - r5, r7, r9 - r12, pc} + + + .align 5 +.global reset_cpu +reset_cpu: + ldr r1, rstctl @ get addr for global reset + @ reg + mov r3, #0x2 @ full reset pll + mpu + str r3, [r1] @ force reset + mov r0, r0 +_loop_forever: + b _loop_forever +rstctl: + .word PRM_RSTCTRL
Dear dirk.behme@googlemail.com,
In message 490df313.1358560a.73b4.222e@mx.google.com you wrote:
--===============1314021165==
- volatile int i;
- /* Many OMAP regs need at least 2 nops */
- for (i = 0; i < 100; i++) ;
There is not much reason for the compiler not to optimize this code away.
- ulong reg;
- reg = read_p15_c1();
- cp_delay();
- write_p15_c1(reg & ~C1_IC);
- ulong reg;
- reg = read_p15_c1 ();
- cp_delay ();
- write_p15_c1 (reg & ~C1_DC);
Would it make sense to flush caches before disbling?
- /* someone ought to write a more effiction fiq_save_user_regs */
effiction ?
- volatile int i;
- ulong reg;
- cp_delay();
- ulong reg;
- cp_delay ();
Basically yes. But regarding the logic used in existing code, e.g.
cpu/arm1176/cpu.c (cleanup_before_linux())
I'm not sure about this. The logic seems to be to provide single functions for each cache operation and then call the functions in the correct order.
effiction ?
Dirk Behme
