[PATCH] ARC: rework setting of ARC CPU specific compiler options
It's a very rare if at all existing occasion when ARC CPU template is used as is w/o any changes - in the end it's a beauty and competitive advantage of ARC cores to be tailored for a particular use-case - and so it doesn't make a lot of sense to offer template-based "-mcpu" selection. Given for each and every platform we end-up adding quite a few more flags it's logical to move "-mcpu" selection to platform's definition as well which we exactly do here.
Signed-off-by: Eugeniy Paltsev Eugeniy.Paltsev@synopsys.com --- arch/arc/config.mk | 20 -------------------- board/abilis/tb100/config.mk | 5 +++++ board/synopsys/axs10x/config.mk | 6 ++++++ board/synopsys/emsdp/config.mk | 2 +- board/synopsys/hsdk/config.mk | 4 ++++ board/synopsys/iot_devkit/config.mk | 3 ++- board/synopsys/nsim/Kconfig | 9 +++++++++ board/synopsys/nsim/config.mk | 8 ++++++++ configs/nsim_700_defconfig | 1 + configs/nsim_700be_defconfig | 1 + configs/nsim_hs38_defconfig | 1 + configs/nsim_hs38be_defconfig | 1 + 12 files changed, 39 insertions(+), 22 deletions(-) create mode 100644 board/abilis/tb100/config.mk create mode 100644 board/synopsys/nsim/config.mk
diff --git a/arch/arc/config.mk b/arch/arc/config.mk index 18005d99930..6fa29adae81 100644 --- a/arch/arc/config.mk +++ b/arch/arc/config.mk @@ -22,26 +22,6 @@ ifdef CONFIG_ARC_MMU_VER CONFIG_MMU = 1 endif
-ifdef CONFIG_CPU_ARC750D -PLATFORM_CPPFLAGS += -mcpu=arc700 -endif - -ifdef CONFIG_CPU_ARC770D -PLATFORM_CPPFLAGS += -mcpu=arc700 -mlock -mswape -endif - -ifdef CONFIG_CPU_ARCEM6 -PLATFORM_CPPFLAGS += -mcpu=arcem -endif - -ifdef CONFIG_CPU_ARCHS34 -PLATFORM_CPPFLAGS += -mcpu=archs -endif - -ifdef CONFIG_CPU_ARCHS38 -PLATFORM_CPPFLAGS += -mcpu=archs -endif - PLATFORM_CPPFLAGS += -ffixed-r25 -D__ARC__ -gdwarf-2 -mno-sdata PLATFORM_RELFLAGS += -ffunction-sections -fdata-sections -fno-common
diff --git a/board/abilis/tb100/config.mk b/board/abilis/tb100/config.mk new file mode 100644 index 00000000000..9e8dee49bd3 --- /dev/null +++ b/board/abilis/tb100/config.mk @@ -0,0 +1,5 @@ +# SPDX-License-Identifier: GPL-2.0+ +# +# Copyright (C) 2020 Synopsys, Inc. All rights reserved. + +PLATFORM_CPPFLAGS += -mcpu=arc700 -mlock -mswape diff --git a/board/synopsys/axs10x/config.mk b/board/synopsys/axs10x/config.mk index 81ff498f818..ccac5442908 100644 --- a/board/synopsys/axs10x/config.mk +++ b/board/synopsys/axs10x/config.mk @@ -2,6 +2,12 @@ # # Copyright (C) 2018 Synopsys, Inc. All rights reserved.
+ifdef CONFIG_TARGET_AXS103 + PLATFORM_CPPFLAGS += -mcpu=archs +else + PLATFORM_CPPFLAGS += -mcpu=arc700 -mlock -mswape +endif + bsp-generate: u-boot u-boot.bin ifdef CONFIG_ISA_ARCV2 $(Q)python3 $(srctree)/board/$(BOARDDIR)/headerize-axs.py \ diff --git a/board/synopsys/emsdp/config.mk b/board/synopsys/emsdp/config.mk index 67fd7bf82a3..5bd10442aff 100644 --- a/board/synopsys/emsdp/config.mk +++ b/board/synopsys/emsdp/config.mk @@ -1,2 +1,2 @@ -PLATFORM_CPPFLAGS += -mlittle-endian -mnorm -mswap -mmpy-option=3 \ +PLATFORM_CPPFLAGS += -mcpu=arcem -mlittle-endian -mnorm -mswap -mmpy-option=3 \ -mbarrel-shifter -mfpu=fpuda_all -mcode-density diff --git a/board/synopsys/hsdk/config.mk b/board/synopsys/hsdk/config.mk index 9e280f921a1..5ae22fa2b75 100644 --- a/board/synopsys/hsdk/config.mk +++ b/board/synopsys/hsdk/config.mk @@ -2,6 +2,10 @@ # # Copyright (C) 2018 Synopsys, Inc. All rights reserved.
+PLATFORM_CPPFLAGS += -mcpu=hs38_linux -mlittle-endian -matomic -mll64 \ + -mdiv-rem -mswap -mnorm -mmpy-option=9 -mbarrel-shifter \ + -mfpu=fpud_all + bsp-generate: u-boot u-boot.bin $(Q)python3 $(srctree)/board/$(BOARDDIR)/headerize-hsdk.py \ --arc-id 0x52 --image $(srctree)/u-boot.bin \ diff --git a/board/synopsys/iot_devkit/config.mk b/board/synopsys/iot_devkit/config.mk index 120733538a4..e1e546a3d04 100644 --- a/board/synopsys/iot_devkit/config.mk +++ b/board/synopsys/iot_devkit/config.mk @@ -1,2 +1,3 @@ -PLATFORM_CPPFLAGS += -mlittle-endian -mcode-density -mdiv-rem -mswap -mnorm -mmpy-option=6 -mbarrel-shifter +PLATFORM_CPPFLAGS += -mcpu=em4_fpuda -mlittle-endian -mcode-density -mdiv-rem \ + -mswap -mnorm -mmpy-option=6 -mbarrel-shifter LDSCRIPT = $(srctree)/board/synopsys/iot_devkit/u-boot.lds diff --git a/board/synopsys/nsim/Kconfig b/board/synopsys/nsim/Kconfig index 22287032bf5..b6966b2991e 100644 --- a/board/synopsys/nsim/Kconfig +++ b/board/synopsys/nsim/Kconfig @@ -9,4 +9,13 @@ config SYS_VENDOR config SYS_CONFIG_NAME default "nsim"
+config NSIM_BOARD_CPPFLAGS + string "board arc-specific compiler options" + help + For nSIM we allow to set custom arc-specific compiler options + (like -mcpu=) instead of hardcoding them in its makefile as nSIM + target is used for representing targets without fixed CPU version + like FPGA-based boards and software simulators. + This variable takes space separated compiler options list. + endif diff --git a/board/synopsys/nsim/config.mk b/board/synopsys/nsim/config.mk new file mode 100644 index 00000000000..40f9578a25a --- /dev/null +++ b/board/synopsys/nsim/config.mk @@ -0,0 +1,8 @@ +# SPDX-License-Identifier: GPL-2.0+ +# +# Copyright (C) 2020 Synopsys, Inc. All rights reserved. + +# CONFIG_NSIM_BOARD_CPPFLAGS is a string variable which comes from defconfig +# with double quotes. We use echo to remove them so CONFIG_NSIM_BOARD_CPPFLAGS +# won't be treated by compiler as a single option. +PLATFORM_CPPFLAGS += $(shell echo $(CONFIG_NSIM_BOARD_CPPFLAGS)) diff --git a/configs/nsim_700_defconfig b/configs/nsim_700_defconfig index 6a38e2c246a..5e897697843 100644 --- a/configs/nsim_700_defconfig +++ b/configs/nsim_700_defconfig @@ -1,5 +1,6 @@ CONFIG_ARC=y CONFIG_TARGET_NSIM=y +CONFIG_NSIM_BOARD_CPPFLAGS="-mcpu=arc700 -mlock -mswape" CONFIG_SYS_TEXT_BASE=0x81000000 CONFIG_DEBUG_UART_BASE=0xf0000000 CONFIG_DEBUG_UART_CLOCK=70000000 diff --git a/configs/nsim_700be_defconfig b/configs/nsim_700be_defconfig index d3ed84a4154..03912712486 100644 --- a/configs/nsim_700be_defconfig +++ b/configs/nsim_700be_defconfig @@ -1,6 +1,7 @@ CONFIG_ARC=y CONFIG_CPU_BIG_ENDIAN=y CONFIG_TARGET_NSIM=y +CONFIG_NSIM_BOARD_CPPFLAGS="-mcpu=arc700 -mlock -mswape" CONFIG_SYS_TEXT_BASE=0x81000000 CONFIG_DEBUG_UART_BASE=0xf0000000 CONFIG_DEBUG_UART_CLOCK=70000000 diff --git a/configs/nsim_hs38_defconfig b/configs/nsim_hs38_defconfig index 2f46610d9cb..a6ebcc49a8c 100644 --- a/configs/nsim_hs38_defconfig +++ b/configs/nsim_hs38_defconfig @@ -1,6 +1,7 @@ CONFIG_ARC=y CONFIG_ISA_ARCV2=y CONFIG_TARGET_NSIM=y +CONFIG_NSIM_BOARD_CPPFLAGS="-mcpu=archs" CONFIG_SYS_TEXT_BASE=0x81000000 CONFIG_DEBUG_UART_BASE=0xf0000000 CONFIG_DEBUG_UART_CLOCK=70000000 diff --git a/configs/nsim_hs38be_defconfig b/configs/nsim_hs38be_defconfig index b074b4ca98c..72472afb2b1 100644 --- a/configs/nsim_hs38be_defconfig +++ b/configs/nsim_hs38be_defconfig @@ -2,6 +2,7 @@ CONFIG_ARC=y CONFIG_ISA_ARCV2=y CONFIG_CPU_BIG_ENDIAN=y CONFIG_TARGET_NSIM=y +CONFIG_NSIM_BOARD_CPPFLAGS="-mcpu=archs" CONFIG_SYS_TEXT_BASE=0x81000000 CONFIG_DEBUG_UART_BASE=0xf0000000 CONFIG_DEBUG_UART_CLOCK=70000000
Eugeniy Paltsev
