[U-Boot] [PATCH v2 1/5] common: Log should depends on DM not be selected by DM
Better use depends on instead of select.
Signed-off-by: Michal Simek michal.simek@xilinx.com Reviewed-by: Tom Rini trini@konsulko.com ---
Changes in v2: None
I found this in connection to setup imply CMD_DM and it seems to not standard that it is selecting DM which is not used anywhere else.
--- common/Kconfig | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/common/Kconfig b/common/Kconfig index 81e88ea77c17..eae5d80cc71b 100644 --- a/common/Kconfig +++ b/common/Kconfig @@ -428,7 +428,7 @@ menu "Logging"
config LOG bool "Enable logging support" - select DM + depends on DM help This enables support for logging of status and debug messages. These can be displayed on the console, recorded in a memory buffer, or
Trivial Kconfig cleanup. Use tabs instead of spaces and every Kconfig entry should be separated by newline.
Changes in v2: - new patch - not to confuse script
arch/arm/Kconfig | 10 +++++----- arch/arm/mach-imx/mx6/Kconfig | 14 +++++++------- cmd/Kconfig | 5 +++-- 3 files changed, 15 insertions(+), 14 deletions(-)
diff --git a/arch/arm/Kconfig b/arch/arm/Kconfig index 376851ef7aa9..ce619641b753 100644 --- a/arch/arm/Kconfig +++ b/arch/arm/Kconfig @@ -169,7 +169,7 @@ config ARM_ERRATA_833471 bool
config ARM_ERRATA_845369 - bool + bool
config ARM_ERRATA_852421 bool @@ -683,7 +683,7 @@ config ARCH_MX31 select CPU_ARM1136
config ARCH_MX7ULP - bool "NXP MX7ULP" + bool "NXP MX7ULP" select CPU_V7A select ROM_UNIFIED_SECTIONS imply MXC_GPIO @@ -709,7 +709,7 @@ config ARCH_MX6
if ARCH_MX6 config SPL_LDSCRIPT - default "arch/arm/mach-omap2/u-boot-spl.lds" + default "arch/arm/mach-omap2/u-boot-spl.lds" endif
config ARCH_MX5 @@ -1486,8 +1486,8 @@ source "arch/arm/Kconfig.debug" endmenu
config SPL_LDSCRIPT - default "arch/arm/cpu/arm926ejs/mxs/u-boot-spl.lds" if (ARCH_MX23 || ARCH_MX28) && !SPL_FRAMEWORK - default "arch/arm/cpu/arm1136/u-boot-spl.lds" if CPU_ARM1136 + default "arch/arm/cpu/arm926ejs/mxs/u-boot-spl.lds" if (ARCH_MX23 || ARCH_MX28) && !SPL_FRAMEWORK + default "arch/arm/cpu/arm1136/u-boot-spl.lds" if CPU_ARM1136 default "arch/arm/cpu/armv8/u-boot-spl.lds" if ARM64
diff --git a/arch/arm/mach-imx/mx6/Kconfig b/arch/arm/mach-imx/mx6/Kconfig index 521fad74b5a2..b7b77cc51b97 100644 --- a/arch/arm/mach-imx/mx6/Kconfig +++ b/arch/arm/mach-imx/mx6/Kconfig @@ -293,11 +293,11 @@ config TARGET_MX6SLEVK select SUPPORT_SPL
config TARGET_MX6SLLEVK - bool "mx6sll evk" + bool "mx6sll evk" select BOARD_LATE_INIT - select MX6SLL - select DM - select DM_THERMAL + select MX6SLL + select DM + select DM_THERMAL
config TARGET_MX6SXSABRESD bool "mx6sxsabresd" @@ -309,11 +309,11 @@ config TARGET_MX6SXSABRESD select BOARD_EARLY_INIT_F
config TARGET_MX6SXSABREAUTO - bool "mx6sxsabreauto" + bool "mx6sxsabreauto" select BOARD_LATE_INIT select MX6SX - select DM - select DM_THERMAL + select DM + select DM_THERMAL select BOARD_EARLY_INIT_F
config TARGET_MX6UL_9X9_EVK diff --git a/cmd/Kconfig b/cmd/Kconfig index 2fa0829925c1..b359ac7118b0 100644 --- a/cmd/Kconfig +++ b/cmd/Kconfig @@ -1012,11 +1012,12 @@ config CMD_USB_SDP help Enables the command "sdp" which is used to have U-Boot emulating the Serial Download Protocol (SDP) via USB. + config CMD_ROCKUSB bool "rockusb" depends on USB_FUNCTION_ROCKUSB help - Rockusb protocol is widely used by Rockchip SoC based devices. It can + Rockusb protocol is widely used by Rockchip SoC based devices. It can read/write info, image to/from devices. This enable rockusb command support to communication with rockusb device. for more detail about this command, please read doc/README.rockusb. @@ -1489,7 +1490,7 @@ config CMD_BLOB the original data.
Sub-commands: - blob enc - encapsulating data as a cryptgraphic blob + blob enc - encapsulating data as a cryptgraphic blob blob dec - decapsulating cryptgraphic blob to get the data
Syntax:
Reviewed-by: Joe Hershberger joe.hershberger@ni.com
Signed-off-by: Michal Simek michal.simek@xilinx.com Reviewed-by: Tom Rini trini@konsulko.com Reviewed-by: Joe Hershberger joe.hershberger@ni.com
Fix Kconfig bool, default, select and imply options to be alphabetically sorted.
I have sorted only Kconfig which I need for the next patch.
--- arch/Kconfig | 54 +++++----- arch/arm/Kconfig | 206 ++++++++++++++++++------------------- arch/arm/mach-at91/Kconfig | 60 +++++------ arch/arm/mach-imx/mx5/Kconfig | 12 +-- arch/arm/mach-imx/mx6/Kconfig | 158 ++++++++++++++-------------- arch/arm/mach-imx/mx7/Kconfig | 18 ++-- arch/arm/mach-omap2/am33xx/Kconfig | 46 ++++----- arch/arm/mach-omap2/omap3/Kconfig | 20 ++-- arch/arm/mach-rmobile/Kconfig.32 | 14 +-- arch/arm/mach-tegra/Kconfig | 8 +- arch/microblaze/Kconfig | 4 +- arch/mips/Kconfig | 50 ++++----- arch/powerpc/cpu/mpc83xx/Kconfig | 6 +- cmd/Kconfig | 14 +-- 14 files changed, 335 insertions(+), 335 deletions(-)
diff --git a/arch/Kconfig b/arch/Kconfig index cbeb9f67348f..7967fa50ac22 100644 --- a/arch/Kconfig +++ b/arch/Kconfig @@ -10,12 +10,12 @@ choice
config ARC bool "ARC architecture" - select HAVE_PRIVATE_LIBGCC - select SUPPORT_OF_CONTROL select ARCH_EARLY_INIT_R + select ARC_TIMER select CLK + select HAVE_PRIVATE_LIBGCC + select SUPPORT_OF_CONTROL select TIMER - select ARC_TIMER
config ARM bool "ARM architecture" @@ -46,10 +46,10 @@ config NDS32
config NIOS2 bool "Nios II architecture" - select SUPPORT_OF_CONTROL - select OF_CONTROL - select DM select CPU + select DM + select OF_CONTROL + select SUPPORT_OF_CONTROL
config PPC bool "PowerPC architecture" @@ -65,30 +65,30 @@ config RISCV config SANDBOX bool "Sandbox" select BOARD_LATE_INIT - select SUPPORT_OF_CONTROL select DM + select DM_GPIO + select DM_I2C select DM_KEYBOARD - select DM_SPI_FLASH + select DM_MMC select DM_SERIAL - select DM_I2C select DM_SPI - select DM_GPIO - select DM_MMC + select DM_SPI_FLASH select HAVE_BLOCK_DEVICE - select SPI select LZO + select SPI + select SUPPORT_OF_CONTROL imply CMD_GETTIME imply CMD_HASH imply CMD_IO imply CMD_IOTRACE imply CMD_LZMADEC + imply CMD_SATA + imply CMD_SF_TEST imply CRC32_VERIFY imply FAT_WRITE imply HASH_VERIFY imply LZMA imply SCSI - imply CMD_SATA - imply CMD_SF_TEST
config SH bool "SuperH architecture" @@ -97,39 +97,39 @@ config SH config X86 bool "x86 architecture" select CREATE_ARCH_SYMLINK - select HAVE_PRIVATE_LIBGCC - select USE_PRIVATE_LIBGCC - select SUPPORT_OF_CONTROL - select OF_CONTROL select DM select DM_PCI + select HAVE_PRIVATE_LIBGCC + select OF_CONTROL select PCI + select SUPPORT_OF_CONTROL select TIMER + select USE_PRIVATE_LIBGCC select X86_TSC_TIMER imply BLK + imply CMD_FPGA_LOADMK + imply CMD_GETTIME + imply CMD_IO + imply CMD_IRQ + imply CMD_PCI + imply CMD_SF_TEST + imply CMD_ZBOOT imply DM_ETH imply DM_GPIO imply DM_KEYBOARD imply DM_MMC imply DM_RTC - imply DM_SERIAL imply DM_SCSI + imply DM_SERIAL imply DM_SPI imply DM_SPI_FLASH imply DM_USB imply DM_VIDEO imply SYSRESET imply SYSRESET_X86 - imply CMD_FPGA_LOADMK - imply CMD_GETTIME - imply CMD_IO - imply CMD_IRQ - imply CMD_PCI - imply CMD_SF_TEST - imply CMD_ZBOOT - imply USB_HOST_ETHER imply USB_ETHER_ASIX imply USB_ETHER_SMSC95XX + imply USB_HOST_ETHER
config XTENSA bool "Xtensa architecture" diff --git a/arch/arm/Kconfig b/arch/arm/Kconfig index ce619641b753..0c43c58ef0ed 100644 --- a/arch/arm/Kconfig +++ b/arch/arm/Kconfig @@ -219,25 +219,25 @@ config CPU_ARM1176
config CPU_V7A bool - select HAS_VBAR select HAS_THUMB2 + select HAS_VBAR select SYS_CACHE_SHIFT_6 imply SYS_ARM_MMU
config CPU_V7M bool select HAS_THUMB2 - select THUMB2_KERNEL - select SYS_CACHE_SHIFT_5 select SYS_ARM_MPU + select SYS_CACHE_SHIFT_5 select SYS_THUMB_BUILD + select THUMB2_KERNEL
config CPU_V7R bool select HAS_THUMB2 - select SYS_CACHE_SHIFT_6 - select SYS_ARM_MPU select SYS_ARM_CACHE_CP15 + select SYS_ARM_MPU + select SYS_CACHE_SHIFT_6
config CPU_PXA bool @@ -427,19 +427,19 @@ config ARCH_DAVINCI
config KIRKWOOD bool "Marvell Kirkwood" - select CPU_ARM926EJS - select BOARD_EARLY_INIT_F select ARCH_MISC_INIT + select BOARD_EARLY_INIT_F + select CPU_ARM926EJS
config ARCH_MVEBU bool "Marvell MVEBU family (Armada XP/375/38x/3700/7K/8K)" - select OF_CONTROL - select OF_SEPARATE select DM select DM_ETH select DM_SERIAL select DM_SPI select DM_SPI_FLASH + select OF_CONTROL + select OF_SEPARATE select SPI
config TARGET_DEVKIT3250 @@ -463,31 +463,31 @@ config ORION5X
config TARGET_SPEAR300 bool "Support spear300" - select CPU_ARM926EJS select BOARD_EARLY_INIT_F - imply CMD_SAVES + select CPU_ARM926EJS select PL011_SERIAL + imply CMD_SAVES
config TARGET_SPEAR310 bool "Support spear310" - select CPU_ARM926EJS select BOARD_EARLY_INIT_F - imply CMD_SAVES + select CPU_ARM926EJS select PL011_SERIAL + imply CMD_SAVES
config TARGET_SPEAR320 bool "Support spear320" - select CPU_ARM926EJS select BOARD_EARLY_INIT_F - imply CMD_SAVES + select CPU_ARM926EJS select PL011_SERIAL + imply CMD_SAVES
config TARGET_SPEAR600 bool "Support spear600" - select CPU_ARM926EJS select BOARD_EARLY_INIT_F - imply CMD_SAVES + select CPU_ARM926EJS select PL011_SERIAL + imply CMD_SAVES
config TARGET_STV0991 bool "Support stv0991" @@ -496,16 +496,16 @@ config TARGET_STV0991 select DM_SERIAL select DM_SPI select DM_SPI_FLASH + select PL01X_SERIAL select SPI select SPI_FLASH - select PL01X_SERIAL
config TARGET_X600 bool "Support x600" select BOARD_LATE_INIT select CPU_ARM926EJS - select SUPPORT_SPL select PL011_SERIAL + select SUPPORT_SPL
config TARGET_WOODBURN bool "Support woodburn" @@ -528,8 +528,8 @@ config TARGET_MX35PDK config ARCH_BCM283X bool "Broadcom BCM283X family" select DM - select DM_SERIAL select DM_GPIO + select DM_SERIAL select OF_CONTROL select PL01X_SERIAL select SERIAL_SEARCH_ALL @@ -577,13 +577,13 @@ config TARGET_BCM28155_AP config TARGET_BCMCYGNUS bool "Support bcmcygnus" select CPU_V7A - imply CRC32_VERIFY + imply BCM_SF2_ETH + imply BCM_SF2_ETH_GMAC imply CMD_HASH + imply CRC32_VERIFY imply FAT_WRITE imply HASH_VERIFY imply NETDEVICES - imply BCM_SF2_ETH - imply BCM_SF2_ETH_GMAC
config TARGET_BCMNSP bool "Support bcmnsp" @@ -600,12 +600,12 @@ config TARGET_BCMNS2 config ARCH_EXYNOS bool "Samsung EXYNOS" select DM + select DM_GPIO select DM_I2C - select DM_SPI_FLASH + select DM_KEYBOARD select DM_SERIAL select DM_SPI - select DM_GPIO - select DM_KEYBOARD + select DM_SPI_FLASH select SPI imply FAT_WRITE
@@ -613,9 +613,9 @@ config ARCH_S5PC1XX bool "Samsung S5PC1XX" select CPU_V7A select DM - select DM_SERIAL select DM_GPIO select DM_I2C + select DM_SERIAL
config ARCH_HIGHBANK bool "Calxeda Highbank" @@ -630,14 +630,14 @@ config ARCH_INTEGRATOR
config ARCH_KEYSTONE bool "TI Keystone" + select CMD_POWEROFF select CPU_V7A select SUPPORT_SPL - select SYS_THUMB_BUILD - select CMD_POWEROFF select SYS_ARCH_TIMER + select SYS_THUMB_BUILD imply CMD_MTDPARTS - imply FIT imply CMD_SAVES + imply FIT
config ARCH_OMAP2PLUS bool "TI OMAP2+" @@ -690,12 +690,12 @@ config ARCH_MX7ULP
config ARCH_MX7 bool "Freescale MX7" + select ARCH_MISC_INIT + select BOARD_EARLY_INIT_F select CPU_V7A select SYS_FSL_HAS_SEC if SECURE_BOOT select SYS_FSL_SEC_COMPAT_4 select SYS_FSL_SEC_LE - select BOARD_EARLY_INIT_F - select ARCH_MISC_INIT imply MXC_GPIO
config ARCH_MX6 @@ -714,8 +714,8 @@ endif
config ARCH_MX5 bool "Freescale MX5" - select CPU_V7A select BOARD_EARLY_INIT_F + select CPU_V7A imply MXC_GPIO
config ARCH_OWL @@ -734,9 +734,9 @@ config ARCH_QEMU
config ARCH_RMOBILE bool "Renesas ARM SoCs" + select BOARD_EARLY_INIT_F select DM select DM_SERIAL - select BOARD_EARLY_INIT_F imply FAT_WRITE imply SYS_THUMB_BUILD
@@ -751,30 +751,32 @@ config ARCH_SNAPDRAGON select DM select DM_GPIO select DM_SERIAL - select SPMI + select MSM_SMEM select OF_CONTROL select OF_SEPARATE select SMEM - select MSM_SMEM + select SPMI
config ARCH_SOCFPGA bool "Altera SOCFPGA family" select ARCH_EARLY_INIT_R select ARCH_MISC_INIT + select ARM64 if TARGET_SOCFPGA_STRATIX10 select CPU_V7A if TARGET_SOCFPGA_GEN5 || TARGET_SOCFPGA_ARRIA10 select DM select DM_SERIAL select ENABLE_ARM_SOC_BOOT0_HOOK if TARGET_SOCFPGA_GEN5 || TARGET_SOCFPGA_ARRIA10 select OF_CONTROL + select SPL_DM_SERIAL select SPL_LIBCOMMON_SUPPORT select SPL_LIBDISK_SUPPORT select SPL_LIBGENERIC_SUPPORT select SPL_MMC_SUPPORT if DM_MMC select SPL_NAND_SUPPORT if SPL_NAND_DENALI select SPL_OF_CONTROL - select SPL_SERIAL_SUPPORT - select SPL_DM_SERIAL select SPL_RESET_SUPPORT + select SPL_SEPARATE_BSS if TARGET_SOCFPGA_STRATIX10 + select SPL_SERIAL_SUPPORT select SPL_SPI_FLASH_SUPPORT if SPL_SPI_SUPPORT select SPL_SPI_SUPPORT if DM_SPI select SPL_WATCHDOG_SUPPORT @@ -782,14 +784,12 @@ config ARCH_SOCFPGA select SYS_MMCSD_RAW_MODE_U_BOOT_USE_PARTITION_TYPE select SYS_NS16550 select SYS_THUMB_BUILD if TARGET_SOCFPGA_GEN5 || TARGET_SOCFPGA_ARRIA10 - select ARM64 if TARGET_SOCFPGA_STRATIX10 imply CMD_MTDPARTS imply CRC32_VERIFY imply DM_SPI imply DM_SPI_FLASH imply FAT_WRITE imply SYS_MMCSD_RAW_MODE_U_BOOT_USE_PARTITION - select SPL_SEPARATE_BSS if TARGET_SOCFPGA_STRATIX10
config ARCH_SUNXI bool "Support sunxi (Allwinner) SoCs" @@ -809,12 +809,12 @@ config ARCH_SUNXI select SPECIFY_CONSOLE_INDEX select SPL_STACK_R if SPL select SPL_SYS_MALLOC_SIMPLE if SPL - select SYS_NS16550 select SPL_SYS_THUMB_BUILD if !ARM64 + select SYS_NS16550 select SYS_THUMB_BUILD if !ARM64 select USB if DISTRO_DEFAULTS - select USB_STORAGE if DISTRO_DEFAULTS select USB_KEYBOARD if DISTRO_DEFAULTS + select USB_STORAGE if DISTRO_DEFAULTS select USE_TINY_PRINTF imply CMD_GPT imply DISTRO_DEFAULTS @@ -839,51 +839,51 @@ config ARCH_VF610
config ARCH_ZYNQ bool "Xilinx Zynq based platform" + select BOARD_EARLY_INIT_F if WDT select BOARD_LATE_INIT + select CLK + select CLK_ZYNQ select CPU_V7A - select SUPPORT_SPL - select OF_CONTROL - select SPL_BOARD_INIT if SPL - select BOARD_EARLY_INIT_F if WDT - select SPL_OF_CONTROL if SPL select DM select DM_ETH if NET - select SPL_DM if SPL select DM_MMC if MMC - select DM_SPI select DM_SERIAL + select DM_SPI select DM_SPI_FLASH - select SPL_SEPARATE_BSS if SPL select DM_USB if USB - select CLK - select SPL_CLK if SPL - select CLK_ZYNQ + select OF_CONTROL select SPI + select SPL_BOARD_INIT if SPL + select SPL_CLK if SPL + select SPL_DM if SPL + select SPL_OF_CONTROL if SPL + select SPL_SEPARATE_BSS if SPL + select SUPPORT_SPL + imply ARCH_EARLY_INIT_R imply CMD_CLK - imply FAT_WRITE imply CMD_SPL - imply ARCH_EARLY_INIT_R + imply FAT_WRITE
config ARCH_ZYNQMP_R5 bool "Xilinx ZynqMP R5 based platform" + select CLK select CPU_V7R - select OF_CONTROL select DM select DM_SERIAL - select CLK + select OF_CONTROL
config ARCH_ZYNQMP bool "Xilinx ZynqMP based platform" select ARM64 select BOARD_LATE_INIT + select CLK select DM - select OF_CONTROL select DM_SERIAL - select SUPPORT_SPL - select CLK + select DM_USB if USB + select OF_CONTROL select SPL_BOARD_INIT if SPL select SPL_CLK if SPL - select DM_USB if USB + select SUPPORT_SPL imply FAT_WRITE
config TEGRA @@ -899,8 +899,8 @@ config TARGET_VEXPRESS64_AEMV8A config TARGET_VEXPRESS64_BASE_FVP bool "Support Versatile Express ARMv8a FVP BASE model" select ARM64 - select SEMIHOSTING select PL01X_SERIAL + select SEMIHOSTING
config TARGET_VEXPRESS64_BASE_FVP_DRAM bool "Support Versatile Express ARMv8a FVP BASE model booting from DRAM" @@ -920,9 +920,9 @@ config TARGET_VEXPRESS64_JUNO config TARGET_LS2080A_EMU bool "Support ls2080a_emu" select ARCH_LS2080A + select ARCH_MISC_INIT select ARM64 select ARMV8_MULTIENTRY - select ARCH_MISC_INIT help Support for Freescale LS2080A_EMU platform The LS2080A Development System (EMULATOR) is a pre silicon @@ -932,9 +932,9 @@ config TARGET_LS2080A_EMU config TARGET_LS2080A_SIMU bool "Support ls2080a_simu" select ARCH_LS2080A + select ARCH_MISC_INIT select ARM64 select ARMV8_MULTIENTRY - select ARCH_MISC_INIT help Support for Freescale LS2080A_SIMU platform The LS2080A Development System (QDS) is a pre silicon @@ -944,9 +944,9 @@ config TARGET_LS2080A_SIMU config TARGET_LS1088AQDS bool "Support ls1088aqds" select ARCH_LS1088A + select ARCH_MISC_INIT select ARM64 select ARMV8_MULTIENTRY - select ARCH_MISC_INIT select BOARD_LATE_INIT select SUPPORT_SPL help @@ -958,11 +958,11 @@ config TARGET_LS1088AQDS config TARGET_LS2080AQDS bool "Support ls2080aqds" select ARCH_LS2080A + select ARCH_MISC_INIT select ARM64 select ARMV8_MULTIENTRY select BOARD_LATE_INIT select SUPPORT_SPL - select ARCH_MISC_INIT imply SCSI imply SCSI_AHCI help @@ -974,11 +974,11 @@ config TARGET_LS2080AQDS config TARGET_LS2080ARDB bool "Support ls2080ardb" select ARCH_LS2080A + select ARCH_MISC_INIT select ARM64 select ARMV8_MULTIENTRY select BOARD_LATE_INIT select SUPPORT_SPL - select ARCH_MISC_INIT imply SCSI imply SCSI_AHCI help @@ -990,11 +990,11 @@ config TARGET_LS2080ARDB config TARGET_LS2081ARDB bool "Support ls2081ardb" select ARCH_LS2080A + select ARCH_MISC_INIT select ARM64 select ARMV8_MULTIENTRY select BOARD_LATE_INIT select SUPPORT_SPL - select ARCH_MISC_INIT help Support for Freescale LS2081ARDB platform. The LS2081A Reference design board (RDB) is a high-performance @@ -1018,9 +1018,9 @@ config TARGET_POPLAR bool "Support Poplar 96boards Enterprise Edition Platform" select ARM64 select DM - select OF_CONTROL select DM_SERIAL select DM_USB + select OF_CONTROL select PL01X_SERIAL help Support for Poplar 96boards EE platform. It features a HI3798cv200 @@ -1067,8 +1067,8 @@ config TARGET_LS1012A2G5RDB config TARGET_LS1012AFRWY bool "Support ls1012afrwy" select ARCH_LS1012A - select BOARD_LATE_INIT select ARM64 + select BOARD_LATE_INIT imply SCSI imply SCSI_AHCI help @@ -1090,9 +1090,9 @@ config TARGET_LS1012AFRDM config TARGET_LS1088ARDB bool "Support ls1088ardb" select ARCH_LS1088A + select ARCH_MISC_INIT select ARM64 select ARMV8_MULTIENTRY - select ARCH_MISC_INIT select BOARD_LATE_INIT select SUPPORT_SPL help @@ -1103,40 +1103,40 @@ config TARGET_LS1088ARDB
config TARGET_LS1021AQDS bool "Support ls1021aqds" + select ARCH_LS1021A + select ARCH_SUPPORT_PSCI + select BOARD_EARLY_INIT_F select BOARD_LATE_INIT select CPU_V7A select CPU_V7_HAS_NONSEC select CPU_V7_HAS_VIRT - select SUPPORT_SPL - select ARCH_LS1021A - select ARCH_SUPPORT_PSCI select LS1_DEEP_SLEEP + select SUPPORT_SPL select SYS_FSL_DDR - select BOARD_EARLY_INIT_F imply SCSI
config TARGET_LS1021ATWR bool "Support ls1021atwr" + select ARCH_LS1021A + select ARCH_SUPPORT_PSCI + select BOARD_EARLY_INIT_F select BOARD_LATE_INIT select CPU_V7A select CPU_V7_HAS_NONSEC select CPU_V7_HAS_VIRT - select SUPPORT_SPL - select ARCH_LS1021A - select ARCH_SUPPORT_PSCI select LS1_DEEP_SLEEP - select BOARD_EARLY_INIT_F + select SUPPORT_SPL imply SCSI
config TARGET_LS1021AIOT bool "Support ls1021aiot" + select ARCH_LS1021A + select ARCH_SUPPORT_PSCI select BOARD_LATE_INIT select CPU_V7A select CPU_V7_HAS_NONSEC select CPU_V7_HAS_VIRT select SUPPORT_SPL - select ARCH_LS1021A - select ARCH_SUPPORT_PSCI imply SCSI help Support for Freescale LS1021AIOT platform. @@ -1149,9 +1149,9 @@ config TARGET_LS1043AQDS select ARCH_LS1043A select ARM64 select ARMV8_MULTIENTRY + select BOARD_EARLY_INIT_F select BOARD_LATE_INIT select SUPPORT_SPL - select BOARD_EARLY_INIT_F imply SCSI help Support for Freescale LS1043AQDS platform. @@ -1161,9 +1161,9 @@ config TARGET_LS1043ARDB select ARCH_LS1043A select ARM64 select ARMV8_MULTIENTRY + select BOARD_EARLY_INIT_F select BOARD_LATE_INIT select SUPPORT_SPL - select BOARD_EARLY_INIT_F imply SCSI help Support for Freescale LS1043ARDB platform. @@ -1173,10 +1173,10 @@ config TARGET_LS1046AQDS select ARCH_LS1046A select ARM64 select ARMV8_MULTIENTRY + select BOARD_EARLY_INIT_F select BOARD_LATE_INIT - select SUPPORT_SPL select DM_SPI_FLASH if DM_SPI - select BOARD_EARLY_INIT_F + select SUPPORT_SPL imply SCSI help Support for Freescale LS1046AQDS platform. @@ -1189,11 +1189,11 @@ config TARGET_LS1046ARDB select ARCH_LS1046A select ARM64 select ARMV8_MULTIENTRY + select BOARD_EARLY_INIT_F select BOARD_LATE_INIT - select SUPPORT_SPL select DM_SPI_FLASH if DM_SPI select POWER_MC34VR500 - select BOARD_EARLY_INIT_F + select SUPPORT_SPL imply SCSI help Support for Freescale LS1046ARDB platform. @@ -1247,12 +1247,12 @@ config STM32
config ARCH_STI bool "Support STMicrolectronics SoCs" + select BLK select CPU_V7A select DM - select DM_SERIAL - select BLK select DM_MMC select DM_RESET + select DM_SERIAL help Support for STMicroelectronics STiH407/10 SoC family. This SoC is used on Linaro 96Board STiH410-B2260 @@ -1266,9 +1266,9 @@ config ARCH_STM32MP select DM_GPIO select DM_RESET select DM_SERIAL + select MISC select OF_CONTROL select OF_LIBFDT - select MISC select PINCTRL select REGMAP select SUPPORT_SPL @@ -1283,44 +1283,44 @@ config ARCH_STM32MP
config ARCH_ROCKCHIP bool "Support Rockchip SoCs" - select OF_CONTROL select BLK select DM - select SPL_DM if SPL - select SYS_MALLOC_F - select SYS_THUMB_BUILD if !ARM64 - select SPL_SYS_MALLOC_SIMPLE if SPL select DM_GPIO select DM_I2C select DM_MMC + select DM_PWM + select DM_REGULATOR select DM_SERIAL select DM_SPI select DM_SPI_FLASH select DM_USB if USB - select DM_PWM - select DM_REGULATOR select ENABLE_ARM_SOC_BOOT0_HOOK + select OF_CONTROL select SPI + select SPL_DM if SPL + select SPL_SYS_MALLOC_SIMPLE if SPL + select SYS_MALLOC_F + select SYS_THUMB_BUILD if !ARM64 + imply ADC imply DISTRO_DEFAULTS imply FAT_WRITE - imply USB_FUNCTION_FASTBOOT - imply SPL_SYSRESET - imply TPL_SYSRESET - imply ADC imply SARADC_ROCKCHIP + imply SPL_SYSRESET imply SYS_NS16550 + imply TPL_SYSRESET + imply USB_FUNCTION_FASTBOOT
config TARGET_THUNDERX_88XX bool "Support ThunderX 88xx" select ARM64 select OF_CONTROL - select SYS_CACHE_SHIFT_7 select PL01X_SERIAL + select SYS_CACHE_SHIFT_7
config ARCH_ASPEED bool "Support Aspeed SoCs" - select OF_CONTROL select DM + select OF_CONTROL
endchoice
diff --git a/arch/arm/mach-at91/Kconfig b/arch/arm/mach-at91/Kconfig index ce6be3829afe..1a56957cf9d1 100644 --- a/arch/arm/mach-at91/Kconfig +++ b/arch/arm/mach-at91/Kconfig @@ -76,18 +76,18 @@ config TARGET_SNAPPER9260 bool "Support snapper9260" select AT91SAM9260 select DM - select DM_SERIAL select DM_GPIO + select DM_SERIAL
config TARGET_GURNARD bool "Support gurnard" select AT91SAM9G45 select BOARD_LATE_INIT select DM + select DM_ETH + select DM_GPIO select DM_SERIAL select DM_SPI - select DM_GPIO - select DM_ETH select SPI
config TARGET_AT91SAM9261EK @@ -115,8 +115,8 @@ config TARGET_PM9263 config TARGET_AT91SAM9M10G45EK bool "Atmel AT91SAM9M10G45-EK board" select AT91SAM9M10G45 - select SUPPORT_SPL select BOARD_EARLY_INIT_F + select SUPPORT_SPL
config TARGET_PM9G45 bool "Ronetix pm9g45 board" @@ -130,8 +130,8 @@ config TARGET_PICOSAM9G45 config TARGET_AT91SAM9N12EK bool "Atmel AT91SAM9N12-EK board" select AT91SAM9N12 - select SUPPORT_SPL select BOARD_EARLY_INIT_F + select SUPPORT_SPL
config TARGET_AT91SAM9RLEK bool "Atmel at91sam9rl reference board" @@ -141,28 +141,28 @@ config TARGET_AT91SAM9RLEK config TARGET_AT91SAM9X5EK bool "Atmel AT91SAM9X5-EK board" select AT91SAM9X5 - select SUPPORT_SPL select BOARD_EARLY_INIT_F select BOARD_LATE_INIT + select SUPPORT_SPL
config TARGET_SAMA5D2_PTC_EK bool "SAMA5D2 PTC EK board" - select SAMA5D2 select BOARD_EARLY_INIT_F + select SAMA5D2
config TARGET_SAMA5D2_XPLAINED bool "SAMA5D2 Xplained board" - select SAMA5D2 - select SUPPORT_SPL select BOARD_EARLY_INIT_F select BOARD_LATE_INIT + select SAMA5D2 + select SUPPORT_SPL
config TARGET_SAMA5D27_SOM1_EK bool "SAMA5D27 SOM1 EK board" - select CPU_V7A - select SUPPORT_SPL select BOARD_EARLY_INIT_F select BOARD_LATE_INIT + select CPU_V7A + select SUPPORT_SPL help The SAMA5D27 SOM1 embeds SAMA5D2 SiP(System in Package), a 64Mbit QSPI flash, KSZ8081 Phy and a Mac-address EEPROM @@ -172,30 +172,30 @@ config TARGET_SAMA5D27_SOM1_EK
config TARGET_SAMA5D3_XPLAINED bool "SAMA5D3 Xplained board" + select BOARD_EARLY_INIT_F select SAMA5D3 select SUPPORT_SPL - select BOARD_EARLY_INIT_F
config TARGET_SAMA5D3XEK bool "SAMA5D3X-EK board" - select SAMA5D3 + select BOARD_EARLY_INIT_F select BOARD_LATE_INIT + select SAMA5D3 select SUPPORT_SPL - select BOARD_EARLY_INIT_F
config TARGET_SAMA5D4_XPLAINED bool "SAMA5D4 Xplained board" - select SAMA5D4 - select SUPPORT_SPL select BOARD_EARLY_INIT_F select BOARD_LATE_INIT + select SAMA5D4 + select SUPPORT_SPL
config TARGET_SAMA5D4EK bool "SAMA5D4 Evaluation Kit" - select SAMA5D4 - select SUPPORT_SPL select BOARD_EARLY_INIT_F select BOARD_LATE_INIT + select SAMA5D4 + select SUPPORT_SPL
config TARGET_MEESC bool "Support meesc" @@ -204,39 +204,39 @@ config TARGET_MEESC config TARGET_CORVUS bool "Support corvus" select AT91SAM9M10G45 - select SUPPORT_SPL select DM - select DM_SERIAL - select DM_GPIO select DM_ETH + select DM_GPIO + select DM_SERIAL + select SUPPORT_SPL
config TARGET_TAURUS bool "Support taurus" select AT91SAM9G20 - select SUPPORT_SPL select DM + select DM_ETH + select DM_GPIO select DM_SERIAL select DM_SPI - select DM_GPIO - select DM_ETH select SPI + select SUPPORT_SPL
config TARGET_SMARTWEB bool "Support smartweb" select AT91SAM9260 - select SUPPORT_SPL select DM - select DM_SERIAL - select DM_GPIO select DM_ETH + select DM_GPIO + select DM_SERIAL + select SUPPORT_SPL
config TARGET_VINCO bool "Support VINCO" - select SAMA5D4 - select SUPPORT_SPL select DM select DM_SPI + select SAMA5D4 select SPI + select SUPPORT_SPL
config TARGET_WB45N bool "Support Laird WB45N" @@ -245,10 +245,10 @@ config TARGET_WB45N
config TARGET_WB50N bool "Support Laird WB50N" + select BOARD_EARLY_INIT_F select BOARD_LATE_INIT select CPU_V7A select SUPPORT_SPL - select BOARD_EARLY_INIT_F
endchoice
diff --git a/arch/arm/mach-imx/mx5/Kconfig b/arch/arm/mach-imx/mx5/Kconfig index 3654670442fb..1bb373bf2d1c 100644 --- a/arch/arm/mach-imx/mx5/Kconfig +++ b/arch/arm/mach-imx/mx5/Kconfig @@ -1,14 +1,14 @@ if ARCH_MX5
config MX5 - select GPT_TIMER bool default y + select GPT_TIMER
config MX51 bool - select SYS_FSL_ERRATUM_ESDHC_A001 select ARM_CORTEX_A8_CVE_2017_5715 + select SYS_FSL_ERRATUM_ESDHC_A001
config MX53 bool @@ -21,13 +21,13 @@ choice config TARGET_KP_IMX53 bool "Support K+P imx53 board" select BOARD_LATE_INIT - select MX53 select DM - select DM_SERIAL select DM_ETH - select DM_I2C select DM_GPIO + select DM_I2C select DM_PMIC + select DM_SERIAL + select MX53
config TARGET_MX51EVK bool "Support mx51evk" @@ -41,9 +41,9 @@ config TARGET_MX53ARD config TARGET_MX53CX9020 bool "Support CX9020" select BOARD_LATE_INIT - select MX53 select DM select DM_SERIAL + select MX53
config TARGET_MX53EVK bool "Support mx53evk" diff --git a/arch/arm/mach-imx/mx6/Kconfig b/arch/arm/mach-imx/mx6/Kconfig index b7b77cc51b97..5cce9ce23c0e 100644 --- a/arch/arm/mach-imx/mx6/Kconfig +++ b/arch/arm/mach-imx/mx6/Kconfig @@ -1,89 +1,89 @@ if ARCH_MX6
config MX6_SMP + bool select ARM_ERRATA_751472 select ARM_ERRATA_761320 select ARM_ERRATA_794072 select ARM_ERRATA_845369 select MP - bool
config MX6 - select ARM_ERRATA_743622 if !MX6UL && !MX6ULL - select GPT_TIMER if !MX6UL && !MX6ULL bool default y + select ARM_ERRATA_743622 if !MX6UL && !MX6ULL + select GPT_TIMER if !MX6UL && !MX6ULL imply CMD_FUSE
config MX6D + bool select HAS_CAAM select MX6_SMP - bool
config MX6DL + bool select HAS_CAAM select MX6_SMP - bool
config MX6Q + bool select HAS_CAAM select MX6_SMP - bool
config MX6QDL + bool select HAS_CAAM select MX6_SMP - bool
config MX6S - select HAS_CAAM bool + select HAS_CAAM
config MX6SL bool
config MX6SX + bool select HAS_CAAM select ROM_UNIFIED_SECTIONS - bool
config MX6SLL - select ROM_UNIFIED_SECTIONS bool + select ROM_UNIFIED_SECTIONS
config MX6UL + bool select HAS_CAAM - select SYS_L2CACHE_OFF select ROM_UNIFIED_SECTIONS select SYSCOUNTER_TIMER - bool + select SYS_L2CACHE_OFF
config MX6UL_LITESOM bool - select MX6UL select DM select DM_THERMAL + select MX6UL select SUPPORT_SPL
config MX6UL_OPOS6UL bool - select MX6UL select BOARD_LATE_INIT select DM select DM_GPIO select DM_MMC select DM_THERMAL - select SUPPORT_SPL + select MX6UL select SPL_DM if SPL select SPL_OF_CONTROL if SPL - select SPL_SEPARATE_BSS if SPL select SPL_PINCTRL if SPL + select SPL_SEPARATE_BSS if SPL + select SUPPORT_SPL
config MX6ULL - select SYS_L2CACHE_OFF + bool select ROM_UNIFIED_SECTIONS select SYSCOUNTER_TIMER - bool + select SYS_L2CACHE_OFF
config MX6_DDRCAL bool "Include dynamic DDR calibration routines" @@ -106,10 +106,10 @@ config TARGET_ADVANTECH_DMS_BA16 config TARGET_APALIS_IMX6 bool "Toradex Apalis iMX6 board" select BOARD_LATE_INIT - select SUPPORT_SPL select DM select DM_SERIAL select DM_THERMAL + select SUPPORT_SPL imply CMD_SATA
config TARGET_ARISTAINETOS @@ -125,44 +125,44 @@ config TARGET_ARISTAINETOS2B
config TARGET_CGTQMX6EVAL bool "cgtqmx6eval" - select MX6QDL select BOARD_LATE_INIT - select SUPPORT_SPL select DM select DM_THERMAL + select MX6QDL + select SUPPORT_SPL
config TARGET_CM_FX6 bool "CM-FX6" - select SUPPORT_SPL - select MX6QDL select BOARD_LATE_INIT select DM - select DM_SERIAL select DM_GPIO + select DM_SERIAL + select MX6QDL + select SUPPORT_SPL
config TARGET_COLIBRI_IMX6 bool "Toradex Colibri iMX6 board" select BOARD_LATE_INIT - select SUPPORT_SPL select DM select DM_SERIAL select DM_THERMAL + select SUPPORT_SPL
config TARGET_DHCOMIMX6 bool "dh_imx6" - select MX6QDL - select BOARD_LATE_INIT select BOARD_EARLY_INIT_F - select SUPPORT_SPL + select BOARD_LATE_INIT select DM select DM_THERMAL + select MX6QDL + select SUPPORT_SPL imply CMD_SPL
config TARGET_DISPLAY5 bool "LWN DISPLAY5 board" - select SUPPORT_SPL select DM select DM_SERIAL + select SUPPORT_SPL
config TARGET_EMBESTMX6BOARDS bool "embestmx6boards" @@ -192,8 +192,8 @@ config TARGET_MCCMON6
config TARGET_MX6CUBOXI bool "Solid-run mx6 boards" - select MX6QDL select BOARD_LATE_INIT + select MX6QDL select SUPPORT_SPL
config TARGET_MX6LOGICPD @@ -222,9 +222,6 @@ config TARGET_MX6QARM2
config TARGET_MX6DL_MAMOJ bool "Support BTicino Mamoj" - select MX6QDL - select OF_CONTROL - select PINCTRL select DM select DM_ETH select DM_GPIO @@ -233,59 +230,62 @@ config TARGET_MX6DL_MAMOJ select DM_PMIC select DM_PMIC_PFUZE100 select DM_THERMAL + select MX6QDL + select OF_CONTROL + select PINCTRL select SPL - select SUPPORT_SPL select SPL_DM if SPL - select SPL_OF_LIBFDT if SPL - select SPL_OF_CONTROL if SPL - select SPL_PINCTRL if SPL - select SPL_SEPARATE_BSS if SPL select SPL_GPIO_SUPPORT if SPL select SPL_LIBCOMMON_SUPPORT if SPL select SPL_LIBDISK_SUPPORT if SPL select SPL_LIBGENERIC_SUPPORT if SPL select SPL_MMC_SUPPORT if SPL + select SPL_OF_CONTROL if SPL + select SPL_OF_LIBFDT if SPL + select SPL_PINCTRL if SPL + select SPL_SEPARATE_BSS if SPL select SPL_SERIAL_SUPPORT if SPL - select SPL_USB_HOST_SUPPORT if SPL select SPL_USB_GADGET_SUPPORT if SPL + select SPL_USB_HOST_SUPPORT if SPL select SPL_USB_SDP_SUPPORT if SPL select SPL_WATCHDOG_SUPPORT if SPL + select SUPPORT_SPL
config TARGET_MX6Q_ENGICAM bool "Support Engicam i.Core(RQS)" select BOARD_LATE_INIT - select MX6QDL - select OF_CONTROL - select SPL_OF_LIBFDT select DM select DM_ETH select DM_GPIO select DM_I2C select DM_MMC select DM_THERMAL - select SUPPORT_SPL + select MX6QDL + select OF_CONTROL select SPL_DM if SPL select SPL_OF_CONTROL if SPL - select SPL_SEPARATE_BSS if SPL + select SPL_OF_LIBFDT select SPL_PINCTRL if SPL + select SPL_SEPARATE_BSS if SPL + select SUPPORT_SPL
config TARGET_MX6SABREAUTO bool "mx6sabreauto" - select MX6QDL + select BOARD_EARLY_INIT_F select BOARD_LATE_INIT - select SUPPORT_SPL select DM select DM_THERMAL - select BOARD_EARLY_INIT_F + select MX6QDL + select SUPPORT_SPL
config TARGET_MX6SABRESD bool "mx6sabresd" - select MX6QDL + select BOARD_EARLY_INIT_F select BOARD_LATE_INIT - select SUPPORT_SPL select DM select DM_THERMAL - select BOARD_EARLY_INIT_F + select MX6QDL + select SUPPORT_SPL
config TARGET_MX6SLEVK bool "mx6slevk" @@ -295,73 +295,73 @@ config TARGET_MX6SLEVK config TARGET_MX6SLLEVK bool "mx6sll evk" select BOARD_LATE_INIT - select MX6SLL select DM select DM_THERMAL + select MX6SLL
config TARGET_MX6SXSABRESD bool "mx6sxsabresd" + select BOARD_EARLY_INIT_F select BOARD_LATE_INIT - select MX6SX - select SUPPORT_SPL select DM select DM_THERMAL - select BOARD_EARLY_INIT_F + select MX6SX + select SUPPORT_SPL
config TARGET_MX6SXSABREAUTO bool "mx6sxsabreauto" + select BOARD_EARLY_INIT_F select BOARD_LATE_INIT - select MX6SX select DM select DM_THERMAL - select BOARD_EARLY_INIT_F + select MX6SX
config TARGET_MX6UL_9X9_EVK bool "mx6ul_9x9_evk" select BOARD_LATE_INIT - select MX6UL select DM select DM_THERMAL + select MX6UL select SUPPORT_SPL
config TARGET_MX6UL_14X14_EVK - select BOARD_LATE_INIT bool "mx6ul_14x14_evk" - select MX6UL + select BOARD_LATE_INIT select DM select DM_THERMAL + select MX6UL select SUPPORT_SPL
config TARGET_MX6UL_ENGICAM bool "Support Engicam GEAM6UL/Is.IoT" select BOARD_LATE_INIT - select MX6UL - select OF_CONTROL select DM select DM_ETH select DM_GPIO select DM_I2C select DM_MMC select DM_THERMAL - select SUPPORT_SPL + select MX6UL + select OF_CONTROL select SPL_DM if SPL select SPL_OF_CONTROL if SPL - select SPL_SEPARATE_BSS if SPL select SPL_PINCTRL if SPL + select SPL_SEPARATE_BSS if SPL + select SUPPORT_SPL
config TARGET_MX6ULL_14X14_EVK bool "Support mx6ull_14x14_evk" select BOARD_LATE_INIT - select MX6ULL select DM select DM_THERMAL + select MX6ULL
config TARGET_NITROGEN6X bool "nitrogen6x" - imply USB_HOST_ETHER imply USB_ETHER_ASIX - imply USB_ETHER_SMSC95XX imply USB_ETHER_MCS7830 + imply USB_ETHER_SMSC95XX + imply USB_HOST_ETHER
config TARGET_OPOS6ULDEV bool "Armadeus OPOS6ULDev board" @@ -396,8 +396,8 @@ config TARGET_PCM058
config TARGET_PFLA02 bool "Phytec PFLA02 (PhyFlex) i.MX6 Quad" - select MX6QDL select BOARD_LATE_INIT + select MX6QDL select SUPPORT_SPL
config TARGET_SECOMX6 @@ -415,12 +415,12 @@ config TARGET_TITANIUM
config TARGET_KP_IMX6Q_TPC bool "K+P KP_IMX6Q_TPC i.MX6 Quad" - select MX6QDL - select BOARD_LATE_INIT select BOARD_EARLY_INIT_F - select SUPPORT_SPL + select BOARD_LATE_INIT select DM select DM_THERMAL + select MX6QDL + select SUPPORT_SPL imply CMD_SPL
config TARGET_TQMA6 @@ -429,57 +429,57 @@ config TARGET_TQMA6
config TARGET_UDOO bool "udoo" - select MX6QDL select BOARD_LATE_INIT + select MX6QDL select SUPPORT_SPL
config TARGET_UDOO_NEO bool "UDOO Neo" select BOARD_LATE_INIT - select SUPPORT_SPL - select MX6SX select DM select DM_THERMAL + select MX6SX + select SUPPORT_SPL
config TARGET_SAMTEC_VINING_2000 bool "samtec VIN|ING 2000" select BOARD_LATE_INIT - select MX6SX select DM select DM_THERMAL + select MX6SX
config TARGET_WANDBOARD bool "wandboard" - select MX6QDL select BOARD_LATE_INIT + select MX6QDL select SUPPORT_SPL
config TARGET_WARP bool "WaRP" - select MX6SL select BOARD_LATE_INIT + select MX6SL
config TARGET_XPRESS bool "CCV xPress" select BOARD_LATE_INIT - select MX6UL select DM select DM_THERMAL + select MX6UL select SUPPORT_SPL
config TARGET_ZC5202 bool "zc5202" select BOARD_LATE_INIT - select SUPPORT_SPL select DM select DM_THERMAL + select SUPPORT_SPL
config TARGET_ZC5601 bool "zc5601" select BOARD_LATE_INIT - select SUPPORT_SPL select DM select DM_THERMAL + select SUPPORT_SPL
endchoice
diff --git a/arch/arm/mach-imx/mx7/Kconfig b/arch/arm/mach-imx/mx7/Kconfig index 2a3db860bbcf..f618a7bb9d1f 100644 --- a/arch/arm/mach-imx/mx7/Kconfig +++ b/arch/arm/mach-imx/mx7/Kconfig @@ -2,19 +2,19 @@ if ARCH_MX7
config MX7 bool + default y + select ARCH_SUPPORT_PSCI + select CPU_V7_HAS_NONSEC + select CPU_V7_HAS_VIRT select ROM_UNIFIED_SECTIONS select SYSCOUNTER_TIMER - select CPU_V7_HAS_VIRT - select CPU_V7_HAS_NONSEC - select ARCH_SUPPORT_PSCI imply CMD_FUSE - default y
config MX7D + bool select HAS_CAAM select ROM_UNIFIED_SECTIONS imply CMD_FUSE - bool
choice prompt "MX7 board select" @@ -22,31 +22,31 @@ choice
config TARGET_CL_SOM_IMX7 bool "CL-SOM-iMX7" - select MX7D select DM select DM_THERMAL + select MX7D select SUPPORT_SPL
config TARGET_MX7DSABRESD bool "mx7dsabresd" select BOARD_LATE_INIT - select MX7D select DM select DM_THERMAL + select MX7D
config TARGET_PICO_IMX7D bool "pico-imx7d" select BOARD_LATE_INIT - select MX7D select DM select DM_THERMAL + select MX7D
config TARGET_WARP7 bool "warp7" select BOARD_LATE_INIT - select MX7D select DM select DM_THERMAL + select MX7D
config TARGET_COLIBRI_IMX7 bool "Support Colibri iMX7S/iMX7D modules" diff --git a/arch/arm/mach-omap2/am33xx/Kconfig b/arch/arm/mach-omap2/am33xx/Kconfig index 76da6d911ed6..94d9d868f893 100644 --- a/arch/arm/mach-omap2/am33xx/Kconfig +++ b/arch/arm/mach-omap2/am33xx/Kconfig @@ -31,9 +31,11 @@ config TARGET_AM335X_EVM bool "Support am335x_evm" select BOARD_LATE_INIT select DM - select DM_SERIAL select DM_GPIO + select DM_SERIAL select TI_I2C_BOARD_DETECT + imply SPL_DM + imply SPL_DM_SEQ_ALIAS imply SPL_ENV_SUPPORT imply SPL_EXT_SUPPORT imply SPL_FAT_SUPPORT @@ -44,15 +46,13 @@ config TARGET_AM335X_EVM imply SPL_LIBGENERIC_SUPPORT imply SPL_MMC_SUPPORT imply SPL_NAND_SUPPORT + imply SPL_OF_LIBFDT imply SPL_POWER_SUPPORT + imply SPL_SEPARATE_BSS imply SPL_SERIAL_SUPPORT + imply SPL_SYS_MALLOC_SIMPLE imply SPL_WATCHDOG_SUPPORT imply SPL_YMODEM_SUPPORT - imply SPL_SYS_MALLOC_SIMPLE - imply SPL_SEPARATE_BSS - imply SPL_DM - imply SPL_DM_SEQ_ALIAS - imply SPL_OF_LIBFDT help This option specifies support for the AM335x GP and HS EVM development platforms. The AM335x @@ -65,30 +65,30 @@ config TARGET_AM335X_BALTOS bool "Support am335x_baltos" select BOARD_LATE_INIT select DM - select DM_SERIAL select DM_GPIO + select DM_SERIAL
config TARGET_AM335X_IGEP003X bool "Support am335x_igep003x" select BOARD_LATE_INIT select DM - select DM_SERIAL select DM_GPIO + select DM_SERIAL
config TARGET_AM335X_SHC bool "Support am335x based shc board from bosch" select BOARD_LATE_INIT select DM - select DM_SERIAL select DM_GPIO + select DM_SERIAL imply CMD_SPL
config TARGET_AM335X_SL50 bool "Support am335x_sl50" select BOARD_LATE_INIT select DM - select DM_SERIAL select DM_GPIO + select DM_SERIAL
config TARGET_BAV335X bool "Support bav335x" @@ -122,68 +122,68 @@ config TARGET_CHILIBOARD config TARGET_CM_T335 bool "Support cm_t335" select DM - select DM_SERIAL select DM_GPIO + select DM_SERIAL
config TARGET_DRACO bool "Support draco" select BOARD_LATE_INIT select DM - select DM_SERIAL select DM_GPIO + select DM_SERIAL
config TARGET_ETAMIN bool "Support etamin" select BOARD_LATE_INIT select DM - select DM_SERIAL select DM_GPIO + select DM_SERIAL
config TARGET_PCM051 bool "Support pcm051" select DM - select DM_SERIAL select DM_GPIO + select DM_SERIAL
config TARGET_PENGWYN bool "Support pengwyn" select DM - select DM_SERIAL select DM_GPIO + select DM_SERIAL
config TARGET_PEPPER bool "Support pepper" select DM - select DM_SERIAL select DM_GPIO + select DM_SERIAL
config TARGET_PXM2 bool "Support pxm2" select BOARD_LATE_INIT select DM - select DM_SERIAL select DM_GPIO + select DM_SERIAL
config TARGET_RASTABAN bool "Support rastaban" select BOARD_LATE_INIT select DM - select DM_SERIAL select DM_GPIO + select DM_SERIAL
config TARGET_RUT bool "Support rut" select BOARD_LATE_INIT select DM - select DM_SERIAL select DM_GPIO + select DM_SERIAL
config TARGET_THUBAN bool "Support thuban" select BOARD_LATE_INIT select DM - select DM_SERIAL select DM_GPIO + select DM_SERIAL
config TARGET_PDU001 bool "Support PDU001" @@ -258,6 +258,8 @@ endif if AM43XX || AM33XX config ISW_ENTRY_ADDR hex "Address in memory or XIP flash of bootloader entry point" + default 0x402F4000 if AM43XX + default 0x402F0400 if AM33XX help After any reset, the boot ROM on the AM43XX SOC searches the boot media for a valid boot image. @@ -268,11 +270,10 @@ config ISW_ENTRY_ADDR point address depending on the device type (secure/non-secure), boot media (xip/non-xip) and image headers. - default 0x402F4000 if AM43XX - default 0x402F0400 if AM33XX
config PUB_ROM_DATA_SIZE hex "Size in bytes of the L3 SRAM reserved by ROM to store data" + default 0x8400 help During the device boot, the public ROM uses the top of the public L3 OCMC RAM to store r/w data like stack, @@ -283,5 +284,4 @@ config PUB_ROM_DATA_SIZE boot image. Once the ROM transfers control to the boot image, this area is no longer used, and can be reclaimed for run time use by the boot image. - default 0x8400 endif diff --git a/arch/arm/mach-omap2/omap3/Kconfig b/arch/arm/mach-omap2/omap3/Kconfig index 6d714f6cdb2c..9e4227d8266b 100644 --- a/arch/arm/mach-omap2/omap3/Kconfig +++ b/arch/arm/mach-omap2/omap3/Kconfig @@ -23,10 +23,10 @@ choice config TARGET_AM3517_EVM bool "AM3517 EVM" select DM - select DM_SERIAL select DM_GPIO select DM_I2C select DM_MMC + select DM_SERIAL
config TARGET_MT_VENTOUX bool "TeeJet Mt.Ventoux" @@ -36,8 +36,8 @@ config TARGET_MT_VENTOUX config TARGET_OMAP3_BEAGLE bool "TI OMAP3 BeagleBoard" select DM - select DM_SERIAL select DM_GPIO + select DM_SERIAL select OMAP3_GPIO_5 select OMAP3_GPIO_6
@@ -56,21 +56,21 @@ config TARGET_CM_T3517 config TARGET_DEVKIT8000 bool "TimLL OMAP3 Devkit8000" select DM - select DM_SERIAL select DM_GPIO + select DM_SERIAL
config TARGET_OMAP3_EVM bool "TI OMAP3 EVM" select DM - select DM_SERIAL select DM_GPIO + select DM_SERIAL select OMAP3_GPIO_3
config TARGET_OMAP3_IGEP00X0 bool "IGEP" select DM - select DM_SERIAL select DM_GPIO + select DM_SERIAL select OMAP3_GPIO_3 select OMAP3_GPIO_5 select OMAP3_GPIO_6 @@ -78,8 +78,8 @@ config TARGET_OMAP3_IGEP00X0 config TARGET_OMAP3_OVERO bool "OMAP35xx Gumstix Overo" select DM - select DM_SERIAL select DM_GPIO + select DM_SERIAL select OMAP3_GPIO_2 select OMAP3_GPIO_3 select OMAP3_GPIO_4 @@ -89,8 +89,8 @@ config TARGET_OMAP3_OVERO config TARGET_OMAP3_ZOOM1 bool "TI Zoom1" select DM - select DM_SERIAL select DM_GPIO + select DM_SERIAL
config TARGET_AM3517_CRANE bool "am3517_crane" @@ -118,8 +118,8 @@ config TARGET_OMAP3_LOGIC bool "OMAP3 Logic" select BOARD_LATE_INIT select DM - select DM_SERIAL select DM_GPIO + select DM_SERIAL select OMAP3_GPIO_3 select OMAP3_GPIO_4 select OMAP3_GPIO_6 @@ -143,14 +143,14 @@ config TARGET_TWISTER config TARGET_OMAP3_CAIRO bool "QUIPOS CAIRO" select DM - select DM_SERIAL select DM_GPIO + select DM_SERIAL
config TARGET_SNIPER bool "LG Optimus Black" select DM - select DM_SERIAL select DM_GPIO + select DM_SERIAL select OMAP3_GPIO_2 select OMAP3_GPIO_3 select OMAP3_GPIO_4 diff --git a/arch/arm/mach-rmobile/Kconfig.32 b/arch/arm/mach-rmobile/Kconfig.32 index c0b5b2457cb1..dc517350ee19 100644 --- a/arch/arm/mach-rmobile/Kconfig.32 +++ b/arch/arm/mach-rmobile/Kconfig.32 @@ -47,25 +47,25 @@ config TARGET_GOSE bool "Gose board" select DM select DM_SERIAL + select SPL_TINY_MEMSET select SUPPORT_SPL select USE_TINY_PRINTF - select SPL_TINY_MEMSET
config TARGET_KOELSCH bool "Koelsch board" select DM select DM_SERIAL + select SPL_TINY_MEMSET select SUPPORT_SPL select USE_TINY_PRINTF - select SPL_TINY_MEMSET
config TARGET_LAGER bool "Lager board" select DM select DM_SERIAL + select SPL_TINY_MEMSET select SUPPORT_SPL select USE_TINY_PRINTF - select SPL_TINY_MEMSET
config TARGET_KZM9G bool "KZM9D board" @@ -74,33 +74,33 @@ config TARGET_ALT bool "Alt board" select DM select DM_SERIAL + select SPL_TINY_MEMSET select SUPPORT_SPL select USE_TINY_PRINTF - select SPL_TINY_MEMSET
config TARGET_SILK bool "Silk board" select DM select DM_SERIAL + select SPL_TINY_MEMSET select SUPPORT_SPL select USE_TINY_PRINTF - select SPL_TINY_MEMSET
config TARGET_PORTER bool "Porter board" select DM select DM_SERIAL + select SPL_TINY_MEMSET select SUPPORT_SPL select USE_TINY_PRINTF - select SPL_TINY_MEMSET
config TARGET_STOUT bool "Stout board" select DM select DM_SERIAL + select SPL_TINY_MEMSET select SUPPORT_SPL select USE_TINY_PRINTF - select SPL_TINY_MEMSET
endchoice
diff --git a/arch/arm/mach-tegra/Kconfig b/arch/arm/mach-tegra/Kconfig index 0fb0c6339018..cd03705b64c0 100644 --- a/arch/arm/mach-tegra/Kconfig +++ b/arch/arm/mach-tegra/Kconfig @@ -22,6 +22,8 @@ config TEGRA_IVC
config TEGRA_COMMON bool "Tegra common options" + select BINMAN + select BOARD_EARLY_INIT_F select CLK select DM select DM_ETH @@ -35,11 +37,9 @@ config TEGRA_COMMON select DM_SPI select DM_SPI_FLASH select MISC - select SPI select OF_CONTROL + select SPI select VIDCONSOLE_AS_LCD if DM_VIDEO - select BOARD_EARLY_INIT_F - select BINMAN imply CRC32_VERIFY
config TEGRA_NO_BPMP @@ -98,8 +98,8 @@ config TEGRA124
config TEGRA210 bool "Tegra210 family" - select TEGRA_GPIO select TEGRA_ARMV8_COMMON + select TEGRA_GPIO select TEGRA_NO_BPMP
config TEGRA186 diff --git a/arch/microblaze/Kconfig b/arch/microblaze/Kconfig index c56459345136..1df1ecf72d19 100644 --- a/arch/microblaze/Kconfig +++ b/arch/microblaze/Kconfig @@ -11,10 +11,10 @@ choice config TARGET_MICROBLAZE_GENERIC bool "Support microblaze-generic" select BOARD_LATE_INIT - select SUPPORT_SPL - select OF_CONTROL select DM select DM_SERIAL + select OF_CONTROL + select SUPPORT_SPL select SYSRESET
endchoice diff --git a/arch/mips/Kconfig b/arch/mips/Kconfig index d07b92d1b442..315d89dbeb3f 100644 --- a/arch/mips/Kconfig +++ b/arch/mips/Kconfig @@ -14,13 +14,13 @@ choice
config TARGET_QEMU_MIPS bool "Support qemu-mips" + select ROM_EXCEPTION_VECTORS select SUPPORTS_BIG_ENDIAN - select SUPPORTS_LITTLE_ENDIAN select SUPPORTS_CPU_MIPS32_R1 select SUPPORTS_CPU_MIPS32_R2 select SUPPORTS_CPU_MIPS64_R1 select SUPPORTS_CPU_MIPS64_R2 - select ROM_EXCEPTION_VECTORS + select SUPPORTS_LITTLE_ENDIAN
config TARGET_MALTA bool "Support malta" @@ -28,98 +28,98 @@ config TARGET_MALTA select DM_SERIAL select DYNAMIC_IO_PORT_BASE select MIPS_CM + select MIPS_L1_CACHE_SHIFT_6 select MIPS_L2_CACHE select OF_CONTROL select OF_ISA_BUS + select ROM_EXCEPTION_VECTORS select SUPPORTS_BIG_ENDIAN - select SUPPORTS_LITTLE_ENDIAN select SUPPORTS_CPU_MIPS32_R1 select SUPPORTS_CPU_MIPS32_R2 select SUPPORTS_CPU_MIPS32_R6 select SUPPORTS_CPU_MIPS64_R1 select SUPPORTS_CPU_MIPS64_R2 select SUPPORTS_CPU_MIPS64_R6 + select SUPPORTS_LITTLE_ENDIAN select SWAP_IO_SPACE - select MIPS_L1_CACHE_SHIFT_6 - select ROM_EXCEPTION_VECTORS
config TARGET_VCT bool "Support vct" + select ROM_EXCEPTION_VECTORS select SUPPORTS_BIG_ENDIAN select SUPPORTS_CPU_MIPS32_R1 select SUPPORTS_CPU_MIPS32_R2 select SYS_MIPS_CACHE_INIT_RAM_LOAD - select ROM_EXCEPTION_VECTORS
config TARGET_DBAU1X00 bool "Support dbau1x00" + select MIPS_TUNE_4KC + select ROM_EXCEPTION_VECTORS select SUPPORTS_BIG_ENDIAN - select SUPPORTS_LITTLE_ENDIAN select SUPPORTS_CPU_MIPS32_R1 select SUPPORTS_CPU_MIPS32_R2 + select SUPPORTS_LITTLE_ENDIAN select SYS_MIPS_CACHE_INIT_RAM_LOAD - select ROM_EXCEPTION_VECTORS - select MIPS_TUNE_4KC
config TARGET_PB1X00 bool "Support pb1x00" - select SUPPORTS_LITTLE_ENDIAN + select MIPS_TUNE_4KC + select ROM_EXCEPTION_VECTORS select SUPPORTS_CPU_MIPS32_R1 select SUPPORTS_CPU_MIPS32_R2 + select SUPPORTS_LITTLE_ENDIAN select SYS_MIPS_CACHE_INIT_RAM_LOAD - select ROM_EXCEPTION_VECTORS - select MIPS_TUNE_4KC
config ARCH_ATH79 bool "Support QCA/Atheros ath79" - select OF_CONTROL select DM + select OF_CONTROL
config ARCH_BMIPS bool "Support BMIPS SoCs" - select OF_CONTROL - select DM select CLK select CPU + select DM + select OF_CONTROL select RAM select SYSRESET
config MACH_PIC32 bool "Support Microchip PIC32" - select OF_CONTROL select DM + select OF_CONTROL
config TARGET_BOSTON bool "Support Boston" select DM select DM_SERIAL - select OF_CONTROL select MIPS_CM select MIPS_L1_CACHE_SHIFT_6 select MIPS_L2_CACHE select OF_BOARD_SETUP + select OF_CONTROL + select ROM_EXCEPTION_VECTORS select SUPPORTS_BIG_ENDIAN - select SUPPORTS_LITTLE_ENDIAN select SUPPORTS_CPU_MIPS32_R1 select SUPPORTS_CPU_MIPS32_R2 select SUPPORTS_CPU_MIPS32_R6 select SUPPORTS_CPU_MIPS64_R1 select SUPPORTS_CPU_MIPS64_R2 select SUPPORTS_CPU_MIPS64_R6 - select ROM_EXCEPTION_VECTORS + select SUPPORTS_LITTLE_ENDIAN
config TARGET_XILFPGA bool "Support Imagination Xilfpga" - select OF_CONTROL select DM - select DM_SERIAL - select DM_GPIO select DM_ETH - select SUPPORTS_LITTLE_ENDIAN - select SUPPORTS_CPU_MIPS32_R1 - select SUPPORTS_CPU_MIPS32_R2 + select DM_GPIO + select DM_SERIAL select MIPS_L1_CACHE_SHIFT_4 + select OF_CONTROL select ROM_EXCEPTION_VECTORS + select SUPPORTS_CPU_MIPS32_R1 + select SUPPORTS_CPU_MIPS32_R2 + select SUPPORTS_LITTLE_ENDIAN help This supports IMGTEC MIPSfpga platform
diff --git a/arch/powerpc/cpu/mpc83xx/Kconfig b/arch/powerpc/cpu/mpc83xx/Kconfig index 05d29d2fd95f..385a7a6e2172 100644 --- a/arch/powerpc/cpu/mpc83xx/Kconfig +++ b/arch/powerpc/cpu/mpc83xx/Kconfig @@ -26,8 +26,8 @@ config TARGET_MPC8308RDB
config TARGET_MPC8313ERDB bool "Support MPC8313ERDB" - select SUPPORT_SPL select BOARD_EARLY_INIT_F + select SUPPORT_SPL
config TARGET_MPC8315ERDB bool "Support MPC8315ERDB" @@ -42,10 +42,10 @@ config TARGET_MPC832XEMDS
config TARGET_MPC8349EMDS bool "Support MPC8349EMDS" + select BOARD_EARLY_INIT_F select SYS_FSL_DDR - select SYS_FSL_HAS_DDR2 select SYS_FSL_DDR_BE - select BOARD_EARLY_INIT_F + select SYS_FSL_HAS_DDR2
config TARGET_MPC8349ITX bool "Support MPC8349ITX" diff --git a/cmd/Kconfig b/cmd/Kconfig index b359ac7118b0..e1c45eeb5ce4 100644 --- a/cmd/Kconfig +++ b/cmd/Kconfig @@ -152,8 +152,8 @@ config CMD_BDI
config CMD_CONFIG bool "config" - select BUILD_BIN2C default SANDBOX + select BUILD_BIN2C help Print ".config" contents.
@@ -429,8 +429,8 @@ config CMD_BINOP
config CMD_CRC32 bool "crc32" - select HASH default y + select HASH help Compute CRC32.
@@ -737,9 +737,9 @@ config CMD_GPIO
config CMD_GPT bool "GPT (GUID Partition Table) command" - select PARTITION_UUIDS select EFI_PARTITION select HAVE_BLOCK_DEVICE + select PARTITION_UUIDS imply RANDOM_UUID help Enable the 'gpt' command to ready and write GPT style partition @@ -899,8 +899,8 @@ config CMD_ONENAND
config CMD_PART bool "part" - select PARTITION_UUIDS select HAVE_BLOCK_DEVICE + select PARTITION_UUIDS help Read and display information about the partition table on various media. @@ -1797,10 +1797,10 @@ endmenu
config CMD_UBI tristate "Enable UBI - Unsorted block images commands" + default y if NAND_SUNXI + select CMD_MTDPARTS select CRC32 select MTD_UBI - select CMD_MTDPARTS - default y if NAND_SUNXI help UBI is a software layer above MTD layer which admits use of LVM-like logical volumes on top of MTD devices, hides some complexities of @@ -1812,9 +1812,9 @@ config CMD_UBI config CMD_UBIFS tristate "Enable UBIFS - Unsorted block images filesystem commands" depends on CMD_UBI + default y if CMD_UBI select CRC32 select LZO - default y if CMD_UBI help UBIFS is a file system for flash devices which works on top of UBI.
CMD_DM is used for debug purpose and it shouldn't be enabled by default via Kconfig. Unfortunately this is in the tree for quite a long time that's why solution is to use imply DM for all targets which are enabling DM.
Changes in v2: - sort them
Based on this discussion: https://lists.denx.de/pipermail/u-boot/2018-July/334952.html
Done by: for i in `git grep "select DM" | grep -v DM_ | cut -d ':' -f 1 | sort | uniq`; do sed -i 's/select DM$/select DM\n\timply CMD_DM/g' $i; done
And sort:
And checked by for i in `ls configs/*`; do NAME=`basename $i`; echo $NAME; make $NAME; make savedefconfig; cp defconfig $i; done
--- arch/Kconfig | 3 +++ arch/arm/Kconfig | 25 +++++++++++++++++++++++++ arch/arm/mach-at91/Kconfig | 6 ++++++ arch/arm/mach-imx/mx5/Kconfig | 2 ++ arch/arm/mach-imx/mx6/Kconfig | 25 +++++++++++++++++++++++++ arch/arm/mach-imx/mx7/Kconfig | 5 +++++ arch/arm/mach-meson/Kconfig | 2 ++ arch/arm/mach-omap2/am33xx/Kconfig | 18 ++++++++++++++++++ arch/arm/mach-omap2/omap3/Kconfig | 10 ++++++++++ arch/arm/mach-rmobile/Kconfig.32 | 8 ++++++++ arch/arm/mach-tegra/Kconfig | 1 + arch/microblaze/Kconfig | 1 + arch/mips/Kconfig | 6 ++++++ arch/powerpc/cpu/mpc83xx/Kconfig | 1 + cmd/Kconfig | 1 - 15 files changed, 113 insertions(+), 1 deletion(-)
diff --git a/arch/Kconfig b/arch/Kconfig index 7967fa50ac22..bf1b4a9afac6 100644 --- a/arch/Kconfig +++ b/arch/Kconfig @@ -50,6 +50,7 @@ config NIOS2 select DM select OF_CONTROL select SUPPORT_OF_CONTROL + imply CMD_DM
config PPC bool "PowerPC architecture" @@ -77,6 +78,7 @@ config SANDBOX select LZO select SPI select SUPPORT_OF_CONTROL + imply CMD_DM imply CMD_GETTIME imply CMD_HASH imply CMD_IO @@ -107,6 +109,7 @@ config X86 select USE_PRIVATE_LIBGCC select X86_TSC_TIMER imply BLK + imply CMD_DM imply CMD_FPGA_LOADMK imply CMD_GETTIME imply CMD_IO diff --git a/arch/arm/Kconfig b/arch/arm/Kconfig index 0c43c58ef0ed..6eaaa1f14826 100644 --- a/arch/arm/Kconfig +++ b/arch/arm/Kconfig @@ -441,6 +441,7 @@ config ARCH_MVEBU select OF_CONTROL select OF_SEPARATE select SPI + imply CMD_DM
config TARGET_DEVKIT3250 bool "Support devkit3250" @@ -499,6 +500,7 @@ config TARGET_STV0991 select PL01X_SERIAL select SPI select SPI_FLASH + imply CMD_DM
config TARGET_X600 bool "Support x600" @@ -533,6 +535,7 @@ config ARCH_BCM283X select OF_CONTROL select PL01X_SERIAL select SERIAL_SEARCH_ALL + imply CMD_DM imply FAT_WRITE
config TARGET_VEXPRESS_CA15_TC2 @@ -548,6 +551,7 @@ config ARCH_BCMSTB select DM select OF_CONTROL select OF_PRIOR_STAGE + imply CMD_DM help This enables support for Broadcom ARM-based set-top box chipsets, including the 7445 family of chips. @@ -607,6 +611,7 @@ config ARCH_EXYNOS select DM_SPI select DM_SPI_FLASH select SPI + imply CMD_DM imply FAT_WRITE
config ARCH_S5PC1XX @@ -616,6 +621,7 @@ config ARCH_S5PC1XX select DM_GPIO select DM_I2C select DM_SERIAL + imply CMD_DM
config ARCH_HIGHBANK bool "Calxeda Highbank" @@ -627,6 +633,7 @@ config ARCH_INTEGRATOR select DM select DM_SERIAL select PL01X_SERIAL + imply CMD_DM
config ARCH_KEYSTONE bool "TI Keystone" @@ -660,6 +667,7 @@ config ARCH_MX8M select ARM64 select DM select SUPPORT_SPL + imply CMD_DM
config ARCH_MX23 bool "NXP i.MX23 family" @@ -724,6 +732,7 @@ config ARCH_OWL select DM select DM_SERIAL select OF_CONTROL + imply CMD_DM
config ARCH_QEMU bool "QEMU Virtual Platform" @@ -731,12 +740,14 @@ config ARCH_QEMU select DM_SERIAL select OF_CONTROL select PL01X_SERIAL + imply CMD_DM
config ARCH_RMOBILE bool "Renesas ARM SoCs" select BOARD_EARLY_INIT_F select DM select DM_SERIAL + imply CMD_DM imply FAT_WRITE imply SYS_THUMB_BUILD
@@ -756,6 +767,7 @@ config ARCH_SNAPDRAGON select OF_SEPARATE select SMEM select SPMI + imply CMD_DM
config ARCH_SOCFPGA bool "Altera SOCFPGA family" @@ -784,6 +796,7 @@ config ARCH_SOCFPGA select SYS_MMCSD_RAW_MODE_U_BOOT_USE_PARTITION_TYPE select SYS_NS16550 select SYS_THUMB_BUILD if TARGET_SOCFPGA_GEN5 || TARGET_SOCFPGA_ARRIA10 + imply CMD_DM imply CMD_MTDPARTS imply CRC32_VERIFY imply DM_SPI @@ -816,6 +829,7 @@ config ARCH_SUNXI select USB_KEYBOARD if DISTRO_DEFAULTS select USB_STORAGE if DISTRO_DEFAULTS select USE_TINY_PRINTF + imply CMD_DM imply CMD_GPT imply DISTRO_DEFAULTS imply FAT_WRITE @@ -861,6 +875,7 @@ config ARCH_ZYNQ select SUPPORT_SPL imply ARCH_EARLY_INIT_R imply CMD_CLK + imply CMD_DM imply CMD_SPL imply FAT_WRITE
@@ -871,6 +886,7 @@ config ARCH_ZYNQMP_R5 select DM select DM_SERIAL select OF_CONTROL + imply CMD_DM
config ARCH_ZYNQMP bool "Xilinx ZynqMP based platform" @@ -884,6 +900,7 @@ config ARCH_ZYNQMP select SPL_BOARD_INIT if SPL select SPL_CLK if SPL select SUPPORT_SPL + imply CMD_DM imply FAT_WRITE
config TEGRA @@ -1010,6 +1027,7 @@ config TARGET_HIKEY select OF_CONTROL select PL01X_SERIAL select SPECIFY_CONSOLE_INDEX + imply CMD_DM help Support for HiKey 96boards platform. It features a HI6220 SoC, with 8xA53 CPU, mali450 gpu, and 1GB RAM. @@ -1022,6 +1040,7 @@ config TARGET_POPLAR select DM_USB select OF_CONTROL select PL01X_SERIAL + imply CMD_DM help Support for Poplar 96boards EE platform. It features a HI3798cv200 SoC, with 4xA53 CPU, 1GB RAM and the high performance Mali T720 GPU @@ -1233,6 +1252,7 @@ config ARCH_UNIPHIER select SPL_OF_CONTROL if SPL select SPL_PINCTRL if SPL select SUPPORT_SPL + imply CMD_DM imply FAT_WRITE help Support for UniPhier SoC family developed by Socionext Inc. @@ -1244,6 +1264,7 @@ config STM32 select DM select DM_SERIAL select SYS_THUMB_BUILD + imply CMD_DM
config ARCH_STI bool "Support STMicrolectronics SoCs" @@ -1253,6 +1274,7 @@ config ARCH_STI select DM_MMC select DM_RESET select DM_SERIAL + imply CMD_DM help Support for STMicroelectronics STiH407/10 SoC family. This SoC is used on Linaro 96Board STiH410-B2260 @@ -1275,6 +1297,7 @@ config ARCH_STM32MP select SYSCON select SYSRESET select SYS_THUMB_BUILD + imply CMD_DM help Support for STM32MP SoC family developed by STMicroelectronics, MPUs based on ARM cortex A core @@ -1302,6 +1325,7 @@ config ARCH_ROCKCHIP select SYS_MALLOC_F select SYS_THUMB_BUILD if !ARM64 imply ADC + imply CMD_DM imply DISTRO_DEFAULTS imply FAT_WRITE imply SARADC_ROCKCHIP @@ -1321,6 +1345,7 @@ config ARCH_ASPEED bool "Support Aspeed SoCs" select DM select OF_CONTROL + imply CMD_DM
endchoice
diff --git a/arch/arm/mach-at91/Kconfig b/arch/arm/mach-at91/Kconfig index 1a56957cf9d1..69856c894285 100644 --- a/arch/arm/mach-at91/Kconfig +++ b/arch/arm/mach-at91/Kconfig @@ -78,6 +78,7 @@ config TARGET_SNAPPER9260 select DM select DM_GPIO select DM_SERIAL + imply CMD_DM
config TARGET_GURNARD bool "Support gurnard" @@ -89,6 +90,7 @@ config TARGET_GURNARD select DM_SERIAL select DM_SPI select SPI + imply CMD_DM
config TARGET_AT91SAM9261EK bool "Atmel at91sam9261 reference board" @@ -209,6 +211,7 @@ config TARGET_CORVUS select DM_GPIO select DM_SERIAL select SUPPORT_SPL + imply CMD_DM
config TARGET_TAURUS bool "Support taurus" @@ -220,6 +223,7 @@ config TARGET_TAURUS select DM_SPI select SPI select SUPPORT_SPL + imply CMD_DM
config TARGET_SMARTWEB bool "Support smartweb" @@ -229,6 +233,7 @@ config TARGET_SMARTWEB select DM_GPIO select DM_SERIAL select SUPPORT_SPL + imply CMD_DM
config TARGET_VINCO bool "Support VINCO" @@ -237,6 +242,7 @@ config TARGET_VINCO select SAMA5D4 select SPI select SUPPORT_SPL + imply CMD_DM
config TARGET_WB45N bool "Support Laird WB45N" diff --git a/arch/arm/mach-imx/mx5/Kconfig b/arch/arm/mach-imx/mx5/Kconfig index 1bb373bf2d1c..051b15dbff1c 100644 --- a/arch/arm/mach-imx/mx5/Kconfig +++ b/arch/arm/mach-imx/mx5/Kconfig @@ -28,6 +28,7 @@ config TARGET_KP_IMX53 select DM_PMIC select DM_SERIAL select MX53 + imply CMD_DM
config TARGET_MX51EVK bool "Support mx51evk" @@ -44,6 +45,7 @@ config TARGET_MX53CX9020 select DM select DM_SERIAL select MX53 + imply CMD_DM
config TARGET_MX53EVK bool "Support mx53evk" diff --git a/arch/arm/mach-imx/mx6/Kconfig b/arch/arm/mach-imx/mx6/Kconfig index 5cce9ce23c0e..6009a96531ac 100644 --- a/arch/arm/mach-imx/mx6/Kconfig +++ b/arch/arm/mach-imx/mx6/Kconfig @@ -64,6 +64,7 @@ config MX6UL_LITESOM select DM_THERMAL select MX6UL select SUPPORT_SPL + imply CMD_DM
config MX6UL_OPOS6UL bool @@ -78,6 +79,7 @@ config MX6UL_OPOS6UL select SPL_PINCTRL if SPL select SPL_SEPARATE_BSS if SPL select SUPPORT_SPL + imply CMD_DM
config MX6ULL bool @@ -110,6 +112,7 @@ config TARGET_APALIS_IMX6 select DM_SERIAL select DM_THERMAL select SUPPORT_SPL + imply CMD_DM imply CMD_SATA
config TARGET_ARISTAINETOS @@ -130,6 +133,7 @@ config TARGET_CGTQMX6EVAL select DM_THERMAL select MX6QDL select SUPPORT_SPL + imply CMD_DM
config TARGET_CM_FX6 bool "CM-FX6" @@ -139,6 +143,7 @@ config TARGET_CM_FX6 select DM_SERIAL select MX6QDL select SUPPORT_SPL + imply CMD_DM
config TARGET_COLIBRI_IMX6 bool "Toradex Colibri iMX6 board" @@ -147,6 +152,7 @@ config TARGET_COLIBRI_IMX6 select DM_SERIAL select DM_THERMAL select SUPPORT_SPL + imply CMD_DM
config TARGET_DHCOMIMX6 bool "dh_imx6" @@ -156,6 +162,7 @@ config TARGET_DHCOMIMX6 select DM_THERMAL select MX6QDL select SUPPORT_SPL + imply CMD_DM imply CMD_SPL
config TARGET_DISPLAY5 @@ -163,6 +170,7 @@ config TARGET_DISPLAY5 select DM select DM_SERIAL select SUPPORT_SPL + imply CMD_DM
config TARGET_EMBESTMX6BOARDS bool "embestmx6boards" @@ -208,6 +216,7 @@ config TARGET_MX6LOGICPD select DM_PMIC select DM_REGULATOR select OF_CONTROL + imply CMD_DM
config TARGET_MX6MEMCAL bool "mx6memcal" @@ -250,6 +259,7 @@ config TARGET_MX6DL_MAMOJ select SPL_USB_SDP_SUPPORT if SPL select SPL_WATCHDOG_SUPPORT if SPL select SUPPORT_SPL + imply CMD_DM
config TARGET_MX6Q_ENGICAM bool "Support Engicam i.Core(RQS)" @@ -268,6 +278,7 @@ config TARGET_MX6Q_ENGICAM select SPL_PINCTRL if SPL select SPL_SEPARATE_BSS if SPL select SUPPORT_SPL + imply CMD_DM
config TARGET_MX6SABREAUTO bool "mx6sabreauto" @@ -277,6 +288,7 @@ config TARGET_MX6SABREAUTO select DM_THERMAL select MX6QDL select SUPPORT_SPL + imply CMD_DM
config TARGET_MX6SABRESD bool "mx6sabresd" @@ -286,6 +298,7 @@ config TARGET_MX6SABRESD select DM_THERMAL select MX6QDL select SUPPORT_SPL + imply CMD_DM
config TARGET_MX6SLEVK bool "mx6slevk" @@ -298,6 +311,7 @@ config TARGET_MX6SLLEVK select DM select DM_THERMAL select MX6SLL + imply CMD_DM
config TARGET_MX6SXSABRESD bool "mx6sxsabresd" @@ -315,6 +329,7 @@ config TARGET_MX6SXSABREAUTO select DM select DM_THERMAL select MX6SX + imply CMD_DM
config TARGET_MX6UL_9X9_EVK bool "mx6ul_9x9_evk" @@ -323,6 +338,7 @@ config TARGET_MX6UL_9X9_EVK select DM_THERMAL select MX6UL select SUPPORT_SPL + imply CMD_DM
config TARGET_MX6UL_14X14_EVK bool "mx6ul_14x14_evk" @@ -331,6 +347,7 @@ config TARGET_MX6UL_14X14_EVK select DM_THERMAL select MX6UL select SUPPORT_SPL + imply CMD_DM
config TARGET_MX6UL_ENGICAM bool "Support Engicam GEAM6UL/Is.IoT" @@ -348,6 +365,7 @@ config TARGET_MX6UL_ENGICAM select SPL_PINCTRL if SPL select SPL_SEPARATE_BSS if SPL select SUPPORT_SPL + imply CMD_DM
config TARGET_MX6ULL_14X14_EVK bool "Support mx6ull_14x14_evk" @@ -355,6 +373,7 @@ config TARGET_MX6ULL_14X14_EVK select DM select DM_THERMAL select MX6ULL + imply CMD_DM
config TARGET_NITROGEN6X bool "nitrogen6x" @@ -421,6 +440,7 @@ config TARGET_KP_IMX6Q_TPC select DM_THERMAL select MX6QDL select SUPPORT_SPL + imply CMD_DM imply CMD_SPL
config TARGET_TQMA6 @@ -440,6 +460,7 @@ config TARGET_UDOO_NEO select DM_THERMAL select MX6SX select SUPPORT_SPL + imply CMD_DM
config TARGET_SAMTEC_VINING_2000 bool "samtec VIN|ING 2000" @@ -447,6 +468,7 @@ config TARGET_SAMTEC_VINING_2000 select DM select DM_THERMAL select MX6SX + imply CMD_DM
config TARGET_WANDBOARD bool "wandboard" @@ -466,6 +488,7 @@ config TARGET_XPRESS select DM_THERMAL select MX6UL select SUPPORT_SPL + imply CMD_DM
config TARGET_ZC5202 bool "zc5202" @@ -473,6 +496,7 @@ config TARGET_ZC5202 select DM select DM_THERMAL select SUPPORT_SPL + imply CMD_DM
config TARGET_ZC5601 bool "zc5601" @@ -480,6 +504,7 @@ config TARGET_ZC5601 select DM select DM_THERMAL select SUPPORT_SPL + imply CMD_DM
endchoice
diff --git a/arch/arm/mach-imx/mx7/Kconfig b/arch/arm/mach-imx/mx7/Kconfig index f618a7bb9d1f..e75e43dc8ffc 100644 --- a/arch/arm/mach-imx/mx7/Kconfig +++ b/arch/arm/mach-imx/mx7/Kconfig @@ -26,6 +26,7 @@ config TARGET_CL_SOM_IMX7 select DM_THERMAL select MX7D select SUPPORT_SPL + imply CMD_DM
config TARGET_MX7DSABRESD bool "mx7dsabresd" @@ -33,6 +34,7 @@ config TARGET_MX7DSABRESD select DM select DM_THERMAL select MX7D + imply CMD_DM
config TARGET_PICO_IMX7D bool "pico-imx7d" @@ -40,6 +42,7 @@ config TARGET_PICO_IMX7D select DM select DM_THERMAL select MX7D + imply CMD_DM
config TARGET_WARP7 bool "warp7" @@ -47,6 +50,7 @@ config TARGET_WARP7 select DM select DM_THERMAL select MX7D + imply CMD_DM
config TARGET_COLIBRI_IMX7 bool "Support Colibri iMX7S/iMX7D modules" @@ -54,6 +58,7 @@ config TARGET_COLIBRI_IMX7 select DM select DM_SERIAL select DM_THERMAL + imply CMD_DM
endchoice
diff --git a/arch/arm/mach-meson/Kconfig b/arch/arm/mach-meson/Kconfig index 76622567907b..ee8b1cdcf674 100644 --- a/arch/arm/mach-meson/Kconfig +++ b/arch/arm/mach-meson/Kconfig @@ -6,6 +6,7 @@ config MESON_GXBB select CLK select DM select DM_SERIAL + imply CMD_DM help The Amlogic Meson GXBaby (S905) is an ARM SoC with a quad-core Cortex-A53 CPU and a Mali-450 GPU. @@ -16,6 +17,7 @@ config MESON_GXL select CLK select DM select DM_SERIAL + imply CMD_DM help The Amlogic Meson GXL (S905X and S905D) is an ARM SoC with a quad-core Cortex-A53 CPU and a Mali-450 GPU. diff --git a/arch/arm/mach-omap2/am33xx/Kconfig b/arch/arm/mach-omap2/am33xx/Kconfig index 94d9d868f893..3529607479d2 100644 --- a/arch/arm/mach-omap2/am33xx/Kconfig +++ b/arch/arm/mach-omap2/am33xx/Kconfig @@ -34,6 +34,7 @@ config TARGET_AM335X_EVM select DM_GPIO select DM_SERIAL select TI_I2C_BOARD_DETECT + imply CMD_DM imply SPL_DM imply SPL_DM_SEQ_ALIAS imply SPL_ENV_SUPPORT @@ -67,6 +68,7 @@ config TARGET_AM335X_BALTOS select DM select DM_GPIO select DM_SERIAL + imply CMD_DM
config TARGET_AM335X_IGEP003X bool "Support am335x_igep003x" @@ -74,6 +76,7 @@ config TARGET_AM335X_IGEP003X select DM select DM_GPIO select DM_SERIAL + imply CMD_DM
config TARGET_AM335X_SHC bool "Support am335x based shc board from bosch" @@ -81,6 +84,7 @@ config TARGET_AM335X_SHC select DM select DM_GPIO select DM_SERIAL + imply CMD_DM imply CMD_SPL
config TARGET_AM335X_SL50 @@ -89,12 +93,14 @@ config TARGET_AM335X_SL50 select DM select DM_GPIO select DM_SERIAL + imply CMD_DM
config TARGET_BAV335X bool "Support bav335x" select BOARD_LATE_INIT select DM select DM_SERIAL + imply CMD_DM help The BAV335x OEM Network Processor integrates all the functions of an embedded network computer in a small, easy to use SODIMM module which @@ -118,12 +124,14 @@ config TARGET_CHILIBOARD select BOARD_LATE_INIT select DM select DM_SERIAL + imply CMD_DM
config TARGET_CM_T335 bool "Support cm_t335" select DM select DM_GPIO select DM_SERIAL + imply CMD_DM
config TARGET_DRACO bool "Support draco" @@ -131,6 +139,7 @@ config TARGET_DRACO select DM select DM_GPIO select DM_SERIAL + imply CMD_DM
config TARGET_ETAMIN bool "Support etamin" @@ -138,24 +147,28 @@ config TARGET_ETAMIN select DM select DM_GPIO select DM_SERIAL + imply CMD_DM
config TARGET_PCM051 bool "Support pcm051" select DM select DM_GPIO select DM_SERIAL + imply CMD_DM
config TARGET_PENGWYN bool "Support pengwyn" select DM select DM_GPIO select DM_SERIAL + imply CMD_DM
config TARGET_PEPPER bool "Support pepper" select DM select DM_GPIO select DM_SERIAL + imply CMD_DM
config TARGET_PXM2 bool "Support pxm2" @@ -163,6 +176,7 @@ config TARGET_PXM2 select DM select DM_GPIO select DM_SERIAL + imply CMD_DM
config TARGET_RASTABAN bool "Support rastaban" @@ -170,6 +184,7 @@ config TARGET_RASTABAN select DM select DM_GPIO select DM_SERIAL + imply CMD_DM
config TARGET_RUT bool "Support rut" @@ -177,6 +192,7 @@ config TARGET_RUT select DM select DM_GPIO select DM_SERIAL + imply CMD_DM
config TARGET_THUBAN bool "Support thuban" @@ -184,11 +200,13 @@ config TARGET_THUBAN select DM select DM_GPIO select DM_SERIAL + imply CMD_DM
config TARGET_PDU001 bool "Support PDU001" select DM select DM_SERIAL + imply CMD_DM help Support for PDU001 platform developed by EETS GmbH. The PDU001 is a processor and display unit developed around diff --git a/arch/arm/mach-omap2/omap3/Kconfig b/arch/arm/mach-omap2/omap3/Kconfig index 9e4227d8266b..e0d02fb4e59a 100644 --- a/arch/arm/mach-omap2/omap3/Kconfig +++ b/arch/arm/mach-omap2/omap3/Kconfig @@ -27,6 +27,7 @@ config TARGET_AM3517_EVM select DM_I2C select DM_MMC select DM_SERIAL + imply CMD_DM
config TARGET_MT_VENTOUX bool "TeeJet Mt.Ventoux" @@ -40,6 +41,7 @@ config TARGET_OMAP3_BEAGLE select DM_SERIAL select OMAP3_GPIO_5 select OMAP3_GPIO_6 + imply CMD_DM
config TARGET_CM_T35 bool "CompuLab CM-T3530 and CM-T3730 boards" @@ -58,6 +60,7 @@ config TARGET_DEVKIT8000 select DM select DM_GPIO select DM_SERIAL + imply CMD_DM
config TARGET_OMAP3_EVM bool "TI OMAP3 EVM" @@ -65,6 +68,7 @@ config TARGET_OMAP3_EVM select DM_GPIO select DM_SERIAL select OMAP3_GPIO_3 + imply CMD_DM
config TARGET_OMAP3_IGEP00X0 bool "IGEP" @@ -74,6 +78,7 @@ config TARGET_OMAP3_IGEP00X0 select OMAP3_GPIO_3 select OMAP3_GPIO_5 select OMAP3_GPIO_6 + imply CMD_DM
config TARGET_OMAP3_OVERO bool "OMAP35xx Gumstix Overo" @@ -85,12 +90,14 @@ config TARGET_OMAP3_OVERO select OMAP3_GPIO_4 select OMAP3_GPIO_5 select OMAP3_GPIO_6 + imply CMD_DM
config TARGET_OMAP3_ZOOM1 bool "TI Zoom1" select DM select DM_GPIO select DM_SERIAL + imply CMD_DM
config TARGET_AM3517_CRANE bool "am3517_crane" @@ -123,6 +130,7 @@ config TARGET_OMAP3_LOGIC select OMAP3_GPIO_3 select OMAP3_GPIO_4 select OMAP3_GPIO_6 + imply CMD_DM
config TARGET_NOKIA_RX51 bool "Nokia RX51" @@ -145,6 +153,7 @@ config TARGET_OMAP3_CAIRO select DM select DM_GPIO select DM_SERIAL + imply CMD_DM
config TARGET_SNIPER bool "LG Optimus Black" @@ -156,6 +165,7 @@ config TARGET_SNIPER select OMAP3_GPIO_4 select OMAP3_GPIO_5 select OMAP3_GPIO_6 + imply CMD_DM
endchoice
diff --git a/arch/arm/mach-rmobile/Kconfig.32 b/arch/arm/mach-rmobile/Kconfig.32 index dc517350ee19..c005ce2a286b 100644 --- a/arch/arm/mach-rmobile/Kconfig.32 +++ b/arch/arm/mach-rmobile/Kconfig.32 @@ -42,6 +42,7 @@ config TARGET_BLANCHE select DM select DM_SERIAL select USE_TINY_PRINTF + imply CMD_DM
config TARGET_GOSE bool "Gose board" @@ -50,6 +51,7 @@ config TARGET_GOSE select SPL_TINY_MEMSET select SUPPORT_SPL select USE_TINY_PRINTF + imply CMD_DM
config TARGET_KOELSCH bool "Koelsch board" @@ -58,6 +60,7 @@ config TARGET_KOELSCH select SPL_TINY_MEMSET select SUPPORT_SPL select USE_TINY_PRINTF + imply CMD_DM
config TARGET_LAGER bool "Lager board" @@ -66,6 +69,7 @@ config TARGET_LAGER select SPL_TINY_MEMSET select SUPPORT_SPL select USE_TINY_PRINTF + imply CMD_DM
config TARGET_KZM9G bool "KZM9D board" @@ -77,6 +81,7 @@ config TARGET_ALT select SPL_TINY_MEMSET select SUPPORT_SPL select USE_TINY_PRINTF + imply CMD_DM
config TARGET_SILK bool "Silk board" @@ -85,6 +90,7 @@ config TARGET_SILK select SPL_TINY_MEMSET select SUPPORT_SPL select USE_TINY_PRINTF + imply CMD_DM
config TARGET_PORTER bool "Porter board" @@ -93,6 +99,7 @@ config TARGET_PORTER select SPL_TINY_MEMSET select SUPPORT_SPL select USE_TINY_PRINTF + imply CMD_DM
config TARGET_STOUT bool "Stout board" @@ -101,6 +108,7 @@ config TARGET_STOUT select SPL_TINY_MEMSET select SUPPORT_SPL select USE_TINY_PRINTF + imply CMD_DM
endchoice
diff --git a/arch/arm/mach-tegra/Kconfig b/arch/arm/mach-tegra/Kconfig index cd03705b64c0..86b1cd11f752 100644 --- a/arch/arm/mach-tegra/Kconfig +++ b/arch/arm/mach-tegra/Kconfig @@ -40,6 +40,7 @@ config TEGRA_COMMON select OF_CONTROL select SPI select VIDCONSOLE_AS_LCD if DM_VIDEO + imply CMD_DM imply CRC32_VERIFY
config TEGRA_NO_BPMP diff --git a/arch/microblaze/Kconfig b/arch/microblaze/Kconfig index 1df1ecf72d19..5cc68d63c4f7 100644 --- a/arch/microblaze/Kconfig +++ b/arch/microblaze/Kconfig @@ -16,6 +16,7 @@ config TARGET_MICROBLAZE_GENERIC select OF_CONTROL select SUPPORT_SPL select SYSRESET + imply CMD_DM
endchoice
diff --git a/arch/mips/Kconfig b/arch/mips/Kconfig index 315d89dbeb3f..31b622ff5108 100644 --- a/arch/mips/Kconfig +++ b/arch/mips/Kconfig @@ -42,6 +42,7 @@ config TARGET_MALTA select SUPPORTS_CPU_MIPS64_R6 select SUPPORTS_LITTLE_ENDIAN select SWAP_IO_SPACE + imply CMD_DM
config TARGET_VCT bool "Support vct" @@ -74,6 +75,7 @@ config ARCH_ATH79 bool "Support QCA/Atheros ath79" select DM select OF_CONTROL + imply CMD_DM
config ARCH_BMIPS bool "Support BMIPS SoCs" @@ -83,11 +85,13 @@ config ARCH_BMIPS select OF_CONTROL select RAM select SYSRESET + imply CMD_DM
config MACH_PIC32 bool "Support Microchip PIC32" select DM select OF_CONTROL + imply CMD_DM
config TARGET_BOSTON bool "Support Boston" @@ -107,6 +111,7 @@ config TARGET_BOSTON select SUPPORTS_CPU_MIPS64_R2 select SUPPORTS_CPU_MIPS64_R6 select SUPPORTS_LITTLE_ENDIAN + imply CMD_DM
config TARGET_XILFPGA bool "Support Imagination Xilfpga" @@ -120,6 +125,7 @@ config TARGET_XILFPGA select SUPPORTS_CPU_MIPS32_R1 select SUPPORTS_CPU_MIPS32_R2 select SUPPORTS_LITTLE_ENDIAN + imply CMD_DM help This supports IMGTEC MIPSfpga platform
diff --git a/arch/powerpc/cpu/mpc83xx/Kconfig b/arch/powerpc/cpu/mpc83xx/Kconfig index 385a7a6e2172..571cf8fc2ef8 100644 --- a/arch/powerpc/cpu/mpc83xx/Kconfig +++ b/arch/powerpc/cpu/mpc83xx/Kconfig @@ -64,6 +64,7 @@ config TARGET_MPC837XERDB config TARGET_IDS8313 bool "Support ids8313" select DM + imply CMD_DM
config TARGET_KM8360 bool "Support km8360" diff --git a/cmd/Kconfig b/cmd/Kconfig index e1c45eeb5ce4..6394c3c8e179 100644 --- a/cmd/Kconfig +++ b/cmd/Kconfig @@ -640,7 +640,6 @@ config CMD_DFU config CMD_DM bool "dm - Access to driver model information" depends on DM - default y help Provides access to driver model data structures and information, such as a list of devices, list of uclasses and the state of each
Signed-off-by: Michal Simek michal.simek@xilinx.com
Reviewed-by: Joe Hershberger joe.hershberger@ni.com
Signed-off-by: Michal Simek michal.simek@xilinx.com Reviewed-by: Tom Rini trini@konsulko.com Reviewed-by: Joe Hershberger joe.hershberger@ni.com
Another round of sorting Kconfig entries aplhabetically.
Changes in v2: None
Kconfig | 22 ++++++++++----------- arch/arc/Kconfig | 10 +++++----- arch/arm/cpu/armv7/ls102xa/Kconfig | 10 +++++----- arch/arm/cpu/armv8/Kconfig | 4 ++-- arch/arm/mach-davinci/Kconfig | 4 ++-- arch/arm/mach-exynos/Kconfig | 30 ++++++++++++++--------------- arch/arm/mach-imx/mx3/Kconfig | 2 +- arch/arm/mach-mvebu/Kconfig | 6 +++--- arch/arm/mach-omap2/Kconfig | 6 +++--- arch/arm/mach-omap2/omap5/Kconfig | 12 ++++++------ arch/arm/mach-qemu/Kconfig | 2 +- arch/arm/mach-rockchip/rk3288/Kconfig | 20 +++++++++---------- arch/arm/mach-socfpga/Kconfig | 4 ++-- arch/arm/mach-stm32/Kconfig | 20 +++++++++---------- arch/arm/mach-tegra/tegra124/Kconfig | 4 ++-- arch/arm/mach-uniphier/Kconfig | 8 ++++---- arch/mips/mach-ath79/Kconfig | 10 +++++----- arch/mips/mach-bmips/Kconfig | 36 +++++++++++++++++------------------ arch/mips/mach-pic32/Kconfig | 6 +++--- arch/powerpc/Kconfig | 2 +- 20 files changed, 109 insertions(+), 109 deletions(-)
diff --git a/Kconfig b/Kconfig index c8b86cd3843d..62235cae96cf 100644 --- a/Kconfig +++ b/Kconfig @@ -68,25 +68,25 @@ config CC_COVERAGE
config DISTRO_DEFAULTS bool "Select defaults suitable for booting general purpose Linux distributions" - imply USE_BOOTCOMMAND - select CMD_BOOTZ if ARM && !ARM64 + select AUTO_COMPLETE + select CMDLINE_EDITING select CMD_BOOTI if ARM64 + select CMD_BOOTZ if ARM && !ARM64 select CMD_DHCP if CMD_NET - select CMD_PING if CMD_NET - select CMD_PXE if NET select CMD_ENV_EXISTS select CMD_EXT2 select CMD_EXT4 select CMD_FAT select CMD_FS_GENERIC - imply CMD_MII if NET select CMD_PART if PARTITIONS + select CMD_PING if CMD_NET + select CMD_PXE if NET + select ENV_VARS_UBOOT_CONFIG select HUSH_PARSER - select CMDLINE_EDITING - select AUTO_COMPLETE - select SYS_LONGHELP select SUPPORT_RAW_INITRD - select ENV_VARS_UBOOT_CONFIG + select SYS_LONGHELP + imply CMD_MII if NET + imply USE_BOOTCOMMAND help Select this to enable various options and commands which are suitable for building u-boot for booting general purpose Linux distributions. @@ -237,8 +237,8 @@ if FIT
config FIT_ENABLE_SHA256_SUPPORT bool "Support SHA256 checksum of FIT image contents" - select SHA256 default y + select SHA256 help Enable this to support SHA256 checksum of FIT image contents. A SHA256 checksum is a 256-bit (32-byte) hash value used to check that @@ -252,8 +252,8 @@ config FIT_ENABLE_SHA256_SUPPORT config FIT_SIGNATURE bool "Enable signature verification of FIT uImages" depends on DM - select RSA select HASH + select RSA help This option enables signature verification of FIT uImages, using a hash signed and verified using RSA. If diff --git a/arch/arc/Kconfig b/arch/arc/Kconfig index 6f139d5bdc52..d59aa3ae291e 100644 --- a/arch/arc/Kconfig +++ b/arch/arc/Kconfig @@ -31,36 +31,36 @@ choice
config CPU_ARC750D bool "ARC 750D" - select ARC_MMU_V2 depends on ISA_ARCOMPACT + select ARC_MMU_V2 help Choose this option to build an U-Boot for ARC750D CPU.
config CPU_ARC770D bool "ARC 770D" - select ARC_MMU_V3 depends on ISA_ARCOMPACT + select ARC_MMU_V3 help Choose this option to build an U-Boot for ARC770D CPU.
config CPU_ARCEM6 bool "ARC EM6" - select ARC_MMU_ABSENT depends on ISA_ARCV2 + select ARC_MMU_ABSENT help Next Generation ARC Core based on ISA-v2 ISA without MMU.
config CPU_ARCHS36 bool "ARC HS36" - select ARC_MMU_ABSENT depends on ISA_ARCV2 + select ARC_MMU_ABSENT help Next Generation ARC Core based on ISA-v2 ISA without MMU.
config CPU_ARCHS38 bool "ARC HS38" - select ARC_MMU_V4 depends on ISA_ARCV2 + select ARC_MMU_V4 help Next Generation ARC Core based on ISA-v2 ISA with MMU.
diff --git a/arch/arm/cpu/armv7/ls102xa/Kconfig b/arch/arm/cpu/armv7/ls102xa/Kconfig index 635358e32838..5d6a711c140c 100644 --- a/arch/arm/cpu/armv7/ls102xa/Kconfig +++ b/arch/arm/cpu/armv7/ls102xa/Kconfig @@ -1,5 +1,7 @@ config ARCH_LS1021A bool + select SYS_FSL_DDR_BE if SYS_FSL_DDR + select SYS_FSL_DDR_VER_50 if SYS_FSL_DDR select SYS_FSL_ERRATUM_A008378 select SYS_FSL_ERRATUM_A008407 select SYS_FSL_ERRATUM_A008997 @@ -10,18 +12,16 @@ config ARCH_LS1021A select SYS_FSL_ERRATUM_A009942 select SYS_FSL_ERRATUM_A010315 select SYS_FSL_HAS_CCI400 - select SYS_FSL_SRDS_1 - select SYS_HAS_SERDES - select SYS_FSL_DDR_BE if SYS_FSL_DDR - select SYS_FSL_DDR_VER_50 if SYS_FSL_DDR select SYS_FSL_HAS_DDR3 if SYS_FSL_DDR select SYS_FSL_HAS_DDR4 if SYS_FSL_DDR select SYS_FSL_HAS_SEC select SYS_FSL_SEC_COMPAT_5 select SYS_FSL_SEC_LE + select SYS_FSL_SRDS_1 + select SYS_HAS_SERDES + imply CMD_PCI imply SCSI imply SCSI_AHCI - imply CMD_PCI
menu "LS102xA architecture" depends on ARCH_LS1021A diff --git a/arch/arm/cpu/armv8/Kconfig b/arch/arm/cpu/armv8/Kconfig index 22d2f295487c..741e15c77378 100644 --- a/arch/arm/cpu/armv8/Kconfig +++ b/arch/arm/cpu/armv8/Kconfig @@ -44,8 +44,8 @@ config ARMV8_SPIN_TABLE menu "ARMv8 secure monitor firmware" config ARMV8_SEC_FIRMWARE_SUPPORT bool "Enable ARMv8 secure monitor firmware framework support" - select OF_LIBFDT select FIT + select OF_LIBFDT help This framework is aimed at making secure monitor firmware load process brief. @@ -60,8 +60,8 @@ config ARMV8_SEC_FIRMWARE_SUPPORT
config SPL_ARMV8_SEC_FIRMWARE_SUPPORT bool "Enable ARMv8 secure monitor firmware framework support for SPL" - select SPL_OF_LIBFDT select SPL_FIT + select SPL_OF_LIBFDT help Say Y here to support this framework in SPL phase.
diff --git a/arch/arm/mach-davinci/Kconfig b/arch/arm/mach-davinci/Kconfig index 5e7baba3fe49..12b1e682e6a2 100644 --- a/arch/arm/mach-davinci/Kconfig +++ b/arch/arm/mach-davinci/Kconfig @@ -18,9 +18,9 @@ config TARGET_DA850EVM
config TARGET_EA20 bool "EA20 board" + select BOARD_LATE_INIT select MACH_DAVINCI_DA850_EVM select SOC_DA850 - select BOARD_LATE_INIT
config TARGET_OMAPL138_LCDK bool "OMAPL138 LCDK" @@ -57,8 +57,8 @@ config SOC_DA850
config SOC_DA8XX bool - select SYS_DA850_PLL_INIT if SUPPORT_SPL || DA850_LOWLEVEL select SYS_DA850_DDR_INIT if SUPPORT_SPL || DA850_LOWLEVEL + select SYS_DA850_PLL_INIT if SUPPORT_SPL || DA850_LOWLEVEL
config MACH_DAVINCI_DA850_EVM bool diff --git a/arch/arm/mach-exynos/Kconfig b/arch/arm/mach-exynos/Kconfig index 65d9168ae2f3..ed04369cfae3 100644 --- a/arch/arm/mach-exynos/Kconfig +++ b/arch/arm/mach-exynos/Kconfig @@ -6,8 +6,8 @@ choice
config ARCH_EXYNOS4 bool "Exynos4 SoC family" - select CPU_V7A select BOARD_EARLY_INIT_F + select CPU_V7A help Samsung Exynos4 SoC family are based on ARM Cortex-A9 CPU. There are multiple SoCs in this family including Exynos4210, Exynos4412, @@ -15,14 +15,14 @@ config ARCH_EXYNOS4
config ARCH_EXYNOS5 bool "Exynos5 SoC family" - select CPU_V7A select BOARD_EARLY_INIT_F + select CPU_V7A select SHA_HW_ACCEL - imply CRC32_VERIFY imply CMD_HASH + imply CRC32_VERIFY imply HASH_VERIFY - imply USB_ETHER_RTL8152 imply USB_ETHER_ASIX + imply USB_ETHER_RTL8152 imply USB_ETHER_SMSC95XX help Samsung Exynos5 SoC family are based on ARM Cortex-A15 CPU (and @@ -46,9 +46,9 @@ choice prompt "EXYNOS4 board select"
config TARGET_SMDKV310 - select SUPPORT_SPL bool "Exynos4210 SMDKV310 board" select OF_CONTROL + select SUPPORT_SPL
config TARGET_TRATS bool "Exynos4210 Trats board" @@ -93,39 +93,39 @@ config TARGET_ARNDALE select ARM_ERRATA_774769 select CPU_V7_HAS_NONSEC select CPU_V7_HAS_VIRT - select SUPPORT_SPL select OF_CONTROL + select SUPPORT_SPL
config TARGET_SMDK5250 bool "SMDK5250 board" - select SUPPORT_SPL select OF_CONTROL + select SUPPORT_SPL
config TARGET_SNOW bool "Snow board" - select SUPPORT_SPL select OF_CONTROL + select SUPPORT_SPL
config TARGET_SPRING bool "Spring board" - select SUPPORT_SPL select OF_CONTROL select SPL_DISABLE_OF_CONTROL + select SUPPORT_SPL
config TARGET_SMDK5420 bool "SMDK5420 board" - select SUPPORT_SPL select OF_CONTROL + select SUPPORT_SPL
config TARGET_PEACH_PI bool "Peach Pi board" - select SUPPORT_SPL select OF_CONTROL + select SUPPORT_SPL
config TARGET_PEACH_PIT bool "Peach Pit board" - select SUPPORT_SPL select OF_CONTROL + select SUPPORT_SPL
endchoice endif @@ -139,12 +139,12 @@ config TARGET_ESPRESSO7420 bool "ESPRESSO7420 board" select ARM64 select ARMV8_MULTIENTRY - select SUPPORT_SPL + select CLK_EXYNOS select OF_CONTROL - select SPL_DISABLE_OF_CONTROL select PINCTRL select PINCTRL_EXYNOS7420 - select CLK_EXYNOS + select SPL_DISABLE_OF_CONTROL + select SUPPORT_SPL
endchoice endif diff --git a/arch/arm/mach-imx/mx3/Kconfig b/arch/arm/mach-imx/mx3/Kconfig index 6cc970fc4992..5028d5ea568a 100644 --- a/arch/arm/mach-imx/mx3/Kconfig +++ b/arch/arm/mach-imx/mx3/Kconfig @@ -9,9 +9,9 @@ choice
config TARGET_MX31PDK bool "Support the i.MX31 PDK board from Freescale/NXP" + select BOARD_EARLY_INIT_F select BOARD_LATE_INIT select SUPPORT_SPL - select BOARD_EARLY_INIT_F
endchoice
diff --git a/arch/arm/mach-mvebu/Kconfig b/arch/arm/mach-mvebu/Kconfig index 5415b5a7bfe2..3df124c6a8ad 100644 --- a/arch/arm/mach-mvebu/Kconfig +++ b/arch/arm/mach-mvebu/Kconfig @@ -6,14 +6,14 @@ config HAVE_MVEBU_EFUSE
config ARMADA_32BIT bool + select ARCH_MISC_INIT + select BOARD_EARLY_INIT_F select CPU_V7A - select SUPPORT_SPL select SPL_DM select SPL_DM_SEQ_ALIAS select SPL_OF_CONTROL select SPL_SIMPLE_BUS - select BOARD_EARLY_INIT_F - select ARCH_MISC_INIT + select SUPPORT_SPL
config ARMADA_64BIT bool diff --git a/arch/arm/mach-omap2/Kconfig b/arch/arm/mach-omap2/Kconfig index f4babc8d2600..76a19064c9b1 100644 --- a/arch/arm/mach-omap2/Kconfig +++ b/arch/arm/mach-omap2/Kconfig @@ -6,11 +6,11 @@ choice
config OMAP34XX bool "OMAP34XX SoC" + select ARM_CORTEX_A8_CVE_2017_5715 select ARM_ERRATA_430973 select ARM_ERRATA_454179 select ARM_ERRATA_621766 select ARM_ERRATA_725233 - select ARM_CORTEX_A8_CVE_2017_5715 select USE_TINY_PRINTF imply NAND_OMAP_GPMC imply SPL_EXT_SUPPORT @@ -52,9 +52,9 @@ config OMAP44XX
config OMAP54XX bool "OMAP54XX SoC" + select ARM_CORTEX_A15_CVE_2017_5715 select ARM_ERRATA_798870 select SYS_THUMB_BUILD - select ARM_CORTEX_A15_CVE_2017_5715 imply NAND_OMAP_ELM imply NAND_OMAP_GPMC imply SPL_DISPLAY_PRINT @@ -116,8 +116,8 @@ config AM43XX
config AM33XX bool "AM33XX SoC" - select SPECIFY_CONSOLE_INDEX select ARM_CORTEX_A8_CVE_2017_5715 + select SPECIFY_CONSOLE_INDEX imply NAND_OMAP_ELM imply NAND_OMAP_GPMC imply SPL_NAND_AM33XX_BCH diff --git a/arch/arm/mach-omap2/omap5/Kconfig b/arch/arm/mach-omap2/omap5/Kconfig index deb9873cc537..f083a4a385c5 100644 --- a/arch/arm/mach-omap2/omap5/Kconfig +++ b/arch/arm/mach-omap2/omap5/Kconfig @@ -23,26 +23,26 @@ config TARGET_DRA7XX_EVM bool "TI DRA7XX" select BOARD_LATE_INIT select DRA7XX - select TI_I2C_BOARD_DETECT select PHYS_64BIT - imply SCSI + select TI_I2C_BOARD_DETECT imply DM_PMIC - imply PMIC_LP87565 imply DM_REGULATOR imply DM_REGULATOR_LP87565 - imply SPL_THERMAL imply DM_THERMAL + imply PMIC_LP87565 + imply SCSI + imply SPL_THERMAL imply TI_DRA7_THERMAL
config TARGET_AM57XX_EVM bool "AM57XX" select BOARD_LATE_INIT + select CMD_DDR3 select DRA7XX select TI_I2C_BOARD_DETECT - select CMD_DDR3 + imply DM_THERMAL imply SCSI imply SPL_THERMAL - imply DM_THERMAL imply TI_DRA7_THERMAL
endchoice diff --git a/arch/arm/mach-qemu/Kconfig b/arch/arm/mach-qemu/Kconfig index 726f8a7d3140..a2e4b98b8887 100644 --- a/arch/arm/mach-qemu/Kconfig +++ b/arch/arm/mach-qemu/Kconfig @@ -14,8 +14,8 @@ endif config TARGET_QEMU_ARM_32BIT bool "Support qemu_arm" depends on ARCH_QEMU - select CPU_V7A select ARCH_SUPPORT_PSCI + select CPU_V7A select SYS_ARCH_TIMER
config TARGET_QEMU_ARM_64BIT diff --git a/arch/arm/mach-rockchip/rk3288/Kconfig b/arch/arm/mach-rockchip/rk3288/Kconfig index 6beb26fd7a68..b5447e5b6587 100644 --- a/arch/arm/mach-rockchip/rk3288/Kconfig +++ b/arch/arm/mach-rockchip/rk3288/Kconfig @@ -87,22 +87,22 @@ config TARGET_POPMETAL_RK3288 config TARGET_VYASA_RK3288 bool "Vyasa-RK3288" select BOARD_LATE_INIT - select TPL + select ROCKCHIP_BROM_HELPER select SUPPORT_TPL - select TPL_DM - select TPL_REGMAP - select TPL_SYSCON - select TPL_CLK - select TPL_RAM - select TPL_OF_PLATDATA - select TPL_OF_CONTROL + select TPL select TPL_BOOTROM_SUPPORT - select TPL_NEEDS_SEPARATE_TEXT_BASE if SPL - select ROCKCHIP_BROM_HELPER + select TPL_CLK + select TPL_DM select TPL_DRIVERS_MISC_SUPPORT select TPL_LIBCOMMON_SUPPORT select TPL_LIBGENERIC_SUPPORT + select TPL_NEEDS_SEPARATE_TEXT_BASE if SPL + select TPL_OF_CONTROL + select TPL_OF_PLATDATA + select TPL_RAM + select TPL_REGMAP select TPL_SERIAL_SUPPORT + select TPL_SYSCON help Vyasa is a RK3288-based development board with 2 USB ports, HDMI, VGA, micro-SD card, audio, WiFi and Gigabit Ethernet, It diff --git a/arch/arm/mach-socfpga/Kconfig b/arch/arm/mach-socfpga/Kconfig index 91ea742f3b10..5c1df2cf1f81 100644 --- a/arch/arm/mach-socfpga/Kconfig +++ b/arch/arm/mach-socfpga/Kconfig @@ -9,8 +9,8 @@ config TARGET_SOCFPGA_ARRIA5
config TARGET_SOCFPGA_ARRIA10 bool - select SPL_BOARD_INIT if SPL select ALTERA_SDRAM + select SPL_BOARD_INIT if SPL
config TARGET_SOCFPGA_CYCLONE5 bool @@ -23,8 +23,8 @@ config TARGET_SOCFPGA_GEN5 config TARGET_SOCFPGA_STRATIX10 bool select ARMV8_MULTIENTRY - select ARMV8_SPIN_TABLE select ARMV8_SET_SMPEN + select ARMV8_SPIN_TABLE
choice prompt "Altera SOCFPGA board select" diff --git a/arch/arm/mach-stm32/Kconfig b/arch/arm/mach-stm32/Kconfig index a45f3fd77a75..cea5ee2ce54a 100644 --- a/arch/arm/mach-stm32/Kconfig +++ b/arch/arm/mach-stm32/Kconfig @@ -9,9 +9,9 @@ config STM32F4 select PINCTRL select PINCTRL_STM32 select RAM - select STM32_SDRAM select STM32_RCC select STM32_RESET + select STM32_SDRAM select STM32_SERIAL select STM32_TIMER select TIMER @@ -25,13 +25,6 @@ config STM32F7 select PINCTRL select PINCTRL_STM32 select RAM - select STM32_SDRAM - select STM32_RCC - select STM32_RESET - select STM32_SERIAL - select STM32_TIMER - select TIMER - select SUPPORT_SPL select SPL select SPL_BOARD_INIT select SPL_CLK @@ -46,13 +39,20 @@ config STM32F7 select SPL_OF_CONTROL select SPL_OF_LIBFDT select SPL_OF_TRANSLATE - imply SPL_OS_BOOT select SPL_PINCTRL select SPL_RAM select SPL_SERIAL_SUPPORT select SPL_SYS_MALLOC_SIMPLE select SPL_TIMER select SPL_XIP_SUPPORT + select STM32_RCC + select STM32_RESET + select STM32_SDRAM + select STM32_SERIAL + select STM32_TIMER + select SUPPORT_SPL + select TIMER + imply SPL_OS_BOOT
config STM32H7 bool "stm32h7 family" @@ -64,9 +64,9 @@ config STM32H7 select PINCTRL_STM32 select RAM select REGMAP - select STM32_SDRAM select STM32_RCC select STM32_RESET + select STM32_SDRAM select STM32_SERIAL select STM32_TIMER select SYSCON diff --git a/arch/arm/mach-tegra/tegra124/Kconfig b/arch/arm/mach-tegra/tegra124/Kconfig index a07add68fd20..6fa31ea0a16c 100644 --- a/arch/arm/mach-tegra/tegra124/Kconfig +++ b/arch/arm/mach-tegra/tegra124/Kconfig @@ -6,16 +6,16 @@ choice
config TARGET_APALIS_TK1 bool "Toradex Apalis TK1 module" + select ARCH_SUPPORT_PSCI select CPU_V7_HAS_NONSEC select CPU_V7_HAS_VIRT - select ARCH_SUPPORT_PSCI
config TARGET_JETSON_TK1 bool "NVIDIA Tegra124 Jetson TK1 board" + select ARCH_SUPPORT_PSCI select BOARD_LATE_INIT select CPU_V7_HAS_NONSEC select CPU_V7_HAS_VIRT - select ARCH_SUPPORT_PSCI
config TARGET_CEI_TK1_SOM bool "Colorado Engineering Inc Tegra124 TK1-som board" diff --git a/arch/arm/mach-uniphier/Kconfig b/arch/arm/mach-uniphier/Kconfig index 91bea776e6cb..bfb445a60296 100644 --- a/arch/arm/mach-uniphier/Kconfig +++ b/arch/arm/mach-uniphier/Kconfig @@ -5,10 +5,10 @@ config SYS_CONFIG_NAME
config ARCH_UNIPHIER_32BIT bool + select ARCH_SUPPORT_PSCI + select ARMV7_NONSEC select CPU_V7A select CPU_V7_HAS_NONSEC - select ARMV7_NONSEC - select ARCH_SUPPORT_PSCI
choice prompt "UniPhier SoC select" @@ -68,8 +68,8 @@ config ARCH_UNIPHIER_LD11 config ARCH_UNIPHIER_LD20 bool "Enable UniPhier LD20 SoC support" depends on ARCH_UNIPHIER_V8_MULTI - select OF_BOARD_SETUP default y + select OF_BOARD_SETUP
config ARCH_UNIPHIER_PXS3 bool "Enable UniPhier PXs3 SoC support" @@ -79,8 +79,8 @@ config ARCH_UNIPHIER_PXS3 config CACHE_UNIPHIER bool "Enable the UniPhier L2 cache controller" depends on ARCH_UNIPHIER_32BIT - select SYS_CACHE_SHIFT_7 default y + select SYS_CACHE_SHIFT_7 help This option allows to use the UniPhier System Cache as L2 cache.
diff --git a/arch/mips/mach-ath79/Kconfig b/arch/mips/mach-ath79/Kconfig index d982b0f8e697..bc86f591df83 100644 --- a/arch/mips/mach-ath79/Kconfig +++ b/arch/mips/mach-ath79/Kconfig @@ -6,30 +6,30 @@ config SYS_SOC
config SOC_AR933X bool + select MIPS_TUNE_24KC + select ROM_EXCEPTION_VECTORS select SUPPORTS_BIG_ENDIAN select SUPPORTS_CPU_MIPS32_R1 select SUPPORTS_CPU_MIPS32_R2 - select ROM_EXCEPTION_VECTORS - select MIPS_TUNE_24KC help This supports QCA/Atheros ar933x family SOCs.
config SOC_AR934X bool + select MIPS_TUNE_74KC select SUPPORTS_BIG_ENDIAN select SUPPORTS_CPU_MIPS32_R1 select SUPPORTS_CPU_MIPS32_R2 - select MIPS_TUNE_74KC help This supports QCA/Atheros ar934x family SOCs.
config SOC_QCA953X bool + select MIPS_TUNE_24KC + select ROM_EXCEPTION_VECTORS select SUPPORTS_BIG_ENDIAN select SUPPORTS_CPU_MIPS32_R1 select SUPPORTS_CPU_MIPS32_R2 - select ROM_EXCEPTION_VECTORS - select MIPS_TUNE_24KC help This supports QCA/Atheros qca953x family SOCs.
diff --git a/arch/mips/mach-bmips/Kconfig b/arch/mips/mach-bmips/Kconfig index 10900bf6045a..5968d5345ed7 100644 --- a/arch/mips/mach-bmips/Kconfig +++ b/arch/mips/mach-bmips/Kconfig @@ -20,10 +20,10 @@ choice
config SOC_BMIPS_BCM3380 bool "BMIPS BCM3380 family" + select MIPS_L1_CACHE_SHIFT_4 + select MIPS_TUNE_4KC select SUPPORTS_BIG_ENDIAN select SUPPORTS_CPU_MIPS32_R1 - select MIPS_TUNE_4KC - select MIPS_L1_CACHE_SHIFT_4 select SWAP_IO_SPACE select SYSRESET_WATCHDOG help @@ -31,10 +31,10 @@ config SOC_BMIPS_BCM3380
config SOC_BMIPS_BCM6318 bool "BMIPS BCM6318 family" + select MIPS_L1_CACHE_SHIFT_4 + select MIPS_TUNE_4KC select SUPPORTS_BIG_ENDIAN select SUPPORTS_CPU_MIPS32_R1 - select MIPS_TUNE_4KC - select MIPS_L1_CACHE_SHIFT_4 select SWAP_IO_SPACE select SYSRESET_SYSCON help @@ -42,10 +42,10 @@ config SOC_BMIPS_BCM6318
config SOC_BMIPS_BCM6328 bool "BMIPS BCM6328 family" + select MIPS_L1_CACHE_SHIFT_4 + select MIPS_TUNE_4KC select SUPPORTS_BIG_ENDIAN select SUPPORTS_CPU_MIPS32_R1 - select MIPS_TUNE_4KC - select MIPS_L1_CACHE_SHIFT_4 select SWAP_IO_SPACE select SYSRESET_SYSCON help @@ -53,10 +53,10 @@ config SOC_BMIPS_BCM6328
config SOC_BMIPS_BCM6338 bool "BMIPS BCM6338 family" + select MIPS_L1_CACHE_SHIFT_4 + select MIPS_TUNE_4KC select SUPPORTS_BIG_ENDIAN select SUPPORTS_CPU_MIPS32_R1 - select MIPS_TUNE_4KC - select MIPS_L1_CACHE_SHIFT_4 select SWAP_IO_SPACE select SYSRESET_SYSCON help @@ -64,10 +64,10 @@ config SOC_BMIPS_BCM6338
config SOC_BMIPS_BCM6348 bool "BMIPS BCM6348 family" + select MIPS_L1_CACHE_SHIFT_4 + select MIPS_TUNE_4KC select SUPPORTS_BIG_ENDIAN select SUPPORTS_CPU_MIPS32_R1 - select MIPS_TUNE_4KC - select MIPS_L1_CACHE_SHIFT_4 select SWAP_IO_SPACE select SYSRESET_WATCHDOG help @@ -75,10 +75,10 @@ config SOC_BMIPS_BCM6348
config SOC_BMIPS_BCM6358 bool "BMIPS BCM6358 family" + select MIPS_L1_CACHE_SHIFT_4 + select MIPS_TUNE_4KC select SUPPORTS_BIG_ENDIAN select SUPPORTS_CPU_MIPS32_R1 - select MIPS_TUNE_4KC - select MIPS_L1_CACHE_SHIFT_4 select SWAP_IO_SPACE select SYSRESET_SYSCON help @@ -86,10 +86,10 @@ config SOC_BMIPS_BCM6358
config SOC_BMIPS_BCM6368 bool "BMIPS BCM6368 family" + select MIPS_L1_CACHE_SHIFT_4 + select MIPS_TUNE_4KC select SUPPORTS_BIG_ENDIAN select SUPPORTS_CPU_MIPS32_R1 - select MIPS_TUNE_4KC - select MIPS_L1_CACHE_SHIFT_4 select SWAP_IO_SPACE select SYSRESET_SYSCON help @@ -97,10 +97,10 @@ config SOC_BMIPS_BCM6368
config SOC_BMIPS_BCM6362 bool "BMIPS BCM6362 family" + select MIPS_L1_CACHE_SHIFT_4 + select MIPS_TUNE_4KC select SUPPORTS_BIG_ENDIAN select SUPPORTS_CPU_MIPS32_R1 - select MIPS_TUNE_4KC - select MIPS_L1_CACHE_SHIFT_4 select SWAP_IO_SPACE select SYSRESET_SYSCON help @@ -108,10 +108,10 @@ config SOC_BMIPS_BCM6362
config SOC_BMIPS_BCM63268 bool "BMIPS BCM63268 family" + select MIPS_L1_CACHE_SHIFT_4 + select MIPS_TUNE_4KC select SUPPORTS_BIG_ENDIAN select SUPPORTS_CPU_MIPS32_R1 - select MIPS_TUNE_4KC - select MIPS_L1_CACHE_SHIFT_4 select SWAP_IO_SPACE select SYSRESET_SYSCON help diff --git a/arch/mips/mach-pic32/Kconfig b/arch/mips/mach-pic32/Kconfig index 8fad4cff9126..5f13bf14ed6b 100644 --- a/arch/mips/mach-pic32/Kconfig +++ b/arch/mips/mach-pic32/Kconfig @@ -9,12 +9,12 @@ choice
config SOC_PIC32MZDA bool "Microchip PIC32MZ[DA] family" - select SUPPORTS_LITTLE_ENDIAN + select MIPS_L1_CACHE_SHIFT_4 + select ROM_EXCEPTION_VECTORS select SUPPORTS_CPU_MIPS32_R1 select SUPPORTS_CPU_MIPS32_R2 - select MIPS_L1_CACHE_SHIFT_4 + select SUPPORTS_LITTLE_ENDIAN select SYS_MIPS_CACHE_INIT_RAM_LOAD - select ROM_EXCEPTION_VECTORS help This supports Microchip PIC32MZ[DA] family of microcontrollers.
diff --git a/arch/powerpc/Kconfig b/arch/powerpc/Kconfig index 13a79560b24b..8faef0ba9fc3 100644 --- a/arch/powerpc/Kconfig +++ b/arch/powerpc/Kconfig @@ -20,9 +20,9 @@ config MPC85xx select CREATE_ARCH_SYMLINK select SYS_FSL_DDR select SYS_FSL_DDR_BE - imply USB_EHCI_HCD if USB imply CMD_HASH imply CMD_IRQ + imply USB_EHCI_HCD if USB
config MPC86xx bool "MPC86xx"
Hi Michal,
Changes in v2: None
[snip]
Acked-by: Alexey Brodkin abrodkin@synopsys.com
Signed-off-by: Michal Simek michal.simek@xilinx.com Reviewed-by: Tom Rini trini@konsulko.com Acked-by: Alexey Brodkin abrodkin@synopsys.com Reviewed-by: Joe Hershberger joe.hershberger@ni.com
On Mon, Jul 23, 2018 at 03:55:11PM +0200, Michal Simek wrote:
Better use depends on instead of select.
Signed-off-by: Michal Simek michal.simek@xilinx.com Reviewed-by: Tom Rini trini@konsulko.com Reviewed-by: Tom Rini trini@konsulko.com
Alexey Brodkin
Joe Hershberger
Michal Simek
