[U-Boot-Users] Enabling both SMC ports
Hi All, Our product ( MPC860 arch with Mvista Kernel) has one serial port connected to the console & is interfaced thru' SMC1.The second serial port needs to be connected to the printer thru' SMC2. The u-boot does not allow enabling SMC1 & SMC2 both togather. How do I go about achieving this ?
Rgds
Kamesh Member, Software Group Signal Networks PVT. LTD
You porbably don't want to control your printer by U-Boot anyway, or do you?
And Linux has no such limitations.
If you really want to use both SMC ports in U-Boot you have to extend the existing driver. But I don't see why you would want to do this.
Hi WD, First of all Thanks for your prompt reply. I needed further info on this issue. I have already tried enabling the SMC2 in the kernel. This is what I tried:
$ make menuconfig
1) Selected MPC8xx CPM Options and Enabled the Foll. i) Use SMC2 for UART ii) Use SMC2 for Console
Then Compiled the kernel & ported it to the board (MPC860) Connected the serial printer to SMC2. Tried printing using 'cat' command $ cat <file-name> > /dev/ttyS1 (since /dev/ttyS0 is for console) Command gets executed but printer does not print anything.
Have I missed anything or not tried enough ? Is there any other workaround ?
Your suggestions would be valuable.
Rgds Kamesh
-- Software Engineering: Embedded and Realtime Systems, Embedded Linux Phone: (+49)-8142-66989-10 Fax: (+49)-8142-66989-80 Email: wd@denx.de If you can't beat it or corrupt it, you pretend it was your idea in the first place. - Terry Pratchett, _Guards! Guards!_
This is off topic here.
[And without further information about your hardware, your kernel version and how it was ported to your hardware you should not expect much help from any other mailing list, either.]
Kamesh K S
