[U-Boot] [U-boot] [PATCH 1/2] rockchip: configs: move env offset to common header
To reduce redundant code.
Signed-off-by: Jacob Chen jacob2.chen@rock-chips.com ---
include/configs/evb_rk3288.h | 14 -------------- include/configs/fennec_rk3288.h | 14 -------------- include/configs/kylin_rk3036.h | 14 -------------- include/configs/miniarm_rk3288.h | 14 -------------- include/configs/popmetal_rk3288.h | 14 -------------- include/configs/rock2.h | 14 -------------- include/configs/rockchip-common.h | 14 ++++++++++++++ 7 files changed, 14 insertions(+), 84 deletions(-)
diff --git a/include/configs/evb_rk3288.h b/include/configs/evb_rk3288.h index 554ca0e..6a068bb 100644 --- a/include/configs/evb_rk3288.h +++ b/include/configs/evb_rk3288.h @@ -13,20 +13,6 @@ #define CONFIG_ENV_IS_IN_MMC #define CONFIG_SYS_MMC_ENV_DEV 1
-#ifdef CONFIG_ROCKCHIP_SPL_BACK_TO_BROM -/* SPL @ 32k for 34k - * u-boot directly after @ 68k for 400k or so - * ENV @ 992k - */ -#define CONFIG_ENV_OFFSET ((1024-32) * 1024) -#else -/* SPL @ 32k for ~36k - * ENV @ 96k - * u-boot @ 128K - */ -#define CONFIG_ENV_OFFSET (96 * 1024) -#endif - #define CONFIG_SYS_WHITE_ON_BLACK
#endif diff --git a/include/configs/fennec_rk3288.h b/include/configs/fennec_rk3288.h index 554ca0e..6a068bb 100644 --- a/include/configs/fennec_rk3288.h +++ b/include/configs/fennec_rk3288.h @@ -13,20 +13,6 @@ #define CONFIG_ENV_IS_IN_MMC #define CONFIG_SYS_MMC_ENV_DEV 1
#endif diff --git a/include/configs/kylin_rk3036.h b/include/configs/kylin_rk3036.h index bc28525..088aced 100644 --- a/include/configs/kylin_rk3036.h +++ b/include/configs/kylin_rk3036.h @@ -20,20 +20,6 @@ #define CONFIG_SYS_MMC_ENV_DEV 0 /* emmc */ #define CONFIG_SYS_MMC_ENV_PART 0 /* user area */
-#ifdef CONFIG_ROCKCHIP_SPL_BACK_TO_BROM -/* SPL @ 32k for 34k - * u-boot directly after @ 68k for 400k or so - * ENV @ 992k - */ -#define CONFIG_ENV_OFFSET ((1024-32) * 1024) -#else -/* SPL @ 32k for ~36k - * ENV @ 96k - * u-boot @ 128K - */ -#define CONFIG_ENV_OFFSET (96 * 1024) -#endif - #endif
#endif diff --git a/include/configs/miniarm_rk3288.h b/include/configs/miniarm_rk3288.h index 5a623ca..860eb40 100644 --- a/include/configs/miniarm_rk3288.h +++ b/include/configs/miniarm_rk3288.h @@ -18,20 +18,6 @@ #define CONFIG_ENV_IS_IN_MMC #define CONFIG_SYS_MMC_ENV_DEV 0
#endif diff --git a/include/configs/popmetal_rk3288.h b/include/configs/popmetal_rk3288.h index 554ca0e..6a068bb 100644 --- a/include/configs/popmetal_rk3288.h +++ b/include/configs/popmetal_rk3288.h @@ -13,20 +13,6 @@ #define CONFIG_ENV_IS_IN_MMC #define CONFIG_SYS_MMC_ENV_DEV 1
#endif diff --git a/include/configs/rock2.h b/include/configs/rock2.h index b9c2290..ec555dd 100644 --- a/include/configs/rock2.h +++ b/include/configs/rock2.h @@ -17,20 +17,6 @@ #define CONFIG_ENV_IS_IN_MMC #define CONFIG_SYS_MMC_ENV_DEV 0
#endif diff --git a/include/configs/rockchip-common.h b/include/configs/rockchip-common.h index be53e65..eb5f1ef 100644 --- a/include/configs/rockchip-common.h +++ b/include/configs/rockchip-common.h @@ -34,4 +34,18 @@
#endif
+#ifdef CONFIG_ROCKCHIP_SPL_BACK_TO_BROM +/* SPL @ 32k for 34k + * u-boot directly after @ 68k for 400k or so + * ENV @ 992k + */ +#define CONFIG_ENV_OFFSET ((1024-32) * 1024) +#else +/* SPL @ 32k for ~36k + * ENV @ 96k + * u-boot @ 128K + */ +#define CONFIG_ENV_OFFSET (96 * 1024) +#endif + #endif /* _ROCKCHIP_COMMON_H_ */
Keep it same with other boards otherwise i have to write special script for it..
configs/firefly-rk3288_defconfig | 2 +- include/configs/firefly-rk3288.h | 5 ----- 2 files changed, 1 insertion(+), 6 deletions(-)
diff --git a/configs/firefly-rk3288_defconfig b/configs/firefly-rk3288_defconfig index 3ed17b4..18e050d 100644 --- a/configs/firefly-rk3288_defconfig +++ b/configs/firefly-rk3288_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_ARCH_ROCKCHIP=y CONFIG_SYS_MALLOC_F_LEN=0x2000 CONFIG_ROCKCHIP_RK3288=y +CONFIG_ROCKCHIP_SPL_BACK_TO_BROM=y CONFIG_TARGET_FIREFLY_RK3288=y CONFIG_SPL_STACK_R_ADDR=0x80000 CONFIG_DEFAULT_DEVICE_TREE="rk3288-firefly" @@ -75,4 +76,3 @@ CONFIG_CONSOLE_SCROLL_LINES=10 CONFIG_USE_TINY_PRINTF=y CONFIG_CMD_DHRYSTONE=y CONFIG_ERRNO_STR=y -# CONFIG_SPL_OF_LIBFDT is not set diff --git a/include/configs/firefly-rk3288.h b/include/configs/firefly-rk3288.h index 14fdead..ec555dd 100644 --- a/include/configs/firefly-rk3288.h +++ b/include/configs/firefly-rk3288.h @@ -16,11 +16,6 @@
#define CONFIG_ENV_IS_IN_MMC #define CONFIG_SYS_MMC_ENV_DEV 0 -/* SPL @ 32k for ~36k - * ENV @ 96k - * u-boot @ 128K - */ -#define CONFIG_ENV_OFFSET (96 * 1024)
Applied to u-boot-rockchip, thanks!
Jacob Chen
