[PATCH] azure: Use msys2 20210604 installer for Windows build
MSYS2 Windows build started to fail since yesterday (Jun 21):
checking keyring... checking package integrity... error: gcc-libs: signature from "David Macek david.macek.0@gmail.com" is unknown trust :: File /var/cache/pacman/pkg/gcc-libs-10.2.0-1-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)). error: gcc: signature from "David Macek david.macek.0@gmail.com" is unknown trust :: File /var/cache/pacman/pkg/gcc-10.2.0-1-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)). error: failed to commit transaction (invalid or corrupted package) Errors occurred, no packages were upgraded.
Switching to the latest installer (version 20210604) seems to fix it.
Signed-off-by: Bin Meng bmeng.cn@gmail.com ---
.azure-pipelines.yml | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/.azure-pipelines.yml b/.azure-pipelines.yml index 35ab7f30b2..221e600806 100644 --- a/.azure-pipelines.yml +++ b/.azure-pipelines.yml @@ -16,7 +16,7 @@ jobs: vmImage: $(windows_vm) steps: - powershell: | - (New-Object Net.WebClient).DownloadFile("https://github.com/msys2/msys2-installer/releases/download/2020-07-20/msys2-...", "sfx.exe") + (New-Object Net.WebClient).DownloadFile("https://github.com/msys2/msys2-installer/releases/download/2021-06-04/msys2-...", "sfx.exe") displayName: 'Install MSYS2' - script: | sfx.exe -y -o%CD:~0,2%\
I had done the same and fired off a test build while this came in, so I'll take yours. Thanks!
Reviewed-by: Tom Rini trini@konsulko.com Tested-by: Tom Rini trini@konsulko.com
Signed-off-by: Bin Meng bmeng.cn@gmail.com Reviewed-by: Tom Rini trini@konsulko.com Tested-by: Tom Rini trini@konsulko.com
Bin Meng
