[U-Boot] [PATCH v5 0/6] power: pmic: Add support for Palmas family of PMICs
The series adds support for Palmas family of PMICs. Implements functions to configure regulators. Enable/Disable Get/Set voltages of regulators.
Supports TPS659038, TPS65917, Palmas.
Tested on TPS659038, TPS65917 using DRA7XX-EVM and AM57XX-EVM.
Changes in v5:
removed u8 i2c read/write functions made use of already existing functions.
Added read/write functions.
Changes in v4:
Added Reviewed-by and a minor change from printf to debug.
Changes in v3:
Introduced u8 i2c read/write functions.
Keerthy (6): power: regulator: Add ctrl_reg and volt_reg fields for pmic power: pmic: Palmas: Add the base pmic support power: regulator: palmas: Add regulator support configs: dra7xx_evm_defconfig: Enable PALMAS options configs: am57xx_evm_defconfig: Enable PALMAS options configs: am57xx_evm_defconfig: Enable CMD_REG option
configs/am57xx_evm_defconfig | 5 + configs/dra7xx_evm_defconfig | 3 + drivers/power/pmic/Kconfig | 7 + drivers/power/pmic/Makefile | 1 + drivers/power/pmic/palmas.c | 108 +++++++ drivers/power/regulator/Kconfig | 8 + drivers/power/regulator/Makefile | 1 + drivers/power/regulator/palmas_regulator.c | 453 +++++++++++++++++++++++++++++ include/power/palmas.h | 25 ++ include/power/regulator.h | 4 + 10 files changed, 615 insertions(+) create mode 100644 drivers/power/pmic/palmas.c create mode 100644 drivers/power/regulator/palmas_regulator.c create mode 100644 include/power/palmas.h
The ctrl reg contains bit fields to enable and disable regulators, and volt_reg has the bit fields to configure the voltage values. The registers are frequently accessed hence make them part of dm_regulator_uclass_platdata structure.
Signed-off-by: Keerthy j-keerthy@ti.com Reviewed-by: Tom Rini trini@konsulko.com Reviewed-by: Simon Glass sjg@chromium.org --- include/power/regulator.h | 4 ++++ 1 file changed, 4 insertions(+)
diff --git a/include/power/regulator.h b/include/power/regulator.h index 9bcd728..2117f55 100644 --- a/include/power/regulator.h +++ b/include/power/regulator.h @@ -152,6 +152,8 @@ enum regulator_flag { * TODO(sjg@chromium.org): Consider putting the above two into @flags * @flags: - flags value (see REGULATOR_FLAG_...) * @name** - fdt regulator name - should be taken from the device tree + * ctrl_reg: - Control register offset used to enable/disable regulator + * volt_reg: - register offset for writing voltage vsel values * * Note: * * - set automatically on device probe by the uclass's '.pre_probe' method. @@ -171,6 +173,8 @@ struct dm_regulator_uclass_platdata { bool boot_on; const char *name; int flags; + u8 ctrl_reg; + u8 volt_reg; };
/* Regulator device operations */
Add support to bind the regulators/child nodes with the pmic. Also adds the pmic i2c based read/write funtions to access pmic registers.
Signed-off-by: Keerthy j-keerthy@ti.com Reviewed-by: Simon Glass sjg@chromium.org Reviewed-by: Tom Rini trini@konsulko.com ---
Changes in v5:
* Added pmic read/write functions.
drivers/power/pmic/Kconfig | 7 +++ drivers/power/pmic/Makefile | 1 + drivers/power/pmic/palmas.c | 108 ++++++++++++++++++++++++++++++++++++++++++++ include/power/palmas.h | 25 ++++++++++ 4 files changed, 141 insertions(+) create mode 100644 drivers/power/pmic/palmas.c create mode 100644 include/power/palmas.h
diff --git a/drivers/power/pmic/Kconfig b/drivers/power/pmic/Kconfig index 69f8d51..92931c5 100644 --- a/drivers/power/pmic/Kconfig +++ b/drivers/power/pmic/Kconfig @@ -135,3 +135,10 @@ config PMIC_TPS65090 FETs and a battery charger. This driver provides register access only, and you can enable the regulator/charger drivers separately if required. + +config PMIC_PALMAS + bool "Enable driver for Texas Instruments PALMAS PMIC" + depends on DM_PMIC + ---help--- + The PALMAS is a PMIC containing several LDOs, SMPS. + This driver binds the pmic children. diff --git a/drivers/power/pmic/Makefile b/drivers/power/pmic/Makefile index 52b4f71..828c0cf 100644 --- a/drivers/power/pmic/Makefile +++ b/drivers/power/pmic/Makefile @@ -15,6 +15,7 @@ obj-$(CONFIG_PMIC_PM8916) += pm8916.o obj-$(CONFIG_PMIC_RK808) += rk808.o obj-$(CONFIG_PMIC_TPS65090) += tps65090.o obj-$(CONFIG_PMIC_S5M8767) += s5m8767.o +obj-$(CONFIG_$(SPL_)PMIC_PALMAS) += palmas.o
obj-$(CONFIG_POWER_LTC3676) += pmic_ltc3676.o obj-$(CONFIG_POWER_MAX77696) += pmic_max77696.o diff --git a/drivers/power/pmic/palmas.c b/drivers/power/pmic/palmas.c new file mode 100644 index 0000000..1d2bd67 --- /dev/null +++ b/drivers/power/pmic/palmas.c @@ -0,0 +1,108 @@ +/* + * (C) Copyright 2016 Texas Instruments Incorporated, <www.ti.com> + * Keerthy j-keerthy@ti.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <fdtdec.h> +#include <errno.h> +#include <dm.h> +#include <i2c.h> +#include <power/pmic.h> +#include <power/regulator.h> +#include <power/palmas.h> +#include <dm/device.h> + +DECLARE_GLOBAL_DATA_PTR; + +static const struct pmic_child_info pmic_children_info[] = { + { .prefix = "ldo", .driver = PALMAS_LDO_DRIVER }, + { .prefix = "smps", .driver = PALMAS_SMPS_DRIVER }, + { }, +}; + +static int palmas_write(struct udevice *dev, uint reg, const uint8_t *buff, + int len) +{ + if (dm_i2c_reg_write(dev, reg, *buff)) { + error("write error to device: %p register: %#x!", dev, reg); + return -EIO; + } + + return 0; +} + +static int palmas_read(struct udevice *dev, uint reg, uint8_t *buff, int len) +{ + int ret; + + ret = dm_i2c_reg_read(dev, reg); + if (ret < 0) { + error("read error %d from device: %p register: %#x!", ret, dev, + reg); + return -EIO; + } + + return ret; +} + +static int palmas_bind(struct udevice *dev) +{ + int pmic_node = -1, regulators_node; + const void *blob = gd->fdt_blob; + int children; + int node = dev->of_offset; + int subnode, len; + + fdt_for_each_subnode(blob, subnode, node) { + const char *name; + char *temp; + + name = fdt_get_name(blob, subnode, &len); + temp = strstr(name, "pmic"); + if (temp) { + pmic_node = subnode; + break; + } + } + + if (pmic_node <= 0) { + debug("%s: %s pmic subnode not found!", __func__, dev->name); + return -ENXIO; + } + + regulators_node = fdt_subnode_offset(blob, pmic_node, "regulators"); + + if (regulators_node <= 0) { + debug("%s: %s reg subnode not found!", __func__, dev->name); + return -ENXIO; + } + + children = pmic_bind_children(dev, regulators_node, pmic_children_info); + if (!children) + debug("%s: %s - no child found\n", __func__, dev->name); + + /* Always return success for this device */ + return 0; +} + +static struct dm_pmic_ops palmas_ops = { + .read = palmas_read, + .write = palmas_write, +}; + +static const struct udevice_id palmas_ids[] = { + { .compatible = "ti,tps659038", .data = TPS659038 }, + { .compatible = "ti,tps65917" , .data = TPS65917 }, + { } +}; + +U_BOOT_DRIVER(pmic_palmas) = { + .name = "palmas_pmic", + .id = UCLASS_PMIC, + .of_match = palmas_ids, + .bind = palmas_bind, + .ops = &palmas_ops, +}; diff --git a/include/power/palmas.h b/include/power/palmas.h new file mode 100644 index 0000000..bad5a35 --- /dev/null +++ b/include/power/palmas.h @@ -0,0 +1,25 @@ +#define PALMAS 0x0 +#define TPS659038 0x1 +#define TPS65917 0x2 + +/* I2C device address for pmic palmas */ +#define PALMAS_I2C_ADDR (0x12 >> 1) +#define PALMAS_LDO_NUM 11 +#define PALMAS_SMPS_NUM 8 + +/* Drivers name */ +#define PALMAS_LDO_DRIVER "palmas_ldo" +#define PALMAS_SMPS_DRIVER "palmas_smps" + +#define PALMAS_SMPS_VOLT_MASK 0x7F +#define PALMAS_SMPS_RANGE_MASK 0x80 +#define PALMAS_SMPS_VOLT_MAX_HEX 0x7F +#define PALMAS_SMPS_VOLT_MAX 3300000 +#define PALMAS_SMPS_MODE_MASK 0x3 +#define PALMAS_SMPS_STATUS_MASK 0x30 + +#define PALMAS_LDO_VOLT_MASK 0x3F +#define PALMAS_LDO_VOLT_MAX_HEX 0x3F +#define PALMAS_LDO_VOLT_MAX 3300000 +#define PALMAS_LDO_MODE_MASK 0x1 +#define PALMAS_LDO_STATUS_MASK 0x10
Hi Keerthy,
Changes in v5:
- Added pmic read/write functions.
+config PMIC_PALMAS
depends on DM_PMIC
---help---
- (C) Copyright 2016 Texas Instruments Incorporated, <www.ti.com>
- Keerthy j-keerthy@ti.com
int len)
I think this should be dm_i2c_write(). You are only writing a single byte.
return -EIO;
int ret;
dm_i2c_read()
if (ret < 0) {
reg);
return -EIO;
return ret;
On Wednesday 28 September 2016 11:21 PM, Simon Glass wrote:
Hi Keerthy,
Changes in v5:
+config PMIC_PALMAS
depends on DM_PMIC
---help---
int len)
Now the v2 of this series had comments suggesting the opposite:
https://www.mail-archive.com/u-boot@lists.denx.de/msg225123.html
return -EIO;
int ret;
dm_i2c_read()
if (ret < 0) {
reg);
return -EIO;
return ret;
Hi Keerthy,
Changes in v5:
+config PMIC_PALMAS
depends on DM_PMIC
---help---
int len)
And i thought dm_i2c_reg_write/read was specifically introduced for writing and reading one byte value?
int dm_i2c_reg_write(struct udevice *dev, uint offset, uint value) { uint8_t val = value;
return dm_i2c_write(dev, offset, &val, 1); }
Regards, Keerthy
dev, reg);
return -EIO;
int ret;
dm_i2c_read()
if (ret < 0) {
ret, dev,
reg);
return -EIO;
return ret;
Hi Keethy,
Hi Keerthy,
Changes in v5:
+config PMIC_PALMAS
depends on DM_PMIC
---help---
int len)
Yes, but your palmas_write() function should be able to write multiple bytes. If you look at the function signature and the comments in pmic.h you should be able to see that.
On Friday 30 September 2016 05:12 AM, Simon Glass wrote:
Hi Keethy,
Hi Keerthy,
Changes in v5:
+config PMIC_PALMAS
depends on DM_PMIC
---help---
int len)
Okay.
The driver provides regulator set/get voltage enable/disable functions for palmas family of PMICs.
Changes in v5:
* Used pmic_reg_read pmic_reg_write functions instead of direct i2c calls.
drivers/power/regulator/Kconfig | 8 + drivers/power/regulator/Makefile | 1 + drivers/power/regulator/palmas_regulator.c | 453 +++++++++++++++++++++++++++++ 3 files changed, 462 insertions(+) create mode 100644 drivers/power/regulator/palmas_regulator.c
diff --git a/drivers/power/regulator/Kconfig b/drivers/power/regulator/Kconfig index 17f22dd..adb710a 100644 --- a/drivers/power/regulator/Kconfig +++ b/drivers/power/regulator/Kconfig @@ -115,3 +115,11 @@ config REGULATOR_TPS65090 regulators, one for each FET. The standard regulator interface is supported, but it is only possible to turn the regulators on or off. There is no voltage/current control. + +config DM_REGULATOR_PALMAS + bool "Enable driver for PALMAS PMIC regulators" + depends on PMIC_PALMAS + ---help--- + This enables implementation of driver-model regulator uclass + features for REGULATOR PALMAS and the family of PALMAS PMICs. + The driver implements get/set api for: value and enable. diff --git a/drivers/power/regulator/Makefile b/drivers/power/regulator/Makefile index 1590d85..75080d4 100644 --- a/drivers/power/regulator/Makefile +++ b/drivers/power/regulator/Makefile @@ -14,3 +14,4 @@ obj-$(CONFIG_REGULATOR_RK808) += rk808.o obj-$(CONFIG_REGULATOR_S5M8767) += s5m8767.o obj-$(CONFIG_DM_REGULATOR_SANDBOX) += sandbox.o obj-$(CONFIG_REGULATOR_TPS65090) += tps65090_regulator.o +obj-$(CONFIG_$(SPL_)DM_REGULATOR_PALMAS) += palmas_regulator.o diff --git a/drivers/power/regulator/palmas_regulator.c b/drivers/power/regulator/palmas_regulator.c new file mode 100644 index 0000000..cce7cd2 --- /dev/null +++ b/drivers/power/regulator/palmas_regulator.c @@ -0,0 +1,453 @@ +/* + * (C) Copyright 2016 + * Texas Instruments Incorporated, <www.ti.com> + * + * Keerthy j-keerthy@ti.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <fdtdec.h> +#include <errno.h> +#include <dm.h> +#include <i2c.h> +#include <power/pmic.h> +#include <power/regulator.h> +#include <power/palmas.h> + +DECLARE_GLOBAL_DATA_PTR; + +#define REGULATOR_ON 0x1 +#define REGULATOR_OFF 0x0 + +#define SMPS_MODE_MASK 0x3 +#define SMPS_MODE_SHIFT 0x0 +#define LDO_MODE_MASK 0x1 +#define LDO_MODE_SHIFT 0x0 + +static const char palmas_smps_ctrl[][PALMAS_SMPS_NUM] = { + {0x20, 0x24, 0x28, 0x2c, 0x30, 0x34, 0x38, 0x3c}, + {0x20, 0x24, 0x28, 0x2c, 0x30, 0x34, 0x38}, + {0x20, 0x24, 0x2c, 0x30, 0x38}, +}; + +static const char palmas_smps_volt[][PALMAS_SMPS_NUM] = { + {0x23, 0x27, 0x2b, 0x2f, 0x33, 0x37, 0x3b, 0x3c}, + {0x23, 0x27, 0x2b, 0x2f, 0x33, 0x37, 0x3b}, + {0x23, 0x27, 0x2f, 0x33, 0x3B} +}; + +static const char palmas_ldo_ctrl[][PALMAS_LDO_NUM] = { + {0x50, 0x52, 0x54, 0x56, 0x58, 0x5a, 0x5c, 0x5e, 0x60, 0x62, 0x64}, + {0x50, 0x52, 0x54, 0x56, 0x58, 0x5a, 0x5c, 0x5e, 0x60, 0x62, 0x64}, + {0x50, 0x52, 0x54, 0x5e, 0x62} +}; + +static const char palmas_ldo_volt[][PALMAS_LDO_NUM] = { + {0x51, 0x53, 0x55, 0x57, 0x59, 0x5b, 0x5d, 0x5f, 0x61, 0x63, 0x65}, + {0x51, 0x53, 0x55, 0x57, 0x59, 0x5b, 0x5d, 0x5f, 0x61, 0x63, 0x65}, + {0x51, 0x53, 0x55, 0x5f, 0x63} +}; + +static int palmas_smps_enable(struct udevice *dev, int op, bool *enable) +{ + int ret; + unsigned int adr; + struct dm_regulator_uclass_platdata *uc_pdata; + + uc_pdata = dev_get_uclass_platdata(dev); + adr = uc_pdata->ctrl_reg; + + ret = pmic_reg_read(dev->parent, adr); + if (ret < 0) + return ret; + + if (op == PMIC_OP_GET) { + ret &= PALMAS_SMPS_STATUS_MASK; + + if (ret) + *enable = true; + else + *enable = false; + + return 0; + } else if (op == PMIC_OP_SET) { + if (*enable) + ret |= PALMAS_SMPS_MODE_MASK; + else + ret &= ~(PALMAS_SMPS_MODE_MASK); + + ret = pmic_reg_write(dev->parent, adr, ret); + if (ret) + return ret; + } + + return 0; +} + +static int palmas_smps_volt2hex(int uV) +{ + if (uV > PALMAS_LDO_VOLT_MAX) + return -EINVAL; + + if (uV > 1650000) + return (uV - 1000000) / 20000 + 0x6; + + if (uV == 500000) + return 0x6; + else + return 0x6 + ((uV - 500000) / 10000); +} + +static int palmas_smps_hex2volt(int hex, bool range) +{ + unsigned int uV = 0; + + if (hex > PALMAS_SMPS_VOLT_MAX_HEX) + return -EINVAL; + + if (hex < 0x7) + uV = 500000; + else + uV = 500000 + (hex - 0x6) * 10000; + + if (range) + uV *= 2; + + return uV; +} + +static int palmas_smps_val(struct udevice *dev, int op, int *uV) +{ + unsigned int hex, adr; + int ret; + bool range; + struct dm_regulator_uclass_platdata *uc_pdata; + + uc_pdata = dev_get_uclass_platdata(dev); + + if (op == PMIC_OP_GET) + *uV = 0; + + adr = uc_pdata->volt_reg; + + ret = pmic_reg_read(dev->parent, adr); + if (ret < 0) + return ret; + + if (op == PMIC_OP_GET) { + if (ret & PALMAS_SMPS_RANGE_MASK) + range = true; + else + range = false; + + ret &= PALMAS_SMPS_VOLT_MASK; + ret = palmas_smps_hex2volt(ret, range); + if (ret < 0) + return ret; + *uV = ret; + + return 0; + } + + hex = palmas_smps_volt2hex(*uV); + if (hex < 0) + return hex; + + ret &= ~PALMAS_SMPS_VOLT_MASK; + ret |= hex; + if (*uV > 1650000) + ret |= PALMAS_SMPS_RANGE_MASK; + + return pmic_reg_write(dev->parent, adr, ret); +} + +static int palmas_ldo_enable(struct udevice *dev, int op, bool *enable) +{ + int ret; + unsigned int adr; + struct dm_regulator_uclass_platdata *uc_pdata; + + uc_pdata = dev_get_uclass_platdata(dev); + adr = uc_pdata->ctrl_reg; + + ret = pmic_reg_read(dev->parent, adr); + if (ret < 0) + return ret; + + if (op == PMIC_OP_GET) { + ret &= PALMAS_LDO_STATUS_MASK; + + if (ret) + *enable = true; + else + *enable = false; + + return 0; + } else if (op == PMIC_OP_SET) { + if (*enable) + ret |= PALMAS_LDO_MODE_MASK; + else + ret &= ~(PALMAS_LDO_MODE_MASK); + + ret = pmic_reg_write(dev->parent, adr, ret); + if (ret) + return ret; + } + + return 0; +} + +static int palmas_ldo_volt2hex(int uV) +{ + if (uV > PALMAS_LDO_VOLT_MAX) + return -EINVAL; + + return (uV - 850000) / 50000; +} + +static int palmas_ldo_hex2volt(int hex) +{ + if (hex > PALMAS_LDO_VOLT_MAX_HEX) + return -EINVAL; + + if (!hex) + return 0; + + return (hex * 50000) + 850000; +} + +static int palmas_ldo_val(struct udevice *dev, int op, int *uV) +{ + unsigned int hex, adr; + int ret; + + struct dm_regulator_uclass_platdata *uc_pdata; + + if (op == PMIC_OP_GET) + *uV = 0; + + uc_pdata = dev_get_uclass_platdata(dev); + + adr = uc_pdata->volt_reg; + + ret = pmic_reg_read(dev->parent, adr); + if (ret < 0) + return ret; + + if (op == PMIC_OP_GET) { + ret &= PALMAS_LDO_VOLT_MASK; + ret = palmas_ldo_hex2volt(ret); + if (ret < 0) + return ret; + *uV = ret; + return 0; + } + + hex = palmas_ldo_volt2hex(*uV); + if (hex < 0) + return hex; + + ret &= ~PALMAS_LDO_VOLT_MASK; + ret |= hex; + if (*uV > 1650000) + ret |= 0x80; + + return pmic_reg_write(dev->parent, adr, ret); +} + +static int palmas_ldo_probe(struct udevice *dev) +{ + struct dm_regulator_uclass_platdata *uc_pdata; + struct udevice *parent; + + uc_pdata = dev_get_uclass_platdata(dev); + + parent = dev_get_parent(dev); + int type = dev_get_driver_data(parent); + + uc_pdata->type = REGULATOR_TYPE_LDO; + + if (dev->driver_data) { + u8 idx = dev->driver_data - 1; + uc_pdata->ctrl_reg = palmas_ldo_ctrl[type][idx]; + uc_pdata->volt_reg = palmas_ldo_volt[type][idx]; + } else { + /* check for ldoln and ldousb cases */ + if (!strcmp("ldoln", dev->name)) { + uc_pdata->ctrl_reg = palmas_ldo_ctrl[type][9]; + uc_pdata->volt_reg = palmas_ldo_volt[type][9]; + } else if (!strcmp("ldousb", dev->name)) { + uc_pdata->ctrl_reg = palmas_ldo_ctrl[type][10]; + uc_pdata->volt_reg = palmas_ldo_volt[type][10]; + } + } + + return 0; +} + +static int ldo_get_value(struct udevice *dev) +{ + int uV; + int ret; + + ret = palmas_ldo_val(dev, PMIC_OP_GET, &uV); + if (ret) + return ret; + + return uV; +} + +static int ldo_set_value(struct udevice *dev, int uV) +{ + return palmas_ldo_val(dev, PMIC_OP_SET, &uV); +} + +static bool ldo_get_enable(struct udevice *dev) +{ + bool enable = false; + int ret; + + ret = palmas_ldo_enable(dev, PMIC_OP_GET, &enable); + if (ret) + return ret; + + return enable; +} + +static int ldo_set_enable(struct udevice *dev, bool enable) +{ + return palmas_ldo_enable(dev, PMIC_OP_SET, &enable); +} + +static int palmas_smps_probe(struct udevice *dev) +{ + struct dm_regulator_uclass_platdata *uc_pdata; + struct udevice *parent; + int idx; + + uc_pdata = dev_get_uclass_platdata(dev); + + parent = dev_get_parent(dev); + int type = dev_get_driver_data(parent); + + uc_pdata->type = REGULATOR_TYPE_BUCK; + + switch (type) { + case PALMAS: + case TPS659038: + switch (dev->driver_data) { + case 123: + case 12: + uc_pdata->ctrl_reg = palmas_smps_ctrl[type][0]; + uc_pdata->volt_reg = palmas_smps_volt[type][0]; + break; + case 3: + uc_pdata->ctrl_reg = palmas_smps_ctrl[type][1]; + uc_pdata->volt_reg = palmas_smps_volt[type][1]; + break; + case 45: + uc_pdata->ctrl_reg = palmas_smps_ctrl[type][2]; + uc_pdata->volt_reg = palmas_smps_volt[type][2]; + break; + case 6: + case 7: + case 8: + case 9: + case 10: + idx = dev->driver_data - 4; + uc_pdata->ctrl_reg = palmas_smps_ctrl[type][idx]; + uc_pdata->volt_reg = palmas_smps_volt[type][idx]; + break; + + default: + printf("Wrong ID for regulator\n"); + } + break; + + case TPS65917: + switch (dev->driver_data) { + case 1: + case 2: + case 3: + case 4: + case 5: + idx = dev->driver_data - 1; + uc_pdata->ctrl_reg = palmas_smps_ctrl[type][idx]; + uc_pdata->volt_reg = palmas_smps_volt[type][idx]; + break; + + default: + printf("Wrong ID for regulator\n"); + } + break; + + default: + printf("Invalid PMIC ID\n"); + } + + return 0; +} + +static int smps_get_value(struct udevice *dev) +{ + int uV; + int ret; + + ret = palmas_smps_val(dev, PMIC_OP_GET, &uV); + if (ret) + return ret; + + return uV; +} + +static int smps_set_value(struct udevice *dev, int uV) +{ + return palmas_smps_val(dev, PMIC_OP_SET, &uV); +} + +static bool smps_get_enable(struct udevice *dev) +{ + bool enable = false; + int ret; + + ret = palmas_smps_enable(dev, PMIC_OP_GET, &enable); + if (ret) + return ret; + + return enable; +} + +static int smps_set_enable(struct udevice *dev, bool enable) +{ + return palmas_smps_enable(dev, PMIC_OP_SET, &enable); +} + +static const struct dm_regulator_ops palmas_ldo_ops = { + .get_value = ldo_get_value, + .set_value = ldo_set_value, + .get_enable = ldo_get_enable, + .set_enable = ldo_set_enable, +}; + +U_BOOT_DRIVER(palmas_ldo) = { + .name = PALMAS_LDO_DRIVER, + .id = UCLASS_REGULATOR, + .ops = &palmas_ldo_ops, + .probe = palmas_ldo_probe, +}; + +static const struct dm_regulator_ops palmas_smps_ops = { + .get_value = smps_get_value, + .set_value = smps_set_value, + .get_enable = smps_get_enable, + .set_enable = smps_set_enable, +}; + +U_BOOT_DRIVER(palmas_smps) = { + .name = PALMAS_SMPS_DRIVER, + .id = UCLASS_REGULATOR, + .ops = &palmas_smps_ops, + .probe = palmas_smps_probe, +};
Enable palmas PMIC config options.
Signed-off-by: Keerthy j-keerthy@ti.com Reviewed-by: Tom Rini trini@konsulko.com --- configs/dra7xx_evm_defconfig | 3 +++ 1 file changed, 3 insertions(+)
diff --git a/configs/dra7xx_evm_defconfig b/configs/dra7xx_evm_defconfig index c74dc18..4af1b03 100644 --- a/configs/dra7xx_evm_defconfig +++ b/configs/dra7xx_evm_defconfig @@ -50,8 +50,11 @@ CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_BAR=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_DM_ETH=y +CONFIG_DM_PMIC=y +CONFIG_PMIC_PALMAS=y CONFIG_DM_REGULATOR=y CONFIG_DM_REGULATOR_FIXED=y +CONFIG_DM_REGULATOR_PALMAS=y CONFIG_DM_SERIAL=y CONFIG_SYS_NS16550=y CONFIG_DM_SPI=y
Signed-off-by: Keerthy j-keerthy@ti.com Reviewed-by: Tom Rini trini@konsulko.com --- configs/am57xx_evm_defconfig | 3 +++ 1 file changed, 3 insertions(+)
diff --git a/configs/am57xx_evm_defconfig b/configs/am57xx_evm_defconfig index 27ea472..6c60d9b 100644 --- a/configs/am57xx_evm_defconfig +++ b/configs/am57xx_evm_defconfig @@ -43,6 +43,9 @@ CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_BAR=y CONFIG_SPI_FLASH_SPANSION=y +CONFIG_DM_PMIC=y +CONFIG_PMIC_PALMAS=y +CONFIG_DM_REGULATOR_PALMAS=y CONFIG_DM_SERIAL=y CONFIG_SYS_NS16550=y CONFIG_DM_SPI=y
Enable CMD_REG option.
Signed-off-by: Keerthy j-keerthy@ti.com --- configs/am57xx_evm_defconfig | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/configs/am57xx_evm_defconfig b/configs/am57xx_evm_defconfig index 6c60d9b..38424e6 100644 --- a/configs/am57xx_evm_defconfig +++ b/configs/am57xx_evm_defconfig @@ -28,6 +28,7 @@ CONFIG_CMD_GPIO=y CONFIG_CMD_DHCP=y CONFIG_CMD_MII=y CONFIG_CMD_PING=y +CONFIG_CMD_REGULATOR=y CONFIG_CMD_EXT2=y CONFIG_CMD_EXT4=y CONFIG_CMD_EXT4_WRITE=y @@ -45,6 +46,7 @@ CONFIG_SPI_FLASH_BAR=y CONFIG_SPI_FLASH_SPANSION=y CONFIG_DM_PMIC=y CONFIG_PMIC_PALMAS=y +CONFIG_DM_REGULATOR=y CONFIG_DM_REGULATOR_PALMAS=y CONFIG_DM_SERIAL=y CONFIG_SYS_NS16550=y
Simon,
I have removed direct i2c read/write calls from regulator driver and introduced pmic read/write functions. Let me know if you are okay with series.
Regards, Keerthy
Changes in v5:
Changes in v4:
Changes in v3:
Keerthy
Keerthy
