[U-Boot] [PATCH v3 0/3] net: fec_mxc: Convert to DM
This series convert fec_mxc to DM and tested both dm and non-dm code. This is on top of engicam qdl[1]
Changes for v3: - Add ARM: dts: imx6qdl-icore: Add FEC support - icorem6: Use CONFIG_DM_ETH support Changes for v2: - Add TODO for implementing the enet reset code
[1] https://www.mail-archive.com/u-boot@lists.denx.de/msg226671.html
Jagan Teki (3): net: fec_mxc: Convert into driver model ARM: dts: imx6qdl-icore: Add FEC support icorem6: Use CONFIG_DM_ETH support
arch/arm/cpu/armv7/mx6/Kconfig | 1 + arch/arm/dts/imx6qdl-icore.dtsi | 24 +++ board/engicam/icorem6/icorem6.c | 71 --------- configs/imx6qdl_icore_mmc_defconfig | 1 - configs/imx6qdl_icore_nand_defconfig | 1 - drivers/net/fec_mxc.c | 273 +++++++++++++++++++++++++++++++---- drivers/net/fec_mxc.h | 11 ++ 7 files changed, 283 insertions(+), 99 deletions(-)
This patch add driver model support for fec_mxc driver.
Cc: Simon Glass sjg@chromium.org Cc: Joe Hershberger joe.hershberger@ni.com Cc: Peng Fan peng.fan@nxp.com Cc: Stefano Babic sbabic@denx.de Cc: Michael Trimarchi michael@amarulasolutions.com Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- drivers/net/fec_mxc.c | 273 +++++++++++++++++++++++++++++++++++++++++++++----- drivers/net/fec_mxc.h | 11 ++ 2 files changed, 258 insertions(+), 26 deletions(-)
diff --git a/drivers/net/fec_mxc.c b/drivers/net/fec_mxc.c index e871b3e..d4f6a08 100644 --- a/drivers/net/fec_mxc.c +++ b/drivers/net/fec_mxc.c @@ -9,6 +9,7 @@ */
#include <common.h> +#include <dm.h> #include <malloc.h> #include <memalign.h> #include <net.h> @@ -362,17 +363,32 @@ static void fec_rbd_clean(int last, struct fec_bd *pRbd) writew(0, &pRbd->data_length); }
+#ifdef CONFIG_DM_ETH +static int fec_get_hwaddr(struct udevice *dev, int dev_id, + unsigned char *mac) +#else static int fec_get_hwaddr(struct eth_device *dev, int dev_id, unsigned char *mac) +#endif { imx_get_mac_from_fuse(dev_id, mac); return !is_valid_ethaddr(mac); }
+#ifdef CONFIG_DM_ETH +static int fecmxc_set_hwaddr(struct udevice *dev) +#else static int fec_set_hwaddr(struct eth_device *dev) +#endif { +#ifdef CONFIG_DM_ETH + struct fec_priv *fec = dev_get_priv(dev); + struct eth_pdata *pdata = dev_get_platdata(dev); + uchar *mac = pdata->enetaddr; +#else uchar *mac = dev->enetaddr; struct fec_priv *fec = (struct fec_priv *)dev->priv; +#endif
writel(0, &fec->eth->iaddr1); writel(0, &fec->eth->iaddr2); @@ -427,9 +443,17 @@ static void fec_reg_setup(struct fec_priv *fec) * Start the FEC engine * @param[in] dev Our device to handle */ +#ifdef CONFIG_DM_ETH +static int fec_open(struct udevice *dev) +#else static int fec_open(struct eth_device *edev) +#endif { +#ifdef CONFIG_DM_ETH + struct fec_priv *fec = dev_get_priv(dev); +#else struct fec_priv *fec = (struct fec_priv *)edev->priv; +#endif int speed; uint32_t addr, size; int i; @@ -535,14 +559,26 @@ static int fec_open(struct eth_device *edev) return 0; }
+#ifdef CONFIG_DM_ETH +static int fecmxc_init(struct udevice *dev) +#else static int fec_init(struct eth_device *dev, bd_t* bd) +#endif { +#ifdef CONFIG_DM_ETH + struct fec_priv *fec = dev_get_priv(dev); +#else struct fec_priv *fec = (struct fec_priv *)dev->priv; +#endif uint32_t mib_ptr = (uint32_t)&fec->eth->rmon_t_drop; int i;
/* Initialize MAC address */ +#ifdef CONFIG_DM_ETH + fecmxc_set_hwaddr(dev); +#else fec_set_hwaddr(dev); +#endif
/* * Setup transmit descriptors, there are two in total. @@ -596,9 +632,17 @@ static int fec_init(struct eth_device *dev, bd_t* bd) * Halt the FEC engine * @param[in] dev Our device to handle */ +#ifdef CONFIG_DM_ETH +static void fecmxc_halt(struct udevice *dev) +#else static void fec_halt(struct eth_device *dev) +#endif { +#ifdef CONFIG_DM_ETH + struct fec_priv *fec = dev_get_priv(dev); +#else struct fec_priv *fec = (struct fec_priv *)dev->priv; +#endif int counter = 0xffff;
/* @@ -638,7 +682,11 @@ static void fec_halt(struct eth_device *dev) * @param[in] length Data count in bytes * @return 0 on success */ +#ifdef CONFIG_DM_ETH +static int fecmxc_send(struct udevice *dev, void *packet, int length) +#else static int fec_send(struct eth_device *dev, void *packet, int length) +#endif { unsigned int status; uint32_t size, end; @@ -650,7 +698,11 @@ static int fec_send(struct eth_device *dev, void *packet, int length) * This routine transmits one frame. This routine only accepts * 6-byte Ethernet addresses. */ +#ifdef CONFIG_DM_ETH + struct fec_priv *fec = dev_get_priv(dev); +#else struct fec_priv *fec = (struct fec_priv *)dev->priv; +#endif
/* * Check for valid length of data. @@ -783,9 +835,17 @@ out: * @param[in] dev Our ethernet device to handle * @return Length of packet read */ +#ifdef CONFIG_DM_ETH +static int fecmxc_recv(struct udevice *dev, int flags, uchar **packetp) +#else static int fec_recv(struct eth_device *dev) +#endif { +#ifdef CONFIG_DM_ETH + struct fec_priv *fec = dev_get_priv(dev); +#else struct fec_priv *fec = (struct fec_priv *)dev->priv; +#endif struct fec_bd *rbd = &fec->rbd_base[fec->rbd_index]; unsigned long ievent; int frame_length, len = 0; @@ -801,8 +861,13 @@ static int fec_recv(struct eth_device *dev) writel(ievent, &fec->eth->ievent); debug("fec_recv: ievent 0x%lx\n", ievent); if (ievent & FEC_IEVENT_BABR) { +#ifdef CONFIG_DM_ETH + fecmxc_halt(dev); + fecmxc_init(dev); +#else fec_halt(dev); fec_init(dev, fec->bd); +#endif printf("some error: 0x%08lx\n", ievent); return 0; } @@ -814,10 +879,18 @@ static int fec_recv(struct eth_device *dev) if (ievent & FEC_IEVENT_GRA) { /* Graceful stop complete */ if (readl(&fec->eth->x_cntrl) & 0x00000001) { +#ifdef CONFIG_DM_ETH + fecmxc_halt(dev); +#else fec_halt(dev); +#endif writel(~0x00000001 & readl(&fec->eth->x_cntrl), &fec->eth->x_cntrl); +#ifdef CONFIG_DM_ETH + fecmxc_init(dev); +#else fec_init(dev, fec->bd); +#endif } }
@@ -971,6 +1044,33 @@ static void fec_free_descs(struct fec_priv *fec) free(fec->tbd_base); }
+struct mii_dev *fec_get_miibus(uint32_t base_addr, int dev_id) +{ + struct ethernet_regs *eth = (struct ethernet_regs *)base_addr; + struct mii_dev *bus; + int ret; + + bus = mdio_alloc(); + if (!bus) { + printf("mdio_alloc failed\n"); + return NULL; + } + bus->read = fec_phy_read; + bus->write = fec_phy_write; + bus->priv = eth; + fec_set_dev_name(bus->name, dev_id); + + ret = mdio_register(bus); + if (ret) { + printf("mdio_register failed\n"); + free(bus); + return NULL; + } + fec_mii_setspeed(eth); + return bus; +} + +#ifndef CONFIG_DM_ETH #ifdef CONFIG_PHYLIB int fec_probe(bd_t *bd, int dev_id, uint32_t base_addr, struct mii_dev *bus, struct phy_device *phydev) @@ -1062,32 +1162,6 @@ err1: return ret; }
-struct mii_dev *fec_get_miibus(uint32_t base_addr, int dev_id) -{ - struct ethernet_regs *eth = (struct ethernet_regs *)base_addr; - struct mii_dev *bus; - int ret; - - bus = mdio_alloc(); - if (!bus) { - printf("mdio_alloc failed\n"); - return NULL; - } - bus->read = fec_phy_read; - bus->write = fec_phy_write; - bus->priv = eth; - fec_set_dev_name(bus->name, dev_id); - - ret = mdio_register(bus); - if (ret) { - printf("mdio_register failed\n"); - free(bus); - return NULL; - } - fec_mii_setspeed(eth); - return bus; -} - int fecmxc_initialize_multi(bd_t *bd, int dev_id, int phy_id, uint32_t addr) { uint32_t base_mii; @@ -1147,3 +1221,150 @@ int fecmxc_register_mii_postcall(struct eth_device *dev, int (*cb)(int)) return 0; } #endif + +#else + +static const struct eth_ops fecmxc_ops = { + .start = fecmxc_init, + .send = fecmxc_send, + .recv = fecmxc_recv, + .stop = fecmxc_halt, + .write_hwaddr = fecmxc_set_hwaddr, +}; + +static int fec_phy_init(struct fec_priv *priv, struct udevice *dev) +{ + struct phy_device *phydev; + int mask = 0xffffffff; + +#ifdef CONFIG_PHYLIB + mask = 1 << CONFIG_FEC_MXC_PHYADDR; +#endif + + phydev = phy_find_by_mask(priv->bus, mask, priv->interface); + if (!phydev) + return -ENODEV; + + phy_connect_dev(phydev, dev); + + priv->phydev = phydev; + phy_config(phydev); + + return 0; +} + +static int fecmxc_probe(struct udevice *dev) +{ + struct eth_pdata *pdata = dev_get_platdata(dev); + struct fec_priv *priv = dev_get_priv(dev); + struct mii_dev *bus = NULL; + int dev_id = -1; + unsigned char ethaddr[6]; + uint32_t start; + int ret; + + ret = fec_alloc_descs(priv); + if (ret) + return ret; + + bus = fec_get_miibus((uint32_t)priv->eth, dev_id); + if (!bus) + goto err_mii; + + priv->bus = bus; + priv->xcv_type = CONFIG_FEC_XCV_TYPE; + priv->interface = pdata->phy_interface; + ret = fec_phy_init(priv, dev); + if (ret) + goto err_phy; + + /* Reset chip. */ + writel(readl(&priv->eth->ecntrl) | FEC_ECNTRL_RESET, &priv->eth->ecntrl); + start = get_timer(0); + while (readl(&priv->eth->ecntrl) & FEC_ECNTRL_RESET) { + if (get_timer(start) > (CONFIG_SYS_HZ * 5)) { + printf("FEC MXC: Timeout reseting chip\n"); + goto err_timeout; + } + udelay(10); + } + + fec_reg_setup(priv); + fec_set_dev_name((char *)dev->name, dev_id); + priv->dev_id = (dev_id == -1) ? 0 : dev_id; + + ret = fec_get_hwaddr(dev, dev_id, ethaddr); + if (!ret) { + debug("got MAC%d address from fuse: %pM\n", dev_id, ethaddr); + memcpy(pdata->enetaddr, ethaddr, 6); + if (!getenv("ethaddr")) + eth_setenv_enetaddr("ethaddr", ethaddr); + } + + return 0; + +err_timeout: + free(priv->phydev); +err_phy: + mdio_unregister(bus); + free(bus); +err_mii: + fec_free_descs(priv); + return ret; +} + +static int fecmxc_remove(struct udevice *dev) +{ + struct fec_priv *priv = dev_get_priv(dev); + + free(priv->phydev); + fec_free_descs(priv); + mdio_unregister(priv->bus); + mdio_free(priv->bus); + + return 0; +} + +static int fecmxc_ofdata_to_platdata(struct udevice *dev) +{ + struct eth_pdata *pdata = dev_get_platdata(dev); + struct fec_priv *priv = dev_get_priv(dev); + const char *phy_mode; + + pdata->iobase = (phys_addr_t)dev_get_addr(dev); + priv->eth = (struct ethernet_regs *)pdata->iobase; + + pdata->phy_interface = -1; + phy_mode = fdt_getprop(gd->fdt_blob, dev->of_offset, "phy-mode", NULL); + if (phy_mode) + pdata->phy_interface = phy_get_interface_by_name(phy_mode); + if (pdata->phy_interface == -1) { + debug("%s: Invalid PHY interface '%s'\n", __func__, phy_mode); + return -EINVAL; + } + + /* TODO + * Need to get the reset-gpio and related properties from DT + * and implemet the enet reset code on .probe call + */ + + return 0; +} + +static const struct udevice_id fecmxc_ids[] = { + { .compatible = "fsl,imx6q-fec" }, + { } +}; + +U_BOOT_DRIVER(fecmxc_gem) = { + .name = "fecmxc", + .id = UCLASS_ETH, + .of_match = fecmxc_ids, + .ofdata_to_platdata = fecmxc_ofdata_to_platdata, + .probe = fecmxc_probe, + .remove = fecmxc_remove, + .ops = &fecmxc_ops, + .priv_auto_alloc_size = sizeof(struct fec_priv), + .platdata_auto_alloc_size = sizeof(struct eth_pdata), +}; +#endif diff --git a/drivers/net/fec_mxc.h b/drivers/net/fec_mxc.h index 0717cc6..84f4149 100644 --- a/drivers/net/fec_mxc.h +++ b/drivers/net/fec_mxc.h @@ -18,6 +18,10 @@ #ifndef __FEC_MXC_H #define __FEC_MXC_H
+#ifdef CONFIG_DM_GPIO +#include <asm-generic/gpio.h> +#endif + void imx_get_mac_from_fuse(int dev_id, unsigned char *mac);
/** @@ -264,6 +268,13 @@ struct fec_priv { int phy_id; int (*mii_postcall)(int); #endif + +#ifdef CONFIG_DM_GPIO + struct gpio_desc reset_gpio; +#endif +#ifdef CONFIG_DM_ETH + u32 interface; +#endif };
I think you would have an easier time if you move all the common code into common functions, and just have stubs for the legacy and new DM path. For example fecmxc_probe() is repeating code. There really should be almost no duplicated code in the driver. It just makes it hard to maintain, and understand what is happening.
I think it is best to avoid renaming the functions. So for example:
#ifdef CONFIG_DM_ETH static int fecmxc_recv(struct udevice *dev, int flags, uchar **packetp) #else static int fec_recv(struct eth_device *dev) #endif {
You may as well keep the name the same - fec_recv().
In one case you have not put the DM_ETH case first. It should be:
#ifdef CONFIG_DM_ETH ... #else #endif
rather than:
#ifndef CONFIG_DM_ETH ... #else #endif
I'm not sure you are dealing with all the cases. Unfortunately the driver already has #idefs. For example if CONFIG_PHYLIB is not defined. With CONFIG_DM_ETH, struct eth_device will not be available, so you need to make sure no code builds with that.
Also fecmxc_recv() does not appear to work. It needs to set packetp and return a packet length. Also, do you need a free_pkt()?
Add FEC dts support for Engicam i.CoreM6 dql modules.
Cc: Joe Hershberger joe.hershberger@ni.com Cc: Stefano Babic sbabic@denx.de Cc: Matteo Lisi matteo.lisi@engicam.com Cc: Michael Trimarchi michael@amarulasolutions.com Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- arch/arm/dts/imx6qdl-icore.dtsi | 24 ++++++++++++++++++++++++ 1 file changed, 24 insertions(+)
diff --git a/arch/arm/dts/imx6qdl-icore.dtsi b/arch/arm/dts/imx6qdl-icore.dtsi index f424cd5..a485c3e 100644 --- a/arch/arm/dts/imx6qdl-icore.dtsi +++ b/arch/arm/dts/imx6qdl-icore.dtsi @@ -75,6 +75,14 @@ assigned-clock-parents = <&clks IMX6QDL_CLK_OSC>; };
+&fec { + pinctrl-names = "default"; + pinctrl-0 = <&pinctrl_enet>; + phy-reset-gpios = <&gpio7 12 GPIO_ACTIVE_LOW>; + phy-mode = "rmii"; + status = "okay"; +}; + &gpmi { pinctrl-names = "default"; pinctrl-0 = <&pinctrl_gpmi_nand>; @@ -118,6 +126,22 @@ };
&iomuxc { + pinctrl_enet: enetgrp { + fsl,pins = < + MX6QDL_PAD_ENET_CRS_DV__ENET_RX_EN 0x1b0b0 + MX6QDL_PAD_GPIO_16__ENET_REF_CLK 0x1b0b1 + MX6QDL_PAD_ENET_TX_EN__ENET_TX_EN 0x1b0b0 + MX6QDL_PAD_ENET_RXD1__ENET_RX_DATA1 0x1b0b0 + MX6QDL_PAD_ENET_RXD0__ENET_RX_DATA0 0x1b0b0 + MX6QDL_PAD_ENET_TXD1__ENET_TX_DATA1 0x1b0b0 + MX6QDL_PAD_ENET_TXD0__ENET_TX_DATA0 0x1b0b0 + MX6QDL_PAD_ENET_MDC__ENET_MDC 0x1b0b0 + MX6QDL_PAD_ENET_MDIO__ENET_MDIO 0x1b0b0 + MX6QDL_PAD_ENET_REF_CLK__GPIO1_IO23 0x1b0b0 + MX6QDL_PAD_GPIO_17__GPIO7_IO12 0x1b0b0 + >; + }; + pinctrl_flexcan1: flexcan1grp { fsl,pins = < MX6QDL_PAD_KEY_ROW2__FLEXCAN1_RX 0x1b020
Use CONFIG_DM_ETH and remove board_eth_init code from board files.
Cc: Joe Hershberger joe.hershberger@ni.com Cc: Peng Fan peng.fan@nxp.com Cc: Stefano Babic sbabic@denx.de Cc: Michael Trimarchi michael@amarulasolutions.com Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- arch/arm/cpu/armv7/mx6/Kconfig | 1 + board/engicam/icorem6/icorem6.c | 71 ------------------------------------ configs/imx6qdl_icore_mmc_defconfig | 1 - configs/imx6qdl_icore_nand_defconfig | 1 - 4 files changed, 1 insertion(+), 73 deletions(-)
diff --git a/arch/arm/cpu/armv7/mx6/Kconfig b/arch/arm/cpu/armv7/mx6/Kconfig index 762a581..8456b0e 100644 --- a/arch/arm/cpu/armv7/mx6/Kconfig +++ b/arch/arm/cpu/armv7/mx6/Kconfig @@ -100,6 +100,7 @@ config TARGET_MX6Q_ICORE select MX6QDL select OF_CONTROL select DM + select DM_ETH select DM_GPIO select DM_MMC select DM_THERMAL diff --git a/board/engicam/icorem6/icorem6.c b/board/engicam/icorem6/icorem6.c index c152007..587775e 100644 --- a/board/engicam/icorem6/icorem6.c +++ b/board/engicam/icorem6/icorem6.c @@ -7,8 +7,6 @@ */
#include <common.h> -#include <miiphy.h> -#include <netdev.h>
#include <asm/io.h> #include <asm/gpio.h> @@ -27,80 +25,11 @@ DECLARE_GLOBAL_DATA_PTR; PAD_CTL_PUS_100K_UP | PAD_CTL_SPEED_MED | \ PAD_CTL_DSE_40ohm | PAD_CTL_SRE_FAST | PAD_CTL_HYS)
-#define ENET_PAD_CTRL (PAD_CTL_PKE | PAD_CTL_PUE | \ - PAD_CTL_PUS_100K_UP | PAD_CTL_SPEED_MED | \ - PAD_CTL_DSE_40ohm | PAD_CTL_HYS) - static iomux_v3_cfg_t const uart4_pads[] = { IOMUX_PADS(PAD_KEY_COL0__UART4_TX_DATA | MUX_PAD_CTRL(UART_PAD_CTRL)), IOMUX_PADS(PAD_KEY_ROW0__UART4_RX_DATA | MUX_PAD_CTRL(UART_PAD_CTRL)), };
-static iomux_v3_cfg_t const enet_pads[] = { - IOMUX_PADS(PAD_ENET_CRS_DV__ENET_RX_EN | MUX_PAD_CTRL(ENET_PAD_CTRL)), - IOMUX_PADS(PAD_GPIO_16__ENET_REF_CLK | MUX_PAD_CTRL(ENET_PAD_CTRL | PAD_CTL_SRE_FAST)), - IOMUX_PADS(PAD_ENET_TX_EN__ENET_TX_EN | MUX_PAD_CTRL(ENET_PAD_CTRL)), - IOMUX_PADS(PAD_ENET_RXD1__ENET_RX_DATA1 | MUX_PAD_CTRL(ENET_PAD_CTRL)), - IOMUX_PADS(PAD_ENET_RXD0__ENET_RX_DATA0 | MUX_PAD_CTRL(ENET_PAD_CTRL)), - IOMUX_PADS(PAD_ENET_TXD1__ENET_TX_DATA1 | MUX_PAD_CTRL(ENET_PAD_CTRL)), - IOMUX_PADS(PAD_ENET_TXD0__ENET_TX_DATA0 | MUX_PAD_CTRL(ENET_PAD_CTRL)), - IOMUX_PADS(PAD_ENET_MDC__ENET_MDC | MUX_PAD_CTRL(ENET_PAD_CTRL)), - IOMUX_PADS(PAD_ENET_MDIO__ENET_MDIO | MUX_PAD_CTRL(ENET_PAD_CTRL)), - IOMUX_PADS(PAD_GPIO_17__GPIO7_IO12 | MUX_PAD_CTRL(NO_PAD_CTRL)), -}; - -#ifdef CONFIG_FEC_MXC -#define ENET_PHY_RST IMX_GPIO_NR(7, 12) -static int setup_fec(void) -{ - struct mxc_ccm_reg *ccm = (struct mxc_ccm_reg *)CCM_BASE_ADDR; - struct anatop_regs *anatop = (struct anatop_regs *)ANATOP_BASE_ADDR; - s32 timeout = 100000; - u32 reg = 0; - int ret; - - /* Enable fec clock */ - setbits_le32(&ccm->CCGR1, MXC_CCM_CCGR1_ENET_MASK); - - /* use 50MHz */ - ret = enable_fec_anatop_clock(0, ENET_50MHZ); - if (ret) - return ret; - - /* Enable PLLs */ - reg = readl(&anatop->pll_enet); - reg &= ~BM_ANADIG_PLL_SYS_POWERDOWN; - writel(reg, &anatop->pll_enet); - reg = readl(&anatop->pll_enet); - reg |= BM_ANADIG_PLL_SYS_ENABLE; - while (timeout--) { - if (readl(&anatop->pll_enet) & BM_ANADIG_PLL_SYS_LOCK) - break; - } - if (timeout <= 0) - return -EIO; - reg &= ~BM_ANADIG_PLL_SYS_BYPASS; - writel(reg, &anatop->pll_enet); - - /* reset the phy */ - gpio_direction_output(ENET_PHY_RST, 0); - udelay(10000); - gpio_set_value(ENET_PHY_RST, 1); - - return 0; -} - -int board_eth_init(bd_t *bis) -{ - int ret; - - SETUP_IOMUX_PADS(enet_pads); - setup_fec(); - - return ret = cpu_eth_init(bis); -} -#endif - #ifdef CONFIG_NAND_MXS
#define GPMI_PAD_CTRL0 (PAD_CTL_PKE | PAD_CTL_PUE | PAD_CTL_PUS_100K_UP) diff --git a/configs/imx6qdl_icore_mmc_defconfig b/configs/imx6qdl_icore_mmc_defconfig index b2d8cdf..a8199d5 100644 --- a/configs/imx6qdl_icore_mmc_defconfig +++ b/configs/imx6qdl_icore_mmc_defconfig @@ -28,7 +28,6 @@ CONFIG_CMD_FS_GENERIC=y CONFIG_OF_LIBFDT=y CONFIG_FEC_MXC=y CONFIG_MXC_UART=y -CONFIG_NETDEVICES=y CONFIG_IMX_THERMAL=y CONFIG_PINCTRL=y CONFIG_PINCTRL_IMX6=y diff --git a/configs/imx6qdl_icore_nand_defconfig b/configs/imx6qdl_icore_nand_defconfig index ca4ff0f..45f4808 100644 --- a/configs/imx6qdl_icore_nand_defconfig +++ b/configs/imx6qdl_icore_nand_defconfig @@ -24,7 +24,6 @@ CONFIG_OF_LIBFDT=y CONFIG_FEC_MXC=y CONFIG_MXC_UART=y CONFIG_NAND_MXS=y -CONFIG_NETDEVICES=y CONFIG_IMX_THERMAL=y CONFIG_PINCTRL=y CONFIG_PINCTRL_IMX6=y
Jagan Teki
