[U-Boot] Pull request, u-boot-tegra/master
Tom,
Please pull u-boot-tegra/master into U-Boot/master. Thanks!
All Tegra builds are OK, and Stephen's automated test system reports that all tests pass.
The following changes since commit f5fd45ff64e28a73499548358e3d1ceda0de7daf:
Merge branch 'master' of git://www.denx.de/git/u-boot-imx (2016-10-08 09:33:37 -0400)
git://git.denx.de/u-boot-tegra.git master
for you to fetch changes up to d40d69ee350b62af90c2b522e05cbb3eb5f27112:
ARM: tegra: reduce DRAM size mapped into MMU on ARM64 (2016-10-10 11:00:03 -0700)
---------------------------------------------------------------- Marcel Ziswiler (5): tegra: usb gadget: fix ci udc operation if not hostpc capable simple panel: fix spelling of debug message regulator: fixed: honour optionality of enable gpio colibri_t20: fix display configuration colibri_t20: fix usb operation and controller order
Stephen Warren (1): ARM: tegra: reduce DRAM size mapped into MMU on ARM64
arch/arm/dts/tegra20-colibri.dts | 117 +++++++++++++++++++----------- arch/arm/mach-tegra/arm64-mmu.c | 2 +- drivers/power/regulator/fixed.c | 21 ++++-- drivers/video/simple_panel.c | 2 +- include/configs/tegra-common-usb-gadget.h | 2 + 5 files changed, 94 insertions(+), 50 deletions(-)
On Mon, Oct 10, 2016 at 01:55:22PM -0700, Tom Warren wrote:
Tom,
Tom Warren
