[U-Boot] [PATCH v2] ARM: kirkwood: disable dcache for Kirkwood boards
Prior to commit 93b283d49f93 ("ARM: CPU: arm926ejs: Consolidate cache routines to common file") the kirkwood boards didn't have and dcache support. The network and usb drivers rely on this. Set CONFIG_SYS_DCACHE_OFF in the Kirkwood specific config.h.
Reported-by: Leigh Brown leigh@solinno.co.uk Signed-off-by: Chris Packham judge.packham@gmail.com ---
Changes in v2: - expand the comment in config.h to provide more info
arch/arm/mach-kirkwood/include/mach/config.h | 6 ++++++ 1 file changed, 6 insertions(+)
diff --git a/arch/arm/mach-kirkwood/include/mach/config.h b/arch/arm/mach-kirkwood/include/mach/config.h index fcd903887bff..aea60688c2d3 100644 --- a/arch/arm/mach-kirkwood/include/mach/config.h +++ b/arch/arm/mach-kirkwood/include/mach/config.h @@ -26,6 +26,12 @@ #define CONFIG_KIRKWOOD_EGIGA_INIT /* Enable GbePort0/1 for kernel */ #define CONFIG_KIRKWOOD_RGMII_PAD_1V8 /* Set RGMII Pad voltage to 1.8V */ #define CONFIG_KIRKWOOD_PCIE_INIT /* Enable PCIE Port0 for kernel */ +/* + * Disable the dcache. Currently the network driver (mvgbe.c) and USB + * EHCI driver (ehci-marvell.c) and possibly others rely on the data + * cache being disabled. + */ +#define CONFIG_SYS_DCACHE_OFF
/* * By default kwbimage.cfg from board specific folder is used
Changes in v2:
- Disable the dcache. Currently the network driver (mvgbe.c) and USB
- EHCI driver (ehci-marvell.c) and possibly others rely on the data
- cache being disabled.
Thanks.
Thanks, Stefan
Changes in v2:
While collecting the queued fixes for the upcoming release, I do have one question regarding this Kirkwood cache issue (I don't have such a board here, so I can't test anything):
Do we need this patch applied [1], if the patch from this thread is applied [2]?
Thanks, Stefan
[1] http://patchwork.ozlabs.org/patch/1048863/ [2] http://patchwork.ozlabs.org/patch/1057716/
Changes in v2:
to 1.8V */
kernel */
Thanks, Stefan
I'm pretty sure you just need [2]. I've tested with just that on it's own and Ethernet works on the kirkwood db. Functionally it's the same change as Michael's just for more boards.
Leigh, can you see if [2] above works for you?
On 19.03.19 09:00, Chris Packham wrote:
On Tue, 19 Mar 2019, 8:39 PM Stefan Roese, <sr@denx.de mailto:sr@denx.de> wrote:
On 18.03.19 08:51, Chris Packham wrote: > Prior to commit 93b283d49f93 ("ARM: CPU: arm926ejs: Consolidate cache > routines to common file") the kirkwood boards didn't have and dcache > support. The network and usb drivers rely on this. Set > CONFIG_SYS_DCACHE_OFF in the Kirkwood specific config.h. > > Reported-by: Leigh Brown <leigh@solinno.co.uk <mailto:leigh@solinno.co.uk>> > Signed-off-by: Chris Packham <judge.packham@gmail.com <mailto:judge.packham@gmail.com>> > --- > > Changes in v2: > - expand the comment in config.h to provide more info > > arch/arm/mach-kirkwood/include/mach/config.h | 6 ++++++ > 1 file changed, 6 insertions(+) > > diff --git a/arch/arm/mach-kirkwood/include/mach/config.h b/arch/arm/mach-kirkwood/include/mach/config.h > index fcd903887bff..aea60688c2d3 100644 > --- a/arch/arm/mach-kirkwood/include/mach/config.h > +++ b/arch/arm/mach-kirkwood/include/mach/config.h > @@ -26,6 +26,12 @@ > #define CONFIG_KIRKWOOD_EGIGA_INIT /* Enable GbePort0/1 for kernel */ > #define CONFIG_KIRKWOOD_RGMII_PAD_1V8 /* Set RGMII Pad voltage to 1.8V */ > #define CONFIG_KIRKWOOD_PCIE_INIT /* Enable PCIE Port0 for kernel */ > +/* > + * Disable the dcache. Currently the network driver (mvgbe.c) and USB > + * EHCI driver (ehci-marvell.c) and possibly others rely on the data > + * cache being disabled. > + */ > +#define CONFIG_SYS_DCACHE_OFF While collecting the queued fixes for the upcoming release, I do have one question regarding this Kirkwood cache issue (I don't have such a board here, so I can't test anything): Do we need this patch applied [1], if the patch from this thread is applied [2]? Thanks, Stefan [1] http://patchwork.ozlabs.org/patch/1048863/ [2] http://patchwork.ozlabs.org/patch/1057716/
Patch [1] from Leigh also removes icache_enable() in arch/arm/mach-kirkwood/cpu.c.
Not sure if this is still needed? Did any of you run into issues with [1] not applied but with CONFIG_SYS_DCACHE_OFF set?
Thanks, Stefan
Hi Stefan,
cache > routines to common file") the kirkwood boards didn't have and dcache > support. The network and usb drivers rely on this. Set > CONFIG_SYS_DCACHE_OFF in the Kirkwood specific config.h. > > Reported-by: Leigh Brown <leigh@solinno.co.uk mailto:leigh@solinno.co.uk> > Signed-off-by: Chris Packham <judge.packham@gmail.com mailto:judge.packham@gmail.com> > --- > > Changes in v2: > - expand the comment in config.h to provide more info > > arch/arm/mach-kirkwood/include/mach/config.h | 6 ++++++ > 1 file changed, 6 insertions(+) > > diff --git a/arch/arm/mach-kirkwood/include/mach/config.h b/arch/arm/mach-kirkwood/include/mach/config.h > index fcd903887bff..aea60688c2d3 100644 > --- a/arch/arm/mach-kirkwood/include/mach/config.h > +++ b/arch/arm/mach-kirkwood/include/mach/config.h > @@ -26,6 +26,12 @@ > #define CONFIG_KIRKWOOD_EGIGA_INIT /* Enable GbePort0/1 for kernel */ > #define CONFIG_KIRKWOOD_RGMII_PAD_1V8 /* Set RGMII Pad voltage to 1.8V */ > #define CONFIG_KIRKWOOD_PCIE_INIT /* Enable PCIE Port0 for kernel */ > +/* > + * Disable the dcache. Currently the network driver (mvgbe.c) and USB > + * EHCI driver (ehci-marvell.c) and possibly others rely on the data > + * cache being disabled. > + */ > +#define CONFIG_SYS_DCACHE_OFF
is applied [2]?
When the cache consolidation patch was applied, it added code to enable the icache much earlier in the process. Therefore, this line of code to enable it became superfluous (assuming enabling the icache multiple times does nothing).
I'd suggest removing it if you agree with that statement, to reduce possible future confusion.
Thanks, Stefan
Regards,
Leigh.
Hi Leigh,
On 19.03.19 10:29, Leigh Brown wrote:
<snip>
is applied [2]?
You mean to remove the icache_enable() call in arch/arm/mach-kirkwood/cpu.c? Yes, with your explanation above I agree with it. Unfortunately your patch also sets CONFIG_SYS_DCACHE_OFF for dreamplug which is not needed any more with Chris's generic approach for Kirkwood. Also I find your patch subject:
Commit "ARM: CPU: arm926ejs: Consolidate cache routines to common file" breaks u-boot on Dreamplug
not optimal. Could you please send a new patch with a short subject and a small commit message with the background (icache is enabled earlier in the common code now) to the list? That would be great.
Thanks, Stefan
Applied to u-boot-marvell/master.
Thanks, Stefan
Chris Packham
Leigh Brown
Stefan Roese
